June 2025 Windows 10 Non-Security Preview Update
Started by Corrine, June 24, 2025, 06:43:12 PM
Microsoft released KB5061087 for Windows 10 version 22H2 optional non-security release preview (Windows monthly updates explained).
Key Issues Addressed
[Mobile Operator Profiles]
  • Updated: Country and Operator Settings Asset (COSA) profiles.
[App Platforms and Frameworks]
  • Fixed: An issue affecting Component Object Model (COM) functionality on Windows platforms. Remote COM activations were failing with error 0x8001011.
  • Updated: The version of the curl tool included in Windows is updated to v8.13.0.
[Authentication Platform]
[Input and Composition]
  • Fixed: An issue affecting the complete removal of unused language packs and Feature on Demand (FOD) packages. This issue led to unnecessary storage use and increased Windows update installation time.
[Print and Peripherals]
  • Fixed: An issue affecting USB-connected Multi-Function printers with dual protocol interfaces. Scanning failed and prevented using the built-in scanning functionality in the operating system.
[Start Menu]
  • Fixed: An issue causing jump lists to disappear from the Start Menu.
  • Fixed: An issue where the Start Menu was not starting after installing an update.
[WinSaS]
  • Fixed: Settings > System > About incorrectly shows version 2009 instead of version 22H2.
  • Change of behavior: To maintain DMA compliance in the European Economic Area (EEA), when a new default browser is set, it is automatically pinned to the Taskbar and Start menu.
  • Change of behavior: Associates HTTP and .pdf file types when setting default browser.
[Servicing]
  • Fixed: An issue where Kiosk devices using the ForceAutoLogon configuration and Shift Override might stop responding with a blue screen after being locked and unlocked by support administrators.
[File Server]
  • Fixed: An issue where the system may stop responding when acknowledging an Oplock break request on resources located on SMB shares.
If you installed earlier updates, only the new updates contained in this package will be downloaded and installed on your device.
Update:  To get the update, go to Settings > Update & Security > Windows Update. The link to download and install the update can be found in the Optional updates available area.
Windows 10 update history
