Windows Security Alert Icon
Started by BarbB, November 30, 2009, 04:27:44 AM
BarbB
Hello LanzDown Forum,
I'm here at the suggestion of someone on  http://ths.gardenweb.com/forums/comphelp/
Edit by EtR http://ths.gardenweb.com/forums/load/comphelp/msg111807191705.html?11
I have a Dell Inspiron laptop running Windows XP Pro, and using IE, and OE6. The other night I was doing a "Google" search and all of a sudden there was an unscheduled "scan" that started. Immediately I knew there was a virus problem so I shut down, rebooted and started a full Webroot Anti Virus scan, which turned up 1 virus "Mal". Went back to "Google" and darn if it didn't start again. Same procedure, but this time I did a "Quick" scan which found 1 more.
Just to make sure I then did a Malwarebyte full scan. This time it turned up 6. Finally did another quick on Malwarebyte and it came back clean. My problem is there is this icon on my task bar that whenever I start up it pops up saying my computer may be at risk and to "click the balloon to fix the problem". Well I think I know better than to do that, so I've done nothing. My problem is I cannot get rid of the icon, although it eventually goes away it always comes back when I reboot.
My final question is IF this icon could start another virus if clicked, why didn't Malwarebyte find it in it's search.
Thanks so much for your help.
BarbB
Hi, BarbB.  Welcome to LandzDown Forum.
Indeed, the icon in your task bar is the sign that the infection has not been removed.  Because there are new variants continually released, it could be that this particular variant is not yet in detection by Malwarebytes.  Is there a "name" when you mouse over the icon?
Please follow the instructions in Log Posting Instructions and post those logs here as a reply, along with the log from the MBAM scan which can be found here: C:\Documents and Settings\Username\Application Data\Malwarebytes\Malwarebytes' Anti-Malware\Logs\log-date.txt.
