Pale Moon Version 33.2.1 Released with Security Update
Started by Corrine, July 15, 2024, 08:19:10 PM
Pale Moon has been updated to version 33.2.1.  This is a bug fix and security update.
Changes/fixes:
  • Fixed a crash in CSS grid layout.
  • Set hidden HTML elements to actually always be hidden.
  • Updated NSS to 3.90.3.
  • Updated SQLite to 3.46.0.
  • Fixed an issue with setting of cookies.
  • Fixed an issue in Linux IPC code.
  • Fixed an issue with DNS prefetching (disabled by default).
  • Security issues addressed: CVE-2024-6611, CVE-2024-6612 DiD and several others (mostly DiD) that do not have a CVE number assigned.
Notes:
*DiD This means that a fix is "Defense-in-Depth": It is a fix that does not apply to a (potentially) actively exploitable vulnerability in Pale Moon, but prevents future vulnerabilities caused by the same code, e.g. when surrounding code changes, exposing the problem, or when new attack vectors are discovered.
Release Cycle
