Ad-Aware and safe mode
Started by so82, October 11, 2005, 08:13:34 PM
so82
Good evening,
I have a general question about scanning with ad-aware se, I wanted to know what do you think about scanning in safe mode?
Can it remove spywares that scanning in normal mode doesnt remove?
Do you know of any specific spywares that the ad-aware is able to remove only when scanning in safe mode?
thanks
sigal
Hi, so82.  It generally isn't necessary to scan with Ad-Aware SE in safe mode.  However, if you are having trouble removing a detected object, scanning in safe mode may indeed help as the object will not be loaded in safe mode, thus more easily allowing Ad-Aware to remove it.  I am not aware of specific objects that Ad-Aware can more easily remove in safe mode.  However, for serious infections, a full system scann, followed by a scan in safe mode are frequently recommended.  Depending upon the circumstances, another method recommended is a command line scan with +procnuke.
Should you have problems removing an object with Ad-Aware, please don't hesitate to post a logfile.
Please let us know if you need further assistance.
so82
thank you for the quick response.
I just wanted to know you opinion on this matter
You're welcome, so82.  Its good to know that you're not currently having problems.  As to an opinion -- I always seem to have one.  :lol:
