Hi all,
This is driving me nuts, I just cant seem to burn movies anymore. I have so many of the kids DVD's and dance concerts that I need to copy for family and nothing works, I decrypt them first, then go to DVD shrink and still I get an error.
I try doing it all through nero and that doesn't work either.
The latest error is this, which I got halfway through DVD shrink...
Is there anything that anyone can do to help me as I'm about to give up. I've gone through so many DVD's trying to do this.
DID I MENTION I'M DESPERATE :sos:
1C82-0000-19E5-MAAX-4004-3304-****
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 21/11/2005 3:48:21 PM
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2/11/2004 1:54:32 PM
NT-SPTI used
Nero API version: 7.2.7.0
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Nero\Nero 7\Core\
Application: ahead\Nero - Burning Rom
Internal Version: 7, 2, 7, 0
Recorder: <PIONEER DVD-RW DVR-111D>Version: 1.23 - HA 1 TA 0 - 7.2.7.0
Adapter driver: <IDE> HA 1
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ?
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD1600JB-00REA0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-111D atapi Port 3 ID 0 DMA: On
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-111D D: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1007MB (1031660kB)
Free physical memory: 168MB (172384kB)
Memory in use : 83 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
25.5.2007
NeroAPI
10:27:33 PM #1 Phase 112 File APIProgress.cpp, Line 278
DVD-Video files reallocation started
10:27:33 PM #2 Phase 114 File APIProgress.cpp, Line 278
DVD-Video files reallocation completed (no file modified)
10:27:33 PM #3 Phase 111 File APIProgress.cpp, Line 278
DVD-Video files sorted
10:27:33 PM #4 Text 0 File ThreadedTransfer.cpp, Line 540
ReadBuffer-Pipe got 262144KB of Memory
10:27:33 PM #5 Text 0 File Reader.cpp, Line 124
Reader running
10:27:33 PM #6 Text 0 File Writer.cpp, Line 113
Writer D: PIONEER DVD-RW DVR-111D running
10:27:33 PM #7 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
10:27:33 PM #8 ISO9660GEN -11 File Geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
10:27:33 PM #9 ISO9660GEN -11 File Geniso.cpp, Line 3312
10:27:33 PM #10 Text 0 File Burncd.cpp, Line 3405
Turn on Disc-At-Once, using DVD media
10:27:34 PM #11 Text 0 File DlgWaitCD.cpp, Line 298
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2162303 (480:30.53, 4223MB)
10:27:34 PM #12 Text 0 File DlgWaitCD.cpp, Line 310
Write in overburning mode: NO
10:27:34 PM #13 Text 0 File DlgWaitCD.cpp, Line 2842
Recorder: PIONEER DVD-RW DVR-111D, Media type: DVD-R
Disc Manufacturer: MCC 03 - RG20
Disc Application Code: 64, Disc Physical Code: 193
10:27:34 PM #14 Text 0 File DlgWaitCD.cpp, Line 482
>>> Protocol of DlgWaitCD activities: <<<
10:27:34 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 848
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2162304 (2162304) = #2162304/480:30.54
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2162304 blocks [D: PIONEER DVD-RW DVR-111D]
10:27:34 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 1063
Prepare recorder [D: PIONEER DVD-RW DVR-111D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4428398592, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 2162304 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2162304 | 0 | 0x00
2162304 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
10:27:34 PM #17 Text 0 File SCSIPassThrough.cpp, Line 39
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
10:27:34 PM #18 Phase 24 File APIProgress.cpp, Line 278
Caching of files started
10:27:34 PM #19 Text 0 File Burncd.cpp, Line 4236
Cache writing successful.
10:27:34 PM #20 Phase 25 File APIProgress.cpp, Line 278
Caching of files completed
10:27:34 PM #21 Phase 36 File APIProgress.cpp, Line 278
Burn process started at 16x (22,160 KB/s)
10:27:37 PM #22 Text 0 File ThreadedTransferInterface.cpp, Line 2722
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
10:27:37 PM #23 Text 0 File DVDR.cpp, Line 2965
Recording mode: Sequential Recording Mode
10:27:37 PM #24 Text 0 File DVDR.cpp, Line 3121
Start write address at LBA 0
DVD high compatibility mode: Yes
10:27:37 PM #25 SPTI -1066 File SCSIPassThrough.cpp, Line 291
D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
Buffer x0c7b2400: Len x648
10:27:37 PM #26 Text 0 File Cdrdrv.cpp, Line 9096
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
10:27:43 PM #27 Text 0 File Cdrdrv.cpp, Line 1230
22:27:43.031 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:25 PM #28 Text 0 File Cdrdrv.cpp, Line 1230
22:28:25.484 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #29 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.109 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #30 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.125 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #31 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.140 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #32 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.156 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #33 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.187 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #34 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.203 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #35 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.218 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #36 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.234 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #37 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.250 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #38 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.265 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #39 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.281 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #40 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.296 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #41 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.343 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #42 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.359 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #43 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.375 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #44 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.390 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #45 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.421 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #46 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.437 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #47 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.453 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #48 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.468 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #49 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.500 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #50 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.515 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #51 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.531 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #52 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.546 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #53 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.578 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #54 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.593 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #55 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.609 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #56 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.625 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #57 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.656 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #58 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.671 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #59 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.687 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #60 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.703 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #61 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.734 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #62 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.750 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #63 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.765 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #64 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.781 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #65 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.812 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #66 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.828 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #67 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.843 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #68 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.859 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #69 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.890 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #70 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.906 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #71 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.921 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #72 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.937 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #73 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.968 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:26 PM #74 Text 0 File Cdrdrv.cpp, Line 1230
22:28:26.984 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #75 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.000 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #76 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.015 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #77 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.046 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #78 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.062 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #79 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.078 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #80 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.093 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #81 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.125 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #82 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.140 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #83 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.156 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #84 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.171 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #85 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.203 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #86 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.218 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #87 Text 0 File Cdrdrv.cpp, Line 1230
10:28:27 PM #88 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.234 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #89 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.281 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #90 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.296 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #91 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.312 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #92 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.328 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #93 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.359 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #94 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.375 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #95 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.390 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #96 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.406 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #97 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.421 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #98 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.437 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #99 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.453 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #100 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.468 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #101 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.515 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #102 Text 0 File Cdrdrv.cpp, Line 1230
10:28:27 PM #103 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.531 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #104 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.546 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #105 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.593 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #106 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.609 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #107 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.625 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #108 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.640 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #109 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.671 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #110 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.687 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #111 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.703 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #112 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.718 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #113 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.750 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #114 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.765 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #115 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.781 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #116 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.796 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #117 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.812 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #118 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.843 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #119 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.859 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #120 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.875 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #121 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.906 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #122 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.921 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #123 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.937 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #124 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.953 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:27 PM #125 Text 0 File Cdrdrv.cpp, Line 1230
22:28:27.984 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:28:28 PM #126 Text 0 File Cdrdrv.cpp, Line 1230
22:28:28.000 - D: PIONEER DVD-RW DVR-111D : Queue again later
10:33:09 PM #127 SPTI -1135 File SCSIPassThrough.cpp, Line 291
D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 1B 2B 60 00 00 20 00 00 00
Sense Area: 0x71 00 03 00 1B 28 C0 0E 00 00 00 00 0C
Buffer x012b0000: Len x10000
0x00 00 01 BA 45 6A 14 6D B6 03 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 BE CA D8 BC 1E AB CA 43 8E
0xB6 34 4D 75 30 01 88 0E 89 A0 60 94 5A 3A 00 6E
10:33:09 PM #128 CDR -1135 File Writer.cpp, Line 302
Write error
10:33:09 PM #129 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
10:33:10 PM #130 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
10:33:10 PM #131 Text 0 File DVDR.cpp, Line 3337
EndDAO: Last written address was 1780575
10:33:10 PM #132 Phase 38 File APIProgress.cpp, Line 278
Burn process failed at 16x (22,160 KB/s)
10:33:10 PM #133 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
10:33:10 PM #134 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 21/11/2005 3:48:21 PM
File 'WNASPINT.DLL': Ver=V1.18, size=57344 bytes, created 5/11/2002 3:16:52 PM
File 'Drivers\PXHELP20.SYS': Ver=3.00.43J, size=36624 bytes, created 27/03/2007 5:55:31 PM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Hijack This Log...
Logfile of Trend Micro HijackThis v2.0.0 (BETA)
Scan saved at 10:50:31 PM, on 25/05/2007
Platform: Windows XP SP2 (WinNT 5.01.2600)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\csrss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\igfxtray.exe
C:\WINDOWS\system32\hkcmd.exe
C:\Program Files\Intel\NCS\PROSet\PRONoMgr.exe
C:\WINDOWS\system32\ELAN.exe
C:\WINDOWS\system32\rundll32.exe
C:\Program Files\CyberLink DVD Solution\PowerDVD\PDVDServ.exe
C:\WINDOWS\system32\NotifyPhoneBook.exe
C:\WINDOWS\SOUNDMAN.EXE
C:\Program Files\Logitech\iTouch\iTouch.exe
C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe
C:\Program Files\ScanSoft\OmniPageSE2.0\OpwareSE2.exe
C:\Program Files\Eset\nod32kui.exe
C:\Program Files\QuickTime\qttask.exe
C:\Program Files\iTunes\iTunesHelper.exe
C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\avgas.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Messenger\msmsgs.exe
C:\Program Files\Common Files\Ahead\Lib\NMBgMonitor.exe
C:\Program Files\Google\Google Talk\googletalk.exe
C:\WINDOWS\system32\ntvdm.exe
C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\guard.exe
C:\Program Files\Eset\nod32krn.exe
C:\Program Files\Spyware Doctor\sdhelp.exe
C:\WINDOWS\system32\wdfmgr.exe
C:\Program Files\iPod\bin\iPodService.exe
C:\WINDOWS\System32\alg.exe
C:\Program Files\MSN Messenger\usnsvc.exe
C:\Program Files\Webshots\webshots.scr
C:\Program Files\FireTrust\MailWasher Pro\MailWasher.exe
C:\Program Files\Mozilla Firefox\firefox.exe
C:\Documents and Settings\Owner\Desktop\HiJackThis_v2.exe
C:\WINDOWS\system32\wbem\wmiprvse.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://windowsupdate.microsoft.com/
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = proxy.iprimus.com.au:8080
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.iprimus.com.au;*.primustel.com.au;*.primus.com.au;<local>
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: PCTools Site Guard - {5C8B2A36-3DB1-42A4-A3CB-D426709BBFEB} - C:\PROGRA~1\SPYWAR~1\tools\iesdsg.dll
O2 - BHO: Canon Easy Web Print Helper - {68F9551E-0411-48E4-9AAF-4BC42A6A46BE} - C:\Program Files\Canon\Easy-WebPrint\EWPBrowseLoader.dll
O2 - BHO: Groove GFS Browser Helper - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\PROGRA~1\MICROS~2\Office12\GRA8E1~1.DLL
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
O2 - BHO: PCTools Browser Monitor - {B56A7D7D-6927-48C8-A975-17DF180C71AC} - C:\PROGRA~1\SPYWAR~1\tools\iesdpb.dll
O3 - Toolbar: Easy-WebPrint - {327C2873-E90D-4c37-AA9D-10AC9BABA46C} - C:\Program Files\Canon\Easy-WebPrint\Toolband.dll
O4 - HKLM\..\Run: [IgfxTray] C:\WINDOWS\system32\igfxtray.exe
O4 - HKLM\..\Run: [HotKeysCmds] C:\WINDOWS\system32\hkcmd.exe
O4 - HKLM\..\Run: [PRONoMgr.exe] C:\Program Files\Intel\NCS\PROSet\PRONoMgr.exe
O4 - HKLM\..\Run: [RemoveElanIcon] C:\WINDOWS\system32\ELAN.exe
O4 - HKLM\..\Run: [AME_CSA] rundll32 AmeCSA.cpl,RUN_DLL
O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Program Files\Java\jre1.5.0_06\bin\jusched.exe
O4 - HKLM\..\Run: [RemoteControl] "C:\Program Files\CyberLink DVD Solution\PowerDVD\PDVDServ.exe"
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [Easy-PrintToolBox] C:\Program Files\Canon\Easy-PrintToolBox\BJPSMAIN.EXE /logon
O4 - HKLM\..\Run: [zBrowser Launcher] C:\Program Files\Logitech\iTouch\iTouch.exe
O4 - HKLM\..\Run: [MediaRemote] D:\MediaRemote.exe
O4 - HKLM\..\Run: [GrooveMonitor] "C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe"
O4 - HKLM\..\Run: [OpwareSE2] "C:\Program Files\ScanSoft\OmniPageSE2.0\OpwareSE2.exe"
O4 - HKLM\..\Run: [nod32kui] "C:\Program Files\Eset\nod32kui.exe" /WAITSERVICE
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [!AVG Anti-Spyware] "C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\avgas.exe" /minimized
O4 - HKLM\..\Run: [NeroFilterCheck] C:\Program Files\Common Files\Ahead\Lib\NeroCheck.exe
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\MSN Messenger\msnmsgr.exe" /background
O4 - HKCU\..\Run: [BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}] "C:\Program Files\Common Files\Ahead\Lib\NMBgMonitor.exe"
O4 - HKCU\..\Run: [googletalk] "C:\Program Files\Google\Google Talk\googletalk.exe" /autostart
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\RunOnce: [nlpo_01] cmd.exe /c md "%USERPROFILE%\Local Settings\Temp" (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\RunOnce: [nlpo_03] rundll32 advpack.dll,LaunchINFSection nlite.inf,I (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\RunOnce: [nlpo_04] rundll32 advpack.dll,DelNodeRunDLL32 "%SystemRoot%\System32\dllcache" (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\RunOnce: [nlpo_05] cmd.exe /c md "%SystemRoot%\System32\dllcache" (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\RunOnce: [nlpo_06] cmd.exe /C move /Y "%SystemRoot%\System32\syssetub.dll" "%SystemRoot%\System32\syssetup.dll" (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\RunOnce: [nlpo_07] rundll32 advpack.dll,LaunchINFSection nlite.inf,nLiteReg (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\RunOnce: [nlpo_08] rundll32 advpack.dll,LaunchINFSection nlite.inf,S (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-20\..\RunOnce: [nlpo_01] cmd.exe /c md "%USERPROFILE%\Local Settings\Temp" (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\S-1-5-18\..\RunOnce: [tscuninstall] %systemroot%\system32\tscupgrd.exe (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
O4 - HKUS\.DEFAULT\..\RunOnce: [tscuninstall] %systemroot%\system32\tscupgrd.exe (User 'Default user')
O4 - Startup: Event Minder Reminders.lnk = C:\HALLMARK\EMREMIND.EXE
O4 - Startup: OneNote 2007 Screen Clipper and Launcher.lnk = C:\Program Files\Microsoft Office\Office12\ONENOTEM.EXE
O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE
O8 - Extra context menu item: Add to AMV Convert Tool... - C:\Program Files\MP3 Player Utilities 4.00\AMVConverter\grab.html
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office12\EXCEL.EXE/3000
O8 - Extra context menu item: Easy-WebPrint Add To Print List - res://C:\Program Files\Canon\Easy-WebPrint\Toolband.dll/RC_AddToList.html
O8 - Extra context menu item: Easy-WebPrint High Speed Print - res://C:\Program Files\Canon\Easy-WebPrint\Toolband.dll/RC_HSPrint.html
O8 - Extra context menu item: Easy-WebPrint Preview - res://C:\Program Files\Canon\Easy-WebPrint\Toolband.dll/RC_Preview.html
O8 - Extra context menu item: Easy-WebPrint Print - res://C:\Program Files\Canon\Easy-WebPrint\Toolband.dll/RC_Print.html
O8 - Extra context menu item: MediaManager tool grab multimedia file - C:\Program Files\MP3 Player Utilities 4.00\MediaManager\grab.html
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204
O16 - DPF: {193C772A-87BE-4B19-A7BB-445B226FE9A1} (ewidoOnlineScan Control) - http://downloads.ewido.net/ewidoOnlineScan.cab
O16 - DPF: {2917297F-F02B-4B9D-81DF-494B6333150B} (Minesweeper Flags Class) - http://messenger.zone.msn.com/binary/MineSweeper.cab50997.cab
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/windowsupdate/v6/V5Controls/en/x86/client/wuweb_site.cab?1170153269496
O16 - DPF: {8E0D4DE5-3180-4024-A327-4DFAD1796A8D} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsClient.cab50997.cab
O18 - Protocol: grooveLocalGWS - {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:\PROGRA~1\MICROS~2\Office12\GR99D3~1.DLL
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\system32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\system32\browseui.dll
O23 - Service: AVG Anti-Spyware Guard - Anti-Malware Development a.s. - C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\guard.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1050\Intel 32\IDriverT.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: NBService - Nero AG - C:\Program Files\Nero\Nero 7\Nero BackItUp\NBService.exe
O23 - Service: Intel NCS NetService (NetSvc) - Intel(R) Corporation - C:\Program Files\Intel\NCS\Sync\NetSvc.exe
O23 - Service: NOD32 Kernel Service (NOD32krn) - Eset - C:\Program Files\Eset\nod32krn.exe
O23 - Service: Roxio UPnP Renderer 9 - Unknown owner - C:\Program Files\Common Files\Sonic Shared\RoxioUPnPRenderer9.exe (file missing)
O23 - Service: Roxio Upnp Server 9 - Unknown owner - C:\Program Files\Common Files\Sonic Shared\RoxioUpnpService9.exe (file missing)
O23 - Service: LiveShare P2P Server 9 (RoxLiveShare9) - Unknown owner - C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxLiveShare9.exe (file missing)
O23 - Service: PC Tools Spyware Doctor (SDhelper) - Unknown owner - C:\Program Files\Spyware Doctor\sdhelp.exe
O23 - Service: stllssvr - Unknown owner - C:\Program Files\Common Files\SureThing Shared\stllssvr.exe (file missing)
End of file - 10985 bytes
To anyone that helps here's a little drink...
For the guys... :Hammys pint:
and for the gals... :hammy:
:flowers:
I even tried using Roxio to burn but that didn't help so took it off and put Nero back on. Which brings me to another question, can you have both on for different things or could they clash??
Cherubs,
QuoteI just cant seem to burn movies anymore
Just a thought but have you tried recording any thing else with your DVD-RW to make sure that it is working, if not try a back-up of some of your files to DVD.
Witch version of DVD Shrink is it you use as if it is an old version perhaps Version - 3.2.0.15 may work for you
GR@PH;<'S :Hammys pint:
Yeah I'm starting to wonder if its the burner as well. I've used it alot for CD's and that works fine, just never seems to work for DVD's, I'll see if I can burn one of my home movies.
Also is there anything on my hijack this log which shouldn't be there, I thought I'd keep the box open until some took a look at it, you just never know when something may have sneaked in or I've put something on which shouldn't be there.
(BETA)Hi, Cherubs.
Trend Micro's version of HJT is still in beta. I don't know that we will see anything, but please uninstall it and install HijackThis© from one of the following sites:
- http://www.thespykiller.co.uk/files/HJTsetup.exe
- http://downloads.malwareremoval.com/HJTsetup.exe
- http://security-central.us/downloads/HJTsetup.exe
At the download prompt, choose "Save"
- Navigate to the saved file and double-click the installer, HJTsetup.exe
- By default, HijackThis will be installed on your computer at C:\Program Files\HijackThis, making an entry in the start menu and also providing a desktop shortcut
- When the installation is complete, double-click the HijackThis icon on your desktop
- Select "Scan"
- When the scan is completed, select "Save log"
- Select a name for this first log and a text file will be produced in Notepad.
- Please UNcheck Word Wrap in Notepad (Click Format > UNcheck Word Wrap)
- Copy the text file and paste it as a reply
- Do NOT fix anything with HijackThis yet. Most of what is found is harmless or even required
- Close HijackThis and Notepad
Hi corrine, I took the Hijack thing off and didn't bother with the other one as I'm not worried about viruses etc with this issue. But if you think I should do it then let me know.
I burnt all my data etc to a DVD and that worked fine, last night I updated the firmware for the burner and then tried again and once again I made another coaster!!
Is there anyone that knows what my error message meant in the first post?
My first question is do you have 2 CD drives on that computer ..
This is how I use DVD Shrink 3.2 , first I put the disc to be copied in to drive D .
Then I put the blank DVD in to my E drive ..
Then I open up shrink DVD and select open disc making sure it pointing to my D drive
Then I encode it, when it has finished encoding I then open up mydocs and make a new folder giving it the name of the DVD I'm burning then I go back to Shrink dvd and tell it to backup the files, it then gives me the option to browse for the folder I want it to backup to, when it has finished backing up the files shrink DVD then automatically starts to burn the DVD in my E drive ..
I have also seen this problem before and it was related to shrink DVD not being able to find to right folder to burn the files from If I were you I would start there as I think by default shrink dvd will store them in your temporary internet files folder..
Clean out your temporary internet files folder making sure it empty and try to burn the dvd again and let me know how you get on ..
tell us about your pc.
how old is it??
what type of cpu and what is its speed?
how much ram?
what is your swap file size set to?
when was the last time you installed drivers for the dvd burner?
have you tried cleaning the dvd burner? (it's about a $19 disk with brushes on it and liquids)
how many unneeded services is xp running?
how many unneeded programs is xp running?
are you browsing the internet while burning?
