Announcing Windows 11 Insider Preview Build 26120.2213 (Dev Channel)
Changes and Improvements gradually being rolled out to the Dev Channel with toggle on
[Input]
  • We are beginning to roll out a change where we now hide the IME toolbar when apps are in full screen mode for those who have the IME toolbar enabled and type in Chinese or Japanese.
  • We have temporarily disabled the new Gamepad keyboard layout for the on-screen keyboard in Windows 11 that began rolling out to Windows Insiders in the Dev Channel with Build 26120.2130 to address some issues. This feature will roll out again in a future flight.
Fixes gradually being rolled out to the Dev Channel with toggle on
[Start menu]
  • Fixed an issue impacting Start menu reliability.
  • Fixed an issue causing some Insiders to see an unexpected amount of spacing between items in the Start menu apps list.
  • Fixed an issue where ability to pin / unpin apps to and from Start menu was unexpectedly unavailable for some people.
[File Explorer]
  • Fixed an issue which was causing the items in the navigation pane to become very spread out (with unexpected padding between each item) for some people.
  • Fixed an underlying issue which was causing RAW images taken in portrait mode to unexpectedly display in landscape mode thumbnails.
[Taskbar]
  • Made a change so you will now see a search box if the taskbar auto-hides when the setting for search on the taskbar is set to "Search box" (rather than an icon).
  • Made a fix for WIN + <# associated with position on taskbar> not working in some cases in the latest flights.
  • Fixed an issue where the X button to close an app window from the taskbar wasn't working for some Insiders.
  • Fixed an issue on secondary monitors for left aligned taskbar users, where the widgets text in the taskbar might overlap the date and time.
[Dev Drive]
  • Fixed an underlying issue leading to Dev Drives potentially not being accessible within WSL after the latest flights.
[Other]
  • Fixed an underlying issue which could potentially lead to not being able to join a domain.
  • Fixed an underlying issue which could lead to DISM /StartComponentCleanup not working properly, getting stuck at 71% and showing error 6842.
  • Fixed an underlying issue which was causing the Get-WindowsCapability command to get into a state sometimes where it would fail unexpectedly until rebooting your PC.
  • Fixed an issue where rotation info about JPGs couldn't be queried via APIs (for example, via PowerShell).
Fixes for everyone in the Dev Channel
[General]
  • Fixed an underlying issue leading to some games not launching in the previous flight.
[Task Manager]
  • Fixed an issue causing Task Manager to show a 0 count for apps and processes.
[Network]
  • Fixed an underlying issue impacting DHCP where unexpected duplicate options would fail lease acquisition, which could cause DHCP to not get an IP address, leading to Wi-Fi not working.
  • Fixed an issue where DirectAccess wasn't working and might stay stuck in a connecting state.
Announcing Windows 11 Insider Preview Build 26120.2222 (Dev Channel)
[General]
  • If you hold Shift and CTRL when clicking on a jump list item in Start menu or taskbar, this will now launch that item as admin, just like if you were to do Shift + CTRL and click the app icon itself. For example, if you right-click on Windows Terminal, and hold Shift and CTRL when you click PowerShell, it would open a PowerShell window as admin.
[File Explorer]
  • Fixed an issue causing the See More ("...") menu to open in the wrong direction (and potentially display offscreen as a result).
[Input]
  • Fixed an underlying issue which could cause the mouse to unlock from a game window on a system with multiple monitors after opening and closing Game Bar, so you couldn't use it within the game.
[Windowing]
  • Fixed a recent issue causing windows to potentially unexpectedly move around after waking from sleep if you had multiple monitors.
[Other]
  • Fixed an underlying issue which could lead to Registry Editor going unresponsive if you pressed Alt after clicking on the license information in the About section.
Previewing Recall with Click to Do on Copilot+ PCs with Windows Insiders in the Dev Channel
Join the Dev Channel on your Copilot+ PC
Here is how you can join the Dev Channel on your Copilot+ PC today (we have a video too!):
  • Register for the Windows Insider Program here via our website with your Microsoft account or Microsoft Entra ID. This should be the same account you use to sign into your Copilot+ PC with.
  • After you have registered, go to Settings > Windows Update > Windows Insider Program on your PC and select the Get Started button.
  • When asked to link an account, choose the account you're signed into Windows with and be sure that it is the same account you registered for the program with.
  • Choose the Dev Channel and reboot.
  • After rebooting and signing into your Copilot+ PC, go to Settings > Windows Update and check for updates and Build 26120.2415 should be offered.
  • Your PC will download the update and reboot to finish the update process.
New Copilot+ PC experiences
Retrace your steps
We're excited to release the first preview of Recall to our Windows Insider community. Recall is an entirely new way to search for things you've seen or done on your PC securely. With the AI capabilities of Copilot+ PCs, it's now possible to quickly find and get back to any app, website, image, or document just by describing its content.
We invite you to try out Recall and share feedback, issues, or suggestions for improvement through in-experience links or the Feedback Hub. We also want to recognize the contributions of researchers and the security community in shaping Recall. If you're an Insider also in this group, we additionally invite feedback on Recall's updated security and privacy architecture through participation in our Windows Insider Preview Bug Bounty Program.
As is typical when first previewing new features with Windows Insiders, you may encounter some known issues listed at the bottom of this blog post we highly recommend you read.
Setup: After installing this build, the models for Recall and Click to Do will start to download in the background. You can check the download status via Settings > Windows Update. To open Recall you can find it in the Start menu under the All apps list.
When you open Recall, you can complete the first-run experience, which will ask you to opt-in to saving snapshots. It will also require you to enroll in Windows Hello to confirm your presence. This requires you to enable BitLocker and Secure Boot if you haven't already. If you don't enable saving snapshots, Recall will not save any snapshots of your activity.
Find It: Use your PC as you normally would. When you need to find or get back to something you've done previously, open Recall and authenticate with Windows Hello. As we use our PCs throughout the day working on documents or presentations, taking video calls, and context switching across activities, Recall helps you find things faster and easier and reduces the strain when you can't remember something. Search using the clues you remember. You can not only search for the text you need to get back to, but now simply describe what you're looking for ("pie chart"). You can also browse the timeline to see snapshots from a specific time you remember and get right back to that document or website quickly. Recall's search results leverage AI to provide both text and visual matches for your query. AI can make mistakes, if the results aren't accurate or don't look right, please provide us with feedback using the feedback link. When you've found what you were looking for, you can get back to the application, website, or document, or use Click to Do to act on any image or text in the snapshot you found. You can learn more about using Recall here.
Control: With Recall, you're in control of what snapshots are saved and when Recalls saves them. A new icon in the system tray displays status and provides quick access to Recall actions. When Recall is enabled, you'll see the Recall icon visible. It provides visual cues to remind you when snapshots are being analyzed and saved. Click the icon and you will be able to pause saving snapshots or view more status information. When paused, you see a slash through the icon.
You can delete any snapshot in Recall that you don't want and tell Recall to ignore that app or website in that snapshot going forward, either when viewing an individual snapshot or by searching for what you want deleted and removing those results.
Your data: Insiders and Recall users, we want you to know your snapshots are truly yours. We do not send your snapshots off your PC to Microsoft or third parties, and don't use them for training purposes. Microsoft can't access the keys to view your encrypted data, so we can't restore your snapshots if you remove Windows Hello or restore your snapshots if you need to reset your PC or move to a new PC. We will in future updates provide ways for you to store a backup of your keys for these cases. For now, your Copilot + PC only releases the keys to use Recall if you show your face, fingerprint, or PIN. Please note that while in preview, we may make updates that require a reset of your saved snapshots and will let you know here. Technical Insiders can learn more about the security and privacy architecture of Recall here.
Privacy: We've updated Recall to detect sensitive information like credit card details, passwords, and personal identification numbers. When detected, Recall won't save or store those snapshots. We'll continue to improve this functionality, and if you find sensitive information that should be filtered out, for your context, language, or geography, please let us know through Feedback Hub. We've also provided an option in Settings that we encourage you to enable that will anonymously share the apps and sites you prefer to be excluded from Recall to help us improve the product. And you can also choose to exclude specific apps and websites through the Recall settings page which we talk about below.
Settings: Try out the additional settings available to configure Recall. Changing Recall settings requires you to authenticate with Windows Hello. You can disable saving snapshots, pause temporarily, filter applications and websites in supported browsers, control disk usage, and delete your snapshots at any time via Settings > Privacy and security > Recall and snapshots. Please provide us with feedback if additional settings would improve your experience. You can also remove Recall entirely by typing "Turn Windows features on or off" in the search box on your taskbar. Uncheck Recall from the dialog and restart your PC.
Enterprises: As announced at Ignite, for our enterprise customers, Recall is removed by default on PCs managed by an IT administrator for work or school, as well as Enterprise versions of Windows 11. IT administrators fully control the availability of Recall within their organization. Employees must choose to opt-in to saving snapshots and enroll their face or fingerprint with Windows Hello for snapshots to be saved. Only the signed-in user can access and decrypt Recall data, so although enterprises cannot access employee Recall data, they can prevent Recall from being used altogether and prevent any saving of specific apps or sites. IT administrators can click here to learn more about managing Recall on Copilot+ PCs in their organizations.
Recall (Preview) will begin to rollout on Snapdragon-powered Copilot+ PCs, with support for AMD and Intel-powered Copilot+ PCs coming soon. As we gradually roll out Recall in preview, Recall is supported on select languages including Chinese (simplified), English, French, German, Japanese, and Spanish. Content-based and storage limitations apply. See here for more details. Recall is not yet available in all regions, with expanded availability coming over time.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Desktop Environment > Recall or through in-experience links.
Click to Do (Preview) with Recall
With Click to Do in Recall, you can get more done with snapshots and improve your productivity and creativity. Click to Do recognizes text and images in snapshots and offers AI powered actions you can take on these, saving you time by helping complete tasks inline, and/or quickly getting you to the app that can best complete the job for you.
For text, Click to Do offers the following actions:
  • Copy: Easily copy text to your clipboard.
  • Open with: Open the selected text with your preferred application.
  • Search the web: Quickly search the web for the selected text.
  • Open website: Open any URL you recognize on screen in your preferred browser
  • Send email: Send email to the email address recognized on screen in your preferred email app
For image, Click to Do provides a variety of options:
  • Copy: Copy the image to your clipboard.
  • Save as: Save the image to your desired location.
  • Share: Share the image with others.
  • Open with: Open the image with your preferred application.
  • Visual search with Bing: Perform a visual search and surface relevant contents using Bing.
  • Blur background with Photos: Blur the background of the image using Photos app.
  • Erase objects with Photos: Erase unwanted objects from the image using Photos app.
  • Remove background with Paint: Remove the background of the image using Paint app.
In this update Click to Do only works within the Recall experience. In a future update, you'll be able to effortlessly engage with Click to Do by simply pressing Windows logo key + mouse click, Windows logo key + Q, through the snipping tool menu and Print Screen, or searching "Click to Do" through Windows Search Box. These methods will make it easier than ever to take immediate action on whatever catches your eye on-screen. We're also working on introducing more intelligent text actions to enhance your experience even further.
Just like with Recall noted above, Click to Do (Preview) is available only on Snapdragon-powered Copilot+ PCs. Support for Intel and AMD-powered Copilot+ PCs is coming soon.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Desktop Environment > Click to Do.
Other changes included in this Dev Channel update
This update (Build 26120.2415) includes additional changes and improvements available to Windows Insiders across every Windows 11 PCs. These changes include:
  • New features, improvements, and fixes that are being gradually rolled out for Insiders who have turned on the toggle to get the latest updates as they are available (via Settings > Windows Update*).
  • New features, improvements, and fixes rolling out to everyone in the Dev Channel.
For more information, see the Reminders section at the bottom of the blog post.
[Windows Hello]
  • The revamped and modernized Windows Hello user experience that is rolling out to Windows Insiders in the Beta and Canary Channels will start rolling out to Insiders in the Dev Channel soon.
[Narrator]
  • We have added new functionalities to Narrator scan mode. Skip past links (N') allows you to navigate to the text after a link. This is most helpful when navigating through long emails, news articles, and wiki pages. Jump to lists (L') allows you to quickly access a list on a web page or a document. To try these new features, you need to turn on Narrator first (Win key + Ctrl + Enter), then turn scan mode ON by pressing Caps Lock + Spacebar and finally use the new shortcuts – 'N' and 'L'. Please note that scan mode is 'ON' by default on most web pages (like news articles, wiki page, etc.).
[Speech in Windows]
  • We have improved our speech-to-text and text-to-speech experience on Windows. Users of Narrator, voice access, live captions, live translations, and voice typing might see a message asking them to update their language files manually. The language files will be released separately through Microsoft Store.
[Taskbar & System Tray]
  • Fixed an issue causing explorer.exe to crash sometimes when interacting with app icons in the taskbar in the latest flights.
[Desktop]
  • Fixed the issue where your desktop background may not show correctly sometimes with multiple monitors (showing big black areas).
[File Explorer]
  • Did some work so the search box in File Explorer shouldn't draw off the end of the window anymore.
[Input]
  • Fixed an underlying issue in the last few flights that could cause Windows wheel devices to not scroll.
[Narrator]
  • Fixed an issue in the previous flight which caused Narrator to crash on launch if you used one of the natural voices (like Jenny).
Previewing More Copilot+ Experiences with Windows Insiders in the Dev Channel
New experiences for AMD and Intel-powered Copilot+ PCs
The following experiences are rolling out to Windows Insiders in the Dev Channel on AMD and Intel-powered Copilot+ PCs. Please install all the latest driver updates available from Windows Update to ensure the following experiences, like Recall, work correctly on your PC. To ensure you have the latest drivers for your Copilot+ PC, make sure the "Get the latest updates as soon as they're available" toggle is on under Settings > Windows Update. Just click the "Check for updates" button and install any new drivers that Windows Update delivers to you.
If you'd like to test the latest driver versions available directly from our partners before they get to Windows Update, you can download them directly here:
Recall (Preview)
After previewing Recall with our Windows Insider community on Snapdragon-powered Copilot+ PCs, we are expanding the preview of Recall to Windows Insiders on AMD and Intel-powered Copilot+ PCs. This includes Click to Do in Recall as well. With the AI capabilities of Copilot+ PCs, it's now possible to quickly find and get back to apps, website, image, or document just by describing its content.
We continue to invite you to try out Recall and share feedback, issues, or suggestions for improvement through in-experience links or the Feedback Hub. We also want to recognize the contributions of researchers and the security community in shaping Recall. If you're an Insider also in this group, we additionally invite feedback on Recall's updated security and privacy architecture through participation in our Windows Insider Preview Bug Bounty Program.
To get started, check out this blog post which highlights all the steps required to opt-in to using Recall and saving snapshots on your Copilot+ PC.
As we gradually roll out Recall in preview, Recall is supported on select languages including Chinese (simplified), English, French, German, Japanese, and Spanish. Content-based and storage limitations apply. See here for more details. Recall is not yet available in all regions, with expanded availability coming over time. As part of today's update, we're expanding the roll out of Recall (Preview) through the Windows Insider Program to the European Economic Area (EEA).
As a reminder for when we first preview new features with Windows Insiders, you may encounter some known issues listed at the bottom of this blog post we highly recommend you read.
Cocreator in Paint
Microsoft Paint is your creative companion, making it effortless to bring your visions to life. The latest update to the Paint app (version 11.2410.1002.0 and higher) brings Cocreator to AMD and Intel-powered Copilot+ PCs. Paint Cocreator allows you to create amazing artwork with the help of AI. You can enter a text prompt and start drawing on the Paint canvas, and Cocreator will generate beautiful artwork based on your input, all for free and without the need for a subscription.
We are beginning to roll out Cocreator to AMD and Intel-powered Copilot+ PCs, so it may not be available on your PC just yet.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Apps > Paint.
Restyle Image and Image Creator in the Photos app
In the latest update to the Microsoft Photos app, we are introducing Image Creator and Restyle Image to AMD and Intel Copilot+ PCs. These advanced AI-powered features are designed to unlock new creative possibilities—all powered locally on your device for fast and seamless performance.
Image Creator lets you generate brand-new images from simple text prompts. For example, you can type "a serene lake at sunset" or "a vibrant city skyline at night," and the AI will transform your idea into a feed of images. Whether you're seeking inspiration or crafting the perfect visual, Image Creator delivers endless possibilities for creativity.
Restyle Image allows you to take an existing photo and apply a variety of artistic styles. Whether you want to give your vacation photos a vintage aesthetic or turn a casual snapshot into a bold modern artwork, Restyle Image makes it effortless.
To get these new features, update your Photos app to version 2024.11120.1001.0 or higher via the Microsoft Store. This update is currently rolling out, so it may not be available right away. Don't forget to share your creations with us!
FEEDBACK: Please file feedback in Feedback Hub (Win + F) under Apps > Photos.
New ways to engage with Click to Do (Preview)
In addition to expanding support for Click to Do with Recall to AMD and Intel-powered Copilot+ PCs, today's update also introduces new ways for you to effortlessly engage with Click to Do outside of Recall on Copilot+ PCs. You can now engage with Click to Do by simply pressing WIN key + mouse-click, WIN + Q, through the Snipping Tool menu and print screen, or searching "Click to Do" through the search box on the Windows taskbar. These methods will make it easier than ever to take immediate action on whatever catches your eye on-screen.
We're also working on introducing more intelligent text actions to enhance your Click to Do experience even further. Use WIN key + mouse-click or WIN + Q to select a text block and then drag to select the text that you want. You'll see options to Summarize or to help you Rewrite your text, so it sounds more causal or more formal.
Click to Do is the first experience to leverage the capabilities of Phi Silica, the on-device Small Language Model (SLM) that is built right into Windows. Results from our local model will show directly inline and if you're happy with the rewrites you can copy them directly to your clipboard for use anywhere. These more intelligent text actions are available on Snapdragon-powered Copilot+ PCs today when your language is set to English with support for AMD and Intel-powered Copilot+ PCs coming soon.
The intelligent text actions leverage the power of Microsoft's secure cloud to improve your text results by ensuring prompts and responses are safe and appropriate. This data is automatically deleted. The analysis of your screen is always performed locally on your device. Content is only shared out of Click to Do if you choose to complete an action, like copying text to your clipboard, for use in another app, or sharing an image with Bing for a visual search.
You can continue to use the same image and text actions you saw for the Click to Do in the Recall experience we released two weeks ago as well including on AMD or Intel-powered Copilot+ PCs too. Click to Do in Recall will recognize text and images in snapshots and offers AI powered actions you can take on these. Just press the Windows logo key and left mouse-click on any image in a snapshot in Recall to get options like Copy, Save, Share, Visual Search with Bing, Blur background with Photos, or Remove background with Paint. And by pressing the WIN key and left mouse-click on any text in a snapshot will give you options to Copy, Search the web, or send email or open a website if an email or URL is recognized.
To use Click to Do, you will need to have Recall enabled on your Copilot+ PC but do not have to opt in to having snapshots saved.
You can learn more about using Click to Do here.
This update (Build 26120.2510) includes other changes and improvements available to Windows Insiders across all Windows 11 PCs in addition to the features noted above that are exclusive to Copilot+ PCs. These changes are documented below in two buckets:
For more information, see the Reminders section at the bottom of the referenced blog post.
New features gradually being rolled out to the Dev Channel with toggle on
Modernized Windows Hello
At Microsoft, we are committed to security and enhancing user experiences. As part of this commitment, we launched enhanced passkey features in September 2023 and are now revamping the Windows Hello user experience. This represents a significant update to Windows Hello, aligning it with contemporary Windows visual design standards. The primary focus is on making authentication intuitive and seamless.
Modernized Windows Hello Visual Communication: The updated Windows Hello visuals are designed to facilitate fast and clear communication and appear on the Windows Sign-in screen as well as other authentication flows such as passkey, Recall, Microsoft Store and many more.
Revamped Windows Hello credential user experience for passkeys and the new administrator protection experience: We redesigned Windows security credential user experience for passkey by creating a cleaner experience that supports secured and quick authentication. Users will now be able to switch between authentication options and select passkey/devices more intuitively.
This experience will also apply for the new administrator protection feature coming to Windows 11, version 24H2 and higher and currently in preview with Windows Insiders in the most recent Canary Channel builds. For more information on administrator protection – you can check out this blog post that highlights our investments in adminless experiences in Windows from Microsoft Ignite.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Security and Privacy > Passwordless experience.
  • The more simplified system tray with shortened form date/time we began rolling out with Build 26120.1843 is being temporarily disabled to address a few issues. Thanks to all the Insiders who gave us feedback on this experience.
  • Fixed a few issues impacting taskbar and explorer.exe reliability.
[Audio]
  • Fixed an underlying issue which could lead to USB audio devices going to sleep after 1 minute of idle time, and not waking up until the PC was rebooted.
  • Fixed an underlying issue which could lead you to unexpectedly hear a mute or unmute noise in certain headsets.
  • Fixed an underlying issue that could lead to the audio on certain audio devices unexpectedly going to 100% on boot or after sleep.
[Other]
  • Fixed an underlying issue which could lead to Excel sometimes hanging on launch when opening certain files.
[Recall]
  • Fixed an issue where Recall didn't warn that you must have Secure Boot enabled for Recall to save snapshots.
  • Improved the experience for submitting feedback for Recall by adding a loading dialog.
  • Fixed an issue where some users experience a delay before snapshots first appear in the timeline while using their device.
  • Fixed an issue where Recall won't save any snapshots if you join the Dev Channel and install Build 26120.2415 after installing KB5046740.
[Other]
  • [Exporting chart objects] Fixed: An app stops responding when it exports chart objects in PDF and XLSX formats.
  • [Internet connection] Fixed: A small number of devices cannot connect to the internet. This occurs when a DHCP server response has duplicate DHCP options. This stops IPv4 connections on certain networks.
  • [Display] Fixed: Some secondary displays might experience lag and screen tearing when a window is in full screen.
  • [HTML Applications (HTA)] Fixed: HTA optional components (OC) are now in ARM64 Windows PE.
Announcing Windows 11 Insider Preview Build 26120.2702 (Dev Channel)
Windows Camera Advanced Configurations
We are beginning to roll out a new advanced camera options page. Just navigate to a camera under Settings > Bluetooth & devices > Cameras and click the edit button for advanced camera options.
This new advanced camera options page will provide you with the following two configurations for your camera:
  • Multi-app camera: Allows multiple applications to access the camera stream simultaneously, developed with the Hard-of-Hearing community to enable video streaming to both a sign language interpreter and the end audience at the same time.
  • Basic camera: Enables basic camera functionality for improved debugging, recommended as a last resort when your camera is not functioning correctly. This feature was developed in collaboration with Microsoft support agents.
Coming in a future build, we plan to introduce a third option here for selecting a media type. This feature will let you choose different media types like resolution and frame rate, with the default setting being "Let Windows Choose" for optimal experience.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Devices and Drivers > Device Camera or Webcams.
Passwordless Improvements
As part of Microsoft's commitment to a passwordless future, on Windows, we are launching API support for third-party passkey providers. Microsoft has been engaging with passkey manager partners on developing this capability. We are committed to bringing a passwordless future to all customers – together with third-party credential providers, we will raise the bar on login security with passkeys for all users on Windows.
WebAuthn Plugin Authenticator APIs
We are releasing updates to WebAuthn APIs to support a plugin authentication model for passkeys. In the coming months, Windows customers will be able to choose a third-party provider as an additional choice alongside the native Windows passkey provider while maintaining the Windows Hello user experience. Messages in WebAuthn flows will be forwarded to the plugin and responses are returned to the WebAuthn client applications. This enables plugins to create and authenticate with passkeys when requested by the customer. This model allows plugins to use Windows Hello as a user verification mechanism to enable a seamless passkey experience. You will notice additional user experience updates to the passkey flows and Settings alongside the new capabilities.
If you are a developer for third-party passkeys, we invite you to integrate with Windows 11 to support customers in their passkey journey. To find out more about implementation detail, go to https://aka.ms/3P-Plugin-API.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Security and Privacy > Passkey.
[Start menu]
  • We are improving the filtering for recommended websites on the Start menu based on feedback from Windows Insiders so that we show the highest quality sites based on your own browsing history. Please continue to give us feedback if you see a website recommended you feel shouldn't be.
[Settings]
  • The ability to change time zones is available again under Settings > Time & Language > Date & Time for standard (non-admin) users.
[Input]
  • Fixed an issue where if pointer trails were enabled, the mouse cursor may become invisible with a black box behind it.
  • Mitigated an issue where the ALT or Shift key on the keyboard may get stuck down in the latest flights after the Windows Hello prompt appeared for some Insiders.
  • Fixed an issue which could lead to the mouse cursor unexpectedly stuttering when you moved it around sometimes.
[Graphics]
  • Fixed an underlying issue which could result in some games appearing oversaturated when using Auto HDR.
[Rollback]
  • We fixed the issue where if you roll back from Build 26120.2510 to an earlier build, you would see an "Your organization used App Control for Business to block this app" dialog when attempting to use or install certain third-party apps on your PC due to an incorrect policy being enforced.
Releasing Real-Time Translation in Live Captions to More Copilot+ PCs in the Dev Channel
Note:  This is the last flight to be released this year.
This update is previewing real-time translation in live captions for AMD and Intel®-powered Copilot+ PCs. There is also an improvement for real-time translation on Snapdragon-powered Copilot+ PCs as well. Beyond these two changes, this update is the same as the update released to the Dev Channel last week.
New experiences for AMD and Intel®-powered Copilot+ PCs
Please install all the latest driver updates available from Windows Update to ensure the following experience work correctly on your AMD or Intel®-powered Copilot+ PC. To ensure you have the latest drivers for your Copilot+ PC, make sure the "Get the latest updates as soon as they're available" toggle is on under Settings > Windows Update. Just click the "Check for updates" button and install any new drivers that Windows Update delivers to you.
Live captions and real-time translation
We are enhancing communication on AMD and Intel®-powered Copilot+ PCs with live captions and real-time translation. We're beginning to roll out the ability in live captions to translate more than 44 languages into English, including speakers in real-time video calls, recordings and streamed content. Real-time translation is rolling out AMD and Intel®-powered Copilot+ PCs with English as the primary language in use.
Note the known issues for real-time translation in live captions:
[Live captions & real-time translation]
The following known issues will be fixed in future updates to Windows Insiders:
  • Some Insiders may see a crash on first launch of live captions. Restart live captions if you encounter this issue and you will not see it again.
  • If audio is playing or the microphone is enabled, switching languages will crash live captions. Stop audio when changing languages to resume captions or translations.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Accessibility > Live captions.
[Live captions]
  • On Snapdragon-powered Copilot+ PCs, we're beginning to roll out the ability to do real-time translation to Chinese (Simplified). Supported languages include Arabic, Bulgarian, Czech Danish, German, Greek English Spanish, English, Estonian, Finnish, France, Hindi, Hungarian, Italian, Japanese, Korean, Lithuanian, Norwegian, Dutch, Polish, Portuguese, Romanian, Russian, Slovak, Slovene, and Swedish.
Previewing Improved Windows Search on Copilot+ PCs with Windows Insiders in the Dev Channel
Windows 11 Insider Preview Build 26120.2992 (KB5050083) to the Dev Channel previewing improved Windows Search with Windows Insiders with Snapdragon-powered Copilot+ PCs.
We are making finding your documents, photos, and settings across Windows 11 easier on Copilot+ PCs by introducing semantic indexing along with traditional indexing. Whether it's searching in File Explorer, in the Windows search box on your taskbar, or in Settings – just type what's on your mind to find it on your Copilot+ PC. You no longer need to remember file names, exact words in file content, or settings names. For example, you can use your own words to find images by typing "bridge at sunset", documents by describing what they are about like "Europe trip budget", or settings like "change my theme". Thanks to the power of the 40+ TOPS NPU onboard Copilot+ PCs, these search improvements work even when you're not connected to the internet.
Today, searching for files on your Copilot+ PC with improved Windows Search will only work for files saved locally in indexed locations on your PC. You can go to Settings > Privacy & security > Searching Windows to adjust which locations are indexed on your PC or turn on "Enhanced" to index your entire PC. In a future flight, we will support searching for documents and photos stored in cloud storage providers such as OneDrive.
Searching for settings like "change my theme" will work within the Settings app for now. In a future flight, you will be able to do this within the Windows search box on the taskbar.
These improved Windows Search experiences will gradually roll out to Windows Insiders on Snapdragon-powered Copilot+ PCs, with support for AMD and Intel-powered Copilot+ PCs coming soon. These experiences are supported in select languages (Chinese, English, French, German, Japanese, and Spanish) and document formats. Supported file formats include .txt, .pdf, .docx, .doc, .rtf, .pptx, .ppt, .xls, .xlsx for documents and .jpg/.jpeg, .png, .gif, .bmp, .ico for images. See here for more details.
You can learn more about semantic search on Copilot + PCs here.
FEEDBACK for File Explorer Search: Please file feedback in Feedback Hub (WIN + F) under Files Folders and Online Storage > File Explorer Search.
FEEDBACK for Windows Taskbar Search: Please file feedback in Feedback Hub (WIN + F) under Desktop Environment > Search.
FEEDBACK for Settings Search: Please file feedback in Feedback Hub (WIN + F) under Settings > Search Settings.
New text action for Click to Do (Preview)
You'll see a new text action for Click to Do available on Copilot+ PCs called Refine. To try this out, press Win + Click directly on a block of text or press Win + Q and then navigate to the text you'd like to proofread and refine. When you open the menu, the new action will be under Rewrite > Refine.
All the other actions you've seen in Click to Do are still here. If anything looks missing, please check the Microsoft Store for the latest Photos and Paint apps installed.
This update (Build 26120.2992) includes other changes and improvements available to Windows Insiders across all Windows 11 PCs in addition to the features noted above that are exclusive to Copilot+ PCs. These changes are documented below in two buckets:
[File Explorer]
  • We've added a New Folder option in the context menu when right-clicking locations in the navigation pane.
[Magnifier]
  • We're adding a new keyboard shortcut CTRL + ALT + Minus for Magnifier users to quickly toggle between the current zoom and 1X zoom.
  • In addition to the keyboard shortcut CTRL + ALT + Minus to quickly toggle between the current zoom and 1X zoom, we have also added buttons in Magnifier to reset zoom to fit to screen and reset zoom to your last/preferred magnification.
[File Explorer]
  • Fixed an issue where the date/time properties of files were unexpectedly updated in some cases after copying them.
  • Fixed an issue where File Explorer may sometimes lose focus on the search box while typing.
  • Fixed an issue where when you did a search it may unexpectedly trigger the search happening repeatedly.
  • Fixed an issue where the Details Pane icons weren't responding correctly to theme changes, making it hard to see if you switched from dark to light or vice versa.
  • Fixed a black flash in File Explorer that appeared when duplicating a tab.
[Task Manager]
  • Fixed an issue where Task manager wrongly identified an HDD as an SSD.
[Click to Do]
  • We fixed the issue where Click to Do would sometimes not highlight any info on screen if there is no content on a connected external monitor in extended mode.
Changes and Improvements gradually being rolled out to everyone in the Dev Channel
[Windows Backup]
  • You will now have a standard Windows 11 taskbar after restoring from a backup via the Windows Setup experience (OOBE) on a new Windows PC. You can still find your apps in the Start menu and Search and pin apps you want to your taskbar.
[Other]
  • [Windows Kernel Vulnerable Driver Blocklist file (DriverSiPolicy.p7b)] This update adds to the list of drivers that are at risk for Bring Your Own Vulnerable Driver (BYOVD) attacks.
Announcing Windows 11 Insider Preview Build 26120.3000 (Dev Channel)
Improving the battery iconography in Windows 11
Introducing new and improved battery icons in Windows 11! These icons have been designed to communicate battery status of your PC with just a quick glance. Key changes include colored icons to indicate charging states, simplified overlays that don't block the progress bar, and an option to turn on battery percentage.
When your battery icon is green, this shows that your PC is charging and in a good state. A yellow battery icon will let you know that your PC using battery in energy saving mode – this automatically happens when your battery is less than or equal to 20% to preserve power. When the battery icon is red, you have a critically low battery and should plug in your PC as soon as possible. You will see these new battery icons on the taskbar in the system tray, in the quick settings flyout, and in Settings. The new battery icons will begin showing on the Lock screen in a future flight.
As always, your PC's battery status and more will also be available to you when you hover over the battery icon in the system tray and under Settings > System > Power & battery where you can also adjust the battery level percentage in which energy saver mode kicks on for your PC.
Along with the updates to the battery icon, we are also introducing the ability to show your battery percentage next to the battery icon in the system tray – a highly requested feature by Insiders and customers. To enable this, go to Settings > Power & battery and toggle on the "Battery Percentage" setting.
[We are beginning to roll this out to Windows Insiders in the Dev Channel, so the experience isn't available to all Insiders just yet as we plan to monitor feedback before pushing it out to everyone.]
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Power and Battery > Battery.
[Input]
  • After being temporarily disabled to address some issues with Build 26120.2213, we are beginning to roll out a new Gamepad keyboard layout for the touch keyboard in Windows 11 again. This change introduces the ability to use your Xbox controller to navigate and type. This includes button accelerators (example: X button for backspace, Y button for spacebar) additionally the keyboard keys have been vertically aligned for better controller navigation patterns.
[Narrator]
  • We have added new functionalities to Narrator scan mode. Jump to list item (I') allows you to quickly access and jump to a list item on a page or a document. Beginning and end of element (Comma (,)  and Period (.)) allow you to quickly jump to the beginning or end of large tables, lists or landmarks. This is most helpful when navigating through long emails, news articles, and wiki pages. To try these new features, you need to turn on Narrator first (Win key + Ctrl + Enter), then turn scan mode ON by pressing Caps Lock + Spacebar and finally use the new shortcuts – 'I', ',' and '.'. Please note that scan mode is 'ON' by default on most web pages (like news articles, wiki pages, etc.).
[Search on the Taskbar]
  • Improved support for web search providers in Windows Search for the EEA, including clearer provider attribution in tabs.
[Oher]
  • Suggested actions that appear when you copy a phone number or future date in Windows 11 are now deprecated. With this build, we're beginning to disable the feature.
[General]
  • Fixed an underlying issue which was causing significant performance degradation for a small population of Insiders in the previous flight due to repeated background crashes.
[File Explorer]
  • Fixed an issue where sometimes you would be unable to navigate by entering a path in the address bar.
  • Fixed an issue where the File Explorer address bar unexpectedly overlapped with content while in full screen (F11) view.
  • Improved performance of context menu launches for people when right-clicking on cloud files.
  • Made a change to help ensure thumbnails for cloud files are displayed more consistently in search results within File Explorer.
  • Fixed an issue where searching might lose keyboard focus on the text box while you were typing.
[Other]
  • Fixed an underlying issue which could lead to scanners not being detected by scanning apps, although the scanner was connected.
  • Fixed an underlying issue which could result in 2 in 1 PCs unexpectedly changing screen orientation when coming out of sleep.
Announcing Windows 11 Insider Preview Build 26120.3073 (Dev and Beta Channels)
Important:
This update includes previewing the ability to use improved Windows Search to find files saved in your OneDrive with Windows Insiders with Snapdragon-powered Copilot+ PCs. There is also a small Paint update rolling out.
There is now a window to switch from the Dev Channel to the Beta Channel if you would like. This window will only be open for as long as the same 24H2-based updates across both the Dev and Beta Channels are being released. By the end of February, the Dev Channel will jump ahead to receiving updates with higher build numbers and once this happens, the opportunity to switch between these channels will close. When the Dev Channel jumps ahead, things might not be as stable as the Dev Channel is today, so Dev Channel Insiders are highly encouraged to evaluate which channel you would like to be in during the time in which the window to switch is open.
Find photos saved in the cloud with improved Windows Search
A few weeks ago, we began previewing improved Windows Search with Windows Insiders on Copilot+ PCs. In that first preview, we introduced semantic indexing along with traditional lexical indexing for finding files saved locally in indexed locations on Copilot+ PCs with 40+ TOPS NPU onboard.
Today, we are excited to announce support for also finding photos saved in the cloud with improved Windows Search. Just use your own words to find photos stored and saved in the cloud by describing what they are about like "European castles" or "summer picnics" in the search box at the top right corner of File Explorer. In addition to photos stored locally on your Copilot+ PC, photos from the cloud will now show up in the search results together. In addition to searching for photos, exact matches for your keywords within the text of your cloud files will show in the search results.
Finding photos saved in the cloud currently works when searching within File Explorer directly. This will also work directly from the Windows search box on the taskbar in a future flight.
You can try this experience out today with your personal OneDrive when signed in with your Microsoft account and connected to the internet. If you are signed into OneDrive with a work or school account (Entra ID), you will only see matches for keywords you are searching for within the text of your cloud files in the search results – not photos. Third-party cloud providers will be able to support this experience with their services as well with documentation coming soon.
We're excited to introduce a new way to find your cloud content in Windows and will continue improving search results and capabilities over time. These improved Windows Search experiences continue to gradually roll out to Windows Insiders on Snapdragon-powered Copilot+ PCs, including finding photos saved in the cloud, so you may not see these experiences right away. Support for AMD and Intel-powered Copilot+ PCs is coming soon. See here for more details.
Other changes that are included in this Dev and Beta Channel update
This update (Build 26120.3073) includes other changes and improvements available to Windows Insiders across all Windows 11 PCs in addition to the features noted above that are exclusive to Copilot+ PCs. These changes are documented below in two buckets:
[Settings]
  • We are starting to roll out the Settings homepage for commercial customers on PCs managed by an IT administrator. The feature will show some existing cards relevant to enterprise-managed PCs like "Recommended settings" and "Bluetooth devices" as well as two new enterprise-specific device info and accessibility preferences cards. For commercial customers who also use their Microsoft account on their managed PC, there will also be a new accounts card indicating the presence of both work and school and Microsoft account types. We are starting the rollout of this gradually with managed commercial PCs who have both work and school, and Microsoft accounts presently seeing this experience first.
  • Fixed an issue which was causing the taskbar preview windows to not display sometimes when hovering over open apps in the taskbar.
[File Explorer]
  • We did some work to help address an issue where File Explorer might hang when browsing a folder with lots of media in it.
  • Fixed an issue where if you opened a File Explorer window and minimized it in, it might not be rendered correctly when you restored it.
[Improved Windows Search]
  • Fixed the issue where in some rare cases, searching on Outlook while offline might result in some results not being found.
[Live Captions]
  • Fixed an issue where live captions might show an icon in the taskbar, but the window wouldn't display on the screen, after disconnecting a second monitor.
[Remote Desktop]
  • Fixed an issue which was causing Remote Desktop to show significant display / rendering issues when connecting to certain other computers.
[Settings]
  • Fixed an issue which was causing Settings to crash when interacting with the Bluetooth & Devices page sometimes.
[Other]
  • Fixed an issue where when using GDI+ to shrink an image, the colors may be wrong afterwards..
  • Fixed an issue which could cause shutdown to be noticeably slower on certain devices when a controller was connected.
  • Fixed an underlying issue causing the Windows Security pop up when signing into certain Wi-Fi networks to not be interactable. This may have also impacted interacting with this pop up for certain other options in Settings.
  • Fixed an issue where the description for virtual NICs wasn't displayed correctly in ncpa.cpl, it showed garbled characters.
[General]
  • We fixed the issue causing a 0xc0e90001 error to occur when booting into Windows Recovery (WinRE) on Arm64 PCs.
[Other]
  • [Memory leak] Fixed: Leaks occur when predictive input ideas show.
  • [High dynamic range (HDR)] Fixed: The display of some games appears oversaturated. This occurs when you use Auto HDR.
  • [Remote Desktop Gateway] Fixed: You get errors or cannot sign when you connect to Windows 11 workstations. This occurs when you enforce device redirection.
  • [USB audio device drivers] Fixed: The code 10 error message, "This device cannot start" appears. This occurs when you connect to certain external audio management devices.
Announcing Windows 11 Insider Preview Build 26120.3281 (Dev and Beta Channels)
Note: The same Dev Channel updates based on Windows 11, version 24H2 are offered to Windows Insiders in the Beta Channel. These updates will be optional at first, so if you are in the Beta Channel today, you can upgrade when you are ready to do so. The plan is to make these updates recommended later this year, which means you will eventually get upgraded to 24H2-based updates automatically in the Beta Channel.
If you are an Insider in the Dev Channel, the window is open to switch from the Dev Channel to the Beta Channel if you would like. This window will only be open for as long as the same 24H2-based updates (same build numbers) are released across both the Dev and Beta Channels. When the Dev Channel jumps ahead (higher build numbers), the window to switch will close. This window is closing soon, so you are highly encouraged to evaluate which channel you would like to be in during the time in which the window to switch is open.
Ability to seamlessly resume OneDrive files in 1-click from your phone to PC
We are gradually rolling out the ability to seamlessly resume working on OneDrive files from your phone (iOS and Android) on your Windows 11 PC with a single click. With this feature, you will get a notification asking you if you want to pick up where you left off editing a OneDrive file like a Word doc that you last viewed or edited on your phone within a 5-minute time window preceding unlocking your PC.
Upon clicking on this notification, the same file that you were viewing or editing previously on your phone will open in your default browser on your PC.
Here are some important details about how this feature works:
  • This feature works only when signing into OneDrive with a Microsoft account. Work and school accounts are not supported. And you need to be using the same Microsoft account signing into OneDrive on your phone and signing into your Windows 11 PC.
  • This feature supports Word docs, Excel spreadsheets, PowerPoint presentations, OneNote notebooks/pages, and PDFs.
  • The OneDrive file must be opened on your phone when your PC is locked. If you then unlock your PC within 5 minutes of accessing the file on your phone, you will receive the resume notification as noted above.
  • For the best experience using this feature, you should be logged into OneDrive in your default browser on your PC.
This feature can be managed and turned off via Settings > Apps > Resume.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Devices and Drivers -> Linked Phone.
[Recall (Preview)]
Recall is currently available in preview for Windows Insiders on Windows 11, version 24H2 in the Dev and Beta Channels on Copilot+ PCs.
  • We're improving Recall on the next update. This important update will improve your experience. As part of this upcoming update, your existing snapshots will be deleted.
  • Recall filtering options are now easily accessible via the Recall system tray flyout instead of having to set filtering directly in Settings.
  • We are rolling out the ability to share files directly from the jump lists on the taskbar, which appears when you right-click on an app with a jump list like Notepad the taskbar.
[Snap]
  • We are introducing an improvement to Snap in Windows 11 aimed at driving contextual learning and discovery of the feature. Inline messaging will now appear when you accidentally invoke the Snap Bar when dragging an app to the top middle of your desktop or Snap Flyout when hovering over the Minimize or Maximize button of an app. This messaging is designed to provide guidance on snapping app windows and educating users on the keyboard shortcuts for quickly snapping app windows in the future. We are trying several variants of this experience out.
[File Explorer]
  • When "Restore previous folder windows at logon" is enabled in File Explorer, we will also now restore all the extra tabs which you previously had open in each File Explorer window. As part of this work, we have also updated the logic for the "Automatically save my restartable apps and restart them when I sign back in" setting via Settings > Accounts > Sign in options, so that when you enable this, we will automatically enable the File Explorer specific setting for you too.
  • We're adding a new option to snooze or turn off the "Start backup" reminder in the File Explorer address bar, for those that aren't already backing up their Documents, Pictures, or Desktop folders. This option is available when you right-click "Start backup".
[Spotlight on the lock screen]
  • We're trying out a few different treatments for the top right hotspot ("Like the image that you see") on the lock screen. You can now learn more about the spotlight image on your lock screen by clicking on the "Like icon" that takes you to the Spotlight landing page.
[Spotlight on the desktop]
  • We're beginning to roll out some changes to the Desktop Spotlight icon interaction model for Windows Insiders. You can now quickly and easily discover more information about your background image by simply hovering over or clicking on the "Learn about this picture" icon on your desktop.
  • We're beginning to roll out some additional changes to the Desktop Spotlight icon for Windows Insiders to help with discoverability including changes to the icon color/backplate and moving the icon to the bottom right position on your desktop.
[Settings]
  • Game Pass Ultimate and PC Game Pass subscribers coming to Settings homepage will begin to see a new card for referring a PC Game Pass subscription to their friends to try PC Game Pass for free. This new card will only appear on the Settings homepage if you're signed into your PC with your Microsoft account and meet the required eligibility criteria.
  • We are temporarily disabling the Settings homepage for commercial customers on PCs managed by an IT administrator which began rolling out with Build 26120.3073. We plan to address some issues and roll it out again in a future flight.
[Other]
  • We are removing the Location History feature, an API used by Cortana to access 24 hours of device history when location was enabled. With the removal of the Location History feature, location data will no longer be saved locally, and the corresponding settings are also being removed from Settings > Privacy & security > Location page.
[General]
  • Fixed the issue causing unexpectedly high DCOM CPU usage for some Insiders after opening the Performance section of Task Manager
[Lock screen]
  • Fixed an issue in recent flights where if you tried to reset your password from the login screen, it wouldn't work due to an underlying crash.
[File Explorer]
  • As part of our ongoing commitment to improving File Explorer accessibility, this release includes increased support for the text scaling (via Settings > Accessibility > Text size) across File Explorer, File Open/Save dialogs and the copy dialogs.
  • Fixed an issue causing the see more "..." menu in the command bar to open in the wrong direction for some resolutions.
  • Fixed an issue when using multiple monitors, where the distance between the date and time and edge of the screen wasn't consistent.
The following fixes are rolling out for improved Windows Search on Snapdragon-powered Copilot+ PCs:
  • Fixed the issue where the AI sparkle and underline animation in the File Explorer search box was not present.
  • The search box on the taskbar now has the AI sparkle and underline animation just like the File Explorer search box has.
  • Fixed the issue where In some rare cases, improved Windows search experiences may not be available and may require a reboot to start working.
  • Fixed the issue where in some rare cases, File explorer search might be unresponsive and may require a reboot to start working.
  • Fixed the issue where the tip about the new search improvements would appear whenever you set focus to the search box in File Explorer, rather than only once.
[Input]
  • Fixed an issue where if you were using a non-default mouse color (enabled in Settings > Accessibility > Mouse pointer and touch), it may unexpectedly revert back to white when you encountered a UAC dialog.
[Settings]
  • Fixed an issue causing Settings to crash on launch for some Insiders.
[Other]
  • Fixed an issue for Shared PC users, where when signing in with a Guest account using Shared PC, the sign in may fail. This happened if DeviceLock password policies were configured.
[File Explorer]
  • We are disabling account-based content in File Explorer under Recent, Favorites, Details Pane, and Recommended for Entra IDs in the European Economic Area (EEA).
Announcing Windows 11 Insider Preview Build 26120.3291 (Dev and Beta Channels)
The update includes two improvements for Windows Insiders on Copilot+ PCs:
  • We are previewing the ability to use improved Windows Search to find files saved in the cloud directly from the Windows search box on the taskbar with Windows Insiders with Snapdragon-powered Copilot+ PCs.
  • This update improves your Recall (Preview) experience and as a result, your previous snapshots were deleted. After installing this build, Recall will continue to save new snapshots normally going forward only if you have the option to save snapshots turned on in Settings.
As a reminder – we're also offering the same Dev Channel updates based on Windows 11, version 24H2 to Windows Insiders in the Beta Channel. These updates will be optional at first, so if you are in the Beta Channel today, you can upgrade when you are ready to do so. We plan to make these updates recommended later this year, which means you will eventually get upgraded to 24H2-based updates automatically in the Beta Channel.
If you are an Insider in the Dev Channel, the window is open to switch from the Dev Channel to the Beta Channel if you would like. This window will only be open for as long as we're releasing the same 24H2-based updates (same build numbers) across both the Dev and Beta Channels. When the Dev Channel jumps ahead (higher build numbers), the window to switch will close.
IMPORTANT: This window is closing soon, so we highly encourage you to evaluate which channel you would like to be in during this time in which the window to switch is still open.
Find photos saved in the cloud via the Windows search box with improved Windows Search
We are excited to extend support for finding photos saved in the cloud with improved Windows Search to the Windows search box on the taskbar. Just use your own words to find photos stored and saved in the cloud by describing what they are about like "European castles" or "summer picnics" in the search box on your taskbar. In addition to photos stored locally on your Copilot+ PC, photos from the cloud will now show up in the search results together. In addition to searching for photos, exact matches for your keywords within the text of your cloud files will show in the search results.
You can try this experience out today with your personal OneDrive when signed in with your Microsoft account and connected to the internet. If you are signed into OneDrive with a work or school account (Entra ID), you will only see matches for keywords you are searching for within the text of your cloud files in the search results – not photos. Third-party cloud providers will be able to support this experience with their services as well, with documentation coming soon.
We're excited to introduce a new way to find your cloud content in Windows and will continue improving search results and capabilities over time. The improved Windows Search experiences continue to gradually roll out to Windows Insiders on Snapdragon-powered Copilot+ PCs, including finding photos saved in the cloud, so you may not see these experiences right away. Some of these improved Windows Search experiences are not yet available in all regions, with expanded availability coming over time. Support for AMD and Intel-powered Copilot+ PCs is coming soon. See here for more details.
NOTE: For improved Windows Search on Copilot+ PCs, it is recommended that you plug in your Copilot+ PC for the initial search indexing to get completed. You can check your search indexing status under Settings > Privacy & security > Searching Windows.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Desktop Environment > Search.
Changes and Improvements gradually being rolled out to the Dev Channel with toggle on
[Recall (Preview)]
  • [IMPORTANT] As mentioned last week, this update improves your Recall experience and as a result, your previous snapshots were deleted. After installing this build, Recall will continue to save new snapshots normally going forward only if you have the option to save snapshots turned on in Settings.
[Other]
Fixes gradually being rolled out to the Dev Channel with toggle on
The following fixes are rolling out for live captions and real-time translation on Copilot+ PCs:
  • Fixed the issue where you might see a crash on first launch of live captions.
  • Fixed the issue where if audio is playing or the microphone is enabled, switching languages will crash live captions.
[File Explorer]
  • Fixed a few issues impacting File Explorer reliability for Insiders.
  • Fixed an issue where opening File Explorer from the command line may result in the address bar being empty and not displaying the current path.
  • Fixed an issue where you couldn't select multiple files in the Recommended section of Home by holding Shift and clicking the files.
[Power & Battery]
[Graphics]
  • Fixed an issue which could cause color profiles to not load correctly after waking your PC from sleep.
[Remote Desktop]
  • Fixed an issue where Remote Desktop wouldn't use UDP, only TCP.
Announcing Windows 11 Insider Preview Build 26120.3360 (Dev and Beta Channels)
If you are an Insider in the Dev Channel, the window is open to switch from the Dev Channel to the Beta Channel if you would like. This window will only be open for as long as we're releasing the same 24H2-based updates (same build numbers) across both the Dev and Beta Channels. When the Dev Channel jumps ahead (higher build numbers), the window to switch will close. Please note that switching from the Dev Channel to the Beta Channel may result in the loss of some features temporarily.
Choose what Lock screen widgets appear
We're beginning to roll out support for lock screen widgets (previously referred to as "Weather and more") to Windows Insiders in the European Economic Area (EEA). You can add, remove, and rearrange lock screen widgets such as Weather, Watchlist, Sports, Traffic, and more. Any widget that supports the small sizing option can be added here. To customize your lock screen widgets, navigate to Settings > Personalization > Lock screen. We are starting this rollout first with Insiders in the EEA and plan to expand to Insiders in other regions in the future. Insiders outside the EEA will continue to see the "Weather and more" experience.
As part of this, we're also adding support for a new group policy called "Disable Widgets On Lock Screen" that will allow IT administrators to disable lock screen widgets without disabling widgets elsewhere on PCs they manage. To edit this policy, please launch the Local Group Policy Editor app and navigate to Computer Configurations > Administrative Templates > Windows Components > Widgets. This policy is only supported in EEA regions at this time but will expand to include other regions in the future as well.
  • We are beginning to roll out a change to the way Task Manager calculates CPU utilization for the Processes, Performance, and Users pages. Task Manager will now use the standard metrics to display CPU workload consistently across all pages and aligning with industry standards and third-party tools. For backward compatibility, a new optional column called CPU Utility is available (hidden by default) on the Details tab showing the previous CPU value used on the Processes page.
New CPU utility column option for Details page in Task Manager.
[Windows Share]
  • We are adding the ability to share directly to apps that support sharing in Windows when right-clicking on local files in File Explorer or the desktop.
[File Explorer]
  • Fixed an issue where File Explorer Home might not load correctly and just show random floating text saying "Name".
[Taskbar]
  • Fixed an issue where the underlines under app icons in the taskbar may get stuck showing even if the app had been closed.
[Remote Desktop]
  • Fixed an issue which was leading to some people experiencing Remote Desktop freezes on login, or frequent disconnects.
[Settings]
  • Fixed an issue where an underlying crash was causing Settings to show an error message on launch ("The instruction at 0x00007FFEDEBDC003 referenced memory at 0x0000000000000010. The memory could not be read,"). If impacted, you might also have seen a similar error message with RuntimeBroker.exe.
[Other]
  • Fixed an issue where if you were upgrading to a higher build number and it failed and rolled back, it could potentially result in a duplicate Windows entry in the boot menu.
  • Fixed an issue for Insiders using the ability to resume OneDrive files, which could result in your mouse frequently showing a spinning icon.
Announcing Windows 11 Insider Preview Build 26120.3380 (Dev and Beta Channels)
Releasing Windows 11 Insider Preview Build 26120.3380 (KB5053660) to the Dev and Beta Channels.
Recommended files in File Explorer
Recommended files in File Explorer Home are now available to all Windows Insiders who are signed in with their personal Microsoft account (and local accounts). These files will provide you quick access to relevant files based on your activity in the Recommended section which is displayed as a carousel with thumbnail previews. This includes content such as files you frequently use, have recently downloaded, or added to your File Explorer Gallery. Users with a work/school account (Entra ID) will have additional types of recommendations available with this update. This change is not yet rolling out in the EEA (European Economic Area). Quick access folders will continue to be available in the navigation pane for easy access to pinned folders.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Files Folders and Online Storage > File Explorer.
[Live captions]
  • On AMD and Intel®-powered Copilot+ PCs, we're beginning to roll out the ability to do real-time translation to Chinese (Simplified). Supported languages include Arabic, Bulgarian, Czech Danish, German, Greek English Spanish, English, Estonian, Finnish, France, Hindi, Hungarian, Italian, Japanese, Korean, Lithuanian, Norwegian, Dutch, Polish, Portuguese, Romanian, Russian, Slovak, Slovene, and Swedish.
[Start menu]
  • We are trying out a new change where we will recommend a snap group in the Recommended section of the Start menu based on two apps that are most likely to be snapped together. Let us know what you think if you see this!
  • Improved support for web search providers in Windows Search for the EEA, including with increased discoverability.
[Notifications]
  • To ensure you never lose access to your Microsoft account, we are introducing a new toast notification that will prompt you to add a secondary email or recovery phone number to your account. This will only appear if you're signed in to your PC with your Microsoft account and this information is missing from your profile. Adding these account proofs will help you recover your Microsoft account if you ever forget your password or get locked out for any reason.
[Widgets]
  • In this flight, we're introducing the ability for web developers to easily utilize their existing web content to build dynamic and interactive widgets that can be added to the widgets surfaces in Windows 11. For more information, click here.
[Input]
  • We are trying out a new experience to improve the discoverability of the emoji and more panel in Windows 11 with the introduction of a new system tray icon on the taskbar. With this new system tray icon, you can easily express yourself by using emojis, GIFs, Kaomoji etc. across all apps and surfaces in Windows in addition to using the WIN + . keyboard shortcut which is also now shown on the emoji and more panel. This new system tray icon for the emoji and more panel shows can be changed by right-clicking on the icon to go to taskbar settings page.
[Settings]
  • We are rolling out "top cards" under Settings > System > About. These top cards provide an easy way to view your PC's key specifications—processor, RAM, storage, and GPU—helping you understand your PC's capabilities at a glance. This is designed to simplify decision-making by highlighting potential areas for hardware improvements while giving you a clear snapshot of your PC. Top Cards won't appear yet on managed commercial PCs. Note this change appears only on specific PC form-factors such as desktops.
[File Explorer]
  • As part of our ongoing commitment to improving File Explorer accessibility, this release includes increased support for the text scaling (via Settings > Text size) across File Open/Save dialogs and Wizard dialogs.
[Windowing]
  • Fixed an issue where the Snap Bar at the top of the screen was unexpectedly showing corners on the side closest to the screen.
[Input]
  • Fixed a high hitting ctfmon.exe crash, which could impact the ability to type.
[Settings]
  • Fixed an underlying issue which could lead to Settings crashing when adding a color profile in Settings > System > Display.
  • Fixed an issue where Settings might crash after using Settings to sign into an MSA.
  • Fixed an issue for Japanese users, where the name displayed at the top of Settings > Accounts showed First Name Last Name instead of Last Name First Name.
[Other]
  • Fixed an issue which could lead to a bugcheck with PDC_WATCHDOG_TIMEOUT when resuming from sleep.
  • Fixed an issue with windows.storage.dll in the last few flights, where trying to open files from an app could lead to the app crashing.
Announcing Windows 11 Insider Preview Build 26120.3576 (Dev and Beta Channels)
Voice access commanding made more intuitive and user-friendly
On Snapdragon-powered Copilot+ PCs, we're introducing the ability for you to speak more flexibly while giving existing commands in voice access.
Traditionally, voice commands in voice access would require you to follow a fixed syntax, making interactions rigid and sometimes frustrating. For example, if you said "Can you Open Edge application" instead of "Open Edge" which is the actual command, it wouldn't work. With this improvement to voice access, you can now say "Can you open Edge application", or "Switch to Microsoft Edge", or "Please open the Edge browser". Voice access understands your intent and executes the right action for the voice command you speak. This means that you no longer need to pause and remember the exact phrasing of a command, just say what feels most intuitive.
Just in case something doesn't get picked up correctly, voice access will also show you real-time command suggestions based on your last utterance to help you recollect the right commands.
We're making voice access more flexible, intelligent, and easy to use on your Copilot+ PC. Let us know what you think!
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Accessibility > Voice access.
[Voice access]
  • We are introducing Chinese support for voice access. You can now use Voice access to navigate, dictate, and interact with Windows using voice commands in Simplified Chinese (zh-cn) and Traditional Chinese (zh-tw).
[File Explorer]
[Login and Lock screen]
  • Fixed an issue which could cause the login screen to crash if you clicked the sign in options link.
[Recall (Preview)]
The following fixes are rolling out for Recall on Copilot+ PCs:
  • We fixed the issue where if you were trying out Recall on a PC managed by an IT administrator in your organization (signed in with a Microsoft Entra ID), you would see your Recall snapshots get deleted after installing Build 26120.3380 and after each reboot on that build.
[Settings]
  • Fixed an issue causing an unexpected amount of extra space at the top of Settings > System > Sound, and a couple other pages.
[Printing]
  • Fixed an issue which was causing some Insiders to unexpectedly see a message saying a Send to OneNote driver for printing wasn't working.
  • Fixed an issue where non-admin users couldn't uninstall printers that they'd added.
Announcing Windows 11 Insider Preview Build 26200.5510 (Dev Channel)
Starting today, the Dev Channel is jumping ahead to receive 26200 series builds. This means that the window to switch from the Dev Channel to the Beta Channel is closed and once Build 26200.5510 is installed. If you are in the Dev Channel today and still want to switch to the Beta Channel at the last minute, when Build 26200.5510 is offered you can pause updates in Windows Update and switch your channel to the Beta Channel and un-pause updates.
These 26200 series builds are based on Windows 11, version 24H2 and will contain many of the same features and improvements as the 26120 series builds that will continue to be released in the Beta Channel. Over time, we will be making behind-the-scenes platform changes in these builds and these builds may have different known issues because of those changes than what we're flighting to the Beta Channel.
In the case of Build 26200.5510 today – this build contains the same features and improvements as Build 26120.3576 released previously.
As always, if you experience any issues while you use your PC on these builds we release to the Dev Channel, please file feedback in Feedback Hub.
IMPORTANT NOTE for Insiders on Copilot+ PCs: Please note that when you update from Build 26120.3576 to Build 26200.5510 on your Copilot+ PC, you will see your snapshots in Recall and Recall settings get deleted and reset.
