Server Move Complete!
Started by Corrine, January 04, 2022, 09:24:08 PM
Will Watts
Do you have a screenshot of the error you're seeing?
It's possible it's just a DNS record propagation issue - as the domain is now pointing to a new server, we do expect it to take up to 48 hours before it's fully resolved everywhere.
You're welcome, icotonev..
Will Watts
Quote from: V.T. Eric Layton on January 05, 2022, 03:07:58 PM
Hmm... how do I get to this new place? Your link above says:
Sorry. We could not locate the item you are trying to view. Error code: 2F173/1
Some additional questions:
1) Do you have a second device / OS you're able to test on, and see if it makes a difference?
2) Are you able to try connecting from a mobile network or a different internet connection?
3) Do you use any custom rules in hosts files / router settings etc that might specify the IP for the domain?
V.T. Eric Layton
No. Not easily, anyway.
No.
Not that I know of. Hmm... although, I am using OpenDNS. I wonder if that's the issue.
Here is my current ping and whois data for "forums.scotsnewsletter.com":
vtel57@ericsbane07~:$ ping -c3 forums.scotsnewsletter.com
PING forums.scotsnewsletter.com (104.193.108.157) 56(84) bytes of data.
64 bytes from 104.193.108.157: icmp_seq=1 ttl=48 time=26.6 ms
64 bytes from 104.193.108.157: icmp_seq=2 ttl=48 time=27.8 ms
64 bytes from 104.193.108.157: icmp_seq=3 ttl=48 time=28.6 ms
--- forums.scotsnewsletter.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2002ms
rtt min/avg/max/mdev = 26.695/27.737/28.641/0.800 ms
vtel57@ericsbane07~:$ whois 104.193.108.157
# ARIN WHOIS data and services are subject to the Terms of Use
# available at: https://www.arin.net/resources/registry/whois/tou/
# If you see inaccuracies in the results, please report at
# https://www.arin.net/resources/registry/whois/inaccuracy_reporting/
# Copyright 1997-2022, American Registry for Internet Numbers, Ltd.
# start
NetRange:       104.193.108.0 - 104.193.111.255
CIDR:           104.193.108.0/22
NetName:        PRIVATE-IPV4-13
NetHandle:      NET-104-193-108-0-1
Parent:         NET104 (NET-104-0-0-0-0)
NetType:        Direct Allocation
OriginAS:       AS63410
Organization:   PrivateSystems Networks (KNOWN-1)
RegDate:        2014-09-18
Updated:        2017-04-28
Ref:            https://rdap.arin.net/registry/ip/104.193.108.0
OrgName:        PrivateSystems Networks
OrgId:          KNOWN-1
Address:        1379 Dilworthtown Crossing
Address:        Suite 214
City:           West Chester
StateProv:      PA
PostalCode:     19382
Country:        US
RegDate:        2008-01-04
Updated:        2017-01-28
Ref:            https://rdap.arin.net/registry/entity/KNOWN-1
OrgNOCHandle: NOC2915-ARIN
OrgNOCName:   Network Operations Center
OrgNOCPhone:  +1-866-332-9894
OrgNOCEmail:  noc@privatesystems.net
OrgNOCRef:    https://rdap.arin.net/registry/entity/NOC2915-ARIN
OrgAbuseHandle: PNA44-ARIN
OrgAbuseName:   PrivateSystems Networks Abuse
OrgAbusePhone:  +1-866-332-9894
OrgAbuseEmail:  abuse@privatesystems.net
OrgAbuseRef:    https://rdap.arin.net/registry/entity/PNA44-ARIN
OrgTechHandle: NOC2915-ARIN
OrgTechName:   Network Operations Center
OrgTechPhone:  +1-866-332-9894
OrgTechEmail:  noc@privatesystems.net
OrgTechRef:    https://rdap.arin.net/registry/entity/NOC2915-ARIN
RAbuseHandle: PNA44-ARIN
RAbuseName:   PrivateSystems Networks Abuse
RAbusePhone:  +1-866-332-9894
RAbuseEmail:  abuse@privatesystems.net
RAbuseRef:    https://rdap.arin.net/registry/entity/PNA44-ARIN
# end
# start
NetName:        ATL-VPS
NetHandle:      NET-104-193-108-0-2
Parent:         PRIVATE-IPV4-13 (NET-104-193-108-0-1)
NetType:        Reassigned
OriginAS:       AS63410
Organization:    PrivateSystems Networks GA (PNG-34)
RegDate:        2020-07-03
Updated:        2020-07-03
OrgName:         PrivateSystems Networks GA
OrgId:          PNG-34
Address:        INAP c/o PrivateSystems Networks
Address:        250 Williams Street NW
City:           Atlanta
StateProv:      GA
PostalCode:     30303
Country:        US
RegDate:        2019-07-15
Updated:        2019-07-15
Ref:            https://rdap.arin.net/registry/entity/PNG-34
# end
V.T. Eric Layton
I believe I'm still on the old server because I can still see that thread that you posted there about "If you can see this... ... you're still on the old server."
Also, the link that Corrine posted above shows topic #97212, which does not exist on the server that I'm on.
Meh... DNS propogation is just probably a bit slow. I'll check in again tomorrow. Thanks, Will.
xrobwx71
No problems here on multiple systems and multiple OS's. Windows / Linux
Will Watts
QuoteNot that I know of. Hmm... although, I am using OpenDNS. I wonder if that's the issue.
I've refreshed the cache on OpenDNS as well - I believe you should be able to access the new server now, but let me know if you're still experiencing issues.
pete319
Quote from: Corrine on January 05, 2022, 03:52:37 PM
That is strange.  I clicked the link and it opened Will's post at SNF in Forum Feedback, https://forums.scotsnewsletter.com/index.php?/topic/97212-new-server-any-issues/
Hi
I tried the link and my anti virus blocked it.
See below
Avast Real-time Shield Scan Report
* This file is generated automatically
* Started on: Thursday, 6 January 2022 4:50:31 PM
6/01/2022 5:26:01 PM   htt://forums.scotsnewsletter.com/index.php?/topic/97212-new-server-any-issues/ [L] URL:TechScam (0)
I changed the https so as link not live
Cheers
Will Watts
I can't see the site flagged in any AV scanners, but I've reported it as a false positive to Avast.
pete319
Quote from: Will Watts on January 06, 2022, 10:16:29 AM
Cheers
Thanks for that
V.T. Eric Layton
Yes, my Firefox also warned about that link... most likely due to domain registration changes. It's NOT warning today, though. I'm in at the new place. All's well!
Glad you finally made it, Eric!
V.T. Eric Layton
Me, too. It was kinda' sad and lonely on that old server the past couple days. I was the only one there. I felt like a ghost. ;)
