Sigdb appearing on desk top
Started by pete, January 26, 2008, 10:51:49 AM
pete
Hi ripley
Thanks for your valuable comments concerning Defence+ and firewalls. :thumbsup:
Will look at putting a folder called security on desktop. :thumbsup:
Well i think i will upload my avator to here.
Cheers pete :Hammys pint:
Even I'm Amazed At My Stupidity!!!
pete
Hi
This is of topic
How do i go about uploading a picture from my computer, as to use for avatar.
Not from the web.
This really shows me as being quite illiterate as far as computers are concerned. :oops: :tech:
pete,
The best way is for you to up load it to a hosting site (Try Searching Google)there are a few good ones around but I recommend Photobucket
Once you have uploaded your images you can then go in to your profiles and add the image you want.
Here's how I do it:
In your LzD User CP (at the top)
Forum Profile Info> Select "I Have My Own Pic"
For LzD avatar use a URL from hosting site or if using PB: "direct link" option
(For LzD signature a URL with "img" tags or if using PB: the "img code" option)
Click "Change Profile" at the bottom.
pete
Thanks a million GR@PH;<'S, have a couple from me :Hammys pint: :Hammys pint:
Also thanks a million ripley, also the private message that you have sent, explaining how to upload and place avatar , on the forums. They are outstanding. :thanks: :Yahoo:
Cheers Pete
Looking pretty snazzy, there, Pete!
pete,
Good to see you have it sorted
GR@PH;<'S   :Hammys pint:
