Links misdirected and can't update Windows
Started by need33zapper, September 24, 2010, 12:55:39 AM
need33zapper
Am trying to fix this computer without success, obviously....
It is a Dell Inc OptiPlex 740 - WinXP SP3.  Wanted to do
a complete recovery, but there are no disks, and apparently
no way to do that (I couldn't find a way, anyway).
Did a restore to back a few days after this nasty bug showed
up, but when there was no fix, could not go back to any
other previous date.
I'm ready to cry "Uncle!"  What now??   Thank you.
Hi, need33zapper.  Welcome to LandzDown Forum.
The Google Redirect infection (aka Win32/Olmarik, Rootkit.Win32.TDSS.u, Win32/Alureon.F, Backdoor.Tidserv!.inf) hijacks your browsers to divert search engines to malware sites. Another symptom is getting the error message "DCOM server protocol launcher server terminated".
It is important that you follow these instructions carefully and do not run any other tools.
1) Safety precautions -- Because you will not always have access to these instructions, please print or save them in Notepad for easy reference.
Backup Your Registry with ERUNT
  • Please use the following link and scroll down to ERUNT and download it.
    http://aumha.org/freeware/freeware.php
  • For version with the Installer:
    Use the setup program to install ERUNT on your computer
[li]For the zipped version:
Unzip all the files into a folder of your choice.
[/li][/list]Click Erunt.exe to backup your registry to the folder of your choice.
Note: to restore your registry, go to the folder and start ERDNT.exe
Please download OTM
  • Save it to your desktop.
  • Please double-click OTM to run it. (Note: If you are running on Vista, right-click on the file and choose Run As Administrator).
  • Copy the lines in the codebox below to the clipboard by highlighting ALL of them and pressing CTRL + C (or, after highlighting, right-click and choose Copy):
:Files
ipconfig /flushdns /c
:Commands
[purity]
[resethosts]
[emptytemp]
[CREATERESTOREPOINT]
[EMPTYFLASH]
[Reboot]
  • Return to OTM, right click in the "Paste Instructions for Items to be Moved" window (under the yellow bar) and choose Paste.
  • Click the red Moveit! button.
  • Copy everything in the Results window (under the green bar) to the clipboard by highlighting ALL of them and pressing CTRL + C (or, after highlighting, right-click and choose copy), and paste it in your next reply.
  • Close OTM and reboot your PC.
Note: If a file or folder cannot be moved immediately you may be asked to reboot the machine to finish the move process. If you are asked to reboot the machine choose Yes.
2) Cleanup
Please download GooredFix from one of the locations below and save it to your Desktop
Download Mirror #1
Download Mirror #2
  • Ensure all Firefox windows are closed.
  • To run the tool, double-click it (XP), or right-click and select Run As Administrator (Vista).
  • When prompted to run the scan, click Yes.
  • It doesn't take long to run, once it is finished move onto the next step
Please read carefully and follow these steps.
  • Download TDSSKiller and save it to your Desktop.
  • Extract its contents to your desktop.
  • Once extracted, open the TDSSKiller folder and double-click on TDSSKiller.exe to run the application, then on Start Scan.
  • If an infected file is detected, the default action will be Cure, click on Continue.
  • If a suspicious file is detected, the default action will be Skip, click on Continue.
  • It may ask you to reboot the computer to complete the process. Click on Reboot Now.
So that I can determine all is well, after completing the above steps, please do the following:
  • Download random's system information tool (RSIT) by random/random from here and save it to your desktop.
  • Double click on RSIT.exe to run RSIT.
  • Once it has finished, two logs will open. Please post the contents of both log.txt (<<will be maximized) and info.txt (<<will be minimized)
need33zapper
Thanks for replying.  I was only able to begin the process you describe.
Downloaded ERUNT and ran it, but could not access the OTM link.
I'll have to go to the other computer, go to the links you provided,
save them to disk, and install them on this computer.
need33zapper
Did as I said in my last message.  Started the
OTM, but it is hung up while trying to put the
list of items in the Results box.
need33zapper
Turned off the computer and started it again.  Notepad
appeared on the desktop and said this:
All processes killed
========== FILES ==========
< ipconfig /flushdns /c >
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
C:\Documents and Settings\Tony\Desktop\fixes\cmd.bat deleted successfully.
C:\Documents and Settings\Tony\Desktop\fixes\cmd.txt deleted successfully.
========== COMMANDS ==========
C:\WINDOWS\System32\drivers\etc\Hosts moved successfully.
HOSTS file reset successfully
[EMPTYTEMP]
User: Administrator
->Temp folder emptied: 0 bytes
->Temporary Internet Files folder emptied: 308528 bytes
User: All Users
User: Default User
->Temporary Internet Files folder emptied: 32902 bytes
->Flash cache emptied: 41620 bytes
User: LocalService
->Temp folder emptied: 65748 bytes
->Temporary Internet Files folder emptied: 11777843 bytes
->Flash cache emptied: 3578 bytes
User: NetworkService
->Temporary Internet Files folder emptied: 329733492 bytes
->Java cache emptied: 4384200 bytes
->Flash cache emptied: 68200 bytes
User: Tony
->Temp folder emptied: 15547088 bytes
->Temporary Internet Files folder emptied: 10487246 bytes
->Java cache emptied: 68215581 bytes
->FireFox cache emptied: 41827911 bytes
->Flash cache emptied: 420921 bytes
%systemdrive% .tmp files removed: 0 bytes
%systemroot% .tmp files removed: 199793 bytes
%systemroot%\System32 .tmp files removed: 2577 bytes
%systemroot%\System32\dllcache .tmp files removed: 0 bytes
%systemroot%\System32\drivers .tmp files removed: 0 bytes
Windows Temp folder emptied: 1235511 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temp folder emptied: 0 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 33170 bytes
RecycleBin emptied: 0 bytes
Total Files Cleaned = 462.00 mb
Restore point Set: OTM Restore Point (0)
OTM by OldTimer - Version 3.1.16.1 log created on 09242010_164111
Files moved on Reboot...
File C:\WINDOWS\temp\_avast5_\Webshlock.txt not found!
Registry entries deleted on Reboot...
What should I do now?
Hi, need33zapper.
That was the "preparation part.  OTM removed a lot of temp files from your computer.  Now you need to move on the part 2) Cleanup.  When that is completed, please post the RSIT log and let me know if you are still getting redirects.
need33zapper
Did as you said.  Only see the contents of one log.
Here it is:
Logfile of random's system information tool 1.08 (written by random/random)
Run by Tony at 2010-09-24 23:11:02
Microsoft Windows XP Home Edition Service Pack 3
System drive C: has 65 GB (86%) free of 76 GB
Total RAM: 446 MB (29% free)
Scan saved at 11:11:20 PM, on 9/24/2010
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v8.00 (8.00.6001.18702)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\Program Files\Alwil Software\Avast5\AvastSvc.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\stsystra.exe
C:\Program Files\HP\HP Software Update\HPWuSchd2.exe
C:\Program Files\Portrait Displays\Pivot Software\wpctrl.exe
C:\Program Files\Alwil Software\Avast5\avastUI.exe
C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe
C:\Program Files\Dell Support\DSAgnt.exe
C:\Program Files\Digital Line Detect\DLG.exe
C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
C:\Program Files\PrintKey2000\Printkey2000.exe
C:\Program Files\Acer Display\eDisplay Management\DTHtml.exe
C:\Program Files\Portrait Displays\Pivot Software\floater.exe
C:\Program Files\Common Files\Portrait Displays\Shared\HookManager.exe
C:\Program Files\Broadcom\ASFIPMon\AsfIpMon.exe
C:\Program Files\Common Files\Portrait Displays\Shared\DTSRVC.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\Program Files\Common Files\Portrait Displays\Drivers\pdisrvc.exe
C:\Program Files\HP\Digital Imaging\bin\hpqSTE08.exe
C:\Documents and Settings\Tony\Desktop\fixes\RSIT.exe
C:\Program Files\trend micro\Tony.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://totalinternet.snap.com:8005/channel/search/0,11,totalinternet-0,00.html
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
O1 - Hosts: ÿþ127.0.0.1 localhost
O1 - Hosts: ::1 localhost
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: MSN Toolbar Helper - {d2ce3e00-f94a-4740-988e-03dc2f38c34f} - C:\Program Files\MSN\Toolbar\3.0.0983.0\msneshellx.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O3 - Toolbar: MSN Toolbar - {1E61ED7C-7CB8-49d6-B9E9-AB4C880C8414} - C:\Program Files\MSN\Toolbar\3.0.0983.0\msneshellx.dll
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [SigmatelSysTrayApp] stsystra.exe
O4 - HKLM\..\Run: [HP Software Update] C:\Program Files\HP\HP Software Update\HPWuSchd2.exe
O4 - HKLM\..\Run: [PivotSoftware] "C:\Program Files\Portrait Displays\Pivot Software\wpctrl.exe"
O4 - HKLM\..\Run: [DT ACR] C:\Program Files\Common Files\Portrait Displays\Shared\DT_startup.exe -ACR
O4 - HKLM\..\Run: [avast5] "C:\Program Files\Alwil Software\Avast5\avastUI.exe" /nogui
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKCU\..\Run: [DellSupport] "C:\Program Files\Dell Support\DSAgnt.exe" /startup
O4 - Global Startup: Digital Line Detect.lnk = ?
O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE
O4 - Global Startup: Printkey2000.lnk = C:\Program Files\PrintKey2000\Printkey2000.exe
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://www.update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1284762328296
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\system32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\system32\browseui.dll
O23 - Service: Broadcom ASF IP Monitor (ASFIPmon) - Broadcom Corporation - C:\Program Files\Broadcom\ASFIPMon\AsfIpMon.exe
O23 - Service: avast! Antivirus - AVAST Software - C:\Program Files\Alwil Software\Avast5\AvastSvc.exe
O23 - Service: avast! Mail Scanner - AVAST Software - C:\Program Files\Alwil Software\Avast5\AvastSvc.exe
O23 - Service: avast! Web Scanner - AVAST Software - C:\Program Files\Alwil Software\Avast5\AvastSvc.exe
O23 - Service: Portrait Displays Display Tune Service (DTSRVC) - Unknown owner - C:\Program Files\Common Files\Portrait Displays\Shared\DTSRVC.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: Portrait Displays SDK Service (PdiService) - Portrait Displays, Inc. - C:\Program Files\Common Files\Portrait Displays\Drivers\pdisrvc.exe
End of file - 6165 bytes
======Registry dump======
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{06849E9F-C8D7-4D59-B87D-784B7D6BE0B3}]
Adobe PDF Reader Link Helper - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll [2010-06-16 61888]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{d2ce3e00-f94a-4740-988e-03dc2f38c34f}]
MSN Toolbar Helper - C:\Program Files\MSN\Toolbar\3.0.0983.0\msneshellx.dll [2008-11-08 83800]
Java(tm) Plug-In 2 SSV Helper - C:\Program Files\Java\jre6\bin\jp2ssv.dll [2010-08-04 41760]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{E7E6F031-17CE-4C07-BC86-EABFE594F69C}]
JQSIEStartDetectorImpl Class - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll [2010-08-04 79648]
{1E61ED7C-7CB8-49d6-B9E9-AB4C880C8414} - MSN Toolbar - C:\Program Files\MSN\Toolbar\3.0.0983.0\msneshellx.dll [2008-11-08 83800]
"NvCplDaemon"=C:\WINDOWS\system32\NvCpl.dll [2006-10-03 7630848]
"NvMediaCenter"=C:\WINDOWS\system32\NvMcTray.dll [2006-10-03 86016]
"SigmatelSysTrayApp"=C:\WINDOWS\stsystra.exe [2006-08-29 282624]
"HP Software Update"=C:\Program Files\HP\HP Software Update\HPWuSchd2.exe [2006-02-19 49152]
"PivotSoftware"=C:\Program Files\Portrait Displays\Pivot Software\wpctrl.exe [2007-02-09 694008]
"DT ACR"=C:\Program Files\Common Files\Portrait Displays\Shared\DT_startup.exe [2008-06-06 81920]
"avast5"=C:\Program Files\Alwil Software\Avast5\avastUI.exe [2010-09-07 2838912]
"Adobe Reader Speed Launcher"=C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe [2010-06-16 40368]
"Adobe ARM"=C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe [2010-06-09 976832]
"DellSupport"=C:\Program Files\Dell Support\DSAgnt.exe [2006-08-28 395776]
"ctfmon.exe"=C:\WINDOWS\system32\ctfmon.exe [2008-04-13 15360]
C:\Documents and Settings\All Users\Start Menu\Programs\Startup
Digital Line Detect.lnk - C:\Program Files\Digital Line Detect\DLG.exe
HP Digital Imaging Monitor.lnk - C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
Microsoft Office.lnk - C:\Program Files\Microsoft Office\Office\OSA9.EXE
Printkey2000.lnk - C:\Program Files\PrintKey2000\Printkey2000.exe
WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll [2006-10-18 133632]
"dontdisplaylastusername"=0
"legalnoticecaption"=
"legalnoticetext"=
"shutdownwithoutlogon"=1
"undockwithoutlogon"=1
"NoDriveTypeAutoRun"=323
"NoDriveAutoRun"=67108863
"NoDrives"=0
"HonorAutoRunSetting"=1
"NoDrives"=0
"%windir%\system32\sessmgr.exe"="%windir%\system32\sessmgr.exe:*:enabled:@xpsp2res.dll,-22019"
"%windir%\Network Diagnostic\xpnetdiag.exe"="%windir%\Network Diagnostic\xpnetdiag.exe:*:Enabled:@xpsp3res.dll,-20000"
======List of files/folders created in the last 1 months======
2010-09-24 23:06:35 ----A---- C:\TDSSKiller.2.4.2.1_24.09.2010_23.06.35_log.txt
2010-09-24 16:41:11 ----D---- C:\_OTM
2010-09-24 06:06:05 ----ASH---- C:\hiberfil.sys
2010-09-23 14:42:18 ----D---- C:\Program Files\trend micro
2010-09-23 14:42:14 ----D---- C:\rsit
2010-09-23 14:33:25 ----D---- C:\Program Files\ERUNT
2010-09-22 00:23:25 ----A---- C:\WINDOWS\system32\javaws.exe
2010-09-22 00:23:25 ----A---- C:\WINDOWS\system32\javaw.exe
2010-09-22 00:23:25 ----A---- C:\WINDOWS\system32\java.exe
2010-09-21 22:57:56 ----SHD---- C:\RECYCLER
2010-09-21 20:53:30 ----A---- C:\WINDOWS\system32\MRT.exe
2010-09-21 16:45:57 ----A---- C:\WINDOWS\system32\drivers\aswRdr.sys
2010-09-21 16:45:57 ----A---- C:\WINDOWS\system32\drivers\aswFsBlk.sys
2010-09-21 16:45:56 ----A---- C:\WINDOWS\system32\drivers\aswmon2.sys
2010-09-21 16:45:56 ----A---- C:\WINDOWS\system32\drivers\aswmon.sys
2010-09-21 16:45:40 ----A---- C:\WINDOWS\system32\aswBoot.exe
2010-09-21 06:18:53 ----A---- C:\WINDOWS\zip.exe
2010-09-21 06:18:53 ----A---- C:\WINDOWS\SWXCACLS.exe
2010-09-21 06:18:53 ----A---- C:\WINDOWS\SWSC.exe
2010-09-21 06:18:53 ----A---- C:\WINDOWS\SWREG.exe
2010-09-21 06:18:53 ----A---- C:\WINDOWS\sed.exe
2010-09-21 06:18:53 ----A---- C:\WINDOWS\PEV.exe
2010-09-21 06:18:53 ----A---- C:\WINDOWS\NIRCMD.exe
2010-09-21 06:18:53 ----A---- C:\WINDOWS\MBR.exe
2010-09-21 06:18:53 ----A---- C:\WINDOWS\grep.exe
2010-09-21 06:16:58 ----D---- C:\Qoobox
2010-09-20 14:53:31 ----A---- C:\WINDOWS\system32\drivers\aswTdi.sys
2010-09-20 14:53:31 ----A---- C:\WINDOWS\system32\drivers\aswSP.sys
2010-09-20 14:53:31 ----A---- C:\WINDOWS\system32\drivers\aavmker4.sys
2010-09-20 14:53:09 ----D---- C:\Program Files\Alwil Software
2010-09-20 14:53:09 ----D---- C:\Documents and Settings\All Users\Application Data\Alwil Software
2010-09-20 13:49:23 ----A---- C:\Boot.bak
2010-09-20 13:49:16 ----RASHD---- C:\cmdcons
2010-09-20 13:45:44 ----D---- C:\WINDOWS\ERDNT
2010-09-17 18:13:18 ----D---- C:\Documents and Settings\Tony\Application Data\Malwarebytes
2010-09-17 18:12:30 ----A---- C:\WINDOWS\system32\drivers\mbamswissarmy.sys
2010-09-17 18:12:29 ----D---- C:\Documents and Settings\All Users\Application Data\Malwarebytes
2010-09-17 18:12:27 ----D---- C:\Program Files\Malwarebytes' Anti-Malware
2010-09-17 18:12:27 ----A---- C:\WINDOWS\system32\drivers\mbam.sys
2010-09-17 17:33:59 ----D---- C:\Documents and Settings\All Users\Application Data\TreeCardGames
2010-09-17 17:33:48 ----D---- C:\Documents and Settings\Tony\Application Data\TreeCardGames
2010-09-17 17:33:27 ----D---- C:\Program Files\123 Free Solitaire
2010-09-17 17:01:21 ----HDC---- C:\WINDOWS\ie8
2010-09-17 14:27:14 ----D---- C:\Program Files\SpywareBlaster
2010-09-12 16:39:48 ----D---- C:\Program Files\SpywareBlaster(2)
======List of files/folders modified in the last 1 months======
2010-09-24 23:11:04 ----D---- C:\WINDOWS\Prefetch
2010-09-24 23:10:03 ----D---- C:\WINDOWS\Temp
2010-09-24 23:09:39 ----A---- C:\WINDOWS\ModemLog_Conexant D850 56K V.92 DFVc Modem.txt
2010-09-24 23:08:08 ----A---- C:\WINDOWS\SchedLgU.Txt
2010-09-24 23:06:35 ----D---- C:\WINDOWS\system32\drivers
2010-09-24 17:19:35 ----D---- C:\WINDOWS\system32
2010-09-24 16:42:41 ----D---- C:\WINDOWS
2010-09-24 16:41:17 ----D---- C:\WINDOWS\system32\drivers\etc
2010-09-24 07:37:35 ----SHD---- C:\WINDOWS\Installer
2010-09-24 07:37:35 ----D---- C:\Config.Msi
2010-09-24 06:05:00 ----ASH---- C:\boot.ini
2010-09-24 05:55:50 ----A---- C:\WINDOWS\ntbtlog.txt
2010-09-23 17:35:43 ----D---- C:\WINDOWS\system32\config
2010-09-23 17:35:30 ----D---- C:\WINDOWS\system32\wbem
2010-09-23 17:35:29 ----D---- C:\WINDOWS\Registration
2010-09-23 14:42:18 ----RD---- C:\Program Files
2010-09-22 00:23:05 ----D---- C:\Program Files\Java
2010-09-21 22:57:00 ----D---- C:\Documents and Settings\All Users\Application Data\Adobe
2010-09-21 22:53:00 ----D---- C:\Program Files\Common Files\Adobe
2010-09-21 22:52:56 ----D---- C:\WINDOWS\WinSxS
2010-09-21 22:52:45 ----D---- C:\Program Files\Adobe
2010-09-21 20:09:39 ----D---- C:\Program Files\Crazy Browser
2010-09-21 20:09:11 ----RSHD---- C:\WINDOWS\system32\dllcache
2010-09-21 20:09:00 ----D---- C:\Program Files\Internet Explorer
2010-09-21 20:08:56 ----D---- C:\Program Files\Mozilla Firefox
2010-09-21 20:02:48 ----AD---- C:\Documents and Settings\All Users\Application Data\TEMP
2010-09-21 19:34:48 ----D---- C:\WINDOWS\system32\CatRoot2
2010-09-21 19:24:31 ----A---- C:\WINDOWS\system.ini
2010-09-21 19:21:00 ----D---- C:\WINDOWS\AppPatch
2010-09-21 19:20:59 ----D---- C:\Program Files\Common Files
2010-09-20 14:47:35 ----SD---- C:\Documents and Settings\Tony\Application Data\Microsoft
2010-09-20 14:20:17 ----SD---- C:\WINDOWS\Tasks
2010-09-17 20:15:15 ----HD---- C:\WINDOWS\inf
2010-09-17 17:03:35 ----D---- C:\WINDOWS\system32\en-US
2010-09-17 17:03:35 ----D---- C:\WINDOWS\Media
2010-09-17 17:03:35 ----D---- C:\WINDOWS\Help
2010-09-17 16:22:00 ----D---- C:\WINDOWS\network diagnostic
2010-09-17 15:25:38 ----D---- C:\WINDOWS\SoftwareDistribution
2010-09-17 15:25:37 ----SD---- C:\WINDOWS\Downloaded Program Files
2010-08-27 06:23:09 ----D---- C:\Program Files\Common Files\Java
R0 nvata;nvata; C:\WINDOWS\system32\drivers\nvata.sys [2007-02-25 105472]
R1 Aavmker4;avast! Asynchronous Virus Monitor; C:\WINDOWS\system32\drivers\Aavmker4.sys [2010-09-07 28880]
R1 AmdK8;AMD Processor Driver; C:\WINDOWS\system32\DRIVERS\AmdK8.sys [2006-07-01 36864]
R1 aswSP;aswSP; C:\WINDOWS\system32\drivers\aswSP.sys [2010-09-07 165584]
R1 aswTdi;avast! Network Shield Support; C:\WINDOWS\system32\drivers\aswTdi.sys [2010-09-07 46672]
R1 BANTExt;Belarc SMBios Access; C:\WINDOWS\System32\Drivers\BANTExt.sys [2005-04-07 3840]
R1 kbdhid;Keyboard HID Driver; C:\WINDOWS\system32\DRIVERS\kbdhid.sys [2008-04-13 14592]
R1 Pivot;Pivot; C:\WINDOWS\System32\drivers\pivot.sys [2007-02-09 17465]
R2 aswFsBlk;aswFsBlk; C:\WINDOWS\system32\drivers\aswFsBlk.sys [2010-09-07 17744]
R2 aswMon2;aswMon2; C:\WINDOWS\system32\drivers\aswMon2.sys [2010-09-07 100176]
R2 BASFND;BASFND; \??\C:\Program Files\Broadcom\ASFIPMon\BASFND.sys []
R2 mdmxsdk;mdmxsdk; C:\WINDOWS\system32\DRIVERS\mdmxsdk.sys [2006-10-18 13059]
R3 aswRdr;aswRdr; C:\WINDOWS\system32\drivers\aswRdr.sys [2010-09-07 23376]
R3 b57w2k;Broadcom NetXtreme Gigabit Ethernet; C:\WINDOWS\system32\DRIVERS\b57xp32.sys [2006-08-14 156160]
R3 DSproct;DSproct; \??\C:\Program Files\Dell Support\GTAction\triggers\DSproct.sys []
R3 HDAudBus;Microsoft UAA Bus Driver for High Definition Audio; C:\WINDOWS\system32\DRIVERS\HDAudBus.sys [2008-04-13 144384]
R3 HidUsb;Microsoft HID Class Driver; C:\WINDOWS\system32\DRIVERS\hidusb.sys [2008-04-13 10368]
R3 HSF_DPV;HSF_DPV; C:\WINDOWS\system32\DRIVERS\HSF_DPV.sys [2006-10-18 1035008]
R3 HSFHWBS2;HSFHWBS2; C:\WINDOWS\system32\DRIVERS\HSFHWBS2.sys [2006-10-18 244480]
R3 MODEMCSA;Unimodem Streaming Filter Device; C:\WINDOWS\system32\drivers\MODEMCSA.sys [2001-08-17 16128]
R3 mouhid;Mouse HID Driver; C:\WINDOWS\system32\DRIVERS\mouhid.sys [2001-08-17 12160]
R3 nv;nv; C:\WINDOWS\system32\DRIVERS\nv4_mini.sys [2006-10-03 3962720]
R3 PdiPorts;Portrait Displays low level device driver; C:\WINDOWS\System32\Drivers\PdiPorts.sys [2008-06-04 17064]
R3 pivotmou;Pivot Mouse/Pointers Filter Driver; \??\C:\WINDOWS\system32\drivers\pivotmou.sys []
R3 STHDA;SigmaTel High Definition Audio CODEC; C:\WINDOWS\system32\drivers\sthda.sys [2006-08-29 1171464]
R3 USBSTOR;USB Mass Storage Driver; C:\WINDOWS\system32\DRIVERS\USBSTOR.SYS [2008-04-13 26368]
R3 winachsf;winachsf; C:\WINDOWS\system32\DRIVERS\HSF_CNXT.sys [2006-10-18 718464]
S3 bvrp_pci;bvrp_pci; C:\WINDOWS\system32\drivers\bvrp_pci.sys []
S3 catchme;catchme; \??\C:\DOCUME~1\Tony\LOCALS~1\Temp\catchme.sys []
S3 E100B;Intel(R) PRO Adapter Driver; C:\WINDOWS\system32\DRIVERS\e100b325.sys [2001-08-17 117760]
S3 usbccgp;Microsoft USB Generic Parent Driver; C:\WINDOWS\system32\DRIVERS\usbccgp.sys [2008-04-13 32128]
S3 usbprint;Microsoft USB PRINTER Class; C:\WINDOWS\system32\DRIVERS\usbprint.sys [2008-04-13 25856]
S3 usbuhci;Microsoft USB Universal Host Controller Miniport Driver; C:\WINDOWS\system32\DRIVERS\usbuhci.sys [2008-04-13 20608]
S3 WudfPf;Windows Driver Foundation - User-mode Driver Framework Platform Driver; C:\WINDOWS\system32\DRIVERS\WudfPf.sys [2006-09-28 77568]
S3 WudfRd;Windows Driver Foundation - User-mode Driver Framework Reflector; C:\WINDOWS\system32\DRIVERS\wudfrd.sys [2006-09-28 82944]
S4 agp440;Intel AGP Bus Filter; C:\WINDOWS\system32\DRIVERS\agp440.sys [2008-04-13 42368]
S4 agpCPQ;Compaq AGP Bus Filter; C:\WINDOWS\system32\DRIVERS\agpCPQ.sys [2008-04-13 44928]
S4 alim1541;ALI AGP Bus Filter; C:\WINDOWS\system32\DRIVERS\alim1541.sys [2008-04-13 42752]
S4 amdagp;AMD AGP Bus Filter Driver; C:\WINDOWS\system32\DRIVERS\amdagp.sys [2008-04-13 43008]
S4 cbidf;cbidf; C:\WINDOWS\system32\DRIVERS\cbidf2k.sys [2001-08-17 13952]
S4 intelppm;Intel Processor Driver; C:\WINDOWS\system32\DRIVERS\intelppm.sys [2008-04-13 36352]
S4 sisagp;SIS AGP Bus Filter; C:\WINDOWS\system32\DRIVERS\sisagp.sys [2008-04-13 40960]
S4 viaagp;VIA AGP Bus Filter; C:\WINDOWS\system32\DRIVERS\viaagp.sys [2008-04-13 42240]
R2 ASFIPmon;Broadcom ASF IP Monitor; C:\Program Files\Broadcom\ASFIPMon\AsfIpMon.exe [2006-03-17 65536]
R2 avast! Antivirus;avast! Antivirus; C:\Program Files\Alwil Software\Avast5\AvastSvc.exe [2010-09-07 40384]
R2 DTSRVC;Portrait Displays Display Tune Service; C:\Program Files\Common Files\Portrait Displays\Shared\DTSRVC.exe [2008-06-06 69632]
R2 NVSvc;NVIDIA Display Driver Service; C:\WINDOWS\system32\nvsvc32.exe [2006-10-03 155715]
R2 PdiService;Portrait Displays SDK Service; C:\Program Files\Common Files\Portrait Displays\Drivers\pdisrvc.exe [2008-06-04 90112]
R3 avast! Mail Scanner;avast! Mail Scanner; C:\Program Files\Alwil Software\Avast5\AvastSvc.exe [2010-09-07 40384]
R3 avast! Web Scanner;avast! Web Scanner; C:\Program Files\Alwil Software\Avast5\AvastSvc.exe [2010-09-07 40384]
S2 Fax;Fax; C:\WINDOWS\system32\fxssvc.exe [2008-04-13 267776]
S3 aspnet_state;ASP.NET State Service; C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\aspnet_state.exe [2004-07-14 32768]
S3 WMPNetworkSvc;Windows Media Player Network Sharing Service; C:\Program Files\Windows Media Player\WMPNetwk.exe [2006-10-18 913408]
S3 WudfSvc;Windows Driver Foundation - User-mode Driver Framework; C:\WINDOWS\system32\svchost.exe [2008-04-13 14336]
need33zapper
Found the info log:
info.txt logfile of random's system information tool 1.08 2010-09-23 14:42:45
======Uninstall list======
-->C:\WINDOWS\IsUninst.exe -fC:\WINDOWS\orun32.isu
-->rundll32.exe setupapi.dll,InstallHinfSection DefaultUninstall 132 C:\WINDOWS\INF\PCHealth.inf
123 Free Solitaire 2009 v7.2-->"C:\Program Files\123 Free Solitaire\unins000.exe"
Acer eDisplay Management-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\PROFES~1\RunTime\11\00\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{A586DC50-B18D-48FB-B7CC-A598200457C2}\setup.exe" -l0x9  -removeonly
Adobe AIR-->C:\Program Files\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe AIR Updater.exe -arp:uninstall
Adobe AIR-->MsiExec.exe /I{A2BCA9F1-566C-4805-97D1-7FDC93386723}
Adobe Flash Player 10 ActiveX-->C:\WINDOWS\system32\Macromed\Flash\FlashUtil10k_ActiveX.exe -maintain activex
Adobe Flash Player 10 Plugin-->C:\WINDOWS\system32\Macromed\Flash\FlashUtil10k_Plugin.exe -maintain plugin
Adobe Media Player-->msiexec /qb /x {3BEF9769-BA52-18F7-1D02-2362F6A27E38}
Adobe Media Player-->MsiExec.exe /I{3BEF9769-BA52-18F7-1D02-2362F6A27E38}
Adobe Reader 8.2.4-->MsiExec.exe /I{AC76BA86-7AD7-1033-7B44-A82000000003}
AMD Processor Driver-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{C151CE54-E7EA-4804-854B-F515368B0798}\setup.exe" -l0x9
avast! Free Antivirus-->C:\Program Files\Alwil Software\Avast5\aswRunDll.exe "C:\Program Files\Alwil Software\Avast5\Setup\setiface.dll" RunSetup
Belarc Advisor 7.2-->C:\PROGRA~1\Belarc\Advisor\Uninstall.exe C:\PROGRA~1\Belarc\Advisor\INSTALL.LOG
Broadcom ASF Management Applications-->MsiExec.exe /I{071B9AFA-EBE8-4ABF-8F4A-9F92612F517E}
Broadcom Management Programs-->MsiExec.exe /X{FB64BF25-3593-4E4E-AA85-84AEF1D1475F}
Conexant D850 56K V.92 DFVc Modem-->C:\Program Files\CONEXANT\CNXT_MODEM_PCI_VEN_14F1&DEV_2F20&SUBSYS_200F14F1\HXFSETUP.EXE -U -Idel200fk.inf
Crazy Browser version 3.0.5-->"C:\Program Files\Crazy Browser\unins003.exe"
Critical Update for Windows Media Player 11 (KB959772)-->"C:\WINDOWS\$NtUninstallKB959772_WM11$\spuninst\spuninst.exe"
Dell ETS Factory Installation-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\PROFES~1\RunTime\09\01\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{92FD71D5-ED7E-40B2-8DF3-4B5E6F684367}\setup.exe" -l0x9
Dell Support 3.2.1-->MsiExec.exe /X{CEE2252C-4035-4B27-8EC6-0B085DD3A413}
Digital Line Detect-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{E646DCF0-5A68-11D5-B229-002078017FBF}\setup.exe" -l0x9 ControlPanelAnyText
ERUNT 1.1j-->"C:\Program Files\ERUNT\unins000.exe"
FLV Player 2.0 (build 25)-->C:\Program Files\FLV Player\uninst.exe
High Definition Audio Driver Package - KB835221-->C:\WINDOWS\$NtUninstallKB835221WXP$\spuninst\spuninst.exe
Hotfix for Windows Internet Explorer 7 (KB947864)-->"C:\WINDOWS\ie7updates\KB947864-IE7\spuninst\spuninst.exe"
Hotfix for Windows Media Format 11 SDK (KB929399)-->"C:\WINDOWS\$NtUninstallKB929399$\spuninst\spuninst.exe"
Hotfix for Windows Media Player 11 (KB939683)-->"C:\WINDOWS\$NtUninstallKB939683$\spuninst\spuninst.exe"
Hotfix for Windows XP (KB952287)-->"C:\WINDOWS\$NtUninstallKB952287$\spuninst\spuninst.exe"
Hotfix for Windows XP (KB976098-v2)-->"C:\WINDOWS\$NtUninstallKB976098-v2$\spuninst\spuninst.exe"
HP Imaging Device Functions 7.0-->C:\Program Files\HP\Digital Imaging\DeviceManagement\hpzscr01.exe -datfile hpqbud01.dat
HP Photosmart and Deskjet 7.0 Software-->C:\Program Files\HP\Digital Imaging\{9D404F8F-05A1-4734-9550-6EC2FEE916B8}\setup\hpzscr01.exe -datfile hphscr10.dat -showdisconnect -forcereboot
HP Photosmart Essential-->MsiExec.exe /X{6994491D-D491-48F1-AE1F-E179C1FFFC2F}
HP Solution Center 7.0-->C:\Program Files\HP\Digital Imaging\eSupport\hpzscr01.exe -datfile hpqbud05.dat
J2SE Runtime Environment 5.0 Update 6-->MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0150060}
Jasc Paint Shop Pro 8-->MsiExec.exe /I{81A34902-9D0B-4920-A25C-4CDC5D14B328}
Java(TM) 6 Update 20-->MsiExec.exe /X{26A24AE4-039D-4CA4-87B4-2F83216020F0}
Java(TM) 6 Update 21-->MsiExec.exe /X{26A24AE4-039D-4CA4-87B4-2F83216010FF}
Malwarebytes' Anti-Malware-->"C:\Program Files\Malwarebytes' Anti-Malware\unins000.exe"
Microsoft .NET Framework 1.1 Security Update (KB953297)-->"C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\Updates\hotfix.exe" "C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\Updates\M953297\M953297Uninstall.msp"
Microsoft .NET Framework 1.1-->msiexec.exe /X {CB2F7EDD-9D1F-43C1-90FC-4F52EAE172A1}
Microsoft .NET Framework 1.1-->MsiExec.exe /X{CB2F7EDD-9D1F-43C1-90FC-4F52EAE172A1}
Microsoft Compression Client Pack 1.0 for Windows XP-->"C:\WINDOWS\$NtUninstallMSCompPackV1$\spuninst\spuninst.exe"
Microsoft Internationalized Domain Names Mitigation APIs-->"C:\WINDOWS\$NtServicePackUninstallIDNMitigationAPIs$\spuninst\spuninst.exe"
Microsoft National Language Support Downlevel APIs-->"C:\WINDOWS\$NtServicePackUninstallNLSDownlevelMapping$\spuninst\spuninst.exe"
Microsoft Office 2000 SR-1 Professional-->MsiExec.exe /I{00010409-78E1-11D2-B60F-006097C998E7}
Microsoft User-Mode Driver Framework Feature Pack 1.0-->"C:\WINDOWS\$NtUninstallWudf01000$\spuninst\spuninst.exe"
Microsoft Visual C++ 2005 Redistributable-->MsiExec.exe /X{837b34e3-7c30-493c-8f6a-2b0f04e2912c}
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148-->MsiExec.exe /X{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}
Modem Helper-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{7F142D56-3326-11D5-B229-002078017FBF}\setup.exe" -l0x9 ControlPanel
Mozilla Firefox (3.6.10)-->C:\Program Files\Mozilla Firefox\uninstall\helper.exe
MSN Toolbar-->MsiExec.exe /I{6710FE30-27F7-492B-A660-D31D4A898A43}
NetWaiting-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{3F92ABBB-6BBF-11D5-B229-002078017FBF}\setup.exe" -l0x9 ControlPanelAnyText
NVIDIA Drivers-->C:\WINDOWS\system32\nvuide.exe UninstallGUI
OpenOffice.org Installer 1.0-->MsiExec.exe /X{0D499481-22C6-4B25-8AC2-6D3F6C885FB9}
Pivot Software-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\PROFES~1\RunTime\11\00\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{0217E1D1-BCEF-4A61-AF6D-F7740F65A066}\setup.exe" -l0x9  -removeonly
PrintKey2000-->C:\PROGRA~1\PRINTK~1\UNWISE.EXE C:\PROGRA~1\PRINTK~1\INSTALL.LOG
SDK-->RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\PROFES~1\RunTime\11\00\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{0DEA342C-15CB-4F52-97B6-06A9C4B9C06F}\setup.exe" -l0x9
Security Update for Step By Step Interactive Training (KB923723)-->"C:\WINDOWS\$NtUninstallKB923723$\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB938127)-->"C:\WINDOWS\ie7updates\KB938127-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB944533)-->"C:\WINDOWS\ie7updates\KB944533-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB950759)-->"C:\WINDOWS\ie7updates\KB950759-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB953838)-->"C:\WINDOWS\ie7updates\KB953838-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB956390)-->"C:\WINDOWS\ie7updates\KB956390-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB958215)-->"C:\WINDOWS\ie7updates\KB958215-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB960714)-->"C:\WINDOWS\ie7updates\KB960714-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB961260)-->"C:\WINDOWS\ie7updates\KB961260-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB963027)-->"C:\WINDOWS\ie7updates\KB963027-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB969897)-->"C:\WINDOWS\ie7updates\KB969897-IE7\spuninst\spuninst.exe"
Security Update for Windows Internet Explorer 7 (KB976325)-->"C:\WINDOWS\ie7updates\KB976325-IE7\spuninst\spuninst.exe"
Security Update for Windows Media Player (KB952069)-->"C:\WINDOWS\$NtUninstallKB952069_WM9$\spuninst\spuninst.exe"
Security Update for Windows Media Player (KB954155)-->"C:\WINDOWS\$NtUninstallKB954155_WM9$\spuninst\spuninst.exe"
Security Update for Windows Media Player (KB968816)-->"C:\WINDOWS\$NtUninstallKB968816_WM9$\spuninst\spuninst.exe"
Security Update for Windows Media Player (KB973540)-->"C:\WINDOWS\$NtUninstallKB973540_WM9$\spuninst\spuninst.exe"
Security Update for Windows Media Player 11 (KB936782)-->"C:\WINDOWS\$NtUninstallKB936782_WMP11$\spuninst\spuninst.exe"
Security Update for Windows Media Player 11 (KB954154)-->"C:\WINDOWS\$NtUninstallKB954154_WM11$\spuninst\spuninst.exe"
Security Update for Windows XP (KB923561)-->"C:\WINDOWS\$NtUninstallKB923561$\spuninst\spuninst.exe"
Security Update for Windows XP (KB923789)-->C:\WINDOWS\system32\MacroMed\Flash\genuinst.exe C:\WINDOWS\system32\MacroMed\Flash\KB923789.inf
Security Update for Windows XP (KB938464)-->"C:\WINDOWS\$NtUninstallKB938464$\spuninst\spuninst.exe"
Security Update for Windows XP (KB938464-v2)-->"C:\WINDOWS\$NtUninstallKB938464-v2$\spuninst\spuninst.exe"
Security Update for Windows XP (KB941569)-->"C:\WINDOWS\$NtUninstallKB941569$\spuninst\spuninst.exe"
Security Update for Windows XP (KB946648)-->"C:\WINDOWS\$NtUninstallKB946648$\spuninst\spuninst.exe"
Security Update for Windows XP (KB950760)-->"C:\WINDOWS\$NtUninstallKB950760$\spuninst\spuninst.exe"
Security Update for Windows XP (KB950762)-->"C:\WINDOWS\$NtUninstallKB950762$\spuninst\spuninst.exe"
Security Update for Windows XP (KB950974)-->"C:\WINDOWS\$NtUninstallKB950974$\spuninst\spuninst.exe"
Security Update for Windows XP (KB951066)-->"C:\WINDOWS\$NtUninstallKB951066$\spuninst\spuninst.exe"
Security Update for Windows XP (KB951376)-->"C:\WINDOWS\$NtUninstallKB951376$\spuninst\spuninst.exe"
Security Update for Windows XP (KB951376-v2)-->"C:\WINDOWS\$NtUninstallKB951376-v2$\spuninst\spuninst.exe"
Security Update for Windows XP (KB951698)-->"C:\WINDOWS\$NtUninstallKB951698$\spuninst\spuninst.exe"
Security Update for Windows XP (KB951748)-->"C:\WINDOWS\$NtUninstallKB951748$\spuninst\spuninst.exe"
Security Update for Windows XP (KB952004)-->"C:\WINDOWS\$NtUninstallKB952004$\spuninst\spuninst.exe"
Security Update for Windows XP (KB952954)-->"C:\WINDOWS\$NtUninstallKB952954$\spuninst\spuninst.exe"
Security Update for Windows XP (KB953839)-->"C:\WINDOWS\$NtUninstallKB953839$\spuninst\spuninst.exe"
Security Update for Windows XP (KB954211)-->"C:\WINDOWS\$NtUninstallKB954211$\spuninst\spuninst.exe"
Security Update for Windows XP (KB954459)-->"C:\WINDOWS\$NtUninstallKB954459$\spuninst\spuninst.exe"
Security Update for Windows XP (KB954600)-->"C:\WINDOWS\$NtUninstallKB954600$\spuninst\spuninst.exe"
Security Update for Windows XP (KB955069)-->"C:\WINDOWS\$NtUninstallKB955069$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956391)-->"C:\WINDOWS\$NtUninstallKB956391$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956572)-->"C:\WINDOWS\$NtUninstallKB956572$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956744)-->"C:\WINDOWS\$NtUninstallKB956744$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956802)-->"C:\WINDOWS\$NtUninstallKB956802$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956803)-->"C:\WINDOWS\$NtUninstallKB956803$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956841)-->"C:\WINDOWS\$NtUninstallKB956841$\spuninst\spuninst.exe"
Security Update for Windows XP (KB956844)-->"C:\WINDOWS\$NtUninstallKB956844$\spuninst\spuninst.exe"
Security Update for Windows XP (KB957095)-->"C:\WINDOWS\$NtUninstallKB957095$\spuninst\spuninst.exe"
Security Update for Windows XP (KB957097)-->"C:\WINDOWS\$NtUninstallKB957097$\spuninst\spuninst.exe"
Security Update for Windows XP (KB958644)-->"C:\WINDOWS\$NtUninstallKB958644$\spuninst\spuninst.exe"
Security Update for Windows XP (KB958687)-->"C:\WINDOWS\$NtUninstallKB958687$\spuninst\spuninst.exe"
Security Update for Windows XP (KB958690)-->"C:\WINDOWS\$NtUninstallKB958690$\spuninst\spuninst.exe"
Security Update for Windows XP (KB958869)-->"C:\WINDOWS\$NtUninstallKB958869$\spuninst\spuninst.exe"
Security Update for Windows XP (KB959426)-->"C:\WINDOWS\$NtUninstallKB959426$\spuninst\spuninst.exe"
Security Update for Windows XP (KB960225)-->"C:\WINDOWS\$NtUninstallKB960225$\spuninst\spuninst.exe"
Security Update for Windows XP (KB960715)-->"C:\WINDOWS\$NtUninstallKB960715$\spuninst\spuninst.exe"
Security Update for Windows XP (KB960803)-->"C:\WINDOWS\$NtUninstallKB960803$\spuninst\spuninst.exe"
Security Update for Windows XP (KB960859)-->"C:\WINDOWS\$NtUninstallKB960859$\spuninst\spuninst.exe"
Security Update for Windows XP (KB961371)-->"C:\WINDOWS\$NtUninstallKB961371$\spuninst\spuninst.exe"
Security Update for Windows XP (KB961373)-->"C:\WINDOWS\$NtUninstallKB961373$\spuninst\spuninst.exe"
Security Update for Windows XP (KB961501)-->"C:\WINDOWS\$NtUninstallKB961501$\spuninst\spuninst.exe"
Security Update for Windows XP (KB968537)-->"C:\WINDOWS\$NtUninstallKB968537$\spuninst\spuninst.exe"
Security Update for Windows XP (KB969059)-->"C:\WINDOWS\$NtUninstallKB969059$\spuninst\spuninst.exe"
Security Update for Windows XP (KB969898)-->"C:\WINDOWS\$NtUninstallKB969898$\spuninst\spuninst.exe"
Security Update for Windows XP (KB969947)-->"C:\WINDOWS\$NtUninstallKB969947$\spuninst\spuninst.exe"
Security Update for Windows XP (KB970238)-->"C:\WINDOWS\$NtUninstallKB970238$\spuninst\spuninst.exe"
Security Update for Windows XP (KB971486)-->"C:\WINDOWS\$NtUninstallKB971486$\spuninst\spuninst.exe"
Security Update for Windows XP (KB971557)-->"C:\WINDOWS\$NtUninstallKB971557$\spuninst\spuninst.exe"
Security Update for Windows XP (KB971633)-->"C:\WINDOWS\$NtUninstallKB971633$\spuninst\spuninst.exe"
Security Update for Windows XP (KB971657)-->"C:\WINDOWS\$NtUninstallKB971657$\spuninst\spuninst.exe"
Security Update for Windows XP (KB971961)-->"C:\WINDOWS\$NtUninstallKB971961$\spuninst\spuninst.exe"
Security Update for Windows XP (KB973346)-->"C:\WINDOWS\$NtUninstallKB973346$\spuninst\spuninst.exe"
Security Update for Windows XP (KB973354)-->"C:\WINDOWS\$NtUninstallKB973354$\spuninst\spuninst.exe"
Security Update for Windows XP (KB973507)-->"C:\WINDOWS\$NtUninstallKB973507$\spuninst\spuninst.exe"
Security Update for Windows XP (KB973525)-->"C:\WINDOWS\$NtUninstallKB973525$\spuninst\spuninst.exe"
Security Update for Windows XP (KB973869)-->"C:\WINDOWS\$NtUninstallKB973869$\spuninst\spuninst.exe"
Security Update for Windows XP (KB973904)-->"C:\WINDOWS\$NtUninstallKB973904$\spuninst\spuninst.exe"
Security Update for Windows XP (KB974112)-->"C:\WINDOWS\$NtUninstallKB974112$\spuninst\spuninst.exe"
Security Update for Windows XP (KB974318)-->"C:\WINDOWS\$NtUninstallKB974318$\spuninst\spuninst.exe"
Security Update for Windows XP (KB974392)-->"C:\WINDOWS\$NtUninstallKB974392$\spuninst\spuninst.exe"
Security Update for Windows XP (KB974571)-->"C:\WINDOWS\$NtUninstallKB974571$\spuninst\spuninst.exe"
Security Update for Windows XP (KB975025)-->"C:\WINDOWS\$NtUninstallKB975025$\spuninst\spuninst.exe"
Security Update for Windows XP (KB975467)-->"C:\WINDOWS\$NtUninstallKB975467$\spuninst\spuninst.exe"
SpywareBlaster 4.4-->"C:\Program Files\SpywareBlaster\unins001.exe"
Update for Windows XP (KB951072-v2)-->"C:\WINDOWS\$NtUninstallKB951072-v2$\spuninst\spuninst.exe"
Update for Windows XP (KB951978)-->"C:\WINDOWS\$NtUninstallKB951978$\spuninst\spuninst.exe"
Update for Windows XP (KB955839)-->"C:\WINDOWS\$NtUninstallKB955839$\spuninst\spuninst.exe"
Update for Windows XP (KB967715)-->"C:\WINDOWS\$NtUninstallKB967715$\spuninst\spuninst.exe"
Update for Windows XP (KB968389)-->"C:\WINDOWS\$NtUninstallKB968389$\spuninst\spuninst.exe"
Update for Windows XP (KB973687)-->"C:\WINDOWS\$NtUninstallKB973687$\spuninst\spuninst.exe"
Update for Windows XP (KB973815)-->"C:\WINDOWS\$NtUninstallKB973815$\spuninst\spuninst.exe"
Virtual Painter-->MsiExec.exe /I{CAB34C17-71D2-406E-A1CB-AE19FA79D2B8}
Windows Internet Explorer 8-->"C:\WINDOWS\ie8\spuninst\spuninst.exe"
Windows Media Format 11 runtime-->"C:\Program Files\Windows Media Player\wmsetsdk.exe" /UninstallAll
Windows Media Format 11 runtime-->"C:\WINDOWS\$NtUninstallWMFDist11$\spuninst\spuninst.exe"
Windows Media Player 11-->"C:\Program Files\Windows Media Player\Setup_wm.exe" /Uninstall
Windows Media Player 11-->"C:\WINDOWS\$NtUninstallwmp11$\spuninst\spuninst.exe"
Windows XP Service Pack 3-->"C:\WINDOWS\$NtServicePackUninstall$\spuninst\spuninst.exe"
======Security center information======
AV: avast! Antivirus
======System event log======
Computer Name: DAD
Event Code: 7901
Message: The At9.job command failed to start due to the following error:
%%2147942402
Record Number: 59120
Source Name: Schedule
Time Written: 20100905080000.000000-420
Event Type: error
User:
Computer Name: DAD
Event Code: 7901
%%2147942402
Record Number: 59093
Time Written: 20100904080000.000000-420
Event Type: error
User:
Computer Name: DAD
Event Code: 7901
Message: The At8.job command failed to start due to the following error:
%%2147942402
Record Number: 59090
Time Written: 20100904070000.000000-420
Event Type: error
User:
Computer Name: DAD
Event Code: 7901
%%2147942402
Record Number: 59036
Time Written: 20100903070000.000000-420
Event Type: error
User:
Computer Name: DAD
Event Code: 7901
Message: The At7.job command failed to start due to the following error:
%%2147942402
Record Number: 59029
Time Written: 20100903060000.000000-420
Event Type: error
User:
Computer Name: DAD
Event Code: 0
Message: !ERROR 53 Refreshing BMAPI data
Record Number: 2995
Source Name: Broadcom ASF IP Monitor
Time Written: 20090609221207.000000-420
Event Type: error
User:
Computer Name: DAD
Event Code: 0
Record Number: 2979
Time Written: 20090607070046.000000-420
Event Type: error
User:
Computer Name: DAD
Event Code: 1002
Message: Hanging application Crazy Browser.exe, version 3.0.0.0, hang module hungapp, version 0.0.0.0, hang address 0x00000000.
Record Number: 2969
Source Name: Application Hang
Time Written: 20090606155224.000000-420
Event Type: error
User:
Computer Name: DAD
Event Code: 1002
Record Number: 2968
Time Written: 20090606155223.000000-420
Event Type: error
User:
Computer Name: DAD
Event Code: 0
Record Number: 2952
Time Written: 20090604061010.000000-420
Event Type: error
User:
"Path"=%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem
"windir"=%SystemRoot%
"FP_NO_HOST_CHECK"=NO
"OS"=Windows_NT
"PROCESSOR_ARCHITECTURE"=x86
"PROCESSOR_LEVEL"=15
"PROCESSOR_IDENTIFIER"=x86 Family 15 Model 95 Stepping 2, AuthenticAMD
"PROCESSOR_REVISION"=5f02
"NUMBER_OF_PROCESSORS"=1
"PATHEXT"=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
"TEMP"=%SystemRoot%\TEMP
"TMP"=%SystemRoot%\TEMP
After this, I'll restart the computer.  Lately, though, at startup it's
been highlighting "Microsoft Windows Recovery Console Do Not
select this (debugger enabled)" -- rather than "M/S Windows XP
Home Edition.  Then I have to hurry and highlight the latter.
Will post now and keep my fingers crossed.
need33zapper
After my last post, restarted the computer and again got
what I'll call #1 option which said "Microsoft Windows
Recovery Console Do Not select this (debugger enabled)."
I quickly highlighted #2 option which said "Microsoft
Windows XP Home Edition."  Seemed to be starting
okay, but then got only a blank blue screen.
Manually turned off computer, #1 option came up
and I chose option #2.  Everything seemed normal.
Went to Start>Programs>Windows Updates, but once
more when the browser opened it said "I E cannot
display the webpage."
Restarted the computer, #1 option highlighted, changed
the highlighting to option #2, hit 'Enter.'  Appeared
to be starting correctly, but this time the background
picture was the only thing on the screen - no taskbar
or desktop icons.
Manually turned the computer off then back on.  Got
option #1, chose option #2, everything showed up
normally.  Left that frustrating business and came
back to my computer...   :look:
Until we 'talk' again.  Whatever happens, thank you
so much for your time and effort.
Hi, need33zapper.
Please follow the instructions in the order provided and answer the included questions in your next reply.
1)  Are you receiving help elsewhere and were given instructions to run ComboFix?  Following the instructions for installing ComboFix results in the installation of the Recovery Console.
To change the boot order, please do the following:
-- Open the Start menu and right-click on "My Computer" and choose "Properties" from the context menu.
-- The System Properties dialog box will open.  Under "Startup and Recovery" click the button "Settings".
-- Under "Default operating system", use the arrow to select "Microsoft Windows XP Home Edition"
-- Click Ok and close the System Properties window.
2)  You have vulnerable versions of Adobe software.  (Note:  When updating, be careful to UNCHECK the "Free McAfee® Security Scan Plus" box or any other unnecessary options.  They are not needed for the update.)
Update Adobe Air
Get the latest version of Adobe Air from the download center:  http://get.adobe.com/air/
Update Adobe Reader
1.  Install the latest version of Adobe Reader from http://www.adobe.com/products/reader/
or
2.  Switch to an alternate PDF reader.  There are a number of open source readers available from http://pdfreaders.org/.
Update Adobe Flash Player
You need to update Flash Player for each browser:
Direct download for IE:  http://fpdownload.adobe.com/get/flashplayer/current/install_flash_player_ax.exe
Direct Download for non-IE (Opera, Firefox etc): http://fpdownload.adobe.com/get/flashplayer/current/install_flash_player.exe
After install, verify Flash Player version for each browser installed at About Flash Player page.
(Uninstaller of previous version:  http://kb2.adobe.com/cps/141/tn_14157.html )
The next step, if you haven't done it before, is to lock down the Flash Player.  Here's a good tutorial:  How to configure your Flash Player settings for maximum privacy and security.
3)  Please go to add/remove programs and uninstall the following vulnerable versions of Java:
Please download JavaRa and unzip it to your desktop.
  • Double-click on JavaRa.exe to start the program.  (Windows Vista users Right-click JavaRa.exe > Select Run as Administrator)
4)  Please download Malwarebytes' Anti-Malware to your desktop.
  • At the end, be sure a checkmark is placed next to Update Malwarebytes' Anti-Malware and Launch Malwarebytes' Anti-Malware, then click Finish.
  • Click Remove Selected.
** Note **
5)  How is your computer now?
need33zapper
Guilty, your Honor.  I had read another post at this forum by someone who had the
apparent same virus.  Tried the 'fix' on my own, but ran into problems.  "A little
knowledge can be a dangerous thing...."
Since we last communicated, my son came in from out of town, did a recovery,
wiped the Dell computer clean, and reinstalled everything it needed.
Feel bad that I put you through so much trouble.  If you don't hate me too much,
I'll undoubtedly be back in the future.
Thank you for everything.  I have learned from you.
Hi, need33zapper.
The "Google redirect" virus is particularly nasty, with rootkit variants.  You are much better with the clean reinstall that your son did for you.
With the reinstall, please make sure that you have all of the Microsoft Security updates, including service packs, antivirus software and firewall active.
To check if your system is missing security updates or has insecure applications installed, install Secunia Personal Software Inspector or, alternatively, visit http://secunia.com/software_inspector/ .  The Secunia Software Inspector runs through your browser with no installation or download required and does the following:
I suggest that you install and update SpywareBlaster to prevent the installation of spyware and other potentially unwanted software: http://www.javacoolsoftware.com/spywareblaster.html
I am confused because of this current post over on GW which seems to indicate still infected and looking for a way to do recovery?
http://ths.gardenweb.com/forums/load/comphelp/msg0919035120707.html?12663
Hi, R-C.
I think she was just replying to Mike's post.
need33zapper
Hi Corrine and is that you Raven?  I really had buckled down and
quit trying to fix the Dell computer without expert advice from
here, but I did want to also find out how to do a recovery in
case this happens again -- that's why I posted in VMirror.
VMirror has always had such generous and knowledgeable
people, and now I know why really, really bad problems
have been referred to this site.
I was hoping, Corrine, with your very clear instructions to
'cure' my husband's computer, and am sure that would have
been the case.  My son came over before I was even awake
and proceeded to do the recovery.  I knew he was talented,
but I didn't know he was a Dell expert!  Obviously, we don't
talk a lot....  I usually don't ask him computer questions,
anyway, because he speaks in computer-language that often
goes over my head.
Thank goodness for people like you.  You all usually present
things in such a wonderfully linear, step-by-step way that
even I can grasp.
I'm embarrassed that I was not able to finish what was
started here, but I will undoubtedly be back, if allowed.
Thank you again so very much.
