Pale Moon Version 33.0.1 Released with Security Updates
Started by Corrine, February 27, 2024, 02:44:25 PM
Pale Moon has been updated to version 33.0.1. This is a bugfix and security update.
Changes/fixes:
  • Removed site-specific override for Amazon.com due to breakage.
  • Fixed script timeout values that were inadvertently overridden in branding.
  • Fixed an issue where empty MIME type registrations would break some parts of the UI.
  • (Linux only) Pasting URLs to content now by default does not navigate to that URL.
  • If content-paste-navigation is enabled (via middlemouse.contentLoadURL), navigation is now restricted to pasting to active body type elements (to prevent unwanted navigation when pasting URLs to input boxes, for example).
  • Fixed a problem with JS modules preventing ExportEntries from working.
  • (Linux only) Fixed a build issue when building with a system-supplied cairo library (unsupported).
  • Fixed an issue where workers could lock up the browser with SetInterval with an out-of-bounds (too small) value. This is now clamped to 4ms matching the HTML spec.
  • Fixed a few usability issues with the built-in developer tools.
  • Fixed a potential crash in web workers.
  • Fixed a potential overflow issue in image maps.
  • Fixed a potential security issue with multi-part/mixed content (CVE-2024-1551).
Release Cycle
