Updated Photos app for Windows 11 with iCloud Photos now rolling out to Windows Insiders
QuoteDuring today's event showcasing what's next for Microsoft Surface, we showed that we're bringing iCloud Photos integration directly to the updated Photos app which began rolling out to Windows Insiders a few weeks ago. We are beginning to roll out an update to the Photos app today (version 2022.31100.9001.0) to Windows Insiders in the Dev Channel with this new integration.
The Microsoft Photos app allows you to view, organize, and share photos from your PC and OneDrive, and with this update, you'll now be able to add and access your iCloud Photos directly from within the app as well. Your iCloud Photos will appear alongside photos from other sources in the beautifully redesigned "All Photos" gallery view, as well as on a dedicated page you can access from the side navigation pane.
To get started, follow the quick setup steps in the Photos app! You'll need to sign into the iCloud for Windows app on your PC and ensure that "Photos" are selected.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Apps > Photos.
Announcing Windows 11 Insider Preview Build 25227
ISOs for this build can be downloaded here.
This build includes improvements for update management for IT administrators and a good set of general changes and improvements.  See the blog post for details.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Install and Update > All other issues.
Microsoft Store Update
Windows Insiders across all channels running version 22209 of the Microsoft Store will see the following improvement:
Pop Up Trailers for Games & Movies: A new way of interaction is added for you to preview trailers of your favorite games and movies.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Microsoft Store.
Changes and Improvements
[Start menu]
  • We are trying out a small change to the Start menu where some Insiders will see badging on their user profile notifying them that certain actions need to be taken.
[Widgets]
  • We're trying out some different positions of the header with new icons for the Widgets board to learn how to best optimize the Widgets board for our users. By using monoline icons, our goal is to bring consistent, clean, and accessible icons to communicate action and features with simple visuals for users.
[Input]
  • The change to support the use of clipboard history (WIN + V) on password fields that began rolling out with Build 25206 is now available to all Windows Insiders in the Dev Channel.
  • We made a change to allow you to contribute your voice clips to Microsoft again even if on-device speech recognition is used.
[Voice typing]
  • We are rolling out a change to sync voice typing settings, Automatic punctuation and Voice typing launcher, across all devices signed in using the same Microsoft account. You can toggle this feature via Settings > Accounts > Windows backup > Remember my preferences > Accessibility. This currently only works with Microsoft accounts today with AAD support coming later.
[Settings]
  • A new dialog will warn users of potential data loss if they elect to change the partition style of their storage drive under System > Storage > Disks & Volumes > Disk Properties.
  • We've updated the ethernet and Wi-Fi property pages in Settings to now show gateway information in the network details summary.
Fixes
[General]
  • Fixed an issue which was causing some Insiders to not be able to upgrade to recent Dev Channel builds, with error 0xC1900101. As a reminder, this is a generic rollback error code, so if you are continuing to see this error after today's update you may be encountering a different issue. If you do, please file feedback about it under Install and Update > Downloading, installing, and configuring Windows Update in the Feedback Hub.
[Tablet-optimized taskbar]
NOTE: These fixes will only show if tablet-optimized taskbar (documented here) is enabled on your device. Tablet-optimized taskbar is still rolling out to Windows Insiders and not yet available for everyone.
  • Fixed an issue that was causing explorer.exe to crash while switching between apps on the tablet-optimized taskbar.
  • Start's touch gesture should now follow your finger correctly with the tablet-optimized taskbar.
  • Improved how touch gestures and their animations with the tablet-optimized taskbar work with the touch keyboard.
  • You can now swipe up from within the taskbar with a pen to expand the tablet-optimized taskbar.
[System Tray Updates]
NOTE: These fixes will only show if System Tray Updates (documented here) is enabled on your device. Tablet-optimized taskbar is still rolling out to Windows Insiders and not yet available for everyone.
  • Fixed an issue causing explorer.exe to crash when dragging icons in the system tray.
  • Right-clicking system tray icons should no longer cause the auto-hidden taskbar to hide incorrectly.
  • The show hidden icons panel in the system tray should no longer block context menus opened after it.
  • Fixed an issue where the first time you tried to open Quick Settings from the system tray it wouldn't work.
  • Fixed an issue that was preventing system tray icons from updating in real time.
[File Explorer]
  • When you scroll to the bottom of the navigation pane using a mouse wheel and try to scroll back up it should no longer get stuck at the bottom.
  • Fixed an issue which could cause certain apps to hang when opening the Open File Dialog or Save File Dialog.
  • Made another fix for a case which could lead to people seeing divider lines overlapping entries in the navigation pane.
[Start menu]
  • Fixed an issue where dragging content across an open Start menu folder could cause a crash.
[Search]
  • Made a fix to help address an issue where Search might not respond when clicking on the search icon in the taskbar.
  • Opening images from search should no longer unexpectedly open them in Print.
[Input]
  • Fixed an issue where over time you might lose the ability to interact with certain games using the mouse.
  • Fixed an issue where the multiplication sign (×, U+00D7) wasn't displaying correctly in the Yu Gothic font family for people with high resolution screens.
[Settings]
  • The size of UWP app icons under Apps > Startup shouldn't be so small now.
[Task Manager]
  • Dragging Task Manager from the bottom area of the title bar to move the window should work now.
[Other]
  • Fixed a couple issues causing certain apps to crash in recent builds, including OneNote. We are continuing to investigate feedback in this space.
  • Made a change to address an issue which could lead to performance degradation when using performance monitoring tools which leveraged the Microsoft-Windows-DxgKrnl ETW provider. This also impacted performance for Windows Mixed Reality. As a reminder, if you're experiencing performance issues, please see here for steps on filing actionable performance feedback.
  • Fixed an issue where recording devices with "Listen to this device" enabled might not show in the volume mixer when they were playing sound.
  • If you reset your PC, the screen displayed while it's resetting will now be black so it's consistent with the upgrade screens.
  • If you were experiencing Gaming Services crashes while trying to play certain games in the previous Dev Channel flight, please check the Microsoft Store for Gaming Servicing updates, it should be resolved now.
  • Fixed an issue which was causing certain PCs to unexpectedly bugcheck on upgrade to the latest builds, with the error message saying "MULTIPROCESSOR_CONFIGURATION_NOT_SUPPORTED".
  • Fixed an issue from the previous flight which could cause Miracast to unexpectedly not be able to connect.
NOTE: Some fixes noted here in Insider Preview builds from the Dev Channel may make their way into the servicing updates for the released version of Windows 11.
UPDATE 10/21: We are starting to roll out Cumulative Update Build 25227.1010 (KB5020539). This update does not include anything new and is designed to test our servicing pipeline for builds in the Dev Channel.
Announcing Windows 11 Insider Preview Build 25231
  • This build includes a few minor changes including increasing the rollouts for a few features.
  • We've also added a handful of known issues – be sure to check them out below.
  • We're also rolling out a Phone Link update to Windows Insiders that introduces instant access to your phone's hotspot with Samsung devices.
[General]
  • The change that began rolling out with Build 25179 to the spelling dictionary so that it now uses a language-neutral word list and syncs across all devices that use the same Windows account is now available to all Windows Insiders in the Dev Channel. Users can toggle this feature via Settings > Accounts > Windows backup > Remember my preferences > Language preferences. This currently only works with Microsoft accounts today with AAD support coming later.
[Input]
  • The cloud suggestion feature Simplified Chinese IME that began rolling out with Build 25217 is now available for all Insiders in the Dev Channel.
Fixes
[System Tray]
  • When moving your mouse over the sound icon on Quick Settings, the tooltip will now display when spatial audio is in use – not just that it is enabled.
[Settings]
  • Removed the backplate from UWP app icons in Apps > Default apps and Apps > Apps for websites.
  • Fixed the font used on the Wi-Fi section of Quick Settings when Wi-Fi was off, so that it's consistent with the other text in Quick Settings
  • Fixed an issue believed to be the root cause of certain network cameras unexpectedly not being added when you selected them under Bluetooth & Devices > Cameras.
  • Improved DPI-awareness when launching setup.exe from a mounted ISO, so the initial logo while it's preparing should no longer be blurry in certain cases.
[Other]
  • Fixed a rare issue where FindWindow and FindWindowEx might return an unexpected window.
  • Fixed an issue where sometimes you wouldn't be able to use FIDO to unlock your PC if it was connected to an external display with the laptop lid closed.
  • Fixed an issue which sometimes led to crashes in certain apps (like Paint, and Windows Terminal) when attempting to display a tooltip.
Announcing Windows 11 Insider Preview Build 25236
[General]
  • To improve the value of Search shortcuts and reduce friction in the broader Windows Search experience, we are trying out different ways to provide tips on how to use Windows Search via the taskbar. Only some English-speaking Windows Insiders in the U.S. will see this. If you do, be sure to give us feedback on what you think in Feedback Hub.
Fixes
[Narrator]
  • We fixed the issue causing natural voices such as Microsoft David or Mark to not speak in Narrator.
[Taskbar & System Tray]
  • Fixed an issue where if you opened the hidden icons flyout, it caused a File Explorer entry for it to appear in the taskbar.
  • Fixed an issue that was causing the taskbar previews to freeze or show as blank and not open when using Windows key + (#) key commands to try and switch between windows.
  • The show hidden icons flyout in the system tray should now responsively resize with changes again to prevent empty spaces and columns.
  • Fixed multiple issues related to the taskbar which were impacting explorer.exe reliability.
  • Fixed an issue that was causing the volume icon in the system tray to incorrectly show as muted.
  • Fixed a GDI handle leak related to updating the notification center icon in the taskbar, which would eventually lead to an explorer.exe crash for people who received a large number of notifications.
  • Narrator will now announce the pinned and unpinned status of apps in the taskbar.
[File Explorer]
  • Fixed an issue which was making File Explorer crash when closing tabs for some people.
  • Made another fix for an issue which could cause errant divider lines in File Explorer's navigation pane.
[Settings]
  • Made a change to hide the battery graph on the Power & Battery page if a UPS is connected, as the capacity information it displayed in that case wasn't correct.
  • If you don't have a kiosk set up, we've now updated the text on Accounts > Other Users > Kiosk to make it clearer you need to do that, so it doesn't appear to be a dead end.
  • Fixed an issue where if you went into the properties for an audio device, this could make it unexpectedly show in the output devices list on System > Sound although it was actually an input device.
  • In the accessibility settings for color filters, the inverted option should work correctly again now and not just set your PC to grayscale colors.
[Other]
  • Fixed an issue causing some Insiders to see a bugcheck with error SYSTEM_THREAD_EXCEPTION_NOT_HANDLED in recent builds.
UPDATE 11/4: We are starting to roll out Cumulative Update Build 25236.1010 (KB5021116). This update does not include anything new and is designed to test our servicing pipeline for builds in the Dev Channel.
Announcing Windows 11 Insider Preview Build 25247
  • We are releasing ISOs for this build – they can be downloaded here.
  • This build includes some new features including Energy Recommendations, some improvements for Task Manager, and changes to the Account settings page.
  • This build also introduces some changes and improvements for the Start menu, taskbar and system tray, and more.
  • With some of the new features and changes introduced with this build, we have also added some new known issues. Be sure to check these known issues out!
  • We're rolling out a new feature for the Microsoft Store – jump list support on the taskbar! See details below.
  • Insider Windows 11 Season 2 continues with episode 3 featuring touch improvements in the Windows 11 2022 Update.
  • We will not be releasing new builds next week to Windows Insiders as the team enjoys some downtime for the U.S. Thanksgiving holiday.
What's new
Access Windows Studio Effects from Quick Settings
Windows Studio effects can now be accessed directly from Quick Settings on the taskbar, for devices that have a supported Neural Processing Unit (NPU). This makes it quick and easy to enable and configure camera effects (Background Blur, Eye Contact, and automatic framing) and audio effects (Voice Focus). You can still access these effects in the Settings pages if desired.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Desktop Environment > Quick Settings.
We are beginning to roll out Energy Recommendations under Settings > System > Power & Battery > Energy Recommendations. Review and apply these recommendations to improve the energy efficiency of your PC and reduce your carbon footprint.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Power and Battery > Energy Recommendations.
Task Manager Improvements
We have a set of Task Manager improvements rolling out with this build.
Filter processes:
We are bringing process filtering to Task Manager. This is the top feature request from our users to filter/search for processes. You can filter either using the binary name, PID or publisher name. The filter algorithm matches the context keyword with all possible matches and displays them on the current page. The filter is also applied as you switch between pages. You can also use the keyboard shortcut ALT + F to focus on the filter box. This is a helpful feature if you want to single out a process or a group of processes and want to take action or just monitor the performance of the filtered processes.
The new search box at the top of Task Manager allows you to filter Binary name, PID or Publisher name.
Better theme support:
We have added the ability to use your preferred theme in Task Manager regardless of the active theme in Windows. You can set it in the setting page in Task Manager.
You can set your preferred theme specifically for Task Manager regardless of your chosen Windows theme.
Task Manager now also supports themes for in-app dialogs. All dialog except for "Run new task" and Properties dialog now support themes and will adhere to either app specific theme or Windows theme.
In-app dialogs such as selecting columns on the Details page will show in the selected theme for Task Manager.
Improved Efficiency mode dialog:
We are making it easy for you to apply Efficiency mode and offering the ability to opt-out of the confirmation dialog. You can make changes on the Efficiency mode dialog box by unchecking "Don't ask me again" or you can enable/disable it the settings for Task Manager.
You can now opt out of seeing future confirmation dialogs when turning on Efficiency mode.  FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Desktop Environment > Task Manager.
New Suggested Action
On copying text with search potential, Windows will pop up an inline light dismissible UI that suggests searching this text in Microsoft Edge. Upon user selection of the search action, a new Edge tab is launched to search the copied text. This will initially be available for Insiders in the U.S. only.
When copying text, a light dismissible UI will appear that suggests searching the text in Microsoft Edge.
[We are beginning to roll this feature out, so it isn't available to all Insiders just yet as we plan to monitor feedback and see how it lands before pushing it out to everyone.]
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Desktop Environment  > Suggested actions on copy.
Updates to your cloud storage in settings for Windows 11
With today's build, the Settings app supports new visuals on your Accounts page to provide a visual overview of your cloud storage usage across Microsoft products. The new visuals include a consolidated cloud storage bar that shows your storage usage for each product and notifies you if you're running low on storage. We removed the quota bar from our subscriptions card to eliminate duplication on these visuals.
In the months to come, you will also see updates to what Microsoft 365 apps and services data is included in your cloud storage. These updates may impact your storage amount starting February 1st, 2023. Learn more about cloud storage here.
A consolidated storage quota bar shown on Accounts page in Settings app with a banner that will alert you if you're running low on storage.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Settings > User Profile Account Settings.
[General]
  • Earlier this week, we released an optional .NET update (2022-11 Cumulative Update Preview for .NET Framework 3.5 and 4.8.1 for Windows Version Next for x64 (KB5020992)) to Windows Insiders in the Dev Channel designed to test delivery of .NET improvements in the future. This .NET update does not include anything new and will be available under Settings > Windows Update > Advanced Options > Optional Updates If you run into any issues finding or installing this update, please submit feedback via Feedback Hub.
[Start menu]
  • We've been working on adding more valuable content to the Recommended section in Start and are excited to introduce a new content type: websites. For the first phase, we will recommend common websites based on your region or browsing history to help you easily get back to the websites you care about. This can be controlled by right-clicking on a website and choosing to remove that website individually or to stop showing all recommended websites entirely. Only some Insiders will see this experience and, if you do, please share your feedback.
  • In response to user feedback, we are introducing the capability to show seconds in the clock on the system tray. This feature can be enabled by toggling the option listed under Settings > Personalization > Taskbar in the Taskbar behavior section. You can also right-click on taskbar to quickly get to taskbar settings. We are beginning to roll this change out so not all Windows Insiders will see this change right away, but we hope to make it available to everyone soon.
We're adding the ability to show seconds in the system tray clock under Settings > Personalization > Taskbar under the Taskbar behavior section.
[Search on the Taskbar]
  • We made performance improvements that will allow more files and content on your PC to show up as results in the Windows search box. We look forward to hearing your feedback on whether you notice an improvement with your file results within Windows.
[Input]
  • Switched the touch keyboard icon option under Settings > Personalization > Taskbar from being a toggle to now being a dropdown where you can select Never, Always, or When no keyboard attached.
  • We are including two new keyboard layouts in this flight. These keyboards implement the two new French keyboard layout standards (AZERTY and BÉPO). The new layouts are designed to allow the user to type all the required characters of the French language. They also include support for all the Latin-based languages of the European Union as well as Greek letters and a large variety of scientific, mathematical, and financial symbols. To enable one of these layouts, go to Settings > Time & language > Language & region and select Language options under the ellipsis for the language you would like to use this keyboard with. On the Options page, select "Add a keyboard" and look for the new keyboard layouts "French (Standard, AZERTY)" or "French (Standard, BÉPO)". The previous AZERTY layout now displays as (Legacy, AZERTY).
  • We have made improvements to Emoji search for Japanese and Simplified Chinese by handling Kana/Kanji and Pinyin properly in the emoji panel.
Fixes
[General]
  • Fixed a bug causing some users to receive a SYSTEM_SERVICE_EXCEPTION bugcheck citing an error with win32kfull.sys when installing via the Build 25227 Dev Channel ISO. Today's release of the Build 25247 ISO should not exhibit this bug.
  • We fixed the issue causing pseudolocalized text to unexpectedly appear across the system for Insiders, leading to (amongst other things) what appeared to be garbled text in the navigation headings of Start's all apps list for Chinese users.
  • When using the bottom right edge gesture to see Quick Settings, the tablet-optimized taskbar will no longer be stuck in the expanded state, instead of dismissing to collapsed state.
  • Fixed multiple explorer.exe crashes impacting taskbar performance.
  • Fixed the issue where certain chat apps (that supported it) weren't flashing with new messages or opening a preview on hover in the system tray.
  • The new show hidden icons flyout's animation should now be consistent with other taskbar flyouts and the arrow will now rotate when open versus closed.
  • Fixed an issue causing the do not disturb icon to disappear while in do not disturb mode.
  • Fixed an issue where invoking the context menu for items in the system tray might not put the context menu in the foreground and it would get stuck behind the taskbar.
  • The pin/unpin visual will now display when dragging system tray icons to any position along the system tray, and not only when hovering over the show hidden icons button.
  • The show hidden icons flyout background color should now align with your accent color if "Show accent color on Start and taskbar" is enabled in Settings > Personalization > Colors.
  • Fixed an issue where the taskbar was sometimes flashing when transitioning between desktop posture and tablet posture.
  • Fixed an issue which was causing certain third-party app icons in the system tray to be unresponsive after the latest system tray changes.
  • The Windows Update icon in the system tray should no longer look pixelated after changing between light and dark mode.
  • Fixed an issue that was causing the NVIDIA icon in the system tray to show empty notifications.
  • Fixed an issue where the weak charger warning (a warning icon on the battery icon) in some cases was not displaying when it should have been.
[Input]
  • Fixed a bug that caused the text cursor to become white on white when hovering over text fields, making it difficult to see.
  • Fixed an issue which could result in the touch keyboard / PIN entry keyboard being unable to input text on the login screen.
  • Fixed a recent issue where the Japanese IME candidate window might fail to display proper candidates when using reconversion in certain edit controls.
  • We're rolling out changes to improve the reliability of the touch keyboard, IME candidate window, and IME toolbar. It includes fixes for an issue where the IME candidate window and IME toolbar weren't shown or cropped sometimes and an issue where a blank window titled "Windows Input Experience" appeared sometimes after resuming from the sleep.
  • We addressed a rare issue which could lead to certain apps crashing after interacting with incorrectly spelled words that were flagged by the spellchecker.
[File Explorer]
  • Fixed a GDI handle leak when opening Show More Options in the context menu, which could lead to graphical issues and an explorer.exe crash over time if you used this a lot.
  • Fixed an issue for Insiders using the Arabic or Hebrew display language which was leading to text not displaying in the context menu when selecting Show More Options.
  • Fixes a bug that was preventing certain phones from showing up in File Explorer when connected via USB in the last 2 Dev Channel flights.
  • When connecting an iPhone via USB, iPhone photos will now be transferred in HEIF format instead of JPEG if the HEVC extension is installed.
  • Fixed an issue which was causing .dotx Word templates to open as new documents instead of a template when you right clicked them and selected Open in File Explorer.
[Settings]
  • Fixed an issue which was causing Settings to crash sometimes when connecting and disconnecting Bluetooth devices.
[Windowing]
  • Fixed an issue where if you maximized a window and then dragged it along the top of the screen into the corner could result in the app getting stuck not being able to resize.
  • Apps like Microsoft Edge should no longer unexpectedly show thick lines on the side of the windows.
  • Fixed a DWM crash which was introduced in the latest Dev Channel flights.
  • If you have two monitors on top of each other, the Desktops list in Task View should no longer appear to be floating in the middle of Task View.
[Other]
  • Switching projection modes using WIN + P / the Project section of Quick Settings should work again now.
  • Fixed a high hitting displayswitch.exe crash in recent Dev Channel builds.
  • If memory integrity in the Windows Security app cannot be enabled due to incompatible drivers, the information about which drivers are incompatible is now selectable so you can copy it if needed.
  • Fixed an issue where the dismiss button for alerts in the Windows Security app might not work.
  • Fixed a rare issue which could lead to a DWM.exe crash when taking screenshots using the Xbox Game Bar.
  • Fixed an issue where if you booted from an ISO to install Windows, the Windows Setup dialog would just show the text "Status" rather than actually displaying helpful text about the current status.
  • Addressed a few issues when booting from an ISO to install Windows, where various items in the Windows Setup dialog weren't being read out correctly by Narrator.
  • Fixed issue where users sometimes could not use FIDO keys to log onto your PC when a full-screen logon message was displayed.
  • Fixed a background crash for Windows Hello which was impacting setup and usage.
  • Improved the experience on logon after booting up by reducing the performance impact of startup apps.
  • Made a change to address a date formatting interoperability issue which was leading to domain login issues on some network shares.
  • Did some work to fix an issue causing VmmemWSL to sometimes use an unexpectedly large amount of CPU and lead to freezing on ARM64 PCs over time.
  • We fixed a bug which could cause your wallpaper to render only a partial section at the top sometimes.
  • Fixed an issue what could lead MSTSC to stop responding when connecting to a RemoteApp or remote desktop.
  • Fixed an issue which was causing https://learn.microsoft.com/previous-versions/windows/it-pro/windows-server-2012-R2-and-2012/cc771525(v=ws.11)[therunascommand to unexpectedly fail in certain cases with error 87 saying the parameter was incorrect (when it wasn't).
  • Fixed the Windows version name written in Microsoft Management Console's help section.
Announcing Windows 11 Insider Preview Build 25252
  • We have added a glanceable VPN status into the system tray when connected to a recognized VPN profile. The VPN icon, a small shield, will be overlayed in your system accent color over the active network connection.
  • In this build, we are continuing to try out different treatments for how search looks on the taskbar. We are excited to learn from your feedback on this, so please let us know what you think via Feedback Hub if you see the different treatments on your PC. Insiders who get this experience will have the ability to change the treatment of search on taskbar in settings under Settings > Personalization > Taskbar > Taskbar Items.
Fixes
  • Fixed an explorer.exe crash when using Alt+F4 with the show hidden icons flyout in the system tray open.
  • Fixed multiple explorer.exe crashes impacting system tray performance.
  • Updated the battery icon's tooltip to let you know if your device is charging slowly.
  • Made a small refinement for tablet-optimized taskbar users to make it a bit easier to expand the taskbar without invoking the Start menu.
  • Fixed an issue which could lead to the taskbar jump lists and preview thumbnails not appearing in the correct position for Insiders with 2 in 1 PCs.
[Start menu]
  • We fixed an issue causing folders in Start menu to not open on the first try.
[Other]
  • Fixed an issue causing some Insiders to see a bugcheck with the error SYSTEM_SERVICE_EXCEPTION after upgrading to the previous flight.
  • Fixed an issue which was causing certain apps (including Media Player) to crash when playing media in the background in recent flights.
  • Fixed an issue which could lead to your PC going to sleep although it was configured to not sleep.
  • Fixed an issue where network-to-local copying (for example, when copying a file from a network share) was slower than expected from some users.
Screen recording in Snipping Tool begins rolling out to Windows Insiders
Hello Windows Insiders, today we are beginning to roll out an update to the Snipping Tool app (version 11.2211.35.0) for Windows 11 to Windows Insiders in the Dev Channel.
We know that Snipping Tool is a favorite among the Insider community, so we are very excited to introduce a built-in screen recorder with this update! Snipping Tool has always made it quick and easy to capture and share content from your PC, and with screen recording built-in, we are expanding these capabilities to even more types of content.
To get started, open the Snipping Tool app and select the new record option. You will then be able to select and refine the part of your screen that you want to record before starting your screen recording session. When you are finished, you can preview your recording before saving or sharing it with others.
We are aware of a couple issues that may impact your experience with this preview. Some users might notice a slight delay between when you click "Start" and when the recording begins. There is also a known issue where the Snipping Tool app window does not restore when initiating a new snip from within the app.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Apps > Snipping Tool.
