removal tool?
Started by jarvis10, January 23, 2012, 08:14:53 PM
jarvis10
Hi, I removed my plus version, the uninstall from start menu failed (just opened windows explorer?) so I used add remove program which seemed to work. However I still have right click winpatrol plus on everything and a few logs data etc.
Anyway to remove it fully? or is it a re install windows job?
Thanks
Hi, jarvis10.
Welcome to LandzDown Forum.  There isn't a removal tool for WinPatrol.  However, you can follow the instructions in this topic:  Completely Uninstall and Reinstall WinPatrol.
jarvis10
Hello and thanks for your help, I already did those, I still cannot remove the right click plus from explorer. There is nothing obvious in regeditcurrent>*>shellex>context menu. am I missing something? thanks.
jarvis10
I tried reinstall and remove again, right click is still there, windows shell seems to be reading from the wrong directory, im going to lose a weeks work and roll back. thanks for trying anyways.
Have you tried the following:
Reinstall WinPatrol
Click on the Scotty icon in your system tray.
go to the OPTIONS tab
===> *** UNcheck the box for Windows Explorer Integration ***
Hopefully, that should remove the Right-Click Plus option from Explorer.
If so, and if you still want to uninstall WinPatrol, EXIT the program, and then uninstall.
Were you having other problems/dissatisfaction with WinPatrol that led you to remove it?
P.S.
If that box wasn't already checked, I would suggest first putting in the check, and then UNchecking it.
