Security => Security Software Programs => Topic started by: Corrine on July 17, 2005, 02:03:41 AM
Title: Need help with Ad-Aware SE?
Post by: Corrine on July 17, 2005, 02:03:41 AM
Do you need help with Ad-Aware SE?
We would be happy to assist.  Please post your question(s) or a logfile in a new topic of your own.
Logfile Preparation and Posting Instructions
Download Ad-Aware SE (http://lavasoft.element5.com/support/download/)) and install it. If you already have Ad-Aware SE, please configure it as indicated below. (Note that Ad-Aware SE is free for non-commercial, non-governmental, and non-educational use.) If you have a previous version of Ad-Aware, please install Build 1.06r1.
Note:  Some Files and Folders may be Hidden, by design. Please ensure that "Show Hidden Files and Folders" is enabled. (Instructions: How to make Windows show all files) (http://service1.symantec.com/SUPPORT/tsgeninfo.nsf/docid/2002092715262339?Open&src=ent&docid=2002092514302348&nsf=ent-security.nsf&view=docid&dtype=corp%E2%88%8F=Symantec%20AntiVirus%20Corporate%20Edition&ver=8.x&osv=&osv_lvl=).  Reverse this process after your system is clean.
1)  Run the Webupdate feature. (Click on the Globe icon > Click connect > Click OK > Click Finish.)
2)  Set up the Configurations (Click the gear wheel at the top) as follows:
    General Button > Safety & Settings:  Check (Green) all three.
    Advanced Button > Logfile Detail Level:  All options under this should be checked (Green).
    Tweak Button >
      >  Scanning Engine:  Check "Obtain command line of scanned processes"
      >  Log Files:  Please check only
            * "Include basic Ad-Aware settings in logfile"
            * "Include additional Ad-Aware settings in logfile"
            * "Include reference summary in logfile"
      > Click on "Proceed"
3)  To start the scan, Click > "Scan Now"
      >  Deselect "Search for negligible risk entries" as negligible risk entries (MRU's) are not considered to be a threat.
      >  Select "Search for low-risk threats"
      >  Select "Perform full system scan"
      >  Click Next
          A full scan is the in-depth scan mode that scans your whole computer for Spyware infections.
          When performing a full scan the following scan settings are used:
                * Full Memory Scan is performed
                * Registry Scan is performed
                * Deep Registry scan is performed
                * Cookie-Scan is performed
                * Favorites are scanned
                * Hosts file is scanned
                * Conditional scans are performed
                * Archive files are scaned
                * All fixed drives are scanned
4)  When the scan has completed, click "Show Logfile".  Copy/paste the complete log file in a thread of your own.  Do not quarantine or remove anything at this time, just post a complete logfile. This sometimes takes 2-3 posts to get it all posted. You will know you are at the end when you see the "Summary of this scan" information has been posted.
Thank you, LandzDown Team
Title: Re: Need help with Ad-Aware SE?
Post by: Corrine on December 18, 2005, 06:00:55 PM
Ad-Aware Freezing/Hanging Help
Ad-Aware SE freezing, stalling or unable to quarantine can be caused by many different situations.  We have found that almost all freezing issues that are resolved were due to corrupted files or some other machine issue.  That does not mean that Ad-Aware SE will successfully run on all machines, but this is no different than any other software. There are simply too many operating systems and program combinations for any program to run in all possible environments.
Collected here are solutions that have been found will generally work.  Although I have updated the original document a number of times, thanks go to the following for their contributions, including suggestions, solutions and verbage for the original document:  appetiser, cannymum, EASTER, Eric the Red, IAMSKINZ, Option^Explicit, rmetzger, Sigma and Totro.
NOTE:  to receive individual attention, please create a topic of your own, kindly indicating what actions you have taken, including a debugf log if you still cannot complete a scan.
Launch Ad-Aware SE and check for any Definition File updates.  Click on the gear to access the Configuration Menu.  Click on Tweak > Cleaning Engine > UNcheck "Always try to unload modules before deletion".
A.  Manually Clean 'Temporary Internet Files'
Clean the following directory contents (but not the directory folder). Please disconnect from the Internet (for broadband (DSL/Cable) users, it is recommended that you disconnect the cable connection) and close All open browsers.
Cleaning 'Temporary Internet Files'
