Security => Analysis and Malware Removal => Topic started by: Doxiemrs on January 06, 2016, 02:38:46 AM
Title: Can't run frst
Post by: Doxiemrs on January 06, 2016, 02:38:46 AM
Hi. I can only check email on firefox. The IE won't work and the firefox either says connection reset or asks how I want to open: save or use IE. The only thing I've done to my laptop so far is run a quick scan with avast and a boot scan two do I emailed the two scans and downloaded. I clicked on run add administrator and the Windows alert comes up and says I may not have authorization to run but I am the administrator. Then it completely deletes the program. Can you help?
Title: Re: Can't run frst
Post by: Doxiemrs on January 06, 2016, 02:51:07 AM
I also meant to report that I emailed myself the two programs from my phone and then downloaded then on desktop, since my computer won't go to any website except google and Gmail.
Post by: Corrine on January 06, 2016, 10:01:29 PM
Hi, Doxiemrs.
It is difficult to provide a solution blindly without knowing what settings have been changed and by what program.
1.  Since you can open your email, if you are subscribed to this topic, you should get a copy of my reply in your email.  If not, try to copy/paste the lines below from your phone to an email sent to yourself.
Please copy/paste the lines in bold below to Notepad:
@Echo on
pushd\windows\system32\drivers\etc
attrib -h -s -r hosts
echo 127.0.0.1 localhost>HOSTS
attrib +r +h +s hosts
popd
ipconfig /release
ipconfig /renew
ipconfig /flushdns
netsh winsock reset all
netsh int ip reset all
shutdown -r -t 1
del %0
Save as flush.bat to your desktop.
Double-click flush.bat file to run it. Your computer will reboot.
Note:  Right-click flush.bat and select "Run as Administrator".
2.  Do you have Malwarebytes installed?  If so, try to update it following the steps below:
To retrieve the Malwarebytes Anti-Malware scan log information (Method 1)
To retrieve the Malwarebytes Anti-Malware 2.0 scan log information (Method 2)
Logs are named by the date of scan in the following format: mbam-log-yyyy-mm-dd and automatically saved to the following locations:
-- XP: C:\Documents and Settings\<Username>\Application Data\Malwarebytes\Malwarebytes Anti-Malware\Logs\mbam-log-yyyy-mm-dd
-- Vista, Windows 7/8: C:\ProgramData\Malwarebytes\Malwarebytes Anti-Malware\Logs\mbam-log-yyyy-mm-dd
