Windows 11 Insider Release Preview Channel
Started by Corrine, September 23, 2021, 05:53:19 PM
Releasing Windows 11 Build 22621.1776 to the Release Preview Channel
The following new features and enhancements will be rolled out slowly. If you want to get them as soon as possible, open Settings > Windows Update and turn on the toggle Get the latest updates as soon as they're available and check for updates. Note: The toggle won't be enabled for managed devices (those that are managed by Windows Update for Business or WSUS).
  • New! This update adds live captions for the following languages:
    • Chinese (Simplified and Traditional)
    • French (France, Canada)
    • German
    • Italian
    • Japanese
    • Portuguese (Brazil, Portugal)
    • Spanish
    • Danish
    • English (Ireland, other English dialects)
    • Korean
To turn on live captions, use the WIN + Ctrl + L keyboard shortcut. You can also use the Quick Settings accessibility flyout menu. When you turn it on for the first time, Windows will ask you to download the required speech recognition support. Speech recognition support might not be available in your preferred language, or you might want support in other languages. You can download speech recognition support from Settings > Time & Language > Language & region. To learn more, see Use live captions to better understand audio.
  • New! This update redesigns the in-app voice access command help page. Every command now has a description and examples of its variations. The search bar allows you to quickly find commands. The new categories provide further guidance. You can access the command help page on the voice access bar from Help > View all commands or use the voice access command "what can I say?" Note that the help page might not include all commands. Also, the supplementary information might be inaccurate. We plan to update this in the future. For a list of all Voice Access commands, see Use voice access to control your PC & author text with your voice.
  • New!This update adds voice access command support for the following English dialects:
    • English (United Kingdom)
    • English (India)
    • English (New Zealand)
    • English (Canada)
    • English (Australia)
When you turn on voice access for the first time, Windows will ask you to download a speech model. You might not find a speech model that matches your display language. You can still use voice access in English (US). You can always choose a different language from Settings > Language on the voice access bar.
  • New! This update adds new text selection and editing voice access commands. Some examples are in the table below.
To do thisSay this
Select a range of text in the text box"Select from [text 1] to [text 2]", e.g., "Select from have to voice access"
Delete all the text in a text box"Delete all"
Apply bold, underline, or italic formatting for the selected text or the last dictated text"Bold that," "Underline that," "Italicize that"
  • New! This update adds a VPN status icon, a small shield, to the system tray. It displays when you are connected to a recognized VPN profile. The VPN icon will be overlayed in your system's accent color over the active network connection.
  • New! You can now choose to display seconds in the clock on the system tray. To turn this on, go to the Taskbar behaviors section in Settings > Personalization > Taskbar. You can also right-click taskbar to quickly get to taskbar settings.
  • New! This update provides a copy button for you to quickly copy two-factor authentication (2FA) codes. These are in notification toasts you get from apps installed on your PC or from phones linked to your PC. Note that this feature only works for English.
  • New! This update adds access key shortcuts to File Explorer's context menu. An access key is a one keystroke shortcut. You can use it to quickly run a command in a context menu using your keyboard. Each access key corresponds to a letter in the display name of the menu item. To try this out, you can click on a file in File Explorer and press the menu key on your keyboard.
  • New!This update adds multi-app kiosk mode, which is a lockdown feature. If you are an administrator, you can specify the apps that can run on a device. Other apps will not run. You can also block certain functionalities. You can configure distinct types of access and apps to run for different users on one device. Multi-app kiosk mode is ideal for scenarios in which multiple people use the same device. Some examples are frontline workers, retail, education, and test taking. Some lockdown customizations include:
    • Limit access to Settings, except certain pages, such as Wi-Fi and screen brightness
    • Show only the apps that are allowed on the Start menu
    • Block certain toasts and pop-up windows
Currently, you can enable multi-app kiosk mode using PowerShell and WMI Bridge. To learn more, see Use MDM Bridge WMI Provider to create a Windows client kiosk and Create the JSON file. Support for Microsoft Intune, mobile device management (MDM), and provisioning package configuration is coming soon.
  • New! This update introduces live kernel memory dump (LKD) collection from Task Manager. Using LKD, you can gather data to troubleshoot an issue while the OS continues to work. This reduces downtime when you must investigate an unresponsive program or high-impact failures. To learn more, see Task Manager live memory dump.
To capture an LKD, go to Task Manager > Details. Right-click the System process. Select Create live kernel memory dump file. This captures a Full live kernel or Kernel stack memory dump. The dump will be written to a fixed location: %LocalAppData%\Microsoft\Windows\TaskManager\LiveKernelDumps. You can also go to the Task Manager Settings page to view or edit the settings for live kernel memory dumps.
  • New! This update replaces the settings for Show the touch keyboard when there's no keyboard attached. These are located at Settings > Time & language > Typing > Touch keyboard. A new dropdown menu gives you three options to control whether tapping an edit control should open the touch keyboard. The options are:
    • Never. This suppresses the touch keyboard even when no hardware keyboard is attached.
    • When no keyboard attached. This shows the touch keyboard only when you use the device as a tablet without the hardware keyboard.
    • Always. This shows the touch keyboard even when the hardware keyboard is attached.
  • New! This update enables Content Adaptive Brightness Control (CABC) to run on laptops and 2-in-1 devices. This feature dims or brightens areas of a display based on the content. It tries to strike a balance between saving battery life and providing a good visual experience. You can adjust the feature setting from Settings > System > Display > Brightness & color. The drop-down menu gives you three options: Off, Always, and On Battery Only. For battery powered devices, the default is On Battery Only. Because the device manufacturer must enable CABC, the feature might not be on all laptops or 2-in-1 devices.
  • New! This update adds a USB4 hubs and devices Settings page. You can find it at Settings > Bluetooth & devices > USB > USB4 Hubs and Devices. This new page provides information about the system's USB4 capabilities and the attached peripherals on a system that supports USB4. This information helps with troubleshooting when you need manufacturer or system administrator support. Some features include:
  • You can view the tree of the connected USB4 hubs and devices.
  • You can copy details to the clipboard to share them.
If your system does not support USB4 with the Microsoft USB4 Connection Manager, this page will not appear. On systems that support USB4, you will see USB4 Host Router in Device Manager.
  • New! This update adds a presence sensor privacy setting in Settings > Privacy & security > Presence sensing. If you have a device that has compatible presence sensors, you can now choose the apps that can access those sensors. You can also choose the apps that do not have access. Microsoft does not collect images or metadata. The device hardware processes your information locally to maximize privacy.
  • New! This update improves the performance of search within Settings.
  • New! This update changes the default print screen (prt scr) key behavior. Pressing the print screen key opens the Snipping Tool by default. You can turn off this setting from Settings > Accessibility > Keyboard. If you have previously changed this setting, Windows will preserve your preference.
  • New! This update introduces a limit of 20 most recent tabs in Settings > Multitasking. This affects the number of tabs that appear when you use ALT + TAB and Snap Assist.
  • New! This update improves the cloud suggestion and the integrated search suggestion. This helps you to easily type popular words in Simplified Chinese using the Input Method Editor (IME). The cloud suggestion adds the most relevant word from Microsoft Bing to the IME candidate window. The integrated search suggestion gives you additional suggestions that are like what you see on a Bing search page. You can insert a suggestion as text or search for it directly in Bing. To turn on these features, select a chevron button in the upper right of the IME candidate window. Then select the Turn on.
This update also includes the following improvements (new toggle control not required):
  • New! This update provides the full amount of storage capacity of all your OneDrive subscriptions. It also displays the total storage on the Accounts page in the Settings app.
  • This update addresses an issue that affects Narrator. It now announces text attributes correctly for words, such as "misspelled", "deletion change," and "comment".
  • This update addresses an issue that affects exe. It stops working after you sign out. This issue occurs after you upgrade your machine to Windows 11 Azure Virtual Desktop (AVD) and sign in to that machine.
  • This update addresses an issue that affects Server Message Block (SMB). You cannot access the SMB shared folder. The errors are, "Not enough memory resources" or "Insufficient system resources".
  • The update addresses an issue that sends unexpected password expiration notices to users. This occurs when you set up an account to use "Smart Card is Required for Interactive Logon" and set "Enable rolling of expiring NTLM secrets".
  • This update addresses an issue that affects the Local Security Authority Subsystem Service (LSASS). It stops working. This occurs when you use Azure Virtual Desktop (AVD).
  • This update addresses an issue that affects the Storage Spaces Direct (S2D) cluster. It might not come online. This occurs after a periodic password rollover. The error code is 1326.
  • This update addresses an issue that affects access to Tab settings for IE mode sites.
  • This update addresses an issue that affects dot sourcing. It fails files that contain class definition in Windows PowerShell.
  • This update addresses an issue that affects the use of Event Viewer. The issue limits the number of event sources that users who are not administrators can access.
  • This update addresses an Event Viewer issue. It affects the rendering of a forwarded event log.
  • This update addresses a memory leak. It occurs every time you print a rich text document.
  • This update addresses an issue that affects a computer when it renders a halftone bitmap. The computer stops working.
  • This update addresses an issue that affects devices that have multiple, discreet GPUs. You cannot choose the high-performance GPUs from the default graphics settings page.
  • This update addresses an issue that stops your device from working when it resumes from Modern Standby. The error is 0x13A KERNEL_MODE_HEAP_CORRUPTION.
  • This update addresses an issue that affects applications that perform certain actions in a callback. The applications might stop working. These actions include closing a Window (WM_CLOSE).
  • This update changes the support phone number for Microsoft India for Windows activation.
  • This update changes the international mobile subscriber identity (IMSI) ranges for certain mobile providers.
  • This update addresses an issue that affects the Windows Firewall. The firewall drops all connections to the IP address of a captive portal. This occurs when you choose the Captive Portal Addresses option.
  • This update addresses a multi-function label printer issue. It affects the installation of some of them.
  • This update addresses an issue that affects devices that are joined to Azure Active Directory (Azure AD). The Windows Firewall cannot apply the correct domain and profile for them.
  • This update addresses an issue that affects audio playback. It fails on devices that have certain processors.
  • This update addresses an issue that affects the touch keyboard. It shows the wrong layout for the French-Canadian language.
  • This update addresses an issue that affects Windows Defender Application Control (WDAC). It might create audit events that you do not need. This occurs when you choose the Disabled: Script Enforcement option.
  • This update addresses an issue that affects the touch keyboard. Sometimes, it does not show the correct layout based on the current input scope.
  • This update addresses an issue that affects the Chinese and Japanese Input Method Editor (IME). When you search the Emoji Panel (Windows key + period ( . ), search might fail for some of you.
  • This update addresses an issue that affects the Chinese and Japanese Handwriting Panel. It does not show text prediction candidates or stops responding. This occurs when you select a word from the candidate list of the Handwriting Panel.
  • This update addresses an issue that affects the runas It stops working. The device behaves as if you did not sign in to your account.
  • This update addresses an issue that might affect a large reparse point. You might get a stop error when you use NTFS to access it. This issue occurs after a canceled FSCTL Set operation changes the reparse tag.
  • This update addresses a known issue that might affect some speech recognition apps. They might have sporadic speech recognition, expressive input, and handwriting issues. This occurs when the display language is Chinese or Japanese. The apps might not recognize certain words. They might not receive any input from speech recognition or affected input types. This issue is more likely to occur when the apps use offline speech recognition. For app developers, this issue only affects speech recognition that uses Speech Recognition Grammar Specification (SRGS) in Media.SpeechRecognition. This issue does not affect other types of speech recognition.
Widget Improvements
We are beginning to roll out a new widget picker experience to the Beta and Release Preview Channels with an image that gives a visual preview of the widget before pinning, a deep linking ability that allows users to jump directly to the picker from the provider app/service as well as a link to the widgets Store collection page where users can discover more apps with widgets.
Releasing Windows 11 Build 22000.2121 to the Release Preview Channel
This update includes the following improvements:
  • New! This update adds many new features and improvements to Microsoft Defender for Endpoint. For more information, see Microsoft Defender for Endpoint.
  • New! This update improves several simplified Chinese fonts and the Microsoft Pinyin Input Method Editor (IME) to support GB18030-2022. You can enter and display characters from conformance level 1 or 2 using the additions to Microsoft Yahei, Simsun, and Dengxian. This update now supports Unicode Extensions E and F in the Simsun Ext-B font. This meets the requirements for level 3.
  • This update affects the Default Terminal settings. It adds "Let Windows Decide" as a default option.
  • This update addresses an issue that affects Narrator. The issue stops Narrator from retaining your scan mode when you switch between browsers.
  • This update addresses an issue that affects Microsoft Intune push notifications. The issue stops devices that have less than 3.5 GB of RAM from getting them.
  • This update addresses an issue that affects the on-screen keyboard. The issue stops it from opening after you lock the machine.
  • This update addresses an issue that affects Narrator. It reads the wrong state when you cancel the selection of an option button you have selected.
  • This update addresses an issue that affects a scheduled monthly task. It might not run on time if the next occurrence happens when daylight savings time occurs.
  • This update addresses an issue that affects certain applications that use IDBObjectStore. They do not work in Microsoft Edge and IE mode.
  • This update addresses an issue that affects all the registry settings under the Policies paths. They might be deleted. This occurs when you do not rename the local temporary user policy file during Group Policy processing.
  • This update affects the Desktop Window Manager (DWM). It improves its reliability.
  • This update addresses an issue that affects .msi files. A minor update is not installed. This occurs when you use the EnterpriseDesktopAppManagement configuration service provider (CSP) to distribute the .msi file.
  • This update addresses an issue that affects msftconnecttext.net. It gets excessive HTTP traffic.
  • This update addresses an issue that affects the Spooler service. It stops working. This issue occurs when you print using a certain workspace.
  • This update addresses an issue that affects the Network Protector for BitLocker. It will not resume after it has been suspended.
  • This update addresses an issue that affects a tib.sys driver. It does not load. This occurs when HyperVisor-protected Code Integrity (HVCI) is enabled.
  • This update addresses an issue that affects TextInputHost.exe. It stops working.
  • This update addresses an issue that affects Azure Virtual Desktop and Windows 365 users. You might not see the right location for a Remote Desktop session in your virtual machine or Cloud PC.
  • This update addresses an issue that affects HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders. You can now set and maintain the correct default permissions for this directory path. When the permissions are wrong, Start menu, search, and Azure Active Directory (Azure AD) authentication fails.
  • This update addresses an issue that affects those who enable the "Smart Card is Required for Interactive Logon" account option. When RC4 is disabled, you cannot authenticate to Remote Desktop Services farms. The error message is, "An authentication error has occurred. The requested encryption type is not supported by the KDC."
Releasing Windows 11 Build 22621.1926 to the Release Preview Channel
  • New! This update expands the roll out of notification badging for Microsoft accounts on the Start menu. A Microsoft account is what connects Windows to your Microsoft apps. The account backs up all your data and helps you to manage your subscriptions. You can also add extra security steps to keep you from being locked out of your account. This feature gives you quick access to important account-related notifications.
  • New! This update improves the sharing of a local file in File Explorer with Microsoft Outlook contacts. You now have the option to quickly email the file to yourself. In addition, loading your contacts from Outlook is better. This feature is not available for files stored in Microsoft OneDrive folders. OneDrive has its own sharing functionality.
  • New! With this update, you can now authenticate across Microsoft clouds. This feature also satisfies Conditional Access checks if they are needed.
  • New!This update adds live captions for the following languages:
    • German
    • Italian
    • Japanese
    • Spanish
    • Danish
    • Korean
    • English (India)
    • English (Canada)
  • New! This update adds new text selection and editing voice access commands. Some examples are in the table.
To do thisSay this
  • New! You can now choose to display seconds in the clock on the system tray. To turn this on, go to the Taskbar behaviors section in Settings > Personalization > Taskbar. You can also right-click the taskbar to quickly get to taskbar settings.
  • New! This update improves the cloud suggestion and the integrated search suggestion. This helps you to easily type popular words in Simplified Chinese using the Input Method Editor (IME). The cloud suggestion adds the most relevant word from Microsoft Bing to the IME candidate window. The integrated search suggestion gives you additional suggestions that are like what you see on a Bing search page. You can insert a suggestion as text or search for it directly in Bing. To turn on these features, select a chevron button in the upper right of the IME candidate window. Then select the Turn on button.
  • New! This update improves your computer's performance when you use a mouse that has a high report rate for gaming. To learn more, see "Reduced game stutter with high report rate mice" in Delivering Delightful Performance for More Than One Billion Users Worldwide.
  • New! This update affects virtual memory ranges. They are now added to kernel-generated minidumps after a stop error. These ranges are marked by a KbCallbackTriageDumpData BugCheck Callback Routine.
  • This update affects the reliability of Windows. It improves after you update the OS.
  • This update addresses an issue that affects certain apps. It stops working when it tries to scan a barcode.
  • This update addresses an issue that affects Teams. The issue stops Teams from alerting you about missed calls or messages.
  • This update gives user accounts the ability to open an elevated Windows Terminal. This only works if they use an admin account that has not signed in before.
  • This update addresses an issue that might affect your computer when you are playing a game. Timeout Detection and Recovery (TDR) errors might occur.
  • This update addresses an issue that affects certain apps. In some instances, video flickering occurs.
  • This update addresses an issue that affects devices that use the Network Protector for BitLocker. The device will not resume after it has been suspended.
  • This update addresses an issue that affects File Explorer (explorer.exe). It stops working.
  • This update addresses an issue that affects File Explorer windows. They unexpectedly appear in the foreground.
  • This update addresses an issue that affects some earbuds. They stop streaming music.
  • This update addresses an issue that affects the Recommended section of the Start menu. When you right-click a local file, it does not behave as expected.
  • This update affects Active Directory event ID 1644 processing. It now accepts events of greater than 64 KB in length. This change truncates Lightweight Directory Access Protocol (LDAP) queries contained within event 1644 to 20000 characters by default. You can configure the 20K value using the registry key "DEFAULT_DB_EXPENSIVE_SEARCH_FILTER_MAX_LOGGING_LENGTH_IN_CHARS."
Releasing Windows 11 Build 22000.2243 to the Release Preview Channel
  • New! This update affects the Handwriting Software Input Panel (SIP), the Handwriting Engine, and the Handwriting Embedded Inking Control. They now support GB18030-2022 conformance level 2. Because of this, they meet the level 3 requirements.
  • [ADDED] This update addresses an issue that might affect Win32 and Universal Windows Platform (UWP) apps. They might close when devices enter Modern Standby. Modern Standby is an expansion of the Connected Standby power model. This issue occurs if certain Bluetooth Phone Link features are turned on.
  • This update affects the Windows Push Notification Services (WNS). It makes the connection between the client and the WNS server more reliable.
  • This update addresses an issue that affects UI Automation and caching mode.
  • This update addresses an issue that affects the Windows Notification Platform. It fails to send notifications from applications to you.
  • This update addresses an issue that affects hybrid joined devices. You cannot sign in to them if they are not connected to the internet. This occurs when you use a Windows Hello for Business PIN or biometric credentials. This issue applies to a cloud trust deployment.
  • This update affects Windows Autopilot profiles. The process to download the Windows Autopilot policy is more resilient. This helps when a network connection might not be fully initialized. This update increases the retry attempts when you try to download the Windows Autopilot profile.
  • This update addresses an issue that affects the Windows Management Instrumentation (WMI) repository. This causes an installation error. The issue occurs when a device does not shut down properly.
  • This update addresses an issue that affects certain CPUs. There is inconsistent reporting of the L2 cache.
  • This update addresses an issue that affects Event Forwarding Subscriptions. When you add an Event Channel to the subscription, it forwards events you do not need.
  • This update enhances hinting for some of the letters of the Verdana Pro font family.
  • This update affects user mode printer drivers. They unload unexpectedly. This occurs when you print from multiple print queues to the same printer driver.
  • This update affects text edit controls in XAML. You cannot edit the controls again after they become read only. This occurs when you use the new Microsoft Input Method Editor for Japanese, Chinese, and Korean.
  • This update makes Narrator announce the "Change product key" label.
  • This update addresses an issue that affects the Defender Firewall Profile. It fails to automatically switch from a LAN that is trusted to a public network.
  • This update addresses an issue that affects some virtual private networks (VPN). The VPN connection is unreliable on some routers.
  • This update makes Country and Operator Settings Asset (COSA) profiles up to date.
  • This update addresses an issue that affects certain display and audio devices. They are missing after your system resumes from sleep.
  • This update addresses a deadlock in Internet Protocol Security (IPsec). When you configure servers with IPsec rules, they stop responding. This issue affects virtual and physical servers.
  • This update addresses an issue that affects the MPSSV service. The issues causes your system to restart repeatedly. The stop error code is 0xEF.
  • This update addresses an issue that affects a Clustered Shared Volume (CSV). The CSV fails to come online. This occurs if you enable BitLocker and local CSV managed protectors, and the system recently rotated the BitLocker keys.
  • This update addresses an issue that causes Windows to fail. This occurs when you use BitLocker on a storage medium that has a large sector size.
  • This update affects the Windows Kernel Vulnerable Driver Blocklist, DriverSiPolicy.p7b. It adds drivers that are at risk for Bring Your Own Vulnerable Driver (BYOVD) attacks.
  • This update addresses an issue that affects the fastfat file system driver. It stops responding because of a race condition.
  • This update addresses an issue that affects refsutil.exe. Options, like salvage and leak, do not work properly on Resilient File System (ReFS) volumes.
  • This update addresses an issue that affects I/O over Server Message Block (SMB). It might fail when you use the LZ77+Huffman compression algorithm.
Releasing Windows 11 Build 22000.2359 to the Release Preview Channel
This update includes the following improvements for the Windows 11 (Original Release) Release Preview Channel:
  • New! This update improves how Windows detects your location. This helps to give you better weather, news, and traffic information.
  • This update makes daylight saving time (DST) changes for Israel.
  • This update addresses an issue that affects the Group Policy Service. It will not wait for 30 seconds, which is the default wait time, for the network to be available. Because of this, policies are not correctly processed.
  • This update adds a new API for D3D12 Independent Devices. You can use it to create multiple D3D12 devices on the same adapter. To learn more, see D3D12 Independent Devices.
  • This update addresses an issue that affects a WS_EX_LAYERED window. The window might render with the wrong dimensions or at the wrong position. This occurs when you scale the display screen.
  • This update addresses an issue that affects print jobs that are sent to a virtual print queue. They fail without an error.
  • This update addresses an issue that causes high CPU use. This occurs when you enable the "fBlockNonDomain policy."
  • This update addresses an issue that affects disk partitions. The system might stop working. This occurs after you delete a disk partition and add the space from the deleted partition to an existing BitLocker partition.
  • This update addresses an issue that affects the Resultant Set of Policy (RSOP). The Windows LAPS "BackupDirectory" policy setting was not being reported. This occurs when the setting is set to 1, which is "Back up to AAD."
Releasing Windows 11 Build 22621.2213 to the Release Preview Channel
Windows 11 Build 22621.2213 (KB5029351) to the Release Preview Channel on Windows 11, version 22H2.
This update includes the following features and improvements:
  • New! This update adds new functionality that affects app defaults. To learn more, see A principled approach to app pinning and app defaults in Windows.
  • New! This update adds a new hover behavior to the search box gleam. When you hover over it, the search flyout box appears. You can adjust this behavior by right clicking the taskbar. Then choose Taskbar settings to change your search box experience.
  • New! This release adds a new policy called "Enable optional updates." Administrators can use it to configure the monthly, optional cumulative updates for commercial devices. You can also use this policy for the gradual Controlled Feature Rollouts (CFR).
  • This update addresses an issue that causes high CPU use. This occurs when you enable the "fBlockNonDomain" policy.
  • This update addresses an issue that affects Remote Desktop sessions. Sometimes you receive a wrong error message when you try to sign in to a session.
  • This update addresses an issue that affects the search icon. When you select it, the Search app does not open. This occurs after a machine has been asleep.
  • This update improves the reliability of the Search app.
  • This update addresses an issue that affects the TAB key. Using it to browse search results requires additional actions.
  • This update addresses an issue that affects Narrator. It does not give distinct context between the search box on the taskbar and search highlights within the search box.
  • This update addresses an issue that affects Start menu icons. They are missing after you sign in for the first time.
  • This update addresses an issue that affects settings. They do not sync even if you turn on the toggle on the Windows backup page in the Settings app.
Releasing Windows 11 Build 22000.2479 to the Release Preview Channel
  • New! This update completes the work to comply with the GB18030-2022 requirements. It removes and remaps characters for Microsoft Wubi input and Microsoft Pinyin U-mode input. You can no longer enter character codepoints that are not supported. All the required codepoints are up to date.
  • This update supports daylight saving time (DST) changes in Greenland.
  • This update changes the spelling of Ukraine's capital from Kiev to Kyiv.
  • This update addresses an issue that affects account lockout event 4625. The format of the event is wrong in the ForwardedEvents log. This occurs when an account name is in the user principal name (UPN) format.
  • This update affects the Key Distribution Center (KDC) and user security identifiers (SID). KDC now reads the user SID from the Subject Alternative Name (SAN) of a certificate. Because of this, mobile device management (MDM) providers can use offline templates to fill in the user SID. To learn more, see KB5014754.
  • This update addresses an issue that affects Microsoft Excel. It stops responding when you try to share a file as a PDF in Microsoft Outlook.
  • This update addresses an issue that is related to changes in the forwarding of events.
  • This update addresses an issue that affects XPath queries on FileHash and other binary fields. It stops them from matching values in event records.
  • This update addresses an issue that affects an Application Virtualization (App-V) environment. Copy operations within it stop working. This occurs after you install the April 2023 update.
  • This update addresses an issue that affects the Simple Certificate Enrollment Protocol (SCEP) certificate. The system reports some SCEP certificate installations as failed. Instead, the system should report them as pending.
  • This update addresses an issue that affects Microsoft Print to PDF. It uses the metadata for the name you sign in with as the author of a printed PDF. It should use the display name instead.
  • This update addresses an issue that affects some USB printers. Microsoft Defender stops them from printing.
  • This update addresses an issue that affects Windows Defender Application Control (WDAC). AppID Tagging policies might greatly increase how long it takes your device to start up.
  • This update addresses an issue that affects IMEPad. It stops working. This occurs when you enter end-user-defined characters (EUDC).
  • This update addresses an issue that affects application compatibility. It is related to Microsoft Defender for Endpoint.
  • This update addresses an issue that affects Remote Apps. The display of some elements is not aligned correctly.
  • This update addresses an issue that affects the Microsoft Distributed Transaction Coordinator (DTC). It has a handle leak. Because of this, the system runs out of memory.
  • This update addresses an issue that might make Windows stop responding. This might occur if you use Microsoft OneDrive files that are compressed by NTFS.
  • This update addresses an issue that might cause a user-mode memory leak. It might occur when you call CopyFile() or MoveFile().
  • This update addresses an issue that affects external binding. It fails. This occurs after you install Windows updates dated May 2023 or later. Because of this, there are issues that affect LDAP queries and authentication.
Rolling out new features for Windows 11 (22H2) to the Release Preview Channel
Releasing Windows 11 Build 22621.2361 (KB5030310) to Insiders in the Release Preview Channel on Windows 11, version 22H2. Also beginning to roll out some of the new features announced yesterday by Yusuf, including Copilot in Windows (in preview)*, Modernized File Explorer, new text authoring experiences to voice access and new natural voices in Narrator, and Windows Backup. A more complete list of features will be shared next week on Sept. 26th.
If you have the toggle to get the latest updates as they are available turned ON via Settings > Windows Update BEFORE installing Build 22621.2361, you will also get Windows Configuration Update (KB5030509) installed at the same time you install Build 22621.2361 in a single reboot. Note only the update for Build 22621.2361 will show during install on the Windows Update settings page. But after reboot, the Windows Configuration Update will be shown in your Update History. This Windows Configuration Update is how we're enabling new features via Controlled Feature Rollout (CFR) technology.
Should you install Build 22621.2361 without turning on the toggle to get the latest updates as they are available before, you can simply turn it on, and Windows Configuration Update (KB5030509) will be downloaded on your PC where you will be asked to reboot. Should you install build 22621.2361 and keep the toggle off, the new features will be gradually rolled out to your device over time.
Releasing Windows 11 Build 22621.2500 to the Release Preview Channel
  • New! This update affects the search highlight gleam in the search box. When you select the gleam, a Bing.com page will appear for the daily search highlight. This is available to a small audience initially and deploys more broadly in the months that follow.
  • This update changes the English name of the former Republic of Turkey. The new, official name is the Republic of Türkiye.
  • This update supports the currency change in Croatia from the Kuna to the Euro.
  • This update supports daylight saving time (DST) changes in Syria. To learn more, see Interim guidance for Syria DST changes 2022.
  • This update addresses an issue that affects fontdrvhost.exe. It stops responding when you use Compact Font Format version 2 (CFF2) fonts.
  • This update addresses a memory leak in ctfmon.exe.
  • This update addresses a memory leak in TextInputHost.exe.
  • This update addresses an issue that affects touchscreens. They do not work properly when you use more than one display.
  • This update addresses an issue that affects Dynamic Lighting. The default provider is not applied as expected. This occurs when you set it up using Unattend files.
  • This update addresses an issue that affects the Microsoft Store. It stops responding when you access it from Windows Mixed Reality.
  • This update addresses an issue that affects cellular settings. The name of the mobile operator is wrong.
  • This update addresses an issue that affects the Windows Firewall Profile. When you are on a domain authenticated network, it detects a public domain. This is wrong.
  • This update addresses an issue that occurs when you use Universal Print to add a printer using its location. When you browse the tree view structure, the tree nodes do not work as you expect.
  • This update addresses an issue that affects Outlook. It stops responding. This occurs when you print to an Internet Printing Protocol (IPP) printer that has a slow response time.
  • This update addresses an error that occurs when you print using v4 print drivers.
  • This update makes Country and Operator Settings Asset (COSA) profiles up to date for certain mobile operators.
  • This update addresses an issue that blocks external connections. This occurs when you set up a Kubernetes load balanced service and turn on session affinity.
  • This update addresses a Firewall configuration service provider (CSP) issue. It stops a device from syncing.
  • This update addresses an issue that affects devices on which you have defined Windows Information Protection (WIP) policies and set up a proxy. A stop error occurs. This happens on devices that use Microsoft Defender Application Guard. In the past, WIP was known as enterprise data protection (EDP).
  • This update addresses an issue that occurs after you run a Push-button reset. You cannot set up Windows Hello facial recognition. This affects devices that have Windows Enhanced Sign-in Security (ESS) turned on.
  • This update addresses an issue that affects PowerShell versions greater than 7.3.1. It might block scripts and not let them run in Constrained Language Mode. This occurs when you turn on a WDAC policy.
  • This update addresses an issue that affects the Automatically Hide the Taskbar setting. You cannot set it using the SHAppBarMessage() API.
  • This update improves the performance of the search box experience.
  • This update addresses an issue that affects robocopy. The /efsraw switch stops it from copying data properly.
October 12th blog post for Build 22621.2500 updated today:
  • [ADDED 10/23] New! We are beginning to roll out digital handwriting (inking) in some edit boxes for Windows Ink. Also, the recognition technology is more accurate. There are gestures to delete, select, join, and split words. You can also gesture to insert a new line.
    • Note These improvements support English (U.S.) only. Broader language support is coming soon. To manage this feature, go to Settings > Bluetooth and devices > Pen and Windows Ink.
  • [ADDED 10/23] New! System Components currently listed in Settings > Apps > Installed Apps page, have moved to its own page under Settings > System > System Components.
Releasing Windows 11 Build 22631.2506 to the Release Preview Channel
(Note: This optional update is currently also rolling out to all customers on Windows 11, version 22H2 including those in Release Preview. Please see this KB article here.)
This update includes the following improvements documented here in this KB article plus these additional changes for Windows 11, version 23H2:
  • Under All apps in the Start menu, Windows 11 system components will now show a "system" label.
Releasing Windows 11 Builds 22621.2787 and 22631.2787 to the Release Preview Channel
  • On Windows 11, version 23H2 – this update previews changes in Windows to comply with the Digital Markets Act in the European Economic Area.
  • New! You can use Copilot in Windows across multiple displays. Press the Copilot in Windows taskbar button on the taskbar of the display where you want Copilot in Windows to appear. To show Copilot in Windows on the last display that it was on, press WIN + C. If you use a keyboard, press WIN +T to put the keyboard focus on the taskbar. Then go to the Copilot in Windows button to open it on any display. This is available to a small audience initially and deploys more broadly in the months that follow.
  • New! You can use Copilot in Windows with ALT +TAB. When you press ALT +TAB, the thumbnail preview for Copilot in Windows appears among other thumbnail previews of open windows. You can switch between them using the Tab keystroke. This is available to a small audience initially and deploys more broadly in the months that follow.
  • New! In the coming weeks, you might see Windows Spotlight set as the default background. This might occur when your background is set to an inbox Windows image.
  • New! You can ask Copilot in Windows for help ten times when you sign in to Windows using a local account. After that, you must sign in using a verified account. These include a Microsoft account (MSA) and Azure Active Directory (Azure AD). Note that the name for Azure AD will change to Microsoft Entra ID.
  • This update affects the shortcut (context) menu. Its performance is better when you open it on the desktop and in File Explorer.
  • This update addresses an issue that affects .RAR files. They display as if they are empty in File Explorer.
  • This update addresses an issue that affects apps that you download from Microsoft store. They stop responding and will not update.
  • This update affects the Netherlands time zone. It adds the recent man-made landmass outside of Rotterdam to the shape files.
  • This update addresses an issue that affects the Trusted Sites Zone logon policy. You cannot manage it using mobile device management (MDM).
  • This update addresses an issue that affects IE mode. A webpage stops working as expected when there is an open modal dialog.
  • This update addresses an issue that causes IE mode to stop responding. This occurs if you press the left arrow key when an empty text box has the focus and caret (cursor) browsing is on.
  • This update addresses app cursor issues. The cursor changes from a hand to a cursor when it should not, or the cursor disappears. These issues occur when apps use the WebView2Standalone XAML control..
  • This update addresses an issue that causes IE mode to stop responding. This occurs when you have multiple IE mode tabs open.
  • This update addresses an issue that affects remote direct memory access (RDMA) performance counters. They did not return networking data on VMs in the right way.
  • This update addresses an issue that affects 32-bit GDI based applications. They stop responding. This occurs when they run on 64-bit Windows OSs that use more than 2GB of memory.
  • This update affects Dynamic Lighting. It reduces the amount of power it uses on your device.
  • This update addresses an issue that might affect the cursor when you write in Japanese. The cursor might move to an unexpected place.
  • This update addresses an issue that might affect Microsoft OneNote. When you use a pen right-click to open it, that might fail.
  • This update addresses an issue that affects the cursor. Its movement lags in some screen capture scenarios.
  • This update addresses an issue that affects the Advanced Audio Coding (AAC) decoder. It does not work well on some websites that set the wrong input sampling rate.
  • This update addresses an issue that affects hardware that uses the PresentAt feature. Power use grows when you play a video in full screen.
  • This update affects feature management. You can now prefetch velocity configs for more than one OS version. Doing that will not harm other versions. After you upgrade and your machine restarts, only the correct velocity config for the current OS version is applied.
  • This update addresses an issue that affects the Systems Settings application. It stops responding after you turn off Device Encryption.
  • This update affects Microsoft Defender for Endpoint (MDE). It enables Conditional Access (CA) scenarios.
  • This update addresses an issue that stops you from reconnecting to an existing cloud session. Instead, you get a new one.
  • This update improves how fast Copilot in Windows opens from the taskbar.
  • This update addresses a leak in volatile notifications. This might stop you from signing in to your machine.
  • This update addresses an issue that affects File Explorer. When you press Shift + F10, the shortcut (context) menu does not open.
  • This update addresses an issue that affects File Explorer windows. When you do not expect them, they appear in the foreground.
  • This update addresses an issue that affects the Widgets notification badge. It is in the wrong position on the taskbar.
  • This update addresses an issue that affects the Copilot in Windows icon on the taskbar. It does not show as active when Copilot in Windows is open.
  • This update addresses an issue that affects Windows LAPS. Its PasswordExpirationProtectionEnabled policy fails to turn on the setting.
  • This update addresses an issue that affects Windows Sandbox. If the locale of your machine is not US English, File Explorer stops responding.
