New active X cert alert ( no patch yet)
Started by mitch, September 28, 2006, 01:11:01 AM
mitch
     this is not the patch that MS released today, but a new one !
                National Cyber Alert System
               Technical Cyber Security Alert TA06-270A
Microsoft Internet Explorer WebViewFolderIcon ActiveX Vulnerability
   Original release date: September 27, 2006
   Last revised: --
   Source: US-CERT
Systems Affected
     * Microsoft Windows
     * Microsoft Internet Explorer
Overview
   The Microsoft Windows WebViewFolderIcon ActiveX control contains an
   integer overflow vulnerability that could allow a remote attacker
   to execute arbitrary code.
I. Description
   integer overflow vulnerability. An attacker could exploit this
   vulnerability through Microsoft Internet Explorer (IE) or any other
   application that hosts the WebViewFolderIcon control. More
   information is available in Vulnerability Note VU#753044.
   Exploit code for this vulnerability is publicly available.
II. Impact
   By convincing a user to open a specially crafted HTML document,
   such as a web page or HTML email message, a remote attacker could
   execute arbitrary code with the privileges of the user who is
   running the program that hosts the WebViewFolderIcon control.
III. Solution
   Microsoft has not released an update for this
   vulnerability. Consider the following workarounds and best
   practices:
   Disable the WebViewFolderIcon ActiveX control
     To protect against this specific vulnerability, disable the
     WebViewFolderIcon control by setting the kill bit for the
     following CLSID:
       {844F4806-E8A8-11d2-9652-00C04FC30871}
     More information about how to set the kill bit is available in
     Microsoft Support Document 240797.
   Disable ActiveX
     To protect against this and other ActiveX and COM
     vulnerabilities, disable ActiveX in the Internet Zone and any
     other zone that might be used by an attacker. Instructions for
     disabling ActiveX in the Internet Zone can be found in the
     "Securing Your Web Browser" document and the Malicious Web
     Scripts FAQ.
   Render email as plain text
     To protect against this and other vulnerabilities that require a
     victim to load a malicious HTML document, configure email clients
     to render email as plain text.
   Do not follow unsolicited links
     victim to load a malicious HTML document, do not follow
     unsolicited or untrusted links.
     In order to convince users to visit their sites, attackers often
     use URL encoding, IP address variations, long URLs, intentional
     misspellings, and other techniques to create misleading links. Do
     not click on unsolicited links received in email, instant
     messages (IMs), web forums, or internet relay chat (IRC)
     channels. Type URLs directly into the browser to avoid these
     misleading links. While these are generally good security
     practices, following these behaviors will not prevent
     exploitation of this vulnerability in all cases, particularly if
     a trusted site has been compromised or allows cross-site
     scripting.
