Pale Moon Version 32.4.1 Released with Security Updates
Started by Corrine, October 03, 2023, 12:54:49 PM
Pale Moon has been updated to version 32.4.1.  This is a bugfix and security release.
Changes/Fixes:
  • Fixed an issue in BigInt typedArray costructors.
  • Added some safety checks for Performance Observers.
  • Fixed JSON BigInt regressions.
  • Fixed missing BigInt increment/decrement operations.
  • Added WASM sign extension opcodes.
  • Fixed an issue with dead Promise wrappers in JavaScript DiD*
  • Fixed an issue with Alternative Services DiD*
  • Fixed an issue with libvpx (address CVE-2023-5217) DiD*
Notes:
*DiD This means that a fix is "Defense-in-Depth": It is a fix that does not apply to a (potentially) actively exploitable vulnerability in Pale Moon, but prevents future vulnerabilities caused by the same code, e.g. when surrounding code changes, exposing the problem, or when new attack vectors are discovered.
Rejected security patches: This means that patches were theoretically applicable to our code but considered undesirable, which could be due to unwanted changes in behavior, known regressions caused by the patches, or unnecessary risks for stability, security or privacy.
Release Cycle
