How to renable a program blocked via WinPatrol?
Started by pastywhitegurl, December 27, 2010, 09:24:30 PM
I would like to know how to remove a block I put on the new version of Secunia PSI via WinPatrol.  I got a WinPatrol alert that an automatic service had been installed and  offered the option to let it run or block it.  I blocked it at the time, but since decided it is probably a good idea to let it do it's thing.  (which is to automatically monitor for needed patches and updates and make an alert)  How do I reverse that decision in WinPatrol?
I can't seem to find a place to allow it. And the history panel is empty.
XP:
Type services.msc at the command prompt or Control Panel > Administrative Tools > Services
Change Startup Type via right-clicking it and chosing Properties
Yay. Thanks. :)
I was thinking I would have to uncheck something within WinPatrol.
Winpatrol is now showing that service as running on automatic.  All is well.
Quote from: pastywhitegurl on December 27, 2010, 09:24:30 PM
Among other programs, the September 27, 2010 update to CCleaner v2.36.1233 added support for Malwarebytes AntiMalware, Avast! Antivirus and WinPatrol.  The listing is under Applications > Utilities and, as I recall, was pre-checked.  If you use CCleaner, running it with that option removed the WinPatrol History information.
Thanks for that information Corinne.  And of course, I dutifully updated CC Cleaner back then when that came out, but apparently didn't realize all that came pre-checked.
Yes...that's what cleaned it out.  I don't think I want any of that stuff removed.  *immediately unchecks those boxes*
