Pale Moon Version 33.3.1 Released with Security Update
Started by Corrine, September 10, 2024, 01:06:52 PM
Pale Moon has been updated to version 33.3.1. This is a minor security and bug fix update.
Changes/fixes:
  • Backed out support for FFmpeg 7.0/libavcodec 61 (Linux) due to it causing a major regression in WebAudio (broken on all platforms). This is being worked on to re-land at a later date.
  • Restricted the NotifyPaintEvent interface to chrome code only; there is no reason (other than potential tracking/fingerprinting) to have this accessible from content.
  • Fixed a potentially exploitable issue in JavaScript (FetchName).
  • Fixed a code correctness issue in XPConnect when creating sandboxes. DiD
  • Added a warning for using externally handled usenet protocols.
  • Security issues addressed: CVE-2024-8383 and CVE-2024-8381.
Notes:
*DiD This means that a fix is "Defense-in-Depth": It is a fix that does not apply to a (potentially) actively exploitable vulnerability in Pale Moon, but prevents future vulnerabilities caused by the same code, e.g. when surrounding code changes, exposing the problem, or when new attack vectors are discovered.
