Please Help! Virus of some sort and NOTHING will open.
Started by murrayr2388, May 31, 2010, 03:38:32 AM
murrayr2388
Hi,
My boyfriend has a Sony Vaio computer running Windows XP, I have no idea what year the computer is. I somehow downloaded a virus (or malware) and now nothing will open. The only thing that will come up is a security warning that says: Application cannot be executed. "The file safari.exe (or whatever I try to open, that was an example) is infected. Do you want to activate your antivirus software now?" If I click "yes" it opens up internet explorer and takes me to some site to buy the program. I have avast on the system and barely managed to get it running last night and it found 2 viruses and said it removed them. However, it only got worse. I have a mac and have been researching via it because nothing on that computer will work. If I can't fix this, I have to get him a new computer so if someone can help that would amazing.
Also, I have one other question, if we simply restore the computer to scratch would that get rid of the virus? Or would it still stay on the system?
As mentioned, I can't get anything to run on that computer so am using my mac to research.
Thank you!!
Rebecca
Hi, Rebecca.
Welcome to LandzDown Forum.
By restore, do you mean a System Restore to prior to the infection?  The success of that depends on whether you have a clean restore point.  If you mean a format, reinstall of the operating system, that would work.  If you wish to attempt to clean the computer, please proceed as instructed below.
One, Two,Three or Four
  • Double-click rkill to run.
Notes:
Next, please go to http://www.malwarebytes.org/ and download Malwarebytes' Anti-Malware to your desktop.
  • At the end, be sure a checkmark is placed next to Update Malwarebytes' Anti-Malware and Launch Malwarebytes' Anti-Malware, then click Finish.
  • Click Remove Selected.
  • When completed, a log will open in Notepad. Please save it to a convenient location. The log can also be found here on Windows XP: C:\Documents and Settings\Username\Application Data\Malwarebytes\Malwarebytes' Anti-Malware\Logs\log-date.txt and C:\Users\UserName\AppData\Roaming\Malwarebytes\Malwarebytes' Anti-Malware\Logs\log-date.txt on Windows Vista and Windows 7.
Please also go to Log Posting Instructions and follow those instructions as well.  Note that it may be necessary to create more than one reply in order to fit in all the logs.
