Unable to "initialize" or run the RootRepeal application.
Started by bdemuth, May 04, 2010, 06:00:36 PM
bdemuth
Brand new to LandzDown and trying to start the process of evaluation, but cannot get the RootRepeal program to load after download. Hangs on "Initializing ... please wait."
sjb007
Hi there bdemuth
Welcome to the LandzDown forums.
As you are having problems with RootRepeal lets try an alternative rootkit scanner:
Download GMER Rootkit Scanner from here or here.
  • Extract the contents of the zipped file to desktop.
  • Double click GMER.exe. If asked to allow gmer.sys driver to load, please consent .
  • If it gives you a warning about rootkit activity and asks if you want to run scan...click on NO.
    Click the image to enlarge it
  • In the right panel, you will see several boxes that have been checked. Uncheck the following ...
    • IAT/EAT
    • Drives/Partition other than Systemdrive (typically C:\)
    • Show All (don't miss this one)
  • Then click the Scan button & wait for it to finish.
  • Once done click on the [Save..] button, and in the File name area, type in "Gmer.txt" or it will save as a .log file
  • Save it where you can easily find it, such as your desktop and copy and paste this in your next reply
**Caution**
Rootkit scans often produce false positives. Do NOT take any action on any "<--- ROOKIT" entries
Also - can I ask do you have the logs from RSIT (log.txt & info.txt - Both logs can be found at C:\RSIT).
Once we have these logs we can then evaluate your system and start the removal processs.
bdemuth
Thanks for getting back.  Unfortunately the GMER application didn't work for me either. The program installed, but during the "scan" (about 12 minutes in), I got a blue screen and a warning saying that windows was shutting down to avoid damage to the system, or some such comment. There was a physical memory dump, and I had to restart my CPU.
Also, attached are the two .txt files requested.
sjb007
Hi there
Regarding GMER - was McAfee disabled during the scan, if not then disable McAfee and retry once again
Please download Flash Disinfector and save it to your desktop.
  • Double-click Flash_Disinfector.exe to run it and follow any prompts that may appear.
  • The utility may ask you to insert your flash drive and/or other removable drives including your mobile phone. Please do so and allow the utility to clean those drives as well.
  • Wait until it has finished scanning and then exit the program.
  • Reboot your computer when done.
Note: Flash_Disinfector will create a hidden folder named autorun.inf in each partition and every USB drive plugged in when you ran the tool. Do not delete this folder. It will help protect your drives from future infection.[/i]
Lets clear out some system junk.....
   1. Download Temp File Cleaner by OldTimer to your desktop, or other location.
   2. Save any unsaved work. TFC will close all open application windows.
   3. Double-click TFC.exe to run the program.
   4. If prompted, click "Yes" to reboot.
Save your work. TFC will automatically close any open programs, let it run uninterrupted. It shouldn't take longer take a couple of minutes, and may only take a few seconds. Only if needed will you be prompted to reboot.
Please download Malwarebytes Anti-Malware (MBAM) and save it to your desktop.
alternate download link 1
alternate download link 2
  • Make sure you are connected to the Internet.
  • Double-click on Download_mbam-setup.exe to install the application. (If using Windows Vista, be sure to "Run As Administrator")[/color]
  • When the installation begins, follow the prompts and do not make any changes to default settings.
  • When installation has finished, make sure you leave both of these checked:
    • Update Malwarebytes' Anti-Malware
    • Launch Malwarebytes' Anti-Malware
  • Then click Finish.
  • MBAM will automatically start and you will be asked to update the program before performing a scan. If an update is found, the program will automatically update itself. Press the OK button to close that box and continue.
  • If you encounter any problems while downloading the updates, manually download them from here and just double-click on mbam-rules.exe to install.
  • On the Scanner tab:
    • Make sure the "Perform Quick Scan" option is selected.
    • Then click on the Scan button.
  • The next screen will ask you to select the drives to scan. Leave all the drives selected and click on the Start Scan button.
  • The scan will begin and "Scan in progress" will show at the top. It may take some time to complete so please be patient.
  • When the scan is finished, a message box will say "The scan completed successfully. Click 'Show Results' to display all objects found".
  • Click OK to close the message box and continue with the removal process.
  • Back at the main Scanner screen, click on the Show Results button to see a list of any malware that was found.
  • Make sure that everything is checked, and click Remove Selected.
  • When removal is completed, a log report will open in Notepad and you may be prompted to restart your computer. (see Note below)
  • The log is automatically saved and can be viewed by clicking the Logs tab in MBAM.
  • Copy and paste the contents of that report in your next reply and exit MBAM.
Note: If MBAM encounters a file that is difficult to remove, you will be presented with 1 of 2 prompts. Click OK to either and let MBAM proceed with the disinfection process. If asked to restart the computer, please do so immediately. Failure to reboot will prevent MBAM from removing all the malware.
Please post back in your next post with the MBAM results and GMER results if successful
Logfile of random's system information tool 1.06 (written by random/random)
Run by HP_Administrator at 2010-05-04 10:06:48
Microsoft Windows XP Professional Service Pack 3
System drive C: has 245 GB (65%) free of 374 GB
Total RAM: 2047 MB (64% free)
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 10:07:05 AM, on 5/4/2010
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v8.00 (8.00.6001.18702)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\LEXBCES.EXE
C:\WINDOWS\system32\LEXPPS.EXE
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\AGRSMMSG.exe
C:\WINDOWS\system32\LXSUPMON.EXE
C:\HP\KBD\KBD.EXE
C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACDaemon.exe
C:\WINDOWS\system32\CTHELPER.EXE
C:\Program Files\ScanSoft\PaperPort\pptd40nt.exe
C:\Program Files\Java\j2re1.4.2_03\bin\jusched.exe
C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PifSvc.exe
C:\Program Files\McAfee.com\Agent\mcagent.exe
C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe
C:\PROGRA~1\Yahoo!\browser\ybrwicon.exe
C:\WINDOWS\system32\wfxsnt40.exe
C:\PROGRA~1\Yahoo!\browser\ycommon.exe
C:\windows\system\hpsysdrv.exe
C:\WINDOWS\system32\hphmon06.exe
C:\Program Files\HP\HP Software Update\HPWuSchd2.exe
C:\Program Files\Creative\SBAudigy2ZS\DVDAudio\CTDVDDet.EXE
C:\Program Files\BroadJump\Client Foundation\CFD.exe
C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
C:\WINDOWS\ALCWZRD.EXE
C:\Program Files\Adobe\Photoshop Elements 5.0\apdproxy.exe
C:\Program Files\Common Files\Real\Update_OB\realsched.exe
C:\Program Files\Common Files\EPSON\eEBAPI\eEBSVC.exe
C:\Program Files\Nuance\PDF Professional 6\pdfpro6hook.exe
C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACService.exe
C:\Program Files\Adobe\Photoshop Elements 5.0\PhotoshopElementsFileAgent.exe
C:\Program Files\QuickTime\QTTask.exe
C:\Program Files\LSI SoftModem\agrsmsvc.exe
C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
C:\Program Files\Symantec\LiveUpdate\AluSchedulerSvc.exe
C:\Program Files\WinFax\WFXCTL32.EXE
C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
C:\WINDOWS\system32\CTsvcCDA.EXE
C:\Program Files\Logitech\SetPoint\SetPoint.exe
C:\Documents and Settings\All Users\Application Data\EPSON\EPW!3 SSRP\E_S40ST7.EXE
C:\Documents and Settings\All Users\Application Data\EPSON\EPW!3 SSRP\E_S40RP7.EXE
C:\Program Files\Updates from HP\309731\Program\Updates from HP.exe
C:\Program Files\Citrix\GoToMyPC\g2svc.exe
C:\Program Files\Windows Desktop Search\WindowsSearch.exe
C:\Program Files\Citrix\GoToMyPC\g2comm.exe
C:\Program Files\Java\jre6\bin\jqs.exe
C:\Program Files\Citrix\GoToMyPC\g2pre.exe
C:\Program Files\McAfee\SiteAdvisor\McSACore.exe
C:\Program Files\Common Files\Logitech\KHAL\KHALMNPR.EXE
C:\PROGRA~1\McAfee\MSC\mcmscsvc.exe
C:\Program Files\Citrix\GoToMyPC\g2tray.exe
c:\PROGRA~1\COMMON~1\mcafee\mna\mcnasvc.exe
C:\Program Files\HP\Digital Imaging\bin\hpqimzone.exe
c:\PROGRA~1\COMMON~1\mcafee\mcproxy\mcproxy.exe
C:\PROGRA~1\McAfee\VIRUSS~1\mcshield.exe
C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
C:\Program Files\McAfee\MPF\MPFSrv.exe
C:\WINDOWS\system32\ofps.exe
C:\Program Files\Nuance\PDF Professional 6\PDFProFiltSrv.exe
C:\Program Files\RDM+\rdmpserv.exe
C:\Program Files\Common Files\Roxio Shared\SharedCOM8\RoxMediaDB.exe
C:\Program Files\RDM+\rdmpserv_cpanel.exe
C:\Program Files\Common Files\Roxio Shared\SharedCOM8\RoxWatch.exe
C:\WINDOWS\system32\tcpsvcs.exe
C:\WINDOWS\system32\WFXSVC.EXE
C:\Program Files\WinFax\WFXMOD32.EXE
C:\WINDOWS\system32\MsPMSPSv.exe
C:\WINDOWS\system32\SearchIndexer.exe
C:\Program Files\HP\Digital Imaging\bin\hpqnrs08.exe
C:\PROGRA~1\McAfee\VIRUSS~1\mcsysmon.exe
C:\Program Files\Google\Chrome\Application\chrome.exe
C:\WINDOWS\system32\SearchProtocolHost.exe
C:\Documents and Settings\HP_Administrator\My Documents\Downloads\RSIT.exe
C:\WINDOWS\system32\HPZinw12.exe
C:\Program Files\trend micro\HP_Administrator.exe
C:\WINDOWS\system32\rundll32.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=EN_US&c=Q105&bd=pavilion&pf=desktop
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iesearch&locale=EN_US&c=Q105&bd=pavilion&pf=desktop
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://www.mirarsearch.com/?useie5=1&q=
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://home.adbsearch.com/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://www.mirarsearch.com/?useie5=1&q=
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://go.microsoft.com/fwlink/?LinkId=33568
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
R3 - URLSearchHook: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn4\yt.dll
R3 - URLSearchHook: McAfee SiteAdvisor Toolbar - {0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O2 - BHO: Yahoo! Toolbar Helper - {02478D38-C3F9-4EFB-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn4\yt.dll
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: RealPlayer Download and Record Plugin for Internet Explorer - {3049C3E9-B461-4BC5-8870-4C09146192CA} - C:\Program Files\Real\RealPlayer\rpbrowserrecordplugin.dll
O2 - BHO: PlusIEEventHelper Class - {551A852F-39A6-44A7-9C13-AFBEC9185A9D} - C:\Program Files\Nuance\PDF Professional 6\Bin\PlusIEContextMenu.dll
O2 - BHO: Yahoo! IE Services Button - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\PROGRA~1\Yahoo!\common\yiesrvc.dll
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\McAfee\VirusScan\scriptsn.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar2.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.4.4525.1752\swg.dll
O2 - BHO: McAfee SiteAdvisor BHO - {B164E929-A1B6-4A06-B104-2CD0E90A88FF} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O2 - BHO: ZeonIEEventHelper Class - {DA986D7D-CCAF-47B2-84FE-BFA1549BEBF9} - C:\Program Files\Nuance\PDF Professional 6\Bin\ZeonIEFavClient.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O2 - BHO: SidebarAutoLaunch Class - {F2AA9440-6328-4933-B7C9-A6CCDF9CBF6D} - C:\Program Files\Yahoo!\browser\YSidebarIEBHO.dll
O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn4\yt.dll
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar2.dll
O3 - Toolbar: McAfee SiteAdvisor Toolbar - {0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O3 - Toolbar: (no name) - {F4571874-4CA5-4154-82BE-0CB76C8D6DAD} - (no file)
O3 - Toolbar: Nuance PDF - {E3286BF1-E654-42FF-B4A6-5E111731DF6B} - C:\Program Files\Nuance\PDF Professional 6\Bin\ZeonIEFavClient.dll
O4 - HKLM\..\Run: [AGRSMMSG] AGRSMMSG.exe
O4 - HKLM\..\Run: [PrinTray] C:\WINDOWS\System32\spool\DRIVERS\W32X86\2\printray.exe
O4 - HKLM\..\Run: [LXSUPMON] C:\WINDOWS\system32\LXSUPMON.EXE RUN
O4 - HKLM\..\Run: [Logitech Hardware Abstraction Layer] KHALMNPR.EXE
O4 - HKLM\..\Run: [ISUSPM Startup] C:\PROGRA~1\COMMON~1\INSTAL~1\UPDATE~1\ISUSPM.exe -startup
O4 - HKLM\..\Run: [KBD] C:\HP\KBD\KBD.EXE
O4 - HKLM\..\Run: [DNS7reminder] "C:\Program Files\Nuance\NaturallySpeaking10\Ereg\Ereg.exe" -r "C:\Documents and Settings\All Users\Application Data\Nuance\NaturallySpeaking10\Ereg.ini
O4 - HKLM\..\Run: [ArcSoft Connection Service] C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACDaemon.exe
O4 - HKLM\..\Run: [CTHelper] CTHELPER.EXE
O4 - HKLM\..\Run: [Nuance OmniPage 17-reminder] "C:\Program Files\Nuance\OmniPage17\Ereg\Ereg.exe" -r "C:\Documents and Settings\All Users\Application Data\ScanSoft\OmniPage 17\Ereg\Ereg.ini"
O4 - HKLM\..\Run: [PaperPort PTD] C:\Program Files\ScanSoft\PaperPort\pptd40nt.exe
O4 - HKLM\..\Run: [IndexSearch] C:\Program Files\ScanSoft\PaperPort\IndexSearch.exe
O4 - HKLM\..\Run: [PPort11reminder] "C:\Program Files\ScanSoft\PaperPort\Ereg\Ereg.exe" -r "C:\Documents and Settings\All Users\Application Data\ScanSoft\PaperPort\11\Config\Ereg\Ereg.ini"
O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Program Files\Java\j2re1.4.2_03\bin\jusched.exe
O4 - HKLM\..\Run: [Symantec PIF AlertEng] "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PifSvc.exe" /a /m "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\AlertEng.dll"
O4 - HKLM\..\Run: [mcagent_exe] "C:\Program Files\McAfee.com\Agent\mcagent.exe" /runkey
O4 - HKLM\..\Run: [McENUI] C:\PROGRA~1\McAfee\MHN\McENUI.exe /hide
O4 - HKLM\..\Run: [Google Desktop Search] "C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe" /startup
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKLM\..\Run: [YOP] C:\PROGRA~1\Yahoo!\YOP\yop.exe /autostart
O4 - HKLM\..\Run: [YBrowser] C:\PROGRA~1\Yahoo!\browser\ybrwicon.exe
O4 - HKLM\..\Run: [WinFaxAppPortStarter] wfxsnt40.exe
O4 - HKLM\..\Run: [VTTimer] VTTimer.exe
O4 - HKLM\..\Run: [UpdReg] C:\WINDOWS\UpdReg.EXE
O4 - HKLM\..\Run: [Symantec NetDriver Monitor] C:\PROGRA~1\SYMNET~1\SNDMon.exe
O4 - HKLM\..\Run: [Recguard] C:\WINDOWS\SMINST\RECGUARD.EXE
O4 - HKLM\..\Run: [PS2] C:\WINDOWS\system32\ps2.exe
O4 - HKLM\..\Run: [IPInSightMonitor 01] "C:\Program Files\SBC Yahoo!\Connection Manager\IP InSight\IPMon32.exe"
O4 - HKLM\..\Run: [IgfxTray] C:\WINDOWS\system32\igfxtray.exe
O4 - HKLM\..\Run: [hpsysdrv] c:\windows\system\hpsysdrv.exe
O4 - HKLM\..\Run: [HPHUPD06] c:\Program Files\HP\{AAC4FC36-8F89-4587-8DD3-EBC57C83374D}\hphupd06.exe
O4 - HKLM\..\Run: [HPHmon06] C:\WINDOWS\system32\hphmon06.exe
O4 - HKLM\..\Run: [HPDJ Taskbar Utility] C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb04.exe
O4 - HKLM\..\Run: [HP Software Update] C:\Program Files\HP\HP Software Update\HPWuSchd2.exe
O4 - HKLM\..\Run: [HotKeysCmds] C:\WINDOWS\system32\hkcmd.exe
O4 - HKLM\..\Run: [EM_EXEC] C:\PROGRA~1\Logitech\MOUSEW~1\SYSTEM\EM_EXEC.EXE
O4 - HKLM\..\Run: [CTDVDDET] C:\Program Files\Creative\SBAudigy2ZS\DVDAudio\CTDVDDet.EXE
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [BJCFD] C:\Program Files\BroadJump\Client Foundation\CFD.exe
O4 - HKLM\..\Run: [AutoTBar] c:\Program Files\HP\Digital Imaging\bin\AUTOTBAR.EXE
O4 - HKLM\..\Run: [ATIPTA] C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
O4 - HKLM\..\Run: [AlcxMonitor] ALCXMNTR.EXE
O4 - HKLM\..\Run: [AlcWzrd] ALCWZRD.EXE
O4 - HKLM\..\Run: [Alcmtr] ALCMTR.EXE
O4 - HKLM\..\Run: [Adobe Photo Downloader] "C:\Program Files\Adobe\Photoshop Elements 5.0\apdproxy.exe"
O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe"  -osboot
O4 - HKLM\..\Run: [PDFHook] C:\Program Files\Nuance\PDF Professional 6\pdfpro6hook.exe
O4 - HKLM\..\Run: [PDF6 Registry Controller] C:\Program Files\Nuance\PDF Professional 6\RegistryController.exe
O4 - HKLM\..\Run: [Nuance PDF Professional 6-reminder] "C:\Program Files\Nuance\PDF Professional 6\Ereg\Ereg.exe" -r "C:\Documents and Settings\All Users\Application Data\Nuance\PDF Professional 6\Ereg\Ereg.ini"
O4 - HKLM\..\Run: [Nuance.ctfmngr] C:\Program Files\Nuance\NaturallySpeaking10\Program\ctfmngr.exe /restore
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\QTTask.exe" -atboottime
O4 - HKCU\..\Run: [swg] "C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe"
O4 - HKCU\..\Run: [EPSON WorkForce 40(Network)] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_FATIELA.EXE /FU "C:\WINDOWS\TEMP\E_SCA2.tmp" /EF "HKCU"
O4 - HKCU\..\Run: [OpAgent] "OpAgent.exe" /agent
O4 - HKCU\..\Run: [WhereSphere] C:\Documents and Settings\HP_Administrator\Application Data\WhereSphere\wheresphere.exe
O4 - HKUS\S-1-5-18\..\RunOnce: [SetDefaultMIDI] MIDIDEF.EXE (User 'SYSTEM')
O4 - HKUS\S-1-5-18\..\RunOnce: [StartMS] "C:\Program Files\Creative\Shared Files\Media Sniffer\StartMS.EXE" /s (User 'SYSTEM')
O4 - HKUS\S-1-5-18\..\RunOnce: [CMSRegOW.exe] "C:\Program Files\InstallShield Installation Information\{56F3E1FF-54FE-4384-A153-6CCABA097814}\CMSRegOW.exe" /r (User 'SYSTEM')
O4 - HKUS\S-1-5-18\..\RunOnce: [RealUpgradeHelper] "C:\Program Files\Common Files\Real\Update_OB\upgrdhlp.exe" "RealNetworks|RealPlayer|12.0" (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\RunOnce: [SetDefaultMIDI] MIDIDEF.EXE (User 'Default user')
O4 - Startup: PowerReg SchedulerV2.exe
O4 - Global Startup: Adobe Gamma Loader.lnk = ?
O4 - Global Startup: Controller.LNK = ?
O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
O4 - Global Startup: HP Photosmart Premier Fast Start.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe
O4 - Global Startup: Logitech Desktop Messenger.lnk = C:\Program Files\Desktop Messenger\8876480\Program\LDMConf.exe
O4 - Global Startup: Logitech SetPoint.lnk = C:\Program Files\Logitech\SetPoint\SetPoint.exe
O4 - Global Startup: Updates from HP.lnk = C:\Program Files\Updates from HP\309731\Program\Updates from HP.exe
O4 - Global Startup: Windows Search.lnk = C:\Program Files\Windows Desktop Search\WindowsSearch.exe
O6 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
O8 - Extra context menu item: Add to Google Photos Screensa&ver - res://c:\WINDOWS\system32\GPhotos.scr/200
O8 - Extra context menu item: Add To HP Organize... - C:\PROGRA~1\HEWLET~1\HPORGA~1\bin/module.main/favorites\ie_add_to.html
O8 - Extra context menu item: Append the content of the link to existing PDF file - res://c:\Program Files\Nuance\PDF Professional 6\Bin\ZeonIEFavClient.dll/ZeonIEAppend.HTML
O8 - Extra context menu item: Append the content of the selected links to existing PDF file - res://c:\Program Files\Nuance\PDF Professional 6\Bin\ZeonIEFavClient.dll/ZeonIEAppendSelLinks.HTML
O8 - Extra context menu item: Append to existing PDF file - res://c:\Program Files\Nuance\PDF Professional 6\Bin\ZeonIEFavClient.dll/ZeonIEAppend.HTML
O8 - Extra context menu item: Create PDF file - res://c:\Program Files\Nuance\PDF Professional 6\Bin\ZeonIEFavClient.dll/ZeonIECapture.HTML
O8 - Extra context menu item: Create PDF file from the content of the link - res://c:\Program Files\Nuance\PDF Professional 6\Bin\ZeonIEFavClient.dll/ZeonIECapture.HTML
O8 - Extra context menu item: Create PDF files from the selected links - res://c:\Program Files\Nuance\PDF Professional 6\Bin\ZeonIEFavClient.dll/ZeonIECaptureSelLinks.HTML
O8 - Extra context menu item: E&xport to Microsoft Excel - res://c:\PROGRA~1\MI1933~1\Office10\EXCEL.EXE/3000
O8 - Extra context menu item: Open with Nuance PDF Converter 6.0 - res://c:\Program Files\Nuance\PDF Professional 6\cnvres_eng.dll /100
O8 - Extra context menu item: Open with PDF Professional 6 - res://c:\Program Files\Nuance\PDF Professional 6\Bin\PlusIEContextMenu.dll/PlusIEContextMenu.htm
O9 - Extra button: AT&T Yahoo! Services - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\PROGRA~1\Yahoo!\common\yiesrvc.dll
O9 - Extra button: (no name) - {B205A35E-1FC4-4CE3-818B-899DBBB3388C} - c:\Program Files\Common Files\Microsoft Shared\Encarta Search Bar\ENCSBAR.DLL
O9 - Extra button: (no name) - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - (no file)
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O16 - DPF: {02BF25D5-8C17-4B23-BC80-D3488ABDDC6B} (QuickTime Object) - https://a248.e.akamai.net/7/248/11498/v1/www.moveonpac.org/content/qt/qtplugin.cab
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (Installation Support) - C:\Program Files\Yahoo!\Common\Yinsthelper20073151.dll
O16 - DPF: {42C9E5EE-DA49-49B4-8ECC-1CAB1C51A2AB} (HomePrintingCtrl Class) - http://www.kodakgallery.com/downloads/hmpr/HMPR_WIN_IE_1/wiaaut.cab
O16 - DPF: {44990301-3C9D-426D-81DF-AAB636FA4345} (Symantec Script Runner Class) - https://www-secure.symantec.com/techsupp/asa/ss/sa/sa_cabs/tgctlsr.cab
O16 - DPF: {46C4B83F-8632-4C31-B86F-4172B1160D0C} (GetEnvironmentVariables.System) - https://cas2.questdiagnostics.com/EREQ_SSLcabs/GetEnvironmentVariables.CAB
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1162086086187
O16 - DPF: {756BEC7B-ADF4-4931-A519-B513B32CFC1B} (BarCodeLabelActiveX.SpecimenLabels) - https://cas2.questdiagnostics.com/EREQ_SSLcabs/LabelControl.CAB
O16 - DPF: {79C259BD-8024-4992-B445-2C52D3449214} (Upgrader.Utility) - https://cas2.questdiagnostics.com/EREQ_SSLcabs/C360Upgrader.CAB
O16 - DPF: {A9F8D9EC-3D0A-4A60-BD82-FBD64BAD370D} (DDRevision Class) - http://h20264.www2.hp.com/ediags/dd/install/HPDriverDiagnosticsxp2k.cab
O16 - DPF: {CE28D5D2-60CF-4C7D-9FE8-0F47A3308078} - http://www.symantec.com/techsupp/asa/SymAData.cab
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - https://fpdownload.macromedia.com/get/shockwave/cabs/flash/swflash.cab
O16 - DPF: {E06E2E99-0AA1-11D4-ABA6-0060082AA75C} -
O16 - DPF: {F812AAD2-8EE4-46C3-8E0F-8A27A7DBFC5F} (EPRINTERX.ctlUser1) - https://www.escription.com/code/ePrinterX.CAB
O18 - Protocol: dssrequest - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O18 - Protocol: sacore - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O20 - AppInit_DLLs: C:\PROGRA~1\Google\GOOGLE~4\GOEC62~1.DLL
O20 - Winlogon Notify: RDM+ - C:\Program Files\RDM+\notify.dll
O23 - Service: McAfee Application Installer Cleanup (0004891270059213) (0004891270059213mcinstcleanup) - Unknown owner - C:\WINDOWS\TEMP\000489~1.EXE (file missing)
O23 - Service: ArcSoft Connect Daemon (ACDaemon) - ArcSoft Inc. - C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACService.exe
O23 - Service: Adobe Active File Monitor V5 (AdobeActiveFileMonitor5.0) - Unknown owner - C:\Program Files\Adobe\Photoshop Elements 5.0\PhotoshopElementsFileAgent.exe
O23 - Service: Agere Modem Call Progress Audio (AgereModemAudio) - LSI Corporation - C:\Program Files\LSI SoftModem\agrsmsvc.exe
O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: Automatic LiveUpdate Scheduler - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\AluSchedulerSvc.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: Symantec Network Proxy (ccProxy) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccProxy.exe
O23 - Service: Creative Service for CDROM Access - Creative Technology Ltd - C:\WINDOWS\system32\CTsvcCDA.EXE
O23 - Service: EpsonBidirectionalService - SEIKO EPSON CORPORATION - C:\Program Files\Common Files\EPSON\eEBAPI\eEBSVC.exe
O23 - Service: EPSON V5 Service4(01) (EPSON_EB_RPCV4_01) - SEIKO EPSON CORPORATION - C:\Documents and Settings\All Users\Application Data\EPSON\EPW!3 SSRP\E_S40ST7.EXE
O23 - Service: EPSON V3 Service4(01) (EPSON_PM_RPCV4_01) - SEIKO EPSON CORPORATION - C:\Documents and Settings\All Users\Application Data\EPSON\EPW!3 SSRP\E_S40RP7.EXE
O23 - Service: Google Desktop Manager 5.9.911.3589 (GoogleDesktopManager-110309-193829) - Google - C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe
O23 - Service: GoToMyPC - Citrix Online, a division of Citrix Systems, Inc. - C:\Program Files\Citrix\GoToMyPC\g2svc.exe
O23 - Service: Google Update Service (gupdate) (gupdate) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: HP Port Resolver - Hewlett-Packard Company - C:\WINDOWS\system32\spool\drivers\w32x86\3\HPBPRO.EXE
O23 - Service: HP Status Server - Hewlett-Packard Company - C:\WINDOWS\system32\spool\drivers\w32x86\3\HPBOID.EXE
O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
O23 - Service: LexBce Server (LexBceS) - Lexmark International, Inc. - C:\WINDOWS\system32\LEXBCES.EXE
O23 - Service: LiveUpdate - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\LuComServer_3_4.EXE
O23 - Service: LiveUpdate Notice Service Ex (LiveUpdate Notice Ex) - Unknown owner - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe (file missing)
O23 - Service: LiveUpdate Notice Service - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PifSvc.exe
O23 - Service: McAfee SiteAdvisor Service - McAfee, Inc. - C:\Program Files\McAfee\SiteAdvisor\McSACore.exe
O23 - Service: McAfee Services (mcmscsvc) - McAfee, Inc. - C:\PROGRA~1\McAfee\MSC\mcmscsvc.exe
O23 - Service: McAfee Network Agent (McNASvc) - McAfee, Inc. - c:\PROGRA~1\COMMON~1\mcafee\mna\mcnasvc.exe
O23 - Service: McAfee Scanner (McODS) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcods.exe
O23 - Service: McAfee Proxy Service (McProxy) - McAfee, Inc. - c:\PROGRA~1\COMMON~1\mcafee\mcproxy\mcproxy.exe
O23 - Service: McAfee Real-time Scanner (McShield) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcshield.exe
O23 - Service: McAfee SystemGuards (McSysmon) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcsysmon.exe
O23 - Service: McAfee Personal Firewall Service (MpfService) - McAfee, Inc. - C:\Program Files\McAfee\MPF\MPFSrv.exe
O23 - Service: OmniForm Printer - Unknown owner - C:\WINDOWS\system32\ofps.exe
O23 - Service: PDFProFiltSrv - Nuance Communications, Inc. - C:\Program Files\Nuance\PDF Professional 6\PDFProFiltSrv.exe
O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\system32\HPZipm12.exe
O23 - Service: RDM+ Local Service (RDMPLocalService) - Unknown owner - C:\Program Files\RDM+\rdmpserv.exe
O23 - Service: LiveShare P2P Server (RoxLiveShare) - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\SharedCOM8\RoxLiveShare.exe
O23 - Service: RoxMediaDB - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\SharedCOM8\RoxMediaDB.exe
O23 - Service: RoxUpnpRenderer (RoxUPnPRenderer) - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\SharedCom\RoxUpnpRenderer.exe
O23 - Service: RoxUpnpServer - Sonic Solutions - C:\Program Files\Roxio\Easy Media Creator 8\Digital Home\RoxUpnpServer.exe
O23 - Service: Roxio Hard Drive Watcher (RoxWatch) - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\SharedCOM8\RoxWatch.exe
O23 - Service: WinFax PRO (wfxsvc) - Symantec Corporation - C:\WINDOWS\system32\WFXSVC.EXE
End of file - 25364 bytes
C:\WINDOWS\tasks\AppleSoftwareUpdate.job
C:\WINDOWS\tasks\Google Software Updater.job
C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore.job
C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
C:\WINDOWS\tasks\McDefragTask.job
C:\WINDOWS\tasks\McQcTask.job
C:\WINDOWS\tasks\NatSpeak Periodic Acoustic Optimization.job
C:\WINDOWS\tasks\NatSpeak Periodic Language Model Optimization.job
======Registry dump======
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{02478D38-C3F9-4EFB-9B51-7695ECA05670}]
Yahoo! Toolbar Helper - C:\Program Files\Yahoo!\Companion\Installs\cpn4\yt.dll [2006-10-26 440384]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{18DF081C-E8AD-4283-A596-FA578C2EBDC3}]
Adobe PDF Link Helper - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll [2010-04-03 75200]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{3049C3E9-B461-4BC5-8870-4C09146192CA}]
RealPlayer Download and Record Plugin for Internet Explorer - C:\Program Files\Real\RealPlayer\rpbrowserrecordplugin.dll [2010-02-05 329312]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{551A852F-39A6-44A7-9C13-AFBEC9185A9D}]
PlusIEEventHelper Class - C:\Program Files\Nuance\PDF Professional 6\Bin\PlusIEContextMenu.dll [2009-02-06 249856]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897}]
Yahoo! IE Services Button - C:\PROGRA~1\Yahoo!\common\yiesrvc.dll [2006-10-31 198136]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{7DB2D5A0-7241-4E79-B68D-6309F01C5231}]
scriptproxy - C:\Program Files\McAfee\VirusScan\scriptsn.dll [2009-11-04 62784]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AA58ED58-01DD-4d91-8333-CF10577473F7}]
Google Toolbar Helper - c:\program files\google\googletoolbar2.dll [2007-01-20 2403392]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AF69DE43-7D58-4638-B6FA-CE66B5AD205D}]
Google Toolbar Notifier BHO - C:\Program Files\Google\GoogleToolbarNotifier\5.4.4525.1752\swg.dll [2009-12-02 764912]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{B164E929-A1B6-4A06-B104-2CD0E90A88FF}]
McAfee SiteAdvisor BHO - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll [2009-11-23 204048]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{DA986D7D-CCAF-47B2-84FE-BFA1549BEBF9}]
ZeonIEEventHelper Class - C:\Program Files\Nuance\PDF Professional 6\Bin\ZeonIEFavClient.dll [2009-03-26 475136]
Java(tm) Plug-In 2 SSV Helper - C:\Program Files\Java\jre6\bin\jp2ssv.dll [2009-11-20 41760]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{E7E6F031-17CE-4C07-BC86-EABFE594F69C}]
JQSIEStartDetectorImpl Class - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll [2009-11-20 73728]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{F2AA9440-6328-4933-B7C9-A6CCDF9CBF6D}]
SidebarAutoLaunch Class - C:\Program Files\Yahoo!\browser\YSidebarIEBHO.dll [2005-02-03 124032]
{EF99BD32-C1FB-11D2-892F-0090271D4F88} - Yahoo! Toolbar - C:\Program Files\Yahoo!\Companion\Installs\cpn4\yt.dll [2006-10-26 440384]
{2318C2B1-4965-11d4-9B18-009027A5CD4F} - &Google - c:\program files\google\googletoolbar2.dll [2007-01-20 2403392]
{0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - McAfee SiteAdvisor Toolbar - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll [2009-11-23 204048]
{E3286BF1-E654-42FF-B4A6-5E111731DF6B} - Nuance PDF - C:\Program Files\Nuance\PDF Professional 6\Bin\ZeonIEFavClient.dll [2009-03-26 475136]
"AGRSMMSG"=C:\WINDOWS\AGRSMMSG.exe [2005-03-04 88209]
"PrinTray"=C:\WINDOWS\System32\spool\DRIVERS\W32X86\2\printray.exe [2000-06-07 36864]
"LXSUPMON"=C:\WINDOWS\system32\LXSUPMON.EXE [2000-06-07 794112]
"Logitech Hardware Abstraction Layer"=C:\WINDOWS\KHALMNPR.EXE [2005-07-23 28160]
"ISUSPM Startup"=C:\PROGRA~1\COMMON~1\INSTAL~1\UPDATE~1\ISUSPM.exe [2005-02-16 221184]
"KBD"=C:\HP\KBD\KBD.EXE [2005-02-02 61440]
"DNS7reminder"=C:\Program Files\Nuance\NaturallySpeaking10\Ereg\Ereg.exe [2007-04-16 259624]
"ArcSoft Connection Service"=C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACDaemon.exe [2008-04-17 98616]
"CTHelper"=C:\WINDOWS\system32\CTHELPER.EXE [2007-04-09 19456]
"Nuance OmniPage 17-reminder"=C:\Program Files\Nuance\OmniPage17\Ereg\Ereg.exe [2008-11-03 54560]
"PaperPort PTD"=C:\Program Files\ScanSoft\PaperPort\pptd40nt.exe [2008-05-10 29984]
"IndexSearch"=C:\Program Files\ScanSoft\PaperPort\IndexSearch.exe [2008-05-10 46368]
"PPort11reminder"=C:\Program Files\ScanSoft\PaperPort\Ereg\Ereg.exe [2007-08-31 328992]
"SunJavaUpdateSched"=C:\Program Files\Java\j2re1.4.2_03\bin\jusched.exe [2004-10-27 32881]
"Symantec PIF AlertEng"=C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PifSvc.exe [2007-11-28 583048]
"mcagent_exe"=C:\Program Files\McAfee.com\Agent\mcagent.exe [2009-10-29 1218008]
"McENUI"=C:\PROGRA~1\McAfee\MHN\McENUI.exe [2009-07-07 1176808]
"Google Desktop Search"=C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe [2009-12-30 30192]
"Adobe Reader Speed Launcher"=C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe [2010-04-03 36272]
"Adobe ARM"=C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe [2010-03-24 952768]
"YOP"=C:\PROGRA~1\Yahoo!\YOP\yop.exe /autostart []
"YBrowser"=C:\PROGRA~1\Yahoo!\browser\ybrwicon.exe [2006-07-21 129536]
"WinFaxAppPortStarter"=C:\WINDOWS\system32\wfxsnt40.exe [2000-09-29 43008]
"VTTimer"=VTTimer.exe []
"UpdReg"=C:\WINDOWS\UpdReg.EXE [2000-05-11 90112]
"Symantec NetDriver Monitor"=C:\PROGRA~1\SYMNET~1\SNDMon.exe []
"Recguard"=C:\WINDOWS\SMINST\RECGUARD.EXE [2004-04-14 233472]
"PS2"=C:\WINDOWS\system32\ps2.exe [2002-10-16 81920]
"IPInSightMonitor 01"=C:\Program Files\SBC Yahoo!\Connection Manager\IP InSight\IPMon32.exe [2003-07-14 98304]
"IgfxTray"=C:\WINDOWS\system32\igfxtray.exe [2004-08-20 155648]
"hpsysdrv"=c:\windows\system\hpsysdrv.exe [1998-05-07 52736]
"HPHUPD06"=c:\Program Files\HP\{AAC4FC36-8F89-4587-8DD3-EBC57C83374D}\hphupd06.exe [2004-06-07 49152]
"HPHmon06"=C:\WINDOWS\system32\hphmon06.exe [2004-06-07 659456]
"HPDJ Taskbar Utility"=C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb04.exe [2001-12-10 196608]
"HP Software Update"=C:\Program Files\HP\HP Software Update\HPWuSchd2.exe [2005-09-24 49152]
"HotKeysCmds"=C:\WINDOWS\system32\hkcmd.exe [2004-08-20 118784]
"EM_EXEC"=C:\PROGRA~1\Logitech\MOUSEW~1\SYSTEM\EM_EXEC.EXE [2001-12-20 35328]
"CTDVDDET"=C:\Program Files\Creative\SBAudigy2ZS\DVDAudio\CTDVDDet.EXE [2003-06-18 45056]
"ccApp"=C:\Program Files\Common Files\Symantec Shared\ccApp.exe []
"BJCFD"=C:\Program Files\BroadJump\Client Foundation\CFD.exe [2002-09-10 368706]
"AutoTBar"=c:\Program Files\HP\Digital Imaging\bin\AUTOTBAR.EXE []
"ATIPTA"=C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe [2004-09-09 344064]
"AlcxMonitor"=C:\WINDOWS\ALCXMNTR.EXE [2004-09-07 57344]
"AlcWzrd"=C:\WINDOWS\ALCWZRD.EXE [2004-07-29 2551808]
"Alcmtr"=C:\WINDOWS\ALCMTR.EXE [2004-07-20 57344]
"Adobe Photo Downloader"=C:\Program Files\Adobe\Photoshop Elements 5.0\apdproxy.exe [2006-09-14 61440]
"TkBellExe"=C:\Program Files\Common Files\Real\Update_OB\realsched.exe [2010-02-05 198160]
"PDFHook"=C:\Program Files\Nuance\PDF Professional 6\pdfpro6hook.exe [2009-07-27 1275168]
"PDF6 Registry Controller"=C:\Program Files\Nuance\PDF Professional 6\RegistryController.exe [2009-07-27 110880]
"Nuance PDF Professional 6-reminder"=C:\Program Files\Nuance\PDF Professional 6\Ereg\Ereg.exe [2008-11-03 54560]
"Nuance.ctfmngr"=C:\Program Files\Nuance\NaturallySpeaking10\Program\ctfmngr.exe [2009-03-16 50536]
"QuickTime Task"=C:\Program Files\QuickTime\QTTask.exe [2010-03-17 421888]
"iTunesHelper"=C:\Program Files\iTunes\iTunesHelper.exe [2010-04-28 142120]
"ctfmon.exe"=C:\WINDOWS\system32\ctfmon.exe [2008-04-13 15360]
"swg"=C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe [2007-06-16 68856]
"EPSON WorkForce 40(Network)"=C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_FATIELA.EXE [2008-03-11 188928]
"OpAgent"=OpAgent.exe /agent []
"WhereSphere"=C:\Documents and Settings\HP_Administrator\Application Data\WhereSphere\wheresphere.exe []
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\AppleSyncNotifier]
C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe []
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\LSBWatcher]
c:\hp\drivers\hplsbwatcher\lsburnwatcher.exe [2004-10-14 253952]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MimBoot]
C:\PROGRA~1\MUSICM~1\MUSICM~1\mimboot.exe [2006-11-07 8192]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\RoxioDragToDisc]
C:\Program Files\Roxio\Easy Media Creator 8\Drag to Disc\DrgToDsc.exe [2005-11-21 1687552]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\RoxWatchTray]
C:\Program Files\Common Files\Roxio Shared\SharedCOM8\RoxWatchTray.exe [2005-11-22 163840]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SSBkgdUpdate]
C:\Program Files\Common Files\Scansoft Shared\SSBkgdUpdate\SSBkgdupdate.exe [2006-10-25 210472]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Yahoo! Pager]
C:\PROGRA~1\Yahoo!\MESSEN~1\YAHOOM~1.EXE [2007-08-30 4670704]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HotSync Manager.lnk]
C:\Palm\HOTSYNC.EXE [2004-06-09 471040]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HOTSYNCSHORTCUTNAME.lnk]
C:\Palm\Hotsync.exe [2004-06-09 471040]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Microsoft Office.lnk]
C:\PROGRA~1\MI1933~1\Office10\OSA.EXE [2001-02-13 83360]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^NkbMonitor.exe.lnk]
C:\PROGRA~1\Nikon\PICTUR~1\NKBMON~1.EXE [2004-09-24 118784]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^NkvMon.exe.lnk]
C:\PROGRA~1\Nikon\NkView6\NkvMon.exe [2005-11-05 233472]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Trend Micro Anti-Spyware.lnk]
C:\PROGRA~1\TRENDM~1\Tmas\Tmas.exe [2005-11-04 1306624]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Yahoo! Autosync.lnk]
C:\Program Files\Yahoo!\Yahoo! Autosync\AutosyncForYahoo.exe  []
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^ymetray.lnk]
C:\PROGRA~1\Yahoo!\YAHOO!~1\ymetray.exe [2008-02-05 54512]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^HP_Administrator^Start Menu^Programs^Startup^Adobe Gamma.lnk]
C:\PROGRA~1\COMMON~1\Adobe\CALIBR~1\ADOBEG~1.EXE [2002-08-06 113664]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^HP_Administrator^Start Menu^Programs^Startup^HotSync Manager.lnk]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupfolder\C:^Documents and Settings^HP_Administrator^Start Menu^Programs^Startup^HP Organize.lnk]
C:\PROGRA~1\HEWLET~1\HPORGA~1\bin\DISPLA~1.EXE [2004-07-15 36864]
C:\Documents and Settings\All Users\Start Menu\Programs\Startup
Adobe Gamma Loader.lnk - C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
Controller.LNK - C:\Program Files\WinFax\WFXCTL32.EXE
HP Digital Imaging Monitor.lnk - C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
HP Photosmart Premier Fast Start.lnk - C:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe
Logitech Desktop Messenger.lnk - C:\Program Files\Desktop Messenger\8876480\Program\LDMConf.exe
Logitech SetPoint.lnk - C:\Program Files\Logitech\SetPoint\SetPoint.exe
Updates from HP.lnk - C:\Program Files\Updates from HP\309731\Program\Updates from HP.exe
Windows Search.lnk - C:\Program Files\Windows Desktop Search\WindowsSearch.exe
C:\Documents and Settings\HP_Administrator\Start Menu\Programs\Startup
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows]
"AppInit_DLLS"="C:\PROGRA~1\Google\GOOGLE~4\GOEC62~1.DLL"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\AtiExtEvent]
C:\WINDOWS\system32\Ati2evxx.dll [2004-09-10 90112]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\GoToMyPC]
C:\Program Files\Citrix\GoToMyPC\G2WinLogon.dll [2009-12-15 15216]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\igfxcui]
C:\WINDOWS\system32\igfxsrvc.dll [2004-08-20 344064]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\RDM+]
C:\Program Files\RDM+\notify.dll [2008-04-13 61440]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\WgaLogon]
C:\WINDOWS\system32\WgaLogon.dll [2009-03-10 239496]
WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll [2006-10-18 133632]
UPnPMonitor - {e57ce738-33e8-4c51-8354-bb4de9d215d1} - C:\WINDOWS\system32\upnpui.dll [2008-04-13 239616]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ShellExecuteHooks]
"{A213B520-C6C2-11d0-AF9D-008029E1027E}"=C:\Program Files\WinFax\WfxSeh32.Dll [1998-07-27 38400]
"{03A80B1D-5C6A-42c2-9DFB-81B6005D8023}"=C:\Program Files\Trend Micro\Tmas\sshook.dll [2005-11-04 77824]
"{56F9679E-7826-4C84-81F3-532071A8BCC5}"=C:\Program Files\Windows Desktop Search\MSNLNamespaceMgr.dll [2009-05-24 304128]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\mcmscsvc]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\mcmscsvc]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\MCODS]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\network\MpfService]
"dontdisplaylastusername"=0
"legalnoticecaption"=
"legalnoticetext"=
"shutdownwithoutlogon"=1
"undockwithoutlogon"=1
"NoDriveTypeAutoRun"=145
"NoDrives"=0
"NoViewOnDrive"=0
"NoDevMgrUpdate"=1
"HonorAutoRunSetting"=
"%windir%\system32\sessmgr.exe"="%windir%\system32\sessmgr.exe:*:enabled:@xpsp2res.dll,-22019"
"C:\Program Files\Updates from HP\309731\Program\Updates from HP.exe"="C:\Program Files\Updates from HP\309731\Program\Updates from HP.exe:*:Enabled:BackWeb for Pavilion"
"C:\Program Files\EarthLink TotalAccess\TaskPanl.exe"="C:\Program Files\EarthLink TotalAccess\TaskPanl.exe:*:Enabled:Earthlink"
"C:\Program Files\LimeWire\LimeWire.exe"="C:\Program Files\LimeWire\LimeWire.exe:*:Enabled:LimeWire"
"%windir%\Network Diagnostic\xpnetdiag.exe"="%windir%\Network Diagnostic\xpnetdiag.exe:*:Enabled:@xpsp3res.dll,-20000"
"F:\setup\HPZNET01.EXE"="F:\setup\HPZNET01.EXE:*:Enabled:hpznet01.exe"
"C:\Program Files\Messenger\msmsgs.exe"="C:\Program Files\Messenger\msmsgs.exe:*:Enabled:Windows Messenger"
"E:\setup\HPZNET01.EXE"="E:\setup\HPZNET01.EXE:*:Enabled:hpznet01.exe"
"C:\Program Files\Common Files\McAfee\MNA\McNASvc.exe"="C:\Program Files\Common Files\McAfee\MNA\McNASvc.exe:*:Enabled:McAfee Network Agent"
"C:\Program Files\Roxio\Easy Media Creator 8\Digital Home\RoxUpnpServer.exe"="C:\Program Files\Roxio\Easy Media Creator 8\Digital Home\RoxUpnpServer.exe:*:Enabled:Roxio Upnp Service"
"C:\Program Files\Bonjour\mDNSResponder.exe"="C:\Program Files\Bonjour\mDNSResponder.exe:*:Enabled:Bonjour Service"
"C:\Program Files\iTunes\iTunes.exe"="C:\Program Files\iTunes\iTunes.exe:*:Enabled:iTunes"
"%ProgramFiles%\iTunes\iTunes.exe"="%ProgramFiles%\iTunes\iTunes.exe:*:enabled:iTunes"
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\explorer\mountpoints2\{772bc303-52fa-11df-913c-00112ff59f67}]
shell\AutoRun\command - ~tmpfolder\~drv089542.exe
shell\explore\command - ~tmpfolder\~drv089542.exe
shell\open\command - ~tmpfolder\~drv089542.exe
shell\search\command - ~tmpfolder\~drv089542.exe
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\explorer\mountpoints2\{80230ea8-5847-11d9-9354-806d6172696f}]
shell\AutoRun\command - E:\AUTORUN.EXE
======List of files/folders created in the last 1 months======
2010-05-04 10:06:48 ----D---- C:\rsit
2010-05-04 10:03:42 ----D---- C:\WINDOWS\ERDNT
2010-05-04 10:03:20 ----D---- C:\Program Files\ERUNT
2010-05-04 08:16:36 ----D---- C:\Program Files\iPod
2010-05-04 08:16:00 ----D---- C:\Program Files\iTunes
2010-05-04 08:00:07 ----D---- C:\Program Files\Bonjour
2010-05-03 13:21:54 ----HD---- C:\Program Files\Zero G Registry
2010-05-03 13:21:54 ----D---- C:\Program Files\AutoReceive
2010-05-03 12:41:19 ----D---- C:\WINDOWS\system32\Adobe
2010-05-03 12:40:57 ----D---- C:\Program Files\WebEx
2010-04-15 09:34:06 ----HDC---- C:\WINDOWS\$NtUninstallKB979683$
2010-04-15 09:33:54 ----HDC---- C:\WINDOWS\$NtUninstallKB980232$
2010-04-15 09:29:45 ----HDC---- C:\WINDOWS\$NtUninstallKB978338$
2010-04-15 09:29:20 ----HDC---- C:\WINDOWS\$NtUninstallKB977816$
2010-04-15 09:29:06 ----HDC---- C:\WINDOWS\$NtUninstallKB978601$
2010-04-15 09:26:49 ----HDC---- C:\WINDOWS\$NtUninstallKB979309$
2010-04-14 08:09:45 ----D---- C:\Documents and Settings\All Users\Application Data\{429CAD59-35B1-4DBC-BB6D-1DB246563521}
2010-04-08 13:20:02 ----A---- C:\WINDOWS\system32\dns-sd.exe
2010-04-08 13:20:02 ----A---- C:\WINDOWS\system32\dnssd.dll
======List of files/folders modified in the last 1 months======
2010-05-04 10:07:05 ----D---- C:\Program Files\Trend Micro
2010-05-04 10:06:55 ----D---- C:\WINDOWS\Temp
2010-05-04 09:59:19 ----A---- C:\WINDOWS\win.ini
2010-05-04 09:57:05 ----A---- C:\WINDOWS\ModemLog_LSI PCI Soft Modem.txt
2010-05-04 09:56:27 ----AD---- C:\Documents and Settings\All Users\Application Data\TEMP
2010-05-04 09:56:18 ----SD---- C:\WINDOWS\Tasks
2010-05-04 09:55:55 ----D---- C:\WINDOWS\system32
2010-05-04 09:55:49 ----HD---- C:\Config.Msi
2010-05-04 09:49:07 ----A---- C:\WINDOWS\SchedLgU.Txt
2010-05-04 09:47:08 ----AC---- C:\WINDOWS\{00000003-00000000-00000003-00001102-00000004-20051102}.BAK
2010-05-04 09:45:52 ----D---- C:\Program Files\WinFax
2010-05-04 08:29:39 ----D---- C:\WINDOWS\Prefetch
2010-05-04 08:28:33 ----SHD---- C:\WINDOWS\Installer
2010-05-04 08:26:23 ----A---- C:\WINDOWS\BRWMARK.INI
2010-05-04 08:16:31 ----D---- C:\Program Files\Common Files\Apple
2010-05-04 07:52:37 ----A---- C:\WINDOWS\BRPP2KA.INI
2010-05-03 12:52:48 ----SD---- C:\WINDOWS\Downloaded Program Files
2010-05-03 12:41:19 ----D---- C:\Program Files\Common Files\Adobe
2010-05-03 12:38:43 ----HD---- C:\WINDOWS\inf
2010-04-29 17:57:06 ----D---- C:\WINDOWS\system32\CatRoot2
2010-04-15 09:34:12 ----RSHDC---- C:\WINDOWS\system32\dllcache
2010-04-15 09:34:02 ----HD---- C:\WINDOWS\$hf_mig$
2010-04-15 09:33:59 ----A---- C:\WINDOWS\imsins.BAK
2010-04-15 09:33:56 ----D---- C:\WINDOWS\system32\drivers
2010-04-15 09:27:05 ----D---- C:\WINDOWS\ie8updates
2010-04-14 14:14:39 ----D---- C:\FILEMAKER PRO
2010-04-14 08:05:13 ----D---- C:\Program Files\QuickTime
2010-04-14 07:56:26 ----DC---- C:\WINDOWS\system32\DRVSTORE
2010-04-13 17:17:37 ----D---- C:\Program Files\Google
2010-04-06 10:52:54 ----A---- C:\WINDOWS\system32\MRT.exe
2010-04-05 08:59:55 ----D---- C:\WINDOWS\system32\config
2010-04-05 08:59:21 ----D---- C:\WINDOWS\system32\wbem
2010-04-05 08:59:20 ----D---- C:\WINDOWS\Registration
2010-04-05 08:52:01 ----D---- C:\Program Files\Internet Explorer
R1 cdudf_xp;cdudf_xp; C:\WINDOWS\system32\drivers\cdudf_xp.sys [2005-10-22 311680]
R1 intelppm;Intel Processor Driver; C:\WINDOWS\system32\DRIVERS\intelppm.sys [2008-04-13 36352]
R1 kbdhid;Keyboard HID Driver; C:\WINDOWS\system32\DRIVERS\kbdhid.sys [2008-04-13 14592]
R1 mfehidk;McAfee Inc. mfehidk; C:\WINDOWS\system32\drivers\mfehidk.sys [2009-11-04 214664]
R1 MPFP;MPFP; C:\WINDOWS\System32\Drivers\Mpfp.sys [2009-07-16 120136]
R1 pwd_2k;pwd_2k; C:\WINDOWS\system32\drivers\pwd_2k.sys [2005-10-22 119168]
R1 RxFilter;RxFilter; C:\WINDOWS\system32\DRIVERS\RxFilter.sys [2005-11-22 50176]
R1 SiSkp;SiSkp; C:\WINDOWS\system32\DRIVERS\srvkp.sys [2004-09-24 12928]
R1 Tcpip6;Microsoft IPv6 Protocol Driver; C:\WINDOWS\system32\DRIVERS\tcpip6.sys [2010-02-11 226880]
R2 BCMNTIO;BCMNTIO; \??\C:\PROGRA~1\CheckIt\DIAGNO~1\BCMNTIO.sys []
R2 MAPMEM;MAPMEM; \??\C:\PROGRA~1\CheckIt\DIAGNO~1\MAPMEM.sys []
R2 PfModNT;PfModNT; \??\C:\WINDOWS\system32\drivers\PfModNT.sys []
R3 AgereSoftModem;Agere Systems Soft Modem; C:\WINDOWS\system32\DRIVERS\AGRSM.sys [2009-08-13 1163328]
R3 Arp1394;1394 ARP Client Protocol; C:\WINDOWS\system32\DRIVERS\arp1394.sys [2008-04-13 60800]
R3 ati2mtag;ati2mtag; C:\WINDOWS\system32\DRIVERS\ati2mtag.sys [2004-09-10 798208]
R3 COMMONFX.DLL;COMMONFX.DLL; C:\WINDOWS\system32\COMMONFX.DLL [2007-04-18 98600]
R3 ctac32k;Creative AC3 Software Decoder; C:\WINDOWS\System32\drivers\ctac32k.sys [2007-04-10 511272]
R3 ctaud2k;Creative Audio Driver (WDM); C:\WINDOWS\system32\drivers\ctaud2k.sys [2007-04-10 520488]
R3 CTAUDFX.DLL;CTAUDFX.DLL; C:\WINDOWS\system32\CTAUDFX.DLL [2007-04-12 546048]
R3 ctprxy2k;Creative Proxy Driver; C:\WINDOWS\System32\drivers\ctprxy2k.sys [2007-04-10 14632]
R3 CTSBLFX.DLL;CTSBLFX.DLL; C:\WINDOWS\system32\CTSBLFX.DLL [2007-04-12 560384]
R3 ctsfm2k;Creative SoundFont Management Device Driver; C:\WINDOWS\System32\drivers\ctsfm2k.sys [2007-04-10 157480]
R3 dfmirage;dfmirage; C:\WINDOWS\system32\DRIVERS\dfmirage.sys [2008-04-15 31896]
R3 dvd_2K;dvd_2K; C:\WINDOWS\system32\drivers\dvd_2K.sys [2005-10-22 27264]
R3 emupia;E-mu Plug-in Architecture Driver; C:\WINDOWS\System32\drivers\emupia2k.sys [2007-04-10 92968]
R3 GEARAspiWDM;GEAR ASPI Filter Driver; C:\WINDOWS\SYSTEM32\DRIVERS\GEARAspiWDM.sys [2009-05-18 26600]
R3 ha10kx2k;Creative Hardware Abstract Layer Driver; C:\WINDOWS\System32\drivers\ha10kx2k.sys [2007-04-10 797992]
R3 hap16v2k;Creative P16V HAL Driver; C:\WINDOWS\System32\drivers\hap16v2k.sys [2007-04-10 163112]
R3 HidUsb;Microsoft HID Class Driver; C:\WINDOWS\system32\DRIVERS\hidusb.sys [2008-04-13 10368]
R3 Iviaspi;IVI ASPI Shell; C:\WINDOWS\system32\drivers\iviaspi.sys [2003-09-11 21060]
R3 LHidFlt2;Logitech HID/USB Mouse Filter Driver; C:\WINDOWS\system32\DRIVERS\LHidFlt2.sys [2001-12-19 22206]
R3 LHidKe;Logitech SetPoint HID Mouse Filter Driver; C:\WINDOWS\system32\DRIVERS\LHidKE.Sys [2005-07-23 26112]
R3 LMouFlt2;Logitech Mouse Class Filter Driver; C:\WINDOWS\system32\DRIVERS\LMouFlt2.sys [2001-12-19 67694]
R3 LMouKE;Logitech SetPoint Mouse Filter Driver; C:\WINDOWS\system32\DRIVERS\LMouKE.Sys [2005-07-23 68864]
R3 mfeavfk;McAfee Inc. mfeavfk; C:\WINDOWS\system32\drivers\mfeavfk.sys [2009-11-04 79816]
R3 mfebopk;McAfee Inc. mfebopk; C:\WINDOWS\system32\drivers\mfebopk.sys [2009-11-04 35272]
R3 mfesmfk;McAfee Inc. mfesmfk; C:\WINDOWS\system32\drivers\mfesmfk.sys [2009-11-04 40552]
R3 mmc_2K;mmc_2K; C:\WINDOWS\system32\drivers\mmc_2K.sys [2005-10-22 27136]
R3 mouhid;Mouse HID Driver; C:\WINDOWS\system32\DRIVERS\mouhid.sys [2001-08-17 12160]
R3 NIC1394;1394 Net Driver; C:\WINDOWS\system32\DRIVERS\nic1394.sys [2008-04-13 61824]
R3 ossrv;Creative OS Services Driver; C:\WINDOWS\system32\drivers\ctoss2k.sys [2007-04-10 126760]
R3 Pfc;Padus ASPI Shell; C:\WINDOWS\system32\drivers\pfc.sys [2003-09-19 10368]
R3 RTL8023xp;Realtek 10/100/1000 PCI NIC Family NDIS XP Driver; C:\WINDOWS\system32\DRIVERS\Rtnicxp.sys [2009-03-25 130432]
R3 tunmp;Microsoft Tun Miniport Adapter Driver; C:\WINDOWS\system32\DRIVERS\tunmp.sys [2008-04-13 12288]
R3 usbccgp;Microsoft USB Generic Parent Driver; C:\WINDOWS\system32\DRIVERS\usbccgp.sys [2008-04-13 32128]
R3 usbehci;Microsoft USB 2.0 Enhanced Host Controller Miniport Driver; C:\WINDOWS\system32\DRIVERS\usbehci.sys [2008-04-13 30208]
R3 usbhub;Microsoft USB Standard Hub Driver; C:\WINDOWS\system32\DRIVERS\usbhub.sys [2008-04-13 59520]
R3 usbprint;Microsoft USB PRINTER Class; C:\WINDOWS\system32\DRIVERS\usbprint.sys [2008-04-13 25856]
R3 usbuhci;Microsoft USB Universal Host Controller Miniport Driver; C:\WINDOWS\system32\DRIVERS\usbuhci.sys [2008-04-13 20608]
S1 AmdK7;AMD K7 Processor Driver; C:\WINDOWS\system32\DRIVERS\amdk7.sys [2008-04-13 37760]
S3 ALCXWDM;Service for Realtek AC97 Audio (WDM); C:\WINDOWS\system32\drivers\ALCXWDM.SYS [2004-10-01 2279424]
S3 CT20XUT.DLL;CT20XUT.DLL; C:\WINDOWS\system32\CT20XUT.DLL [2007-04-12 164608]
S3 ctdvda2k;Creative DVD-Audio Device Driver; C:\WINDOWS\System32\drivers\ctdvda2k.sys [2003-11-13 333600]
S3 CTEAPSFX.DLL;CTEAPSFX.DLL; C:\WINDOWS\system32\CTEAPSFX.DLL [2007-04-12 168192]
S3 CTEDSPFX.DLL;CTEDSPFX.DLL; C:\WINDOWS\system32\CTEDSPFX.DLL [2007-04-12 280320]
S3 CTEDSPIO.DLL;CTEDSPIO.DLL; C:\WINDOWS\system32\CTEDSPIO.DLL [2007-04-12 128768]
S3 CTEDSPSY.DLL;CTEDSPSY.DLL; C:\WINDOWS\system32\CTEDSPSY.DLL [2007-04-12 323328]
S3 CTERFXFX.DLL;CTERFXFX.DLL; C:\WINDOWS\system32\CTERFXFX.DLL [2007-04-12 94976]
S3 CTEXFIFX.DLL;CTEXFIFX.DLL; C:\WINDOWS\system32\CTEXFIFX.DLL [2007-04-12 1317632]
S3 CTHWIUT.DLL;CTHWIUT.DLL; C:\WINDOWS\system32\CTHWIUT.DLL [2007-04-12 66816]
S3 hap17v2k;Creative P17V HAL Driver; C:\WINDOWS\system32\drivers\hap17v2k.sys [2007-04-10 189736]
S3 HDAudBus;Microsoft UAA Bus Driver for High Definition Audio; C:\WINDOWS\system32\DRIVERS\HDAudBus.sys [2008-04-13 144384]
S3 HPZid412;IEEE-1284.4 Driver HPZid412; C:\WINDOWS\system32\DRIVERS\HPZid412.sys [2005-10-27 49664]
S3 HPZipr12;Print Class Driver for IEEE-1284.4 HPZipr12; C:\WINDOWS\system32\DRIVERS\HPZipr12.sys [2005-10-27 16496]
S3 HPZius12;USB to IEEE-1284.4 Translation Driver HPZius12; C:\WINDOWS\system32\DRIVERS\HPZius12.sys [2005-10-27 21568]
S3 ialm;ialm; C:\WINDOWS\system32\DRIVERS\ialmnt5.sys [2004-08-20 737874]
S3 IntcAzAudAddService;Service for Realtek HD Audio (WDM); C:\WINDOWS\system32\drivers\RtkHDAud.sys [2004-07-29 2216128]
S3 L8042mou;Logitech SetPoint PS/2 Mouse Filter Driver; C:\WINDOWS\system32\DRIVERS\L8042mou.Sys [2005-07-23 55040]
S3 LHidUsb;Logitech USB Receiver device driver; C:\WINDOWS\system32\drivers\LHidUsb.Sys [2001-12-19 39932]
S3 LKbdFlt2;Logitech Keyboard Class Filter Driver; C:\WINDOWS\system32\DRIVERS\LKbdFlt2.sys [2001-12-19 5838]
S3 mferkdk;McAfee Inc. mferkdk; C:\WINDOWS\system32\drivers\mferkdk.sys [2009-11-04 34248]
S3 nv;nv; C:\WINDOWS\system32\DRIVERS\nv4_mini.sys [2004-08-03 1897408]
S3 OlCamudp;OLYMPUS Digital Camera; C:\WINDOWS\System32\Drivers\olcamudp.sys [2000-02-08 10379]
S3 PalmUSBD;PalmUSBD; C:\WINDOWS\system32\drivers\PalmUSBD.sys []
S3 Ps2;PS2; C:\WINDOWS\system32\DRIVERS\PS2.sys [2001-06-04 14112]
S3 RiotDrv;Rio Riot driver; C:\WINDOWS\System32\Drivers\RiotDrv.sys [2002-02-20 12474]
S3 rtl8139;Realtek RTL8139/810x Family Fast Ethernet NIC NT Driver; C:\WINDOWS\system32\DRIVERS\R8139n51.SYS [2002-10-04 46976]
S3 Ser2pl;Prolific Serial port driver; C:\WINDOWS\system32\DRIVERS\ser2pl.sys [2002-04-09 39552]
S3 SiS315;SiS315; C:\WINDOWS\system32\DRIVERS\sisgrp.sys [2004-09-29 229888]
S3 SymIM;Symantec Network Security Intermediate Filter Service; C:\WINDOWS\system32\DRIVERS\SymIM.sys []
S3 SymIMMP;SymIMMP; C:\WINDOWS\system32\DRIVERS\SymIM.sys []
S3 USBAAPL;Apple Mobile USB Driver; C:\WINDOWS\System32\Drivers\usbaapl.sys [2009-08-28 40448]
S3 usbohci;Microsoft USB Open Host Controller Miniport Driver; C:\WINDOWS\system32\DRIVERS\usbohci.sys [2008-04-13 17152]
S3 usbscan;USB Scanner Driver; C:\WINDOWS\system32\DRIVERS\usbscan.sys [2008-04-13 15104]
S3 USBSTOR;USB Mass Storage Driver; C:\WINDOWS\system32\DRIVERS\USBSTOR.SYS [2008-04-13 26368]
S3 viagfx;viagfx; C:\WINDOWS\system32\DRIVERS\vtmini.sys [2004-09-23 173312]
S3 WpdUsb;WpdUsb; C:\WINDOWS\System32\Drivers\wpdusb.sys [2006-10-18 38528]
S3 WudfRd;Windows Driver Foundation - User-mode Driver Framework Reflector; C:\WINDOWS\system32\DRIVERS\wudfrd.sys [2006-09-28 82944]
R2 6to4;IPv6 Helper Service; C:\WINDOWS\system32\svchost.exe [2008-04-13 14336]
R2 ACDaemon;ArcSoft Connect Daemon; C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACService.exe [2008-04-17 102712]
R2 AdobeActiveFileMonitor5.0;Adobe Active File Monitor V5; C:\Program Files\Adobe\Photoshop Elements 5.0\PhotoshopElementsFileAgent.exe [2006-09-14 102400]
R2 AgereModemAudio;Agere Modem Call Progress Audio; C:\Program Files\LSI SoftModem\agrsmsvc.exe [2009-03-27 14336]
R2 Apple Mobile Device;Apple Mobile Device; C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe [2010-04-16 144672]
R2 Ati HotKey Poller;Ati HotKey Poller; C:\WINDOWS\system32\Ati2evxx.exe [2004-09-10 405504]
R2 Automatic LiveUpdate Scheduler;Automatic LiveUpdate Scheduler; C:\Program Files\Symantec\LiveUpdate\AluSchedulerSvc.exe [2008-02-09 238968]
R2 Bonjour Service;Bonjour Service; C:\Program Files\Bonjour\mDNSResponder.exe [2010-04-08 345376]
R2 Creative Service for CDROM Access;Creative Service for CDROM Access; C:\WINDOWS\system32\CTsvcCDA.EXE [1999-12-12 44032]
R2 EPSON_EB_RPCV4_01;EPSON V5 Service4(01); C:\Documents and Settings\All Users\Application Data\EPSON\EPW!3 SSRP\E_S40ST7.EXE [2007-12-16 143872]
R2 EPSON_PM_RPCV4_01;EPSON V3 Service4(01); C:\Documents and Settings\All Users\Application Data\EPSON\EPW!3 SSRP\E_S40RP7.EXE [2007-01-10 113664]
R2 EpsonBidirectionalService;EpsonBidirectionalService; C:\Program Files\Common Files\EPSON\eEBAPI\eEBSVC.exe [2006-12-19 94208]
R2 GoToMyPC;GoToMyPC; C:\Program Files\Citrix\GoToMyPC\g2svc.exe [2009-12-15 557424]
R2 Iprip;RIP Listener; C:\WINDOWS\System32\svchost.exe [2008-04-13 14336]
R2 JavaQuickStarterService;Java Quick Starter; C:\Program Files\Java\jre6\bin\jqs.exe [2009-11-20 153376]
R2 LexBceS;LexBce Server; C:\WINDOWS\system32\LEXBCES.EXE [2000-06-07 285184]
R2 LiveUpdate Notice Service;LiveUpdate Notice Service; C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PifSvc.exe [2007-11-28 583048]
R2 McAfee SiteAdvisor Service;McAfee SiteAdvisor Service; C:\Program Files\McAfee\SiteAdvisor\McSACore.exe [2009-12-08 93320]
R2 mcmscsvc;McAfee Services; C:\PROGRA~1\McAfee\MSC\mcmscsvc.exe [2009-10-29 865832]
R2 McNASvc;McAfee Network Agent; c:\PROGRA~1\COMMON~1\mcafee\mna\mcnasvc.exe [2009-07-07 2482848]
R2 McProxy;McAfee Proxy Service; c:\PROGRA~1\COMMON~1\mcafee\mcproxy\mcproxy.exe [2009-07-08 359952]
R2 McShield;McAfee Real-time Scanner; C:\PROGRA~1\McAfee\VIRUSS~1\mcshield.exe [2009-11-04 144704]
R2 MDM;Machine Debug Manager; C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE [2003-06-20 322120]
R2 MpfService;McAfee Personal Firewall Service; C:\Program Files\McAfee\MPF\MPFSrv.exe [2009-10-27 895696]
R2 OmniForm Printer;OmniForm Printer; C:\WINDOWS\system32\ofps.exe [2001-10-17 32768]
R2 PDFProFiltSrv;PDFProFiltSrv; C:\Program Files\Nuance\PDF Professional 6\PDFProFiltSrv.exe [2009-07-27 134944]
R2 RDMPLocalService;RDM+ Local Service; C:\Program Files\RDM+\rdmpserv.exe [2008-07-01 849920]
R2 RoxWatch;Roxio Hard Drive Watcher; C:\Program Files\Common Files\Roxio Shared\SharedCOM8\RoxWatch.exe [2005-11-22 155648]
R2 SimpTcp;Simple TCP/IP Services; C:\WINDOWS\system32\tcpsvcs.exe [2004-08-04 19456]
R2 wfxsvc;WinFax PRO; C:\WINDOWS\system32\WFXSVC.EXE [2000-09-29 129536]
R2 WMDM PMSP Service;WMDM PMSP Service; C:\WINDOWS\system32\MsPMSPSv.exe [2000-06-26 53520]
R2 WSearch;Windows Search; C:\WINDOWS\system32\SearchIndexer.exe [2008-05-26 439808]
R2 WudfSvc;Windows Driver Foundation - User-mode Driver Framework; C:\WINDOWS\system32\svchost.exe [2008-04-13 14336]
R3 iPod Service;iPod Service; C:\Program Files\iPod\bin\iPodService.exe [2010-04-28 545576]
R3 McSysmon;McAfee SystemGuards; C:\PROGRA~1\McAfee\VIRUSS~1\mcsysmon.exe [2009-11-04 606736]
R3 RoxMediaDB;RoxMediaDB; C:\Program Files\Common Files\Roxio Shared\SharedCOM8\RoxMediaDB.exe [2005-11-22 864256]
S2 0004891270059213mcinstcleanup;McAfee Application Installer Cleanup (0004891270059213); C:\WINDOWS\TEMP\000489~1.EXE C:\PROGRA~1\COMMON~1\McAfee\INSTAL~1\cleanup.ini -cleanup -nolog -service []
S2 ccProxy;Symantec Network Proxy; C:\Program Files\Common Files\Symantec Shared\ccProxy.exe [2006-06-14 235168]
S2 gupdate;Google Update Service (gupdate); C:\Program Files\Google\Update\GoogleUpdate.exe [2009-12-30 133104]
S2 gusvc;Google Software Updater; C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe [2010-02-01 194032]
S2 LiveUpdate Notice E
Continued:
S2 LiveUpdate Notice Ex;LiveUpdate Notice Service Ex; C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe /h ccCommon []
S2 Pml Driver HPZ12;Pml Driver HPZ12; C:\WINDOWS\system32\HPZipm12.exe [2005-03-14 69632]
S2 RoxLiveShare;LiveShare P2P Server; C:\Program Files\Common Files\Roxio Shared\SharedCOM8\RoxLiveShare.exe [2005-11-22 233472]
S2 RoxUpnpServer;RoxUpnpServer; C:\Program Files\Roxio\Easy Media Creator 8\Digital Home\RoxUpnpServer.exe [2005-11-21 409600]
S3 aspnet_state;ASP.NET State Service; C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_state.exe [2008-07-25 34312]
S3 clr_optimization_v2.0.50727_32;.NET Runtime Optimization Service v2.0.50727_X86; C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorsvw.exe [2008-07-25 69632]
S3 FontCache3.0.0.0;Windows Presentation Foundation Font Cache 3.0.0.0; c:\WINDOWS\Microsoft.NET\Framework\v3.0\WPF\PresentationFontCache.exe [2008-07-29 46104]
S3 GoogleDesktopManager-110309-193829;Google Desktop Manager 5.9.911.3589; C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe [2009-12-30 30192]
S3 HP Port Resolver;HP Port Resolver; C:\WINDOWS\system32\spool\drivers\w32x86\3\HPBPRO.EXE [2005-05-20 81920]
S3 HP Status Server;HP Status Server; C:\WINDOWS\system32\spool\drivers\w32x86\3\HPBOID.EXE [2004-10-16 73728]
S3 IDriverT;InstallDriver Table Manager; C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe [2005-04-04 69632]
S3 idsvc;Windows CardSpace; C:\WINDOWS\Microsoft.NET\Framework\v3.0\Windows Communication Foundation\infocard.exe [2008-07-29 881664]
S3 LiveUpdate;LiveUpdate; C:\Program Files\Symantec\LiveUpdate\LuComServer_3_4.EXE [2008-08-04 3220856]
S3 McODS;McAfee Scanner; C:\PROGRA~1\McAfee\VIRUSS~1\mcods.exe [2009-10-28 365072]
S3 p2pgasvc;Peer Networking Group Authentication; C:\WINDOWS\system32\svchost.exe [2008-04-13 14336]
S3 p2pimsvc;Peer Networking Identity Manager; C:\WINDOWS\system32\svchost.exe [2008-04-13 14336]
S3 p2psvc;Peer Networking; C:\WINDOWS\system32\svchost.exe [2008-04-13 14336]
S3 PNRPSvc;Peer Name Resolution Protocol; C:\WINDOWS\system32\svchost.exe [2008-04-13 14336]
S3 RoxUPnPRenderer;RoxUpnpRenderer; C:\Program Files\Common Files\Roxio Shared\SharedCom\RoxUpnpRenderer.exe [2005-11-21 45056]
S3 WMPNetworkSvc;Windows Media Player Network Sharing Service; C:\Program Files\Windows Media Player\WMPNetwk.exe [2006-10-18 913408]
S4 NetTcpPortSharing;Net.Tcp Port Sharing Service; C:\WINDOWS\Microsoft.NET\Framework\v3.0\Windows Communication Foundation\SMSvcHost.exe [2008-07-29 132096]
info.txt logfile of random's system information tool 1.06 2010-05-04 10:07:10
======Uninstall list======
-->"C:\Program Files\Symantec\LiveUpdate\LSETUP.EXE" /U
-->C:\Program Files\Yahoo!\Yahoo! Music Jukebox\oggcodecs\uninst.exe
-->C:\WINDOWS\IsUninst.exe -fC:\WINDOWS\orun32.isu
-->C:\WINDOWS\system32\\MSIEXEC.EXE /x {637099FB-45FD-4BC7-9651-6FB540DBB749}
-->c:\WINDOWS\system32\\MSIEXEC.EXE /x {9541FED0-327F-4df0-8B96-EF57EF622F19}
-->MsiExec.exe /I{0D330013-4A99-46D6-83C6-2C959C68DBFF}
-->MsiExec.exe /I{26792CA7-D87A-4DBE-896B-C2F66B344511}
-->MsiExec.exe /I{637099FB-45FD-4BC7-9651-6FB540DBB749}
-->MsiExec.exe /I{6D4F02C4-F6AF-4659-A933-7FC06235A8D5}
-->MsiExec.exe /I{7FD9FD10-9F7F-4DDF-B9F0-911209FF0CEA}
-->MsiExec.exe /I{8A42F680-2DD6-11D4-9A8C-0040F6982C20}
-->MsiExec.exe /I{8C60949A-46F9-4DD7-BA9F-78C00D9D4C8D}
-->MsiExec.exe /I{A2529672-574A-4A99-86A5-C1770A0E31FE}
-->MsiExec.exe /X{1AFDB2AB-DF91-47B8-8A9C-A6E4BBAD562B}
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{169F8893-C1C5-4847-972C-EA1E008112AC}\setup.exe" -l0x9
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{169F8893-C1C5-4847-972C-EA1E008112AC}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{1888DAFD-C634-4BC4-865C-3455E24F6177}\setup.exe" -l0x9
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{1888DAFD-C634-4BC4-865C-3455E24F6177}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{236FADD8-58FD-11D6-A285-00A0CC51B2FE}\setup.exe" -l0x9
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{236FADD8-58FD-11D6-A285-00A0CC51B2FE}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{5210ED6D-52A9-11D6-A285-00A0CC51B2FE}\setup.exe" -l0x9
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{5210ED6D-52A9-11D6-A285-00A0CC51B2FE}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{5CDC05F7-83E4-4611-AD3C-A6EB2100332A}\setup.exe" -l0x9
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{5CDC05F7-83E4-4611-AD3C-A6EB2100332A}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{5CDDF96A-BC34-4D72-9ABA-E1FFF0C39977}\setup.exe" -l0x9
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{67AEFC4C-69E4-11D7-85F4-00E018013273}\setup.exe" -l0x9
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{67AEFC4C-69E4-11D7-85F4-00E018013273}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{7201B853-5833-11D6-A285-00A0CC51B2FE}\setup.exe" -l0x9
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{7201B853-5833-11D6-A285-00A0CC51B2FE}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{77ACE67A-0D21-4CEF-8A97-ED20A61B978B}\setup.exe" -l0x9
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{77ACE67A-0D21-4CEF-8A97-ED20A61B978B}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{7A900EAB-DA37-4554-AF19-9C337476D05D}\setup.exe" -l0x9
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{7A900EAB-DA37-4554-AF19-9C337476D05D}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{869D88A5-BD6C-4E39-8536-D95259EAD7E8}\setup.exe" -l0x9
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{869D88A5-BD6C-4E39-8536-D95259EAD7E8}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{881A74B3-3D17-4842-B9AF-0761C6E6C4B5}\setup.exe" -l0x9
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{881A74B3-3D17-4842-B9AF-0761C6E6C4B5}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{9154ED7C-926E-49CC-B677-0CF3C5267457}\setup.exe" -l0x9
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{9154ED7C-926E-49CC-B677-0CF3C5267457}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{9A4D2983-4662-4387-BE3D-4CFC2FA9C100}\setup.exe" -l0x9
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{9A4D2983-4662-4387-BE3D-4CFC2FA9C100}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{A1185190-514F-11D6-A285-00A0CC51B2FE}\setup.exe" -l0x9
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{A1185190-514F-11D6-A285-00A0CC51B2FE}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{B3549608-69D3-11D7-AB2D-0090271A23A2}\setup.exe" -l0x9
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{B3549608-69D3-11D7-AB2D-0090271A23A2}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{B5BAAFAE-3561-463D-8E3F-91761A57ADB8}\setup.exe" -l0x9
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{B5BAAFAE-3561-463D-8E3F-91761A57ADB8}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{C6866B7D-ACFD-4C49-B77B-3B2F8CF54B96}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{DEBD7BF3-5856-11D6-A285-00A0CC51B2FE}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{F445476A-42DE-11D4-80D0-00C04F2750A6}\Setup.exe"  -u -uninst  -fUninst.isu -c"C:\Program Files\Epocrates\Suite\Win32\Win32_Dll\AupdUnInstall.dll"
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{FB2292C6-1F0A-11D7-AB2D-0090271A23A2}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{FD549B7B-3532-4160-80D4-3E3DD39A9AE5}\setup.exe" -l0x9  /remove
-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{FD851F7E-F887-405D-9E1C-488811113EF3}\setup.exe" -l0x9  /remove
-->rundll32.exe setupapi.dll,InstallHinfSection DefaultUninstall 132 C:\WINDOWS\INF\PCHealth.inf
Adobe AIR-->C:\Program Files\Common Files\Adobe AIR\Versions\1.0\Adobe AIR Updater.exe -arp:uninstall
Adobe AIR-->MsiExec.exe /I{00203668-8170-44A0-BE44-B632FA4D780F}
Adobe Atmosphere Player for Acrobat and Adobe Reader-->C:\WINDOWS\atmoUn.exe
Adobe Common File Installer-->MsiExec.exe /I{8EDBA74D-0686-4C99-BFDD-F894678E5102}
Adobe Flash Player 10 ActiveX-->C:\WINDOWS\system32\Macromed\Flash\uninstall_activeX.exe
Adobe Flash Player 10 Plugin-->C:\WINDOWS\system32\Macromed\Flash\uninstall_plugin.exe
Adobe Help Center 2.1-->MsiExec.exe /I{25569723-DC5A-4467-A639-79535BF01B71}
Adobe Media Player-->C:\Program Files\Common Files\Adobe AIR\Versions\1.0\Adobe AIR Application Installer.exe -uninstall com.adobe.amp 4875E02D9FB21EE389F73B8D1702B320485DF8CE.1
Adobe Media Player-->MsiExec.exe /I{1EBB57D4-63FF-87CC-A0F0-D73982CF6008}
Adobe Photoshop Album 2.0 Starter Edition-->MsiExec.exe /I{11B569C2-4BF6-4ED0-9D17-A4273943CB24}
Adobe Photoshop Elements 2.0-->C:\WINDOWS\ISUNINST.EXE -f"C:\Program Files\Adobe\Photoshop Elements 2\Uninst.isu" -c"C:\Program Files\Adobe\Photoshop Elements 2\Uninst.dll"
Adobe Photoshop Elements 5.0-->msiexec /I {A7B609FB-83D8-4FC3-8477-1BC65ECFE85B}
Adobe Premiere Elements 3.0 Templates-->MsiExec.exe /I{6EACDDF4-4220-49A3-9204-984C86852C3D}
Adobe Premiere Elements 3.0-->msiexec /I {530AFAFF-6F0A-48BB-88D0-04F9658322D3}
Adobe Premiere Elements 3.0-->MsiExec.exe /I{530AFAFF-6F0A-48BB-88D0-04F9658322D3}
Adobe Reader 9.3.2-->MsiExec.exe /I{AC76BA86-7AD7-1033-7B44-A93000000001}
Adobe SVG Viewer 3.0-->C:\Program Files\Common Files\Adobe\SVG Viewer 3.0\Uninstall\Winstall.exe -u -fC:\Program Files\Common Files\Adobe\SVG Viewer 3.0\Uninstall\Install.log
Agere Systems PCI Soft Modem-->C:\WINDOWS\agrsmdel
Apple Application Support-->MsiExec.exe /I{553255F3-78FD-40F1-A6F8-6882140265FE}
Apple Mobile Device Support-->MsiExec.exe /I{9DE1BE03-AFE2-4CDB-BFEB-D06D736CD01A}
Apple Software Update-->MsiExec.exe /I{6956856F-B6B3-4BE0-BA0B-8F495BE32033}
ArcSoft Print Creations - Brochure-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{F626E006-C06C-466A-B133-92C1991385CA}\Setup.exe" -l0x9  -1Brochure
AT&T Yahoo! Applications-->C:\PROGRA~1\Yahoo!\common\uninstall.exe
AT&T Yahoo! Music Jukebox-->MsiExec.exe /X{54AA707B-68DA-49A4-9916-68DD670241BD}
ATI Control Panel-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{0BEDBD4E-2D34-47B5-9973-57E62B29307C}\setup.exe"
ATI Display Driver-->rundll32 C:\WINDOWS\system32\atiiiexx.dll,_InfEngUnInstallINFFile_RunDLL@16 -force_restart -flags:0x2010001 -inf_class:DISPLAY -clean
Bonjour-->MsiExec.exe /X{8A253629-0511-4854-8B4E-46E57E66005C}
BroadJump Client Foundation-->C:\WINDOWS\IsUninst.exe -f"C:\Program Files\BroadJump\Client Foundation\Uninst.isu" -c"C:\Program Files\BroadJump\Client Foundation\RmvBJCFD.dll" -b"CFD" -h"CFD" -a
CheckIt  Diagnostics-->C:\PROGRA~1\CheckIt\DIAGNO~1\UNWISE.EXE C:\PROGRA~1\CheckIt\DIAGNO~1\INSTALL.LOG
Compatibility Pack for the 2007 Office system-->MsiExec.exe /X{90120000-0020-0409-0000-0000000FF1CE}
Creative Driver-->System32\ctdrvins /s /u
Creative Jukebox Driver-->C:\Program Files\Creative\Jukebox 3 Drivers\DrvUnins.exe /s
Creative MediaSource-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{56F3E1FF-54FE-4384-A153-6CCABA097814}\SETUP.EXE" -l0x9 /remove
Critical Update for Windows Media Player 11 (KB959772)-->"C:\WINDOWS\$NtUninstallKB959772_WM11$\spuninst\spuninst.exe"
DivX-->C:\Program Files\DivX\DivXCodecUninstall.exe /CODEC
Easy Internet Sign-up-->C:\PROGRA~1\COMMON~1\INSTAL~1\Driver\7\INTEL3~1\IDriver.exe /M{8105684D-8CA6-440D-8F58-7E5FD67A499D} /l1033
Enhanced Multimedia Keyboard Solution-->C:\HP\KBD\Install.exe /u
EPSON Printer Software-->C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\EPUPDATE.EXE /R
EPSON WorkForce 40 Series Printer Uninstall-->C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_FINSELA.EXE /R /APD /P:"EPSON WorkForce 40 Series"
EpsonNet Config V3-->C:\Program Files\InstallShield Installation Information\{2B0CDD4D-5C1A-47F7-89E2-9BF604670ABC}\Setup.exe -runfromtemp -l0x0009 -removeonly
EpsonNet Print-->C:\Program Files\InstallShield Installation Information\{3E31400D-274E-4647-916C-2CACC3741799}\ENPSETUP.exe -runfromtemp -l0x0009 -EPSON -removeonly
ERUNT 1.1j-->"C:\Program Files\ERUNT\unins000.exe"
FileMaker Pro 3.0-->C:\WINDOWS\uninst.exe -f"C:\Program Files\Claris Corp\FileMaker Pro 3.0\System\DeIsL1.isu"
FileMaker Pro 5.0-->C:\WINDOWS\IsUninst.exe -f"C:\Program Files\FileMaker\FileMaker Pro 5\System\DeIsL1.isu"
FileMaker Pro 7-->MsiExec.exe /I{65FA5E6D-B3D7-46D9-9571-CBBA1968346B}
FileMaker Pro 8 Advanced-->MsiExec.exe /I{681B92B1-A58A-487A-B601-4F0F23BA228D}
Google Chrome-->"C:\Program Files\Google\Chrome\Application\4.1.249.1064\Installer\setup.exe" --uninstall --system-level
Google Desktop-->C:\Program Files\Google\Google Desktop Search\GoogleDesktopSetup.exe -uninstall
Google Earth-->MsiExec.exe /X{08C0729E-3E50-11DF-9D81-005056806466}
Google Toolbar for Internet Explorer-->regsvr32 /u /s "c:\program files\google\googletoolbar2.dll"
Google Update Helper-->MsiExec.exe /I{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}
Google Updater-->"C:\Program Files\Google\Google Updater\GoogleUpdater.exe" -uninstall
GoToMyPC-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{58F4D4FD-1814-4068-B316-C28FC776C6DD}\Setup.exe" -l0x9 AddRemovePrograms
Guitar Pro 5.2-->"C:\Program Files\Guitar Pro 5\unins000.exe"
Help and Support Additions-->C:\PROGRA~1\HELPAN~1\UNWISE.EXE C:\PROGRA~1\HELPAN~1\INSTALL.LOG
High Definition Audio Driver Package - KB835221-->C:\WINDOWS\$NtUninstallKB835221WXP$\spuninst\spuninst.exe
HijackThis 2.0.2-->"C:\Program Files\trend micro\HijackThis.exe" /uninstall
Hotfix for Windows Internet Explorer 7 (KB947864)-->"C:\WINDOWS\ie7updates\KB947864-IE7\spuninst\spuninst.exe"
Hotfix for Windows Media Format 11 SDK (KB929399)-->"C:\WINDOWS\$NtUninstallKB929399$\spuninst\spuninst.exe"
Hotfix for Windows Media Format SDK (KB902344)-->"C:\WINDOWS\$NtUninstallKB902344$\spuninst\spuninst.exe"
Hotfix for Windows Media Format SDK (KB910998)-->"C:\WINDOWS\$NtUninstallKB910998$\spuninst\spuninst.exe"
Hotfix for Windows Media Player 11 (KB939683)-->"C:\WINDOWS\$NtUninstallKB939683$\spuninst\spuninst.exe"
Hotfix for Windows XP (KB915800-v4)-->"C:\WINDOWS\$NtUninstallKB915800-v4$\spuninst\spuninst.exe"
Hotfix for Windows XP (KB952287)-->"C:\WINDOWS\$NtUninstallKB952287$\spuninst\spuninst.exe"
Hotfix for Windows XP (KB961118)-->"C:\WINDOWS\$NtUninstallKB961118$\spuninst\spuninst.exe"
Hotfix for Windows XP (KB970653-v3)-->"C:\WINDOWS\$NtUninstallKB970653-v3$\spuninst\spuninst.exe"
Hotfix for Windows XP (KB976098-v2)-->"C:\WINDOWS\$NtUninstallKB976098-v2$\spuninst\spuninst.exe"
Hotfix for Windows XP (KB979306)-->"C:\WINDOWS\$NtUninstallKB979306$\spuninst\spuninst.exe"
HP Driver Diagnostics-->MsiExec.exe /X{4CCC7F68-A437-4559-A840-F5E010934951}
HP Extended Capabilities 6.0-->C:\Program Files\HP\Digital Imaging\ExtCapUninstall\hpzscr01.exe -datfile hpqhsc01.dat
HP Imaging Device Functions 6.0-->C:\Program Files\HP\Digital Imaging\DigitalImagingMonitor\hpzscr01.exe -datfile hpqbud01.dat
HP Photosmart Cameras 4.0-->C:\Program Files\HP\Digital Imaging\{4C04DF1B-6A39-4299-9DD1-1FA60000266E}\setup\hpzscr01.exe -datfile hpiscr01.dat
HP Photosmart Premier Software 6.0-->C:\Program Files\HP\Digital Imaging\uninstall\hpzscr01.exe -datfile hpqscr01.dat
HP PSC & OfficeJet 4.0-->"C:\Program Files\HP\Digital Imaging\{A1062847-0846-427A-92A1-BB8251A91E91}\setup\hpzscr01.exe" -datfile hposcr04.dat
HP Software Update-->MsiExec.exe /X{457791C5-D702-4143-A7B2-2744BE9573F2}
HP Solution Center and Imaging Support Tools 6.0-->C:\Program Files\HP\Digital Imaging\eSupport\hpzscr01.exe -datfile hpqbud05.dat
IntelliMover Data Transfer Demo-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{14589F05-C658-4594-9429-D437BA688686}\Setup.exe" -l0x9
InterVideo WinDVD Creator-->"C:\Program Files\InstallShield Installation Information\{2FCE4FC5-6930-40E7-A4F1-F862207424EF}\setup.exe" REMOVEALL
InterVideo WinDVD Player-->"C:\Program Files\InstallShield Installation Information\{91810AFC-A4F8-4EBA-A5AA-B198BBC81144}\setup.exe" REMOVEALL
iTunes-->MsiExec.exe /I{5ECB3A3C-980B-4D12-9724-25DCB07A1F47}
J2SE Runtime Environment 5.0 Update 10-->MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0150100}
J2SE Runtime Environment 5.0 Update 11-->MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0150110}
J2SE Runtime Environment 5.0 Update 3-->MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0150030}
J2SE Runtime Environment 5.0 Update 6-->MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0150060}
J2SE Runtime Environment 5.0 Update 8-->MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0150080}
J2SE Runtime Environment 5.0 Update 9-->MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0150090}
Java 2 Runtime Environment, SE v1.4.2_03-->MsiExec.exe /I{7148F0A8-6813-11D6-A77B-00B0D0142030}
Java(TM) 6 Update 17-->MsiExec.exe /X{26A24AE4-039D-4CA4-87B4-2F83216017FF}
Java(TM) 6 Update 2-->MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0160020}
Java(TM) 6 Update 3-->MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0160030}
Java(TM) 6 Update 5-->MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0160050}
Java(TM) 6 Update 7-->MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0160070}
Java(TM) SE Runtime Environment 6 Update 1-->MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0160010}
Kwanzy 1.0 build 134-->C:\Program Files\Kwanzy\uninstall.exe
LiveReg (Symantec Corporation)-->C:\Program Files\Common Files\Symantec Shared\LiveReg\VCSetup.exe /REMOVE
LiveUpdate (Symantec Corporation)-->MsiExec.exe /x {E80F62FF-5D3C-4A19-8409-9721F2928206} /l*v "C:\Documents and Settings\All Users\Application Data\LuUninstall.LiveUpdate"
Logitech Desktop Messenger-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{900B1197-53F5-4F46-A882-2CFFFE2EEDCB}\setup.exe" -l0x9 UNINSTALL /L9
Logitech MouseWare 9.42 .1-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{5809E7CF-4DCF-11D4-9875-00105ACE7734}\setup.exe" -l0x9 -l0009 UNINSTALL
Logitech SetPoint-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\PROFES~1\RunTime\11\00\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{2E8EAC71-BFE4-417A-88F0-5A1BDFBCF5D3}\setup.exe" -l0x9  -removeonly
LSI PCI Soft Modem-->C:\WINDOWS\agrsmdel
McAfee SecurityCenter-->C:\Program Files\McAfee\MSC\mcuninst.exe
Microsoft .NET Framework 1.1 Security Update (KB953297)-->"C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\Updates\hotfix.exe" "C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\Updates\M953297\M953297Uninstall.msp"
Microsoft .NET Framework 1.1-->msiexec.exe /X {CB2F7EDD-9D1F-43C1-90FC-4F52EAE172A1}
Microsoft .NET Framework 2.0 Service Pack 2-->MsiExec.exe /I{C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F}
Microsoft .NET Framework 3.0 Service Pack 2-->MsiExec.exe /I{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}
Microsoft .NET Framework 3.5 SP1-->C:\WINDOWS\Microsoft.NET\Framework\v3.5\Microsoft .NET Framework 3.5 SP1\setup.exe
Microsoft Base Smart Card Cryptographic Service Provider Package-->"C:\WINDOWS\$NtUninstallbasecsp$\spuninst\spuninst.exe"
Microsoft Compression Client Pack 1.0 for Windows XP-->"C:\WINDOWS\$NtUninstallMSCompPackV1$\spuninst\spuninst.exe"
Microsoft Encarta Encyclopedia Standard 2005-->MsiExec.exe /I{05410044-64A6-4248-A026-9745C1E9E159}
Microsoft Internationalized Domain Names Mitigation APIs-->"C:\WINDOWS\$NtServicePackUninstallIDNMitigationAPIs$\spuninst\spuninst.exe"
Microsoft Money 2005-->C:\Program Files\Microsoft Money 2005\MNYCoreFiles\Setup\uninst.exe /s:120
Microsoft National Language Support Downlevel APIs-->"C:\WINDOWS\$NtServicePackUninstallNLSDownlevelMapping$\spuninst\spuninst.exe"
Microsoft Office XP Media Content-->MsiExec.exe /I{90300409-6000-11D3-8CFE-0050048383C9}
Microsoft Office XP Small Business-->MsiExec.exe /I{91130409-6000-11D3-8CFE-0050048383C9}
Microsoft Picture It! Premium 10-->"c:\Program Files\Common Files\Microsoft Shared\Picture It!\RmvSuite.exe" ADDREMOVE=1 SKU=PREM
Microsoft Plus! Digital Media Edition Installer-->MsiExec.exe /X{6E45BA47-383C-4C1E-8ED0-0D4845C293D7}
Microsoft Plus! Photo Story 2 LE-->MsiExec.exe /X{0EB5D9B7-8E6C-4A9E-B74F-16B7EE89A67B}
Microsoft Silverlight-->MsiExec.exe /I{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}
Microsoft Streets and Trips 2005-->MsiExec.exe /I{67E4EE98-59F4-4210-89A6-A20AF5BEC689}
Microsoft User-Mode Driver Framework Feature Pack 1.0-->"C:\WINDOWS\$NtUninstallWudf01000$\spuninst\spuninst.exe"
Microsoft Visual C++ 2005 ATL Update kb973923 - x86 8.0.50727.4053-->MsiExec.exe /X{770657D0-A123-3C07-8E44-1C83EC895118}
Microsoft Visual C++ 2005 Redistributable-->MsiExec.exe /X{7299052b-02a4-4627-81f2-1818da5d550d}
Microsoft Visual C++ 2008 ATL Update kb973924 - x86 9.0.30729.4148-->MsiExec.exe /X{002D9D5E-29BA-3E6D-9BC4-3D7D6DBC735C}
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17-->MsiExec.exe /X{9A25302D-30C0-39D9-BD6F-21E6EC160475}
Microsoft Word 2002-->MsiExec.exe /I{911B0409-6000-11D3-8CFE-0050048383C9}
Microsoft Works 2005 Setup Launcher-->C:\Program Files\Microsoft Works Suite 2005\Setup\Launcher.exe /ARP E:\
Microsoft Works-->MsiExec.exe /I{416D80BA-6F6D-4672-B7CF-F54DA2F80B44}
MSN-->C:\Program Files\MSN\MsnInstaller\msninst.exe /Action:ARP
MSXML 4.0 SP2 (KB925672)-->MsiExec.exe /I{A9CF9052-F4A0-475D-A00F-A8388C62DD63}
MSXML 4.0 SP2 (KB927978)-->MsiExec.exe /I{37477865-A3F1-4772-AD43-AAFC6BCFF99F}
MSXML 4.0 SP2 (KB936181)-->MsiExec.exe /I{C04E32E0-0416-434D-AFB9-6969D703A9EF}
MSXML 4.0 SP2 (KB954430)-->MsiExec.exe /I{86493ADD-824D-4B8E-BD72-8C5DCDC52A71}
MSXML 6.0 Parser (KB933579)-->MsiExec.exe /I{0A869A65-8C94-4F7C-A5C7-972D3C8CED9E}
Musicmatch® Jukebox-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{85D3CC30-8859-481A-9654-FD9B74310BEF}\setup.exe" -l0x9  -uninst
Musicnotes Player V1.22.2-->"C:\Program Files\Musicnotes\Player\unins000.exe"
muvee autoProducer 3.5 magicMoments - HPD-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\PROFES~1\RunTime\0701\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{B103C8A7-D1CC-4B1A-BD41-883F652E097D}\setup.exe" -l0x9
NetUtils-->C:\WINDOWS\IsUninst.exe -f"C:\Program Files\Century\TinyTERM\NetUtils\DeIsNetU.isu"
Nikon View 6-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{AAB84E83-C8DF-4752-9DFC-2E2A48EE5E9F}\setup.exe" UNINSTALL
Nuance OmniPage 17-->MsiExec.exe /I{34AFE453-F544-4269-89C9-CAB7F0744963}
Nuance PDF Professional 6-->MsiExec.exe /I{1093648B-1375-44BC-BC5E-39BF977D53FA}
Ofoto Print@Home ActiveX Control-->RunDll32 advpack.dll,LaunchINFSection C:\WINDOWS\Downloaded Program Files\axhomepr.inf, Uninstall
OGA Notifier 2.0.0048.0-->MsiExec.exe /I{B2544A03-10D0-4E5E-BA69-0362FFC20D18}
OLYMPUS CAMEDIA Master 2.01-->C:\WINDOWS\IsUninst.exe -f"C:\Program Files\OLYMPUS\CAMEDIA Master\Uninst.isu"
OmniForm 5.0-->MsiExec.exe /I{89DD6626-F35B-4989-9703-699E75129D0E}
OpenOffice.org Installer 1.0-->MsiExec.exe /X{0D499481-22C6-4B25-8AC2-6D3F6C885FB9}
PaperPort Image Printer-->MsiExec.exe /X{2BC2781A-F7F6-452E-95EB-018A522F1B2C}
PC-Doctor for Windows-->C:\Program Files\Common Files\InstallShield\Driver\8\Intel 32\IDriver.exe /M{0C66761E-497A-4BE3-AE0D-8EC30FC9A9AA} /l1033
PDR Electronic Library-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\PROFES~1\RunTime\10\50\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{09C2A345-0975-45FE-AF25-64C24A0592EA}\setup.exe" -l0x9  -removeonly
Photosmart 320,370,7400,8100,8400 Series-->C:\Program Files\HP\{AAC4FC36-8F89-4587-8DD3-EBC57C83374D}\setup\hpzscr01.exe -datfile hphscr01.dat
Picasa 3-->"C:\Program Files\Google\Picasa3\Uninstall.exe"
PS2-->C:\WINDOWS\system32\ps2.exe uninstall
Python 2.2 combined Win32 extensions-->C:\Python22\Lib\SITE-P~1\UNWISE~1.EXE C:\Python22\Lib\SITE-P~1\w32inst.log
Python 2.2.1-->C:\Python22\UNWISE.EXE C:\Python22\INSTALL.LOG
QuickTime-->MsiExec.exe /I{28BE306E-5DA6-4F9C-BDB0-DBA3C8C6FFFD}
RDM+ 3.7-->C:\Program Files\RDM+\rdmp_uninstall.exe
RealPlayer-->C:\Program Files\Common Files\Real\Update_OB\r1puninst.exe RealNetworks|RealPlayer|12.0
RealSpeakEnx-->MsiExec.exe /X{0585AFE2-148B-4184-BCFA-3980704E45D8}
Roxio Easy Media Creator 8 Suite-->MsiExec.exe /I{868901EE-7807-4F89-A134-7C705D34F91F}
Rt-Plot 2.5-->"C:\Program Files\Rt-Science\Rt-Plot\unins000.exe"
Safari-->MsiExec.exe /I{A67BB21E-D419-45BB-AB86-7D87D14BBCE2}
SBC Yahoo! DSL Activation-->C:\PROGRA~1\Yahoo!\common\undsldlk.exe
ScanSoft PaperPort 11-->MsiExec.exe /I{8EAA36CC-E2CA-44AA-B113-CD65FD0F3AC8}
Security Update for CAPICOM (KB931906)-->MsiExec.exe /I{0EFDF2F9-836D-4EB7-A32D-038BD3F1FB2A}
Security Update for CAPICOM (KB931906)-->MsiExec.exe /X{0EFDF2F9-836D-4EB7-A32D-038BD3F1FB2A}
Security Update for Step By Step Interactive Training (KB898458)-->"C:\WINDOWS\$NtUninstallKB898458$\spuninst\spuninst.exe"
Security Update for Step By Step Interactive Training (KB923723)-->"C:\WINDOWS\$NtUninstallKB923723$\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB928090)-->"C:\WINDOWS\ie7updates\KB928090-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB931768)-->"C:\WINDOWS\ie7updates\KB931768-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB933566)-->"C:\WINDOWS\ie7updates\KB933566-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB937143)-->"C:\WINDOWS\ie7updates\KB937143-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB938127)-->"C:\WINDOWS\ie7updates\KB938127-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB939653)-->"C:\WINDOWS\ie7updates\KB939653-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB942615)-->"C:\WINDOWS\ie7updates\KB942615-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB944533)-->"C:\WINDOWS\ie7updates\KB944533-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB950759)-->"C:\WINDOWS\ie7updates\KB950759-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB953838)-->"C:\WINDOWS\ie7updates\KB953838-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB956390)-->"C:\WINDOWS\ie7updates\KB956390-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB958215)-->"C:\WINDOWS\ie7updates\KB958215-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB960714)-->"C:\WINDOWS\ie7updates\KB960714-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB961260)-->"C:\WINDOWS\ie7updates\KB961260-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB963027)-->"C:\WINDOWS\ie7updates\KB963027-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB969897)-->"C:\WINDOWS\ie7updates\KB969897-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB972260)-->"C:\WINDOWS\ie7updates\KB972260-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB974455)-->"C:\WINDOWS\ie7updates\KB974455-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB976325)-->"C:\WINDOWS\ie7updates\KB976325-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 8 (KB971961)-->"C:\WINDOWS\ie8updates\KB971961-IE8\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 8 (KB976325)-->"C:\WINDOWS\ie8updates\KB976325-IE8\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 8 (KB978207)-->"C:\WINDOWS\ie8updates\KB978207-IE8\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 8 (KB981332)-->"C:\WINDOWS\ie8updates\KB981332-IE8\spuninst\spuninst.exe"
Security Update for Windows Media Player (KB952069)-->"C:\WINDOWS\$NtUninstallKB952069_WM9$\spuninst\spuninst.exe"
Security Update for Windows Media Player (KB954155)-->"C:\WINDOWS\$NtUninstallKB954155_WM9$\spuninst\spuninst.exe"
Security Update for Windows Media Player (KB968816)-->"C:\WINDOWS\$NtUninstallKB968816_WM9$\spuninst\spuninst.exe"
Security Update for Windows Media Player (KB973540)-->"C:\WINDOWS\$NtUninstallKB973540_WM9$\spuninst\spuninst.exe"
Security Update for Windows Media Player 10 (KB911565)-->"C:\WINDOWS\$NtUninstallKB911565$\spuninst\spuninst.exe"
Security Update for Windows Media Player 10 (KB917734)-->"C:\WINDOWS\$NtUninstallKB917734_WMP10$\spuninst\spuninst.exe"
Security Update for Windows Media Player 11 (KB936782)-->"C:\WINDOWS\$NtUninstallKB936782_WMP11$\spuninst\spuninst.exe"
Security Update for Windows Media Player 11 (KB954154)-->"C:\WINDOWS\$NtUninstallKB954154_WM11$\spuninst\spuninst.exe"
Security Update for Windows Search 4 - KB963093-->"C:\WINDOWS\$NtUninstallKB963093$\spuninst\spuninst.exe"
Security Update for Windows XP (KB923561)-->"C:\WINDOWS\$NtUninstallKB923561$\spuninst\spuninst.exe"
Security Update for Windows XP (KB938464)-->"C:\WINDOWS\$NtUninstallKB938464$\spuninst\spuninst.exe"
Security Update for Windows XP (KB941569)-->"C:\WINDOWS\$NtUninstallKB941569$\spuninst\spuninst.exe"
Security Update for Windows XP (KB946648)-->"C:\WINDOWS\$NtUninstallKB946648$\spuninst\spuninst.exe"
Security Update for Windows XP (KB950760)-->"C:\WINDOWS\$NtUninstallKB950760$\spuninst\spuninst.exe"
Security Update for Windows XP (KB950762)-->"C:\WINDOWS\$NtUninstallKB950762$\spuninst\spuninst.exe"
Security Update for Windows XP (KB950974)-->"C:\WINDOWS\$NtUninstallKB950974$\spuninst\spuninst.exe"
Security Update for Windows XP (KB951066)-->"C:\WINDOWS\$NtUninstallKB951066$\spuninst\spuninst.exe"
Security Update for Windows XP (KB951376)-->"C:\WINDOWS\$NtUninstallKB951376$\spuninst\spuninst.exe"
Security Update for Windows XP (KB951376-v2)-->"C:\WINDOWS\$NtUninstallKB951376-v2$\spuninst\spuninst.exe"
Security Update for Windows XP (KB951698)-->"C:\WINDOWS\$NtUninstallKB951698$\spuninst\spuninst.exe"
Security Update for Windows XP (KB951748)-->"C:\WINDOWS\$NtUninstallKB951748$\spuninst\spuninst.exe"
Security Update for Windows XP (KB952004)-->"C:\WINDOWS\$NtUninstallKB952004$\spuninst\spuninst.exe"
Security Update for Windows XP (KB952954)-->"C:\WINDOWS\$NtUninstallKB952954$\spuninst\spuninst.exe"
Security Update for Windows XP (KB953839)-->"C:\WINDOWS\$NtUninstallKB953839$\spuninst\spuninst.exe"
Security Update for Windows XP (KB954211)-->"C:\WINDOWS\$NtUninstallKB954211$\spuninst\spuninst.exe"
Security Update for Windows XP (KB954459)-->"C:\WINDOWS\$NtUninstallKB954459$\spuninst\spuninst.exe"
Security Update for Windows XP (KB954600)-->"C:\WINDOWS\$NtUninstallKB954600$\spuninst\spuninst.exe"
Security Update for Windows XP (KB955069)-->"C:\WINDOWS\$NtUninstallKB955069$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956391)-->"C:\WINDOWS\$NtUninstallKB956391$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956572)-->"C:\WINDOWS\$NtUninstallKB956572$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956744)-->"C:\WINDOWS\$NtUninstallKB956744$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956802)-->"C:\WINDOWS\$NtUninstallKB956802$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956803)-->"C:\WINDOWS\$NtUninstallKB956803$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956841)-->"C:\WINDOWS\$NtUninstallKB956841$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956844)-->"C:\WINDOWS\$NtUninstallKB956844$\spuninst\spuninst.exe"
Security Update for Windows XP (KB957095)-->"C:\WINDOWS\$NtUninstallKB957095$\spuninst\spuninst.exe"
Security Update for Windows XP (KB957097)-->"C:\WINDOWS\$NtUninstallKB957097$\spuninst\spuninst.exe"
Security Update for Windows XP (KB958644)-->"C:\WINDOWS\$NtUninstallKB958644$\spuninst\spuninst.exe"
Security Update for Windows XP (KB958687)-->"C:\WINDOWS\$NtUninstallKB958687$\spuninst\spuninst.exe"
Security Update for Windows XP (KB958690)-->"C:\WINDOWS\$NtUninstallKB958690$\spuninst\spuninst.exe"
Security Update for Windows XP (KB958869)-->"C:\WINDOWS\$NtUninstallKB958869$\spuninst\spuninst.exe"
Security Update for Windows XP (KB959426)-->"C:\WINDOWS\$NtUninstallKB959426$\spuninst\spuninst.exe"
Security Update for Windows XP (KB960225)-->"C:\WINDOWS\$NtUninstallKB960225$\spuninst\spuninst.exe"
Security Update for Windows XP (KB960715)-->"C:\WINDOWS\$NtUninstallKB960715$\spuninst\spuninst.exe"
Security Update for Windows XP (KB960803)-->"C:\WINDOWS\$NtUninstallKB960803$\spuninst\spuninst.exe"
Security Update for Windows XP (KB960859)-->"C:\WINDOWS\$NtUninstallKB960859$\spuninst\spuninst.exe"
Security Update for Windows XP (KB961371)-->"C:\WINDOWS\$NtUninstallKB961371$\spuninst\spuninst.exe"
Security Update for Windows XP (KB961373)-->"C:\WINDOWS\$NtUninstallKB961373$\spuninst\spuninst.exe"
Security Update for Windows XP (KB961501)-->"C:\WINDOWS\$NtUninstallKB961501$\spuninst\spuninst.exe"
Security Update for Windows XP (KB968537)-->"C:\WINDOWS\$NtUninstallKB968537$\spuninst\spuninst.exe"
Security Update for Windows XP (KB969059)-->"C:\WINDOWS\$NtUninstallKB969059$\spuninst\spuninst.exe"
Security Update for Windows XP (KB969898)-->"C:\WINDOWS\$NtUninstallKB969898$\spuninst\spuninst.exe"
Security Update for Windows XP (KB969947)-->"C:\WINDOWS\$NtUninstallKB969947$\spuninst\spuninst.exe"
Security Update for Windows XP (KB970238)-->"C:\WINDOWS\$NtUninstallKB970238$\spuninst\spuninst.exe"
Security Update for Windows XP (KB970430)-->"C:\WINDOWS\$NtUninstallKB970430$\spuninst\spuninst.exe"
Security Update for Windows XP (KB971468)-->"C:\WINDOWS\$NtUninstallKB971468$\spuninst\spuninst.exe"
Security Update for Windows XP (KB971486)-->"C:\WINDOWS\$NtUninstallKB971486$\spuninst\spuninst.exe"
Security Update for Windows XP (KB971557)-->"C:\WINDOWS\$NtUninstallKB971557$\spuninst\spuninst.exe"
Security Update for Windows XP (KB971633)-->"C:\WINDOWS\$NtUninstallKB971633$\spuninst\spuninst.exe"
Security Update for Windows XP (KB971657)-->"C:\WINDOWS\$NtUninstallKB971657$\spuninst\spuninst.exe"
Security Update for Windows XP (KB971961)-->"C:\WINDOWS\$NtUninstallKB971961$\spuninst\spuninst.exe"
Security Update for Windows XP (KB972270)-->"C:\WINDOWS\$NtUninstallKB972270$\spuninst\spuninst.exe"
Security Update for Windows XP (KB973346)-->"C:\WINDOWS\$NtUninstallKB973346$\spuninst\spuninst.exe"
Security Update for Windows XP (KB973354)-->"C:\WINDOWS\$NtUninstallKB973354$\spuninst\spuninst.exe"
Security Update for Windows XP (KB973507)-->"C:\WINDOWS\$NtUninstallKB973507$\spuninst\spuninst.exe"
Security Update for Windows XP (KB973525)-->"C:\WINDOWS\$NtUninstallKB973525$\spuninst\spuninst.exe"
Security Update for Windows XP (KB973869)-->"C:\WINDOWS\$NtUninstallKB973869$\spuninst\spuninst.exe"
Security Update for Windows XP (KB973904)-->"C:\WINDOWS\$NtUninstallKB973904$\spuninst\spuninst.exe"
Security Update for Windows XP (KB974112)-->"C:\WINDOWS\$NtUninstallKB974112$\spuninst\spuninst.exe"
Security Update for Windows XP (KB974318)-->"C:\WINDOWS\$NtUninstallKB974318$\spuninst\spuninst.exe"
Security Update for Windows XP (KB974392)-->"C:\WINDOWS\$NtUninstallKB974392$\spuninst\spuninst.exe"
Security Update for Windows XP (KB974571)-->"C:\WINDOWS\$NtUninstallKB974571$\spuninst\spuninst.exe"
Security Update for Windows XP (KB975025)-->"C:\WINDOWS\$NtUninstallKB975025$\spuninst\spuninst.exe"
Security Update for Windows XP (KB975467)-->"C:\WINDOWS\$NtUninstallKB975467$\spuninst\spuninst.exe"
Security Update for Windows XP (KB975560)-->"C:\WINDOWS\$NtUninstallKB975560$\spuninst\spuninst.exe"
Security Update for Windows XP (KB975561)-->"C:\WINDOWS\$NtUninstallKB975561$\spuninst\spuninst.exe"
Security Update for Windows XP (KB975713)-->"C:\WINDOWS\$NtUninstallKB975713$\spuninst\spuninst.exe"
Security Update for Windows XP (KB977165)-->"C:\WINDOWS\$NtUninstallKB977165$\spuninst\spuninst.exe"
Security Update for Windows XP (KB977816)-->"C:\WINDOWS\$NtUninstallKB977816$\spuninst\spuninst.exe"
Security Update for Windows XP (KB977914)-->"C:\WINDOWS\$NtUninstallKB977914$\spuninst\spuninst.exe"
Security Update for Windows XP (KB978037)-->"C:\WINDOWS\$NtUninstallKB978037$\spuninst\spuninst.exe"
Security Update for Windows XP (KB978251)-->"C:\WINDOWS\$NtUninstallKB978251$\spuninst\spuninst.exe"
Security Update for Windows XP (KB978262)-->"C:\WINDOWS\$NtUninstallKB978262$\spuninst\spuninst.exe"
Security Update for Windows XP (KB978338)-->"C:\WINDOWS\$NtUninstallKB978338$\spuninst\spuninst.exe"
Security Update for Windows XP (KB978601)-->"C:\WINDOWS\$NtUninstallKB978601$\spuninst\spuninst.exe"
Security Update for Windows XP (KB978706)-->"C:\WINDOWS\$NtUninstallKB978706$\spuninst\spuninst.exe"
Security Update for Windows XP (KB979309)-->"C:\WINDOWS\$NtUninstallKB979309$\spuninst\spuninst.exe"
Security Update for Windows XP (KB979683)-->"C:\WINDOWS\$NtUninstallKB979683$\spuninst\spuninst.exe"
Security Update for Windows XP (KB980232)-->"C:\WINDOWS\$NtUninstallKB980232$\spuninst\spuninst.exe"
Shockwave-->C:\WINDOWS\system32\Macromed\SHOCKW~1\UNWISE.EXE C:\WINDOWS\system32\Macromed\SHOCKW~1\Install.log
Sibelius Scorch (ActiveX Only)-->MsiExec.exe /I{15CCBC5D-66A7-4131-8D36-E05F27B0E68F}
Sibelius Scorch (Firefox, Opera, Netscape only)-->MsiExec.exe /I{5F4B558D-8AEB-4DEE-AAB3-C00D1D9A86BA}
Sibelius Scorch Plugin-->"C:\Program Files\Musicnotes\uninstsc.exe"
Sonic Express Labeler-->MsiExec.exe /I{6675CA7F-E51B-4F6A-99D4-F8F0124C6EAA}
Sonic RecordNow!-->MsiExec.exe /I{9541FED0-327F-4DF0-8B96-EF57EF622F19}
Sound Blaster Audigy 2 ZS-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{A9FC3677-D5CD-4169-B78A-297D541EEB36}\Setup.exe" -l0x9
Steinberg Cubase LE-->"C:\Program Files\Steinberg\Cubase LE\Uninstall.exe" "C:\Program Files\Steinberg\Cubase LE\Install.log"
Symantec WinFax PRO 10.01-->C:\WINDOWS\IsUninst.exe -f"C:\Program Files\WinFax\WFXUNIST.ISU" -c"C:\Program Files\WinFax\UNINSTUB.DLL"
TinyTERM Plus Edition-->C:\Program Files\Century\TinyTERM\rem.exe PL2 C:\WINDOWS\IsUninst.exe -f"C:\Program Files\Century\TinyTERM\DeIsWpl.isu"
Trend Micro Anti-Spyware-->C:\Program Files\Trend Micro\Tmas\tmas.exe -uninstall
Update for Microsoft Windows (KB971513)-->"C:\WINDOWS\$NtUninstallKB971513$\spuninst\spuninst.exe"
Update for Windows Internet Explorer 7 (KB976749)-->"C:\WINDOWS\ie7updates\KB976749-IE7\spuninst\spuninst.exe"
Update for Windows Internet Explorer 8 (KB975364)-->"C:\WINDOWS\ie8updates\KB975364-IE8\spuninst\spuninst.exe"
Update for Windows Internet Explorer 8 (KB976662)-->"C:\WINDOWS\ie8updates\KB976662-IE8\spuninst\spuninst.exe"
Update for Windows Internet Explorer 8 (KB980182)-->"C:\WINDOWS\ie8updates\KB980182-IE8\spuninst\spuninst.exe"
Update for Windows XP (KB951072-v2)-->"C:\WINDOWS\$NtUninstallKB951072-v2$\spuninst\spuninst.exe"
Update for Windows XP (KB951978)-->"C:\WINDOWS\$NtUninstallKB951978$\spuninst\spuninst.exe"
Update for Windows XP (KB955759)-->"C:\WINDOWS\$NtUninstallKB955759$\spuninst\spuninst.exe"
Update for Windows XP (KB955839)-->"C:\WINDOWS\$NtUninstallKB955839$\spuninst\spuninst.exe"
Update for Windows XP (KB967715)-->"C:\WINDOWS\$NtUninstallKB967715$\spuninst\spuninst.exe"
Update for Windows XP (KB968389)-->"C:\WINDOWS\$NtUninstallKB968389$\spuninst\spuninst.exe"
Update for Windows XP (KB971737)-->"C:\WINDOWS\$NtUninstallKB971737$\spuninst\spuninst.exe"
Update for Windows XP (KB973687)-->"C:\WINDOWS\$NtUninstallKB973687$\spuninst\spuninst.exe"
Update for Windows XP (KB973815)-->"C:\WINDOWS\$NtUninstallKB973815$\spuninst\spuninst.exe"
Updates from HP-->C:\WINDOWS\BWUnin-6.3.2.62.exe -AppId 309731
Visual C++ Runtime for Dragon NaturallySpeaking-->MsiExec.exe /I{4A5A427F-BA39-4BF0-9A47-9999FBE60C9F}
Windows Imaging Component-->"C:\WINDOWS\$NtUninstallWIC$\spuninst\spuninst.exe"
Windows Internet Explorer 8-->"C:\WINDOWS\ie8\spuninst\spuninst.exe"
Windows Media Format 11 runtime-->"C:\Program Files\Windows Media Player\wmsetsdk.exe" /UninstallAll
Windows Media Format 11 runtime-->"C:\WINDOWS\$NtUninstallWMFDist11$\spuninst\spuninst.exe"
Windows Media Player 11-->"C:\Program Files\Windows Media Player\Setup_wm.exe" /Uninstall
Windows Media Player 11-->"C:\WINDOWS\$NtUninstallwmp11$\spuninst\spuninst.exe"
Windows PowerShell(TM) 1.0-->"C:\WINDOWS\$NtUninstallKB926139-v2$\spuninst\spuninst.exe"
Windows Presentation Foundation-->MsiExec.exe /X{BAF78226-3200-4DB4-BE33-4D922A799840}
Windows Search 4.0-->"C:\WINDOWS\$NtUninstallKB940157$\spuninst\spuninst.exe"
Windows XP Service Pack 3-->"C:\WINDOWS\$NtServicePackUninstall$\spuninst\spuninst.exe"
======Security center information======
AV: McAfee VirusScan
FW: McAfee Personal Firewall
======System event log======
Computer Name: HP850
Event Code: 10021
Message: The launch and activation security descriptor for the COM Server application with CLSID
{17EAB2A0-70E2-11CE-A7FB-008029E0ABE9}
is invalid. It contains Access Control Entries with permissions that are invalid. The requested action was therefore not performed. This security permission can be corrected using the Component Services administrative tool.
Record Number: 219943
Source Name: DCOM
Time Written: 20100504095707.000000-420
Event Type: error
User:
Event Code: 8
Message: Printer Go To My PC was purged.
Record Number: 219942
Source Name: Print
Time Written: 20100504095626.000000-420
Event Type: warning
User: NT AUTHORITY\SYSTEM
Event Code: 8
Message: Printer GoToMyPC - EPSON Stylus Photo 800 was purged.
Record Number: 219941
Source Name: Print
Event Type: warning
Event Code: 8
Message: Printer GoToMyPC - HP LaserJet 4100 Series PS was purged.
Record Number: 219940
Source Name: Print
Event Type: warning
Event Code: 8
Message: Printer ScanSoft PDF Create! was purged.
Record Number: 219805
Source Name: Print
Time Written: 20100504082116.000000-420
Event Type: warning
User: HP850\HP_Administrator
Event Code: 5051
Message: A thread in process C:\PROGRA~1\McAfee\VIRUSS~1\mcshield.exe took longer than 90000 ms to complete a request.
The process will be terminated.
Thread id : 5196 (0x144c)
Thread address : 0x7C90E514
Thread message :
Build VSCORE.14.0.0.435 / 5301.4018
Object being scanned = \Device\HarddiskVolume2\Documents and Settings\HP_Administrator\My Documents\Downloads\DragonPreferred10.1ENX_078.exe
by C:\WINDOWS\Explorer.EXE
4(0)(0)
4(0)(0)
7200(0)(0)
7595(0)(0)
7005(0)(0)
7004(0)(0)
5006(0)(0)
5004(0)(0)
Record Number: 120128
Source Name: McLogEvent
Time Written: 20100224125941.000000-480
Event Type: error
Event Code: 1002
Message: Hanging application WINWORD.EXE, version 10.0.6856.0, hang module hungapp, version 0.0.0.0, hang address 0x00000000.
Record Number: 120126
Source Name: Application Hang
Time Written: 20100224125152.000000-480
Event Type: error
User:
Event Code: 5051
Thread id : 3088 (0xc10)
Thread message :
4(0)(0)
4(0)(0)
7200(0)(0)
7595(0)(0)
7005(0)(0)
7004(0)(0)
5006(0)(0)
5004(0)(0)
Record Number: 120125
Time Written: 20100224125136.000000-480
Event Type: error
Event Code: 1002
Message: Hanging application FileMaker Pro Advanced.exe, version 8.0.3.349, hang module hungapp, version 0.0.0.0, hang address 0x00000000.
Record Number: 120118
Time Written: 20100224100544.000000-480
Event Type: error
User:
Event Code: 2570
Message: Adobe Active File Monitor Service has Started.
Record Number: 120097
Source Name: Adobe Active File Monitor 5.0
Time Written: 20100224095859.000000-480
Event Type:
User:
"Path"=C:\Program Files\Common Files\ArcSoft\Bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;c:\Python22;C:\Program Files\PC-Doctor for Windows\;C:\Program Files\ATI Technologies\ATI Control Panel;C:\PROGRA~1\COMMON~1\Odbc\FILEMA~1;C:\Program Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Common Files\Adobe\AGL;C:\WINDOWS\system32\WindowsPowerShell\v1.0;C:\Program Files\QuickTime\QTSystem\
"windir"=%SystemRoot%
"FP_NO_HOST_CHECK"=NO
"OS"=Windows_NT
"PROCESSOR_ARCHITECTURE"=x86
"PROCESSOR_LEVEL"=15
"PROCESSOR_IDENTIFIER"=x86 Family 15 Model 4 Stepping 1, GenuineIntel
"PROCESSOR_REVISION"=0401
"NUMBER_OF_PROCESSORS"=2
"PATHEXT"=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PSC1
"TEMP"=%SystemRoot%\TEMP
"TMP"=%SystemRoot%\TEMP
"RoxioCentral"=C:\Program Files\Common Files\Roxio Shared\Roxio Central\
"asl.log"=Destination=file;OnFirstLog=command,environment
"CLASSPATH"=.;C:\Program Files\Java\jre6\lib\ext\QTJava.zip
"QTJAVA"=C:\Program Files\Java\jre6\lib\ext\QTJava.zip
Hi, bdemuth.
I've posted your RSIT logs.  Please copy/paste requested logs with your replies rather than attaching.
Thanks!
bdemuth
Here's my "MBAM" report.  Unfortunately, I could not get the GMER to work. Several HOURS into the scan, my computer shut dow..  Was in the middle of the night, so I don't know what immediately preceded the failure.  Sorry.
Malwarebytes' Anti-Malware 1.46
www.malwarebytes.org
Database version: 4083
Windows 5.1.2600 Service Pack 3
5/9/2010 12:32:08 PM
mbam-log-2010-05-09 (12-32-08).txt
Scan type: Quick scan
Objects scanned: 142024
Time elapsed: 37 minute(s), 55 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 6
Registry Values Infected: 1
Registry Data Items Infected: 5
Folders Infected: 3
Files Infected: 5
(No malicious items detected)
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{42f2c9ba-614f-47c0-b3e3-ecfd34eed658} (Adware.ISTBar) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\IEBarProperties (Adware.Mirar) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Kwanzy (Adware.Kwanzy) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\kwanzy (Adware.Kwanzy) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\install.exe (Trojan.Dropper) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\MediaHoldings (Malware.Trace) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\wheresphere (Adware.WhereSphere) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Main\Start Page (Hijack.StartPage) -> Bad: (http://home.adbsearch.com/) Good: (http://www.google.com) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\Search Bar (Hijack.SearchPage) -> Bad: (http://www.mirarsearch.com/?useie5=1&q=) Good: (http://www.google.com) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Main\Search Bar (Hijack.SearchPage) -> Bad: (http://www.mirarsearch.com/?useie5=1&q=) Good: (http://www.google.com) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\AntiVirusDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\FirewallDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
Folders Infected:
C:\Documents and Settings\HP_Administrator\Application Data\WhereSphere (Adware.WhereSphere) -> Quarantined and deleted successfully.
C:\Program Files\Kwanzy (Adware.Kwanzy) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\Kwanzy (Adware.Kwanzy) -> Quarantined and deleted successfully.
Files Infected:
C:\Downloads\SpyInstall.exe (Trojan.Dropper) -> Quarantined and deleted successfully.
C:\Documents and Settings\HP_Administrator\Application Data\WhereSphere\config.cfg (Adware.WhereSphere) -> Quarantined and deleted successfully.
C:\Documents and Settings\HP_Administrator\Application Data\WhereSphere\WSUninstall.exe (Adware.WhereSphere) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Desktop\Streaming Music - MediaPass.lnk (Adware.Trace) -> Quarantined and deleted successfully.
C:\Documents and Settings\HP_Administrator\install.exe (Trojan.Dropper) -> Quarantined and deleted successfully.
sjb007
Hi bdemuth
Please re-run GMER, this time just check the boxes beside "sections" and the C:\ drive, leave everything else blank.
Please download and scan with ComboFix.exe. Please visit this web page for download links, and instructions for running the tool:
http://www.bleepingcomputer.com/combofix/how-to-use-combofix
Please ensure you install the recovery console if requested
Ensure you have disabled all anti virus and anti malware programs so they do not interfere with the running of ComboFix.
Please include the C:\ComboFix.txt in your next reply for further review and the GMER log if successful.
bdemuth
ComboFix.txt follows; then gmer.txt after the break:
ComboFix 10-05-09.04 - HP_Administrator 05/09/2010  20:34:17.1.2 - x86
Microsoft Windows XP Professional  5.1.2600.3.1252.1.1033.18.2047.1326 [GMT -7:00]
Running from: c:\documents and settings\HP_Administrator\My Documents\Downloads\ComboFix.exe
AV: McAfee VirusScan *On-access scanning enabled* (Updated) {84B5EE75-6421-4CDE-A33A-DD43BA9FAD83}
FW: McAfee Personal Firewall *disabled* {94894B63-8C7F-4050-BDA4-813CA00DA3E8}
c:\docume~1\HP_ADM~1\LOCALS~1\Temp\IadHide5.dll
c:\documents and settings\HP_Administrator\GoToAssistDownloadHelper.exe
c:\documents and settings\HP_Administrator\Local Settings\Temp\IadHide5.dll
C:\Thumbs.db
c:\windows\patch.exe
c:\windows\system32\Vb40032.dll
D:\Autorun.inf
c:\windows\system32\gotomon.log . . . . failed to delete
(((((((((((((((((((((((((((((((((((((((   Drivers/Services   )))))))))))))))))))))))))))))))))))))))))))))))))
-------\Legacy_IPRIP
-------\Service_Iprip
(((((((((((((((((((((((((   Files Created from 2010-04-10 to 2010-05-10  )))))))))))))))))))))))))))))))
2010-05-09 17:33 . 2010-05-09 17:33   --------   d-----w-   c:\documents and settings\HP_Administrator\Application Data\Malwarebytes
2010-05-09 17:33 . 2010-04-29 22:39   38224   ----a-w-   c:\windows\system32\drivers\mbamswissarmy.sys
2010-05-09 17:33 . 2010-05-09 17:33   --------   d-----w-   c:\documents and settings\All Users\Application Data\Malwarebytes
2010-05-09 17:33 . 2010-05-09 17:33   --------   d-----w-   c:\program files\Malwarebytes' Anti-Malware
2010-05-09 17:33 . 2010-04-29 22:39   20952   ----a-w-   c:\windows\system32\drivers\mbam.sys
2010-05-06 15:30 . 2010-05-06 15:30   --------   d-----w-   c:\documents and settings\HP_Administrator\Local Settings\Application Data\Zeon
2010-05-04 17:06 . 2010-05-04 17:31   --------   d-----w-   C:\rsit
2010-05-04 17:03 . 2010-05-04 17:03   --------   d-----w-   c:\program files\ERUNT
2010-05-04 15:16 . 2010-05-04 15:16   --------   d-----w-   c:\program files\iPod
2010-05-04 15:16 . 2010-05-04 15:18   --------   d-----w-   c:\program files\iTunes
2010-05-04 15:00 . 2010-05-04 15:00   --------   d-----w-   c:\program files\Bonjour
2010-05-03 20:21 . 2010-05-04 15:27   --------   d-----w-   c:\program files\AutoReceive
2010-05-03 20:21 . 2010-05-03 20:22   --------   d--h--w-   c:\program files\Zero G Registry
2010-05-03 20:21 . 2010-05-03 20:21   --------   d--h--w-   c:\documents and settings\HP_Administrator\InstallAnywhere
2010-05-03 19:41 . 2010-05-03 19:41   --------   d-----w-   c:\windows\system32\Adobe
2010-05-03 19:40 . 2010-05-03 19:41   --------   d-----w-   c:\program files\WebEx
2010-05-03 19:40 . 2010-05-03 19:40   --------   d-----w-   c:\documents and settings\All Users\Quest
2010-04-14 15:09 . 2010-04-14 15:11   --------   d-----w-   c:\documents and settings\All Users\Application Data\{429CAD59-35B1-4DBC-BB6D-1DB246563521}
2010-05-10 03:44 . 2008-09-09 18:10   --------   d---a-w-   c:\documents and settings\All Users\Application Data\TEMP
2010-05-09 20:16 . 2007-01-25 20:34   --------   d-----w-   c:\program files\Google
2010-05-07 14:14 . 2005-01-04 22:51   --------   d-----w-   c:\program files\WinFax
2010-05-06 14:10 . 2007-02-09 01:10   4675   ----a-w-   c:\documents and settings\HP_Administrator\Application Data\SAS7_000.DAT
2010-05-04 17:07 . 2005-11-04 23:42   --------   d-----w-   c:\program files\Trend Micro
2010-05-04 15:16 . 2007-07-02 17:52   --------   d-----w-   c:\program files\Common Files\Apple
2010-05-04 14:53 . 2010-05-04 14:53   73000   ----a-w-   c:\documents and settings\All Users\Application Data\Apple Computer\Installer Cache\iTunes 9.1.1.12\SetupAdmin.exe
2010-05-03 19:41 . 2005-01-06 16:58   --------   d-----w-   c:\program files\Common Files\Adobe
2010-04-14 15:05 . 2008-04-06 20:53   --------   d-----w-   c:\program files\QuickTime
2010-04-08 20:20 . 2010-04-08 20:20   91424   ----a-w-   c:\windows\system32\dnssd.dll
2010-04-08 20:20 . 2010-04-08 20:20   107808   ----a-w-   c:\windows\system32\dns-sd.exe
2010-04-06 14:07 . 2007-03-12 17:42   --------   d-----w-   c:\documents and settings\NetworkService\Application Data\Nuance
2010-04-02 20:48 . 2009-12-29 01:52   --------   d-----w-   c:\program files\McAfee
2010-03-31 21:17 . 2005-01-05 20:55   --------   d--h--w-   c:\documents and settings\HP_Administrator\Application Data\Yahoo!
2010-03-19 14:01 . 2005-03-01 16:18   --------   d-----w-   c:\program files\Quicken
2010-03-17 15:22 . 2008-03-22 16:32   --------   d-----w-   c:\program files\Safari
2010-03-17 15:16 . 2010-03-17 15:16   79144   ----a-w-   c:\documents and settings\All Users\Application Data\Apple Computer\Installer Cache\Safari 5.31.22.7\SetupAdmin.exe
2010-03-15 21:05 . 2009-07-09 00:57   --------   d--h--w-   c:\documents and settings\HP_Administrator\Application Data\.oit
2010-03-10 06:15 . 2004-11-29 15:58   420352   ----a-w-   c:\windows\system32\vbscript.dll
2010-03-05 19:25 . 2010-03-05 04:00   120616   ----a-w-   c:\windows\system32\GDIPFONTCACHEV1.DAT
2010-02-25 06:24 . 2005-01-04 22:52   916480   ----a-w-   c:\windows\system32\wininet.dll
2010-02-24 13:11 . 2004-11-29 16:54   455680   ----a-w-   c:\windows\system32\drivers\mrxsmb.sys
2010-02-22 20:34 . 2004-10-28 19:55   3645   -c--a-w-   c:\windows\viassary-hp.reg
2010-02-22 15:03 . 2010-02-22 15:58   193588   ----a-w-   c:\windows\pchealth\helpctr\Config\Cache\Professional_32_1033.dat
2010-02-16 14:08 . 2004-11-29 15:56   2146304   ----a-w-   c:\windows\system32\ntoskrnl.exe
2010-02-16 13:25 . 2004-08-04 05:59   2024448   ----a-w-   c:\windows\system32\ntkrnlpa.exe
2010-02-12 04:33 . 2004-11-29 16:52   100864   ----a-w-   c:\windows\system32\6to4svc.dll
2010-02-11 12:02 . 2004-11-29 15:58   226880   ----a-w-   c:\windows\system32\drivers\tcpip6.sys
2010-02-09 18:50 . 2010-02-09 18:50   34   ----a-w-   c:\windows\system32\bd407cdw.dat
2005-02-09 17:21 . 2005-02-09 17:21   0   -csha-w-   c:\windows\SMINST\HPCD.sys
REGEDIT4
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2007-06-16 68856]
"AGRSMMSG"="AGRSMMSG.exe" [2005-03-04 88209]
"PrinTray"="c:\windows\System32\spool\DRIVERS\W32X86\2\printray.exe" [2000-06-07 36864]
"LXSUPMON"="c:\windows\system32\LXSUPMON.EXE" [2000-06-07 794112]
"Logitech Hardware Abstraction Layer"="KHALMNPR.EXE" [2005-07-23 28160]
"ISUSPM Startup"="c:\progra~1\COMMON~1\INSTAL~1\UPDATE~1\ISUSPM.exe" [2005-02-17 221184]
"KBD"="c:\hp\KBD\KBD.EXE" [2005-02-03 61440]
"DNS7reminder"="c:\program files\Nuance\NaturallySpeaking10\Ereg\Ereg.exe" [2007-04-16 259624]
"ArcSoft Connection Service"="c:\program files\Common Files\ArcSoft\Connection Service\Bin\ACDaemon.exe" [2008-04-17 98616]
"CTHelper"="CTHELPER.EXE" [2007-04-09 19456]
"Nuance OmniPage 17-reminder"="c:\program files\Nuance\OmniPage17\Ereg\Ereg.exe" [2008-11-03 54560]
"PaperPort PTD"="c:\program files\ScanSoft\PaperPort\pptd40nt.exe" [2008-05-10 29984]
"IndexSearch"="c:\program files\ScanSoft\PaperPort\IndexSearch.exe" [2008-05-10 46368]
"PPort11reminder"="c:\program files\ScanSoft\PaperPort\Ereg\Ereg.exe" [2007-08-31 328992]
"SunJavaUpdateSched"="c:\program files\Java\j2re1.4.2_03\bin\jusched.exe" [2004-10-28 32881]
"Symantec PIF AlertEng"="c:\program files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PifSvc.exe" [2007-11-29 583048]
"mcagent_exe"="c:\program files\McAfee.com\Agent\mcagent.exe" [2009-10-29 1218008]
"McENUI"="c:\progra~1\McAfee\MHN\McENUI.exe" [2009-07-08 1176808]
"Google Desktop Search"="c:\program files\Google\Google Desktop Search\GoogleDesktop.exe" [2009-12-30 30192]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2010-04-04 36272]
"Adobe ARM"="c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2010-03-24 952768]
"YBrowser"="c:\progra~1\Yahoo!\browser\ybrwicon.exe" [2006-07-22 129536]
"WinFaxAppPortStarter"="wfxsnt40.exe" [2000-09-29 43008]
"UpdReg"="c:\windows\UpdReg.EXE" [2000-05-11 90112]
"Recguard"="c:\windows\SMINST\RECGUARD.EXE" [2004-04-15 233472]
"PS2"="c:\windows\system32\ps2.exe" [2002-10-16 81920]
"IPInSightMonitor 01"="c:\program files\SBC Yahoo!\Connection Manager\IP InSight\IPMon32.exe" [2003-07-14 98304]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2004-08-21 155648]
"hpsysdrv"="c:\windows\system\hpsysdrv.exe" [1998-05-07 52736]
"HPHUPD06"="c:\program files\HP\{AAC4FC36-8F89-4587-8DD3-EBC57C83374D}\hphupd06.exe" [2004-06-08 49152]
"HPHmon06"="c:\windows\system32\hphmon06.exe" [2004-06-08 659456]
"HPDJ Taskbar Utility"="c:\windows\system32\spool\drivers\w32x86\3\hpztsb04.exe" [2001-12-10 196608]
"HP Software Update"="c:\program files\HP\HP Software Update\HPWuSchd2.exe" [2005-09-24 49152]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2004-08-21 118784]
"EM_EXEC"="c:\progra~1\Logitech\MOUSEW~1\SYSTEM\EM_EXEC.EXE" [2001-12-20 35328]
"CTDVDDET"="c:\program files\Creative\SBAudigy2ZS\DVDAudio\CTDVDDet.EXE" [2003-06-18 45056]
"BJCFD"="c:\program files\BroadJump\Client Foundation\CFD.exe" [2002-09-11 368706]
"ATIPTA"="c:\program files\ATI Technologies\ATI Control Panel\atiptaxx.exe" [2004-09-10 344064]
"AlcxMonitor"="ALCXMNTR.EXE" [2004-09-08 57344]
"AlcWzrd"="ALCWZRD.EXE" [2004-07-29 2551808]
"Adobe Photo Downloader"="c:\program files\Adobe\Photoshop Elements 5.0\apdproxy.exe" [2006-09-14 61440]
"TkBellExe"="c:\program files\Common Files\Real\Update_OB\realsched.exe" [2010-02-05 198160]
"PDFHook"="c:\program files\Nuance\PDF Professional 6\pdfpro6hook.exe" [2009-07-27 1275168]
"PDF6 Registry Controller"="c:\program files\Nuance\PDF Professional 6\RegistryController.exe" [2009-07-27 110880]
"Nuance PDF Professional 6-reminder"="c:\program files\Nuance\PDF Professional 6\Ereg\Ereg.exe" [2008-11-03 54560]
"Nuance.ctfmngr"="c:\program files\Nuance\NaturallySpeaking10\Program\ctfmngr.exe" [2009-03-17 50536]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2010-03-18 421888]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2010-04-28 142120]
"SetDefaultMIDI"="MIDIDEF.EXE" [2003-06-21 49152]
"StartMS"="c:\program files\Creative\Shared Files\Media Sniffer\StartMS.EXE" [2003-03-26 57344]
"CMSRegOW.exe"="c:\program files\InstallShield Installation Information\{56F3E1FF-54FE-4384-A153-6CCABA097814}\CMSRegOW.exe" [2003-06-16 57344]
"RealUpgradeHelper"="c:\program files\Common Files\Real\Update_OB\upgrdhlp.exe" [2010-02-05 136744]
c:\documents and settings\HP_Administrator\Start Menu\Programs\Startup\
PowerReg SchedulerV2.exe [2004-12-27 256000]
Adobe Gamma Loader.lnk - c:\program files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe [2005-1-10 113664]
Controller.LNK - c:\program files\WinFax\WFXCTL32.EXE [2005-1-12 542208]
HP Digital Imaging Monitor.lnk - c:\program files\HP\Digital Imaging\bin\hpqtra08.exe [2005-9-24 282624]
HP Photosmart Premier Fast Start.lnk - c:\program files\HP\Digital Imaging\bin\hpqthb08.exe [2005-9-24 73728]
Logitech Desktop Messenger.lnk - c:\program files\Desktop Messenger\8876480\Program\LDMConf.exe [2005-1-19 156160]
Logitech SetPoint.lnk - c:\program files\Logitech\SetPoint\SetPoint.exe [2006-1-11 528384]
Updates from HP.lnk - c:\program files\Updates from HP\309731\Program\Updates from HP.exe [2004-10-28 45056]
Windows Search.lnk - c:\program files\Windows Desktop Search\WindowsSearch.exe [2008-5-26 123904]
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\policies\explorer]
"NoDevMgrUpdate"= 1 (0x1)
"{A213B520-C6C2-11d0-AF9D-008029E1027E}"= "c:\program files\WinFax\WfxSeh32.Dll" [1998-07-27 38400]
"{03A80B1D-5C6A-42c2-9DFB-81B6005D8023}"= "c:\program files\Trend Micro\Tmas\sshook.dll" [2005-11-04 77824]
"{56F9679E-7826-4C84-81F3-532071A8BCC5}"= "c:\program files\Windows Desktop Search\MSNLNamespaceMgr.dll" [2009-05-25 304128]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\GoToMyPC]
2009-12-16 02:13   15216   ----a-w-   c:\program files\Citrix\GoToMyPC\G2WinLogon.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\RDM+]
2008-04-13 11:43   61440   ----a-w-   c:\program files\RDM+\notify.dll
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\mcmscsvc]
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HotSync Manager.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\HotSync Manager.lnk
backup=c:\windows\pss\HotSync Manager.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HOTSYNCSHORTCUTNAME.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\HOTSYNCSHORTCUTNAME.lnk
backup=c:\windows\pss\HOTSYNCSHORTCUTNAME.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Microsoft Office.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Microsoft Office.lnk
backup=c:\windows\pss\Microsoft Office.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^NkbMonitor.exe.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\NkbMonitor.exe.lnk
backup=c:\windows\pss\NkbMonitor.exe.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^NkvMon.exe.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\NkvMon.exe.lnk
backup=c:\windows\pss\NkvMon.exe.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Trend Micro Anti-Spyware.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Trend Micro Anti-Spyware.lnk
backup=c:\windows\pss\Trend Micro Anti-Spyware.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Yahoo! Autosync.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Yahoo! Autosync.lnk
backup=c:\windows\pss\Yahoo! Autosync.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^ymetray.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\ymetray.lnk
backup=c:\windows\pss\ymetray.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^HP_Administrator^Start Menu^Programs^Startup^Adobe Gamma.lnk]
path=c:\documents and settings\HP_Administrator\Start Menu\Programs\Startup\Adobe Gamma.lnk
backup=c:\windows\pss\Adobe Gamma.lnkStartup
[HKLM\~\startupfolder\C:^Documents and Settings^HP_Administrator^Start Menu^Programs^Startup^HotSync Manager.lnk]
path=c:\documents and settings\HP_Administrator\Start Menu\Programs\Startup\HotSync Manager.lnk
backup=c:\windows\pss\HotSync Manager.lnkStartup
[HKLM\~\startupfolder\C:^Documents and Settings^HP_Administrator^Start Menu^Programs^Startup^HP Organize.lnk]
path=c:\documents and settings\HP_Administrator\Start Menu\Programs\Startup\HP Organize.lnk
backup=c:\windows\pss\HP Organize.lnkStartup
2010-04-28 22:06   142120   ----a-w-   c:\program files\iTunes\iTunesHelper.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\LSBWatcher]
2004-10-15 04:54   253952   -c--a-w-   c:\hp\drivers\hplsbwatcher\LSBurnWatcher.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MimBoot]
2006-11-07 23:41   8192   -c--a-w-   c:\progra~1\MUSICM~1\MUSICM~1\mimboot.exe
2010-03-18 04:53   421888   ----a-w-   c:\program files\QuickTime\QTTask.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\RoxioDragToDisc]
2005-11-22 04:47   1687552   ----a-w-   c:\program files\Roxio\Easy Media Creator 8\Drag to Disc\DrgToDsc.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\RoxWatchTray]
2005-11-22 16:34   163840   ----a-w-   c:\program files\Common Files\Roxio Shared\SharedCOM8\RoxWatchTray.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SSBkgdUpdate]
2006-10-25 16:03   210472   ----a-w-   c:\program files\Common Files\ScanSoft Shared\SSBkgdUpdate\SSBkgdUpdate.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Yahoo! Pager]
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring]
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\McAfeeAntiVirus]
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\McAfeeFirewall]
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\SymantecAntiVirus]
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\SymantecFirewall]
"EnableFirewall"= 0 (0x0)
"c:\\Program Files\\Updates from HP\\309731\\Program\\Updates from HP.exe"=
"c:\\Program Files\\Messenger\\msmsgs.exe"=
"c:\\Program Files\\Common Files\\McAfee\\MNA\\McNASvc.exe"=
"c:\\Program Files\\Roxio\\Easy Media Creator 8\\Digital Home\\RoxUpnpServer.exe"=
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]
"3587:TCP"= 3587:TCP:Windows Peer-to-Peer Grouping
"3540:UDP"= 3540:UDP:Peer Name Resolution Protocol (PNRP)
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\IcmpSettings]
"AllowInboundEchoRequest"= 1 (0x1)
R2 BCMNTIO;BCMNTIO;c:\progra~1\CheckIt\DIAGNO~1\BCMNTIO.sys [2/2/2007 3:22 PM 3744]
R2 MAPMEM;MAPMEM;c:\progra~1\CheckIt\DIAGNO~1\MAPMEM.sys [2/2/2007 3:22 PM 3904]
R2 McAfee SiteAdvisor Service;McAfee SiteAdvisor Service;c:\program files\McAfee\SiteAdvisor\McSACore.exe [12/28/2009 6:57 PM 93320]
R2 PDFProFiltSrv;PDFProFiltSrv;c:\program files\Nuance\PDF Professional 6\PDFProFiltSrv.exe [7/27/2009 3:15 AM 134944]
R2 RDMPLocalService;RDM+ Local Service;c:\program files\RDM+\rdmpserv.exe [7/1/2008 4:44 AM 849920]
R3 dfmirage;dfmirage;c:\windows\system32\drivers\dfmirage.sys [4/15/2008 4:49 AM 31896]
S2 0004891270059213mcinstcleanup;McAfee Application Installer Cleanup (0004891270059213);c:\windows\TEMP\000489~1.EXE c:\progra~1\COMMON~1\McAfee\INSTAL~1\cleanup.ini -cleanup -nolog -service --> c:\windows\TEMP\000489~1.EXE c:\progra~1\COMMON~1\McAfee\INSTAL~1\cleanup.ini -cleanup -nolog -service [?]
S2 gupdate;Google Update Service (gupdate);c:\program files\Google\Update\GoogleUpdate.exe [12/30/2009 8:51 AM 133104]
S3 GoogleDesktopManager-110309-193829;Google Desktop Manager 5.9.911.3589;c:\program files\Google\Google Desktop Search\GoogleDesktop.exe [12/30/2009 8:49 AM 30192]
S3 OlCamudp;OLYMPUS Digital Camera;c:\windows\system32\drivers\olcamudp.sys [1/6/2005 11:04 AM 10379]
S3 RiotDrv;Rio Riot driver;c:\windows\system32\drivers\RiotDrv.sys [1/31/2005 2:34 PM 12474]
S3 rootrepeal1;rootrepeal1;\??\c:\windows\system32\drivers\rootrepeal1.sys --> c:\windows\system32\drivers\rootrepeal1.sys [?]
p2psvc   REG_MULTI_SZ      p2psvc p2pimsvc p2pgasvc PNRPSvc
2010-05-04 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 19:34]
2010-05-10 c:\windows\Tasks\Google Software Updater.job
- c:\program files\Google\Common\Google Updater\GoogleUpdaterService.exe [2007-01-25 03:36]
2010-05-10 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files\Google\Update\GoogleUpdate.exe [2009-12-30 15:51]
2010-05-10 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2010-04-15 c:\windows\Tasks\McDefragTask.job
- c:\progra~1\mcafee\mqc\QcConsol.exe [2009-12-29 20:22]
2010-05-01 c:\windows\Tasks\McQcTask.job
2010-05-03 c:\windows\Tasks\NatSpeak Periodic Acoustic Optimization.job
- c:\program files\Nuance\NaturallySpeaking10\Program\schedmgr.exe [2009-03-17 05:17]
2010-05-09 c:\windows\Tasks\NatSpeak Periodic Language Model Optimization.job
uDefault_Search_URL = hxxp://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iesearch&locale=EN_US&c=Q105&bd=pavilion&pf=desktop
uSearchMigratedDefaultURL = hxxp://www.google.com/search?q={searchTerms}&sourceid=ie7&rls=com.microsoft:en-US&ie=utf8&oe=utf8
uStart Page = hxxp://www.google.com
mSearch Bar = hxxp://www.google.com
uSearchAssistant = hxxp://www.google.com/ie
uSearchURL,(Default) = hxxp://www.google.com/search?q=%s
IE: Add to Google Photos Screensa&ver - c:\windows\system32\GPhotos.scr/200
IE: Add To HP Organize... - c:\progra~1\HEWLET~1\HPORGA~1\bin/module.main/favorites\ie_add_to.html
IE: Append the content of the link to existing PDF file - c:\program files\Nuance\PDF Professional 6\Bin\ZeonIEFavClient.dll/ZeonIEAppend.HTML
IE: Append the content of the selected links to existing PDF file - c:\program files\Nuance\PDF Professional 6\Bin\ZeonIEFavClient.dll/ZeonIEAppendSelLinks.HTML
IE: Append to existing PDF file - c:\program files\Nuance\PDF Professional 6\Bin\ZeonIEFavClient.dll/ZeonIEAppend.HTML
IE: Create PDF file - c:\program files\Nuance\PDF Professional 6\Bin\ZeonIEFavClient.dll/ZeonIECapture.HTML
IE: Create PDF file from the content of the link - c:\program files\Nuance\PDF Professional 6\Bin\ZeonIEFavClient.dll/ZeonIECapture.HTML
IE: Create PDF files from the selected links - c:\program files\Nuance\PDF Professional 6\Bin\ZeonIEFavClient.dll/ZeonIECaptureSelLinks.HTML
IE: E&xport to Microsoft Excel - c:\progra~1\MI1933~1\Office10\EXCEL.EXE/3000
IE: Open with Nuance PDF Converter 6.0 - c:\program files\Nuance\PDF Professional 6\cnvres_eng.dll /100
IE: Open with PDF Professional 6 - c:\program files\Nuance\PDF Professional 6\Bin\PlusIEContextMenu.dll/PlusIEContextMenu.htm
Trusted Zone: care360.com
Trusted Zone: questdiagnostics.com
Trusted Zone: musicmatch.com\online
DPF: Microsoft XML Parser for Java - file://c:\windows\Java\classes\xmldso.cab
DPF: {46C4B83F-8632-4C31-B86F-4172B1160D0C} - hxxps://cas2.questdiagnostics.com/EREQ_SSLcabs/GetEnvironmentVariables.CAB
DPF: {756BEC7B-ADF4-4931-A519-B513B32CFC1B} - hxxps://cas2.questdiagnostics.com/EREQ_SSLcabs/LabelControl.CAB
DPF: {79C259BD-8024-4992-B445-2C52D3449214} - hxxps://cas2.questdiagnostics.com/EREQ_SSLcabs/C360Upgrader.CAB
DPF: {F812AAD2-8EE4-46C3-8E0F-8A27A7DBFC5F} - hxxps://www.escription.com/code/ePrinterX.CAB
Toolbar-{F4571874-4CA5-4154-82BE-0CB76C8D6DAD} - (no file)
WebBrowser-{F4571874-4CA5-4154-82BE-0CB76C8D6DAD} - (no file)
HKCU-Run-OpAgent - OpAgent.exe
HKLM-Run-YOP - c:\progra~1\Yahoo!\YOP\yop.exe
HKLM-Run-VTTimer - VTTimer.exe
HKLM-Run-Symantec NetDriver Monitor - c:\progra~1\SYMNET~1\SNDMon.exe
HKLM-Run-ccApp - c:\program files\Common Files\Symantec Shared\ccApp.exe
HKLM-Run-AutoTBar - c:\program files\HP\Digital Imaging\bin\AUTOTBAR.EXE
MSConfigStartUp-AppleSyncNotifier - c:\program files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe
AddRemove-Agere Systems Soft Modem - c:\windows\agrsmdel
AddRemove-LSI Soft Modem - c:\windows\agrsmdel
AddRemove-Pilot Desktop - c:\palm\Palm.isu
Rootkit scan 2010-05-09 20:45
scanning hidden processes ...
scanning hidden files ...
scan completed successfully
hidden files: 0
- - - - - - - > 'winlogon.exe'(824)
c:\windows\system32\Ati2evxx.dll
- - - - - - - > 'explorer.exe'(5420)
c:\program files\Logitech\SetPoint\KEMHook.dll
c:\program files\Logitech\SetPoint\lgscroll.dll
c:\program files\Roxio\Easy Media Creator 8\Drag to Disc\Shellex.dll
c:\windows\system32\Ati2evxx.exe
c:\windows\system32\LEXBCES.EXE
c:\windows\system32\LEXPPS.EXE
c:\program files\Common Files\EPSON\eEBAPI\eEBSVC.exe
c:\program files\Common Files\ArcSoft\Connection Service\Bin\ACService.exe
c:\program files\Adobe\Photoshop Elements 5.0\PhotoshopElementsFileAgent.exe
c:\program files\LSI SoftModem\agrsmsvc.exe
c:\program files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
c:\program files\Symantec\LiveUpdate\AluSchedulerSvc.exe
c:\program files\Bonjour\mDNSResponder.exe
c:\windows\system32\CTsvcCDA.EXE
c:\documents and settings\All Users\Application Data\EPSON\EPW!3 SSRP\E_S40ST7.EXE
c:\documents and settings\All Users\Application Data\EPSON\EPW!3 SSRP\E_S40RP7.EXE
c:\program files\Citrix\GoToMyPC\g2svc.exe
c:\program files\Citrix\GoToMyPC\g2comm.exe
c:\program files\Java\jre6\bin\jqs.exe
c:\program files\Citrix\GoToMyPC\g2pre.exe
c:\windows\AGRSMMSG.exe
c:\program files\Citrix\GoToMyPC\g2tray.exe
c:\windows\system32\wfxsnt40.exe
c:\progra~1\Yahoo!\browser\ycommon.exe
c:\progra~1\McAfee\MSC\mcmscsvc.exe
c:\progra~1\COMMON~1\mcafee\mna\mcnasvc.exe
c:\progra~1\COMMON~1\mcafee\mcproxy\mcproxy.exe
c:\progra~1\McAfee\VIRUSS~1\mcshield.exe
c:\windows\ALCWZRD.EXE
c:\program files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
c:\program files\McAfee\MPF\MPFSrv.exe
c:\program files\RDM+\rdmpserv_cpanel.exe
c:\program files\Common Files\Roxio Shared\SharedCOM8\RoxMediaDB.exe
c:\program files\Common Files\Roxio Shared\SharedCOM8\RoxWatch.exe
c:\windows\system32\tcpsvcs.exe
c:\windows\system32\WFXSVC.EXE
c:\program files\WinFax\WFXMOD32.EXE
c:\windows\system32\MsPMSPSv.exe
c:\program files\Common Files\Logitech\KHAL\KHALMNPR.EXE
c:\program files\HP\Digital Imaging\bin\hpqimzone.exe
c:\program files\HP\Digital Imaging\bin\hpqnrs08.exe
c:\windows\system32\SearchIndexer.exe
c:\windows\system32\wscntfy.exe
c:\program files\iPod\bin\iPodService.exe
c:\windows\system32\HPZinw12.exe
Completion time: 2010-05-09  20:52:03 - machine was rebooted
ComboFix-quarantined-files.txt  2010-05-10 03:52
Pre-Run: 257,552,441,344 bytes free
Post-Run: 257,728,929,792 bytes free
- - End Of File - - 50938DC27BE3020CE6466B7804B1CCE2
Gmer.txt:
GMER 1.0.15.15281 - http://www.gmer.net
Rootkit scan 2010-05-09 20:07:05
Running: gmer.exe; Driver: C:\DOCUME~1\HP_ADM~1\LOCALS~1\Temp\uxldipog.sys
---- Kernel code sections - GMER 1.0.15 ----
.text  ntkrnlpa.exe!ZwYieldExecution        80504AF4 7 Bytes  JMP A88CD7B8 \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!NtCreateFile        80579084 5 Bytes  JMP A88CD78E \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!NtMapViewOfSection        805B1FE6 7 Bytes  JMP A88CD7CE \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwUnmapViewOfSection        805B2DF4 5 Bytes  JMP A88CD7E4 \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwProtectVirtualMemory        805B83CA 7 Bytes  JMP A88CD7A2 \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!NtOpenProcess        805CB3FA 5 Bytes  JMP A88CD714 \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!NtOpenThread        805CB686 5 Bytes  JMP A88CD728 \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!NtSetInformationProcess        805CDE44 5 Bytes  JMP A88CD766 \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwCreateProcessEx        805D1134 7 Bytes  JMP A88CD750 \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwCreateProcess        805D11EA 5 Bytes  JMP A88CD73C \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwSetContextThread        805D16F4 5 Bytes  JMP A88CD77A \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwTerminateProcess        805D2982 5 Bytes  JMP A88CD7FD \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwQueryValueKey        806219EC 7 Bytes  JMP A88CD891 \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwSetValueKey        80621D3A 7 Bytes  JMP A88CD87B \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwUnloadKey        80622064 7 Bytes  JMP A88CD8E9 \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwQueryMultipleValueKey        80622916 7 Bytes  JMP A88CD8A7 \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwRenameKey        806231EA 7 Bytes  JMP A88CD84F \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwCreateKey        806237C8 5 Bytes  JMP A88CD825 \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwDeleteKey        80623C64 7 Bytes  JMP A88CD839 \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwDeleteValueKey        80623E34 7 Bytes  JMP A88CD865 \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwEnumerateKey        80624014 7 Bytes  JMP A88CD8D3 \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwEnumerateValueKey        8062427E 7 Bytes  JMP A88CD8BD \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwOpenKey        80624BA6 5 Bytes  JMP A88CD811 \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwQueryKey        80624EE8 7 Bytes  JMP A88CD93B \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwRestoreKey        806251A8 5 Bytes  JMP A88CD913 \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwReplaceKey        8062589C 5 Bytes  JMP A88CD927 \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
PAGE   ntkrnlpa.exe!ZwNotifyChangeKey        806259B6 5 Bytes  JMP A88CD8FF \SystemRoot\system32\drivers\mfehidk.sys (Host Intrusion Detection Link Driver/McAfee, Inc.)
?      lnsbsgnp.sys        The system cannot find the file specified. !
---- User code sections - GMER 1.0.15 ----
?      C:\Program Files\Java\j2re1.4.2_03\bin\jusched.exe[292] C:\WINDOWS\system32\msvcrt.dll               IMAGE_DOS_SIGNATURE not found;
.text  C:\WINDOWS\system32\services.exe[872] kernel32.dll!CreateFileA                                       7C801A28 5 Bytes  JMP 00FF0FE5
.text  C:\WINDOWS\system32\services.exe[872] kernel32.dll!VirtualProtectEx                                  7C801A61 5 Bytes  JMP 00FF0F83
.text  C:\WINDOWS\system32\services.exe[872] kernel32.dll!VirtualProtect                                    7C801AD4 5 Bytes  JMP 00FF0F9E
.text  C:\WINDOWS\system32\services.exe[872] kernel32.dll!LoadLibraryExW                                    7C801AF5 5 Bytes  JMP 00FF006C
.text  C:\WINDOWS\system32\services.exe[872] kernel32.dll!LoadLibraryExA                                    7C801D53 5 Bytes  JMP 00FF005B
.text  C:\WINDOWS\system32\services.exe[872] kernel32.dll!LoadLibraryA                                      7C801D7B 5 Bytes  JMP 00FF0FCA
.text  C:\WINDOWS\system32\services.exe[872] kernel32.dll!GetStartupInfoW                                   7C801E54 5 Bytes  JMP 00FF0F4B
.text  C:\WINDOWS\system32\services.exe[872] kernel32.dll!GetStartupInfoA                                   7C801EF2 5 Bytes  JMP 00FF0093
.text  C:\WINDOWS\system32\services.exe[872] kernel32.dll!CreateProcessW                                    7C802336 5 Bytes  JMP 00FF0F26
.text  C:\WINDOWS\system32\services.exe[872] kernel32.dll!CreateProcessA                                    7C80236B 5 Bytes  JMP 00FF00BF
.text  C:\WINDOWS\system32\services.exe[872] kernel32.dll!GetProcAddress                                    7C80AE40 5 Bytes  JMP 00FF0F15
.text  C:\WINDOWS\system32\services.exe[872] kernel32.dll!LoadLibraryW                                      7C80AEEB 5 Bytes  JMP 00FF0FB9
.text  C:\WINDOWS\system32\services.exe[872] kernel32.dll!CreateFileW                                       7C810800 5 Bytes  JMP 00FF000A
.text  C:\WINDOWS\system32\services.exe[872] kernel32.dll!CreatePipe                                        7C81D83F 5 Bytes  JMP 00FF0F68
.text  C:\WINDOWS\system32\services.exe[872] kernel32.dll!CreateNamedPipeW                                  7C82F0DD 5 Bytes  JMP 00FF0036
.text  C:\WINDOWS\system32\services.exe[872] kernel32.dll!CreateNamedPipeA                                  7C860CDC 5 Bytes  JMP 00FF0025
.text  C:\WINDOWS\system32\services.exe[872] kernel32.dll!WinExec                                           7C86250D 5 Bytes  JMP 00FF00AE
.text  C:\WINDOWS\system32\services.exe[872] ADVAPI32.dll!RegOpenKeyExW                                     77DD6AAF 5 Bytes  JMP 00FE0FC3
.text  C:\WINDOWS\system32\services.exe[872] ADVAPI32.dll!RegCreateKeyExW                                   77DD776C 5 Bytes  JMP 00FE005B
.text  C:\WINDOWS\system32\services.exe[872] ADVAPI32.dll!RegOpenKeyExA                                     77DD7852 5 Bytes  JMP 00FE000A
.text  C:\WINDOWS\system32\services.exe[872] ADVAPI32.dll!RegOpenKeyW                                       77DD7946 5 Bytes  JMP 00FE0FD4
.text  C:\WINDOWS\system32\services.exe[872] ADVAPI32.dll!RegCreateKeyExA                                   77DDE9F4 5 Bytes  JMP 00FE0F9E
.text  C:\WINDOWS\system32\services.exe[872] ADVAPI32.dll!RegOpenKeyA                                       77DDEFC8 5 Bytes  JMP 00FE0FEF
.text  C:\WINDOWS\system32\services.exe[872] ADVAPI32.dll!RegCreateKeyW                                     77DFBA55 5 Bytes  JMP 00FE0040
.text  C:\WINDOWS\system32\services.exe[872] ADVAPI32.dll!RegCreateKeyA                                     77DFBCF3 5 Bytes  JMP 00FE002F
.text  C:\WINDOWS\system32\services.exe[872] msvcrt.dll!_wsystem                                            77C2931E 5 Bytes  JMP 00E10FD9
.text  C:\WINDOWS\system32\services.exe[872] msvcrt.dll!system                                              77C293C7 5 Bytes  JMP 00E1005A
.text  C:\WINDOWS\system32\services.exe[872] msvcrt.dll!_creat                                              77C2D40F 5 Bytes  JMP 00E10038
.text  C:\WINDOWS\system32\services.exe[872] msvcrt.dll!_open                                               77C2F566 5 Bytes  JMP 00E10000
.text  C:\WINDOWS\system32\services.exe[872] msvcrt.dll!_wcreat                                             77C2FC9B 5 Bytes  JMP 00E10049
.text  C:\WINDOWS\system32\services.exe[872] msvcrt.dll!_wopen                                              77C30055 5 Bytes  JMP 00E10011
.text  C:\WINDOWS\system32\services.exe[872] WS2_32.dll!socket                                              71AB4211 5 Bytes  JMP 00E0000A
.text  C:\WINDOWS\system32\lsass.exe[884] kernel32.dll!CreateFileA                                          7C801A28 5 Bytes  JMP 00E80FEF
.text  C:\WINDOWS\system32\lsass.exe[884] kernel32.dll!VirtualProtectEx                                     7C801A61 5 Bytes  JMP 00E80F75
.text  C:\WINDOWS\system32\lsass.exe[884] kernel32.dll!VirtualProtect                                       7C801AD4 5 Bytes  JMP 00E80060
.text  C:\WINDOWS\system32\lsass.exe[884] kernel32.dll!LoadLibraryExW                                       7C801AF5 5 Bytes  JMP 00E80F86
.text  C:\WINDOWS\system32\lsass.exe[884] kernel32.dll!LoadLibraryExA                                       7C801D53 5 Bytes  JMP 00E80FA1
.text  C:\WINDOWS\system32\lsass.exe[884] kernel32.dll!LoadLibraryA                                         7C801D7B 5 Bytes  JMP 00E80FC3
.text  C:\WINDOWS\system32\lsass.exe[884] kernel32.dll!GetStartupInfoW                                      7C801E54 5 Bytes  JMP 00E80F3D
.text  C:\WINDOWS\system32\lsass.exe[884] kernel32.dll!GetStartupInfoA                                      7C801EF2 5 Bytes  JMP 00E80F5A
.text  C:\WINDOWS\system32\lsass.exe[884] kernel32.dll!CreateProcessW                                       7C802336 5 Bytes  JMP 00E800C2
.text  C:\WINDOWS\system32\lsass.exe[884] kernel32.dll!CreateProcessA                                       7C80236B 5 Bytes  JMP 00E800B1
.text  C:\WINDOWS\system32\lsass.exe[884] kernel32.dll!GetProcAddress                                       7C80AE40 5 Bytes  JMP 00E800D3
.text  C:\WINDOWS\system32\lsass.exe[884] kernel32.dll!LoadLibraryW                                         7C80AEEB 5 Bytes  JMP 00E80FB2
.text  C:\WINDOWS\system32\lsass.exe[884] kernel32.dll!CreateFileW                                          7C810800 5 Bytes  JMP 00E80014
.text  C:\WINDOWS\system32\lsass.exe[884] kernel32.dll!CreatePipe                                           7C81D83F 5 Bytes  JMP 00E80085
.text  C:\WINDOWS\system32\lsass.exe[884] kernel32.dll!CreateNamedPipeW                                     7C82F0DD 5 Bytes  JMP 00E8002F
.text  C:\WINDOWS\system32\lsass.exe[884] kernel32.dll!CreateNamedPipeA                                     7C860CDC 5 Bytes  JMP 00E80FDE
.text  C:\WINDOWS\system32\lsass.exe[884] kernel32.dll!WinExec                                              7C86250D 5 Bytes  JMP 00E800A0
.text  C:\WINDOWS\system32\lsass.exe[884] ADVAPI32.dll!RegOpenKeyExW                                        77DD6AAF 5 Bytes  JMP 00E70014
.text  C:\WINDOWS\system32\lsass.exe[884] ADVAPI32.dll!RegCreateKeyExW                                      77DD776C 5 Bytes  JMP 00E70F61
.text  C:\WINDOWS\system32\lsass.exe[884] ADVAPI32.dll!RegOpenKeyExA                                        77DD7852 5 Bytes  JMP 00E70FCD
.text  C:\WINDOWS\system32\lsass.exe[884] ADVAPI32.dll!RegOpenKeyW                                          77DD7946 5 Bytes  JMP 00E70FDE
.text  C:\WINDOWS\system32\lsass.exe[884] ADVAPI32.dll!RegCreateKeyExA                                      77DDE9F4 5 Bytes  JMP 00E70F7C
.text  C:\WINDOWS\system32\lsass.exe[884] ADVAPI32.dll!RegOpenKeyA                                          77DDEFC8 5 Bytes  JMP 00E70FEF
.text  C:\WINDOWS\system32\lsass.exe[884] ADVAPI32.dll!RegCreateKeyW                                        77DFBA55 2 Bytes  JMP 00E70F8D
.text  C:\WINDOWS\system32\lsass.exe[884] ADVAPI32.dll!RegCreateKeyW + 3                                    77DFBA58 2 Bytes  [07, 89]
.text  C:\WINDOWS\system32\lsass.exe[884] ADVAPI32.dll!RegCreateKeyA                                        77DFBCF3 5 Bytes  JMP 00E70F9E
.text  C:\WINDOWS\system32\lsass.exe[884] msvcrt.dll!_wsystem                                               77C2931E 5 Bytes  JMP 00DA0F9C
.text  C:\WINDOWS\system32\lsass.exe[884] msvcrt.dll!system                                                 77C293C7 5 Bytes  JMP 00DA0FB7
.text  C:\WINDOWS\system32\lsass.exe[884] msvcrt.dll!_creat                                                 77C2D40F 5 Bytes  JMP 00DA0016
.text  C:\WINDOWS\system32\lsass.exe[884] msvcrt.dll!_open                                                  77C2F566 5 Bytes  JMP 00DA0FEF
.text  C:\WINDOWS\system32\lsass.exe[884] msvcrt.dll!_wcreat                                                77C2FC9B 5 Bytes  JMP 00DA0027
.text  C:\WINDOWS\system32\lsass.exe[884] msvcrt.dll!_wopen                                                 77C30055 5 Bytes  JMP 00DA0FDE
.text  C:\WINDOWS\system32\lsass.exe[884] WS2_32.dll!socket                                                 71AB4211 5 Bytes  JMP 00C50000
.text  C:\WINDOWS\system32\svchost.exe[1088] kernel32.dll!CreateFileA                                       7C801A28 5 Bytes  JMP 02660FE5
.text  C:\WINDOWS\system32\svchost.exe[1088] kernel32.dll!VirtualProtectEx                                  7C801A61 5 Bytes  JMP 02660040
.text  C:\WINDOWS\system32\svchost.exe[1088] kernel32.dll!VirtualProtect                                    7C801AD4 5 Bytes  JMP 02660F55
.text  C:\WINDOWS\system32\svchost.exe[1088] kernel32.dll!LoadLibraryExW                                    7C801AF5 5 Bytes  JMP 0266002F
.text  C:\WINDOWS\system32\svchost.exe[1088] kernel32.dll!LoadLibraryExA                                    7C801D53 5 Bytes  JMP 02660F72
.text  C:\WINDOWS\system32\svchost.exe[1088] kernel32.dll!LoadLibraryA                                      7C801D7B 5 Bytes  JMP 02660F9E
.text  C:\WINDOWS\system32\svchost.exe[1088] kernel32.dll!GetStartupInfoW                                   7C801E54 5 Bytes  JMP 02660F13
.text  C:\WINDOWS\system32\svchost.exe[1088] kernel32.dll!GetStartupInfoA                                   7C801EF2 5 Bytes  JMP 0266005B
.text  C:\WINDOWS\system32\svchost.exe[1088] kernel32.dll!CreateProcessW                                    7C802336 5 Bytes  JMP 02660EC9
.text  C:\WINDOWS\system32\svchost.exe[1088] kernel32.dll!CreateProcessA                                    7C80236B 5 Bytes  JMP 0266006C
.text  C:\WINDOWS\system32\svchost.exe[1088] kernel32.dll!GetProcAddress                                    7C80AE40 5 Bytes  JMP 02660EAE
.text  C:\WINDOWS\system32\svchost.exe[1088] kernel32.dll!LoadLibraryW                                      7C80AEEB 5 Bytes  JMP 02660F83
.text  C:\WINDOWS\system32\svchost.exe[1088] kernel32.dll!CreateFileW                                       7C810800 5 Bytes  JMP 0266000A
.text  C:\WINDOWS\system32\svchost.exe[1088] kernel32.dll!CreatePipe                                        7C81D83F 5 Bytes  JMP 02660F30
.text  C:\WINDOWS\system32\svchost.exe[1088] kernel32.dll!CreateNamedPipeW                                  7C82F0DD 5 Bytes  JMP 02660FAF
.text  C:\WINDOWS\system32\svchost.exe[1088] kernel32.dll!CreateNamedPipeA                                  7C860CDC 5 Bytes  JMP 02660FD4
.text  C:\WINDOWS\system32\svchost.exe[1088] kernel32.dll!WinExec                                           7C86250D 5 Bytes  JMP 02660EF8
.text  C:\WINDOWS\system32\svchost.exe[1088] ADVAPI32.dll!RegOpenKeyExW                                     77DD6AAF 5 Bytes  JMP 02650FB9
.text  C:\WINDOWS\system32\svchost.exe[1088] ADVAPI32.dll!RegCreateKeyExW                                   77DD776C 5 Bytes  JMP 02650F72
.text  C:\WINDOWS\s
sjb007
Hi bdemuth
Great work in getting the logs to me, how are things running now?
Lets clear out some system junk.....
   1. Download Temp File Cleaner by OldTimer to your desktop, or other location.
   2. Save any unsaved work. TFC will close all open application windows.
   3. Double-click TFC.exe to run the program.
   4. If prompted, click "Yes" to reboot.
Save your work. TFC will automatically close any open programs, let it run uninterrupted. It shouldn't take longer take a couple of minutes, and may only take a few seconds. Only if needed will you be prompted to reboot.
Once done.....
Please run this online scan to help look for remnants. One vendor's definitions may find what another's does not. This scan will take an hour or two, please don't use the machine for anything else while the scan is ongoing.
Establish an internet connection & perform an online scan with Internet Explorer at Kaspersky Online Scanner.
Please note that this may take some time to complete
Click Accept, when prompted to download and install the program files and database of malware definitions.
  • Click Run at the Security prompt.
  • The program will then begin downloading and installing and will also update the database.
  • Please be patient as this can take several minutes.
  • Once the update is complete, click on My Computer under the green Scan bar to the left to start the scan.
  • Once the scan is complete, it will display if your system has been infected. It does not provide an option to clean/disinfect. We only require a report from it.
  • Do NOT be alarmed by what you see in the report. Many of the finds have likely been quarantined.
  • Click View scan report at the bottom.
  • Click the Save Report As... button.
  • Click the Save as Text button to save the file to your desktop so that you may post it in your next reply.
This animation will guide you through the process:
**Note**
To optimize scanning time and produce a more sensible report for review:
Close any open programs
Turn off the real time scanner of any existing antivirus program while performing the online scan. You may disconnect from the internet once you begin the scan.
Note for Internet Explorer 7 users: If at any time you have trouble viewing the accept button of the license, click on the Zoom tool located at the bottom right of the IE window and set the zoom to 75 %. Once the license accepted, reset to 100%.
Post back with the resuting log in your next reply
bdemuth
Here's the Kaspersky report.  Thanks again for all your help.
KASPERSKY ONLINE SCANNER 7.0: scan report
Tuesday, May 11, 2010
Operating system: Microsoft Windows XP Professional Service Pack 3 (build 2600)
Kaspersky Online Scanner version: 7.0.26.13
Last database update: Tuesday, May 11, 2010 00:34:12
Records in database: 4092647
Scan settings:
   scan using the following database: extended
   Scan archives: yes
   Scan e-mail databases: yes
Scan area - My Computer:
   C:\
   D:\
   E:\
   F:\
Scan statistics:
   Objects scanned: 234623
   Threats found: 6
   Infected objects found: 7
   Suspicious objects found: 1
   Scan duration: 06:15:12
File name / Threat / Threats count
C:\Documents and Settings\HP_Administrator\Incomplete\Preview-T-5078290-little wing stevie ray vaughan [extended version].wav   Infected: Trojan-Downloader.WMA.GetCodec.s   1
C:\Documents and Settings\HP_Administrator\My Documents\Downloads\Auto Receive.exe   Infected: not-a-virus:Tool.Win32.PrcView.3725   1
C:\Downloads\Download_x-video-converter.exe   Infected: not-a-virus:Downloader.Win32.SpyNoMore.a   1
C:\Downloads\waterfalls_en.exe   Infected: not-a-virus:AdWare.Win32.180Solutions   1
C:\Downloads\waterfalls_en.exe   Infected: not-a-virus:AdWare.Win32.WebRebates.c   3
C:\Program Files\Yahoo!\YPSR\Quarantine\20050809001912.zip   Suspicious: Password-protected-EXE   1
Selected area has been scanned.
sjb007
Hi there
I do notice that you have placed sites in your trusted zone. Sites in the trusted zone have the security level set to low by default. These site can be removed from the trusted zone and simply placed in bookmarks. More information on using the trusted zone is available from here -> How to use security zones in Internet Explorer
Close any open browsers.
Open notepad and copy/paste the text in the quotebox below into it:
File::
Save this as CFScript.txt, in the same location as ComboFix.exe
Refering to the picture above, drag CFScript into ComboFix.exe
When finished, it shall produce a log for you at C:\ComboFix.txt which I will require in your next reply.
Copy and paste this log back in your next reply, update me on how things are running now.
