Windows 11 Insider Release Preview Channel
Started by Corrine, September 23, 2021, 05:53:19 PM
Releasing Windows 11 Build 22621.457 to the Release Preview Channel
This non-security update KB5016695 includes quality improvements. Key changes include:
  • New! We enhanced Microsoft Defender for Endpoint's ability to identify and intercept ransomware and advanced attacks.
  • New! We compressed a file regardless of its size if you have configured Server Message Block (SMB) Compression.
  • New! We improved storage replication that occurs over low bandwidth or congested wide area networks (WAN).
  • New! You can now view the usage history for the following resources from the Settings page:
  • Camera
  • Microphone
  • Phone Calls
  • Messaging
  • Contacts
  • Screenshots and apps
  • Music library
To use this feature, navigate to Settings >Privacy & Security
  • We fixed an issue that causes Windows to display tablet mode features for some devices that do not have touchscreens.
  • We fixed an issue that causes some application windows to have blank sections in the Task View preview.
  • We fixed an issue that occurs for some of you when you copy files from network drives. The error code is 0x80070026.
  • We fixed an issue that might cause the Local Security Authority Server Service (LSASS) to leak tokens. This issue affects devices that have installed Windows updates dated June 14, 2022 or later. This issue occurs when the device performs a specific form of service for user (S4U) in a non-Trusted Computing Base (TCB) Windows service that runs as Network Service.
  • We fixed an issue that, in certain cases, causes sihost.exe to use a high amount of the CPU.
  • We fixed an issue that causes Microsoft Edge to stop responding when you use IE mode. This issue also prevents you from interacting with a dialog. 40242609
  • We fixed an issue that causes the App-V client service to leak memory when you delete App-V registry nodes.
  • We fixed an issue that prevents you from opening a URL if the URL's length is more than 2084 characters. This update supports a URL of up to 8192 characters.
  • We fixed an issue that prevents codecs from being updated from the Microsoft Store.
  • We fixed an issue that causes ServerAssignedConfigurations to be null in a few full configuration scenarios.
  • We fixed an issue that sometimes prematurely interrupts the resizing operations of a Snap Assist area.
  • We fixed an issue that might cause the deployment of the Windows Hello for Business certificate to fail in certain circumstances after you reset a device.
  • We fixed an issue that prevents you from reinstalling Universal Printers after you remove them.
  • We fixed an issue that prevents non-Windows devices from authenticating when they connect to a Windows-based remote desktop and use a smart card as the authentication method.
  • We fixed an issue that causes the Settings app to stop working on server domain controllers (DCs) when accessing the Privacy > Activity history page.
  • We fixed an issue that affects a lookup for a nonexistent security ID (SID) from the local domain using read-only domain controller (RODC). The lookup unexpectedly returns the STATUS_TRUSTED_DOMAIN_FAILURE error instead of STATUS_NONE_MAPPED or STATUS_SOME_MAPPED.
  • We fixed an issue that prevents the Storage Migration Service (SMS) from completing the inventory on servers that have many shares. Error event 2509 appears in Microsoft-Windows-StorageMigrationService/Admin channel (ErrorId=-2146233088/ErrorMessage="Invalid table id").
  • We fixed an issue that affects the Sync across your devices option under Settings > System > Clipboard. The option will not remain enabled.
Releasing Windows 11 Build 22000.1041 to the Release Preview Channel
This update includes the following improvements:
  • New! We introduced WebAuthn redirection. It lets you authenticate in apps and on websites without a password when you use Remote Desktop. Then, you can use Windows Hello or security devices, such as Fast Identity Online 2.0 (FIDO2) keys.
  • New! We added more dynamic Widgets content to your taskbar with notification badging. When you open the Widgets board, a banner appears at the top of the board. It provides more information about what triggered the notification badge.
  • We fixed an issue that requires you to reinstall an app if the Microsoft Store has not signed that app. This issue occurs after you upgrade to a newer OS.
  • We fixed an issue that stops codecs from being updated from the Microsoft Store.
  • We fixed a race condition in framework autorepair registration. This issue occurs because a registration key is missing.
  • We fixed an issue that affects the Network Policy Server Management (NPSM) service. This issue causes major delays when you sign out.
  • We fixed an issue that affects the Windows Search service. Indexing progress is slow when you use the service.
  • We fixed an issue that affects cached credentials for security keys and FIDO2 authentications. On hybrid domain-joined devices, the system removes these cached credentials.
  • We fixed an issue that affects a network's static IP. The issue causes the configuration of the static IP to be inconsistent. Because of this, NetworkAdapterConfiguration() fails sporadically.
  • We fixed a rare stop error that happens after you change the display mode and more than one display is in use.
  • We fixed an issue that affects rendering in Desktop Window Manager (DWM). This issue might cause your device to stop responding in a virtual machine setting when you use certain video graphics drivers.
  • We fixed an issue that affects graphics drivers that use d3d9on12.dll.
  • We fixed an issue that affects URLs generated by JavaScript: URLs. These URLs do not work as expected when you add them to the Favorites menu in IE mode.
  • We fixed an issue that forces the IE mode tabs in a session to reload.
  • We fixed an issue that successfully opens a browser window in IE mode to display a PDF file. Later, browsing to another IE mode site within the same window fails.
  • We fixed an issue that affects window.open in IE mode.
  • We introduced a Group Policy that enables and disables Microsoft HTML Application (MSHTA) files.
  • We fixed an issue that affects the Microsoft Japanese input method editor (IME). Text reconversion fails when you use some third-party virtual desktops.
  • We fixed an issue that occurs when the input queue overflows. This might cause an application to stop responding.
  • We fixed an issue that might cause a black screen to appear on your display. This might occur when you use a pen to turn on high dynamic range (HDR).
  • We fixed an issue that affects the App-V client service. The service leaks memory when you delete App-V registry nodes.
  • We fixed an issue that might change the default printer if the printer is a network printer.
  • We fixed an issue that affects WDAC policies. If you enable SecureLaunch on a device, WDAC policies will not apply to that device.
  • We fixed an issue that affects Windows Defender Application Control (WDAC) path rules. This issue stops .msi and PowerShell scripts from running.
  • We fixed an issue that might bypass MSHTML and ActiveX rules for WDAC.
  • We fixed an issue that causes WDAC to log 3091 and 3092 events in audit mode.
  • We fixed an issue that affects Windows Defender Application Control (WDAC). It stops WDAC from logging .NET Dynamic Code trust verification failures.
  • We fixed an issue that occurs when a WDAC policy fails to load. The system logs that failure as an error, but the system should log the failure as a warning.
  • We fixed an issue that affects Code Integrity logging. It logs issues as errors instead of warnings. Because of this, automatic repair is triggered.
  • We fixed an issue that affects the touch keyboard. The touch keyboard immediately closes when you tap to switch apps.
  • We fixed an issue that causes LogonUI.exe to stop working. Because of this, you cannot dismiss the lock screen to view the credentials screen.
  • We fixed an issue that affects the FindNextFileNameW() It might leak memory.
  • We fixed an issue that affects robocopy. Robocopy fails to set a file to the right modified time when using the /IS
  • We fixed an issue that affects cldflt.sys. A stop error occurs when it is used with Microsoft OneDrive.
  • We fixed an issue that affects the LanmanWorkstation service. When you mount a network drive, the service leaks memory.
  • We fixed an issue that affects the Get-SmbServerNetworkInterface It only retrieves a subset of the available network interfaces.
  • We fixed an issue that affects the Get-SmbServerConfiguration It only allows you to run it if you are an administrator.
  • We fixed an issue that affects Roaming User Profiles. After you sign in or sign out, some of your settings are not restored.
  • We fixed a known issue that affects XML Paper Specification (XPS) viewers. This might stop you from opening XPS files in some non-English languages. These include some Japanese and Chinese character encodings. This issue affects XPS and Open XPS (OXPS) files.
  • We fixed a known issue that affects daylight saving time in Chile. This issue might affect the time and dates used for meetings, apps, tasks, services, transactions, and more.
Releasing Windows 11 Build 22621.607 to the Release Preview Channel
  • We fixed an issue that affects some apps that were not signed by the Microsoft Store. You must reinstall them after you upgrade the OS.
  • We fixed issues that cause updates to the Microsoft Store to fail.
  • We fixed an issue that stops you from signing in to various Microsoft Office 365 apps. This affects Outlook, Word, Teams, and so on.
  • We updated the start date for daylight saving time in Chile. It will start on September 11, 2022 instead of on September 4, 2022.
  • We fixed an issue that affects the Windows Search service. It causes the indexing progress for the service to be slow.
  • We fixed an issue that affects some processors. This issue occurs when you turn on Hyper-V and kernel Direct Memory Access (DMA) protections.
  • We fixed an issue that affects Task Manager. It stops working when you switch between light and dark mode or change the accent color.
  • We fixed an issue that affects the font of three Chinese characters. When you format these characters as bold, the width size is wrong.
  • We reduced the power that the Dynamic Host Configuration Protocol uses on some devices when they are in Sleep mode.
  • We fixed an issue that affects window. Open in IE mode.
  • We fixed an issue that might cause an application to stop responding. This might occur when the input queue overflows.
  • We fixed an issue that affects XML Paper Specification (XPS) viewers. This might stop you from opening XPS files in some non-English languages. These include some Japanese and Chinese character encodings. This issue affects XPS and Open XPS (OXPS) files.
  • We fixed an issue that creates a duplicate print queue. Because of this, the original print queue stops working.
  • We fixed an issue that might bypass MSHTML and ActiveX rules for Windows Defender Application Control (WDAC).
  • We fixed an issue that affects the Miracast UI. Sometimes it closes too soon when you cast to devices that use the DeviceObjectType:Aep.
  • We added more dynamic Widgets content to your taskbar with notification badging. When you open the Widgets board, a banner appears at the top of the board. It provides more information about what triggered the notification badge.
  • We fixed an issue that affects the SharedPC account manager. The issue stops it from deleting many accounts during cleanup.
  • We fixed an issue that affects Dual SIM calling. If you select no SIM on your phone and initiate a call on your device, Dual SIM functionality does not work.
  • We fixed an issue that affects the LanmanWorkstation service. It leaks memory when you mount a network drive.
Rolling out new features for Windows 11, version 22H2 in the Release Preview Channel
  • New! We enhance File Explorer. It now includes tabs to help you organize your File Explorer sessions like you do in Microsoft Edge. On the new File Explorer homepage, you can pin important files for quick and easy access. Using the power of Microsoft OneDrive, you can view your colleagues' actions on your shared files. We also provide personalized suggestions based on your Microsoft 365 account.
  • New! We add suggestions for actions when you copy items. For example, when you copy phone numbers or future dates, we provide suggestions, such as make a call with Teams or Skype or add an event in the Calendar app.
  • New! We add a taskbar overflow menu. The taskbar will offer an entry point to a menu that shows you all your overflowed apps in one space.
  • New! You can now share to more devices. You can discover and share to more devices, including desktops, using a nearby share.
NOTE: Not all Insiders will see these new features right away as we monitor feedback before pushing them out to more Insiders.
Releasing Windows 11 Build 22621.675 to the Release Preview Channel
This update enables the following new features that began rolling out to Insiders in Release Preview on Windows 11, version 22H2, last week:
  • New! We add a feature called Suggested Actions for items that you copy. This is available for customers in the United States, Canada, and Mexico. For example, when you copy phone numbers or future dates, we provide suggestions, such as make a call with Teams or Skype or add an event in the Calendar app.
  • New! You can now share to more devices. You can discover and share to more devices, including desktops, using a nearby sharing.
Releasing Windows 11 Build 22000.1163 to the Release Preview Channel
  • New! We added improvements to Windows search results and performance.
  • New! We added Task Manager to the context menu when you right-click the taskbar. This feature rolls out in the coming weeks.
  • We fixed an issue that affects Distributed Component Object Model (DCOM) authentication hardening. We will automatically raise the authentication level for all non-anonymous activation requests from DCOM clients to RPC_C_AUTHN_LEVEL_PKT_INTEGRITY. This occurs if the authentication level is below Packet Integrity.
  • We fixed a DCOM issue that affects the Remote Procedure Call Service (rpcss.exe). We raise the authentication level to RPC_C_AUTHN_LEVEL_PKT_INTEGRITY instead of RPC_C_AUTHN_LEVEL_CONNECT if RPC_C_AUTHN_LEVEL_NONE is specified.
  • We fixed an issue that affects the Microsoft Azure Active Directory (AAD) Application Proxy connector. It cannot retrieve a Kerberos ticket on behalf of the user. The error message is, "The handle specified is invalid (0x80090301)."
  • We fixed an issue that affects scheduled Native Image Generator (Ngen.exe) tasks on devices that have certain processors.
  • We fixed an issue that affects certificate mapping. When it fails, lsass.exe might stop working in schannel.dll.
  • We fixed an issue that causes an OS upgrade to stop responding, and then it fails.
  • We fixed an issue that affects a task you schedule to run every two weeks. It runs every week.
  • We fixed an issue that affects Microsoft Direct3D 9 games. The graphics hardware stops working if the hardware does not have a native Direct3D 9 driver.
  • We fixed graphical issues in games that use Microsoft D3D9 on some platforms.
  • We fixed an issue that affects Microsoft Edge when it is in IE Mode. The titles of pop-up windows and tabs are wrong.
  • We fixed an issue that affects Microsoft Edge IE mode. It stops you from opening webpages. This occurs when you enable Windows Defender Application Guard (WDAG) and you do not configure Network Isolation policies.
  • We fixed an issue that affects input method editors (IME) from Microsoft and third parties. They stop working when you close the IME window. This occurs if the IME uses Windows Text Services Framework (TSF) 1.0.
  • We fixed an issue that affects the lasso tool in a graphics editing program.
  • We fixed an issue that affects a universal printer. You cannot reinstall it after you remove it.
  • We fixed an issue that affects some drivers. They use more power when you play hardware-protected digital rights management (DRM) content.
  • We fixed an issue that affects driver installation on certain hardware. You cannot see the display of the progress of the installation.
  • We fixed an issue that affects the Clipchamp application that is in the Windows 11 SE edition. Clipchamp will not run.
  • We fixed an issue that affects .msi files. Windows Defender Application Control (WDAC) will ignore them when you disable script enforcement.
  • We fixed an issue that affects a remote desktop virtual desktop infrastructure (VDI) scenario. The session might use the wrong time zone.
  • We fixed an issue that affects File Explorer on a remote desktop (RD) session host. File Explorer stops working. This occurs when a non-Windows client connects to a Windows 11 RD session host, and you enable the Time Zone Redirection policy.
  • We fixed an issue that affects the button style BS_PUSHLIKE. Buttons that have this style are difficult to identify against a dark background.
  • We fixed an issue in that stops the credentials UI from displaying in IE mode when you use Microsoft Edge.
  • We fixed an issue that affects Server Manager. It might reset the wrong disk when several disks have the same UniqueId.
Releasing Windows 11 Build 22621.754 to the Release Preview Channel
  • New! We added a new consent form for those of you enrolled in Windows Hello Face and Fingerprint. You have new choices for your biometric data. You can keep storing your biometric data or open Settings to delete the data if you have not used your face or fingerprint for authentication in over 365 days. You also have these options if you upgraded to Windows 11 and have not yet seen the new Hello Learn More Privacy text.
  • New! We added improvements to the Microsoft Account experience in Settings. For instance, you can manage your Microsoft One Drive subscription and related storage alerts.
  • New! We enhanced search visual treatments on the taskbar to improve discoverability. This is available to a small audience initially and deploys more broadly in the months that follow. Some devices might notice different visual treatments as we gather feedback. To learn more about why you might be seeing these changes, see Search for anything, anywhere.
  • New! We enhance the backup experience when using your Microsoft Account (MSA). Some devices might notice visual treatments for this enhancement. This is available to a small audience initially and deploys more broadly in the months that follow.
  • We enabled the ms-appinstaller Uniform Resource Identifier (URI) to work for the DesktopAppInstaller.
  • We will not start daylight saving time in Jordan at the end of October 2022.
  • We fixed an issue that affects cached credentials for security keys and Fast Identity Online 2.0 (FIDO2) authentications. On hybrid domain-joined devices, the system removes these cached credentials.
  • We fixed an issue that might affect some types of Secure Sockets Layer (SSL) and Transport Layer Security (TLS) connections. These connections might have handshake failures. For developers, the affected connections are likely to send multiple frames followed by a partial frame with a size of less than 5 bytes within a single input buffer. If the connection fails, your app will receive the error, "SEC_E_ILLEGAL_MESSAGE".
  • We fixed an issue that affects title bars when you use third-party tools to customize them. The title bars did not render. This update ensures that title bars render; however, we cannot guarantee all text customizations will work as before.
  • We fixed an issue that might cause vertical and horizontal line artifacts to appear on the screen.
  • We fixed an issue that might fail to sync the audio when you record game play using the Xbox Game Bar.
  • We updated DriverSiPolicy.p7b for the Windows kernel vulnerable driver blocklist. This update includes drivers that are vulnerable to Bring Your Own Vulnerable Driver (BYOVD) attacks.
  • We extended original equipment manufacturer (OEM) control of Hypervisor-protected Code Integrity (HVCI) enforcement for targeted hardware configurations.
  • We fixed an issue that affects File Explorer. It is less dependable when you browse for Microsoft OneDrive folders.
  • We fixed an issue in that stops the credential UI from displaying in IE mode when you use Microsoft Edge.
  • We address an issue that affects the CopyFile function. It returns ERROR_INVALID_HANDLE instead of ERROR_FILE_NOT_FOUND when it is called with an invalid source file.
  • We fixed an issue that affects the Start menu. It stops working when you use keyboard commands to move pinned items to a folder at the end of a list.
Releasing Windows 11 Build 22621.898 to the Release Preview Channel
  • New! We gave Microsoft OneDrive subscribers storage alerts on the Systems page in the Settings app. The alerts appear when you are close to your storage limit. You can also manage your storage and purchase additional storage, if needed.
  • New! We provided the full amount of storage capacity from all your OneDrive subscriptions. It also displays the total storage on the Accounts page in the Settings app.
  • New! We combined Windows Spotlight with Themes on the Personalization page. This makes it easier for you to discover and turn on the Windows Spotlight feature.
  • New! We added the organizational messages feature. With it, third-party companies can now provide content to their employees. They do not need to use the default behavior of Windows.
  • We fixed an issue that affected some modern applications. It stopped them from opening.
  • We fixed an issue that affected some devices that are managed by an enterprise. We improved the reliability of app installations for them.
  • We fixed an issue that affected daylight saving time (DST) in the Republic of Fiji. It canceled DST for 2022.
  • We fixed an issue that affected Distributed Component Object Model (DCOM) authentication hardening. We will automatically raise the authentication level for all non-anonymous activation requests from DCOM clients to RPC_C_AUTHN_LEVEL_PKT_INTEGRITY. This occurs if the authentication level is below Packet Integrity.
  • We fixed an issue that affected Unified Update Platform (UUP) on-premises customers. It removed the block that stopped them from getting offline language packs.
  • We fixed an issue that affected process creation. It failed to create security audits for it and other related audit events.
  • We fixed an issue that affected cluster name objects (CNO) or virtual computer objects (VCO). Password reset failed. The error message was, "There was an error resetting the AD password... // 0x80070005".
  • We fixed an issue that affected transparency in layered windows. This occurred when you were in High Definition remote applications integrated locally (RAIL) mode.
  • We fixed an issue that affected certain applications. They stopped working. This occurred when you used keyboard shortcuts to change the input mode for the Japanese Input Method Editor (IME).
  • We fixed an issue that affected microphone streams that used the Listen To feature to route to the speaker endpoint. The microphone stopped working after you restarted the device.
  • We fixed an issue that might have affected applications that run on the Windows Lock Down Policy (WLDP). They might have stopped working.
  • We fixed an issue that affected Microsoft Defender when it is not the primary antivirus. Microsoft Defender failed to turn off passive mode. This issue occurred when you turned off Smart App Control (SAC).
  • We added .wcx to the list of Dangerous Extensions that some app control policies do not allow.
  • We fixed an issue that affected Microsoft Defender for Endpoint. Automated investigation blocked live response investigations.
  • We fixed an issue that affected printing in landscape mode in Microsoft Edge. The print output was incorrect. This issue occurred when you used Microsoft Defender Application Guard.
  • We fixed an issue that caused File Explorer to stop working. This occurred when you closed context menus and menu items.
  • We fixed an issue that might have caused certain apps to stop responding. This occurred when you opened the Open File dialog.
  • We fixed an issue that sometimes affected File Explorer when you opened a file. Because of this, there was high CPU usage.
  • We fixed an issue that affected protocol activation of the Settings app. The app failed to open a page under the Accounts category.
  • We fixed an issue that affected a computer account. Use of non-standard characters stopped the cleanup of the Out of Box Experience (OOBE) accounts.
  • We fixed an issue that affected the CopyFile It might have sometimes returned error 317: ERROR_MR_MID_NOT_FOUND.
Releasing Windows 11 Build 22621.1192 to the Release Preview Channel
Note: This Build is for Windows Insider in the Release Preview Channel on Windows 11, version 22H2.
Starting this month, when customers upgrade to Windows 11, version 22H2, they will get the January optional quality update (KB5022360) and the .NET update alongside the Feature Update. This means when you upgrade to Windows 11, version 22H2 you will get the feature update with the latest and greatest security fixes for both Windows and .NET– all with only a single reboot!
  • New! We changed the experience for preview .NET Framework updates. After you installed this update, all future preview (optional) .NET Framework updates will be displayed on the Settings > Windows Update > Advanced options > Optional updates page. On that page, you could control which optional updates you wanted to install.
  • We fixed an issue that affected searchindexer.exe. It randomly stopped you from signing in or signing out.
  • We fixed an issue that stopped you from searching for a file based on the file's contents.
  • We fixed a resource conflict issue between two or more threads (known as a deadlock). This deadlock affected COM+ applications.
  • We fixed an issue that affected conhost.exe. It stopped responding.
  • We fixed an issue that might have affected the Domain Name System (DNS) suffix search list. When you configured it, the parent domain might have been missing.
  • We fixed an issue that might have occurred when the Input Method Editor (IME) was active. Applications might have stopped responding when you used the mouse and keyboard at the same time.
  • We fixed an issue that might have affected FindWindow() or FindWindowEx(). They might have returned the wrong window handle.
  • We fixed an issue that might have occurred when you converted or reconverted Japanese Kanji using a multibyte character set (MBCS) app. The cursor might have moved to the wrong location when you typed.
  • We fixed an issue that might have affected applications that used Microsoft Edge WebView2 to display content. Applications that used WebView2 included Microsoft Office and the Widgets app. The content might have appeared blank or greyed out.
  • We fixed an issue that affected certain systems that had firmware Trusted Platform Modules. (TPM). This issue stopped you from using AutoPilot to set up those systems.
  • We fixed an issue that affected picture files you found using search on the taskbar. This issue stopped you from opening those pictures.
  • We fixed an issue that affected mstsc.exe. It stopped responding while connecting to a RemoteApp and Desktop Connection.
  • We fixed an issue that affected a Group Policy for Expanded Toasts.
  • We fixed an issue that caused Windows Server 2022 domain controllers (DC) to stop responding. This occurred when they processed Lightweight Directory Access Protocol (LDAP) requests.
  • We fixed an issue that affected the Resilient File System (ReFS) MSba tag. The issue caused a nonpaged pool leak.
  • We fixed an issue that affected the ReFS. The issue caused high nonpaged pool usage, which depleted system memory.
  • We fixed an issue that affected devices that were subject to Microsoft Exploit Protection Export Address Filtering (EAF). Some applications stopped responding or did not open. These included Microsoft Office and Adobe Reader.
  • We fixed an issue that affected some game controllers. When the game controller was connected to the computer, the computer might not have gone to Sleep mode.
Releasing Windows 11 Build 22000.1515 to the Release Preview Channel
Note: This Build is for Windows Insiders in the Release Preview Channel on Windows 11 (original release).
  • New! We combined Windows Spotlight with Themes on the Personalization page. This made it easier for you to discover and turn on the Windows Spotlight feature.
  • New! We improved the Microsoft Account experience in Settings. For example, you could manage OneDrive subscriptions and storage alerts.
  • New! We provide the full amount of storage capacity of all your OneDrive subscriptions. It also displayed the total storage on the Accounts page in the Settings app.
  • New! We displayed storage alerts for Microsoft OneDrive subscribers on the Systems page in the Settings app. The alerts appeared when you were close to your storage limit. You could also manage your storage and purchase additional storage, if needed.
  • New! We displayed Xbox subscription details on the Accounts page in the Settings app. Xbox subscribers could also manage their subscription on that page. Users who are not subscribers could explore Xbox subscription options on the Accounts page
  • We fixed an issue that affected some modern applications. This issue stopped them from opening.
  • We fixed an issue that affected the Domain Name System (DNS) suffix search list. When you configured it, the parent domain might have been missing.
  • We added support for long URL lengths of up to 8196 characters.
  • We fixed an issue that damaged memory. The issue occurred when you used certain HD audio controller hardware.
  • We fixed an issue the stopped the touch keyboard from opening.
  • We fixed an issue that stopped explorer.exe from responding. This issue occurred when you used the play and pause buttons on your keyboard on certain devices.
  • We fixed an issue that affected Windows Server 2022 domain controllers. They stopped responding when they managed Lightweight Directory Access Protocol (LDAP) requests.
  • We fixed an issue that affected ReFS. The issue caused high nonpaged pool usage, which depleted system memory.
Releasing Windows 10 Build 19045.2670 to Release Preview Channel
  • We fixed an issue that stopped hyperlinks from working in Microsoft Excel.
  • We fixed an issue that affected the Appx State Repository. When you removed a user profile, the cleanup was incomplete. Because of that, its database grew as time passes. This growth might have caused delays when users signed into multi-user environments like FSLogix.
  • We provided support for the United Mexican States' daylight-saving time change order for 2023.
  • We fixed an issue that affected IE mode. The text on the status bar was not always visible.
  • We fixed an issue that affected cbs.log. This issue logged messages that were not error messages in cbs.log.
  • We improved how the Remove-Item cmdlet worked for Microsoft OneDrive folders.
  • We fixed an issue that affected AppV. It stopped file names from having the correct letter case (uppercase or lowercase).
  • We fixed an issue that affected Microsoft Edge. The issue removed conflicting policies for Microsoft Edge. This occurred when you set the MDMWinsOverGPFlag in a Microsoft Intune tenant and Intune detected a policy conflict.
  • We fixed an issue that affected Azure Active Directory (Azure AD). Using a provisioning package for bulk provisioning failed.
  • We fixed an issue that affected a certain streaming app. The issue stopped video playback after an advertisement played in the app.
  • We fixed an issue that affected MSInfo.exe. It did not correctly report the enforcement status of the Windows Defender Application Control (WDAC) user mode policy.
  • We fixed accessibility issues. They affected Narrator on the Settings home page.
  • We fixed an issue that affected the Local Security Authority Subsystem Service (LSASS). LSASS might have stopped responding after you ran Sysprep on a domain-joined machine.
  • We fixed an issue that affected virtual machines (VM). They stopped responding when you added a new disk to a storage pool in thin provisioning scenarios.
Releasing Windows 11 Build 22621.1343 to the Release Preview Channel
This update includes the following features and improvements:
  • New! This update provided access Windows Studio effects directly from quick settings on the taskbar for devices that had a supported neural processing unit (NPU). This made it quick and easy to turn on and configure camera effects. Those effects included Background blur, Eye contact, Automatic framing, and Audio effects (Voice focus). You can still access these effects in the Settings pages.
  • New! This update made it easier to get help if you were having PC issues. It added a link to the Quick Assist app at the bottom of Settings > System > Troubleshooters. You could also find Quick Assist in the Start menu's All apps list.
  • New! This update improved the search box experience on the taskbar. As you typed in the search box, search results appeared in the search box. You could also change the search experience you wanted for your taskbar by going to Settings > Personalization > Taskbar. For commercial customers, this update added a new policy for IT administrators to manage how the search box on the taskbar appears in your organization. For more information, see Customizing search on the Windows 11 taskbar.
  • New! This update provided energy recommendations. If you used them, they could help to improve the energy efficiency of your PC and reduce your carbon footprint. Go to Settings > System > Power & Battery > Energy Recommendations.
  • New! This update enhanced the system tray (formerly called the notification area). All icons had a rounded focus and hover treatment in the lower right, including the "Show hidden icons" flyout menu. You could move icons to rearrange them in the "Show hidden icons" flyout menu or move icons to the taskbar.
  • New! This update introduced a touch-optimized taskbar for 2-in-1 devices that you could use as a tablet. There were two states of this taskbar: collapsed and expanded. To switch between the two states, swipe up and down on the bottom of your screen. When collapsed in tablet mode, the taskbar receded to give you more screen space and kept you from accidentally opening the taskbar. When expanded in tablet mode, the taskbar was optimized to be easier to use with touch. Your taskbar automatically changed to this optimized version when you disconnected or folded back the keyboard.
    • This feature only worked on devices that could be used as tablets and was on by default. To change that, go to Settings > Personalization > Taskbar > Taskbar behaviors. The setting is called "Optimize taskbar for touch interactions when this device is used as a tablet." If your company manages Windows updates for your device, this feature will be off by default. Administrators can turn it on using the new commercial control for continuous innovation.
  • New! This update provided enhanced support for braille devices. They continued working while you switched between Microsoft Narrator and third-party screen readers. Narrator automatically changed braille drivers. For more information, see Chapter 8: Using Narrator with braille.
  • New! This update also added support for new braille displays and new braille input and output languages in Narrator. Some of the new braille displays included the APH Chameleon, the APH Mantis Q40, the NLS eReader, and many more. For more information, see Chapter 8: Using Narrator with braille.
  • New!This update made voice access more flexible and supported interaction with more user interface (UI) controls. For example, voice interacted with controls that contained:
    • Names that had numbers, such as "Click 5"
    • Names without whitespaces between them, such as "click PivotTable" or "click PivotChart"
    • Names that had special characters, such as Bluetooth & devices ("click Bluetooth and devices") or Dial – up ("click dial hyphen up")
  • New! This update added voice access support for spin controls, thumb controls, and split buttons. You interact with these controls by using the "click" command or number overlays. This update also fixed issues that affected snapping commands that snapped a window left or right. Commands that moved the cursor in a text box ran instantly.
  • New! This update also provided voice scrolling enhancements. You could use voice to scroll to the extreme left and right on a page. You could also use continuous scrolling to the left or right like what is already present for vertical scrolling. For more information about the new voice access commands, see Voice access command list.
  • New! For devices that were joined to Azure Active Directory (AAD), this update provided AI-powered recommended content on your Start menu. On the Start menu, you found content to help you to prepare for meetings, quickly access files you were collaborating on, and more.
  • New! We added the new Tamil Anjal keyboard for the Tamil language. To add it, make sure Tamil (Singapore), Tamil (Malaysia), Tamil (Sri Lanka), or Tamil (India) appears in Settings > Time & Language > Language & Region. Select the ellipses (...) next to the language. Select Language Options. Add Tamil Anjal (QWERTY) to the list of keyboards.
  • We fixed an issue that affected the Color filters setting. When you selected Inverted, the system set it to Grayscale instead.
  • We improved the reliability of Windows after you installed an update.
  • We supported the United Mexican States' daylight-saving time change order for 2023.
  • We fixed a date information issue. It affected the format of dates sent between Windows and some versions of the Heimdal Kerberos library.
  • We fixed compatibility issues that affected some printers. Those printers used Windows Graphical Device Interface (GDI) printer drivers. Those drivers did not completely adhere to GDI specifications.
  • We fixed an issue that affected the software keyboard. It did not appear in the Out-of-Box Experience (OOBE) after a Push-button reset (factory reset). This type of reset required an external keyboard to be attached to provide credentials.
  • We fixed an issue that displayed a blue screen during video playback. This occurred after you set high dynamic range (HDR) on your display.
  • We fixed an issue that might have affected the touch keyboard and the PIN entry keyboard. You might not have been able to use them to enter text when you signed in to your device.
  • We fixed an issue that affected provisioning packages. They failed to apply in certain circumstances when elevation was required.
  • We fixed an issue that affected Universal Print's Configuration Service Provider (CSP). A command prompt window appeared when you installed a printer.
  • We fixed a reliability issue that occurred when you used Task View.
  • We fixed an issue that affected which folders appeared in the Browse for Folder picker.
  • We fixed an issue that affected File Explorer. When you used Shift  +Tab or Shift+F6, the input focus did not move.
  • We fixed an issue that affected the user interface (UI). The volume up and volume down commands from a Bluetooth keyboard did not display.
  • We fixed an issue that affected Xbox subscribers. If you purchased an Xbox subscription using the "Redeem code" option, the Xbox subscription card did not appear on the Settings Accounts page. This occurred when recurring billing was off.
  • We fixed an issue that might have affected lsass.exe. It might have stopped responding. This occurred when it sent a Lightweight Directory Access Protocol (LDAP) query to a domain controller that had a very large LDAP filter.
  • We fixed an issue that affected the Local Security Authority Subsystem Service (LSASS). LSASS might have stopped responding. This occurred after you ran Sysprep on a domain-joined machine.
  • We fixed an issue that affected copying from a network to a local drive. Copying was slower than expected for some users.
  • We fixed an issue that affected parity virtual disks. Using Server Manager to create them failed.
Releasing Windows 11 Build 22000.1757 to the Release Preview Channel
  • This update addresses an issue that affects the command line. It fails when you set the system locale to Japanese and cmd.exe is configured in legacy mode.
  • This update addresses an issue that affects the Notepad box in Settings. It fails to show all the available options.
  • This update addresses an issue that affects Microsoft PowerPoint. It stops responding. This occurs when you use accessibility tools.
  • The update addresses an issue that affects the Remote Procedure Call Service (rpcss.exe). The issue might cause a race condition between the Distributed Component Object Model (DCOM) and the Microsoft Remote Procedure Call (RPC) endpoint mapper.
  • This update affects the ms-appinstaller URI. It now works with the DesktopAppInstaller policy.
  • This update addresses an issue that affects Microsoft PowerPoint. It stops responding on the Azure Virtual Desktop. This occurs while you are using Think-Cell Features.
  • This update addresses an issue that affects Windows Search. Windows Search fails inside of Windows container images.
  • This update addresses an issue that affects the Microsoft HTML Application Host (HTA). This issue blocks code execution that uses Microsoft HTA. This occurs when you turn on Windows Defender Application Control (WDAC) User Mode Code Integrity (UMCI) enforced mode.
  • This update addresses an issue that affects Desired State Configuration. It loses its previously configured options. This occurs if metaconfig.mof is missing.
  • This update addresses compatibility issues that affect some printers. These printers use Windows Graphical Device Interface (GDI) printer drivers. These drivers do not completely adhere to GDI specifications.
  • This update addresses an issue that affects the Simple Certificate Enrollment Protocol (SCEP) certificate. The system reports some SCEP certificate installations as failed. Instead, the system should report them as pending.
  • This update addresses an issue that affects the new Windows Runtime (WinRT) API. This issue stops an application from querying for location information using MBIM2.0+.
  • This update addresses an issue that affects USB printers. The system classifies them as multimedia devices even though they are not.
  • This update addresses an issue that affects the Fast Identity Online 2.0 (FIDO2) PIN credential icon. It does not appear on the credentials screen of an external monitor. This occurs when that monitor is attached to a closed laptop.
  • This update affects the "Set a default associations configuration file" Group Policy Object (GPO). You can now use it to create an extension to specific applications.
  • This update addresses an issue that affects the SharedPC account manager. It cannot delete multiple accounts during cleanup.
  • This update addresses an issue that affects Xbox subscribers. If you purchase an Xbox subscription using the "Redeem code" option, the Xbox subscription card does not appear on the Settings Accounts page. This occurs when recurring billing is off.
  • This update addresses an issue that might affect lsass.exe. It might stop responding. This occurs when it sends a Lightweight Directory Access Protocol (LDAP) query to a domain controller that has a very large LDAP filter.
Releasing Windows 11 Build 22621.1483 to the Release Preview Channel
  • New! This update introduces notifications for Microsoft accounts in the Start menu. This is only available to a small audience right now. It will deploy more broadly in the coming months. Some devices might notice different visual treatments as we gather feedback.
  • New! Once you have access to the new Bing, the search box on the taskbar will include a button that opens the Bing chat experience in Microsoft Edge. If you don't have access, the search box on the taskbar will feature a dynamic search highlight button.
  • New! This update adds many new features and improvements to Microsoft Defender for Endpoint. For more information, see Microsoft Defender for Endpoint.
  • New! The search box on the taskbar will be lighter when you set Windows to a custom color mode. This will occur when you set the Windows mode to dark and the app mode to light in Settings > Personalization > Colors.
  • This update addresses an issue that affects the combo box in Settings. It fails to show all the available options.
  • This update addresses an issue that affects Microsoft Narrator. It fails to read items in dropdown lists in Microsoft Excel.
  • This update addresses an issue that affects complexity policy settings for PINs. They are ignored.
  • This update addresses an issue that affects a Clustered Shared Volume (CSV). The CSV fails to come online. This occurs if you enable BitLocker and local CSV managed protectors, and the system recently rotated the BitLocker keys.
  • This update addresses an issue that affects Active Directory Users & Computers. It stops responding. This occurs when you use TaskPad view to enable or disable many objects at the same time.
  • This update affects the Group Policy Editor. It adds Transport Layer Security (TLS) 1.3 to the list of protocols that you can set.
  • This update affects the Arab Republic of Egypt. The update supports the government's daylight saving time change order for 2023.
  • This update affects jscript9Legacy.dll. It adds ITracker and ITrackingService to stop MHTML from not responding.
  • This update affects the Group Policy Management Console. It addresses a scripting error in the Group Policy Preferences window.
  • This update addresses an issue that affects the Windows Remote Management (WinRM) client. The client returns an HTTP server error status (500). This error occurs when it runs a transfer job in the Storage Migration Service.
  • This update addresses an issue that affects the Dynamic Host Configuration Protocol (DHCP) option 119 – Domain Search Option. The issue stops you from using a connection-specific DNS Suffix Search List.
  • This update addresses a rare issue that might cause an input destination to be null. This issue might occur when you attempt to convert a physical point to a logical point during hit testing. Because of this, the computer raises a stop error.
  • This update addresses a known issue that affects kiosk device profiles. If you have enabled automatic logon, it might not work. After Autopilot completes provisioning, these devices stay on the credential screen. This issue occurs after you install updates dated January 10, 2023, and later.
Releasing Windows 11 Build 22621.1631 to the Release Preview Channel
  • New! This update changes firewall settings. You can now configure application group rules.
  • New!This update adds animations to a few icons on the Widgets taskbar button. These animations turn on when:
    • A new announcement appears on the Widgets taskbar button.
    • You hover over or click the Widgets taskbar button.
  • This update affects the Islamic Republic of Iran. The update supports the government's daylight-saving time change order from 2022.
  • This update addresses an issue that affects the Local Security Authority Subsystem Service (LSASS) process. It might stop responding. Because of this, the machine restarts. The error is 0xc0000005 (STATUS_ACCESS_VIOLATION).
  • This update addresses an issue that affects Microsoft Edge IE mode. The Tab Window Manager stops responding.
  • This update addresses an issue that affects Microsoft Edge IE mode. Pop-up windows open in the background instead of in the foreground.
  • This update addresses an issue that affects protected content. When you minimize a window that has protected content, the content displays when it should not. This occurs when you are using Taskbar Thumbnail Live Preview.
  • This update addresses an issue that affects mobile device management (MDM) customers. The issue stops you from printing. This occurs because of an exception.
  • This update changes the app icons for certain mobile providers.
  • This update addresses an issue that affects signed Windows Defender Application Control (WDAC) policies. They are not applied to the Secure Kernel. This occurs when you enable Secure Boot.
  • This update addresses an issue that displays Task View in the wrong area. This occurs when you close a full screen game by pressing Win+Tab.
  • This update addresses an issue that affects the Chinese input method. You cannot see all of the first suggested item.
  • This update addresses an issue that occurs when you use a PIN to sign in to Windows Hello for Business. Signing in to Remote Desktop Services might fail. The error message is, "The request is not supported".
  • This update addresses an issue that affects Administrator Account Lockout policies. GPResult and Resultant Set of Policy did not report them.
  • This update addresses an issue that affects the Unified Write Filter (UWF). When you turn it off by using a call to Windows Management Instrumentation (WMI), your device might stop responding.
  • This update addresses an issue that affects the Resilient File System (ReFS). A stop error occurs that stops the OS from starting up correctly.
  • This update addresses an issue that affects MySQL commands. The commands fail on Windows Xenon containers.
  • This update addresses an issue that affects SMB Direct. Endpoints might not be available on systems that use multi-byte character sets.
