Pale Moon Version 33.4.1 Released with Security Update
Started by Corrine, November 05, 2024, 03:47:35 PM
Pale Moon has been updated to version 33.4.1. This is a minor security and bug fix update.
Changes/fixes:
  • Added a processor check to the 64-bit installer for Windows to check for AVX.
Note: this check does not work on Window 7/8/8.1 and will allow installations on non-AVX processors there.
Note: if you are running Windows 10 before build 2004 (before 20H1), this check may fail on AVX-capable CPUs and prevent installation.
  • Improved handling of multipart/mixed documents. (CVE-2024-10461 and CVE-2016-2816) DiD
  • Addressed CVE-2024-10463.
Notes: *DiD This means that a fix is "Defense-in-Depth": It is a fix that does not apply to a (potentially) actively exploitable vulnerability in Pale Moon, but prevents future vulnerabilities caused by the same code, e.g. when surrounding code changes, exposing the problem, or when new attack vectors are discovered.
Release Cycle
