Pale Moon Version 34.1.0 Released with Security Updates
Started by Corrine, March 03, 2026, 04:52:31 PM
 Pale Moon has been updated to version 34.1.0.  This is an important update landing technological enhancements previously intended to be in the v34.0 milestone.
The update also addresses security issues:  CVE-2026-2806 (DiD), CVE-2026-2758, CVE-2026-2804, CVE-2026-2787 (DiD), CVE-2026-2757, CVE-2026-2773, CVE-2026-2779 (DiD), CVE-2026-2775, and several others that do not have a CVE designation.
*DiD: This means that a fix is "Defense-in-Depth": It is a fix that does not apply to a (potentially) actively exploitable vulnerability in Pale Moon, but prevents future vulnerabilities caused by the same code, e.g. when surrounding code changes, exposing the problem, or when new attack vectors are discovered.
Release Cycle
