Security => Security Software Programs => Topic started by: Corrine on June 18, 2011, 07:31:58 PM
Title: Completely Uninstall and Reinstall WinPatrol
Post by: Corrine on June 18, 2011, 07:31:58 PM
There are occasions when the only way to solve a problem is to completely remove all traces and reinstall the program.  Although this step is very seldom needed with WinPatrol, the steps are provided below.
    REGISTRY DISCLAIMER:
    Important: The steps below include information on modifying the registry. Serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, it is strongly advised that you back up the registry before any modifications. Then, if a problem occurs, the registry can be restored.
    See Microsoft Knowledge Base Article 322756, "How to back up and restore the registry in Windows" located at http://support.microsoft.com/kb/322756.
    WinPatrol PLUS Note
    Important: The steps below will remove your WinPatrol PLUS Username and Registration Code from memory.  Before going further, launch WinPatrol and click the PLUS tab.  Write down your Username and Reg Code.
Instructions:
Title: Re: Completely Uninstall and Reinstall WinPatrol
Post by: Corrine on May 14, 2012, 06:31:03 PM
Update:  http://www.landzdown.com/winpatrol-help-information/cannot-get-rid-of-win-patrol/msg153214/#msg153214
Quote from: BillPStudios on May 14, 2012, 06:13:48 PM
As always, you ask and I'll do my best to make everyone satisfied with their WinPatrol experience.
I have created a single WinPatrol Remove program which cleans up all the entries created in the registry (including the one previously mentioned) and all the files in our Program Files folders.
Ironically, the exefile registry entry could have been removed on the WinPatrol options tab by unchecking the Explorer Integration option.
Ultimately, all the features of the new stand alone WinPatrolRemove.exe will be integrated properly into our normal Add/Remove/Uninstall applet.  I will also be creating a WinPatrolRepair.exe program that will allow folks to fix individual requests without having to Uninstall WinPatrol.
For now however you can go to http://www.winpatrol.com/download.html and click on the WinPatrol Removal Program.
Thanks again,
Bill Pytlovany
BillP Studios
