OneDrive asks for sign in every time I log in Windows
Started by DR M, June 17, 2020, 04:53:30 PM
Thanks for the update, Panos.  Fingers crossed that this has indeed solved the issue.
The problem returned, then "solved", then returned and so on...
Not the same issue, but OneDrive and v. 2004 are connected with some way in this article:
OneDrive app mysteriously blocks Windows 10 v.2004 update
QuoteMeanwhile, Microsoft has acknowledged that after updating to Windows 10 2004, some older devices or devices with certain older apps installed that use legacy file system filter drivers might be unable to connect to OneDrive via the OneDrive app. To address this issue, Microsoft is currently working on a fix and will provide an update in its upcoming Windows 10 release.
Meanwhile, I set my Windows to sign in with a Microsoft instead of a local account. All is good. Until the problem returns? Well, I hope no!!!
Signing in with a Microsoft account seems that solved the issue so far. :)
Question: in case of no internet connection, will I be able to sign in?
Quote from: DR M on July 14, 2020, 10:17:36 AM
Yes.  However, if the password is changed while not connected, it won't be synced to other devices until connected to the Internet again.
