Major slowdown
Started by the GJ, February 06, 2011, 05:28:43 AM
  • Click Start
  • Click Start
  • Click Scan
  • Wait for the scan to finish
the GJ
Here is the latest Corrine, thanks. Nothing was found, a good sign yes?
ComboFix 11-02-05.01 - Owner 02/08/2011  12:31:48.4.1 - x86
Microsoft Windows XP Home Edition  5.1.2600.3.1252.1.1033.18.1023.663 [GMT -8:00]
Running from: c:\documents and settings\Owner\My Documents\Downloads\ComboFix.exe
Command switches used :: c:\documents and settings\Owner\Desktop\CFScript.txt
AV: Kaspersky Internet Security *Disabled/Updated* {2C4D4BC6-0793-4956-A9F9-E252435469C0}
FW: Kaspersky Internet Security *Disabled* {2C4D4BC6-0793-4956-A9F9-E252435469C0}
(((((((((((((((((((((((((   Files Created from 2011-01-08 to 2011-02-08  )))))))))))))))))))))))))))))))
2011-02-06 22:23 . 2010-12-21 02:09   38224   ----a-w-   c:\windows\system32\drivers\mbamswissarmy.sys
2011-02-06 22:23 . 2011-02-06 22:23   --------   d-----w-   c:\program files\Malwarebytes' Anti-Malware
2011-02-06 22:23 . 2010-12-21 02:08   20952   ----a-w-   c:\windows\system32\drivers\mbam.sys
2011-02-06 03:00 . 2011-02-06 03:00   --------   d-----w-   c:\program files\Belarc
2011-02-06 03:00 . 2008-02-27 20:49   3840   ----a-w-   c:\windows\system32\drivers\BANTExt.sys
2011-02-06 02:55 . 2011-02-06 02:56   --------   d-----w-   C:\rsit
2011-02-06 02:54 . 2011-02-06 02:54   --------   d-----w-   c:\program files\ERUNT
2011-02-04 18:22 . 2011-02-04 18:37   --------   d-----w-   c:\program files\Windows Live Safety Center
2011-01-28 03:20 . 2011-01-28 03:20   --------   d-----w-   c:\windows\system32\XPSViewer
2011-01-28 03:19 . 2011-01-28 03:19   --------   d-----w-   c:\program files\MSBuild
2011-01-28 03:19 . 2011-01-28 03:19   --------   d-----w-   c:\program files\Reference Assemblies
2011-01-27 02:34 . 2011-01-27 02:34   --------   d-sh--w-   c:\documents and settings\LocalService\IETldCache
2011-01-27 01:54 . 2010-11-02 15:17   40960   -c----w-   c:\windows\system32\dllcache\ndproxy.sys
2011-01-27 01:52 . 2010-09-18 06:53   974848   -c----w-   c:\windows\system32\dllcache\mfc42.dll
2011-01-27 01:52 . 2010-09-18 06:53   953856   -c----w-   c:\windows\system32\dllcache\mfc40u.dll
2011-01-27 01:50 . 2010-08-23 16:12   617472   -c----w-   c:\windows\system32\dllcache\comctl32.dll
2011-01-27 01:45 . 2010-06-14 14:31   744448   -c----w-   c:\windows\system32\dllcache\helpsvc.exe
2011-01-26 20:39 . 2011-01-26 20:39   --------   d-----w-   c:\documents and settings\Owner\Local Settings\Application Data\Temp
2011-01-26 20:25 . 2011-01-26 20:25   --------   d-----w-   c:\program files\Common Files\Adobe
2011-01-26 20:20 . 2011-01-26 20:20   --------   d-----w-   c:\program files\Common Files\Adobe AIR
2011-01-26 20:20 . 2011-01-26 20:39   --------   d-----w-   c:\documents and settings\Owner\Local Settings\Application Data\Adobe
2011-01-26 19:39 . 2011-01-26 19:39   --------   d-----w-   c:\program files\PDFArea
2011-01-26 19:39 . 2007-09-14 19:53   518064   ----a-w-   c:\windows\system32\Codejock.SkinFramework.Unicode.v11.2.0.ocx
2011-01-26 19:39 . 2007-09-14 19:53   1746864   ----a-w-   c:\windows\system32\Codejock.CommandBars.Unicode.v11.2.0.ocx
2011-01-26 19:39 . 2006-01-03 22:37   665600   ----a-w-   c:\windows\system32\pdfgenx.ocx
2011-01-24 23:49 . 2011-01-24 23:59   --------   d-----w-   c:\program files\PlanSwift9
2010-11-18 18:12 . 2005-07-15 02:08   81920   ----a-w-   c:\windows\system32\isign32.dll
REGEDIT4
"AVP"="c:\program files\Kaspersky Lab\Kaspersky Internet Security 2011\avp.exe" [2010-09-28 352976]
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Google Updater.lnk]
backup=c:\windows\pss\Google Updater.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^HP Digital Imaging Monitor.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\HP Digital Imaging Monitor.lnk
backup=c:\windows\pss\HP Digital Imaging Monitor.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^QuickBooks Update Agent.lnk]
backup=c:\windows\pss\QuickBooks Update Agent.lnkCommon Startup
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\QuickBooks Update Agent.lnk
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Adobe ARM]
2010-11-10 20:49   932288   ----a-w-   c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Adobe Reader Speed Launcher]
2010-11-10 20:49   35736   ----a-w-   c:\program files\Adobe\Reader 10.0\Reader\reader_sl.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ctfmon.exe]
2008-04-14 00:12   15360   ----a-w-   c:\windows\system32\ctfmon.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\HP Software Update]
2007-10-15 05:17   49152   ----a-w-   c:\program files\HP\HP Software Update\hpwuSchd2.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Intuit SyncManager]
2010-01-27 05:04   1337608   ----a-w-   c:\program files\Common Files\Intuit\Sync\IntuitSyncManager.exe
2010-07-21 22:53   141608   ----a-w-   c:\program files\iTunes\iTunesHelper.exe
2010-03-19 05:16   421888   ----a-w-   c:\program files\QuickTime\QTTask.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\services]
"aawservice"=2 (0x2)
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\KasperskyAntiVirus]
"EnableFirewall"= 0 (0x0)
"DisableNotifications"= 1 (0x1)
"c:\\WINDOWS\\system32\\sessmgr.exe"=
"c:\\WINDOWS\\Network Diagnostic\\xpnetdiag.exe"=
"c:\\Program Files\\Intuit\\QuickBooks 2007\\QBDBMgrN.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqtra08.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqste08.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpofxm08.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hposfx08.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hposid01.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqkygrp.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpzwiz01.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\Unload\\HpqPhUnl.exe"=
"c:\\Program Files\\Intuit\\QuickBooks 2010\\QBDBMgrN.exe"=
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]
"7939:TCP"= 7939:TCP:*:Disabled:PlanSwift
R0 hotcore3;hc3ServiceName;c:\windows\system32\drivers\hotcore3.sys [8/30/2010 6:22 PM 56208]
R1 kl2;kl2;c:\windows\system32\drivers\kl2.sys [6/9/2010 4:43 PM 11352]
R3 cmudax;C-Media High Definition Audio Interface;c:\windows\system32\drivers\cmudax.sys [7/14/2005 8:16 PM 1287296]
R3 klim5;Kaspersky Anti-Virus NDIS Filter;c:\windows\system32\drivers\klim5.sys [5/13/2009 4:46 PM 32856]
S3 klmouflt;Kaspersky Lab KLMOUFLT;c:\windows\system32\drivers\klmouflt.sys [5/16/2009 7:59 PM 19472]
S4 ALLN;ALLN;c:\docume~1\Owner\LOCALS~1\Temp\ALLN.exe --> c:\docume~1\Owner\LOCALS~1\Temp\ALLN.exe [?]
HPZ12   REG_MULTI_SZ      Pml Driver HPZ12 Net Driver HPZ12
hpdevmgmt   REG_MULTI_SZ      hpqcxs08 hpqddsvc
uSearchMigratedDefaultURL = hxxp://www.google.com/search?q={searchTerms}&sourceid=ie7&rls=com.microsoft:en-US&ie=utf8&oe=utf8
uStart Page = hxxp://google.com/
IE: Add to Anti-Banner - c:\program files\Kaspersky Lab\Kaspersky Internet Security 2011\ie_banner_deny.htm
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
Handler: intu-help-qb3 - {c5e479ea-0a65-4b05-8c6c-2fc8cc682eb4} - c:\program files\Intuit\QuickBooks 2010\HelpAsyncPluggableProtocol.dll
FF - ProfilePath - c:\documents and settings\Owner\Application Data\Mozilla\Firefox\Profiles\ovd7wa10.default\
FF - prefs.js: browser.search.selectedEngine - Google
FF - prefs.js: browser.startup.homepage - hxxp://www.google.com/
FF - prefs.js: network.proxy.http - 127.0.0.1
FF - prefs.js: network.proxy.type - 1
FF - Ext: Default: {972ce4c6-7e08-4474-a285-3208198ce6fd} - c:\documents and settings\Owner\Local Settings\Application Data\Mozilla Firefox\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd}
FF - Ext: DownThemAll!: {DDC359D1-844A-42a7-9AA1-88A850A938A8} - %profile%\extensions\{DDC359D1-844A-42a7-9AA1-88A850A938A8}
FF - Ext: FastestFox: smarterwiki@wikiatic.com - %profile%\extensions\smarterwiki@wikiatic.com
FF - Ext: LastPass: support@lastpass.com - %profile%\extensions\support@lastpass.com
FF - Ext: Microsoft .NET Framework Assistant: {20a82645-c095-46ed-80e3-08825760534b} - c:\windows\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension
FF - user.js: yahoo.homepage.dontask - true
Rootkit scan 2011-02-08 12:41
scanning hidden processes ...
scanning hidden files ...
scan completed successfully
hidden files: 0
- - - - - - - > 'winlogon.exe'(620)
c:\windows\system32\Ati2evxx.dll
- - - - - - - > 'explorer.exe'(2804)
c:\progra~1\WINDOW~3\wmpband.dll
Completion time: 2011-02-08  12:45:03
ComboFix-quarantined-files.txt  2011-02-08 20:44
ComboFix2.txt  2011-02-08 20:04
ComboFix3.txt  2011-02-08 19:39
ComboFix4.txt  2011-02-07 04:43
Pre-Run: 57,609,179,136 bytes free
Post-Run: 57,596,764,160 bytes free
- - End Of File - - 25C86AF5E384DC4B52F90F7F39412D54
Is your computer still slow?  If so, please do the online scan I requested:
Quote from: Corrine on February 08, 2011, 10:27:24 PM
  • Click Start
  • Click Start
  • Click Scan
Thanks!
the GJ
The computer is humming right along now, thanks to you Corrine; thanks so much for all your help and guidance, GJ
Hi, GJ.
I'm glad to know your computer is back to normal.  To finish, please do the following:
ComboFix /Uninstall
Note:  Adobe released critical updates yesterday for both Adobe Reader and Adobe Flash.  I strongly encourage you to update both.
Install the latest version of Adobe Reader from http://www.adobe.com/products/reader/
For Adobe Flash:
Direct download for IE:  http://fpdownload.adobe.com/get/flashplayer/current/install_flash_player_ax.exe
Direct Download for non-IE (Opera, Firefox etc): http://fpdownload.adobe.com/get/flashplayer/current/install_flash_player.exe
After install, verify Flash Player version for each browser installed at About Flash Player page.
Having a firewall, anti-virus and anti-malware software are not enough.  You also need to stay current with security updates.  If you don't have your computer set to automatically install the Microsoft Security Updates, please check for updates now.  For additional information, see my blog post Understanding Microsoft Updates
To check if your system is missing security updates or has insecure applications, install Secunia Personal Software Inspector or, alternatively, visit http://secunia.com/software_inspector/ .  The Secunia Software Inspector runs through your browser with no installation or download required and does the following:
Install and update SpywareBlaster to prevent the installation of spyware and other potentially unwanted software: http://www.javacoolsoftware.com/spywareblaster.html
the GJ
I followed all the instructions in your last missive Corrine, thanks once more for everything, you are my new hero! GJ
You are very welcome, GJ, and thank you!
