I recontly downloaded the upgraded versions for Spybot, SpywareBlaster, and Ad-Aware. Since the upgrade, whenever I try to update the defintions for any of the three programs, the program stops responding. I tried manual updates, but they did not work. Before I upgraded the version of the programs, they all worked fine together. Does anyone have any suggestions on how to get the programs to work?
PS: I am not the only person haveing this problem
PSS: I will inculde a log report latter.
i have one quick idea?
what are you using as a firewall?
MOST firewalls would see a change and ask you if you want to allow, so i would check and make sure that the new versions are in the "trusted aps" area !
and do you use a router? check your settings in the program and make sure it's set right
That sounds like the best place to check first! Even though they are the same software you had before, the versions are new, so your firewall needs permission for granting those update programs to access the internet.
If the firewall check doesn't solve your problem, please see the instructions in the linked topic below and post a HJT logfile for review.
http://www.landzdown.com/index.php/topic,423.0.html
Thanks & please let us know how you make out.
Did you update to a new version of Zone Alarm as well?
1. I forgot to mention I have Norton SystemWorks 2005 and Norton Persional Firewall 2005. They both worked fine, and I ameditly checked if Norton's Firewall was blocking it, because I thought that was an abvious solution, but they are set to always allow Ad-Aware, SpyBot, and Spyware Blaster to connect to the internet.
PS: I would have included the log, but someone close Ad-Aware on me, and I need to rescan the computer.
PSS: I do not have ZoneAlarm
PSSS: I do not use a router/network or proxies
A router is one of the first things you need when going online, especially if you have a broadband connection.
well we need some exact error codes or something
and highspeed,dialup?
and if you feel lucky, turn off the firewall for a few seconds to do a update on one of the programs
just because your firewall said it is allowed doesn't mean much !
i know of two brands of firewalls that had that problem, sometime you could fix by deleting it from the firewall and then try again and alow it again, sometimes required a reload of the firewall software !
if you have a dialup you can see if data is going both ways
the more info you can provide the more help we can give
if XP have you disabled the ms firewall?
Hi, campsoup1988 :)
You may have something blocking your access to those security sites in your HOSTS file ...
Have a look and see what's in there ...
It should look like this (unless you have deliberately added sites - or using a "managed" HOSTS file) ....
This is what a Default "Clean Original" HOSTS File should look like.
For XP it is located in > C:\WINDOWS\System32\Drivers\etc\Hosts
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
Please check it out and let us know ...
The other question is did you un-install the older versions of those three proggies before you installed the new versions?
Cheers, Totro :thumbsup:
I do not have a ruter because I do not have a network, and I have a 56k dialup. I will not disable Norton Firewall 2005. I keep WinXp's SP2's Firewall disabled because I use Norton's instead.
mitch: what do you mean about seeing if data is going both ways?
Totro: what do you want me to do the host list?
open the HOST file in notepad
there is no file extension. just HOST
see if those programs are in a list there?
if so someone/thing put them there and that is why you can't update
confirm nothing has changed your settings
i do not know norton firewall ( or want to)
butif you can see a applications list, remove one of them, then try and update and it should ask if you want to allow and say "yes"
as i said it would not be the first time a firewall got a bit confused !
do you have any program like" netstat live" so you can see the data transfer/and rate from and two your computer ?
and can show ping times
http://www.analogx.com/contents/download/network/nsl.htm (http://www.analogx.com/contents/download/network/nsl.htm)
now what about a error message? and exactly what it is doing???
Hi again campsoup1988 :)
As mitch says we are looking (in the HOSTS file) for where a baddie may have entered the Update sites you are trying to access.
They may be there but prefixed by the address 127.0.0.1 which is the address of your own machine thus if you try to update, the HOSTS file redirects the enquiry right back to you! Thus you never get to the site!
Does your HOSTS file look any different to the default one I posted?
You can always copy/paste your HOST File here and we will look at it for you (Provided it is not a huge great long intentionally "Managed" HOSTS - in which case it would prove so long as to be difficult to post LOL! I think you would know if you have a Managed HOSTS because you would have built it yourself or be using one of the "pre-configured" ones that are available...
If you are uncomfortable with playing with the HOSTS file there is a very good (small) program called HostsFileReader which I use ...
Please download the "HostsFileReader" by Option^Explicit. It is a small program which will allow you to find/view/open/read/edit/restore to default settings your HOSTS file. Instructions are on the display screen of the program. You may want to restore to the default settings.
It is available from mitch's very own security site here >>>
http://members.accessbee.com/mitch/HostsFileReader.zip
the sites added to the host list was added from Spybot S&D
Here is my hosts list:
# space.
# For example:
127.0.0.1 localhost
# Start of entries inserted by Spybot - Search & Destroy
127.0.0.1 babe.the-killer.bz
127.0.0.1 babe.k-lined.com
127.0.0.1 did.i-used.cc
127.0.0.1 coolwwwsearch.com
127.0.0.1 coolwebsearch.com
127.0.0.1 hi.studioaperto.net
127.0.0.1 www.webbrowser.tv
127.0.0.1 www.wazzupnet.com
127.0.0.1 gueb.com
127.0.0.1 kabex.com
127.0.0.1 www.hityou.com
127.0.0.1 miosearch.com
127.0.0.1 wazzupnet.com
127.0.0.1 213.131.225.2
127.0.0.1 www.blue-elefant.com
127.0.0.1 babeweb.de
127.0.0.1 start-seite.com
127.0.0.1 sexolymp.com
127.0.0.1 toriii.cc
127.0.0.1 www.xtipp.de
127.0.0.1 urawa.cool.ne.jp
127.0.0.1 777search.com
127.0.0.1 ace-webmaster.com
127.0.0.1 aifind.info
127.0.0.1 amateurliveshow.com
127.0.0.1 anarchylolita.com
127.0.0.1 anarchyporn.com
127.0.0.1 approvedlinks.com
127.0.0.1 cantfind.com
127.0.0.1 castingsamateur.com
127.0.0.1 cyberrape.com
127.0.0.1 dialerclub.com
127.0.0.1 exit.megago.com
127.0.0.1 fastmetasearch.com
127.0.0.1 findwhatevernow.com
127.0.0.1 globesearch.com
127.0.0.1 hotfreebies.com
127.0.0.1 krankin.com
127.0.0.1 begin2search.com
127.0.0.1 mainstreamdollars.com
127.0.0.1 live.sex-explorer.com
127.0.0.1 loveadot.com
127.0.0.1 megaseek.net
127.0.0.1 mixsearch.com
127.0.0.1 munky.com
127.0.0.1 newtopsites.com
127.0.0.1 noblindlinks.com
127.0.0.1 r.babenet.com
127.0.0.1 searchresult.net
127.0.0.1 sexarena.org
127.0.0.1 skeech.com
127.0.0.1 superwp.by.ru
127.0.0.1 sureseeker.com
127.0.0.1 wethere.com
127.0.0.1 wowsearch.org
127.0.0.1 www.xxx.com
127.0.0.1 www.websearch.com
127.0.0.1 partner23.firehunt.com
127.0.0.1 screensaver.it
127.0.0.1 xads.cliks.org
127.0.0.1 xwebsearch.biz
127.0.0.1 znext.com
127.0.0.1 rawtocash.net
127.0.0.1 7search.com
127.0.0.1 zestyfind.com
127.0.0.1 dev.ntcor.com
127.0.0.1 search.xrenoder.com
127.0.0.1 193.125.201.50
127.0.0.1 www.allcybersearch.com
127.0.0.1 www.tinybar.com
127.0.0.1 topsite.us
127.0.0.1 topsites.us
127.0.0.1 topsitez.us
127.0.0.1 out.true-counter.com
127.0.0.1 www.cnetadd.com
127.0.0.1 okmmm.com
127.0.0.1 www.139mm.com
127.0.0.1 008k.com
127.0.0.1 00hq.com
127.0.0.1 1-domains-registrations.com
127.0.0.1 100sexlinks.com
127.0.0.1 157.238.62.14
127.0.0.1 1sexparty.com
127.0.0.1 1stpagehere.com
127.0.0.1 2020search.com
127.0.0.1 209.66.114.130
127.0.0.1 24teen.com
127.0.0.1 36site.com
127.0.0.1 4corn.net
127.0.0.1 66.117.14.138
127.0.0.1 66.197.100.83
127.0.0.1 66.250.107.99
127.0.0.1 66.250.107.100
127.0.0.1 66.250.107.101
127.0.0.1 66.250.130.194
127.0.0.1 66.250.170.107
127.0.0.1 66.250.57.26
127.0.0.1 66.250.57.27
127.0.0.1 66.250.57.28
127.0.0.1 66.250.74.150
127.0.0.1 777top.com
127.0.0.1 8ad.com
127.0.0.1 aboutclicker.com
127.0.0.1 abrp.net
127.0.0.1 accessthefuture.net
127.0.0.1 acemedic.com
127.0.0.1 actionbreastcancer.org
127.0.0.1 activexupdate.com
127.0.0.1 adamsupportgroup.org
127.0.0.1 adasearch.com
127.0.0.1 adipics.com
127.0.0.1 adspics.com
127.0.0.1 adult-engine-search.com
127.0.0.1 adult-erotic-guide.net
127.0.0.1 adult-friends-finder.net
127.0.0.1 adulthyperlinks.com
127.0.0.1 adulttds.com
127.0.0.1 advert.exaccess.ru
127.0.0.1 agentstudio.com
127.0.0.1 africaspromise.org
127.0.0.1 akril.com
127.0.0.1 alcatel.ws
127.0.0.1 alfa-search.com
127.0.0.1 all-inet.com
127.0.0.1 allabtcars.com
127.0.0.1 allabtjeeps.com
127.0.0.1 allcybersearch.com
127.0.0.1 allhyperlinks.com
127.0.0.1 allinternetbusiness.com
127.0.0.1 almarvideos.com
127.0.0.1 amandamountains.com
127.0.0.1 amigeek.com
127.0.0.1 amisbusiness.com
127.0.0.1 analmovi.com
127.0.0.1 anin.org
127.0.0.1 annaromeo.com
127.0.0.1 antrocity.com
127.0.0.1 anything4health.com
127.0.0.1 apsua.com
127.0.0.1 aregay.com
127.0.0.1 arheo.com
127.0.0.1 arizonaweb.org
127.0.0.1 armitageinn.com
127.0.0.1 art-func.com
127.0.0.1 art-xxx.com
127.0.0.1 artachnid.com
127.0.0.1 asiankingkong.com
127.0.0.1 ass-gals.com
127.0.0.1 athenrye.com
127.0.0.1 avian-ads.com
127.0.0.1 ayakawamura.com
127.0.0.1 ayumitaniguchi.com
127.0.0.1 bannedhost.net
127.0.0.1 barbudafarms.com
127.0.0.1 barnandfence.com
127.0.0.1 batsearch.com
127.0.0.1 baygraphicsllc.com
127.0.0.1 bb-search.com
127.0.0.1 bbbsearch.com
127.0.0.1 bedhome.com
127.0.0.1 bediadance.com
127.0.0.1 bellabasketsfl.com
127.0.0.1 bernaolatwin.com
127.0.0.1 best-counter.com
127.0.0.1 best-hardpics.com
127.0.0.1 best-winning-casino.com
127.0.0.1 bestcrawler.com
127.0.0.1 bestfor.ru
127.0.0.1 bestporngate.com
127.0.0.1 bestxporno.com
127.0.0.1 blackjack-free.net
127.0.0.1 blender.xu.pl
127.0.0.1 bodaciousbabette.com
127.0.0.1 boobdoll.com
127.0.0.1 boobsandtits.com
127.0.0.1 boobsclub.com
127.0.0.1 boredlife.com
127.0.0.1 bowlofogumbo.com
127.0.0.1 bradcoem.org
127.0.0.1 brandiyoung.com
127.0.0.1 brookeburn.com
127.0.0.1 bucps.com
127.0.0.1 burgerkingbigscreen.com
127.0.0.1 buscards.net
127.0.0.1 bustyrussell.com
127.0.0.1 buttejazz.org
127.0.0.1 buyselldomain.net
127.0.0.1 calcioturris.com
127.0.0.1 canberracricketcoaching.com
127.0.0.1 candycantaloupes.com
127.0.0.1 careers.dulcineasystems.net
127.0.0.1 carsands.com
127.0.0.1 carsrentals.net
127.0.0.1 casino-gambling-1.net
127.0.0.1 casino-gambling-2.net
127.0.0.1 casino-onlines.net
127.0.0.1 casino.com.free.game.pogo.gratisdownloads.nl
127.0.0.1 casino2win.net
127.0.0.1 casinomidas.net
127.0.0.1 casinonline.net
127.0.0.1 catallogue.com
127.0.0.1 catsss.da.ru
127.0.0.1 caxa.ru
127.0.0.1 cclebali.org
127.0.0.1 ceewawires.org
127.0.0.1 certumgroup.com
127.0.0.1 chelancatering.com
127.0.0.1 childrenvilla.com
127.0.0.1 chips-4-free.com
127.0.0.1 chrisswasey.com
127.0.0.1 chriswallace.net
127.0.0.1 ckick4thumbs.com
127.0.0.1 clackamasliteraryreview.com
127.0.0.1 clearsearch.cc
127.0.0.1 clearsearch.net
127.0.0.1 clickaire.com
127.0.0.1 clickyestoenter.net
127.0.0.1 clrsch.com
127.0.0.1 cmtapestry.com
127.0.0.1 cool-homepage.co
127.0.0.1 cool-homepage.com
127.0.0.1 cool-search.net
127.0.0.1 cool-search.netfartpost.com
127.0.0.1 cool-web-search.com
127.0.0.1 coolfetishsite.com
127.0.0.1 coolfreehost.com
127.0.0.1 coolfreepage.com
127.0.0.1 coolfreepages.com
127.0.0.1 coolmoneysearch.com
127.0.0.1 coolpornsearch.com
127.0.0.1 coolsearcher.info
127.0.0.1 coolwebsearsh.com
127.0.0.1 copmtraine.com
127.0.0.1 couldnotfind.com
127.0.0.1 count-all.com
127.0.0.1 cracks.me.uk
127.0.0.1 creamedcutties.com
127.0.0.1 creditsearchonline.com
127.0.0.1 crestring.com
127.0.0.1 crooder.com
127.0.0.1 curvedspaces.com
127.0.0.1 cvs.jps.ru
127.0.0.1 cvsymphony.com
127.0.0.1 cydom.com
127.0.0.1 daily-gals.com
127.0.0.1 dancingbabycd.com
127.0.0.1 datanotary.com
127.0.0.1 datareco.com
127.0.0.1 davemarshall.org
127.0.0.1 dcfitusa.com
127.0.0.1 defaultsearch.net
127.0.0.1 desarrollocreativo.com
127.0.0.1 develip.com
127.0.0.1 dewis.spb.ru
127.0.0.1 dewis.us
127.0.0.1 df809jow4wj2304lfd0sf9fsd0a2t4ldf809jow4wj2304lfd0sf9fsd0a2t4ld.biz
127.0.0.1 dietpills4free.com
127.0.0.1 dietpussy.com
127.0.0.1 digistreamsa.com
127.0.0.1 dionforvalleycouncil.org
127.0.0.1 doctorwaldron.com
127.0.0.1 document-not-found.pornpic.org
127.0.0.1 doggyaction.com
127.0.0.1 domain-your-registration.com
127.0.0.1 domains-for-you-online.com
127.0.0.1 domains2003.net
127.0.0.1 domkrat.com
127.0.0.1 dp-host.com
127.0.0.1 dragqueen.gay-clan.com
127.0.0.1 drug-sources-exposed.com
127.0.0.1 drvvv.com
127.0.0.1 dutch-sex.com
127.0.0.1 dvdbank.org
127.0.0.1 e-localad.com
127.0.0.1 e-plus.cc
127.0.0.1 e-websitesolutions.com
127.0.0.1 eases.net
127.0.0.1 easy-search.net
127.0.0.1 easycategories.com
127.0.0.1 ecosrioplatenses.org
127.0.0.1 ecstasyporn.net
127.0.0.1 eikokoike.com
127.0.0.1 epornsex.com
127.0.0.1 euuu.com
127.0.0.1 evidence-detector.biz
127.0.0.1 evilspidercomics.com
127.0.0.1 ewebsearch.net
127.0.0.1 findloss.com
127.0.0.1 excellentsckin.com
127.0.0.1 extremeseek.net
127.0.0.1 f*ckdenniss.com
127.0.0.1 f*cknicepics.com
127.0.0.1 faithstevens.com
127.0.0.1 fantasiewelten.com
127.0.0.1 farmsteadbandb.com
127.0.0.1 fartpost.com
127.0.0.1 fastwebfinder.com
127.0.0.1 faxporn.com
127.0.0.1 fickenisgeil.de
127.0.0.1 finance-loans.com
127.0.0.1 find-itnow.com
127.0.0.1 find-uk-health.co.uk
127.0.0.1 find4u.net
127.0.0.1 findit-now.com
127.0.0.1 findthesite.com
127.0.0.1 findthewebsiteyouneed.com
127.0.0.1 fionasteel.com
127.0.0.1 firstbookmark.net
127.0.0.1 fitness-free.com
127.0.0.1 foodvacations.net
127.0.0.1 forex.jps.ru
127.0.0.1 forexcredit.com
127.0.0.1 forexcredit.ru
127.0.0.1 formingfusions.com
127.0.0.1 forsythfire.net
127.0.0.1 forthline.com
127.0.0.1 free-chipes.com
127.0.0.1 free-f*cking-video.com
127.0.0.1 free-hit.com
127.0.0.1 free-pics-and-movies.com
127.0.0.1 free-sex-movie-clips.net
127.0.0.1 free4porno.net
127.0.0.1 free64all.com
127.0.0.1 freebookmark.net
127.0.0.1 freebookmarks.net
127.0.0.1 freecategories.com
127.0.0.1 freecoolhost.com
127.0.0.1 freerbhost.com
127.0.0.1 freeshemalepics.net
127.0.0.1 freeyaho.com
127.0.0.1 freshseek.com
127.0.0.1 freshteensite.com
127.0.0.1 gabrielscott.com
127.0.0.1 galpostgirls.com
127.0.0.1 gals-for-free.com
127.0.0.1 gambling-online4you.com
127.0.0.1 gameterror.net
127.0.0.1 gay50.com
127.0.0.1 generalsmeltingofcanada.com
127.0.0.1 geteens.com
127.0.0.1 getpicshere.com
127.0.0.1 gimmezamore.com
127.0.0.1 gimnasiaer.com
127.0.0.1 girls-porn-life.com
127.0.0.1 glbdf.org
127.0.0.1 global-finder.com
127.0.0.1 globe-finder.cc
127.0.0.1 globe-finder.com
127.0.0.1 gocybersearch.com
127.0.0.1 golftennis.net
127.0.0.1 good-mortgages-calculator.com
127.0.0.1 good-mortgages.net
127.0.0.1 goodsexs.com
127.0.0.1 googlebar.jps.ru
127.0.0.1 googlf.com
127.0.0.1 gradforum.org
127.0.0.1 gratis-porn-movie.com
127.0.0.1 gratis-pornopics.com
127.0.0.1 guzzycats.com
127.0.0.1 gzphoenix.com
127.0.0.1 hallnetaccolade.com
127.0.0.1 hand-book.com
127.0.0.1 happyanal.com
127.0.0.1 hard-gals.com
127.0.0.1 hardbodytgp.com
127.0.0.1 hardcoreover.com
127.0.0.1 hardloved.com
127.0.0.1 hardwareseek.net
127.0.0.1 harukaigawa.com
127.0.0.1 hccsolanonapa.org
127.0.0.1 health-protein.com
127.0.0.1 hentai4u.net
127.0.0.1 here4search.com
127.0.0.1 heyrichy.com
127.0.0.1 hi-search.com
127.0.0.1 hiddenguides.com
127.0.0.1 hitlistlyrics.com
127.0.0.1 holidayautostr.com
127.0.0.1 homemortage.ws
127.0.0.1 hostssp.com
127.0.0.1 hot-cartoon-sex.anime.american-teens.net
127.0.0.1 hotbookmark.com
127.0.0.1 hotels-list.net
127.0.0.1 hotelxxxcams.com
127.0.0.1 hotpopup.com
127.0.0.1 hotsearchbox.com
127.0.0.1 hotsex-series.com
127.0.0.1 hotstartpage.com
127.0.0.1 hqsex.biz
127.0.0.1 hugeporn4u.net
127.0.0.1 hunacsa.com
127.0.0.1 hupacasath.com
127.0.0.1 hzsx.com
127.0.0.1 icansearch.net
127.0.0.1 idgsearch.com
127.0.0.1 ie-search.com
127.0.0.1 incestporngate.com
127.0.0.1 infodigger.net
127.0.0.1 infoglobus.com
127.0.0.1 inherhole.com
127.0.0.1 insertthiscock.com
127.0.0.1 insurance-flood.net
127.0.0.1 insuranceall.net
127.0.0.1 internetsearch.ru
127.0.0.1 ionichost.com
127.0.0.1 ionomist.com
127.0.0.1 ipsex.net
127.0.0.1 itsanal.com
127.0.0.1 itseasy.us
127.0.0.1 iweb-commerce.com
127.0.0.1 iwebland.com
127.0.0.1 jeannineoldfield.com
127.0.0.1 jethomepage.com
127.0.0.1 jetseeker.com
127.0.0.1 jmhgallery.org
127.0.0.1 joannelatham.com
127.0.0.1 judin.ru
127.0.0.1 junkysex.com
127.0.0.1 karleyt.narod.ru
127.0.0.1 kathisomers.com
127.0.0.1 kazaa-lite.ws
127.0.0.1 keithgreenpro.com
127.0.0.1 kenmccaul.com
127.0.0.1 kilosex.com
127.0.0.1 kimhines.com
127.0.0.1 kinoru.com
127.0.0.1 ksdspups.org
127.0.0.1 landrape.com
127.0.0.1 lauraroebuck.com
127.0.0.1 leannalovelace.com
127.0.0.1 lesobank.ru
127.0.0.1 libertyonlinehosting.com
127.0.0.1 lingerie-mania.com
127.0.0.1 lisamatthew.com
127.0.0.1 liveholio.com
127.0.0.1 livenewspaper.com
127.0.0.1 louiseleeds.com
127.0.0.1 love-pix.com
127.0.0.1 lovelas.com
127.0.0.1 lovelysearch.com
127.0.0.1 low-taxes.com
127.0.0.1 luckysearch.net
127.0.0.1 lunitaweb.net
127.0.0.1 lustful-porno.com
127.0.0.1 mackinnonsbrook.org
127.0.0.1 madfinder.com
127.0.0.1 madisonmoons.com
127.0.0.1 madisonoilco.com
127.0.0.1 madonalive.com
127.0.0.1 majuozawa.com
127.0.0.1 makin-do.com
127.0.0.1 male4free.com
127.0.0.1 map-quest.org
127.0.0.1 marilynchamber.com
127.0.0.1 martfinder.com
127.0.0.1 massearch.com
127.0.0.1 matetrava.com
127.0.0.1 mature50.com
127.0.0.1 matureporngate.com
127.0.0.1 maxdzines.com
127.0.0.1 mcgeeforlabor.com
127.0.0.1 mdstunisie.org
127.0.0.1 medicare-insurance.net
127.0.0.1 medicare-supplemental.com
127.0.0.1 mega-dating-tips.com
127.0.0.1 megumikanzaki.com
127.0.0.1 meshalynn.com
127.0.0.1 meta-adult.com
127.0.0.1 meta-casino.com
127.0.0.1 meta-mobile.com
127.0.0.1 meta-porn.com
127.0.0.1 metafora.ru
127.0.0.1 metapoisk.ru
127.0.0.1 michiyonakajima.com
127.0.0.1 miconsultamedica.com
127.0.0.1 mikasakamoto.com
127.0.0.1 mikoni.com
127.0.0.1 militarygods.porn4porn.net
127.0.0.1 millennialpeople.org
127.0.0.1 mipham.org
127.0.0.1 missingcommand.com
127.0.0.1 mommykiss.com
127.0.0.1 moneyhunters.com
127.0.0.1 montgomeryhospitalanesthesia.com
127.0.0.1 morflot.com
127.0.0.1 mortgage-debt.net
127.0.0.1 mortismaximus.com
127.0.0.1 moscowwhores.com
127.0.0.1 moviecategories.com
127.0.0.1 mp3-pix.com
127.0.0.1 mrtg.jps.ru
127.0.0.1 msn-info.net
127.0.0.1 multipussy.com
127.0.0.1 mundopolar.com
127.0.0.1 mustv.com
127.0.0.1 mywebsearch.net
127.0.0.1 nativehardcore.com
127.0.0.1 naturalspy.com
127.0.0.1 nbasportsbook.net
127.0.0.1 needf*cknow.com
127.0.0.1 nellyslyrics.com
127.0.0.1 nepgyan.com
127.0.0.1 nesrecords.com
127.0.0.1 netshastra.net
127.0.0.1 nettime.ru
127.0.0.1 nettracker.jps.ru
127.0.0.1 netyellowpages.info
127.0.0.1 new-incest.com
127.0.0.1 newcategories.com
127.0.0.1 newcracks.com
127.0.0.1 newcracks.net
127.0.0.1 newlife-lajolla.com
127.0.0.1 newsexgate.com
127.0.0.1 newtonsracks.com
127.0.0.1 newxpics.com
127.0.0.1 nhlsportsbook.net
127.0.0.1 niagaracapital.com
127.0.0.1 niche-tv.com
127.0.0.1 nmrba.com
127.0.0.1 nocalories.net
127.0.0.1 nocensor.com
127.0.0.1 ormandcompany.com
127.0.0.1 nsbabes.com
127.0.0.1 nuclearwitness.org
127.0.0.1 nursemania.com
127.0.0.1 nvntour.com
127.0.0.1 nvphall.org
127.0.0.1 oborot.com
127.0.0.1 ocalalivestockmarket.com
127.0.0.1 ocsff.com
127.0.0.1 oeatlanta.com
127.0.0.1 oharrowsearch.com
127.0.0.1 ok-search.com
127.0.0.1 okulta.com
127.0.0.1 omegabrains.net
127.0.0.1 online-casino-1.net
127.0.0.1 online-casino-bonus.info
127.0.0.1 online-casinos-x.com
127.0.0.1 online-winning.net
127.0.0.1 onlineserverz.com
127.0.0.1 onlinetradings.net
127.0.0.1 onlycunt.com
127.0.0.1 onlyinsured.com
127.0.0.1 operanabuco.com
127.0.0.1 opsex.com
127.0.0.1 oregoncharters.org
127.0.0.1 otrlives.com
127.0.0.1 ozawamadoka.com
127.0.0.1 paigesummer.com
127.0.0.1 pamelacollections.com
127.0.0.1 panamcup.com
127.0.0.1 pantygirls4u.com
127.0.0.1 pantyhoserealm.com
127.0.0.1 pantyplace.com
127.0.0.1 pastubes.com
127.0.0.1 paulapage.com
127.0.0.1 paulhoover.com
127.0.0.1 payfortraffic.net
127.0.0.1 pedo.ws
127.0.0.1 people.1gb.ru
127.0.0.1 pervertbot.com
127.0.0.1 pharma-diet-pills.com
127.0.0.1 pharmacy2003.com
127.0.0.1 pharmalocator.com
127.0.0.1 phendimetrazine-tenuate-adipex.com
127.0.0.1 pics-videos.com
127.0.0.1 picsdir.com
127.0.0.1 picsforbucks.com
127.0.0.1 picsofseductiveladies.com
127.0.0.1 pills-birth-control.com
127.0.0.1 pillsmall.com
127.0.0.1 pilotronix.com
127.0.0.1 pixpox.com
127.0.0.1 planemusic.com
127.0.0.1 poiska.net
127.0.0.1 poker-casino-free.com
127.0.0.1 poker-games-free.net
127.0.0.1 polradiologia.com
127.0.0.1 pooi.net
127.0.0.1 porn-teacher.com
127.0.0.1 porncamz.com
127.0.0.1 pornfree.info
127.0.0.1 pornnightdreams.com
127.0.0.1 pornokopec.com
127.0.0.1 porntetris.com
127.0.0.1 porntwist.com
127.0.0.1 powerwebsearch.com
127.0.0.1 prblitz.com
127.0.0.1 pretypics.com
127.0.0.1 pribalt.com
127.0.0.1 privacy-support.biz
127.0.0.1 privateporn.net
127.0.0.1 prostactive.com
127.0.0.1 prostol.com
127.0.0.1 protect-yourself.biz
127.0.0.1 prsainlandempire.org
127.0.0.1 put-your-link-here.com
127.0.0.1 pyrocorp.com
127.0.0.1 quick-search.ws
127.0.0.1 quiksearchgenealogy.com
127.0.0.1 radfrall.org
127.0.0.1 ramgo.com
127.0.0.1 ranafrog.ne
127.0.0.1 rapegate.com
127.0.0.1 redbudbmx.com
127.0.0.1 refinance-help.com
127.0.0.1 removeearthkeepers.org
127.0.0.1 rightfinder.net
127.0.0.1 robbsproshop.com
127.0.0.1 robertferencz.com
127.0.0.1 rotocasters.com
127.0.0.1 royalsearch.net
127.0.0.1 runsearch.com
127.0.0.1 russiansponsor.com
127.0.0.1 russogay.com
127.0.0.1 s2.exocrew.com
127.0.0.1 sacitylife.com
127.0.0.1 samplegals.com
127.0.0.1 satisf*cktion.net
127.0.0.1 sbssurvivor.com
127.0.0.1 scarypix.com
127.0.0.1 sccdnet.com
127.0.0.1 schoolforest.com
127.0.0.1 search-1.net
127.0.0.1 search-2003.com
127.0.0.1 search-about.net
127.0.0.1 search-hawk.com
127.0.0.1 search-log.com
127.0.0.1 search-meta.com
127.0.0.1 search-safe.com
127.0.0.1 search.psn.cn
127.0.0.1 searchadultweb.com
127.0.0.1 searchbutler.com
127.0.0.1 searchbuttler.com
127.0.0.1 searchbutler.org
127.0.0.1 searchcomplete.com
127.0.0.1 searchdesire.com
127.0.0.1 searchdot.net
127.0.0.1 searchexpander.com
127.0.0.1 searchfastnet.com
127.0.0.1 searchforge.com
127.0.0.1 searching-the-net.com
127.0.0.1 searchmeta.md
127.0.0.1 searchmeta.net
127.0.0.1 searchmeta.ru
127.0.0.1 searchmeta.webhost.ru
127.0.0.1 searchnow.ws
127.0.0.1 searchonfly.com
127.0.0.1 searchv.com
127.0.0.1 searchxl.com
127.0.0.1 searchxp.com
127.0.0.1 sebot.com
127.0.0.1 securenp.org
127.0.0.1 security-warning.biz
127.0.0.1 seehardcore.com
127.0.0.1 seekwell.net
127.0.0.1 selfbookmark.com
127.0.0.1 selfbookmark.info
127.0.0.1 selfbookmark.net
127.0.0.1 sex.free4porno.net
127.0.0.1 sex-coach.com
127.0.0.1 sex-festival.com
127.0.0.1 sex-video-galleries.com
127.0.0.1 sexgalleries4all.com
127.0.0.1 sexmoviesnet.com
127.0.0.1 sexpatriot.net
127.0.0.1 sexy18.cc
127.0.0.1 sexycat.adult-host.org
127.0.0.1 sfbayfolkboats.com
127.0.0.1 sgirls.net
127.0.0.1 sharempeg.com
127.0.0.1 shopcards.net
127.0.0.1 shopknights.com
127.0.0.1 sic02.com
127.0.0.1 sintrader.com
127.0.0.1 site1.ru
127.0.0.1 sites-in-web.com
127.0.0.1 sitevictoria.com
127.0.0.1 sixroads.com
127.0.0.1 skakalka.ru
127.0.0.1 slawsearch.com
127.0.0.1 slotch.com
127.0.0.1 smartsumo.com
127.0.0.1 smutarchive.net
127.0.0.1 solongas.com
127.0.0.1 sonomaevents.com
127.0.0.1 spermatrix.com
127.0.0.1 sportbooks-free4you.com
127.0.0.1 spros.com
127.0.0.1 spyass.com
127.0.0.1 spyorgy.net
127.0.0.1 staceyowens.com
127.0.0.1 stacistaxx.com
127.0.0.1 stacystaxx.com
127.0.0.1 start-space.com
127.0.0.1 steamycock.com
127.0.0.1 sterva.com
127.0.0.1 stevecashdollar.com
127.0.0.1 stop-tracking.biz
127.0.0.1 stopvotefraud.com
127.0.0.1 stopxxxpics.com
127.0.0.1 strekoza.com
127.0.0.1 stuffstore.com
127.0.0.1 styleclickink.com
127.0.0.1 summercollins.com
127.0.0.1 summitcross.com
127.0.0.1 super-spider.com
127.0.0.1 super-websearch.com
127.0.0.1 supersexmachine.com
127.0.0.1 superwebsearch.com
127.0.0.1 supret.com
127.0.0.1 suzannebrecht.com
127.0.0.1 sweeteenz.com
127.0.0.1 tacil.org
127.0.0.1 tangounion.com
127.0.0.1 tastethemusic.com
127.0.0.1 tax-refund4you.com
127.0.0.1 tech-jobs.ws
127.0.0.1 technology-related.com
127.0.0.1 teen-biz.com
127.0.0.1 teen-pic-post.com
127.0.0.1 teenpornosex.com
127.0.0.1 teens4free.net
127.0.0.1 teensact.com
127.0.0.1 teensgate.com
127.0.0.1 teensguru.com
127.0.0.1 teenswamp.com
127.0.0.1 testosterone-birth-control.com
127.0.0.1 the-exit.com
127.0.0.1 the-huns-yellow-pages.com
127.0.0.1 thefakejournal.com
127.0.0.1 thehuy.net
127.0.0.1 theproxy.org
127.0.0.1 therealsearch.com
127.0.0.1 thesten.com
127.0.0.1 thornleygroup.com
127.0.0.1 tings.org
127.0.0.1 tinybar.com
127.0.0.1 tit-x.com
127.0.0.1 titanvision.com
127.0.0.1 titsianna.com
127.0.0.1 toddhayes.com
127.0.0.1 toon-comics.com
127.0.0.1 tooncomics.com
127.0.0.1 topsearcher.com
127.0.0.1 trafficback.com
127.0.0.1 trafficswitcher.com
127.0.0.1 travel.picture-posters.com
127.0.0.1 true-counter.com
127.0.0.1 true-portal.com
127.0.0.1 trytechnical.com
127.0.0.1 ufindall.click-now.net
127.0.0.1 umaxsearch.com
127.0.0.1 une-autre-france.com
127.0.0.1 unigays.com
127.0.0.1 unipages.cc
127.0.0.1 up2you.ru
127.0.0.1 urlstat.com
127.0.0.1 urlstat.ru
127.0.0.1 uralitel.ru
127.0.0.1 ursie.net
127.0.0.1 utahsweet.com
127.0.0.1 utopicportal.com
127.0.0.1 uusocialjustice.org
127.0.0.1 v61.com
127.0.0.1 vaginpics.com
127.0.0.1 valmyers.com
127.0.0.1 vegas-free.com
127.0.0.1 vegbuy.com
127.0.0.1 veloventures.com
127.0.0.1 verzila.com
127.0.0.1 victoriaadam.com
127.0.0.1 videocategories.com
127.0.0.1 vitamins-for-each.com
127.0.0.1 votehowe.org
127.0.0.1 vxebony.com
127.0.0.1 wakeupdick.com
127.0.0.1 warnomore.org
127.0.0.1 watersport-specialties.com
127.0.0.1 web-homepage.net
127.0.0.1 web-search.tk
127.0.0.1 webcoolsearch.com
127.0.0.1 websearchdot.com
127.0.0.1 weekend-movies.com
127.0.0.1 wetpornostars.com
127.0.0.1 whatsyoursearch.com
127.0.0.1 white-pages.ws
127.0.0.1 whittierblvd.com
127.0.0.1 win-in-casino.com
127.0.0.1 wiresearch.com
127.0.0.1 wolfpacracing.com
127.0.0.1 wordlist.jps.ru
127.0.0.1 wpc2001.org
127.0.0.1 wspzone.sexpornonline.com
127.0.0.1 wwwbet.net
127.0.0.1 wwwbetting.net
127.0.0.1 wwwpokergames.com
127.0.0.1 wwwpokerplayers.com
127.0.0.1 wwwroulette.net
127.0.0.1 x-library.com
127.0.0.1 x-webdesign.com
127.0.0.1 xcomics4u.com
127.0.0.1 xic-bs.com
127.0.0.1 xldr.com
127.0.0.1 xp18.com
127.0.0.1 xrenosearch.com
127.0.0.1 xtragay.com
127.0.0.1 xu.xu.pl
127.0.0.1 xxxcategories.com
127.0.0.1 xxxemailxxx.com
127.0.0.1 y-e-l-l-o-w.com
127.0.0.1 yellow500.com
127.0.0.1 yezol.com
127.0.0.1 you-search.com
127.0.0.1 you-search.com.ru
127.0.0.1 youfindall.com
127.0.0.1 youfindall.net
127.0.0.1 your-prescriptions.net
127.0.0.1 yourbookmarks.info
127.0.0.1 yourbookmarks.ws
127.0.0.1 ypir.com
127.0.0.1 ysa-info.net
127.0.0.1 yukohamano.com
127.0.0.1 ywebsearch.info
127.0.0.1 zapros.com
127.0.0.1 zesearch.com
127.0.0.1 ziportal.com
127.0.0.1 zipportal.com
127.0.0.1 zoneoffreeporn.com
127.0.0.1 zoomegasite.com
127.0.0.1 zvimigdal.com
127.0.0.1 zyban-zocor-levitra.com
127.0.0.1 t.rack.cc
127.0.0.1 omega-search.com
127.0.0.1 cool-xxx.net
127.0.0.1 revolto3.da.ru
127.0.0.1 dating-search.net
127.0.0.1 linksummary.com
127.0.0.1 duolaimi.net
127.0.0.1 ez-searching.com
127.0.0.1 freehqmovies.com
127.0.0.1 xzoomy.com
127.0.0.1 freescratchandwin.com
127.0.0.1 globalwebsearch.com
127.0.0.1 www.gocybersearch.com
127.0.0.1 mayancasino.com
127.0.0.1 www.hastalavista.com
127.0.0.1 www.free-popup-killer.com
127.0.0.1 www.digitalfan.com
127.0.0.1 google123.web1000.com
127.0.0.1 search.ieplugin.com
127.0.0.1 i-lookup.com
127.0.0.1 spidersearch.com
127.0.0.1 istarthere.com
127.0.0.1 xxxtoolbar.com
127.0.0.1 www.seekporn.org
127.0.0.1 17-plus.com
127.0.0.1 lolita4all1.xrensmagpost.com
127.0.0.1 mafiapics.com
127.0.0.1 www.teenmonster.com
127.0.0.1 ie.marketdart.com
127.0.0.1 masterbar.com
127.0.0.1 search.netzany.co
127.0.0.1 only-virgins.com
127.0.0.1 passthison.com
127.0.0.1 blondetgp.com
127.0.0.1 prolivation.com
127.0.0.1 server-au.imrworldwide.com
127.0.0.1 .roar.com
127.0.0.1 rocketsearch.com
127.0.0.1 searchaccurate.com
127.0.0.1 searchalot.com
127.0.0.1 searchandbrowse.com
127.0.0.1 gtawarehouse.com
127.0.0.1 startium.com
127.0.0.1 searchandclick.com
127.0.0.1 searchby.net
127.0.0.1 searchdot.com
127.0.0.1 search-exe.com
127.0.0.1 secret-crush.com
127.0.0.1 seekseek.com
127.0.0.1 sexarena.com
127.0.0.1 sexocean.play-lolita.com
127.0.0.1 startsurfing.com
127.0.0.1 66.197.138.235
127.0.0.1 srng.net
127.0.0.1 apps.webservicehost.com
127.0.0.1 search.shopnav.com
127.0.0.1 wish7.com
127.0.0.1 216.65.3.68
127.0.0.1 www.supersexpass.com
127.0.0.1 surferbar.com
127.0.0.1 xlola.underagehost.com
127.0.0.1 hotlolitas.underagehost.com
127.0.0.1 loading-lolita.com
127.0.0.1 www.xupiter.com
127.0.0.1 xjupiter.com
127.0.0.1 www.xjupiter.com
127.0.0.1 www.browserwise.com
127.0.0.1 sqwire.com
127.0.0.1 orbitexplorer.com
127.0.0.1 searchcentrix.com
127.0.0.1 categories.mygeek.com
127.0.0.1 web-entrance.co
127.0.0.1 whazit.com
127.0.0.1 windowenhancer.com
127.0.0.1 buz.ru
127.0.0.1 iwon.com
127.0.0.1 www.bonzi.com
127.0.0.1 featured-results.com
127.0.0.1 searchmadesafe.net
127.0.0.1 quicklaunch.com
127.0.0.1 www.cashsurfers.com
127.0.0.1 .lop.com
127.0.0.1 .tjdo.com
127.0.0.1 /tjdo.com
127.0.0.1 .ebav.com
127.0.0.1 /ebav.com
127.0.0.1 .ebgo.com
127.0.0.1 /ebgo.com
127.0.0.1 .ebaw.com
127.0.0.1 /ebaw.com
127.0.0.1 .ebkb.com
127.0.0.1 /ebkb.com
127.0.0.1 .ebmu.com
127.0.0.1 /ebmu.com
127.0.0.1 .ecmp.com
127.0.0.1 /ecmp.com
127.0.0.1 .edhq.com
127.0.0.1 /edhq.com
127.0.0.1 .edty.com
127.0.0.1 /edty.com
127.0.0.1 .sbee.com
127.0.0.1 /sbee.com
127.0.0.1 .aavc.com
127.0.0.1 /aavc.com
127.0.0.1 .acjp.com
127.0.0.1 /acjp.com
127.0.0.1 .ecmh.com
127.0.0.1 /ecmh.com
127.0.0.1 .emch.com
127.0.0.1 /emch.com
127.0.0.1 .ecpm.com
127.0.0.1 /ecpm.com
127.0.0.1 .wabu.com
127.0.0.1 /wabu.com
127.0.0.1 .wabq.com
127.0.0.1 .wabq.com
127.0.0.1 /wabq.com
127.0.0.1 .ebch.com
127.0.0.1 /ebch.com
127.0.0.1 .ebdv.com
127.0.0.1 /ebdv.com
127.0.0.1 .ebdw.com
127.0.0.1 /ebdw.com
127.0.0.1 .ebjp.com
127.0.0.1 /ebjp.com
127.0.0.1 .ebkn.com
127.0.0.1 /ebkn.com
127.0.0.1 .ebky.com
127.0.0.1 /ebky.com
127.0.0.1 .eblv.com
127.0.0.1 /eblv.com
127.0.0.1 .wbkb.com
127.0.0.1 /wbkb.com
127.0.0.1 .ebvr.com
127.0.0.1 /ebvr.com
127.0.0.1 .ecwz.com
127.0.0.1 /ecwz.com
127.0.0.1 .ecyb.com
127.0.0.1 /ecyb.com
127.0.0.1 .eduy.com
127.0.0.1 /eduy.com
127.0.0.1 .eeev.com
127.0.0.1 /eeev.com
127.0.0.1 .farse.com
127.0.0.1 /farse.com
127.0.0.1 .ibmx.com
127.0.0.1 /ibmx.com
127.0.0.1 .icwb.com
127.0.0.1 /icwb.com
127.0.0.1 .icwo.com
127.0.0.1 /icwo.com
127.0.0.1 .icwp.com
127.0.0.1 /icwp.com
127.0.0.1 .iddh.com
127.0.0.1 /iddh.com
127.0.0.1 .idhh.com
127.0.0.1 /idhh.com
127.0.0.1 .ifiz.com
127.0.0.1 /ifiz.com
127.0.0.1 .iguu.com
127.0.0.1 /iguu.com
127.0.0.1 .samz.com
127.0.0.1 /samz.com
127.0.0.1 .saoe.com
127.0.0.1 /saoe.com
127.0.0.1 .sbjr.com
127.0.0.1 /sbjr.com
127.0.0.1 .sbnl.com
127.0.0.1 /sbnl.com
127.0.0.1 .sbnt.com
127.0.0.1 /sbnt.com
127.0.0.1 .sbvr.com
127.0.0.1 /sbvr.com
127.0.0.1 .scbm.com
127.0.0.1 /scbm.com
127.0.0.1 .sckr.com
127.0.0.1 /sckr.com
127.0.0.1 .scrk.com
127.0.0.1 /scrk.com
127.0.0.1 .sdry.com
127.0.0.1 /sdry.com
127.0.0.1 .seld.com
127.0.0.1 /seld.com
127.0.0.1 .sfux.com
127.0.0.1 /sfux.com
127.0.0.1 .sheat.com
127.0.0.1 /sheat.com
127.0.0.1 .sipo.com
127.0.0.1 /sipo.com
127.0.0.1 .smds.com
127.0.0.1 /smds.com
127.0.0.1 .srib.com
127.0.0.1 /srib.com
127.0.0.1 .srox.com
127.0.0.1 /srox.com
127.0.0.1 .srsf.com
127.0.0.1 /srsf.com
127.0.0.1 .ssaw.com
127.0.0.1 /ssaw.com
127.0.0.1 .ssby.com
127.0.0.1 /ssby.com
127.0.0.1 .surj.com
127.0.0.1 /surj.com
127.0.0.1 .tbvg.com
127.0.0.1 /tbvg.com
127.0.0.1 .tdak.com
127.0.0.1 /tdak.com
127.0.0.1 .tdmy.com
127.0.0.1 /tdmy.com
127.0.0.1 .tefs.com
127.0.0.1 /tefs.com
127.0.0.1 .tfil.com
127.0.0.1 /tfil.com
127.0.0.1 .tjar.com
127.0.0.1 /tjar.com
127.0.0.1 .tjaw.com
127.0.0.1 /tjaw.com
127.0.0.1 .tjgo.com
127.0.0.1 /tjgo.com
127.0.0.1 .tjem.com
127.0.0.1 /tjem.com
127.0.0.1 .torc.com
127.0.0.1 /torc.com
127.0.0.1 .wfix.com
127.0.0.1 /wfix.com
127.0.0.1 .wflu.com
127.0.0.1 /wflu.com
127.0.0.1 .tdko.com
127.0.0.1 /tdko.com
127.0.0.1 .thko.com
127.0.0.1 /thko.com
127.0.0.1 H24413.tfil.com
127.0.0.1 germany.rub.to
127.0.0.1 search.rub.to
127.0.0.1 unitedstates.rub.to
127.0.0.1 www.commonname.com
127.0.0.1 www.ezcybersearch.com
127.0.0.1 www.jethomepage.com
127.0.0.1 www.gohip.com
127.0.0.1 hotbar.com
127.0.0.1 www.huntbar.com
127.0.0.1 search.imiserver.com
127.0.0.1 infospace.com/blsrch.dp.toolbar
127.0.0.1 searchenhancement.com
127.0.0.1 newtonknows.com
127.0.0.1 search-explorer.net
127.0.0.1 searchsquire.com
127.0.0.1 secondpower.com
127.0.0.1 2ndpower.com
127.0.0.1 searchgateway.net
127.0.0.1 worldusa.com
127.0.0.1 www.topsearcher.com
127.0.0.1 smutserver.com
127.0.0.1 searchmeup.com
127.0.0.1 cameup.com
127.0.0.1 kliksearch.com
127.0.0.1 realphx.com
127.0.0.1 blazefind.com
127.0.0.1 66.40.16.198
127.0.0.1 zoofil.com
127.0.0.1 terafinder.com
127.0.0.1 008i.com
127.0.0.1 171203.com
127.0.0.1 39-93.com
127.0.0.1 adult-personal.us
127.0.0.1 cashsearch.biz
127.0.0.1 cl55.biz
127.0.0.1 dailyteenspic.com
127.0.0.1 dialer2004.com
127.0.0.1 digital-pornography.com
127.0.0.1 eager-sex.com
127.0.0.1 ergosites.com
127.0.0.1 freecj.com
127.0.0.1 greg-search.com
127.0.0.1 incest-host.com
127.0.0.1 ironcarteam.com
127.0.0.1 is-best.com
127.0.0.1 killerpornstars.com
127.0.0.1 lollitop.com
127.0.0.1 love-host.com
127.0.0.1 myexexex.com
127.0.0.1 my-finder.com
127.0.0.1 onlineclick.net
127.0.0.1 onlysex.ws
127.0.0.1 regfreeze.com
127.0.0.1 ruworld.com
127.0.0.1 selltraffic.biz
127.0.0.1 sexunique.net
127.0.0.1 sinpussy.com
127.0.0.1 teenhost.net
127.0.0.1 ultraload.net
127.0.0.1 vse-moe.biz
127.0.0.1 xsex.ws
127.0.0.1 .75tz.com
127.0.0.1 /75tz.com
127.0.0.1 .iefeadsl.com
127.0.0.1 /iefeadsl.com
127.0.0.1 /rf104.com
127.0.0.1 .rf104.com
127.0.0.1 www.v61.com
127.0.0.1 .00hq.com
127.0.0.1 /00hq.com
127.0.0.1 ads.centralmedia.ws
127.0.0.1 c.centralmedia.ws
127.0.0.1 .count.cc
127.0.0.1 /count.cc
127.0.0.1 .topx.cc
127.0.0.1 /topx.cc
127.0.0.1 www.sidefind.com
127.0.0.1 thenewsearch.com
127.0.0.1 new-search.net
127.0.0.1 x-google.net
127.0.0.1 adultgambling.org
127.0.0.1 bitchesonline.net
127.0.0.1 girls4rent.net
127.0.0.1 usefullsoft.net
127.0.0.1 livegambling.com
127.0.0.1 adultsgames.net
127.0.0.1 easyantispy.com
127.0.0.1 spybotremover.net
127.0.0.1 winprotect.net
127.0.0.1 funny-girls.com
127.0.0.1 winmsn.com
# This list is Copyright 2000-2004 Patrick M. Kolla / Safer Networking Limited
# End of entries inserted by Spybot - Search & Destroy
Here is my log:
Ad-Aware SE Build 1.06r1
Logfile Created on:Monday, August 08, 2005 1:24:13 AM
Created with Ad-Aware SE Personal, free for private use.
Using definitions file:SE1R59 02.08.2005
References detected during the scan:
Windows(TAC index:3):2 total references
Ad-Aware SE Settings
Set : Search for low-risk threats
Set : Safe mode (always request confirmation)
Set : Scan active processes
Set : Scan registry
Set : Deep-scan registry
Set : Scan my IE Favorites for banned URLs
Set : Scan within archives
Set : Scan my Hosts file
Extended Ad-Aware SE Settings
Set : Unload recognized processes & modules during scan
Set : Obtain command line of scanned processes
Set : Scan registry for all users instead of current user only
Set : Always try to unload modules before deletion
Set : During removal, unload Explorer and IE if necessary
Set : Let Windows remove files in use at next reboot
Set : Delete quarantined objects after restoring
Set : Include basic Ad-Aware settings in log file
Set : Include additional Ad-Aware settings in log file
Set : Include reference summary in log file
Set : Play sound at scan completion if scan locates critical objects
8-8-2005 1:24:13 AM - Scan started. (Full System Scan)
Listing running processes
#:1 [smss.exe]
ModuleName : \SystemRoot\System32\smss.exe
Command Line : n/a
ProcessID : 468
ThreadCreationTime : 8-7-2005 12:34:25 AM
BasePriority : Normal
#:2 [csrss.exe]
ModuleName : \??\C:\WINDOWS\system32\csrss.exe
Command Line : C:\WINDOWS\system32\csrss.exe ObjectDirectory=\Windows SharedSection=1024,3072,512 Windows=On SubSystemType=Windows ServerDll=basesrv,1 ServerDll=winsrv:UserServerDllInitialization,3 ServerDll=winsrv:ConServerDllInitialization,2 ProfileControl=Off MaxRequestTh
ProcessID : 632
ThreadCreationTime : 8-7-2005 12:34:30 AM
#:3 [winlogon.exe]
ModuleName : \??\C:\WINDOWS\system32\winlogon.exe
Command Line : winlogon.exe
ProcessID : 656
ThreadCreationTime : 8-7-2005 12:34:37 AM
BasePriority : High
#:4 [services.exe]
ModuleName : C:\WINDOWS\system32\services.exe
Command Line : C:\WINDOWS\system32\services.exe
ProcessID : 700
ThreadCreationTime : 8-7-2005 12:34:41 AM
FileVersion : 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
ProductVersion : 5.1.2600.2180
ProductName : Microsoft® Windows® Operating System
CompanyName : Microsoft Corporation
FileDescription : Services and Controller app
InternalName : services.exe
LegalCopyright : © Microsoft Corporation. All rights reserved.
OriginalFilename : services.exe
#:5 [lsass.exe]
ModuleName : C:\WINDOWS\system32\lsass.exe
Command Line : C:\WINDOWS\system32\lsass.exe
ProcessID : 712
FileDescription : LSA Shell (Export Version)
InternalName : lsass.exe
OriginalFilename : lsass.exe
#:6 [svchost.exe]
ModuleName : C:\WINDOWS\system32\svchost.exe
Command Line : C:\WINDOWS\system32\svchost -k DcomLaunch
ProcessID : 856
ThreadCreationTime : 8-7-2005 12:34:47 AM
FileDescription : Generic Host Process for Win32 Services
InternalName : svchost.exe
OriginalFilename : svchost.exe
#:7 [svchost.exe]
Command Line : C:\WINDOWS\system32\svchost -k rpcss
ProcessID : 952
ThreadCreationTime : 8-7-2005 12:34:52 AM
#:8 [svchost.exe]
ModuleName : C:\WINDOWS\System32\svchost.exe
Command Line : C:\WINDOWS\System32\svchost.exe -k netsvcs
ProcessID : 996
ThreadCreationTime : 8-7-2005 12:34:55 AM
#:9 [svchost.exe]
Command Line : C:\WINDOWS\System32\svchost.exe -k NetworkService
ProcessID : 1120
ThreadCreationTime : 8-7-2005 12:34:56 AM
#:10 [svchost.exe]
Command Line : C:\WINDOWS\System32\svchost.exe -k LocalService
ProcessID : 1148
ThreadCreationTime : 8-7-2005 12:34:57 AM
#:11 [explorer.exe]
ModuleName : C:\WINDOWS\Explorer.EXE
Command Line : C:\WINDOWS\Explorer.EXE
ProcessID : 1368
ThreadCreationTime : 8-7-2005 12:35:02 AM
FileVersion : 6.00.2900.2180 (xpsp_sp2_rtm.040803-2158)
ProductVersion : 6.00.2900.2180
FileDescription : Windows Explorer
InternalName : explorer
OriginalFilename : EXPLORER.EXE
#:12 [spoolsv.exe]
ModuleName : C:\WINDOWS\system32\spoolsv.exe
Command Line : C:\WINDOWS\system32\spoolsv.exe
ProcessID : 1432
ThreadCreationTime : 8-7-2005 12:35:03 AM
FileDescription : Spooler SubSystem App
InternalName : spoolsv.exe
OriginalFilename : spoolsv.exe
#:13 [ctfmon.exe]
ModuleName : C:\WINDOWS\system32\ctfmon.exe
Command Line : ctfmon.exe
ProcessID : 1436
FileDescription : CTF Loader
InternalName : CTFMON
OriginalFilename : CTFMON.EXE
#:14 [aolacsd.exe]
ModuleName : C:\PROGRA~1\COMMON~1\AOL\ACS\AOLacsd.exe
Command Line : C:\PROGRA~1\COMMON~1\AOL\ACS\AOLacsd.exe
ProcessID : 1648
ThreadCreationTime : 8-7-2005 12:35:12 AM
#:15 [hpsysdrv.exe]
ModuleName : C:\windows\system\hpsysdrv.exe
Command Line : "c:\windows\system\hpsysdrv.exe"
ProcessID : 1684
ThreadCreationTime : 8-7-2005 12:35:14 AM
FileVersion : 1, 7, 0, 0
ProductVersion : 1, 7, 0, 0
ProductName : hpsysdrv
CompanyName : Hewlett-Packard Company
FileDescription : hpsysdrv
InternalName : hpsysdrv
LegalCopyright : Copyright © 1998
OriginalFilename : hpsysdrv.exe
#:16 [hkcmd.exe]
ModuleName : C:\WINDOWS\System32\hkcmd.exe
Command Line : "C:\WINDOWS\System32\hkcmd.exe"
ProcessID : 1700
ThreadCreationTime : 8-7-2005 12:35:15 AM
FileVersion : 3.0.0.3943
ProductVersion : 7.0.0.3943
ProductName : Intel(R) Common User Interface
CompanyName : Intel Corporation
FileDescription : hkcmd Module
InternalName : HKCMD
LegalCopyright : Copyright 1999-2004, Intel Corporation
OriginalFilename : HKCMD.EXE
#:17 [hphmon05.exe]
ModuleName : C:\WINDOWS\System32\hphmon05.exe
Command Line : "C:\WINDOWS\System32\hphmon05.exe"
ProcessID : 1724
ThreadCreationTime : 8-7-2005 12:35:16 AM
FileVersion : 5,0,84
ProductVersion : 5,0,84
ProductName : HP Photosmart
FileDescription : HPHmon05
InternalName : HPHmon05
LegalCopyright : Copyright (C) 2003
OriginalFilename : HPHmon05.exe
#:18 [kbd.exe]
ModuleName : C:\HP\KBD\KBD.EXE
Command Line : "C:\HP\KBD\KBD.EXE"
ProcessID : 1732
BasePriority : High
#:19 [ltmsg.exe]
ModuleName : C:\WINDOWS\LTMSG.exe
Command Line : "C:\WINDOWS\LTMSG.exe" 7
ProcessID : 1768
ThreadCreationTime : 8-7-2005 12:35:17 AM
FileVersion : 3, 0, 0, 4
ProductVersion : 3, 0, 0, 4
ProductName : Agere Systems ltmsg
CompanyName : Agere Systems
FileDescription : ltmsg
InternalName : ltmsg
LegalCopyright : Copyright © 2003
OriginalFilename : ltmsg.exe
Comments : Messaging application for Agere Win Modem
#:20 [mmtask.exe]
ModuleName : C:\Program Files\MUSICMATCH\MUSICMATCH Jukebox\mmtask.exe
Command Line : "C:\Program Files\MUSICMATCH\MUSICMATCH Jukebox\mmtask.exe"
ProcessID : 1788
ThreadCreationTime : 8-7-2005 12:35:18 AM
FileVersion : 1.0.0.1
ProductVersion : 1.0.0.1
ProductName : TODO: <Product name>
CompanyName : TODO: <Company name>
FileDescription : TODO: <File description>
InternalName : mmtask.exe
LegalCopyright : TODO: (c) <Company name>. All rights reserved.
OriginalFilename : mmtask.exe
#:21 [point32.exe]
ModuleName : C:\Program Files\Microsoft IntelliPoint\point32.exe
Command Line : "C:\Program Files\Microsoft IntelliPoint\point32.exe"
ProcessID : 1836
#:22 [ccproxy.exe]
ModuleName : C:\Program Files\Common Files\Symantec Shared\ccProxy.exe
Command Line : n/a
ProcessID : 1852
ThreadCreationTime : 8-7-2005 12:35:19 AM
FileVersion : 103.0.4.3
ProductVersion : 103.0.4.3
ProductName : Client and Host Security Platform
CompanyName : Symantec Corporation
FileDescription : Symantec Network Proxy Service
InternalName : ccProxy
LegalCopyright : Copyright (c) 2000-2004 Symantec Corporation. All rights reserved.
OriginalFilename : ccProxy.exe
#:23 [hpwuschd2.exe]
ModuleName : C:\Program Files\HP\HP Software Update\HPWuSchd2.exe
Command Line : "C:\Program Files\HP\HP Software Update\HPWuSchd2.exe"
ProcessID : 2020
ThreadCreationTime : 8-7-2005 12:35:25 AM
FileVersion : 5, 0, 0, 0
ProductVersion : 5, 0, 0, 0
ProductName : HP Software Update Application
FileDescription : hpwuSchd
InternalName : hpwuSchd
OriginalFilename : hpwuSchd.exe
#:24 [ccsetmgr.exe]
ModuleName : C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
Command Line : n/a
ProcessID : 2040
FileVersion : 103.0.5.2
ProductVersion : 103.0.5.2
FileDescription : Symantec Settings Manager Service
InternalName : ccSetMgr
OriginalFilename : ccSetMgr.exe
#:25 [hpqcmon.exe]
ModuleName : C:\Program Files\HP\Digital Imaging\Unload\hpqcmon.exe
Command Line : "C:\Program Files\HP\Digital Imaging\Unload\hpqcmon.exe"
ProcessID : 120
FileVersion : 2.0.0.133
ProductVersion : 2.0.0.133
ProductName : HpqCmon Application
FileDescription : HpqCmon MFC Application
InternalName : HpqCmon
LegalCopyright : Copyright (C) 2001
OriginalFilename : HpqCmon.EXE
#:26 [ncltray.exe]
ModuleName : C:\Program Files\Common Files\Nokia\NCLTools\NclTray.exe
Command Line : "C:\Program Files\Common Files\Nokia\NCLTools\NclTray.exe"
ProcessID : 180
ThreadCreationTime : 8-7-2005 12:35:27 AM
#:27 [eebsvc.exe]
ModuleName : C:\Program Files\Common Files\EPSON\EBAPI\eEBSVC.exe
Command Line : "C:\Program Files\Common Files\EPSON\EBAPI\eEBSVC.exe"
ProcessID : 184
#:28 [sagent2.exe]
ModuleName : C:\Program Files\Common Files\EPSON\EBAPI\SAgent2.exe
Command Line : "C:\Program Files\Common Files\EPSON\EBAPI\SAgent2.exe"
ProcessID : 224
ThreadCreationTime : 8-7-2005 12:35:28 AM
FileVersion : 2, 2, 0, 0
ProductVersion : 1, 0, 0, 0
ProductName : EPSON Bidirectional Printer
CompanyName : SEIKO EPSON CORPORATION
FileDescription : EPSON Printer Status Agent
InternalName : SAgent2
LegalCopyright : Copyright (C) SEIKO EPSON CORP. 2000-2001
OriginalFilename : SAgent2.exe
#:29 [gearsec.exe]
ModuleName : C:\WINDOWS\System32\gearsec.exe
Command Line : C:\WINDOWS\System32\gearsec.exe
ProcessID : 284
ThreadCreationTime : 8-7-2005 12:35:30 AM
FileVersion : 1, 0, 0, 6
ProductVersion : 1, 0, 0, 6
ProductName : gearsec
CompanyName : GEAR Software
FileDescription : gearsec
InternalName : gearsec
LegalCopyright : Copyright © 2001-2003 GEAR Software
OriginalFilename : gearsec.exe
#:30 [aoldial.exe]
ModuleName : C:\Program Files\Common Files\AOL\ACS\AOLDial.exe
Command Line : "C:\Program Files\Common Files\AOL\ACS\AOLDial.exe"
ProcessID : 424
ThreadCreationTime : 8-7-2005 12:35:33 AM
FileVersion : 2.0.20.1.US.1
ProductVersion : 2.0.20.1.US.1
ProductName : AOL Connectivity Service
CompanyName : America Online, Inc
FileDescription : AOL Connectivity Service Dialer
LegalCopyright : Copyright © 2003 America Online, Inc.
OriginalFilename : AOLDial.exe
#:31 [servicelayer.exe]
ModuleName : C:\Program Files\Common Files\Nokia\Services\ServiceLayer.exe
Command Line : "C:\Program Files\Common Files\Nokia\Services\ServiceLayer.exe" -Embedding
ProcessID : 528
ThreadCreationTime : 8-7-2005 12:35:34 AM
FileVersion : 5.00.021
ProductVersion : 5.0
ProductName : Nokia Connectivity Library
CompanyName : Nokia Corp.
FileDescription : ServiceLayer Module
InternalName : ServiceLayer
LegalCopyright : Copyright © 2002, 2003 Nokia. All Rights Reserved.
OriginalFilename : ServiceLayer.exe
#:32 [mdm.exe]
ModuleName : C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
Command Line : "C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE"
ProcessID : 532
FileVersion : 7.00.9466
ProductVersion : 7.00.9466
ProductName : Microsoft® Visual Studio .NET
FileDescription : Machine Debug Manager
InternalName : mdm.exe
OriginalFilename : mdm.exe
#:33 [ituneshelper.exe]
ModuleName : C:\Program Files\iTunes\iTunesHelper.exe
Command Line : "C:\Program Files\iTunes\iTunesHelper.exe"
ProcessID : 888
ThreadCreationTime : 8-7-2005 12:35:36 AM
FileVersion : 4.2.0.72
ProductVersion : 4.2.0.72
ProductName : iTunes
CompanyName : Apple Computer, Inc.
FileDescription : iTunesHelper Module
InternalName : iTunesHelper
LegalCopyright : © Apple Computer, Inc. 2003
OriginalFilename : iTunesHelper.exe
#:34 [ccapp.exe]
ModuleName : C:\Program Files\Common Files\Symantec Shared\ccApp.exe
Command Line : n/a
ProcessID : 1100
FileDescription : Symantec User Session
InternalName : ccApp
OriginalFilename : ccApp.exe
#:35 [sqlservr.exe]
ModuleName : C:\Program Files\Microsoft SQL Server\MSSQL$MICROSOFTBCM\Binn\sqlservr.exe
Command Line : "C:\Program Files\Microsoft SQL Server\MSSQL$MICROSOFTBCM\Binn\sqlservr.exe" -sMICROSOFTBCM
ProcessID : 1108
FileVersion : 2000.080.0818.00
ProductVersion : 8.00.818
ProductName : Microsoft SQL Server
FileDescription : SQL Server Windows NT
InternalName : SQLSERVR
LegalCopyright : © 1988-2003 Microsoft Corp. All rights reserved.
LegalTrademarks : Microsoft® is a registered trademark of Microsoft Corporation. Windows(TM) is a trademark of Microsoft Corporation
OriginalFilename : SQLSERVR.EXE
Comments : NT INTEL X86
#:36 [navapsvc.exe]
ModuleName : C:\Program Files\Norton SystemWorks\Norton AntiVirus\navapsvc.exe
Command Line : n/a
ProcessID : 1284
ThreadCreationTime : 8-7-2005 12:35:45 AM
FileVersion : 11.0.9.16
ProductVersion : 11.0.9
ProductName : Norton AntiVirus
FileDescription : Norton AntiVirus Auto-Protect Service
InternalName : NAVAPSVC
LegalCopyright : Norton AntiVirus 2005 for Windows 98/ME/2000/XP Copyright © 2004 Symantec Corporation. All rights reserved.
OriginalFilename : NAVAPSVC.EXE
#:37 [teatimer.exe]
ModuleName : C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
Command Line : "C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe"
ProcessID : 1340
ThreadCreationTime : 8-7-2005 12:35:46 AM
BasePriority : Idle
FileVersion : 1, 4, 0, 2
ProductVersion : 1, 4, 0, 3
ProductName : Spybot - Search & Destroy
CompanyName : Safer Networking Limited
FileDescription : System settings protector
InternalName : TeaTimer
LegalCopyright : © 2000-2005 Patrick M. Kolla / Safer Networking Limited. Alle Rechte vorbehalten.
LegalTrademarks : "Spybot" und "Spybot - Search & Destroy" sind registrierte Warenzeichen.
OriginalFilename : TeaTimer.exe
Comments : Schützt Systemeinstellungen vor ungewollten Änderungen.
#:38 [npfmntor.exe]
ModuleName : C:\Program Files\Norton SystemWorks\Norton AntiVirus\IWP\NPFMntor.exe
Command Line : n/a
ProcessID : 1564
ThreadCreationTime : 8-7-2005 12:35:55 AM
FileDescription : Norton AntiVirus Firewall Install Monitor
InternalName : NPFMonitor
OriginalFilename : NPFMonitor.EXE
#:39 [accagnt.exe]
ModuleName : C:\Program Files\AOL Computer Check-Up\ACCAgnt.exe
Command Line : "C:\Program Files\AOL Computer Check-Up\ACCAgnt.exe" /startup
ProcessID : 1668
ThreadCreationTime : 8-7-2005 12:35:59 AM
BasePriority : Below Normal
FileVersion : 1, 1, 0, 98
ProductVersion : 1, 1, 0, 98
ProductName : AOL Computer Check-Up
CompanyName : America Online Inc.
FileDescription : AOL Computer Check-Up
InternalName : AUAgent
LegalCopyright : Copyright (C) 2000 - 2004 America Online Inc.
OriginalFilename : AUAgent.exe
#:40 [backweb-1940576.exe]
ModuleName : C:\Program Files\Compaq Connections\1940576\Program\BackWeb-1940576.exe
Command Line : "C:\Program Files\Compaq Connections\1940576\Program\BackWeb-1940576.exe" -startup
ProcessID : 2176
ThreadCreationTime : 8-7-2005 12:36:29 AM
#:41 [spamsub.exe]
ModuleName : C:\Program Files\interMute\SpamSubtract\SpamSub.exe
Command Line : "C:\Program Files\interMute\SpamSubtract\SpamSub.exe" -q
ProcessID : 2232
ThreadCreationTime : 8-7-2005 12:36:47 AM
FileVersion : 1,0,0,76
ProductVersion : 1,0,0,76
ProductName : SpamSubtract from interMute
CompanyName : interMute, Inc.
FileDescription : SpamSubtract
InternalName : SpamSubtract
LegalCopyright : Copyright (C) 2002
OriginalFilename : SpamSubtract.EXE
#:42 [sndsrvc.exe]
ModuleName : C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
Command Line : n/a
ProcessID : 2372
ThreadCreationTime : 8-7-2005 12:36:59 AM
FileVersion : 5.5.1.6
ProductVersion : 5.5
ProductName : Symantec Security Drivers
FileDescription : Network Driver Service
InternalName : SndSrvc
LegalCopyright : Copyright 2002, 2003, 2004 Symantec Corporation
OriginalFilename : SndSrvc.exe
#:43 [spbbcsvc.exe]
ModuleName : C:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCSvc.exe
Command Line : n/a
ProcessID : 2436
ThreadCreationTime : 8-7-2005 12:37:10 AM
FileVersion : 1,0,1,47
ProductVersion : 1,0,1,47
ProductName : SPBBC
FileDescription : SPBBC Service
InternalName : SPBBCSvc
LegalCopyright : Copyright (c) 2004 Symantec Corporation. All rights reserved.
OriginalFilename : SPBBCSvc.exe
#:44 [nopdb.exe]
ModuleName : C:\PROGRA~1\NORTON~1\NORTON~2\SPEEDD~1\NOPDB.EXE
Command Line : n/a
ProcessID : 2504
ThreadCreationTime : 8-7-2005 12:37:16 AM
FileVersion : 7.00.0.24
ProductVersion : 7.00.0.24
ProductName : Norton Speed Disk
FileDescription : NOPDB
InternalName : NOPDB
LegalCopyright : Copyright (c) 1997-2004 Symantec Corporation
OriginalFilename : NOPDB.dll
#:45 [svchost.exe]
Command Line : C:\WINDOWS\System32\svchost.exe -k imgsvc
ProcessID : 2556
ThreadCreationTime : 8-7-2005 12:37:27 AM
#:46 [symlcsvc.exe]
ModuleName : C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
Command Line : n/a
ProcessID : 2732
ThreadCreationTime : 8-7-2005 12:37:34 AM
FileVersion : 1, 8, 54, 478
ProductVersion : 1, 8, 54, 478
ProductName : Symantec Core Component
FileDescription : Symantec Core Component
InternalName : symlcsvc
OriginalFilename : symlcsvc.exe
#:47 [hpqtra08.exe]
ModuleName : C:\Program Files\HP\Digital Imaging\bin\hpqtra08\hpqtra08.exe
Command Line : "C:\Program Files\HP\Digital Imaging\bin\hpqtra08\hpqtra08.exe"
ProcessID : 2752
ThreadCreationTime : 8-7-2005 12:37:38 AM
FileVersion : 5.31.0.147
ProductVersion : 005.031.000.147
ProductName : hp digital imaging - hp all-in-one series
CompanyName : Hewlett-Packard Co.
FileDescription : HP Digital Imaging Monitor (CUE)
InternalName : HPQTRA00
LegalCopyright : Copyright (C) Hewlett-Packard Co. 1995-2001
OriginalFilename : HPQTRA00.EXE
Comments : HP Digital Imaging Monitor (CUE)
#:48 [wdfmgr.exe]
ModuleName : C:\WINDOWS\system32\wdfmgr.exe
Command Line : C:\WINDOWS\system32\wdfmgr.exe
ProcessID : 2800
ThreadCreationTime : 8-7-2005 12:37:43 AM
FileVersion : 5.2.3790.1230 built by: DNSRV(bld4act)
ProductVersion : 5.2.3790.1230
FileDescription : Windows User Mode Driver Manager
InternalName : WdfMgr
OriginalFilename : WdfMgr.exe
#:49 [ccevtmgr.exe]
ModuleName : C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
Command Line : n/a
ProcessID : 2912
ThreadCreationTime : 8-7-2005 12:38:09 AM
FileDescription : Symantec Event Manager Service
InternalName : ccEvtMgr
OriginalFilename : ccEvtMgr.exe
#:50 [ipodservice.exe]
ModuleName : C:\Program Files\iPod\bin\iPodService.exe
Command Line : "C:\Program Files\iPod\bin\iPodService.exe"
ProcessID : 3872
ThreadCreationTime : 8-7-2005 12:40:58 AM
FileDescription : iPodService Module
InternalName : iPodService
OriginalFilename : iPodService.exe
#:51 [wmiprvse.exe]
ModuleName : C:\WINDOWS\System32\wbem\wmiprvse.exe
Command Line : C:\WINDOWS\System32\wbem\wmiprvse.exe -Embedding
ProcessID : 2076
ThreadCreationTime : 8-7-2005 12:41:22 AM
FileDescription : WMI
InternalName : Wmiprvse.exe
OriginalFilename : Wmiprvse.exe
#:52 [alg.exe]
ModuleName : C:\WINDOWS\System32\alg.exe
Command Line : C:\WINDOWS\System32\alg.exe
ProcessID : 2592
ThreadCreationTime : 8-7-2005 12:41:28 AM
FileDescription : Application Layer Gateway Service
InternalName : ALG.exe
OriginalFilename : ALG.exe
#:53 [wuauclt.exe]
ModuleName : C:\WINDOWS\system32\wuauclt.exe
Command Line : "C:\WINDOWS\system32\wuauclt.exe"
ProcessID : 2496
ThreadCreationTime : 8-7-2005 12:42:26 AM
FileVersion : 5.8.0.2469 built by: lab01_n(wmbla)
ProductVersion : 5.8.0.2469
FileDescription : Automatic Updates
InternalName : wuauclt.exe
OriginalFilename : wuauclt.exe
#:54 [sgtray.exe]
ModuleName : C:\Program Files\Common Files\Sonic\Update Manager\sgtray\sgtray.exe
Command Line : "C:\Program Files\Common Files\Sonic\Update Manager\sgtray\sgtray.exe" /r
ProcessID : 1424
ThreadCreationTime : 8-7-2005 12:47:10 AM
FileVersion : 1.01.32a
CompanyName : Sonic Solutions
FileDescription : Sonic Update Manager
LegalCopyright : Copyright © 2002 Sonic Solutions
#:55 [winword.exe]
ModuleName : C:\Program Files\Microsoft Office\OFFICE11\WINWORD.EXE
Command Line : "C:\Program Files\Microsoft Office\OFFICE11\WINWORD.EXE"
ProcessID : 1996
ThreadCreationTime : 8-7-2005 2:53:24 AM
#:56 [companion.exe]
ModuleName : C:\Program Files\AOL Companion\companion.exe
Command Line : "C:\Program Files\AOL Companion\companion.exe" /a
ProcessID : 848
ThreadCreationTime : 8-7-2005 9:41:00 PM
FileVersion : 1, 6, 2, 0
ProductVersion : 1, 6, 2, 0
ProductName : AOL Companion
FileDescription : AOL Companion
InternalName : Companion
LegalCopyright : Copyright 2004
OriginalFilename : Companion.EXE
#:57 [realsched.exe]
ModuleName : C:\Program Files\Common Files\Real\Update_OB\realsched.exe
Command Line : "C:\Program Files\Common Files\Real\Update_OB\realsched.exe" -restart
ProcessID : 928
ThreadCreationTime : 8-8-2005 12:35:28 AM
FileVersion : 0.1.0.1622
ProductVersion : 0.1.0.1622
ProductName : RealOne Player (32-bit)
CompanyName : RealNetworks, Inc.
FileDescription : RealNetworks Scheduler
InternalName : schedapp
LegalCopyright : Copyright © RealNetworks, Inc. 1995-2002
LegalTrademarks : RealAudio(tm) is a trademark of RealNetworks, Inc.
OriginalFilename : realsched.exe
#:58 [ad-aware.exe]
ModuleName : C:\Program Files\Lavasoft\Ad-Aware SE Personal\Ad-Aware.exe
Command Line : "C:\Program Files\Lavasoft\Ad-Aware SE Personal\Ad-Aware.exe"
ProcessID : 2832
ThreadCreationTime : 8-8-2005 3:36:49 AM
FileVersion : 6.2.0.236
ProductVersion : SE 106
ProductName : Lavasoft Ad-Aware SE
CompanyName : Lavasoft Sweden
FileDescription : Ad-Aware SE Core application
InternalName : Ad-Aware.exe
LegalCopyright : Copyright © Lavasoft AB Sweden
OriginalFilename : Ad-Aware.exe
Comments : All Rights Reserved
Memory scan result:
New critical objects: 0
Objects found so far: 0
Started registry scan
Windows Object Recognized!
Type : RegData
Data :
TAC Rating : 3
Category : Vulnerability
Comment : Manual changing of browser start-page restricted
Rootkey : HKEY_USERS
Object : S-1-5-21-4235648181-2224328701-2728591992-1003\software\policies\microsoft\internet explorer\control panel
Value : Homepage
Data :
Type : RegData
Data :
TAC Rating : 3
Comment : Manual changing of internet-settings restricted
Object : S-1-5-21-4235648181-2224328701-2728591992-1003\software\policies\microsoft\internet explorer\restrictions
Value : NoBrowserOptions
Data :
Registry Scan result:
New critical objects: 2
Objects found so far: 2
Started deep registry scan
Deep registry scan result:
Started Tracking Cookie scan
Tracking cookie scan result:
Deep scanning and examining files (C:)
Disk Scan Result for C:\
Deep scanning and examining files (D:)
Disk Scan Result for D:\
Deep scanning and examining files (G:)
Disk Scan Result for G:\
Scanning Hosts file......
Hosts file location:"C:\WINDOWS\system32\drivers\etc\hosts".
Hosts file scan result:
1159 entries scanned.
New critical objects:0
Performing conditional scans...
Conditional scan result:
1:50:51 AM Scan Complete
Summary Of This Scan
Total scanning time:00:26:37.719
Objects scanned:292609
Objects identified:2
Objects ignored:0
New critical objects:2
I have had a look through your HOSTS list and can see nothing obvious.
You have Tea Timer running in your SB S&D - Turn that OFF ... and try doing your updates again.
(Don't forget to turn it back on - if you like to use it ... when we have you "fixed up")
You also didn't say whether you un-installed all the old versions of the proggies before you installed the new versions???
Anyway, try the updates without Tea Timer on.
And then, whether that works or not, follow the advice Corrine gave you in her earlier post (3rd post in this thread) and post an HJT Log in the HJT Forum as she detailed above.
Fear not, we will get this sorted for you :)
PS When you post your HJT Log - place a reference link back to this thread, so the HJT Experts know where we are at ... But don't worry too much if you don't know how to do links - I'm sure one of us will help if the link is not there.
Quote from: Totro on August 08, 2005, 12:36:42 PM
Ill try updating without teatimer when I get home How do you disable TeaTimer, I cant seem to figure out how to do it?
I did uninstall the old version before installing the new version
I use Spybot S & D but do not use TeaTimer - but I think you will find - on your GUI (program interface) bottom left of the GUI "Tools"
Go Tools>Resident>Resident TeaTimer - You should then have the option to tick or un-tick Resident TeaTimer.
I think you have to re-start your computer for the change to take effect.
From How to Disable Real Time Monitoring Programs (http://www.landzdown.com/index.php/topic,422.0.html)
Spybot S&D (Teatimer)
1. Run Spybot-S&D in Advanced Mode.
2. If it is not already set to do this Go to the Mode menu select "Advanced Mode"
3. On the left hand side, Click on Tools
4. Then click on the Resident Icon in the List
5. Uncheck "Resident TeaTimer" and OK any prompts.
6. Restart your computer.
I split your HJT log to here: http://www.landzdown.com/index.php/topic,1091.0.html
This way the HJT experts can more easily locate it. :)
