vundo problems
Started by trouble, March 02, 2008, 05:23:20 PM
Clark76
QuoteShould I turn off my mcafee firewall and virus scan for this process?
Turn off the firewall then try Jotti again.  Make sure to turn the firewall back on right after though ;)
If you get the same thing again then please navigate to this file C:\WINDOWS\LMI38.tmp.  It appears to be a file but one of the tools says that it might actually be a folder.  Please let us know.
Proud Member of ASAP
Proud Member of UNITE
trouble
I turned off the firewall and tried again, got the same response.   :(
I navigated to c:\windows and the LMI38.tmp is actually a folder as oppossed to a file.
I also have a bunch of $NtUninstall folders???  Not sure if this is normal or related to the work we have been doing?
Another wierd thing I noticed is that when McAfee runs a scan sometimes it detects items, but may not remove them or be able to remove them?
LMI38.tmp does not yield any results in a search, however, I would rather take the safe route and submit the folder for examination.
Open notepad and copy/paste the text in the code box below into it:
http://www.landzdown.com/index.php?topic=23102.msg72619#msg72619
Suspect::
Save this as CFScript.txt
Refering to the picture above, drag CFScript.txt into ComboFix.exe
When finished, it shall produce a log for you. Post that log in your next reply.
Note:
Do not mouseclick combofix's window whilst it's running. That may cause it to stall
When CF finishes running, the ComboFix log will open along with a message box--do not be alarmed.  With the above script, ComboFix will capture a file to submit for analysis.
Ensure you are connected to the internet and click OK on the message box. A browser will open. Simply follow the instructions to copy/paste/send the requested file.
SpyDie
Quote from: trouble on March 14, 2008, 02:04:43 PM
Those folders are the uninstall files relating to each individual update from Microsoft, and the service packs.
Can you tell us where McAfee is detecting those too? Does it produce any logfile?
trouble
I submitted the log file for your review.
Just in case here is copy of the log file:
ComboFix 08-03-10.1 - Mark Neary 2008-03-15 18:15:49.5 - NTFSx86
Microsoft Windows XP Professional  5.1.2600.2.1252.1.1033.18.195 [GMT -7:00]
Running from: C:\Documents and Settings\Mark Neary\Desktop\ComboFix.exe
Command switches used :: C:\Documents and Settings\Mark Neary\Desktop\CFScript.txt
* Created a new restore point
(((((((((((((((((((((((((   Files Created from 2008-02-16 to 2008-03-16  )))))))))))))))))))))))))))))))
2008-03-13 05:12 . 2008-03-13 05:13   <DIR>   d--------   C:\Program Files\Panda Security
2008-03-09 10:32 . 2008-03-09 10:32   <DIR>   d--------   C:\WINDOWS\system32\Kaspersky Lab
2008-03-09 10:32 . 2008-03-09 10:32   <DIR>   d--------   C:\Documents and Settings\All Users\Application Data\Kaspersky Lab
2008-03-03 00:16 . 2008-03-03 00:16   <DIR>   d--------   C:\Documents and Settings\Mark Neary\Application Data\Talkback
2008-03-03 00:15 . 2008-03-03 00:15   <DIR>   d--------   C:\Program Files\Common Files\xing shared
2008-03-03 00:15 . 2008-03-03 00:15   0   --a------   C:\WINDOWS\nsreg.dat
2008-03-02 23:58 . 2008-02-22 02:33   69,632   --a------   C:\WINDOWS\system32\javacpl.cpl
2008-03-02 23:57 . 2008-03-02 23:57   <DIR>   d--------   C:\Program Files\Common Files\Java
2008-03-02 08:58 . 2008-03-02 08:58   <DIR>   d--------   C:\Program Files\Trend Micro
2008-02-27 22:58 . 2008-03-13 18:43   <DIR>   d--------   C:\Documents and Settings\Mark Neary\Application Data\SpywareStop
2008-02-27 21:52 . 2008-02-27 21:52   <DIR>   d--------   C:\VundoFix Backups
2008-02-27 21:27 . 2008-02-28 16:32   <DIR>   d--------   C:\WINDOWS\LMI38.tmp
2008-03-12 13:34   ---------   d-----w   C:\Program Files\Java
2008-03-08 08:00   ---------   d-----w   C:\Program Files\Common Files\Adobe
2008-03-08 06:54   ---------   d--h--w   C:\Program Files\InstallShield Installation Information
2008-03-08 06:54   ---------   d-----w   C:\Program Files\Common Files\AnswerWorks 4.0
2008-03-08 06:43   ---------   d-----w   C:\Program Files\TurboTax
2008-03-05 02:40   3,350   --sha-w   C:\WINDOWS\system32\KGyGaAvL.sys
2008-03-03 07:15   ---------   d-----w   C:\Program Files\Real
2008-03-03 07:14   348,160   ----a-w   C:\WINDOWS\system32\msvcr71.dll
2008-03-03 07:14   ---------   d-----w   C:\Program Files\Common Files\Real
2008-02-26 05:09   ---------   d-----w   C:\Program Files\McAfee
2008-02-15 01:22   ---------   d-----w   C:\Documents and Settings\All Users\Application Data\Dell
2008-02-06 17:51   171,400   ----a-w   C:\WINDOWS\system32\drivers\mfehidk.sys
2008-01-30 04:56   ---------   d-----w   C:\Program Files\Dell Games
2008-01-30 04:55   ---------   d-----w   C:\Program Files\Eusing Free Registry Cleaner
2008-01-30 04:54   ---------   d-----w   C:\Program Files\Dell
2008-01-28 05:03   ---------   d-----w   C:\Program Files\SpywareBlaster
2008-01-11 05:53   44,544   ----a-w   C:\WINDOWS\system32\dllcache\pngfilt.dll
2007-12-19 23:01   347,136   ----a-w   C:\WINDOWS\system32\dllcache\dxtmsft.dll
2007-12-18 09:51   179,584   ------w   C:\WINDOWS\system32\dllcache\mrxdav.sys
2006-11-07 01:54   774,144   ----a-w   C:\Program Files\RngInterstitial.dll
REGEDIT4
"MSMSGS"="C:\Program Files\Messenger\msmsgs.exe" [2004-10-13 09:24 1694208]
"ctfmon.exe"="C:\WINDOWS\system32\ctfmon.exe" [2004-08-10 04:00 15360]
"swg"="C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2007-12-01 18:48 68856]
"SpywareStop"="C:\Program Files\SpywareStop\SpywareStop.exe" [ ]
"ehTray"="C:\WINDOWS\ehome\ehtray.exe" [2005-09-29 13:01 67584]
"SigmatelSysTrayApp"="stsystra.exe" [2005-03-22 23:20 339968 C:\WINDOWS\stsystra.exe]
"IAAnotif"="C:\Program Files\Intel\Intel Matrix Storage Manager\iaanotif.exe" [2005-06-17 06:56 139264]
"ATIPTA"="C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe" [2005-08-05 20:05 344064]
"DVDLauncher"="C:\Program Files\CyberLink\PowerDVD\DVDLauncher.exe" [2005-02-23 15:19 53248]
"ISUSPM Startup"="C:\Program Files\Common Files\InstallShield\UpdateService\isuspm.exe" [2005-06-10 09:44 249856]
"ISUSScheduler"="C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe" [2005-06-10 09:44 81920]
"Corel Photo Downloader"="C:\Program Files\Corel\Corel Photo Album 6\MediaDetect.exe" [2006-02-09 15:34 106496]
"dla"="C:\WINDOWS\system32\dla\tfswctrl.exe" [2005-05-31 05:33 122941]
"HP Software Update"="C:\Program Files\HP\HP Software Update\HPWuSchd2.exe" [2006-02-19 02:41 49152]
"QuickTime Task"="C:\Program Files\QuickTime\qttask.exe" [2007-11-15 00:43 286720]
"iTunesHelper"="C:\Program Files\iTunes\iTunesHelper.exe" [2007-11-15 14:11 267048]
"SunJavaUpdateSched"="C:\Program Files\Java\jre1.6.0_05\bin\jusched.exe" [2008-02-22 04:25 144784]
"TkBellExe"="C:\Program Files\Common Files\Real\Update_OB\realsched.exe" [2008-03-03 00:14 185896]
"Adobe Reader Speed Launcher"="C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2008-01-11 23:16 39792]
"InstallVisualStyle"= C:\WINDOWS\Resources\Themes\Royale\Royale.msstyles
"InstallTheme"= C:\WINDOWS\Resources\Themes\Royale.theme
[HKEY_LOCAL_MACHINE\software\microsoft\security center]
"AntiVirusDisableNotify"=dword:00000001
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\McAfeeAntiVirus]
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\McAfeeFirewall]
"EnableFirewall"= 0 (0x0)
"C:\\Program Files\\Intuit\\QuickBooks 2005\\QBDBMgrN.exe"=
"C:\\Program Files\\Messenger\\msmsgs.exe"=
"C:\\Program Files\\iTunes\\iTunes.exe"=
"C:\\Program Files\\Common Files\\McAfee\\MNA\\McNASvc.exe"=
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\explorer\mountpoints2\{361ac05d-0e0d-11da-9aa9-806d6172696f}]
\Shell\AutoRun\command - E:\setup.exe
*Newly Created Service* - CATCHME
"2008-03-10 22:36:03 C:\WINDOWS\Tasks\AppleSoftwareUpdate.job"
- C:\Program Files\Apple Software Update\SoftwareUpdate.exe
"2008-03-15 08:16:12 C:\WINDOWS\Tasks\McDefragTask.job"
- c:\PROGRA~1\mcafee\mqc\QcConsol.exe'
"2008-02-01 09:00:14 C:\WINDOWS\Tasks\McQcTask.job"
"2008-03-15 10:00:01 C:\WINDOWS\Tasks\SpywareBot Scheduled Scan.job"
- C:\Program Files\SpywareBot\SpywareBot.ex
catchme 0.3.1344 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2008-03-15 18:18:08
Windows 5.1.2600 Service Pack 2 NTFS
scanning hidden processes ...
scanning hidden files ...
scan completed successfully
hidden files: 0
Completion time: 2008-03-15 18:18:57
ComboFix-quarantined-files.txt  2008-03-16 01:18:46
ComboFix2.txt  2008-03-13 12:06:57
ComboFix3.txt  2008-03-09 17:20:53
ComboFix4.txt  2008-03-08 05:50:24
ComboFix5.txt  2008-03-06 06:30:12
2008-03-12 13:41:07   --- E O F ---
Here is a hyjack this log too:
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 6:23:33 PM, on 3/15/2008
MSIE: Internet Explorer v7.00 (7.00.6000.16608)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\Program Files\Lavasoft\Ad-Aware 2007\aawservice.exe
C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
C:\WINDOWS\eHome\ehRecvr.exe
C:\WINDOWS\eHome\ehSched.exe
C:\Program Files\Intel\Intel Matrix Storage Manager\iaantmon.exe
C:\Program Files\Common Files\McAfee\HackerWatch\HWAPI.exe
C:\PROGRA~1\McAfee\MSC\mcmscsvc.exe
c:\PROGRA~1\COMMON~1\mcafee\mna\mcnasvc.exe
C:\PROGRA~1\McAfee\VIRUSS~1\mcods.exe
C:\PROGRA~1\McAfee\MSC\mcpromgr.exe
c:\PROGRA~1\COMMON~1\mcafee\mcproxy\mcproxy.exe
c:\PROGRA~1\COMMON~1\mcafee\redirsvc\redirsvc.exe
C:\PROGRA~1\McAfee\VIRUSS~1\mcshield.exe
C:\Program Files\McAfee\MPF\MPFSrv.exe
C:\PROGRA~1\McAfee\MPS\mps.exe
C:\WINDOWS\system32\HPZipm12.exe
C:\Program Files\Canon\CAL\CALMAIN.exe
C:\WINDOWS\system32\dllhost.exe
C:\Program Files\McAfee\MPS\mpsevh.exe
c:\PROGRA~1\mcafee.com\agent\mcagent.exe
c:\PROGRA~1\mcafee\VIRUSS~1\mcvsshld.exe
C:\WINDOWS\eHome\ehmsas.exe
C:\PROGRA~1\COMMON~1\McAfee\EmProxy\emproxy.exe
C:\WINDOWS\explorer.exe
C:\WINDOWS\system32\notepad.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\PROGRA~1\McAfee\VIRUSS~1\mcsysmon.exe
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.comcast.net/
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = :0
O2 - BHO: Yahoo! Toolbar Helper - {02478D38-C3F9-4EFB-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: RealPlayer Download and Record Plugin for Internet Explorer - {3049C3E9-B461-4BC5-8870-4C09146192CA} - C:\Program Files\Real\RealPlayer\rpbrowserrecordplugin.dll
O2 - BHO: DriveLetterAccess - {5CA3D70E-1895-11CF-8E15-001234567890} - C:\WINDOWS\system32\dla\tfswshx.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - c:\PROGRA~1\mcafee\VIRUSS~1\scriptcl.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar1.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\2.0.1121.2472\swg.dll
O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar1.dll
O3 - Toolbar: Popup Killer - {2D58DD23-2759-4C7B-9351-D68AF7D0D868} - C:\PROGRA~1\POPUPR~1\popup.dll
O4 - HKLM\..\Run: [ehTray] C:\WINDOWS\ehome\ehtray.exe
O4 - HKLM\..\Run: [SigmatelSysTrayApp] stsystra.exe
O4 - HKLM\..\Run: [IAAnotif] C:\Program Files\Intel\Intel Matrix Storage Manager\iaanotif.exe
O4 - HKLM\..\Run: [ATIPTA] "C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe"
O4 - HKLM\..\Run: [DVDLauncher] "C:\Program Files\CyberLink\PowerDVD\DVDLauncher.exe"
O4 - HKLM\..\Run: [ISUSPM Startup] "C:\Program Files\Common Files\InstallShield\UpdateService\isuspm.exe" -startup
O4 - HKLM\..\Run: [ISUSScheduler] "C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe" -start
O4 - HKLM\..\Run: [Corel Photo Downloader] C:\Program Files\Corel\Corel Photo Album 6\MediaDetect.exe
O4 - HKLM\..\Run: [dla] C:\WINDOWS\system32\dla\tfswctrl.exe
O4 - HKLM\..\Run: [HP Software Update] C:\Program Files\HP\HP Software Update\HPWuSchd2.exe
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_05\bin\jusched.exe"
O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe"  -osboot
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
O4 - HKCU\..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
O4 - HKCU\..\Run: [SpywareStop] C:\Program Files\SpywareStop\SpywareStop.exe -boot
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
O9 - Extra button: ComcastHSI - {669B269B-0D4E-41FB-A3D8-FD67CA94F646} - http://www.comcast.net/ (file missing)
O9 - Extra button: Support - {8828075D-D097-4055-AA02-2DBFA9D85E8A} - http://www.comcastsupport.com/ (file missing)
O9 - Extra button: Help - {97809617-3937-4F84-B335-9BB05EF1A8D4} - http://online.comcast.net/help/ (file missing)
O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\system32\Shdocvw.dll
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O16 - DPF: {0EB0E74A-2A76-4AB3-A7FB-9BD8C29F7F75} (CKAVWebScan Object) - http://www.kaspersky.com/kos/eng/partner/default/kavwebscan_unicode.cab
O16 - DPF: {193C772A-87BE-4B19-A7BB-445B226FE9A1} (ewidoOnlineScan Control) - http://downloads.ewido.net/ewidoOnlineScan.cab
O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} -
O16 - DPF: {512FC5A1-7DE1-43F1-BC0C-371622FCB409} (TotalScan Installer Class) - http://www.nanoscan.com/as/cabs/ascstubie.cab
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} - http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
O23 - Service: Ad-Aware 2007 Service (aawservice) - Lavasoft AB - C:\Program Files\Lavasoft\Ad-Aware 2007\aawservice.exe
O23 - Service: Apple Mobile Device - Apple, Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: Canon Camera Access Library 8 (CCALib8) - Canon Inc. - C:\Program Files\Canon\CAL\CALMAIN.exe
O23 - Service: DSBrokerService - Unknown owner - C:\Program Files\DellSupport\brkrsvc.exe
O23 - Service: McAfee E-mail Proxy (Emproxy) - McAfee, Inc. - C:\PROGRA~1\COMMON~1\McAfee\EmProxy\emproxy.exe
O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: Intel(R) Matrix Storage Event Monitor (IAANTMon) - Intel Corporation - C:\Program Files\Intel\Intel Matrix Storage Manager\iaantmon.exe
O23 - Service: McAfee HackerWatch Service - McAfee, Inc. - C:\Program Files\Common Files\McAfee\HackerWatch\HWAPI.exe
O23 - Service: McAfee Update Manager (mcmispupdmgr) - McAfee, Inc. - C:\PROGRA~1\McAfee\MSC\mcupdmgr.exe
O23 - Service: McAfee Services (mcmscsvc) - McAfee, Inc. - C:\PROGRA~1\McAfee\MSC\mcmscsvc.exe
O23 - Service: McAfee Network Agent (McNASvc) - McAfee, Inc. - c:\PROGRA~1\COMMON~1\mcafee\mna\mcnasvc.exe
O23 - Service: McAfee Scanner (McODS) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcods.exe
O23 - Service: McAfee Protection Manager (mcpromgr) - McAfee, Inc. - C:\PROGRA~1\McAfee\MSC\mcpromgr.exe
O23 - Service: McAfee Proxy Service (McProxy) - McAfee, Inc. - c:\PROGRA~1\COMMON~1\mcafee\mcproxy\mcproxy.exe
O23 - Service: McAfee Redirector Service (McRedirector) - McAfee, Inc. - c:\PROGRA~1\COMMON~1\mcafee\redirsvc\redirsvc.exe
O23 - Service: McAfee Real-time Scanner (McShield) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcshield.exe
O23 - Service: McAfee SystemGuards (McSysmon) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcsysmon.exe
O23 - Service: McAfee Personal Firewall Service (MpfService) - McAfee, Inc. - C:\Program Files\McAfee\MPF\MPFSrv.exe
O23 - Service: McAfee Privacy Service (MPS9) - McAfee, Inc. - C:\PROGRA~1\McAfee\MPS\mps.exe
O23 - Service: Intel NCS NetService (NetSvc) - Intel(R) Corporation - C:\Program Files\Intel\PROSetWired\NCS\Sync\NetSvc.exe
O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\system32\HPZipm12.exe
O23 - Service: Intuit QuickBooks FCS (QBFCService) - Intuit Inc. - C:\Program Files\Common Files\Intuit\QuickBooks\FCS\Intuit.QuickBooks.FCS.exe
End of file - 10638 bytes
trouble
McAfee detects three potentially unwated programs and does not delete them.  One is called GenericPUP.g, this is located in C:\Documents and Settings\Mark Neary\Desktop\Smitfraudfix\reboot.exe.
The next one is Prcviewer located here C:\Documents and Settings\Mark Neary\Desktop\Smitfraudfix\Process.exe
The last one is called RemAdm-ProcLaunch!171 and it is located in C:\Documents and Settings\Mark Neary\Desktop\Combofix.exe
Hopefully this is the information that you were asking for.  Let me know if you need something different.
Thanks.  It is common that A/V software detects Smitfraudfix and Combofix.  We'll take care of those at the end.  I'm wondering why SpywareStop is still showing in Program Files.  We can remove the entry from Start Up, but I want to be sure the software is off your computer.
Clark76
Hello Trouble
Open notepad and copy/paste the text in the codebox below into it:
DirLook::
Registry::
"SpywareStop"=-
Save this as "CFScript"
Refering to the picture above, drag CFScript into ComboFix.exe
Then post the resultant log
Note:
Do not mouseclick combofix's window while it's running. That may cause it to stall
Post back with a new Hijackthis log also.
trouble
I went into add/remove programs and spywarestop was still there so I removed it.  Then I copied the CFScript and ran combodix.  The logs are presented below:
combofix:
ComboFix 08-03-10.1 - Mark Neary 2008-03-16 20:04:44.6 - NTFSx86
Microsoft Windows XP Professional  5.1.2600.2.1252.1.1033.18.167 [GMT -7:00]
(((((((((((((((((((((((((   Files Created from 2008-02-17 to 2008-03-17  )))))))))))))))))))))))))))))))
((((((((((((((((((((((((((((((((((((((((((((   Look   )))))))))))))))))))))))))))))))))))))))))))))))))))))))))
---- Directory of C:\WINDOWS\LMI38.tmp ----
2008-02-27 23:50   324   --a------   C:\WINDOWS\LMI38.tmp\rescue.log
REGEDIT4
"ISUSPM Startup"="c:\Program Files\Common Files\InstallShield\UpdateService\isuspm.exe" [2005-06-10 09:44 249856]
"2008-03-16 10:00:01 C:\WINDOWS\Tasks\SpywareBot Scheduled Scan.job"
Rootkit scan 2008-03-16 20:06:46
hidden files: 0
Completion time: 2008-03-16 20:07:17
ComboFix-quarantined-files.txt  2008-03-17 03:07:14
ComboFix2.txt  2008-03-16 01:18:58
ComboFix3.txt  2008-03-13 12:06:57
ComboFix4.txt  2008-03-09 17:20:53
ComboFix5.txt  2008-03-08 05:50:24
the hijackthis log:
Scan saved at 8:09:07 PM, on 3/16/2008
Boot mode: Normal
Running processes:
C:\WINDOWS\system32\msiexec.exe
O4 - HKLM\..\Run: [ISUSPM Startup] "c:\Program Files\Common Files\InstallShield\UpdateService\isuspm.exe" -startup
End of file - 10538 bytes
Clark76
We are just about there.
Please submit the following file to Jotti File Scan
At the top of the window you should see "File to Upload & Scan" and a blank box. Copy and paste the red text from above into the box. Then click "submit".
When it is finished, please copy and paste the information listed under "Service" and "Scanner Results" back in this thread.
If the site is too busy, upload it here http://www.virustotal.com/en/indexf.html
Folder::
FileLook::
Note:
Are you experiencing any problems with your computer?
trouble
here is the jotti file results
Service load:  0%        100%
File:  rescue.log
Status:  OK
MD5:  d138b481bade595e5bfc5bba9a0b65a1
Packers detected:  -
Bit9 reports:  File not found
Scanner results
Scan taken on 18 Mar 2008 04:13:39 (GMT)
A-Squared  Found nothing
AntiVir  Found nothing
ArcaVir  Found nothing
Avast  Found nothing
AVG Antivirus  Found nothing
BitDefender  Found nothing
ClamAV  Found nothing
CPsecure  Found nothing
Dr.Web  Found nothing
F-Prot Antivirus  Found nothing
F-Secure Anti-Virus  Found nothing
Fortinet  Found nothing
Ikarus  Found nothing
Kaspersky Anti-Virus  Found nothing
NOD32  Found nothing
Norman Virus Control  Found nothing
Panda Antivirus  Found nothing
Rising Antivirus  Found nothing
Sophos Antivirus  Found nothing
VirusBuster  Found nothing
VBA32  Found nothing
trouble
The computer seems to be working fine.  It is a little slow during startup, but when I get on the internet it does not have a bunch of advertisements popping up.  Seems like that part has been fixed.  Except for the items I noted above mcAfee is not detecting any more problems. :Hammys pint:
Here is the combofix log
ComboFix 08-03-10.1 - Mark Neary 2008-03-17 21:23:04.7 - NTFSx86
Microsoft Windows XP Professional  5.1.2600.2.1252.1.1033.18.207 [GMT -7:00]
C:\Documents and Settings\Mark Neary\Application Data\SpywareStop\Log\2008 Mar 07 - 03_40_20 PM_687.log
C:\Documents and Settings\Mark Neary\Application Data\SpywareStop\rs.dat
(((((((((((((((((((((((((   Files Created from 2008-02-18 to 2008-03-18  )))))))))))))))))))))))))))))))
REGEDIT4
"2008-03-17 22:36:03 C:\WINDOWS\Tasks\AppleSoftwareUpdate.job"
Rootkit scan 2008-03-17 21:25:13
hidden files: 0
Completion time: 2008-03-17 21:25:43
ComboFix-quarantined-files.txt  2008-03-18 04:25:41
ComboFix2.txt  2008-03-17 03:07:17
ComboFix3.txt  2008-03-16 01:18:58
ComboFix4.txt  2008-03-13 12:06:57
ComboFix5.txt  2008-03-09 17:20:53
Just in case here is a hijackthis log:
Scan saved at 9:27:24 PM, on 3/17/2008
Boot mode: Normal
Running processes:
End of file - 10456 bytes
Thank you very much for all of your help.  This is an awesome site that I have already told some friend and family about.   :flowers:
Clark76
Well done, your logs appear clean :thumbsup:
Go to -> Run -> copy/paste in the following single line command & click OK
combofix /u
This will uninstall ComboFix. It will also implement some cleanup procedures and reset System Restore points.
If you have not already, please make sure you have re-enabled your anti-virus, and firewall ;)
You can delete the following:
VundoFix.exe <-- located on your desktop
C:\VundoFix Backups  <-- folder
Go into the Control Panel and double-click the Java Icon. (looks like a coffee cup)
  • On the General tab, under Temporary Internet Files, click the Settings button.
  • Next, click on the Delete Files button
  • There are two options in the window to clear the cache - Leave BOTH Checked
    Applications and Applets
    Trace and Log Files
  • Click OK on Delete Temporary Files Window
    Note: This deletes ALL the Downloaded Applications and Applets from the CACHE.
  • Click OK to leave the Temporary Files Window
  • Click OK to leave the Java Control Panel.
It is very important that you get all of the critical updates for your Operating System and Internet Explorer. Keeping your OS and browser up to date will help make you less susceptible to attacks by Trojans and viruses. Please go to   Microsoft and download all the critical updates to help prevent possible re-infection.
This is a good time to set up protection against further attacks. Read TonyKlein's How Did I Get Infected In The First Place?. You need an antivirus that is continually updated, a good firewall, a spyware blocker such as Spyware Blaster, and a real time spyware program such as Spyware Guard, to prevent spyware intrusions. IE-Spyad is another excellent program that places over 4000 websites and domains in the IE Restricted list, which will help prevent attempts to infect your system. All of the above have good free versions available. However, be very wary with any security software that is advertised in popups or in other ways. They are not only usually of no use, but often have malware in them.
More information and downloads are available at the following links:
Spyware Blaster
Spyware Guard
IE-Spyad
If you want to fight back the Malware Writers that have made your life a misery, please take a look here and read what you can do against it.
Quote from: troubleThank you very much for all of your help.  This is an awesome site that I have already told some friend and family about.
I guess you're not "trouble" any longer!
Clark76, thank you for jumping in while I was tied up as well as for your earlier consultation.  Greatly appreciated!  :rose:
Clark76
No trouble at all Corrine :) and happy and safe surfing to you Trouble
