Help I have a virus on my laptop that wont let me connect to the internet
Started by DHS1014, May 05, 2012, 01:15:04 AM
DHS1014
Hi, I have a virus i think its a bunch of *32 kind of virus...anyway I cant connect to the internet at all whether it be wired or wireless. I have tried downloading malware bytes and avg and others to flash drive and installing...but they dont work they supposedly found and got rid of 4 viruses but, they say that everytime I run them. Any assistance would be greatly appreciated. Thank you.
Hi, DHS1014.  Welcome to LandzDown Forum.
1.  Please restart the computer in Safe Mode with Networking. (To do this, turn your computer off and then back on and immediately when you see anything on the screen, start tapping the F8 key on your keyboard. Using the arrow keys on your keyboard, select Safe Mode with Networking and press Enter on your keyboard. Windows will now boot into safe mode with networking and prompt you to login as a user.)
2.  Please download rkill from one of the following links and save to your Desktop:
Note:  DHS1014, if you are not able to connect using Safe Mode with Networking, download RKill to a flash drive and move it to the desktop of the infected computer.
One, Two,Three or Four
  • Double-click rkill to run.
Note: If you you receive security warnings about rkill, please ignore and allow the download to continue.
3.  To give you a bit of breathing space, try running Malwarebytes again after running rkill as follows:
  • Launch Malwarebytes' Anti-Malware then click the Update tab and "Check for Updates
  • Once the update has been installed and the program has loaded, select Quick scan
    • Click Remove Selected.
    ** Note **
    Note:  If you need to restart the computer, if you still cannot connect in normal mode, try Safe Mode with Networking again.
    4.  Download DDS.scr by sUBs from one of the following links and save it to your desktop.
    Link 1
    Link 2
    5.  Download Security Check by screen317 from here or here.
    • Save it to your Desktop.
    • Double click SecurityCheck.exe and follow the onscreen instructions inside of the black box.
    • A Notepad document should open automatically called checkup.txt; please post the contents of that document.
    Requested logs:
    Malwarebytes
    Both DDS.txt and Attach.txt
    checkup.txt
    Please be also confirm if you can connect to the Internet normal or Safe Mode with Networking.
