Bad virus, need help
Started by jmattinson, December 24, 2010, 02:55:36 PM
jmattinson
I have a Dell Dimension E510 running XP, SP 3.  I have a virus on my computer that will no longer let me run AVG (the free antivirus I was using) and won't let me install MalwareBytes.  I have tried running AVG and installing MalwareBytes from safe mode, but the computer won't let me.  What steps do I need to take to get rid of this problem?
Hi, jmattinson.  Welcome to LandzDown Forum.
One, Two,Three or Four
  • Double-click rkill to run.
Notes:
  • Click Finish.
  • Click Remove Selected.
** Note **
NOTE If you restart the computer, you will need to run RKill again before running Malwarebytes.
Please download random's system information tool (RSIT):
  • Download RSIT by random/random from here and save it to your desktop.
    Note:  For users with 64-bit systems, please download RSIT from here.
  • Double-click RSIT.exe to run RSIT.
  • Once it has finished, two logs will open. Please post the contents of both log.txt (<<will be maximized) and info.txt (<<will be minimized).
Please post the MBAM log as well as the two logs from RSIT.
