Pale Moon Version 25.4 Released
Started by Corrine, May 08, 2015, 04:05:37 PM
Pale Moon has been updated to version 25.4.  This is a major update which numerous fixes/changes as well as security updates.
Important:  If you use a language pack, make sure to update it to the latest version!  Although automatic updates are enabled for language packs, double-check that the version matches. If you are using an older language pack with this version of the browser, some dialog boxes may come up blank.
Security fixes:
  •     Fixed several memory safety hazards (UAF/DF/UU); applicable bugs covered by CVE-2015-0815 and CVE-2015-0815.
  •     Fixed CVE-2015-0811 [qcms] heap info leak.
  •     Fixed CVE-2015-0810 clickjacking attacks via a Flash object in conjunction with DIV elements.
  •     Fixed CVE-2015-0801 a variant of CVE-2015-0818.
  •     Fixed CVE-2015-0800 improve randomness of DNS resolver queries on Android.
  •     Fixed CVE-2015-0798 access to privileged URLs through about: redirector.
See the Release Notes for the extensive list of fixes, changes and additions.
Thanks for helping keep us current!
siljaline
siljaline
MVPS Hosts . MBAM . Why ESET
PaleMoon itself stopped supporting XP... however, it has endorsed the third-party customized build by Binary Outcast http://binaryoutcast.com/projects/pm4xp/
Version 25.4.0 - Released: 2015-05-08
satrow
Pale Moon's own Atom/XP version will also work fine on XP x86: http://www.palemoon.org/palemoon-atom.shtml
siljaline
Quote from: ky331 on May 09, 2015, 10:35:19 AM
What is that, a software fork ? Not a big fan of forks as they can and do run away from what the developers initially intended for the product.
Nevertheless, no one should be running Windows XP these days.  Someone on XP was able to updgrade internally just today, so this is a bit of a support mess now as well.
siljaline
satrow
Not really a fork, it's built from data supplied by the Pale Moon Dev, who doesn't have the time (and maybe not an XP machine) to build it himself, it's built by Tobin, a very active member of the Pale Moon team.
When it comes down to Atom netbooks/nettops that were designed with very limited hardware and might already be very close to retirement, I see little mileage to be gained out of trying to force those users into an OS upgrade (W7 could well be their limit anyway) when they would be better served putting aside that money towards their next computer.
Pale Moon has been updated to 25.4.1 to address two critical bugs in 25.4:
◦Fixed loss of the browser's disk cache on startup due to incorrect corruption detection logic
◦Fixed a browser crash on some HTML5 games
http://www.palemoon.org/releasenotes.shtml
The following note was provided by Matt Tobin:
QuoteNOTE: The the following comment ONLY affects the third party contributed version Pale Moon for Windows XP.. The Atom version is not affected and is not subject to this comment or issue.
Please pay CLOSE attention to the upgrade dialog.. If you happen to be on PM4XP There was an issue with the 25.4.0...
If you see the Update dialog say "Pale Moon 25.4.1 (x86 or x64) DO NOT UPDATE and go to http://binaryoutcast.com/projects/pm4xp/ and download the full installer. If you are on PM4XP 25.3.2 or lower and see it say "Pale Moon for Windows XP 25.4.1" then it is safe to update...
If you are in doubt please go and get the full installer from the BinOC page.
