Windows 11 Insider Release Preview Channel
Started by Corrine, September 23, 2021, 05:53:19 PM
Releasing Windows 11 Build 22621.457 to the Release Preview Channel
This non-security update KB5016695 includes quality improvements. Key changes include:
  • New! We enhanced Microsoft Defender for Endpoint's ability to identify and intercept ransomware and advanced attacks.
  • New! We compressed a file regardless of its size if you have configured Server Message Block (SMB) Compression.
  • New! We improved storage replication that occurs over low bandwidth or congested wide area networks (WAN).
  • New! You can now view the usage history for the following resources from the Settings page:
  • Camera
  • Microphone
  • Phone Calls
  • Messaging
  • Contacts
  • Screenshots and apps
  • Music library
To use this feature, navigate to Settings >Privacy & Security
  • We fixed an issue that causes Windows to display tablet mode features for some devices that do not have touchscreens.
  • We fixed an issue that causes some application windows to have blank sections in the Task View preview.
  • We fixed an issue that occurs for some of you when you copy files from network drives. The error code is 0x80070026.
  • We fixed an issue that might cause the Local Security Authority Server Service (LSASS) to leak tokens. This issue affects devices that have installed Windows updates dated June 14, 2022 or later. This issue occurs when the device performs a specific form of service for user (S4U) in a non-Trusted Computing Base (TCB) Windows service that runs as Network Service.
  • We fixed an issue that, in certain cases, causes sihost.exe to use a high amount of the CPU.
  • We fixed an issue that causes Microsoft Edge to stop responding when you use IE mode. This issue also prevents you from interacting with a dialog. 40242609
  • We fixed an issue that causes the App-V client service to leak memory when you delete App-V registry nodes.
  • We fixed an issue that prevents you from opening a URL if the URL's length is more than 2084 characters. This update supports a URL of up to 8192 characters.
  • We fixed an issue that prevents codecs from being updated from the Microsoft Store.
  • We fixed an issue that causes ServerAssignedConfigurations to be null in a few full configuration scenarios.
  • We fixed an issue that sometimes prematurely interrupts the resizing operations of a Snap Assist area.
  • We fixed an issue that might cause the deployment of the Windows Hello for Business certificate to fail in certain circumstances after you reset a device.
  • We fixed an issue that prevents you from reinstalling Universal Printers after you remove them.
  • We fixed an issue that prevents non-Windows devices from authenticating when they connect to a Windows-based remote desktop and use a smart card as the authentication method.
  • We fixed an issue that causes the Settings app to stop working on server domain controllers (DCs) when accessing the Privacy > Activity history page.
  • We fixed an issue that affects a lookup for a nonexistent security ID (SID) from the local domain using read-only domain controller (RODC). The lookup unexpectedly returns the STATUS_TRUSTED_DOMAIN_FAILURE error instead of STATUS_NONE_MAPPED or STATUS_SOME_MAPPED.
  • We fixed an issue that prevents the Storage Migration Service (SMS) from completing the inventory on servers that have many shares. Error event 2509 appears in Microsoft-Windows-StorageMigrationService/Admin channel (ErrorId=-2146233088/ErrorMessage="Invalid table id").
  • We fixed an issue that affects the Sync across your devices option under Settings > System > Clipboard. The option will not remain enabled.
Releasing Windows 11 Build 22000.1041 to the Release Preview Channel
This update includes the following improvements:
  • New! We introduced WebAuthn redirection. It lets you authenticate in apps and on websites without a password when you use Remote Desktop. Then, you can use Windows Hello or security devices, such as Fast Identity Online 2.0 (FIDO2) keys.
  • New! We added more dynamic Widgets content to your taskbar with notification badging. When you open the Widgets board, a banner appears at the top of the board. It provides more information about what triggered the notification badge.
  • We fixed an issue that requires you to reinstall an app if the Microsoft Store has not signed that app. This issue occurs after you upgrade to a newer OS.
  • We fixed an issue that stops codecs from being updated from the Microsoft Store.
  • We fixed a race condition in framework autorepair registration. This issue occurs because a registration key is missing.
  • We fixed an issue that affects the Network Policy Server Management (NPSM) service. This issue causes major delays when you sign out.
  • We fixed an issue that affects the Windows Search service. Indexing progress is slow when you use the service.
  • We fixed an issue that affects cached credentials for security keys and FIDO2 authentications. On hybrid domain-joined devices, the system removes these cached credentials.
  • We fixed an issue that affects a network's static IP. The issue causes the configuration of the static IP to be inconsistent. Because of this, NetworkAdapterConfiguration() fails sporadically.
  • We fixed a rare stop error that happens after you change the display mode and more than one display is in use.
  • We fixed an issue that affects rendering in Desktop Window Manager (DWM). This issue might cause your device to stop responding in a virtual machine setting when you use certain video graphics drivers.
  • We fixed an issue that affects graphics drivers that use d3d9on12.dll.
  • We fixed an issue that affects URLs generated by JavaScript: URLs. These URLs do not work as expected when you add them to the Favorites menu in IE mode.
  • We fixed an issue that forces the IE mode tabs in a session to reload.
  • We fixed an issue that successfully opens a browser window in IE mode to display a PDF file. Later, browsing to another IE mode site within the same window fails.
  • We fixed an issue that affects window.open in IE mode.
  • We introduced a Group Policy that enables and disables Microsoft HTML Application (MSHTA) files.
  • We fixed an issue that affects the Microsoft Japanese input method editor (IME). Text reconversion fails when you use some third-party virtual desktops.
  • We fixed an issue that occurs when the input queue overflows. This might cause an application to stop responding.
  • We fixed an issue that might cause a black screen to appear on your display. This might occur when you use a pen to turn on high dynamic range (HDR).
  • We fixed an issue that affects the App-V client service. The service leaks memory when you delete App-V registry nodes.
  • We fixed an issue that might change the default printer if the printer is a network printer.
  • We fixed an issue that affects WDAC policies. If you enable SecureLaunch on a device, WDAC policies will not apply to that device.
  • We fixed an issue that affects Windows Defender Application Control (WDAC) path rules. This issue stops .msi and PowerShell scripts from running.
  • We fixed an issue that might bypass MSHTML and ActiveX rules for WDAC.
  • We fixed an issue that causes WDAC to log 3091 and 3092 events in audit mode.
  • We fixed an issue that affects Windows Defender Application Control (WDAC). It stops WDAC from logging .NET Dynamic Code trust verification failures.
  • We fixed an issue that occurs when a WDAC policy fails to load. The system logs that failure as an error, but the system should log the failure as a warning.
  • We fixed an issue that affects Code Integrity logging. It logs issues as errors instead of warnings. Because of this, automatic repair is triggered.
  • We fixed an issue that affects the touch keyboard. The touch keyboard immediately closes when you tap to switch apps.
  • We fixed an issue that causes LogonUI.exe to stop working. Because of this, you cannot dismiss the lock screen to view the credentials screen.
  • We fixed an issue that affects the FindNextFileNameW() It might leak memory.
  • We fixed an issue that affects robocopy. Robocopy fails to set a file to the right modified time when using the /IS
  • We fixed an issue that affects cldflt.sys. A stop error occurs when it is used with Microsoft OneDrive.
  • We fixed an issue that affects the LanmanWorkstation service. When you mount a network drive, the service leaks memory.
  • We fixed an issue that affects the Get-SmbServerNetworkInterface It only retrieves a subset of the available network interfaces.
  • We fixed an issue that affects the Get-SmbServerConfiguration It only allows you to run it if you are an administrator.
  • We fixed an issue that affects Roaming User Profiles. After you sign in or sign out, some of your settings are not restored.
  • We fixed a known issue that affects XML Paper Specification (XPS) viewers. This might stop you from opening XPS files in some non-English languages. These include some Japanese and Chinese character encodings. This issue affects XPS and Open XPS (OXPS) files.
  • We fixed a known issue that affects daylight saving time in Chile. This issue might affect the time and dates used for meetings, apps, tasks, services, transactions, and more.
Releasing Windows 11 Build 22621.607 to the Release Preview Channel
  • We fixed an issue that affects some apps that were not signed by the Microsoft Store. You must reinstall them after you upgrade the OS.
  • We fixed issues that cause updates to the Microsoft Store to fail.
  • We fixed an issue that stops you from signing in to various Microsoft Office 365 apps. This affects Outlook, Word, Teams, and so on.
  • We updated the start date for daylight saving time in Chile. It will start on September 11, 2022 instead of on September 4, 2022.
  • We fixed an issue that affects the Windows Search service. It causes the indexing progress for the service to be slow.
  • We fixed an issue that affects some processors. This issue occurs when you turn on Hyper-V and kernel Direct Memory Access (DMA) protections.
  • We fixed an issue that affects Task Manager. It stops working when you switch between light and dark mode or change the accent color.
  • We fixed an issue that affects the font of three Chinese characters. When you format these characters as bold, the width size is wrong.
  • We reduced the power that the Dynamic Host Configuration Protocol uses on some devices when they are in Sleep mode.
  • We fixed an issue that affects window. Open in IE mode.
  • We fixed an issue that might cause an application to stop responding. This might occur when the input queue overflows.
  • We fixed an issue that affects XML Paper Specification (XPS) viewers. This might stop you from opening XPS files in some non-English languages. These include some Japanese and Chinese character encodings. This issue affects XPS and Open XPS (OXPS) files.
  • We fixed an issue that creates a duplicate print queue. Because of this, the original print queue stops working.
  • We fixed an issue that might bypass MSHTML and ActiveX rules for Windows Defender Application Control (WDAC).
  • We fixed an issue that affects the Miracast UI. Sometimes it closes too soon when you cast to devices that use the DeviceObjectType:Aep.
  • We added more dynamic Widgets content to your taskbar with notification badging. When you open the Widgets board, a banner appears at the top of the board. It provides more information about what triggered the notification badge.
  • We fixed an issue that affects the SharedPC account manager. The issue stops it from deleting many accounts during cleanup.
  • We fixed an issue that affects Dual SIM calling. If you select no SIM on your phone and initiate a call on your device, Dual SIM functionality does not work.
  • We fixed an issue that affects the LanmanWorkstation service. It leaks memory when you mount a network drive.
Rolling out new features for Windows 11, version 22H2 in the Release Preview Channel
  • New! We enhance File Explorer. It now includes tabs to help you organize your File Explorer sessions like you do in Microsoft Edge. On the new File Explorer homepage, you can pin important files for quick and easy access. Using the power of Microsoft OneDrive, you can view your colleagues' actions on your shared files. We also provide personalized suggestions based on your Microsoft 365 account.
  • New! We add suggestions for actions when you copy items. For example, when you copy phone numbers or future dates, we provide suggestions, such as make a call with Teams or Skype or add an event in the Calendar app.
  • New! We add a taskbar overflow menu. The taskbar will offer an entry point to a menu that shows you all your overflowed apps in one space.
  • New! You can now share to more devices. You can discover and share to more devices, including desktops, using a nearby share.
NOTE: Not all Insiders will see these new features right away as we monitor feedback before pushing them out to more Insiders.
Releasing Windows 11 Build 22621.675 to the Release Preview Channel
This update enables the following new features that began rolling out to Insiders in Release Preview on Windows 11, version 22H2, last week:
  • New! We add a feature called Suggested Actions for items that you copy. This is available for customers in the United States, Canada, and Mexico. For example, when you copy phone numbers or future dates, we provide suggestions, such as make a call with Teams or Skype or add an event in the Calendar app.
  • New! You can now share to more devices. You can discover and share to more devices, including desktops, using a nearby sharing.
Releasing Windows 11 Build 22000.1163 to the Release Preview Channel
  • New! We added improvements to Windows search results and performance.
  • New! We added Task Manager to the context menu when you right-click the taskbar. This feature rolls out in the coming weeks.
  • We fixed an issue that affects Distributed Component Object Model (DCOM) authentication hardening. We will automatically raise the authentication level for all non-anonymous activation requests from DCOM clients to RPC_C_AUTHN_LEVEL_PKT_INTEGRITY. This occurs if the authentication level is below Packet Integrity.
  • We fixed a DCOM issue that affects the Remote Procedure Call Service (rpcss.exe). We raise the authentication level to RPC_C_AUTHN_LEVEL_PKT_INTEGRITY instead of RPC_C_AUTHN_LEVEL_CONNECT if RPC_C_AUTHN_LEVEL_NONE is specified.
  • We fixed an issue that affects the Microsoft Azure Active Directory (AAD) Application Proxy connector. It cannot retrieve a Kerberos ticket on behalf of the user. The error message is, "The handle specified is invalid (0x80090301)."
  • We fixed an issue that affects scheduled Native Image Generator (Ngen.exe) tasks on devices that have certain processors.
  • We fixed an issue that affects certificate mapping. When it fails, lsass.exe might stop working in schannel.dll.
  • We fixed an issue that causes an OS upgrade to stop responding, and then it fails.
  • We fixed an issue that affects a task you schedule to run every two weeks. It runs every week.
  • We fixed an issue that affects Microsoft Direct3D 9 games. The graphics hardware stops working if the hardware does not have a native Direct3D 9 driver.
  • We fixed graphical issues in games that use Microsoft D3D9 on some platforms.
  • We fixed an issue that affects Microsoft Edge when it is in IE Mode. The titles of pop-up windows and tabs are wrong.
  • We fixed an issue that affects Microsoft Edge IE mode. It stops you from opening webpages. This occurs when you enable Windows Defender Application Guard (WDAG) and you do not configure Network Isolation policies.
  • We fixed an issue that affects input method editors (IME) from Microsoft and third parties. They stop working when you close the IME window. This occurs if the IME uses Windows Text Services Framework (TSF) 1.0.
  • We fixed an issue that affects the lasso tool in a graphics editing program.
  • We fixed an issue that affects a universal printer. You cannot reinstall it after you remove it.
  • We fixed an issue that affects some drivers. They use more power when you play hardware-protected digital rights management (DRM) content.
  • We fixed an issue that affects driver installation on certain hardware. You cannot see the display of the progress of the installation.
  • We fixed an issue that affects the Clipchamp application that is in the Windows 11 SE edition. Clipchamp will not run.
  • We fixed an issue that affects .msi files. Windows Defender Application Control (WDAC) will ignore them when you disable script enforcement.
  • We fixed an issue that affects a remote desktop virtual desktop infrastructure (VDI) scenario. The session might use the wrong time zone.
  • We fixed an issue that affects File Explorer on a remote desktop (RD) session host. File Explorer stops working. This occurs when a non-Windows client connects to a Windows 11 RD session host, and you enable the Time Zone Redirection policy.
  • We fixed an issue that affects the button style BS_PUSHLIKE. Buttons that have this style are difficult to identify against a dark background.
  • We fixed an issue in that stops the credentials UI from displaying in IE mode when you use Microsoft Edge.
  • We fixed an issue that affects Server Manager. It might reset the wrong disk when several disks have the same UniqueId.
Releasing Windows 11 Build 22621.754 to the Release Preview Channel
  • New! We added a new consent form for those of you enrolled in Windows Hello Face and Fingerprint. You have new choices for your biometric data. You can keep storing your biometric data or open Settings to delete the data if you have not used your face or fingerprint for authentication in over 365 days. You also have these options if you upgraded to Windows 11 and have not yet seen the new Hello Learn More Privacy text.
  • New! We added improvements to the Microsoft Account experience in Settings. For instance, you can manage your Microsoft One Drive subscription and related storage alerts.
  • New! We enhanced search visual treatments on the taskbar to improve discoverability. This is available to a small audience initially and deploys more broadly in the months that follow. Some devices might notice different visual treatments as we gather feedback. To learn more about why you might be seeing these changes, see Search for anything, anywhere.
  • New! We enhance the backup experience when using your Microsoft Account (MSA). Some devices might notice visual treatments for this enhancement. This is available to a small audience initially and deploys more broadly in the months that follow.
  • We enabled the ms-appinstaller Uniform Resource Identifier (URI) to work for the DesktopAppInstaller.
  • We will not start daylight saving time in Jordan at the end of October 2022.
  • We fixed an issue that affects cached credentials for security keys and Fast Identity Online 2.0 (FIDO2) authentications. On hybrid domain-joined devices, the system removes these cached credentials.
  • We fixed an issue that might affect some types of Secure Sockets Layer (SSL) and Transport Layer Security (TLS) connections. These connections might have handshake failures. For developers, the affected connections are likely to send multiple frames followed by a partial frame with a size of less than 5 bytes within a single input buffer. If the connection fails, your app will receive the error, "SEC_E_ILLEGAL_MESSAGE".
  • We fixed an issue that affects title bars when you use third-party tools to customize them. The title bars did not render. This update ensures that title bars render; however, we cannot guarantee all text customizations will work as before.
  • We fixed an issue that might cause vertical and horizontal line artifacts to appear on the screen.
  • We fixed an issue that might fail to sync the audio when you record game play using the Xbox Game Bar.
  • We updated DriverSiPolicy.p7b for the Windows kernel vulnerable driver blocklist. This update includes drivers that are vulnerable to Bring Your Own Vulnerable Driver (BYOVD) attacks.
  • We extended original equipment manufacturer (OEM) control of Hypervisor-protected Code Integrity (HVCI) enforcement for targeted hardware configurations.
  • We fixed an issue that affects File Explorer. It is less dependable when you browse for Microsoft OneDrive folders.
  • We fixed an issue in that stops the credential UI from displaying in IE mode when you use Microsoft Edge.
  • We address an issue that affects the CopyFile function. It returns ERROR_INVALID_HANDLE instead of ERROR_FILE_NOT_FOUND when it is called with an invalid source file.
  • We fixed an issue that affects the Start menu. It stops working when you use keyboard commands to move pinned items to a folder at the end of a list.
Releasing Windows 11 Build 22621.898 to the Release Preview Channel
  • New! We gave Microsoft OneDrive subscribers storage alerts on the Systems page in the Settings app. The alerts appear when you are close to your storage limit. You can also manage your storage and purchase additional storage, if needed.
  • New! We provided the full amount of storage capacity from all your OneDrive subscriptions. It also displays the total storage on the Accounts page in the Settings app.
  • New! We combined Windows Spotlight with Themes on the Personalization page. This makes it easier for you to discover and turn on the Windows Spotlight feature.
  • New! We added the organizational messages feature. With it, third-party companies can now provide content to their employees. They do not need to use the default behavior of Windows.
  • We fixed an issue that affected some modern applications. It stopped them from opening.
  • We fixed an issue that affected some devices that are managed by an enterprise. We improved the reliability of app installations for them.
  • We fixed an issue that affected daylight saving time (DST) in the Republic of Fiji. It canceled DST for 2022.
  • We fixed an issue that affected Distributed Component Object Model (DCOM) authentication hardening. We will automatically raise the authentication level for all non-anonymous activation requests from DCOM clients to RPC_C_AUTHN_LEVEL_PKT_INTEGRITY. This occurs if the authentication level is below Packet Integrity.
  • We fixed an issue that affected Unified Update Platform (UUP) on-premises customers. It removed the block that stopped them from getting offline language packs.
  • We fixed an issue that affected process creation. It failed to create security audits for it and other related audit events.
  • We fixed an issue that affected cluster name objects (CNO) or virtual computer objects (VCO). Password reset failed. The error message was, "There was an error resetting the AD password... // 0x80070005".
  • We fixed an issue that affected transparency in layered windows. This occurred when you were in High Definition remote applications integrated locally (RAIL) mode.
  • We fixed an issue that affected certain applications. They stopped working. This occurred when you used keyboard shortcuts to change the input mode for the Japanese Input Method Editor (IME).
  • We fixed an issue that affected microphone streams that used the Listen To feature to route to the speaker endpoint. The microphone stopped working after you restarted the device.
  • We fixed an issue that might have affected applications that run on the Windows Lock Down Policy (WLDP). They might have stopped working.
  • We fixed an issue that affected Microsoft Defender when it is not the primary antivirus. Microsoft Defender failed to turn off passive mode. This issue occurred when you turned off Smart App Control (SAC).
  • We added .wcx to the list of Dangerous Extensions that some app control policies do not allow.
  • We fixed an issue that affected Microsoft Defender for Endpoint. Automated investigation blocked live response investigations.
  • We fixed an issue that affected printing in landscape mode in Microsoft Edge. The print output was incorrect. This issue occurred when you used Microsoft Defender Application Guard.
  • We fixed an issue that caused File Explorer to stop working. This occurred when you closed context menus and menu items.
  • We fixed an issue that might have caused certain apps to stop responding. This occurred when you opened the Open File dialog.
  • We fixed an issue that sometimes affected File Explorer when you opened a file. Because of this, there was high CPU usage.
  • We fixed an issue that affected protocol activation of the Settings app. The app failed to open a page under the Accounts category.
  • We fixed an issue that affected a computer account. Use of non-standard characters stopped the cleanup of the Out of Box Experience (OOBE) accounts.
  • We fixed an issue that affected the CopyFile It might have sometimes returned error 317: ERROR_MR_MID_NOT_FOUND.
