Rootkit 0Access
Started by linda93, July 02, 2012, 05:41:45 PM
Let's run ComboFix again.
Custom CFScript
ClearJavaCache::
File::
f3e6ff104e47d5c5
Driver::
C:\SystemRoot\System32\Drivers\f3e6ff104e47d5c5.sys
  • Close any open browsers.
linda93
Corrine, I get an error message that says "The name, CFSScript appears to be incorrectly spelt."
Also it is now asking me if I want to update Combofix.
I also have a strange message above my clock and date on my desktop that says "Windows 7 Build 7601 This copy of Windows in not genuine.
Thanks
Linda
Delete the existing CFScript.txt and create a new one following the instructions above.  Also allow ComboFix to update.
What you have on your computer is a nasty rootkit, and the message is most likely caused by a corrupted file.
Download and run the Genuine Diagnostics tool (MGADiag.exe) at this link http://go.microsoft.com/fwlink/?linkid=52012. Click "Continue", click the "Copy" button then "Paste" the report into a reply message in this thread along with the new ComboFix log.
linda93
Thanks, that worked.
ComboFix 12-07-06.02 - Nat 07/06/2012  14:29:37.3.4 - x64
Microsoft Windows 7 Professional   6.1.7601.1.1252.1.1033.18.4003.2603 [GMT -7:00]
Running from: c:\users\Nat\Desktop\ComboFix.exe
Command switches used :: c:\users\Nat\Desktop\CFScript.txt
AV: Microsoft Security Essentials *Disabled/Updated* {9765EA51-0D3C-7DFB-6091-10E4E1F341F6}
SP: Microsoft Security Essentials *Disabled/Updated* {2C040BB5-2B06-7275-5A21-2B969A740B4B}
* Created a new restore point
(((((((((((((((((((((((((   Files Created from 2012-06-06 to 2012-07-06  )))))))))))))))))))))))))))))))
2012-07-06 21:33 . 2012-07-06 21:33   --------   d-----w-   c:\users\Default\AppData\Local\temp
2012-07-04 21:29 . 2012-07-04 21:29   --------   d-----w-   c:\program files (x86)\ESET
2012-07-04 15:54 . 2012-07-04 15:54   --------   d-----w-   c:\windows\system32\appmgmt
2012-06-30 20:49 . 2012-06-30 20:49   --------   d-sh--w-   c:\windows\system32\%APPDATA%
2012-06-21 15:51 . 2012-06-02 22:19   2428952   ----a-w-   c:\windows\system32\wuaueng.dll
2012-06-21 15:51 . 2012-06-02 22:19   57880   ----a-w-   c:\windows\system32\wuauclt.exe
2012-06-21 15:51 . 2012-06-02 22:19   44056   ----a-w-   c:\windows\system32\wups2.dll
2012-06-21 15:51 . 2012-06-02 22:15   2622464   ----a-w-   c:\windows\system32\wucltux.dll
2012-06-21 15:50 . 2012-06-02 22:19   186752   ----a-w-   c:\windows\system32\wuwebv.dll
2012-06-21 15:50 . 2012-06-02 22:15   36864   ----a-w-   c:\windows\system32\wuapp.exe
2012-06-20 22:39 . 2012-05-31 04:04   9013136   ----a-w-   c:\programdata\Microsoft\Microsoft Antimalware\Definition Updates\{8FCC415D-B7FB-49ED-80C6-74B39BC1744B}\mpengine.dll
2012-06-19 22:27 . 2012-05-31 04:04   9013136   ----a-w-   c:\programdata\Microsoft\Microsoft Antimalware\Definition Updates\Backup\mpengine.dll
2012-06-13 15:19 . 2012-04-26 05:41   77312   ----a-w-   c:\windows\system32\rdpwsx.dll
2012-06-12 15:24 . 2012-02-11 05:30   927800   ------w-   c:\programdata\Microsoft\Microsoft Antimalware\Definition Updates\{149BB2C9-459F-4F19-98C5-C083FD89B67B}\gapaengine.dll
2012-06-23 04:19 . 2012-05-12 16:02   426184   ----a-w-   c:\windows\SysWow64\FlashPlayerApp.exe
2012-06-23 04:19 . 2011-12-08 23:00   70344   ----a-w-   c:\windows\SysWow64\FlashPlayerCPLApp.cpl
2012-04-18 20:49 . 2012-05-24 21:40   405176   ----a-w-   c:\windows\SysWow64\Newtonsoft.Json.Net20.dll
(((((((((((((((((((((((((((((   SnapShot@2012-07-03_16.27.36   )))))))))))))))))))))))))))))))))))))))))
+ 2012-07-06 21:21 . 2012-07-06 21:21   11799              c:\windows\SysWOW64\config\systemprofile\AppData\Roaming\SoftGrid Client\Icon Cache\icon_ex.dat
- 2012-07-03 16:26 . 2012-07-03 16:26   11799              c:\windows\SysWOW64\config\systemprofile\AppData\Roaming\SoftGrid Client\Icon Cache\icon_ex.dat
- 2009-07-14 04:54 . 2012-07-03 16:27   16384              c:\windows\SysWOW64\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2009-07-14 04:54 . 2012-07-06 21:24   16384              c:\windows\SysWOW64\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
- 2009-07-14 04:54 . 2012-07-03 16:27   81920              c:\windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
+ 2009-07-14 04:54 . 2012-07-06 21:24   81920              c:\windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
+ 2009-07-14 04:54 . 2012-07-06 21:24   16384              c:\windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
- 2009-07-14 04:54 . 2012-07-03 16:27   16384              c:\windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2009-07-14 05:10 . 2012-07-06 21:24   39764              c:\windows\system32\wdi\BootPerformanceDiagnostics_SystemData.bin
+ 2012-07-03 17:00 . 2012-07-03 17:00   1604              c:\windows\system32\wdi\ERCQueuedResolutions.dat
+ 2011-09-20 20:48 . 2012-07-06 21:24   7664              c:\windows\system32\wdi\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-2243763373-2349021115-3601667197-1000_UserData.bin
+ 2012-07-06 21:22 . 2012-07-06 21:22   2048              c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive1.dat
- 2012-07-03 16:27 . 2012-07-03 16:27   2048              c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive1.dat
+ 2012-07-06 21:22 . 2012-07-06 21:22   2048              c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive0.dat
- 2012-07-03 16:27 . 2012-07-03 16:27   2048              c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive0.dat
+ 2011-09-20 21:38 . 2012-07-06 15:20   242434              c:\windows\system32\wdi\SuspendPerformanceDiagnostics_SystemData_S3.bin
- 2009-07-14 02:36 . 2012-07-03 15:29   673892              c:\windows\system32\perfh009.dat
+ 2009-07-14 02:36 . 2012-07-06 21:28   673892              c:\windows\system32\perfh009.dat
+ 2009-07-14 02:36 . 2012-07-06 21:28   125918              c:\windows\system32\perfc009.dat
- 2009-07-14 02:36 . 2012-07-03 15:29   125918              c:\windows\system32\perfc009.dat
- 2011-09-20 20:49 . 2012-07-03 15:56   327680              c:\windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2011-09-20 20:49 . 2012-07-05 18:55   327680              c:\windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2009-07-14 04:46 . 2012-07-03 16:35   109712              c:\windows\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\SoftwareProtectionPlatform\Cache\cache.dat
- 2011-09-23 10:33 . 2012-07-03 15:53   539232              c:\windows\ServiceProfiles\LocalService\AppData\Local\FontCache3.0.0.0.dat
+ 2011-09-23 10:33 . 2012-07-06 21:21   539232              c:\windows\ServiceProfiles\LocalService\AppData\Local\FontCache3.0.0.0.dat
+ 2009-07-14 05:01 . 2012-07-06 21:21   235556              c:\windows\ServiceProfiles\LocalService\AppData\Local\FontCache-System.dat
- 2009-07-14 05:01 . 2012-07-03 16:26   235556              c:\windows\ServiceProfiles\LocalService\AppData\Local\FontCache-System.dat
+ 2011-09-20 20:49 . 2012-07-05 18:55   2736128              c:\windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
- 2011-09-20 20:49 . 2012-07-03 15:56   2736128              c:\windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
+ 2011-09-23 10:33 . 2012-07-06 21:21   4873472              c:\windows\ServiceProfiles\LocalService\AppData\Local\FontCache-S-1-5-21-2243763373-2349021115-3601667197-1000-8192.dat
- 2012-06-30 19:25 . 2012-07-03 16:26   7775060              c:\windows\ServiceProfiles\LocalService\AppData\Local\FontCache-S-1-5-18-16384.dat
+ 2012-06-30 19:25 . 2012-07-06 21:21   7775060              c:\windows\ServiceProfiles\LocalService\AppData\Local\FontCache-S-1-5-18-16384.dat
+ 2009-07-14 04:54 . 2012-07-05 18:55   11403264              c:\windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
- 2009-07-14 04:54 . 2012-07-03 15:56   11403264              c:\windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
REGEDIT4
"SUPERAntiSpyware"="c:\program files\SUPERAntiSpyware\SUPERAntiSpyware.exe" [2012-06-22 4786048]
"k0kcwz1xjp"="c:\users\Nat\k0kcwz1xjp.exe" [1601-01-01 0]
"Dell Webcam Central"="c:\program files (x86)\Dell Webcam\Dell Webcam Central\WebcamDell2.exe" [2011-04-13 503942]
"IAStorIcon"="c:\program files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe" [2010-11-06 283160]
"NUSB3MON"="c:\program files (x86)\Renesas Electronics\USB 3.0 Host Controller Driver\Application\nusb3mon.exe" [2010-11-17 113288]
"Adobe ARM"="c:\program files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2012-01-03 843712]
"APSDaemon"="c:\program files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe" [2011-09-27 59240]
"iTunesHelper"="c:\program files (x86)\iTunes\iTunesHelper.exe" [2011-10-10 421736]
"Garmin Lifetime Updater"="c:\program files (x86)\Garmin\Lifetime Updater\GarminLifetime.exe" [2012-01-07 1446760]
"SunJavaUpdateSched"="c:\program files (x86)\Common Files\Java\Java Update\jusched.exe" [2012-01-18 254696]
"Nike+ Connect"="c:\program files (x86)\Nike\Nike+ Connect\Nike+ Connect daemon.exe" [2012-05-09 70656]
Audible Download Manager.lnk - c:\program files (x86)\Audible\Bin\AudibleDownloadHelper.exe [2011-3-14 2125472]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa]
Notification Packages   REG_MULTI_SZ      DPPassFilter scecli
Security Packages   REG_MULTI_SZ      kerberos msv1_0 schannel wdigest tspkg pku2u livessp
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\!SASCORE]
@="Driver"
R2 Bluetooth OBEX Service;Bluetooth OBEX Service;c:\program files (x86)\Intel\Bluetooth\obexsrv.exe [2011-05-19 995392]
R2 clr_optimization_v4.0.30319_64;Microsoft .NET Framework NGEN v4.0.30319_X64;c:\windows\Microsoft.NET\Framework64\v4.0.30319\mscorsvw.exe [2010-03-18 138576]
R2 wntpport;wntpport;
  • R3 AdobeFlashPlayerUpdateSvc;Adobe Flash Player Update Service;c:\windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe [2012-06-23 250056]
    R3 AMPPALP;Intel® Centrino® Wireless Bluetooth® 3.0 + High Speed Protocol;c:\windows\system32\DRIVERS\amppal.sys
  • R3 Bluetooth Media Service;Bluetooth Media Service;c:\program files (x86)\Intel\Bluetooth\mediasrv.exe [2011-05-19 1335360]
    R3 dmvsc;dmvsc;c:\windows\system32\drivers\dmvsc.sys
  • R3 intaud_WaveExtensible;Intel WiDi Audio Device;c:\windows\system32\drivers\intelaud.sys
  • R3 MyWiFiDHCPDNS;Wireless PAN DHCP Server;c:\program files\Intel\WiFi\bin\PanDhcpDns.exe [2011-07-28 340240]
    R3 NisDrv;Microsoft Network Inspection System;c:\windows\system32\DRIVERS\NisDrvWFP.sys
  • R3 NisSrv;Microsoft Network Inspection;c:\program files\Microsoft Security Client\NisSrv.exe [2012-03-27 291696]
    R3 osppsvc;Office Software Protection Platform;c:\program files\Common Files\Microsoft Shared\OfficeSoftwareProtectionPlatform\OSPPSVC.EXE [2010-01-10 4925184]
    R3 RSUSBSTOR;RtsUStor.Sys Realtek USB Card Reader;c:\windows\system32\Drivers\RtsUStor.sys
  • R3 RTL8187;NETGEAR WG111v2 54Mbps Wireless USB 2.0 Adapter Vista Driver;c:\windows\system32\DRIVERS\wg111v2.sys
  • R3 SydexFDD;Sydex Diskette Driver;c:\windows\SysWOW64\Drivers\sydexfdd.sys [2011-01-18 13359]
    R3 TsUsbFlt;TsUsbFlt;c:\windows\system32\drivers\tsusbflt.sys
  • R3 TsUsbGD;Remote Desktop Generic USB Device;c:\windows\system32\drivers\TsUsbGD.sys
  • R3 TurboBoost;Intel(R) Turbo Boost Technology Monitor 2.0;c:\program files\Intel\TurboBoost\TurboBoost.exe [2010-11-29 149504]
    R3 USBAAPL64;Apple Mobile USB Driver;c:\windows\system32\Drivers\usbaapl64.sys
  • R3 WatAdminSvc;Windows Activation Technologies Service;c:\windows\system32\Wat\WatAdminSvc.exe [2011-09-23 1255736]
    R4 wlcrasvc;Windows Live Mesh remote connections service;c:\program files\Windows Live\Mesh\wlcrasvc.exe [2010-09-22 57184]
    S0 stdcfltn;Disk Class Filter Driver for Accelerometer;c:\windows\system32\DRIVERS\stdcfltn.sys
  • S1 SASDIFSV;SASDIFSV;c:\program files\SUPERAntiSpyware\SASDIFSV64.SYS
  • S1 SASKUTIL;SASKUTIL;c:\program files\SUPERAntiSpyware\SASKUTIL64.SYS
  • S1 vwififlt;Virtual WiFi Filter Driver;c:\windows\system32\DRIVERS\vwififlt.sys
  • S2 !SASCORE;SAS Core Service;c:\program files\SUPERAntiSpyware\SASCORE64.EXE [2011-08-11 140672]
    S2 AdobeARMservice;Adobe Acrobat Update Service;c:\program files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe [2012-01-03 63928]
    S2 AESTFilters;Andrea ST Filters Service;c:\program files\IDT\WDM\AESTSr64.exe [2009-03-03 89600]
    S2 AMPPALR3;Intel® Centrino® Wireless Bluetooth® 3.0 + High Speed Service;c:\program files\Intel\BluetoothHS\BTHSAmpPalService.exe [2011-08-08 1166848]
    S2 Bluetooth Device Monitor;Bluetooth Device Monitor;c:\program files (x86)\Intel\Bluetooth\devmonsrv.exe [2011-05-19 921664]
    S2 BTHSSecurityMgr;Intel(R) Centrino(R) Wireless Bluetooth(R) 3.0 + High Speed Security Service;c:\program files\Intel\BluetoothHS\BTHSSecurityMgr.exe [2011-06-03 134928]
    S2 cvhsvc;Client Virtualization Handler;c:\program files (x86)\Common Files\Microsoft Shared\Virtualization Handler\CVHSVC.EXE [2012-01-04 822624]
    S2 DellDigitalDelivery;Dell Digital Delivery Service;c:\program files (x86)\Dell Digital Delivery\DeliveryService.exe [2012-04-10 166912]
    S2 IAStorDataMgrSvc;Intel(R) Rapid Storage Technology;c:\program files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe [2010-11-06 13336]
    S2 MediaMall Server;MediaMall Server;c:\program files (x86)\MediaMall\MediaMallServer.exe [2012-06-18 2976632]
    S2 sftlist;Application Virtualization Client;c:\program files (x86)\Microsoft Application Virtualization Client\sftlist.exe [2011-10-01 508776]
    S2 TurboB;Turbo Boost UI Monitor driver;c:\windows\system32\DRIVERS\TurboB.sys
  • S2 UNS;Intel(R) Management and Security Application User Notification Service;c:\program files (x86)\Intel\Intel(R) Management Engine Components\UNS\UNS.exe [2010-10-06 2655768]
    S2 vcsFPService;Validity VCS Fingerprint Service;c:\windows\system32\vcsFPService.exe [2010-12-03 3143472]
    S3 Acceler;Accelerometer Service;c:\windows\system32\DRIVERS\Accelern.sys
  • S3 AMPPAL;Intel® Centrino® Wireless Bluetooth® 3.0 + High Speed Virtual Adapter;c:\windows\system32\DRIVERS\AMPPAL.sys
  • S3 btmaudio;Intel Bluetooth Audio Service;c:\windows\system32\drivers\btmaud.sys
  • S3 btmaux;Intel Bluetooth Auxiliary Service;c:\windows\system32\DRIVERS\btmaux.sys
  • S3 btmhsf;btmhsf;c:\windows\system32\DRIVERS\btmhsf.sys
  • S3 CtClsFlt;Creative Camera Class Upper Filter Driver;c:\windows\system32\DRIVERS\CtClsFlt.sys
  • S3 iBtFltCoex;iBtFltCoex;c:\windows\system32\DRIVERS\iBtFltCoex.sys
  • S3 IntcDAud;Intel(R) Display Audio;c:\windows\system32\DRIVERS\IntcDAud.sys
  • S3 iwdbus;IWD Bus Enumerator;c:\windows\system32\DRIVERS\iwdbus.sys
  • S3 MEIx64;Intel(R) Management Engine Interface;c:\windows\system32\DRIVERS\HECIx64.sys
  • S3 NETwNs64;___ Intel(R) Wireless WiFi Link 5000 Series Adapter Driver for Windows 7 - 64 Bit;c:\windows\system32\DRIVERS\NETwNs64.sys
  • S3 nusb3hub;Renesas Electronics USB 3.0 Hub Driver;c:\windows\system32\DRIVERS\nusb3hub.sys
  • S3 nusb3xhc;Renesas Electronics USB 3.0 Host Controller Driver;c:\windows\system32\DRIVERS\nusb3xhc.sys
  • S3 RTL8167;Realtek 8167 NT Driver;c:\windows\system32\DRIVERS\Rt64win7.sys
  • S3 Sftfs;Sftfs;c:\windows\system32\DRIVERS\Sftfslh.sys
  • S3 Sftplay;Sftplay;c:\windows\system32\DRIVERS\Sftplaylh.sys
  • S3 Sftredir;Sftredir;c:\windows\system32\DRIVERS\Sftredirlh.sys
  • S3 Sftvol;Sftvol;c:\windows\system32\DRIVERS\Sftvollh.sys
  • S3 sftvsa;Application Virtualization Service Agent;c:\program files (x86)\Microsoft Application Virtualization Client\sftvsa.exe [2011-10-01 219496]
    S3 vwifimp;Microsoft Virtual WiFi Miniport Service;c:\windows\system32\DRIVERS\vwifimp.sys
    *Deregistered* - f3e6ff104e47d5c5
    2012-07-06 c:\windows\Tasks\Adobe Flash Player Updater.job
    - c:\windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe [2012-05-12 04:19]
    2012-06-14 c:\windows\Tasks\PCDoctorBackgroundMonitorTask.job
    - c:\program files\Dell Support Center\uaclauncher.exe [2011-03-22 17:20]
    2012-07-05 c:\windows\Tasks\SystemToolsDailyTest.job
    - c:\program files\Dell Support Center\pcdrcui.exe [2011-03-22 17:20]
    --------- X64 Entries -----------
    "IgfxTray"="c:\windows\system32\igfxtray.exe" [2011-04-20 168216]
    "HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2011-04-20 392472]
    "Persistence"="c:\windows\system32\igfxpers.exe" [2011-04-20 416024]
    "SysTrayApp"="c:\program files\IDT\WDM\sttray64.exe" [2011-01-25 525312]
    "Apoint"="c:\program files\DellTPad\Apoint.exe" [2011-04-12 609144]
    "IntelTBRunOnce"="wscript.exe" [2009-07-14 168960]
    "FreeFallProtection"="c:\program files (x86)\STMicroelectronics\AccelerometerP11\FF_Protection.exe" [2010-12-15 686704]
    "IntelPAN"="c:\program files\Common Files\Intel\WirelessCommon\iFrmewrk.exe" [2011-07-28 1935120]
    "BTMTrayAgent"="c:\program files (x86)\Intel\Bluetooth\btmshell.dll" [2011-05-19 10365952]
    "DBRMTray"="c:\dell\DBRM\Reminder\DbrmTrayIcon.exe" [2010-09-10 206336]
    "MSC"="c:\program files\Microsoft Security Client\msseces.exe" [2012-03-27 1271168]
    uStart Page = hxxp://google.com/
    IE: Free YouTube Download - c:\users\Nat\AppData\Roaming\DVDVideoSoftIEHelpers\freeytvdownloader.htm
    TCP: DhcpNameServer = 192.168.1.254
    DPF: Garmin Communicator Plug-In - hxxps://static.garmincdn.com/gcp/ie/4.0.1.0/GarminAxControl_32.CAB
    [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\services\f3e6ff104e47d5c5]
    "ImagePath"="\SystemRoot\System32\Drivers\f3e6ff104e47d5c5.sys"
    [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\PCW\Security]
    @Denied: (Full) (Everyone)
    Completion time: 2012-07-06  14:35:16
    ComboFix-quarantined-files.txt  2012-07-06 21:35
    ComboFix2.txt  2012-07-04 16:11
    ComboFix3.txt  2012-07-03 16:31
    Pre-Run: 249,420,451,840 bytes free
    Post-Run: 250,140,200,960 bytes free
    - - End Of File - - AD8EEDEDE38EDD272EA436DAA7E584AB
    Here is the second log.
    Diagnostic Report (1.9.0027.0):
    Windows Validation Data-->
    Validation Code: 0
    Cached Online Validation Code: 0x0
    Windows Product Key: *****-*****-M3DJT-4J3WC-733WD
    Windows Product Key Hash: xo+ajVSpae7/4VoZjS7m6JL0f3A=
    Windows Product ID: 00371-OEM-8992671-00524
    Windows Product ID Type: 2
    Windows License Type: OEM SLP
    Windows OS version: 6.1.7601.2.00010100.1.0.048
    Is Admin: Yes
    TestCab: 0x0
    LegitcheckControl ActiveX: N/A, hr = 0x80070002
    Signed By: N/A, hr = 0x80070002
    Product Name: Windows 7 Professional
    Architecture: 0x00000009
    Build lab: 7601.win7sp1_gdr.120503-2030
    TTS Error:
    Validation Diagnostic:
    Resolution Status: N/A
    Vista WgaER Data-->
    ThreatID(s): N/A, hr = 0x80070002
    Version: N/A, hr = 0x80070002
    Windows XP Notifications Data-->
    Cached Result: N/A, hr = 0x80070002
    File Exists: No
    WgaTray.exe Signed By: N/A, hr = 0x80070002
    WgaLogon.dll Signed By: N/A, hr = 0x80070002
    OGA Notifications Data-->
    OGAExec.exe Signed By: N/A, hr = 0x80070002
    OGAAddin.dll Signed By: N/A, hr = 0x80070002
    OGA Data-->
    Office Status: 109 N/A
    OGA Version: N/A, 0x80070002
    Office Diagnostics: 025D1FF3-364-80041010_025D1FF3-229-80041010_025D1FF3-230-1_025D1FF3-517-80040154_025D1FF3-237-80040154_025D1FF3-238-2_025D1FF3-244-80070002_025D1FF3-258-3
    Browser Data-->
    Proxy settings: N/A
    User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Win32)
    Default Browser: C:\Program Files (x86)\Internet Explorer\iexplore.exe
    Download signed ActiveX controls: Prompt
    Download unsigned ActiveX controls: Disabled
    Run ActiveX controls and plug-ins: Allowed
    Initialize and script ActiveX controls not marked as safe: Disabled
    Allow scripting of Internet Explorer Webbrowser control: Disabled
    Active scripting: Allowed
    Script ActiveX controls marked as safe for scripting: Allowed
    File Scan Data-->
    Other data-->
    Office Details: <GenuineResults><MachineData><UGUID>{612CA6B9-84FB-4F59-B508-C7F5D5689B71}</UGUID><Version>1.9.0027.0</Version><OS>6.1.7601.2.00010100.1.0.048</OS><Architecture>x64</Architecture><PKey>*****-*****-*****-*****-733WD</PKey><PID>00371-OEM-8992671-00524</PID><PIDType>2</PIDType><SID>S-1-5-21-2243763373-2349021115-3601667197</SID><SYSTEM><Manufacturer>Dell Inc.</Manufacturer><Model>Vostro 3550</Model></SYSTEM><BIOS><Manufacturer>Dell Inc.</Manufacturer><Version>A07</Version><SMBIOSVersion major="2" minor="6"/><Date>20110718000000.000000+000</Date></BIOS><HWID>ADD93407018400FE</HWID><UserLCID>0409</UserLCID><SystemLCID>0409</SystemLCID><TimeZone>Pacific Standard Time(GMT-08:00)</TimeZone><iJoin>0</iJoin><SBID><stat>3</stat><msppid></msppid><name></name><model></model></SBID><OEM><OEMID>DELL  </OEMID><OEMTableID>WN09   </OEMTableID></OEM><GANotification/></MachineData><Software><Office><Result>109</Result><Products/><Applications/></Office></Software></GenuineResults>
    Spsys.log Content: 0x80070002
    Licensing Data-->
    Software licensing service version: 6.1.7601.17514
    Name: Windows(R) 7, Professional edition
    Description: Windows Operating System - Windows(R) 7, OEM_SLP channel
    Activation ID: 50e329f7-a5fa-46b2-85fd-f224e5da7764
    Application ID: 55c92734-d682-4d71-983e-d6ec3f16059f
    Extended PID: 00371-00178-926-700524-02-1033-7601.0000-2572011
    Installation ID: 016840936642035106528415267011100012227251262644489905
    Processor Certificate URL: http://go.microsoft.com/fwlink/?LinkID=88338
    Machine Certificate URL: http://go.microsoft.com/fwlink/?LinkID=88339
    Use License URL: http://go.microsoft.com/fwlink/?LinkID=88341
    Product Key Certificate URL: http://go.microsoft.com/fwlink/?LinkID=88340
    Partial Product Key: 733WD
    License Status: Licensed
    Remaining Windows rearm count: 1
    Trusted time: 7/6/2012 2:39:08 PM
    Windows Activation Technologies-->
    HrOffline: 0x00000000
    HrOnline: 0x00000000
    HealthStatus: 0x0000000000000000
    Event Time Stamp: 6:29:2012 19:31
    ActiveX: Registered, Version: 7.1.7600.16395
    Admin Service: Registered, Version: 7.1.7600.16395
    HealthStatus Bitmask Output:
    HWID Data-->
    HWID Hash Current: NAAAAAEAAQABAAEAAAADAAAABAABAAEA6GGiavQ2vDq4+S5YjGyWdL6kDk+MVs5EaA4ucw==
    OEM Activation 1.0 Data-->
    N/A
    OEM Activation 2.0 Data-->
    BIOS valid for OA 2.0: yes
    Windows marker version: 0x20001
    OEMID and OEMTableID Consistent: yes
    BIOS Information:
      ACPI Table Name   OEMID Value   OEMTableID Value
      APIC         DELL      WN09
      FACP         DELL      WN09
      HPET         DELL      WN09
      MCFG         DELL      WN09
      SSDT         TrmRef      PtidDevc
      SLIC         DELL        WN09
      OSFR         DELL        M08
Excellent.  Are you still getting the "not valid" message?
ComboFix isn't able to shake that loose so I'd like you to run Windows Defender Offline.  Since you have a 64-bit computer, you need to download that version.  The download and FAQ's are available here:  What is Windows Defender Offline?.  In addition, I have a tutorial at Setting Up the Microsoft Standalone System Sweeper Beta, Now Windows Defender Offline.
Please note what Windows Defender Offline finds and removes in your next post and post a fresh DDS.txt log.
Do you have a Windows 7 CD/DVD?
linda93
Yes, I've dug out my windows 7 cd and have made the windows defender cd.  Should I go ahead?
linda93
Okay I reread instructions and ran Windows Defender Offline.
It reports it removed 2 threats.
Trojan:Win64/Necurs
Trojan Downloader:cutwail.BE
Also the  message above my clock on the desktop now reads, "Test Mode Windows 7 Build 7601"  I still cannot start Windows Security.
Here are the DDS files.
DDS (Ver_2011-08-26.01) - NTFSAMD64
Internet Explorer: 9.0.8112.16421
Run by Nat at 10:27:57 on 2012-07-07
Microsoft Windows 7 Professional   6.1.7601.1.1252.1.1033.18.4003.2484 [GMT -7:00]
C:\windows\system32\wininit.exe
C:\windows\system32\lsm.exe
C:\windows\system32\svchost.exe -k DcomLaunch
C:\windows\system32\svchost.exe -k RPCSS
C:\windows\System32\svchost.exe -k LocalServiceNetworkRestricted
C:\windows\System32\svchost.exe -k LocalSystemNetworkRestricted
C:\windows\system32\svchost.exe -k netsvcs
C:\Program Files\IDT\WDM\STacSV64.exe
C:\windows\system32\svchost.exe -k LocalService
C:\Windows\system32\vcsFPService.exe
C:\windows\system32\svchost.exe -k NetworkService
C:\windows\system32\WLANExt.exe
C:\windows\system32\conhost.exe
C:\windows\System32\spoolsv.exe
C:\Program Files\DigitalPersona\Bin\DpHostW.exe
C:\windows\system32\taskhost.exe
C:\windows\system32\Dwm.exe
C:\windows\Explorer.EXE
C:\windows\system32\svchost.exe -k LocalServiceNoNetwork
C:\Program Files\SUPERAntiSpyware\SASCORE64.EXE
C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe
C:\Program Files\IDT\WDM\AESTSr64.exe
C:\Program Files\Intel\BluetoothHS\BTHSAmpPalService.exe
C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
C:\Program Files (x86)\Intel\Bluetooth\devmonsrv.exe
C:\windows\system32\svchost.exe -k bthsvcs
C:\Program Files\Intel\BluetoothHS\BTHSSecurityMgr.exe
C:\Program Files\Intel\WiFi\bin\EvtEng.exe
C:\windows\system32\svchost.exe -k LocalServiceAndNoImpersonation
C:\Program Files (x86)\MediaMall\MediaMallServer.exe
C:\windows\system32\svchost.exe -k NetworkServiceNetworkRestricted
C:\Program Files\Common Files\Intel\WirelessCommon\RegSrvc.exe
C:\Program Files (x86)\Microsoft Application Virtualization Client\sftvsa.exe
C:\windows\system32\svchost.exe -k imgsvc
C:\Program Files (x86)\Intel\Bluetooth\obexsrv.exe
C:\Windows\System32\igfxtray.exe
C:\Program Files (x86)\Microsoft Application Virtualization Client\sftlist.exe
C:\Windows\System32\hkcmd.exe
C:\Program Files\IDT\WDM\sttray64.exe
C:\Program Files\DellTPad\Apoint.exe
C:\Program Files (x86)\STMicroelectronics\AccelerometerP11\FF_Protection.exe
C:\Program Files\Common Files\Intel\WirelessCommon\iFrmewrk.exe
C:\windows\system32\wbem\unsecapp.exe
C:\windows\system32\wbem\wmiprvse.exe
C:\Windows\System32\rundll32.exe
C:\Dell\DBRM\Reminder\DbrmTrayicon.exe
C:\Program Files\Microsoft Security Client\msseces.exe
C:\Program Files (x86)\Audible\Bin\AudibleDownloadHelper.exe
C:\Program Files (x86)\Dell Webcam\Dell Webcam Central\WebcamDell2.exe
C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe
C:\Program Files (x86)\Renesas Electronics\USB 3.0 Host Controller Driver\Application\nusb3mon.exe
C:\Program Files (x86)\iTunes\iTunesHelper.exe
C:\Program Files (x86)\Garmin\Lifetime Updater\GarminLifetime.exe
C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe
C:\Program Files (x86)\Nike\Nike+ Connect\Nike+ Connect daemon.exe
C:\Program Files (x86)\Common Files\Microsoft Shared\Virtualization Handler\CVHSVC.EXE
C:\Program Files (x86)\Intel\Bluetooth\mediasrv.exe
C:\windows\system32\SearchIndexer.exe
C:\Program Files (x86)\Intel\Bluetooth\BTPlayerCtrl.exe
C:\Program Files\DellTPad\ApMsgFwd.exe
C:\Program Files\DellTPad\Apntex.exe
C:\Program Files\DellTPad\HidFind.exe
C:\windows\System32\svchost.exe -k LocalServicePeerNet
C:\windows\system32\DllHost.exe
C:\Program Files (x86)\Dell Digital Delivery\DeliveryService.exe
C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe
C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
C:\windows\system32\sppsvc.exe
C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\UNS\UNS.exe
C:\windows\servicing\TrustedInstaller.exe
C:\windows\system32\vssvc.exe
C:\windows\System32\svchost.exe -k swprv
C:\windows\SysWOW64\cmd.exe
C:\windows\SysWOW64\cscript.exe
BHO: Adobe PDF Link Helper: {18df081c-e8ad-4283-a596-fa578c2ebdc3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
BHO: TmIEPlugInBHO Class: {1ca1377b-dc1d-4a52-9585-6e06050fac53} - C:\Program Files (x86)\Trend Micro\Client Server Security Agent\bho\1009\TmIEPlg32.dll
BHO: Java(tm) Plug-In SSV Helper: {761497bb-d6f0-462c-b6eb-d4daf1d92d43} - C:\Program Files (x86)\Java\jre6\bin\ssv.dll
BHO: Windows Live ID Sign-in Helper: {9030d464-4c02-4abf-8ecc-5164760863c6} - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
BHO: Skype add-on for Internet Explorer: {ae805869-2e5c-4ed4-8f7b-f1f7851a4497} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
BHO: WOT Helper: {c920e44a-7f78-4e64-bdd7-a57026e7feb7} - C:\Program Files (x86)\WOT\WOT.dll
BHO: Java(tm) Plug-In 2 SSV Helper: {dbc80044-a445-435b-bc74-9c25c1c588a9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll
TB: WOT: {71576546-354d-41c9-aae8-31f2ec22bf0d} - C:\Program Files (x86)\WOT\WOT.dll
uRun: [SUPERAntiSpyware] C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
mRun: [Dell Webcam Central] "C:\Program Files (x86)\Dell Webcam\Dell Webcam Central\WebcamDell2.exe" /mode2
mRun: [IAStorIcon] C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe
mRun: [NUSB3MON] "C:\Program Files (x86)\Renesas Electronics\USB 3.0 Host Controller Driver\Application\nusb3mon.exe"
mRun: [APSDaemon] "C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe"
mRun: [iTunesHelper] "C:\Program Files (x86)\iTunes\iTunesHelper.exe"
mRun: [Garmin Lifetime Updater] C:\Program Files (x86)\Garmin\Lifetime Updater\GarminLifetime.exe /StartMinimized
mRun: [SunJavaUpdateSched] "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe"
mRun: [Nike+ Connect] "C:\Program Files (x86)\Nike\Nike+ Connect\Nike+ Connect daemon.exe"
StartupFolder: C:\PROGRA~3\MICROS~1\Windows\STARTM~1\Programs\Startup\AUDIBL~1.LNK - C:\Program Files (x86)\Audible\Bin\AudibleDownloadHelper.exe
mPolicies-system: ConsentPromptBehaviorAdmin = 5 (0x5)
mPolicies-system: ConsentPromptBehaviorUser = 3 (0x3)
mPolicies-system: EnableUIADesktopToggle = 0 (0x0)
IE: Free YouTube Download - C:\Users\Nat\AppData\Roaming\DVDVideoSoftIEHelpers\freeytvdownloader.htm
IE: {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
DPF: {02BF25D5-8C17-4B23-BC80-D3488ABDDC6B} - hxxp://appldnld.apple.com.edgesuite.net/content.info.apple.com/QuickTime/qtactivex/qtplugin.cab
DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_31-windows-i586.cab
DPF: {CAFEEFAC-0016-0000-0031-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_31-windows-i586.cab
DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_31-windows-i586.cab
TCP: Interfaces\{8D34841B-CC98-4159-957A-B84EA7BF85A5} : DhcpNameServer = 192.168.1.254
TCP: Interfaces\{8D34841B-CC98-4159-957A-B84EA7BF85A5}\35F6E69636E2E65647F5639313 : DhcpNameServer = 192.168.1.1
TCP: Interfaces\{8D34841B-CC98-4159-957A-B84EA7BF85A5}\3627167766F62746 : DhcpNameServer = 192.168.1.1
TCP: Interfaces\{8D34841B-CC98-4159-957A-B84EA7BF85A5}\36A613031366 : DhcpNameServer = 192.168.0.1 205.171.3.25
TCP: Interfaces\{8D34841B-CC98-4159-957A-B84EA7BF85A5}\C696E6B6379737 : DhcpNameServer = 192.168.1.254
TCP: Interfaces\{8D34841B-CC98-4159-957A-B84EA7BF85A5}\D616474713 : DhcpNameServer = 192.168.2.1
TCP: Interfaces\{8D34841B-CC98-4159-957A-B84EA7BF85A5}\E4564776561627 : DhcpNameServer = 192.168.1.1
Handler: skype-ie-addon-data - {91774881-D725-4E58-B298-07617B9B86A8} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
Handler: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\PROGRA~2\COMMON~1\Skype\SKYPE4~1.DLL
Handler: tmpx - {0E526CB5-7446-41D1-A403-19BFE95E8C23} -
Handler: wlpg - {E43EF6CD-A37A-4A9B-9E6F-83F89B8E6324} - C:\Program Files (x86)\Windows Live\Photo Gallery\AlbumDownloadProtocolHandler.dll
Handler: wot - {C2A44D6B-CB9F-4663-88A6-DF2F26E4D952} - C:\Program Files (x86)\WOT\WOT.dll
LSA: Notification Packages = DPPassFilter scecli
BHO-X64: Adobe PDF Link Helper: {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
BHO-X64:     AcroIEHelperStub - No File
BHO-X64: TmIEPlugInBHO Class: {1CA1377B-DC1D-4A52-9585-6E06050FAC53} - C:\Program Files (x86)\Trend Micro\Client Server Security Agent\bho\1009\TmIEPlg32.dll
BHO-X64:     Trend Micro NSC BHO - No File
BHO-X64: Java(tm) Plug-In SSV Helper: {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files (x86)\Java\jre6\bin\ssv.dll
BHO-X64: Windows Live ID Sign-in Helper: {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
BHO-X64: Skype add-on for Internet Explorer: {AE805869-2E5C-4ED4-8F7B-F1F7851A4497} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
BHO-X64:     SkypeIEPluginBHO - No File
BHO-X64: WOT Helper: {C920E44A-7F78-4E64-BDD7-A57026E7FEB7} - C:\Program Files (x86)\WOT\WOT.dll
BHO-X64: Java(tm) Plug-In 2 SSV Helper: {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll
TB-X64: WOT: {71576546-354D-41c9-AAE8-31F2EC22BF0D} - C:\Program Files (x86)\WOT\WOT.dll
mRun-x64: [Dell Webcam Central] "C:\Program Files (x86)\Dell Webcam\Dell Webcam Central\WebcamDell2.exe" /mode2
mRun-x64: [IAStorIcon] C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe
mRun-x64: [NUSB3MON] "C:\Program Files (x86)\Renesas Electronics\USB 3.0 Host Controller Driver\Application\nusb3mon.exe"
mRun-x64: [Adobe ARM] "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
mRun-x64: [APSDaemon] "C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe"
mRun-x64: [iTunesHelper] "C:\Program Files (x86)\iTunes\iTunesHelper.exe"
mRun-x64: [Garmin Lifetime Updater] C:\Program Files (x86)\Garmin\Lifetime Updater\GarminLifetime.exe /StartMinimized
mRun-x64: [SunJavaUpdateSched] "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe"
mRun-x64: [Nike+ Connect] "C:\Program Files (x86)\Nike\Nike+ Connect\Nike+ Connect daemon.exe"
R0 MpFilter;Microsoft Malware Protection Driver;C:\windows\system32\DRIVERS\MpFilter.sys --> C:\windows\system32\DRIVERS\MpFilter.sys [?]
R0 stdcfltn;Disk Class Filter Driver for Accelerometer;C:\windows\system32\DRIVERS\stdcfltn.sys --> C:\windows\system32\DRIVERS\stdcfltn.sys [?]
R1 SASDIFSV;SASDIFSV;C:\Program Files\SUPERAntiSpyware\sasdifsv64.sys [2011-7-22 14928]
R1 SASKUTIL;SASKUTIL;C:\Program Files\SUPERAntiSpyware\saskutil64.sys [2011-7-12 12368]
R1 vwififlt;Virtual WiFi Filter Driver;C:\windows\system32\DRIVERS\vwififlt.sys --> C:\windows\system32\DRIVERS\vwififlt.sys [?]
R2 !SASCORE;SAS Core Service;C:\Program Files\SUPERAntiSpyware\SASCore64.exe [2011-8-11 140672]
R2 AdobeARMservice;Adobe Acrobat Update Service;C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe [2012-1-3 63928]
R2 AESTFilters;Andrea ST Filters Service;C:\Program Files\IDT\WDM\AESTSr64.exe [2011-9-14 89600]
R2 AMPPALR3;Intel® Centrino® Wireless Bluetooth® 3.0 + High Speed Service;C:\Program Files\Intel\BluetoothHS\BTHSAmpPalService.exe [2011-8-8 1166848]
R2 Bluetooth Device Monitor;Bluetooth Device Monitor;C:\Program Files (x86)\Intel\Bluetooth\devmonsrv.exe [2011-5-18 921664]
R2 Bluetooth OBEX Service;Bluetooth OBEX Service;C:\Program Files (x86)\Intel\Bluetooth\obexsrv.exe [2011-5-18 995392]
R2 BTHSSecurityMgr;Intel(R) Centrino(R) Wireless Bluetooth(R) 3.0 + High Speed Security Service;C:\Program Files\Intel\BluetoothHS\BTHSSecurityMgr.exe [2011-6-3 134928]
R2 cvhsvc;Client Virtualization Handler;C:\Program Files (x86)\Common Files\microsoft shared\Virtualization Handler\CVHSVC.EXE [2012-1-4 822624]
R2 DellDigitalDelivery;Dell Digital Delivery Service;C:\Program Files (x86)\Dell Digital Delivery\DeliveryService.exe [2012-4-10 166912]
R2 IAStorDataMgrSvc;Intel(R) Rapid Storage Technology;C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe [2011-9-14 13336]
R2 MediaMall Server;MediaMall Server;C:\Program Files (x86)\MediaMall\MediaMallServer.exe [2012-5-17 2976632]
R2 sftlist;Application Virtualization Client;C:\Program Files (x86)\Microsoft Application Virtualization Client\sftlist.exe [2011-10-1 508776]
R2 TurboB;Turbo Boost UI Monitor driver;C:\windows\system32\DRIVERS\TurboB.sys --> C:\windows\system32\DRIVERS\TurboB.sys [?]
R2 UNS;Intel(R) Management and Security Application User Notification Service;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\UNS\UNS.exe [2011-9-14 2655768]
R2 vcsFPService;Validity VCS Fingerprint Service;C:\Windows\System32\vcsFPService.exe [2010-12-3 2696496]
R3 Acceler;Accelerometer Service;C:\windows\system32\DRIVERS\Accelern.sys --> C:\windows\system32\DRIVERS\Accelern.sys [?]
R3 AMPPAL;Intel® Centrino® Wireless Bluetooth® 3.0 + High Speed Virtual Adapter;C:\windows\system32\DRIVERS\AMPPAL.sys --> C:\windows\system32\DRIVERS\AMPPAL.sys [?]
R3 Bluetooth Media Service;Bluetooth Media Service;C:\Program Files (x86)\Intel\Bluetooth\mediasrv.exe [2011-5-18 1335360]
R3 btmaudio;Intel Bluetooth Audio Service;C:\windows\system32\drivers\btmaud.sys --> C:\windows\system32\drivers\btmaud.sys [?]
R3 btmaux;Intel Bluetooth Auxiliary Service;C:\windows\system32\DRIVERS\btmaux.sys --> C:\windows\system32\DRIVERS\btmaux.sys [?]
R3 btmhsf;btmhsf;C:\windows\system32\DRIVERS\btmhsf.sys --> C:\windows\system32\DRIVERS\btmhsf.sys [?]
R3 CtClsFlt;Creative Camera Class Upper Filter Driver;C:\windows\system32\DRIVERS\CtClsFlt.sys --> C:\windows\system32\DRIVERS\CtClsFlt.sys [?]
R3 iBtFltCoex;iBtFltCoex;C:\windows\system32\DRIVERS\iBtFltCoex.sys --> C:\windows\system32\DRIVERS\iBtFltCoex.sys [?]
R3 IntcDAud;Intel(R) Display Audio;C:\windows\system32\DRIVERS\IntcDAud.sys --> C:\windows\system32\DRIVERS\IntcDAud.sys [?]
R3 iwdbus;IWD Bus Enumerator;C:\windows\system32\DRIVERS\iwdbus.sys --> C:\windows\system32\DRIVERS\iwdbus.sys [?]
R3 MEIx64;Intel(R) Management Engine Interface;C:\windows\system32\DRIVERS\HECIx64.sys --> C:\windows\system32\DRIVERS\HECIx64.sys [?]
R3 NETwNs64;___ Intel(R) Wireless WiFi Link 5000 Series Adapter Driver for Windows 7 - 64 Bit;C:\windows\system32\DRIVERS\NETwNs64.sys --> C:\windows\system32\DRIVERS\NETwNs64.sys [?]
R3 nusb3hub;Renesas Electronics USB 3.0 Hub Driver;C:\windows\system32\DRIVERS\nusb3hub.sys --> C:\windows\system32\DRIVERS\nusb3hub.sys [?]
R3 nusb3xhc;Renesas Electronics USB 3.0 Host Controller Driver;C:\windows\system32\DRIVERS\nusb3xhc.sys --> C:\windows\system32\DRIVERS\nusb3xhc.sys [?]
R3 RTL8167;Realtek 8167 NT Driver;C:\windows\system32\DRIVERS\Rt64win7.sys --> C:\windows\system32\DRIVERS\Rt64win7.sys [?]
R3 Sftfs;Sftfs;C:\windows\system32\DRIVERS\Sftfslh.sys --> C:\windows\system32\DRIVERS\Sftfslh.sys [?]
R3 Sftplay;Sftplay;C:\windows\system32\DRIVERS\Sftplaylh.sys --> C:\windows\system32\DRIVERS\Sftplaylh.sys [?]
R3 Sftredir;Sftredir;C:\windows\system32\DRIVERS\Sftredirlh.sys --> C:\windows\system32\DRIVERS\Sftredirlh.sys [?]
R3 Sftvol;Sftvol;C:\windows\system32\DRIVERS\Sftvollh.sys --> C:\windows\system32\DRIVERS\Sftvollh.sys [?]
R3 sftvsa;Application Virtualization Service Agent;C:\Program Files (x86)\Microsoft Application Virtualization Client\sftvsa.exe [2011-10-1 219496]
R3 vwifimp;Microsoft Virtual WiFi Miniport Service;C:\windows\system32\DRIVERS\vwifimp.sys --> C:\windows\system32\DRIVERS\vwifimp.sys [?]
S2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe [2010-3-18 130384]
S2 clr_optimization_v4.0.30319_64;Microsoft .NET Framework NGEN v4.0.30319_X64;C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscorsvw.exe [2010-3-18 138576]
S3 AdobeFlashPlayerUpdateSvc;Adobe Flash Player Update Service;C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe [2012-5-12 250056]
S3 AMPPALP;Intel® Centrino® Wireless Bluetooth® 3.0 + High Speed Protocol;C:\windows\system32\DRIVERS\amppal.sys --> C:\windows\system32\DRIVERS\amppal.sys [?]
S3 dmvsc;dmvsc;C:\windows\system32\drivers\dmvsc.sys --> C:\windows\system32\drivers\dmvsc.sys [?]
S3 intaud_WaveExtensible;Intel WiDi Audio Device;C:\windows\system32\drivers\intelaud.sys --> C:\windows\system32\drivers\intelaud.sys [?]
S3 MyWiFiDHCPDNS;Wireless PAN DHCP Server;C:\Program Files\Intel\WiFi\bin\PanDhcpDns.exe [2011-7-27 340240]
S3 NisDrv;Microsoft Network Inspection System;C:\windows\system32\DRIVERS\NisDrvWFP.sys --> C:\windows\system32\DRIVERS\NisDrvWFP.sys [?]
S3 NisSrv;Microsoft Network Inspection;C:\Program Files\Microsoft Security Client\NisSrv.exe [2012-3-26 291696]
S3 osppsvc;Office Software Protection Platform;C:\Program Files\Common Files\Microsoft Shared\OfficeSoftwareProtectionPlatform\OSPPSVC.EXE [2010-1-9 4925184]
S3 RSUSBSTOR;RtsUStor.Sys Realtek USB Card Reader;C:\windows\system32\Drivers\RtsUStor.sys --> C:\windows\system32\Drivers\RtsUStor.sys [?]
S3 RTL8187;NETGEAR WG111v2 54Mbps Wireless USB 2.0 Adapter Vista Driver;C:\windows\system32\DRIVERS\wg111v2.sys --> C:\windows\system32\DRIVERS\wg111v2.sys [?]
S3 StorSvc;Storage Service;C:\windows\System32\svchost.exe -k LocalSystemNetworkRestricted [2009-7-13 20992]
S3 SydexFDD;Sydex Diskette Driver;C:\Windows\SysWOW64\drivers\SYDEXFDD.SYS [2012-3-16 13359]
S3 TsUsbFlt;TsUsbFlt;C:\windows\system32\drivers\tsusbflt.sys --> C:\windows\system32\drivers\tsusbflt.sys [?]
S3 TsUsbGD;Remote Desktop Generic USB Device;C:\windows\system32\drivers\TsUsbGD.sys --> C:\windows\system32\drivers\TsUsbGD.sys [?]
S3 TurboBoost;Intel(R) Turbo Boost Technology Monitor 2.0;C:\Program Files\Intel\TurboBoost\TurboBoost.exe [2010-11-29 149504]
S3 USBAAPL64;Apple Mobile USB Driver;C:\windows\system32\Drivers\usbaapl64.sys --> C:\windows\system32\Drivers\usbaapl64.sys [?]
S3 WatAdminSvc;Windows Activation Technologies Service;C:\windows\system32\Wat\WatAdminSvc.exe --> C:\windows\system32\Wat\WatAdminSvc.exe [?]
S4 wlcrasvc;Windows Live Mesh remote connections service;C:\Program Files\Windows Live\Mesh\wlcrasvc.exe [2010-9-22 57184]
2012-07-07 18:09:30   --------   d-----w-   C:\windows\Microsoft Antimalware
2012-07-07 17:03:07   --------   d-sh--w-   C:\$RECYCLE.BIN
2012-07-06 21:39:21   --------   d-----w-   C:\MGADiagToolOutput
2012-07-04 21:29:14   --------   d-----w-   C:\Program Files (x86)\ESET
2012-07-04 15:54:59   --------   d-----w-   C:\windows\System32\appmgmt
2012-07-03 16:10:50   98816   ----a-w-   C:\windows\sed.exe
2012-07-03 16:10:50   518144   ----a-w-   C:\windows\SWREG.exe
2012-07-03 16:10:50   256000   ----a-w-   C:\windows\PEV.exe
2012-07-03 16:10:50   208896   ----a-w-   C:\windows\MBR.exe
2012-06-30 20:49:15   --------   d-sh--w-   C:\windows\System32\%APPDATA%
2012-06-21 15:51:16   2622464   ----a-w-   C:\windows\System32\wucltux.dll
2012-06-21 15:50:55   36864   ----a-w-   C:\windows\System32\wuapp.exe
2012-06-21 15:50:55   186752   ----a-w-   C:\windows\System32\wuwebv.dll
2012-06-20 22:39:29   9013136   ----a-w-   C:\ProgramData\Microsoft\Microsoft Antimalware\Definition Updates\{8FCC415D-B7FB-49ED-80C6-74B39BC1744B}\mpengine.dll
2012-06-19 22:27:44   9013136   ----a-w-   C:\ProgramData\Microsoft\Microsoft Antimalware\Definition Updates\Backup\mpengine.dll
2012-06-13 15:19:59   9216   ----a-w-   C:\windows\System32\rdrmemptylst.exe
2012-06-12 15:24:43   927800   ------w-   C:\ProgramData\Microsoft\Microsoft Antimalware\Definition Updates\{149BB2C9-459F-4F19-98C5-C083FD89B67B}\gapaengine.dll
2012-06-23 04:19:48   70344   ----a-w-   C:\windows\SysWow64\FlashPlayerCPLApp.cpl
2012-06-23 04:19:48   426184   ----a-w-   C:\windows\SysWow64\FlashPlayerApp.exe
2012-05-18 02:06:48   2311680   ----a-w-   C:\windows\System32\jscript9.dll
2012-05-18 01:59:14   1392128   ----a-w-   C:\windows\System32\wininet.dll
2012-05-18 01:58:39   1494528   ----a-w-   C:\windows\System32\inetcpl.cpl
2012-05-18 01:55:22   173056   ----a-w-   C:\windows\System32\ieUnatt.exe
2012-05-18 01:51:30   2382848   ----a-w-   C:\windows\System32\mshtml.tlb
2012-05-17 22:45:37   1800192   ----a-w-   C:\windows\SysWow64\jscript9.dll
2012-05-17 22:35:47   1129472   ----a-w-   C:\windows\SysWow64\wininet.dll
2012-05-17 22:35:39   1427968   ----a-w-   C:\windows\SysWow64\inetcpl.cpl
2012-05-17 22:29:45   142848   ----a-w-   C:\windows\SysWow64\ieUnatt.exe
2012-05-17 22:24:45   2382848   ----a-w-   C:\windows\SysWow64\mshtml.tlb
2012-05-15 01:32:33   3146752   ----a-w-   C:\windows\System32\win32k.sys
2012-05-04 11:06:22   5559664   ----a-w-   C:\windows\System32\ntoskrnl.exe
2012-05-04 10:03:53   3968368   ----a-w-   C:\windows\SysWow64\ntkrnlpa.exe
2012-05-04 10:03:50   3913072   ----a-w-   C:\windows\SysWow64\ntoskrnl.exe
2012-05-01 05:40:20   209920   ----a-w-   C:\windows\System32\profsvc.dll
2012-04-28 03:55:21   210944   ----a-w-   C:\windows\System32\drivers\rdpwd.sys
2012-04-26 05:41:56   77312   ----a-w-   C:\windows\System32\rdpwsx.dll
2012-04-26 05:41:55   149504   ----a-w-   C:\windows\System32\rdpcorekmts.dll
2012-04-24 05:37:37   184320   ----a-w-   C:\windows\System32\cryptsvc.dll
2012-04-24 05:37:37   140288   ----a-w-   C:\windows\System32\cryptnet.dll
2012-04-24 05:37:36   1462272   ----a-w-   C:\windows\System32\crypt32.dll
2012-04-24 04:36:42   140288   ----a-w-   C:\windows\SysWow64\cryptsvc.dll
2012-04-24 04:36:42   1158656   ----a-w-   C:\windows\SysWow64\crypt32.dll
2012-04-24 04:36:42   103936   ----a-w-   C:\windows\SysWow64\cryptnet.dll
2012-04-18 20:49:50   405176   ----a-w-   C:\windows\SysWow64\Newtonsoft.Json.Net20.dll
============= FINISH: 10:28:09.75 ===============
Hi, Linda.
From what has turned up so far on that computer, I would strongly advise you to not do any online banking or credit card transactions until you can go to a known clean computer and change your passwords.  The description of just one.  With its rootkit capabilities, you are likely best off backing up critical data and doing a clean install.
QuoteTrojanDownloader:Win32/Cutwail.BE is a member of Win32/Cutwail - a multi-component family of malware that downloads and executes arbitrary files. This functionality is mostly used to install additional Cutwail components, and other malware on an affected computer. In general, the Cutwail family is used to compromise computers and direct them in various ways at the attacker's will, usually for monetary gain. This could include using the affected computer to distribute additional malware, send spam, generate 'pay per click' advertising revenue, harvest email addresses, and break captchas. Its components are varied, but include trojan downloaders and droppers, spammers, and viruses. Cutwail also employs a rootkit and other defensive techniques to avoid detection and removal.
That said, I am not seeing the persistent files that continued to show up in the ComboFix log and am hoping that Windows Defender Offline was successful in removing them.  We'll find out after the next steps.
Custom CFScript
DDS::
linda93
Thanks, I stopped using this computer when I fist found out what a rootkit was, but that's a good point about the passwords.
ComboFix 12-07-07.04 - Nat 07/07/2012  12:05:50.4.4 - x64
Microsoft Windows 7 Professional   6.1.7601.1.1252.1.1033.18.4003.2534 [GMT -7:00]
(((((((((((((((((((((((((   Files Created from 2012-06-07 to 2012-07-07  )))))))))))))))))))))))))))))))
2012-07-07 19:09 . 2012-07-07 19:09   --------   d-----w-   c:\users\Default\AppData\Local\temp
2012-07-07 18:09 . 2012-07-07 18:09   --------   d-----w-   c:\windows\Microsoft Antimalware
2012-07-06 21:39 . 2012-07-06 21:39   --------   d-----w-   C:\MGADiagToolOutput
2012-07-06 21:39 . 2012-07-06 21:39   --------   d-----w-   c:\programdata\Office Genuine Advantage
+ 2012-07-07 17:07 . 2012-07-07 17:07   11799              c:\windows\SysWOW64\config\systemprofile\AppData\Roaming\SoftGrid Client\Icon Cache\icon_ex.dat
+ 2012-07-07 17:03 . 2012-07-07 17:03   16384              c:\windows\SysWOW64\config\systemprofile\AppData\Roaming\Microsoft\Windows\PrivacIE\index.dat
+ 2009-07-14 04:54 . 2012-07-07 17:22   16384              c:\windows\SysWOW64\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2009-07-14 04:54 . 2012-07-07 17:22   81920              c:\windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
+ 2009-07-14 04:54 . 2012-07-07 17:22   16384              c:\windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2012-07-07 17:03 . 2012-07-07 17:03   49120              c:\windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Internet Explorer\MSIMGSIZ.DAT
+ 2010-11-21 03:09 . 2012-07-07 17:22   42934              c:\windows\system32\wdi\ShutdownPerformanceDiagnostics_SystemData.bin
+ 2009-07-14 05:10 . 2012-07-07 17:22   39772              c:\windows\system32\wdi\BootPerformanceDiagnostics_SystemData.bin
+ 2011-09-20 20:48 . 2012-07-07 17:22   7672              c:\windows\system32\wdi\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-2243763373-2349021115-3601667197-1000_UserData.bin
+ 2012-07-07 17:20 . 2012-07-07 17:20   2048              c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive1.dat
+ 2012-07-07 17:20 . 2012-07-07 17:20   2048              c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive0.dat
+ 2011-09-20 21:38 . 2012-07-07 15:47   242650              c:\windows\system32\wdi\SuspendPerformanceDiagnostics_SystemData_S3.bin
+ 2009-07-14 02:36 . 2012-07-07 17:24   673892              c:\windows\system32\perfh009.dat
+ 2009-07-14 02:36 . 2012-07-07 17:24   125918              c:\windows\system32\perfc009.dat
+ 2011-09-20 20:49 . 2012-07-06 21:36   327680              c:\windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2009-07-14 04:46 . 2012-07-06 21:39   184896              c:\windows\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\SoftwareProtectionPlatform\Cache\cache.dat
+ 2012-07-07 18:16 . 2012-07-07 18:18   262144              c:\windows\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\usrclass.dat
+ 2012-07-07 18:09 . 2012-07-07 18:18   262144              c:\windows\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\usrclass.dat
+ 2009-07-14 05:01 . 2012-07-07 17:07   235556              c:\windows\ServiceProfiles\LocalService\AppData\Local\FontCache-System.dat
+ 2012-07-07 18:09 . 2012-07-07 18:19   159744              c:\windows\Microsoft Antimalware\Support\MpWppTracing-07072012-100930-00000003-ffffffff.bin
+ 2012-07-07 18:09 . 2012-07-07 18:09   311296              c:\windows\Microsoft Antimalware\Scans\History\CacheManager\MpScanCache-0.bin
+ 2011-09-20 20:49 . 2012-07-06 21:36   2736128              c:\windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
+ 2011-09-23 10:33 . 2012-07-07 17:07   5087064              c:\windows\ServiceProfiles\LocalService\AppData\Local\FontCache-S-1-5-21-2243763373-2349021115-3601667197-1000-8192.dat
+ 2012-06-30 19:25 . 2012-07-07 17:07   7775060              c:\windows\ServiceProfiles\LocalService\AppData\Local\FontCache-S-1-5-18-16384.dat
+ 2012-07-07 18:09 . 2012-06-18 11:12   9013136              c:\windows\Microsoft Antimalware\Definition Updates\{6E43E0BB-5118-4DE5-A286-771C3D8FB2C6}\mpengine.dll
+ 2009-07-14 04:54 . 2012-07-06 21:36   11403264              c:\windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
REGEDIT4
@="Driver"
    R3 AMPPALP;Intel® Centrino® Wireless Bluetooth® 3.0 + High Speed Protocol;c:\windows\system32\DRIVERS\amppal.sys [2011-08-08 299008]
    R3 dmvsc;dmvsc;c:\windows\system32\drivers\dmvsc.sys [2010-11-21 71168]
    R3 intaud_WaveExtensible;Intel WiDi Audio Device;c:\windows\system32\drivers\intelaud.sys [2011-03-24 34200]
    R3 NisDrv;Microsoft Network Inspection System;c:\windows\system32\DRIVERS\NisDrvWFP.sys [2012-03-21 98688]
    R3 RSUSBSTOR;RtsUStor.Sys Realtek USB Card Reader;c:\windows\system32\Drivers\RtsUStor.sys [2010-10-30 250984]
    R3 RTL8187;NETGEAR WG111v2 54Mbps Wireless USB 2.0 Adapter Vista Driver;c:\windows\system32\DRIVERS\wg111v2.sys [2007-12-26 340992]
    R3 TsUsbFlt;TsUsbFlt;c:\windows\system32\drivers\tsusbflt.sys [2010-11-21 59392]
    R3 TsUsbGD;Remote Desktop Generic USB Device;c:\windows\system32\drivers\TsUsbGD.sys [2010-11-21 31232]
    R3 USBAAPL64;Apple Mobile USB Driver;c:\windows\system32\Drivers\usbaapl64.sys [2011-08-03 51712]
    S0 stdcfltn;Disk Class Filter Driver for Accelerometer;c:\windows\system32\DRIVERS\stdcfltn.sys [2010-08-20 21616]
    S1 SASDIFSV;SASDIFSV;c:\program files\SUPERAntiSpyware\SASDIFSV64.SYS [2011-07-22 14928]
    S1 SASKUTIL;SASKUTIL;c:\program files\SUPERAntiSpyware\SASKUTIL64.SYS [2011-07-12 12368]
    S1 vwififlt;Virtual WiFi Filter Driver;c:\windows\system32\DRIVERS\vwififlt.sys [2009-07-14 59904]
    S2 TurboB;Turbo Boost UI Monitor driver;c:\windows\system32\DRIVERS\TurboB.sys [2010-11-29 16120]
    S3 Acceler;Accelerometer Service;c:\windows\system32\DRIVERS\Accelern.sys [2010-12-13 27760]
    S3 AMPPAL;Intel® Centrino® Wireless Bluetooth® 3.0 + High Speed Virtual Adapter;c:\windows\system32\DRIVERS\AMPPAL.sys [2011-08-08 299008]
    S3 btmaudio;Intel Bluetooth Audio Service;c:\windows\system32\drivers\btmaud.sys [2011-05-19 51712]
    S3 btmaux;Intel Bluetooth Auxiliary Service;c:\windows\system32\DRIVERS\btmaux.sys [2011-05-19 53248]
    S3 btmhsf;btmhsf;c:\windows\system32\DRIVERS\btmhsf.sys [2011-07-19 282624]
    S3 CtClsFlt;Creative Camera Class Upper Filter Driver;c:\windows\system32\DRIVERS\CtClsFlt.sys [2011-01-20 176096]
    S3 iBtFltCoex;iBtFltCoex;c:\windows\system32\DRIVERS\iBtFltCoex.sys [2011-07-19 59904]
    S3 IntcDAud;Intel(R) Display Audio;c:\windows\system32\DRIVERS\IntcDAud.sys [2010-10-15 317440]
    S3 iwdbus;IWD Bus Enumerator;c:\windows\system32\DRIVERS\iwdbus.sys [2011-03-24 25496]
    S3 MEIx64;Intel(R) Management Engine Interface;c:\windows\system32\DRIVERS\HECIx64.sys [2010-09-21 56344]
    S3 NETwNs64;___ Intel(R) Wireless WiFi Link 5000 Series Adapter Driver for Windows 7 - 64 Bit;c:\windows\system32\DRIVERS\NETwNs64.sys [2011-08-03 8604672]
    S3 nusb3hub;Renesas Electronics USB 3.0 Hub Driver;c:\windows\system32\DRIVERS\nusb3hub.sys [2010-12-10 80384]
    S3 nusb3xhc;Renesas Electronics USB 3.0 Host Controller Driver;c:\windows\system32\DRIVERS\nusb3xhc.sys [2010-12-10 181248]
    S3 RTL8167;Realtek 8167 NT Driver;c:\windows\system32\DRIVERS\Rt64win7.sys [2010-10-26 406632]
    S3 Sftfs;Sftfs;c:\windows\system32\DRIVERS\Sftfslh.sys [2011-10-01 764264]
    S3 Sftplay;Sftplay;c:\windows\system32\DRIVERS\Sftplaylh.sys [2011-10-01 268648]
    S3 Sftredir;Sftredir;c:\windows\system32\DRIVERS\Sftredirlh.sys [2011-10-01 25960]
    S3 Sftvol;Sftvol;c:\windows\system32\DRIVERS\Sftvollh.sys [2011-10-01 22376]
    S3 vwifimp;Microsoft Virtual WiFi Miniport Service;c:\windows\system32\DRIVERS\vwifimp.sys [2009-07-14 17920]
    2012-07-07 c:\windows\Tasks\Adobe Flash Player Updater.job
    2012-07-06 c:\windows\Tasks\SystemToolsDailyTest.job
    Completion time: 2012-07-07  12:11:01
    ComboFix-quarantined-files.txt  2012-07-07 19:11
    ComboFix2.txt  2012-07-06 21:35
    ComboFix3.txt  2012-07-04 16:11
    ComboFix4.txt  2012-07-03 16:31
    Pre-Run: 250,100,555,776 bytes free
    Post-Run: 250,071,568,384 bytes free
    - - End Of File - - 30E36E16B117B8F64FC6479120AF8A1C
Hi, Linda.
First, to address the "Test Mode Windows 7 Build 7601" error, which is likely due to the unsigned driver from the rootkit:
  •   Type CMD in the Start menu search box.  When it comes up, right-click CMD and select Run as administrator.
  •   Type and execute the following commands, one at a time, exactly as shown below:
    bcdedit.exe -set loadoptions ENABLE_INTEGRITY_CHECKS
    bcdedit.exe -set TESTSIGNING OFF
  •   Exit the Command Prompt, and then restart Windows 7.
(The procedure is documented on the Microsoft TechNet help forums and illustrated at How To Remove "Test Mode Windows 7 Build 7601" Watermark From Windows 7 Desktop.)
The System File Checker tool
To determine whether the issue that you are experiencing is caused by one or more system files that are used by Windows, run the System File Checker tool. The System File Checker tool scans system files and replaces incorrect versions of the system files by using the correct versions.
To run the System File Checker tool, follow these steps:
  • Click Start, and then type cmd in the Start Search box.
  • Right-click cmd in the Programs list, and then click Run as administrator.
  • At the command prompt, type the following line, and then press ENTER:
    sfc /scannow (note the space before the forward slash)
  • When the scan is complete, test to see whether the issue that you are experiencing is resolved.
Following that, let's see what shows in an updated MBAM scan:
  • Launch Malwarebytes' Anti-Malware then click the Update tab and "Check for Updates
  • Once the update has been installed and the program has loaded, select Quick scan
    • Click Remove Selected.
    ** Note **
linda93
The Windows error message was gone once I restarted after the first CMD commands.
Windows Resource Protection did not find any intergrity violations.
I still cannot start Windows Security Essentials.
There was nothing to remove at the end of scan in Malwarebytes.  Here is the log.
Malwarebytes Anti-Malware 1.61.0.1400
www.malwarebytes.org
Database version: v2012.07.07.07
Windows 7 Service Pack 1 x64 NTFS
Internet Explorer 9.0.8112.16421
Nat :: NAT-PC [administrator]
7/7/2012 2:45:49 PM
mbam-log-2012-07-07 (14-45-49).txt
Scan type: Quick scan
Scan options disabled: P2P
Objects scanned: 209581
Time elapsed: 1 minute(s), 38 second(s)
Memory Processes Detected: 0
(No malicious items detected)
Memory Modules Detected: 0
Registry Keys Detected: 0
Registry Values Detected: 0
Folders Detected: 0
Files Detected: 0
(end)
Hi, Linda.
Can you access the Windows Security Center?  Is the Windows 7 Firewall operational?
Let's try manually starting the service for Microsoft Security Essentials.
  • For Windows 7, click Start, click in the Start Search box, type services.msc, and then press Enter.
  • Search for Microsoft Antimalware Service. Right-click it and select Properties or double-click it to open the service.
  • Check to make sure that the "Startup Type" is set to "Automatic".
  • Click the Start button to start the service. If the Start button isn't available, click the Stop button, and then click the Start button to restart the service.
  • Make sure you note any errors that may appear during this process, submit a case online, and include the error information.
linda93
Thanks so much.
My firewall is on.  But I followed your directions and still Eindows Defender and Microsoft Security Essentials both report that they are turned off.  I restarted and changed the settings again but still no.
Anyway, if I understand correctly, I should take this issue to Microsoft?
Linda
Let's try reinstalling Microsoft Security Essentials:
  • Click Start, and in the Start Search box, type appwiz.cpl, and then press Enter.
  • In the list of installed programs, click Microsoft Security Essentials, and then uninstall it.
  • If prompted, restart your computer, and then try to install Microsoft Security Essentials again.
Download link:  Download: Microsoft Security Essentials - Microsoft Download Center - Download Details
linda93
Thanks Corrine, that did it, Windows Security is running again.
