Microsoft windows internal protect
Started by sdivad87, January 14, 2006, 04:12:52 PM
sdivad87
Hey this is my first post here so I don't know if this is the right topic area but I recently found out I have a problem. From time to time when I use my computer or when I reboot, I get a message in the corner of my taskbar that says: (word for word)
Microsoft Windows has detected abnormal activity on your computer
Attention: Your system has been infected
Your PC Status:
OS Type: Windows
IP: (has IP listed)
Infected files: 11%
Spyware detected: HIGH RISK
Recommendations: Install spyware and antivirus software and clear your system. Spyware can be easily detected and removed with a free spyware scanner available for download at the link below
(Then it has a button "Next page" that I am allegedly supposed to click)
When I click on X button on the top a window comes out with:
Do you really want to exit? Information on your PC may be corrupted
(with a "Microsoft windows internal protect" heading)
I ran spyware scanners such as Ad-aware and Spybot and ran virus scanners and although they detected spyware items and I removed them from my computer, this was still exists. Any suggestions would be very appreciated. Thanks.
sdivad87,
I recommend that you try this shoot  the messenger
Also can you make sure that you are using
Ad-aware SE Build 106 (Free/Personal)
Then use the WebUpDate
(SE1R.85.04.01.2006)
To do this Open Ad-aware
Click the WebUpDate
button at the top right hand side of the Ad-aware screen (The world globe).
Click "Connect"
Ad-aware will then download the latest  Definition file for you.
To make sure it is updated , look at the main
Ad-aware screen, and look under "Initialization Status"
It should say the Latest Definition file.
As Logs are stored in :
C:\Documents and Settings\USERNAME\Application Data\Lavasoft\Ad-aware\Logs\.
An easy way to get there is to
click Start,
click Run
And type in and press ENTER: %appdata%
then click  Lavasoft
then Ad-Aware
and then Logs.
scroll down to find the latest one that you have
(by date & time)
(note The Application Data is a hidden folder, so you will need to show hidden files and folders
and for Windows 98/ME users your logs are stored in
C:\WINDOWS\All Users\Application Data\ ) by default
GR@PH;<'S   :breakkie:
sdivad87
Ok here are the scan results:
Ad-Aware SE Build 1.06r1
Logfile Created on:Saturday, January 14, 2006 5:46:46 PM
Using definitions file:SE1R86 11.01.2006
MRU List(TAC index:0):55 total references
Tracking Cookie(TAC index:3):1 total references
Ad-Aware SE Settings
Set : Scan active processes
Set : Scan registry
Set : Deep-scan registry
Set : Scan my Hosts file
Extended Ad-Aware SE Settings
Set : Ignore spanned files when scanning cab archives
Set : Block pop-ups aggressively
Set : Automatically select problematic objects in results lists
Set : Show splash screen
Set : Backup current definitions file before updating
1-14-2006 5:46:46 PM - Scan started. (Full System Scan)
MRU List Object Recognized!
    Location:          : C:\Documents and Settings\David\Application Data\microsoft\office\recent
    Description        : list of recently opened documents using microsoft office
    Location:          : C:\Documents and Settings\David\recent
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\adobe\acrobat reader\6.0\avgeneral\crecentfiles
    Description        : list of recently used files in adobe reader
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\ahead\nero - burning rom\recent file list
    Description        : list of recently used files in nero burning rom
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\clipart gallery\2.0\mrudescription
    Description        : most recently used description in microsoft clipart gallery
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\direct3d\mostrecentapplication
    Description        : most recent application to use microsoft direct3d
    Location:          : software\microsoft\direct3d\mostrecentapplication
    Description        : most recent application to use microsoft direct X
    Location:          : software\microsoft\directdraw\mostrecentapplication
    Description        : most recent application to use microsoft directdraw
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\directinput\mostrecentapplication
    Description        : most recent application to use microsoft directinput
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\internet explorer
    Description        : last download directory used in microsoft internet explorer
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\internet explorer\main
    Description        : last save directory used in microsoft internet explorer
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\internet explorer\typedurls
    Description        : list of recently entered addresses in microsoft internet explorer
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\mediaplayer\medialibraryui
    Description        : last selected node in the microsoft windows media player media library
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\mediaplayer\player\settings
    Description        : last save as directory used in jasc paint shop pro
    Description        : last open directory used in jasc paint shop pro
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\mediaplayer\preferences
    Description        : last cd record path used in microsoft windows media player
    Description        : last playlist index loaded in microsoft windows media player
    Location:          : .DEFAULT\software\microsoft\mediaplayer\preferences
    Description        : last playlist loaded in microsoft windows media player
    Location:          : S-1-5-18\software\microsoft\mediaplayer\preferences
    Location:          : S-1-5-19\software\microsoft\mediaplayer\preferences
    Location:          : S-1-5-20\software\microsoft\mediaplayer\preferences
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\microsoft management console\recent file list
    Description        : list of recent snap-ins used in the microsoft management console
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\office\11.0\common\open find\microsoft office powerpoint\settings\insert picture\file name mru
    Description        : list of recent pictured inserted in microsoft powerpoint
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\office\11.0\common\open find\microsoft office word\settings\open\file name mru
    Description        : list of recent documents opened by microsoft word
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\office\11.0\common\open find\microsoft office word\settings\save as\file name mru
    Description        : list of recent documents saved by microsoft word
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\office\11.0\powerpoint\recent file list
    Description        : list of recent files used by microsoft powerpoint
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\office\11.0\publisher\recent file list
    Description        : list of recent files used by microsoft publisher
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\office\9.0\common\open find\microsoft powerpoint\settings\insert picture\file name mru
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\office\9.0\common\open find\microsoft powerpoint\settings\save as\file name mru
    Description        : list of recent documents saved by microsoft powerpoint
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\office\9.0\common\open find\microsoft word\settings\open\file name mru
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\office\9.0\common\open find\microsoft word\settings\save as\file name mru
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\office\9.0\powerpoint\recent file list
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\office\9.0\powerpoint\recent typeface list
    Description        : list of recently used typefaces in microsoft powerpoint
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\office\9.0\publisher\recent file list
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\search assistant\acmru
    Description        : list of recent search terms used with the search assistant
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\windows\currentversion\applets\paint\recent file list
    Description        : list of files recently opened using microsoft paint
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\windows\currentversion\applets\regedit
    Description        : last key accessed using the microsoft registry editor
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\windows\currentversion\applets\wordpad\recent file list
    Description        : list of recent files opened using wordpad
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\windows\currentversion\explorer\comdlg32\lastvisitedmru
    Description        : list of recent programs opened
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\windows\currentversion\explorer\comdlg32\opensavemru
    Description        : list of recently saved files, stored according to file extension
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\windows\currentversion\explorer\recentdocs
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\windows\currentversion\explorer\runmru
    Description        : mru list for items opened in start | run
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\nico mak computing\winzip\filemenu
    Description        : winzip recently used archives
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\nvidia corporation\global\nview\windowmanagement
    Description        : nvidia nview cached application window positions
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\realnetworks\realplayer\6.0\preferences
    Description        : list of recent skins in realplayer
    Description        : list of recent clips in realplayer
    Description        : last login time in realplayer
    Location:          : .DEFAULT\software\microsoft\windows media\wmsdk\general
    Description        : windows media sdk
    Location:          : S-1-5-18\software\microsoft\windows media\wmsdk\general
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\microsoft\windows media\wmsdk\general
    Location:          : S-1-5-21-790525478-1935655697-854245398-1003\software\winrar\dialogedithistory\extrpath
    Description        : winrar "extract-to" history
sdivad87
Listing running processes
#:1 [smss.exe]
    FilePath           : \SystemRoot\System32\
    ProcessID          : 908
    ThreadCreationTime : 1-14-2006 3:55:46 PM
    BasePriority       : Normal
#:2 [csrss.exe]
    FilePath           : \??\C:\WINDOWS\system32\
    ProcessID          : 1008
    ThreadCreationTime : 1-14-2006 3:55:54 PM
#:3 [winlogon.exe]
    ProcessID          : 1032
    ThreadCreationTime : 1-14-2006 3:55:57 PM
    BasePriority       : High
#:4 [services.exe]
    ProcessID          : 1080
    ThreadCreationTime : 1-14-2006 3:55:58 PM
    FileVersion        : 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
    ProductVersion     : 5.1.2600.2180
#:5 [lsass.exe]
    ProcessID          : 1092
#:6 [svchost.exe]
    ProcessID          : 1260
    ThreadCreationTime : 1-14-2006 3:55:59 PM
#:7 [svchost.exe]
    ProcessID          : 1328
    ThreadCreationTime : 1-14-2006 3:56:00 PM
#:8 [svchost.exe]
    ProcessID          : 1452
#:9 [svchost.exe]
    ProcessID          : 1500
#:10 [svchost.exe]
    ProcessID          : 1680
    ThreadCreationTime : 1-14-2006 3:56:01 PM
#:11 [ccsetmgr.exe]
    FilePath           : C:\Program Files\Common Files\Symantec Shared\
    ProcessID          : 2004
    ThreadCreationTime : 1-14-2006 3:56:03 PM
    FileVersion        : 104.0.4.3
    ProductVersion     : 104.0.4.3
    ProductName        : Client and Host Security Platform
    CompanyName        : Symantec Corporation
    FileDescription    : Symantec Settings Manager Service
    InternalName       : ccSetMgr
    LegalCopyright     : Copyright (c) 2000-2005 Symantec Corporation. All rights reserved.
    OriginalFilename   : ccSetMgr.exe
#:12 [ccevtmgr.exe]
    ProcessID          : 332
    ThreadCreationTime : 1-14-2006 3:56:06 PM
    FileDescription    : Symantec Event Manager Service
    InternalName       : ccEvtMgr
    OriginalFilename   : ccEvtMgr.exe
#:13 [sndsrvc.exe]
    ProcessID          : 532
    ThreadCreationTime : 1-14-2006 3:56:07 PM
    FileVersion        : 6.0.0.99
    ProductVersion     : 6.0
    ProductName        : Symantec Security Drivers
    FileDescription    : Network Driver Service
    InternalName       : SndSrvc
    LegalCopyright     : Copyright 2002 - 2005 Symantec Corporation
    OriginalFilename   : SndSrvc.exe
#:14 [spbbcsvc.exe]
    FilePath           : C:\Program Files\Common Files\Symantec Shared\SPBBC\
    ProcessID          : 576
    FileVersion        : 2,0,0,73
    ProductVersion     : 2,0,0,73
    ProductName        : SPBBC
    FileDescription    : SPBBC Service
    InternalName       : SPBBCSvc
    LegalCopyright     : Copyright (c) 2004, 2005 Symantec Corporation. All rights reserved.
    OriginalFilename   : SPBBCSvc.exe
#:15 [spoolsv.exe]
    ProcessID          : 688
    FileVersion        : 5.1.2600.2696 (xpsp_sp2_gdr.050610-1519)
    ProductVersion     : 5.1.2600.2696
#:16 [explorer.exe]
    ProcessID          : 1412
    ThreadCreationTime : 1-14-2006 3:56:12 PM
    FileVersion        : 6.00.2900.2180 (xpsp_sp2_rtm.040803-2158)
    ProductVersion     : 6.00.2900.2180
    InternalName       : explorer
#:17 [ccapp.exe]
    ProcessID          : 1784
    ThreadCreationTime : 1-14-2006 3:56:16 PM
    FileDescription    : Symantec User Session
    InternalName       : ccApp
    OriginalFilename   : ccApp.exe
#:18 [drgtodsc.exe]
    FilePath           : C:\Program Files\Roxio\Easy Media Creator 8\Drag to Disc\
    ProcessID          : 1808
    FileVersion        : 8.0.1.60
    ProductVersion     : 8.0.1.60
    ProductName        : Drag-to-Disc
    CompanyName        : Sonic Solutions
    FileDescription    : Drag To Disc Application
    InternalName       : D2D
    LegalCopyright     : Copyright (c) 1994-2005 Sonic Solutions
    LegalTrademarks    : Copyright (c) 1994-2005 Sonic Solutions
    OriginalFilename   : BurnCtrl.EXE
#:19 [icasserv.exe]
    ProcessID          : 1816
#:20 [wlancfg5.exe]
    FilePath           : C:\Program Files\NETGEAR WG311v2 Adapter\
    ProcessID          : 1912
    ThreadCreationTime : 1-14-2006 3:56:17 PM
    FileVersion        : 2, 0, 0, 7
    ProductVersion     : 2, 0, 0, 7
    ProductName        : NetgearCUv2 Application
    FileDescription    : NetgearCUv2 MFC Application
    InternalName       : NETGEAR WG511v2 Smart Configuration
    LegalCopyright     : Copyright (C) 2003
    OriginalFilename   : NetgearCUv2.EXE
#:21 [aluschedulersvc.exe]
    FilePath           : C:\Program Files\Symantec\LiveUpdate\
    ProcessID          : 1980
    ThreadCreationTime : 1-14-2006 3:56:18 PM
    FileVersion        : 3.0.0.150
    ProductVersion     : 3.0.0.150
    ProductName        : LiveUpdate
    FileDescription    : Automatic LiveUpdate Scheduler Service
    InternalName       : Automatic LiveUpdate Scheduler Service
    LegalCopyright     : Copyright © 1996-2005 Symantec Corporation
    OriginalFilename   : ALUSchedulerSvc.exe
#:22 [devldr32.exe]
    ProcessID          : 220
    ThreadCreationTime : 1-14-2006 3:56:20 PM
    FileVersion        : 1, 0, 0, 17
    ProductVersion     : 1, 0, 0, 17
    ProductName        : Creative Ring3 NT Inteface
    CompanyName        : Creative Technology Ltd.
    FileDescription    : DevLdr32
    InternalName       : DevLdr
    LegalCopyright     : Copyright (C) Creative Technology Ltd. 1998-2001
    OriginalFilename   : DevLdr32.exe
#:23 [navapsvc.exe]
    FilePath           : C:\Program Files\Norton AntiVirus\
    ProcessID          : 416
    ThreadCreationTime : 1-14-2006 3:56:21 PM
    FileVersion        : 12.1.0.20
    ProductVersion     : 12.1.0
    ProductName        : Norton AntiVirus
    FileDescription    : Norton AntiVirus Auto-Protect Service
    InternalName       : NAVAPSVC
    LegalCopyright     : Norton AntiVirus 2006 for Windows 2000/XP Copyright © 2005 Symantec Corporation. All rights reserved.
    OriginalFilename   : NAVAPSVC.EXE
#:24 [npfmntor.exe]
    FilePath           : C:\Program Files\Norton AntiVirus\IWP\
    ProcessID          : 528
    ThreadCreationTime : 1-14-2006 3:56:23 PM
    FileDescription    : Norton AntiVirus Firewall Install Monitor
    InternalName       : NPFMonitor
    OriginalFilename   : NPFMonitor.EXE
#:25 [nvsvc32.exe]
    ProcessID          : 564
    ThreadCreationTime : 1-14-2006 3:56:24 PM
    FileVersion        : 6.14.10.8185
    ProductVersion     : 6.14.10.8185
    ProductName        : NVIDIA Driver Helper Service, Version 81.85
    CompanyName        : NVIDIA Corporation
    FileDescription    : NVIDIA Driver Helper Service, Version 81.85
    InternalName       : NVSVC
    LegalCopyright     : (C) NVIDIA Corporation. All rights reserved.
    OriginalFilename   : nvsvc32.exe
#:26 [wrsssdk.exe]
    FilePath           : C:\Program Files\Webroot\Spy Sweeper\
    ProcessID          : 996
    ThreadCreationTime : 1-14-2006 3:56:26 PM
    FileVersion        : 2,0,8,483
    ProductName        : Spy Sweeper SDK
    CompanyName        : Webroot Software, Inc.
    FileDescription    : Spy Sweeper SDK
    LegalCopyright     : Copyright (C) 2002 - 2005, All Rights Reserved.
    LegalTrademarks    : Spy Sweeper is a trademark of Webroot Software, Inc.
    OriginalFilename   : SpySweeper.exe
#:27 [symlcsvc.exe]
    FilePath           : C:\Program Files\Common Files\Symantec Shared\CCPD-LC\
    ProcessID          : 2168
    ThreadCreationTime : 1-14-2006 3:56:38 PM
    FileVersion        : 1.9.1.762
    ProductVersion     : 1.9.1.762
    ProductName        : Symantec Core Component
    FileDescription    : Symantec Core Component
    InternalName       : symlcsvc
    OriginalFilename   : symlcsvc.exe
#:28 [wdfmgr.exe]
    ProcessID          : 2192
    ThreadCreationTime : 1-14-2006 3:56:39 PM
    FileVersion        : 5.2.3790.1230 built by: dnsrv(bld4act)
    ProductVersion     : 5.2.3790.1230
    FileDescription    : Windows User Mode Driver Manager
    InternalName       : WdfMgr
    OriginalFilename   : WdfMgr.exe
#:29 [savscan.exe]
    ProcessID          : 3476
    ThreadCreationTime : 1-14-2006 3:57:03 PM
    FileVersion        : 9.7.0.10
    ProductVersion     : 9.7
    ProductName        : Symantec AntiVirus AutoProtect
    FileDescription    : AutoProtect
    InternalName       : SAVSCAN
    LegalCopyright     : Copyright (c) 2005 Symantec Corporation
    OriginalFilename   : SAVSCAN.EXE
#:30 [alg.exe]
    ProcessID          : 3896
    ThreadCreationTime : 1-14-2006 3:57:07 PM
    FileDescription    : Application Layer Gateway Service
    InternalName       : ALG.exe
    OriginalFilename   : ALG.exe
#:31 [nscsrvce.exe]
    FilePath           : C:\Program Files\Common Files\Symantec Shared\Security Console\
    ProcessID          : 1212
    ThreadCreationTime : 1-14-2006 3:57:20 PM
    FileVersion        : 2006.1.3.2
    ProductVersion     : 2006.1.3
    ProductName        : Norton Security Console
    FileDescription    : Norton Security Console Norton Protection Center Service
    InternalName       : NSCService
    LegalCopyright     : Norton Security Console 2006 for Windows 2000/XP Copyright © 2005 Symantec Corporation. All rights reserved.
    OriginalFilename   : NSCSrvce.exe
#:32 [btdownloadgui.exe]
    FilePath           : C:\Program Files\bittorrent2\BitTornado\
    ProcessID          : 2304
    ThreadCreationTime : 1-14-2006 4:54:07 PM
#:33 [ad-aware.exe]
    FilePath           : C:\Program Files\Lavasoft\Ad-Aware SE Professional\
    ProcessID          : 4004
    ThreadCreationTime : 1-14-2006 10:44:43 PM
    FileVersion        : 6.2.0.238
    ProductVersion     : SE 106
Memory scan result:
New critical objects: 0
Objects found so far: 55
Started registry scan
Registry Scan result:
Started deep registry scan
Deep registry scan result:
Started Tracking Cookie scan
Tracking Cookie Object Recognized!
    Type               : IECache Entry
    Data               : david@live365[1].txt
    TAC Rating         : 3
    Category           : Data Miner
    Comment            : Hits:1
    Value              : Cookie:david@live365.com/
    Expires            : 1-18-2011 4:19:22 PM
    LastSync           : Hits:1
    UseCount           : 0
    Hits               : 1
Tracking cookie scan result:
New critical objects: 1
Objects found so far: 56
Disk Scan Result for C:\
Deep scanning and examining files (D:)
Disk Scan Result for D:\
Scanning Hosts file......
Hosts file scan result:
1 entries scanned.
New critical objects:0
Conditional scan result:
6:22:15 PM Scan Complete
Summary Of This Scan
Total scanning time:00:35:28.460
Objects scanned:185314
Objects identified:1
Objects ignored:0
New critical objects:1
sdivad87,
go to Add and Remove and scroll down and remove the icasserv.exe as this
Quote#:19 [icasserv.exe]
is a
QuoteBrowser hijacker, redirecting to Searchforfree.info. Also detected as the ICASERV-A TROJAN!
once you have removved I recommend that you  Reboot (ie: Re-start your PC)
Then do a trojan scan with a dedicated trojan scanner ie:TrojanHunter (Note Trojan Scanner 30 day Trial)
or a2
(Either way chech for updates before scanning)
then remove any think that the scan find then Reboot (ie: Re-start your PC)
Then once you have done clear out your cache folder again ie: Run
CCleaner
(Note in CCleaner: go to >options > advanced > Uncheck "Only delete files in Windows Temp folders older than 48 hours").
then rescan with Ad-aware doing a  "Full Scan"  and post your logfile here by using the "Add-reply" feature
sdivad87
I couldn't find it in my Add/Remove Programs but I did find it in my Registry when I searched for the key.  I deleted it from my Registry and I will post the Ad-aware results when finished. I had one question though. One of the ICASSERV.exe keys was found in my Webroot Spy Sweeper folder. Does that mean this program is infected and I should remove/uninstall it?
sdivad87,
QuoteICASSERV.exe keys was found in my Webroot Spy Sweeper folder. Does that mean this program is infected It may be in there Quaratine folder if you have had it already removed with there programand I should remove/uninstall it?
if you have already tried to remove it using there program then it is more than lighly in there quarantine folder
to clean up the left overs can you please download
HijackThis
After you have downloaded  it and Unzipped it, doubleclick HijackThis.exe, and hit "Scan".
When the scan is finished, the "Scan" button will change into a "Save Log" button.
Press that, save the log somewhere, and then can you please post you Logfile in the
HijackThis Logs  forum.
Call it some ting like "my HijachThis log" in the Topic Title
and then put "referred by GR@PH;<'S" as the Topic Description
Also Please can you include a link to this post for reference
sdivad87
Here are my Ad-aware scan results:
Logfile Created on:Sunday, January 15, 2006 1:53:54 PM
MRU List(TAC index:0):28 total references
Set : Scan registry
1-15-2006 1:53:54 PM - Scan started. (Full System Scan)
#:1 [smss.exe]
    ProcessID          : 500
    ThreadCreationTime : 1-15-2006 6:49:36 PM
#:2 [csrss.exe]
    ProcessID          : 564
    ThreadCreationTime : 1-15-2006 6:49:43 PM
#:3 [winlogon.exe]
    ProcessID          : 588
    ThreadCreationTime : 1-15-2006 6:49:47 PM
    BasePriority       : High
#:4 [services.exe]
    ProcessID          : 636
#:5 [lsass.exe]
    ProcessID          : 648
#:6 [svchost.exe]
    ProcessID          : 804
    ThreadCreationTime : 1-15-2006 6:49:49 PM
#:7 [svchost.exe]
    ProcessID          : 872
#:8 [svchost.exe]
    ProcessID          : 908
#:9 [svchost.exe]
    ProcessID          : 956
#:10 [svchost.exe]
    ProcessID          : 1020
    ThreadCreationTime : 1-15-2006 6:49:50 PM
#:11 [ccsetmgr.exe]
    ProcessID          : 1100
    ThreadCreationTime : 1-15-2006 6:49:52 PM
#:12 [ccevtmgr.exe]
    ProcessID          : 1128
    ThreadCreationTime : 1-15-2006 6:49:54 PM
#:13 [explorer.exe]
    ProcessID          : 1304
    ThreadCreationTime : 1-15-2006 6:49:57 PM
#:14 [sndsrvc.exe]
    ProcessID          : 1336
    ThreadCreationTime : 1-15-2006 6:49:58 PM
sdivad87
#:15 [spbbcsvc.exe]
    ProcessID          : 1376
    ProductName        : SPBBC
#:16 [spoolsv.exe]
    ProcessID          : 1504
    ThreadCreationTime : 1-15-2006 6:49:59 PM
#:17 [aluschedulersvc.exe]
    ProcessID          : 1648
    ThreadCreationTime : 1-15-2006 6:50:01 PM
#:18 [ccapp.exe]
    ProcessID          : 1788
    ThreadCreationTime : 1-15-2006 6:50:03 PM
#:19 [drgtodsc.exe]
    ProcessID          : 1856
    ThreadCreationTime : 1-15-2006 6:50:04 PM
    InternalName       : D2D
#:20 [navapsvc.exe]
    ProcessID          : 1928
    ThreadCreationTime : 1-15-2006 6:50:05 PM
#:21 [npfmntor.exe]
    ProcessID          : 1968
    ThreadCreationTime : 1-15-2006 6:50:08 PM
#:22 [nvsvc32.exe]
    ProcessID          : 2024
    ThreadCreationTime : 1-15-2006 6:50:09 PM
#:23 [wlancfg5.exe]
    ProcessID          : 264
    ThreadCreationTime : 1-15-2006 6:50:10 PM
#:24 [symlcsvc.exe]
    ProcessID          : 292
    ThreadCreationTime : 1-15-2006 6:50:12 PM
#:25 [devldr32.exe]
    ProcessID          : 316
#:26 [wdfmgr.exe]
    ProcessID          : 544
    ThreadCreationTime : 1-15-2006 6:50:16 PM
#:27 [savscan.exe]
    ProcessID          : 2640
    ThreadCreationTime : 1-15-2006 6:51:09 PM
#:28 [wuauclt.exe]
    ProcessID          : 2748
    ThreadCreationTime : 1-15-2006 6:51:21 PM
    FileVersion        : 5.8.0.2469 built by: lab01_n(wmbla)
    ProductVersion     : 5.8.0.2469
    FileDescription    : Automatic Updates
    InternalName       : wuauclt.exe
    OriginalFilename   : wuauclt.exe
#:29 [ad-aware.exe]
    ProcessID          : 2812
    ThreadCreationTime : 1-15-2006 6:51:23 PM
#:30 [alg.exe]
    ProcessID          : 2896
    ThreadCreationTime : 1-15-2006 6:51:45 PM
#:31 [nscsrvce.exe]
    ProcessID          : 2940
    ThreadCreationTime : 1-15-2006 6:51:48 PM
Memory scan result:
Objects found so far: 28
1 entries scanned.
2:29:06 PM Scan Complete
Total scanning time:00:35:11.607
Objects scanned:174389
Objects identified:0
Objects ignored:0
sdivad87,
You can safely remove the MRU's items that Ad-aware finds, or you can un-check / un-tick the the option to scan for them ie:un-check the "Search for negligible risk entries" .
SpiritWind
 :)  Sdivad87 :
    I see you took my advise on the pcmag.com "Discussion" forums & came here for
    help; as you probably realize by now you have made an excellent decision.
    One note : It is best to uncheck the "Search for negligible risk entries" settings
    so that the no-threat "MRU"s do NOT show up in the logfile. And it is usually
    recommended to "check" the "Search for low-risk threats".
    I see the "icasserv.exe" is gone from your "Running Processes" .
www.tacf.org
SpiritWind,
QuoteI see you took my advise on the pcmag.com "Discussion" forums & came here for
     help
Thanks for getting the word out in the big wide world
sdivad87
Hehe hey Spiritwind,
Yes I am glad I came here =]
So just one quick question, the negligible entries Ad-aware found, should I get rid of them or not? (because GR@PH you said I could while Spiritwind thinks it's best not to?) For future reference though, I will uncheck the scan of those kind of entries.
SpiritWind
 :) sdivad87 :
     GR@PH;<'S said it is ok to delete them; I said uncheck the "Search for negligible
     risk entries" setting so that they will NOT show up in the logfile. If they do not
     show up in logfile, there is no need to delete what has not shown up.
www.tacf.org
sdivad87,
Negligible risk entries are not considered to be a threat. They consist of MRU (Most Recently Used items) lists which store information about the most recently used items, for example files, search words and programs.
So if you want the MRU lists can be removed.
Some tend to un-check / un-tick the Search for negligible risk entries and select it say once a week then remove it (or month depending on there PC usage)
