September 2023 Windows 10 Non-Security Optional Preview "C" Release
Started by Corrine, September 26, 2023, 07:17:08 PM
Microsoft released KB5030300 for Windows 10 version 22H2 optional non-security release preview.
The following are the highlighted changes included in the update:
  • New! This update brings back an improved search box experience on the taskbar. If you have a top, bottom, regular, or small icons taskbar, you will see the search box appear. You can use it to easily access apps, files, settings, and more from Windows and the web. You will also have access to the latest search updates, such as search highlights. If you want to restore your previous search experience, you can do that easily. Use the taskbar shortcut menu or respond to a dialog that appears when you use search.
  • New! This update adds animations to a few icons on the news and interests taskbar button. These animations occur when:
    • A new announcement appears on the news and interests taskbar button.
    • You hover over or click the icon while the announcement is on the taskbar.
  • This update addresses an issue that affects Microsoft Excel. It stops responding when you try to share a file as a PDF in Outlook.
  • This update addresses an issue that affects the touch keyboard. Sometimes it does not open.
See the referenced KB Article for long list of quality improvements included in the update.
Windows 10 update history
