Adobe Flash Player and AIR Security Updates
Started by Corrine, June 09, 2015, 03:52:35 PM
Yes, it is Update Tuesday and with it comes updates to Adobe Flash Player and AIR.  Users of the Adobe Flash Player desktop runtime for Windows and Macintosh should update to Adobe Flash Player 18.0.0.160.  The current version of Adobe AIR is 18.0.0.144.  (The latest versions for Linux, Android and Flash Player ESR are included in my blog post.)
An interesting update to the latest version of Flash Player is the Improved Flash Player Install Process, documented in the Release Notes, Flash Player® 18 AIR® 18:
Quote"With Flash Player 18, in the vast majority of cases, the installer will no longer display a dialog to shut down the currently running browsers or applications that are using Flash Player!
    Once the installation is completed, you will be notified that the browser may need to be restarted to use the newly installed version. This requirement depends on your browser's ability to see the new version.  Either way, Flash will continue to work and you can easily force the new version to appear by simply restarting your browser when it's convenient for you."
Direct download links for Windows 7 and below:
    Non-IE Plugin (Opera, Firefox, Etc.):  http://download.macromedia.com/get/flashplayer/current/licensing/win/install_flash_player_18_plugin.exe
    Flash Player For Internet Explorer, Windows 7 and earlier:  http://download.macromedia.com/get/flashplayer/current/licensing/win/install_flash_player_18_active_x.exe
