LandzDown Forum IRC
Started by SpyDie, July 11, 2007, 10:09:27 PM
no.
no connect.
i right clicked the greyed-out irc (white) icon as illustrated.
i put in #LandzDown as illustrated.
nothing.
stealthzone,
QuoteIt was just wut I needed   :D It works, Thanks
Gald to see you made it  :mitch: chat you for a drink later
Just a thought but is your Firewall blocking it ?
Quote from: Temmu on July 30, 2007, 02:22:13 PM
#landzdown.com
Don't forget the .com ;)
Paddy
What Firewall are you useing ??
numbnuts...
1.  i just hooked up straight to the internet with a real ip address (i have several.)
2.    I can ping irc.landzdown.com
it replies:
216.127.74.139 in 29 to 291 ms; ttl=51 - i guess i'm a good many hops away.
3.  no firewall.  windows firewall service is always set to DISABLED on my stuff.
4.  i am using trillian basic v3, just downloaded a couple of days ago.
5.  i am configured exactly as shown in the screenshots you/i have posted.
6.  i have r. clicked the white, irc icon and chosen "join a channel..." and typed exactly #LandzDown.com
and have tried #landzdown.com
7.  the perform buffer has exactly this, including the word password, everything exactly in the same case as typed here:
/ns identify password;/join #LandzDown.com
ideas? :sos:  :sinking:
Been a while... but is there a status window you can open when you right-click the white button?  It may have some message that'll explain why you're not getting in.
Temmu  :D
Hail mary pass to you.  You got connected once with Trillian so... :mitch:
Before you attempt a re-connect to Lzd chat...open Trillian...go to "Identities & Connections", clk on LandzDown via IRC > Change >and remove the checkmark in "Perform Buffer" section...save your settings, close Trill.
Re-open Trillian>Identities & Connections> Landzdown via IRC > Connect > then right click on the IRC button > Join Channel type in #LandzDown.com.
If no joy...see no open window...try a right click on the IRC Connection button (white button) and click "Show Staus Window" if you get a server window, type /join #LandzDown.com.
Let us know how you get on.
i hate to type all this, but...
reconnecting to irc as "temmu"
will attempt 10 connections with 60 second intervals
error while connecting (error code 10053).  disconnecting.
error while connecting (error code 0). disconnecting.
repeats itself with this, instead...
connecting to irc as "landzdown", attempt #4
notice how the first try was temmu, the second, landzdown...
:exorcize:  :sinking:
Well the first time you had it right with the username.
For the heck of it, try downloading a different IRC client (mIRC, Ice Chat, etc) and give that a try.  I am absolutely baffled here.  You can get out on port 6667 yes?
ugh... :flame:
See if any of this matches with the error 10053?
http://forums.ceruleanstudios.com/showthread.php?t=84555&highlight=error+code+10053
Quote from: Temmu7.  the perform buffer has exactly this, including the word password, everything exactly in the same case as typed here:
If STILL no joy...cross-reference the above with Corrine's verbal instructions in her attachment??
In the box, type /ns identify PASSWORD;/join #LandzDown.com (Substitute your desired password for the word PASSWORD).  Then click Save Settings:
Sorry...I am grabbing at straws here too  :tease:
On July 11 I tried the link it did not work( Didn't connect) tried it again on about the 13th. or 14th. I could type a mess. and send it but I could not find anyone there?  Now when I try it shuts my browser page/pages?  Dunno
Quote from: Niecarrah on July 31, 2007, 03:53:46 AM
This was using the Java applet that SpyDie posted?   http://www.landzdown.com/irc/
Which browser?  Which version of Java?
Some members are getting in and not others...still sorting...we'll get it figured out together  :mitch:
Feedback is good  8)
Yes using the Java applet that SpyDie posted.
Mozilla Firefox
The latest that is FF compatible?  The update downloads but says it is not compatible?
Info related to connecting to the LzD chatroom using the Java applet ONLY:
(Expanding details that might help others)
"imcompatibility" message thrown at the last few FF version updates refers to the Java Console.  Java should function fine in FF w/o it.  Java Console is dialogue window used more by developers.
Check to see which java plugin version your FF is using? Type about:plugins in your FF address bar.
(TIP: You can bookmark the about:plugins page once loaded for quick access in the future)
All things Java for FF and link to test your Java version and whether it is enabled in FF & IE here:
QuoteBrowserSpy - Java Information at gemal.dk will tell you whether or not Java is installed and the JRE version, even if Java is currently disabled in the browser (you can disregard any of the "Could not read" notations listed under the "Java using the applet tag:" heading).
http://kb.mozillazine.org/Java    <<<Link to BrowserSpy-Java Info at the bottom of page :Testing Java
If you are using NoScript to handle Java in FF...
Tools>Add-ons>What version of NoScript?
NoScript  1.1.6.08 (latest version listed at addons.mozilla.org today and what I have been using with no problems.)
(NOTE: NoScript Add-0n has been updating frequently, actual latest NS version today per the developer is 1.1.6.12 See changelog for details http://noscript.net/getit)
IF you have Java enabled in FF, but use NoScript to control it...
You would need to temporarily allow http://www.landzdown.com when you load the LandzDown Java applet
Alternately, you have the option to Permanently Allow http://www.landzdown.com at which case...it should show in your NoScripts whitelist. Click on the NoScript status bar icon lower rt corner>clk the S icon>Options to get to the NS console>clk the Whitelist tab, where you can review sites allowed.  I keep LandzDown in my Whitelist.
Quote from: NiecarrahI could type a mess. and send it but I could not find anyone there?
This sounds good.  Maybe no one was there. Members come & go.  The list of users currently logged in the chat room will be listed in the upper rt corner of the open window.  Ignore member names with "bot" at the end for now.
Quote from: SpyDieNote: When you use the web applet, you are automatically given a username of LzdGuest### (### = random numbers). If you want to change this, simply put this command into the message box and hit Enter: /nick NEWNICKNAME
In your case, /nick Niecarrah
This last part of changing your nick is optional, but then your LzD member name will show in the upper right corner.
