Microsoft Edge Preview Builds
Started by Corrine, April 08, 2019, 09:49:13 PM
Dev channel update to 99.0.1131.3 is live
Note:  See the referenced link for a number of videos and articles.
Added features:
  • Added the ability to manually set which profile certain websites open in via edge://settings/profiles/multiProfileSettings.
  • Added the ability to edit saved passwords from the initial dialog to save them.
  • Added an option to the right-click menu to open links in new Application Guard windows when Application Guard is available.
  • Added info to the Edge Bar settings page informing users which extensions they have installed that are preventing the use of the Edge Bar.
  • Management policies (note that updates to documentation and administrative templates may not have happened yet):
    • Added a management policy to control if Address Bar Editing is Enabled.
    • Added support on mobile for disabling autofill via management policy.
  • Developer:
    • Added support for custom formats on the clipboard (Chromium Issue 106449).
    • Added support for the WebView2 API BasicAuthenticationRequested, which was previously in the experimental state (Issue 120).
    • Added support for the dual screen web developer APIs CSS Foldables and Viewport Segments that were previously in the Experimental stage.
Dev channel update to 99.0.1135.5 is live
Added features:
  • Added the ability to use Web Capture in PDFs.
  • Added address bar dropdown content when first clicking on the address bar like Edge Legacy had.
  • Added the ability to change the units that the air temperature is shown in on mobile's new tab page.
  • Enabled support for Data Loss Prevention on websites by default.
  • Un-deprecated the management policy to control if the Win Http Proxy Resolver is Enabled, which will be re-deprecated at a later time.
  • Added a management policy to Allow the Games Menu (note that updates to documentation and administrative templates may not have happened yet).
  • Added an experimental WebView2 API for Clearing Browsing Data (Issue 140).
Dev channel update to 99.0.1141.0 is live
Added Features:
  • Added a management policy to control if the Sign In Cta (call to action) On the Ntp (new tab page) is Enabled.  Note that updates to documentation and administrative templates may not have happened yet.
Dev channel update to 99.0.1150.2 is live
Added Features:
  • Added a Setting to control the related matches feature in Find on Page.
  • Enabled support for Password Monitor on iOS.
  • Enabled support for Shopping on Android.
  • Developer:
  • Management policies (note that updates to documentation and administrative templates may not have occurred yet):
    • Added a policy to control if the Related Matches Cloud Service is Enabled, which controls the related matches feature in Find on Page.
    • Added a policy to control the Password Manager Blocklist, which is the list of sites that aren't allowed to save or fill passwords.
    • Added a policy to control if the Hubs Sidebar is Enabled.
    • Added a policy to say Do Not Silently Block Protocols From specific Origins to the external application launcher, which lets certain protocols coming from a defined list of origins bypass protections designed to prevent a flood of application launches.
    • Enabled support for a policy from Chromium to control User Agent Reduction, which controls whether the full or the reduced version of the User Agent header is sent with web requests and whether or not experimentation is allowed to control it.
Dev channel update to 100.0.1156.1 is live
The long-awaited capability to sign into the browser with a work or school account on Linux is now enabled by default and will be available in Beta and Stable once version 100 is released there.
Added features:
  • Added info to the Performance Hub about how much savings Sleeping Tabs are providing.
  • Enabled by default the Rewards hub.
Improved reliability:
  • Fixed a crash when searching for words in a PDF.
  • Fixed a crash when signing into the browser.
  • Fixed a crash when using Guest mode windows.
  • Fixed a crash when sending feedback.
  • Fixed an issue where the Rewards Hub crashes.
  • Fixed a crash on Mac when using Read Aloud.
  • Fixed a hang when viewing tooltips or other popups that appear when hovering over IE mode tabs.
Changed behavior:
  • Changed the JavaScript Share API to call the new Share flyout when available.
  • Changed Startup Boost to be enablable even when conflicting extensions are present.
  • Fixed an issue where Find on Page sometimes gets stuck and can't advance to the next match when iterating through all the matches.
  • Fixed an issue where clicking a misspelled word sometimes doesn't bring up the spellcheck suggestions card to fix it.
  • Fixed an issue where the setting to Open System Preferences For Captions doesn't work.
  • Fixed an issue with WebView2 apps where the IsMuted attribute can't be set if media isn't playing (Issue 2120).
Dev channel update to 100.0.1163.1 is live
Added features:
  • Enabled by default the ability to search through open tabs.
  • Enabled by default Image Auto Captioning in Accessibility Settings.
  • Enabled by default the availability of the Discover pane.  Note that certain entry points into the Discover pane are not yet enabled.
  • Mobile:  Enabled by default Scrolling Screenshot functionality on Android.
  • Developer:  Added an API to WebView2 to listen for PermissionRequested events from any iframe in a page.  Note that updates to documentation and SDKs may not have occurred yet.
  • Fixed a crash when using text prediction.
  • Fixed a crash when showing Spellcheck correction popups.
  • Fixed a crash when logging into certain websites.
  • Fixed a crash after using the Edge Bar.
  • Fixed a crash when closing the browser.
  • Fixed an issue where tabs sometimes crash on versions of Windows prior to 10.
  • Mobile:
    • Fixed a crash when using Read Aloud.
    • Fixed a crash on Android 12.
    • Fixed a crash when navigating to certain websites.
    • Fixed a crash when viewing Cookie information.
  • Developer:
    • Fixed a crash in WebView2 applications (Issue 2130).
    • Fixed a crash with WebView2 applications when certain programs are installed on the device (Issue 1882).
Changed behavior:
  • Fixed an issue where built-in themes don't work and instead just display white.
  • Fixed an issue where the mini context menu sometimes prevents keyboard shortcuts from copying or cutting selected text.
  • Fixed an issue where the progress ring around the Downloads toolbar icon doesn't appear when a download is in progress.
  • Fixed an issue where certain tooltips get stuck onscreen.
  • Fixed an issue where the browser sometimes won't close.
  • Fixed an issue where the context menu option to save a webpage is missing.
  • Fixed an issue where dragging and dropping pinned tabs sometimes doesn't work with vertical tabs.
  • Fixed an issue where context menus sometimes appear at the wrong location.
  • Fixed an issue where Spellcheck correction cards sometimes don't appear when they should.
  • Fixed an issue where Camera selection in Site Permission Settings sometimes fails to find the device's camera.
  • Fixed an issue where certain Settings pages on Linux go blank.
  • Fixed an issue where changing what format of Citation to use sometimes crashes Collections.
  • Fixed an issue where clicking on desktop notifications sometimes does nothing when the browser is closed or when the website that sent the notification is already open in another tab.
  • Fixed an issue in IE mode tabs where the initial HWND size is incorrect.
  • Fixed an issue where Edge prompts for updates on Xbox when it shouldn't since Edge updates are handled by the OS on Xbox.
  • Mobile:  Fixed an issue where changing saved passwords sometimes fails.
  • Developer:  Fixed an issue with WebView2 applications where back/forward navigations sometimes don't work as expected (Issue 1492).
  • Enterprise:  Obsoleted the management policy to Allow Sync XHR In Page Dismissal, which lets webpages send synchronous XHR requests during page dismissal.
Dev channel update to 100.0.1169.1 is live
Added features:
  • Added support for a textprediction attribute on forms in webpages that allows web developers to enable or disable text prediction similar to the way they can control spellcheck and autocomplete.
  • Enabled support for custom text cursors on Windows.
  • Added a Setting on Mac to allow the browser to be automatically updated for all device users.
  • Added the ability on Android to have Read Aloud work when the tab or app is in the background.
  • Enabled a management policy from Chromium to Force the Major Version number To the Minor Position In the User Agent string, which is a temporary policy to freeze the major version number at 99 and place the actual version number in the minor position, for example turning version 101.0.0.0 into 99.101.0.0.
  • Developer (Note that these APIs were previously in the "Experimental" status):
    • Added an API to WebView2 to hide buttons from the PDF toolbar.
    • Added an API to WebView2 to Call Dev Tools Protocol Method For Session, which runs an asynchronous method on a specific WebView session.
    • Added an API to WebView2 to control the Exclusive User Data Folder Access property, which prevents other WebViews and browser processes from accessing the user data folder.
    • Added an API to WebView2 to Allow External Drop, which controls if objects from outside a WebView application are allowed to be dragged and dropped into it.
  • Fixed a crash on the new tab page.
  • Fixed a crash when certain popups appear.
  • Fixed a crash when interacting with the Shopping button.
  • Fixed a crash on Mac.
  • Fixed a crash on Mac when interacting with the address bar.
  • Fixed an issue where certain websites crash.
  • Mobile:
    • Fixed a crash on launch on Android.
    • Fixed a crash when checking for leaked passwords.
    • Fixed a hang when signing into the browser.
Changed behavior:
  • Fixed an issue where certain sites like Spotify that play protected media don't work.
  • Fixed an issue where passwords saved in Settings sometimes can't be removed.
  • Fixed an issue where Spellcheck isn't available for certain languages that it should be.
  • Fixed an issue where printing sometimes fails.
  • Fixed an issue where a prompt to save info like addresses into Autofill unexpectedly appears after filling unrelated data into forms.
  • Fixed an issue where payment cards don't sync when they should.
  • Fixed an issue where certain buttons appear that shouldn't when hovering over tabs.
  • Fixed an issue where certain popups don't have an X button to close them.
  • Fixed an issue where Web Select sometimes doesn't copy certain selected items properly.
  • Fixed an issue where shortcuts on the Taskbar are sometimes duplicated.
  • Fixed an issue where the navigation buttons in the Edge Bar sometimes don't work.
  • Fixed an issue in the Edge Bar where tabs sometimes can't be reordered.
  • Improved support for scrolling PDFs using a touchscreen.
  • Mobile:
    • Fixed an issue where credit card autofill sometimes doesn't work.
    • Fixed an issue where Microsoft Rewards info is missing.
    • Fixed an issue where Read Aloud sometimes doesn't work.
  • Enterprise (removed management policies):
    • Removed the policy to control if Cloud Profile Reporting functionality is Enabled.
    • Removed the policy to control if Cloud Extension Request functionality is Enabled.
  • Developer:
    • Fixed an issue in WebView2 apps where the Document Title property sometimes isn't updated on navigation (Issue 2055).
    • Fixed an issue where WebView2 apps sometimes hang when first opening or restoring from minimization (Issue 2079).
Dev channel update to 100.0.1181.0 is live
Added features:
  • Enabled by default the ability to create a custom Primary Password for use with autofill. Note that this feature also completed its gradual rollout last week.
    • Added a policy to Control if the Default State Of the Allow Extension From Other Stores Setting is Enabled.
    • Added a policy to control if the ability to Hide the Restore Dialog is Enabled, which hides the "Restore pages" dialog that appears after the browser crashes or closes unexpectedly.
    • Enabled support for a policy from Chromium to Prompt On Multiple Matching Certificates, which is functionally identical to the existing Edge policy to Force Certificate Prompts On Multiple Matches.
    • Enabled support for policies from Chromium to control input devices like keyboards and game controllers:  Default Web Hid Guard Setting, which controls if websites are allowed to ask for access to devices; Web Hid Ask For Urls, which is the list of sites allowed to ask for access to devices; and Web Hid Blocked For Urls, which is the list of sites not allowed to ask for access to devices.
  • Added the ability to hide trending searches on mobile.
  • Added an API to WebView2 to customize context menus by listening to the Context Menu Requested event and inserting items via the Create Context Menu Item method, as well as obtaining information about the type of item that was right-clicked.  Note that this API was previously in the "Experimental" status.
  • Fixed a crash on launch on Mac.
  • Fixed a crash when downloading certain types of files.
  • Fixed a crash on versions of Windows older than 10 when downloading files.
  • Fixed an issue where deleting text while a Text Prediction is showing sometimes crashes the tab.
  • Mobile:
    • Fixed a crash when visiting certain websites.
    • Fixed a crash when changing new tab page settings.
    • Fixed a crash when using Shopping features.
  • Fixed a crash in WebView2 applications when viewing them in fullscreen (Issue 2082).
Changed behavior:
  • Fixed an issue where clicking on the volume icon to mute tabs that are playing media doesn't work.
  • Fixed an issue where the Tracking Prevention switch on the InPrivate new tab page doesn't work.
  • Fixed an issue where the Find on Page index resets if another tab is switched to and back.
  • Fixed an issue where Find on Page says it returns 0 matches, but it actually does find matches and highlights them on the page.
  • Fixed an issue where Application Guard windows sometimes can't navigate and show a "Can't reach this page" error.
  • Fixed an issue where Spellcheck sometimes suggests synonyms for the wrong words in its suggestion list.
  • Fixed an issue where Sharing sometimes fails or misses content when sharing from a PWA.
  • Fixed an issue where certain parts of the History menu crash or appear blank.
  • Fixed an issue where the keyboard shortcut to open the F12 Dev Tools console doesn't work.
  • Fixed an issue where clicking on a desktop notification sometimes opens a blank new tab instead of a tab to the website the notification was sent from.
  • Fixed an issue where text labels on extension buttons are cut off or unreadable in PWA windows.
  • Improved messaging when tabs fail to load due to management policy.
  • Management policies:
    • Fixed an issue where the policies to control what sites are able to access file:// URLs don't work when the file names contain spaces.
    • Fixed an issue where the policies to control what sites are able to access file:// URLs sometimes open the wrong folder then the link is to a folder.
    • Fixed an issue where the management policy to control if Microsoft Edge Insider Promotion is Enabled doesn't work.
    • Renamed the policy to control if Transparent Ad Providers are Enabled into "Ads Transparency Enabled".
  • Mobile:
    • Fixed an issue where viewing a page in desktop mode sometimes doesn't work.
    • Fixed an issue where Guided Switch sometimes doesn't work.
    • Fixed an issue where Read Aloud sometimes plays in multiple tabs simultaneously.
    • Fixed an issue where Read Aloud stops unexpectedly while the app is in the background and is then brought back into the foreground.
    • Fixed an issue where certain new tab page settings buttons don't work.
    • Fixed an issue where a dialog showing that ads are blocked appears too frequently.
    • Fixed an issue where certain dialogs don't get closed when they should be.
    • Fixed an issue where the list of accounts available when signing into the browser sometimes is missing some of them.
    • Fixed an issue where the management policy to disable saving passwords sometimes doesn't work.
  • Developer:
    • Fixed an issue with WebView2 apps where certain keyboard shortcuts break window focus (Issue 1225).
    • Fixed an issue in WebView2 apps where the touch keyboard sometimes doesn't appear when it should (Issue 1887).
Dev channel update to 100.0.1185.7 is live
Added features:
  • Enabled by default support for Clarity Boost in Xbox Cloud Gaming.
  • Added a prompt to automatically sign into sites (with the same account that's used for signing into the browser) that are preventing it because they've previously been signed out of.
    • Added a management policy to control if the Edge Asset Delivery Service is Enabled, which is a service that the browser uses to download various configuration files and machine learning models that power certain features.
    • Added support for the PDF Secure Mode management policy, which controls Digital Signature validation of PDFs.
  • Developer:
    • Added an API to WebView2 to update Status Bar text.  Note that this API was previously in "Experimental" status and updates to documentation and SDKs may not have occurred yet.
    • Added support for non-value badges on PWA shortcuts to show when a website wants to set an alert but doesn't want to specify any text on the badge.
  • Fixed a crash when using Find on Page.
  • Fixed a crash when opening certain PDFs.
  • Fixed a crash when interacting with IE mode tabs.
  • Fixed a crash when refreshing IE mode tabs.
  • Fixed an issue where the browser sometimes can't navigate to any websites and load endlessly.
  • Mobile:
    • Fixed a crash when viewing tabs.
    • Fixed a crash when using certain Shopping features.
Changed behavior:
  • Reduced the number of extensions that block Startup Boost.
  • Fixed an issue where the browser re-opens as soon as it's closed.
  • Fixed an issue where Family Safety sometimes doesn't work, and instead launches a regular window.
  • Fixed an issue where clicking websites pinned to the taskbar sometimes activates existing tabs of the same site instead of opening a new tab to the site.
  • Fixed an issue where websites are sometimes attached to the incorrect pinned website icon on the taskbar when there are multiple pages from the same website pinned.
  • Fixed an issue where certain buttons can't be hidden from the toolbar.
  • Fixed an issue where Tab Groups don't have the correct colors in certain menus.
    • Fixed an issue where certain versions of Windows report that they don't support enterprise management when they should.
    • Fixed an issue where the management policy to control if Kiosk Address Bar Editing is Enabled sometimes doesn't work.
    • Removed support for the management policy from Chromium to control if the Lock Icon In the Address Bar is Enabled, which controls which kinds of sites show the lock icon.
  • Mobile:
    • Fixed an issue where downloaded files sometimes can't be opened.
    • Fixed an issue where files sometimes can't be downloaded and then shared to OneDrive.
    • Fixed an issue where profiles sometimes can't be switched after using Guided Switch.
    • Fixed an issue where cookie consent dialogs from certain websites can't be dismissed.
Dev channel update to 101.0.1198.0 is live
Added features:
  • Enabled by default the ability to view PDF properties and metadata.
  • Added info to the Edge Bar about the current URL.
    • Added a policy to control if Kiosk Swipe Gestures are Enabled, which controls if swipe gestures to navigate forward and back are functional in Kiosk mode.
    • Added a policy to Configure Keyboard Shortcuts, which configures which keyboard shortcuts are disabled.
    • Added a policy to control if the Microsoft Office Menu is Enabled.
    • Added a policy in Internet Explorer Mode to Enable Save page As, which has previously been disabled in IE mode tabs.
    • Added support on Mac for the policy to set the Auto Update Check Period in Minutes.
  • Developer (note that updates to documentation and SDKs may not have occurred yet):
    • Added an API to WebView2 for initial support for multiple profiles.  Note that this API was previously in the "Experimental" status.
    • Added an API to WebView2 to set the default download location.  Note that this API was previously in the "Experimental" status.
    • Added an experimental API to WebView2 to verify or block a certificate from the server when an error is detected.
  • Fixed a crash on launch.
  • Fixed an issue where closing a tab group sometimes crashes the browser.
  • Fixed a crash when typing into a webpage.
  • Fixed a crash when changing certain Settings.
  • Fixed a crash when signing out of the browser.
  • Fixed a crash when using Picture in Picture.
  • Fixed an issue where the Spotify PWA sometimes crashes.
  • Fixed a hang.
  • Mobile:
    • Fixed a crash when interacting with the address bar.
    • Fixed a crash when navigating using Top Sites.
    • Fixed a crash when performing a search.
    • Fixed a crash when editing autofill data.
    • Fixed a crash when changing accessibility settings.
    • Fixed a crash on Surface Duo when dragging and dropping text.
    • Fixed a crash when accessing edge://policy.
    • Fixed a hang when using Read Aloud.
Changed behavior:
  • Fixed an issue where Spellcheck sometimes doesn't work.
  • Fixed an issue on Mac where the window control buttons aren't available after exiting fullscreen.
  • Fixed an issue where the Pin To Taskbar option for websites installed as apps and PWAs sometimes doesn't work.
  • Fixed an issue where uninstalling websites installed as apps sometimes doesn't properly uninstall them on other machines when App syncing is enabled.
  • Fixed an issue where the dialog to add a new profile sometimes doesn't open when clicking the button to open it.
  • Fixed an issue where the Travel recommendation popup sometimes appears blank.
  • Fixed an issue where certain browsing data is sometimes unintentionally deleted when other browsing data is intentionally deleted.
  • Fixed an issue where tabs sometimes enter IE mode unexpectedly.
  • Fixed an issue where the IME popup is sometimes placed incorrectly.
  • Mobile:
    • Fixed an issue where tabs sometimes can't be selected in the Tab Center.
    • Fixed an issue where Read Aloud sometimes fails when online voices can't be used instead of falling back to offline voices.
    • Fixed an issue where Read Aloud doesn't start if there's no network connection.
    • Fixed an issue where certain Collection items sometimes are unintentionally deleted when other items are intentionally deleted.
    • Fixed an issue on Android where the Search widget doesn't work.
    • Fixed an issue where feedback can't be sent.
    • Fixed an issue where Top Sites sometimes can't be manually added.
    • Fixed an issue where the option to share a tab sometimes isn't available.
    • Fixed an issue where updating a password sometimes changes the wrong password.
  • Developer:
    • Fixed a WebView2 issue where apps created using certain SDKs report 0 for both MouseEvent movement properties (Issue 2220).
    • Fixed an issue in WebView2 apps where popups like permission prompts and context menus sometimes don't appear.
Dev channel update to 101.0.1210.1 is live
Added features:
  • Added support for viewing PDFs in fullscreen.
  • Enabled by default the Performance hub and its Efficiency Mode.
  • Enabled by default the in-browser assistance search box.
  • Enterprise:
    • Added functionality to Application Guard to make network isolation policies optional.
    • Added a management policy to control if Edge Spaces are Enabled (formerly known as Workspaces).  Note that updates to documentation and administrative templates may not have occurred yet.
    • Added an API to WebView2 to allow apps to automatically change their color scheme to light or dark mode depending on the current OS settings.  Note that this API was previously in the "Experimental" status.
    • Added an experimental API to WebView2 to listen to HTTP Status Codes from navigations.
    • Added an Experimental API to WebView2 get favicons and listen for changes to them.
  • Fixed an issue where the browser won't open.
  • Fixed a crash on launch when certain sidebars are enabled.
  • Fixed a crash when restarting the browser.
  • Fixed a crash when closing a tab.
  • Fixed a crash when closing a window.
  • Fixed a crash when closing a tab while certain popups are open.
  • Fixed a crash when interacting with misspelled words in text boxes.
  • Fixed a crash when viewing edge://crashes.
  • Fixed a crash when searching from the Edge Bar.
  • Fixed a crash when zooming a webpage.
  • Fixed a crash when adding a profile to the browser.
  • Fixed a crash when pinning a website to the Taskbar.
  • Fixed a crash on Linux when signing into the browser with a work or school account.
  • Mobile:
    • Fixed a crash when interacting with the password saving dialog.
    • Fixed a crash when interacting with password popups.
Changed behavior:
  • Fixed an issue where Netflix is slow or hangs.
  • Fixed an issue where opening multiple Collection items at a time opens them in the wrong order.
  • Fixed an issue where title bar text and icons are pink.
  • Fixed an issue where websites sometimes show up as being blocked even though they're not.
  • Fixed an issue where the PDF toolbar sometimes doesn't appear.
  • Fixed an issue where websites sometimes can't be pinned to the Taskbar.
  • Fixed an issue where a Sidebar button on the toolbar couldn't be disabled.
  • Fixed an issue where certain Settings pages take a long time to load.
  • Fixed an issue where IE mode tabs sometimes fail to open.
  • Fixed an issue with IE mode cookie syncing where cookies sometimes get out of sync.
  • Fixed an issue where downloading files from IE mode tabs sometimes leaves extra tabs open.
  • Mobile:
    • Fixed an issue on iOS where credit card autofill doesn't work on some websites.
    • Fixed an issue where the new tab page feed is blank.
    • Fixed an issue on mobile where the setting to make the browser the default browser sometimes doesn't work.
    • Fixed an issue where Read Aloud sometimes skips or stutters when starting.
    • Fixed an issue where Read Aloud unexpectedly stops.
    • Fixed an issue where downloads sometimes can't be opened from completion notifications.
    • Fixed an issue on mobile where certain Shopping popups can't be closed.
    • Disabled screenshots on the New Tab Page on mobile because they aren't functional.
Dev channel update to 102.0.1217.0 is live  Also see Sleeping tabs in Microsoft Edge: Save even more resources with recent updates.
Added features:
  • Added a button to the toolbar for Web Select.
  • Added a management policy to control if All Http Auth Schemes are Allowed For Origins, which controls the list of origins that allow all HTTP Authentication schemes.  Updates to documentation and administrative templates may not have occurred yet.
  • Fixed a crash when downloading certain items.
  • Fixed a crash when opening popups like the Downloads menu in Guest windows.
  • Fixed a crash on Mac when interacting with Tab Groups.
  • Mobile:
    • Fixed an issue where using InPrivate tabs sometimes crashes the browser.
  • Fixed a crash in WebView2 applications when viewing Office documents.
Changed behavior:
  • Improved autofill when performing travel-related tasks.
  • Fixed an issue where Sleeping Tabs settings are missing on some devices.
  • Fixed an issue where the IE mode site list is erased after updating the browser.
  • Fixed an issue where payment cards can't be manually added in Settings.
  • Fixed an issue where Spellcheck sometimes can't be enabled.
  • Fixed an issue where pages sometimes flash red when loading.
  • Fixed an issue where certain borders are pink.
  • Fixed a blank popup.
  • Fixed an issue where autofill popups sometimes suggest the same entry multiple times.
  • Fixed an issue where the option to hide the Smart Explore buttons sometimes doesn't work.
  • Mobile:
    • Fixed an issue where PDFs can't be opened.
    • Fixed an issue where editing a Collection sometimes causes images in it to disappear.
    • Fixed an issue where the button to add the current page to favorites is missing.
    • Fixed an issue where passwords sometimes aren't autofilled.
    • Fixed an issue where the new tab page feed doesn't work in landscape mode.
  • Fixed an issue with WebView2 apps where zoom levels are sometimes inadvertently reset.
  • Disabled Web Capture in IE mode tabs because it's not functional.
Dev channel update to 102.0.1220.1 is live
Added features:
  • Added a prompt to pin PWAs after they've been installed from the Microsoft Store.
  • Redesigned the Apps management page.
  • Added the ability to import passwords on mobile.
  • Added a management policy to control if the Outlook Hub Menu is Enabled.  Note that updates to documentation and administrative templates may not have occurred yet.
  • Fixed a crash when using 2-factor authentication to sign into the browser.
  • Fixed a crash on Android.
  • Fixed a crash on Android when using the search widget.
Changed behavior:
  • Fixed an issue where the tab bar sometimes disappears.
  • Fixed an issue where the Setting to use a custom Secure DNS provider doesn't work.
  • Fixed an issue where the Find bar shows 0 matches even though there are related matches shown on the page.
  • Fixed an issue where the window control buttons are sometimes invisible when certain themes are applied.
  • Fixed an issue where background tabs are sometimes invisible when certain themes are applied.
  • Fixed an issue on mobile where signing into the browser fails.
  • Fixed an issue in WebView2 apps where URL fragments are sometimes inadvertently removed during a navigation redirection.
  • Disabled Kids Mode in Application Guard windows.
Dev channel update to 102.0.1227.0 is live
Added features:
  • Added a management policy to control if the Network Service Sandbox is Enabled.  Note that disabling the Network process sandbox is an increased security risk, and updates to documentation and administrative templates may not have occurred yet.
  • Fixed a crash on startup.
  • Fixed a crash on launch on Mac when certain pages are restored during startup.
  • Fixed a crash when enabling Rewards.
  • Mobile:
    • Fixed a crash when interacting with popups.
  • Fixed a crash in WebView2 apps when their window position changes (Issue 1531).
Changed behavior:
  • Reduced the amount of duplicate autofill entries that are saved in Settings.
  • Improved the number of forms that get autofilled accurately.
  • Fixed an issue where autofilling travel data sometimes results in dates being filled incorrectly.
  • Fixed an issue where dropdowns in PDF forms sometimes can't be interacted with.
  • Fixed an issue where the Setting to control the Picture in Picture button isn't available.
  • Fixed an issue where searching for a setting makes the Settings page go blank.
  • Fixed an issue where certain Settings pages like the Profile Preferences page are blank.
  • Mobile:
    • Fixed an issue where the webpage sometimes goes blank.
    • Fixed an issue where Read Aloud is unexpectedly disabled.
    • Fixed an issue where Read Aloud sometimes unexpectedly stops and can't be restarted.
    • Fixed an issue where copy/paste sometimes doesn't work.
    • Fixed an issue where copy/paste sometimes works when it shouldn't because it's restricted via management policy.
  • Fixed an issue where certain management policies like for setting the Homepage don't work.
Dev channel update to 102.0.1235.1 is live
Added features:
  • Added a link to Tabs From Other Devices in the Tab Actions menu.
  • Enabled support for a management policy from Chromium to control if the javascript engine behavior to Set Timeout Without 1 Ms Clamp is Enabled, which controls if calls to setTimeout() with a 0ms timeout are changed to have a 1ms timeout.  Note that updates to documentation and administrative templates may not have occurred yet.
  • Fixed an issue where all tabs crash with an error code:  FACILITY_VISUALCPP/ERROR_PROC_NOT_FOUND.
  • Fixed a crash on mobile when sending feedback.
  • Fixed an issue where WebView2 apps crash when setting User Data Folder Access options (Issue 2363).
  • Fixed a crash on Xbox when using Tab Search.
Changed behavior:
  • Improved how many types of tabs can be put to sleep.
  • Reduced the number of tabs that are discarded due to memory pressure in certain situations.
  • Fixed an issue where Tab Search doesn't work.
  • Fixed an issue where printing and print preview sometimes doesn't work.
  • Fixed an issue where certain search engines can't be removed from Settings.
  • Fixed an issue where certain languages aren't available in Spell Check.
  • Fixed an issue where IE mode sometimes can't be enabled or configured.
  • Fixed an issue in Application Guard windows where downloads are sometimes blocked when they shouldn't.
  • Fixed an issue where work/school results don't appear in the search engine when searching from the address bar.
  • Mobile:
    • Fixed an issue where Top Sites can't be edited because the edit button is too hard to hit.
    • Fixed an issue where Read Aloud sometimes doesn't highlight words that it should, or says words that it shouldn't.
    • Fixed an issue where the Read Aloud controls sometimes don't appear in the notification shade.
