My Computer Delayed Opening Too Long
Started by E A S T E R, February 23, 2009, 06:56:49 AM
E A S T E R
I just about given up. I searched Microsoft Knowledge base and tried what was listed as a possible workaround and/or solution.
Everytime i opened My Computer on at least 2 different boxes recently, i was mysteriously met with an enormous delay and often times just accessed Disk Management console to get to my drives. A real problem in the making without a solution it seemed.
I tried an internet Google Search method of exporting .NET Oracle & SQL in the registry then entering the info back again.since it was mentioned several times as working for some but not for others.  Didn't work for me though.
Then i finally after many days of frustration ran across the absolute solution. The WMI (Windows Image Acquisition) service was sticking on "starting" but wouldn't display started, and also no way to stop the service even with the net stop command from CMD console. The solution was to disable it entirely and do a reboot, then on return, finally the My Computer drives instantly began opening & showing drives like it should again.
I have no idea what or why the WIA on some of my units shows a tendency to not fully start either in automatic or manual setting, but at least the problem was pinned down and fixed. I since always return it to MANUAL once booted up, but just wanted to share this with everyone in case they ever run into a similar problem like i experienced.
Also mentioned as a solution was to go to Internet Options, Under Browsing Section, then the ADVANCED TAB, and "uncheck" enable third party browser extensions (requires restart)
Maybe Aaron or anyone else could comment on this odd behavior i experienced recently and if it's a possibility that some imaging app on my machine was interrupting it from fully starting or something else.
At any rate, after many several days on the internet doing Google Searches, the answer surfaced and the problem ended.
EASTER
Aaron Hulett
Scanners and digital cameras come to mind.  Driver updates?
-A
This post is provided "AS IS" without warranty, and confers no rights.
E A S T E R
Quote from: Aaron Hulett - MSFT on February 23, 2009, 10:21:42 AM
-A
I believe you zeroed in on it Aaron. Thanks
I somewhat frequently tether my Olympus Camera to the PC and frankly i haven't updated any drivers for it depending on what partition i happen to be in at the time. I use Camedia and their drivers but i bet anything i been plugging into some partitions RAW without first considering if the software is installed or not, because it still transfers just fine, the same with my cellphone, but you nailed it i'm sure. It was a driver issue, or lack thereof that was prompting WIA to stall in the "starting" mode perhaps waiting for the devices to connect when there wasn't any at the time.
That was great help Aaron, thanks again. Windows having become such a multi-faceted communication and entertainment center of sorts opens all sorts of avenues that must be properly in sync with supporting circuit commands or things can get a little dicey or downright confusing.
EASTER
