A Check Up Please
Started by hayc59, January 09, 2006, 02:14:20 AM
Want to know about two items
if needed and can be killed off?
they are highlighted in blue
thank you
G.
Logfile of HijackThis v1.99.1
Scan saved at 6:15:01 PM, on 1/8/2006
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\Program Files\Eset\nod32krn.exe
C:\Program Files\Webroot\Spy Sweeper\WRSSSDK.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Eset\nod32kui.exe
C:\Program Files\Agnitum\Outpost Firewall\outpost.exe
C:\Documents and Settings\Gordon&Nancy\Desktop\Junk\HiJack\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://my.msn.com/
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page =
O4 - HKLM\..\Run: [nod32kui] "C:\Program Files\Eset\nod32kui.exe" /WAITSERVICE
O4 - HKLM\..\Run: [Outpost Firewall] C:\Program Files\Agnitum\Outpost Firewall\outpost.exe /waitservice
O4 - HKLM\..\Run: [ISUSPM Startup] C:\PROGRA~1\COMMON~1\INSTAL~1\UPDATE~1\ISUSPM.exe -startup
O23 - Service: NOD32 Kernel Service (NOD32krn) - Eset  - C:\Program Files\Eset\nod32krn.exe
O23 - Service: Outpost Firewall Service (OutpostFirewall) - Agnitum Ltd. - C:\Program Files\Agnitum\Outpost Firewall\outpost.exe
O23 - Service: Webroot Spy Sweeper Engine (svcWRSSSDK) - Webroot Software, Inc. - C:\Program Files\Webroot\Spy Sweeper\WRSSSDK.exe
Did you edit the log?
isuspm.exe is a process that belongs InstallShield from Macrovision. The process automatically checks for the latest updates online. By removing this process you will not get informed about the latest updates for InstallShield.
Services are programs that are loaded automatically by Windows on startup. These services are loaded regardless of whether or not a user logs on to the the computer and tend to be used to handle system wide tasks such as Windows operating system features, antivirus software, or application servers.
Quote from: Corrine on January 09, 2006, 02:56:30 AM
Nope that's it
can i remove those two that you looked at?
... and to think I thought my HJT log was lean and mean ...  :)
The InstallShield Update Service Scheduler is certainly not required to run when you boot up.  It's easy enough to start manually should you wish to.  Fixing it with "HJT" won't eliminate it from your computer, only prevent it from loading when you boot up.
The O23 item is legitimate:  http://castlecops.com/o23list-495.html
The IDriverT.exe process belongs to the InstallShield product installation service, and appears when you are installing a new piece of software. It is not necessary, but most references indicate it should only be terminated if it is malfunctioning or causing problems.
Personally, I'd fix the O4 but leave the O23.
thank you and done!! :thumbsup:
