January 2024 Windows 11 23H2 and Windows 11 22H2 Non-Security Update
Started by Corrine, January 23, 2024, 11:25:25 PM
Microsoft released KB5034204 (OS Builds 22621.3085 and 22631.3085) today for Windows 11 23H3 and Windows 11 22H2.
IMPORTANT: After February 2024, there are no more optional, non-security preview releases for Windows 11, version 22H2. Only cumulative monthly security updates (known as the "B" or Update Tuesday release) will continue for this version. Windows 11, version 23H2 and Windows 10, version 22H2 will continue to receive security and optional releases.
Highlights included in the update:
  • This update addresses an issue that stops search from working on the Start menu for some users. The issue occurs because of a deadlock.
  • This update addresses an issue to make video calls more reliable.
  • This update addresses an issue that causes your device to stop responding. This is intermittent and occurs after you install a print support app.
  • This update addresses an issue that makes the troubleshooting process fail. This occurs when you use the Get Help app.
  • This update addresses an issue that affects the File Explorer Gallery. It stops you from closing a tooltip.
  • This update addresses an issue that affects Bluetooth Low Energy (LE) Audio earbuds. They lose sound when you stream music.
  • This update addresses an issue that affects a Bluetooth phone call. It stops the audio from routing through the PC when you answer the call on your PC.
See the KB article for a separate list of quality improvements included in the update for Windows 11 23H3 and Windows 11 22H2.
References:
Windows 11 update history
