MBAM Test
Started by Corrine, February 27, 2011, 09:24:37 PM
Please download Malwarebytes' Anti-Malware to your desktop from here.
    -- Update Malwarebytes' Anti-Malware and
    -- Launch Malwarebytes' Anti-Malware
  • Click Finish.
  • Once the program has loaded, check the following settings:
    -- On the Scanner tab, check Perform quick scan.
    -- On the Settings tab, Scanner Settings, leave the default boxes checked but change the drop-down boxes to Show in results list and check for removal.
  • Click Remove Selected.
** Note **
Corrine,
Looking good  :flowers:
Surprising how these things get copied to my notes :tease:
GR@PH;<'S   :Hammys pint:
Thanks, GR@PH;<'S.  Sometimes it helps to have these instructions handy. :)
Please download random's system information tool (RSIT) (Note: Please allow the download of HijackThis if requested by RSIT).
  • Download RSIT by random/random from here and save it to your desktop.
    Note:  For users with 64-bit systems, please download RSIT from here.
  • Double-click RSIT.exe to run RSIT.
  • Once it has finished, two logs will open. Please post the contents of both log.txt (<<will be maximized) and info.txt (<<will be minimized).
Corrine,
Quoteit helps to have these instructions handy
It sure is as it has saved me loads of time on aerage two trips to the bar a week
Would it help if I sent my notes to the local pub?  ;)
Corrine,
What a good idea  :flowers:
You know me I can always be found down my local( <--Clicky You Tube)
WooHoo! MBAM canned with sys. vol. info. image!
I had no idea this thread was here. Thanks for bumping.
Copied----pasted-----in storage and ready for use...thanks Corrine!     :hug:
Been trying to find the time to create that one manually since the first time I saw it.
:dance:
Please download [url=http://www.malwarebytes.org/mbam.php][color=blue][b]Malwarebytes' Anti-Malware[/b][/color][/url] to your desktop.
[list type=lower-alpha]
[li]Double-click [b]mbam-setup.exe[/b] and follow the prompts to install the program.[/li]
[li]At the end, be sure a checkmark is placed next to
[b]Update Malwarebytes' Anti-Malware[/b] and
[b]Launch Malwarebytes' Anti-Malware[/b][/li]
[li]Click [b]Finish[/b].[/li]
[li]If an update is found, it will download and install the latest version.[/li]
[li]Once the program has loaded, be sure [b]Quick scan[/b] is selected, then click [b]Scan[/b].[/li]
[li]When the scan is complete, click [b]OK[/b], then [b]Show Results[/b] to view the results.[/li]
[li]Be sure that everything is checked, [b]EXCEPT[/b] items in System Restore as shown in this sample:
[img]http://securitygarden.googlepages.com/MBAM_SR.png[/img][/li]
[li]Click [b]Remove Selected[/b].[/li]
[li][*]When disinfection is completed, a log will open in Notepad and you may be prompted to Restart. (See the [color=blue][b]Note[/b][/color] below)[/li]
[li]The log is automatically saved by MBAM and can be viewed by clicking the [b]Logs[/b] tab in MBAM.[/li]
[li]Please post contents of that file in your next reply.[/li][/list]
[color=blue][b]** Note **[/b][/color]
If MBAM encounters a file that is difficult to remove, you will be presented with 1 of 2 prompts. Click [b]OK[/b] to either and let MBAM proceed with the disinfection process. If asked to restart the computer, please do so immediately.
[/quote]
Now! Time to swoop in and grab the one for TFC!!    :goodie:
DonnaB,
:flowers:
There be no stopping you now.
Donna, note that is for SMF forums, not IPB or phpBB.  This will work for those forums:
[list][*]Double-click [b]mbam-setup.exe[/b] and follow the prompts to install the program.
[*]At the end, be sure a checkmark is placed next to [b]Update Malwarebytes' Anti-Malware[/b] and [b]Launch Malwarebytes' Anti-Malware[/b], then click [b]Finish[/b].
[*]If an update is found, it will download and install the latest version.
[*]Once the program has loaded, be sure [b]Quick scan[/b] is selected, then click [b]Scan[/b].
[*]When the scan is complete, click [b]OK[/b], then [b]Show Results[/b] to view the results.
[*]Be sure that everything is checked, [b]EXCEPT[/b] items in System Restore as shown in this sample:
[*] Click [b]Remove Selected[/b].
[*]The log is automatically saved by MBAM and can be viewed by clicking the [b]Logs[/b] tab in MBAM.
[*]Please post contents of that file in your next reply.[/list]
Oh my goodness! Thank you Corrine. I was just in the middle of "translating"  for the IPB forums. You saved me lots of time!  :hug:
Happy to be of assistance. :)
