Removing Gator/Claria from System Restore
Started by SpiritWind, August 05, 2005, 04:45:25 PM
SpiritWind
 :D  Several months ago I visited a fellow Bridge player's home to "checkout" his computer; after
      uninstalling, then downloading & installing the latest versions of Ad-Aware & SpywareBlaster, I ran
     a "Full System Scan" and part of the results showed Gator/Claria in the System Restore. Not
     remembering the sequence of steps necessary to clean adware/spyware from there, I cleaned
     everything else & asked him if he was interested in getting rid of Gator/Claria. His response was
    "wishy- washy", so I let things "slide" & uninstalled Gator/Claria from Add/Remove programs, though
     I am not sure how much "returned" the next time he rebooted. Later on I loaned him a
     SearchSecurity.com article on Spyware for his education. Recently he has expressed an interest in
     removing Gator/Claria from his computer; would someone respond with SIMPLE instructions I could
     print out & give him on how to do this on his Win XP SP1/2 OS !? I am unsure as to if he has
     Dialup or DSL and possibly I could go to his home in the future IF he has trouble following the
    "instructions" !?
www.tacf.org
SpiritWind,
I would sooner get your friend to make sure that they have and are using the latest
Ad-aware SE Build 106 (Free/Personal)
with the  latest Definition file
(SE1R60.04.08.2005)
As Logs are stored in :
C:\Documents and Settings\USERNAME\Application Data\Lavasoft\Ad-aware\Logs\.
An easy way to get there is to
click Start,
click Run
And type in and press ENTER: %appdata%
then click  Lavasoft
then Ad-Aware
and then Logs.
scroll down to find the latest one that you have
(by date & time)
(note The Application Data is a hidden folder, so you will need to show hidden files and folders
and for Windows 98/ME users your logs are stored in
C:\WINDOWS\All Users\Application Data\ ) by default
GR@PH;<'S   :breakkie:
