139d2e78.exe again
Started by PeterJ, June 19, 2013, 02:39:33 PM
PeterJ
Hi. It seems I have pretty much the same problem as  Ovaunda had recently.  I am locked out of my account on this PC (which is the Adminstrator's account). I can only access the computer via my wife's account at the moment. My symptoms are that when I try to log into my account I get a command prompt that says '"C:\Documents and Settings\user\My Documents\139d2e78.exe"' is not recognised as an operable program or batch file C:\Documents and Settings\User> - and I then can go no further.
I have a fairly elderly Dell Dimension 8250 running Windows XP Professional Version 5.1.2600 Service Pack 3 Build 2600.
I have tried Malwarebytes which found and removed 139d2e78.dll (not .exe) but the problem persists.
I also bought PC Cleaner Pro on the recommendation I found via Google but I'm regretting  that decision already. It has not fixed the problem and their 'expert' technical support service was no help at all.  I have now uninstalled it.
One more thing - I have downloaded DDS.scr and run it but the resulting text file is gobblydook - here's a small sample
 ÆãK@×lÿà   \ÔkÙwÑ`2ˆp!@ à•€ØI½o¶
How can I correct that please?
Here is my Checkup log:
Results of screen317's Security Check version 0.99.66
Windows XP Service Pack 3 x86 (UAC is disabled!)
Internet Explorer 8 Out of date!
Windows Firewall Disabled!
Please wait while WMIC compiles updated MOF files.d
i
s
p
l
a
y
N
a
m
e
ECHO is off.
P
C
ECHO is off.
C
l
e
a
n
e
r
ECHO is off.
P
r
o
ECHO is off.
A
V
G
ECHO is off.
A
n
t
i
V
i
r
u
s
ECHO is off.
F
r
e
ECHO is off.
E
d
i
t
i
o
n
ECHO is off.
2
0
1
2
ECHO is off.
Antivirus up to date! (On Access scanning disabled!)
Malwarebytes Anti-Malware version 1.75.0.1300
Java(TM) 6 Update 24
Java version out of Date!
Adobe Flash Player    11.7.700.202
Adobe Reader 10.1.7 Adobe Reader out of Date!
AVG avgwdsvc.exe
AVG avgtray.exe
AVG avgrsx.exe
AVG avgnsx.exe
AVG avgemc.exe
Total Fragmentation on Drive C:: 22% Defragment your hard drive soon! (Do NOT defrag if SSD!)
Hi, PeterJ.  Welcome to LandzDown Forum.
1.  Based on the reputation of PC Cleaner Pro, please consider contacting your credit card company.  You may be able to get the charges reversed.  See WOT for information about PC Cleaner Pro:  http://www.mywot.com/en/scorecard/pccleanerpro.com/event-84510#events
2.  Can you log on to our account via Safe Mode, ideally Safe Mode with Networking?  To do this, turn your computer off and then back on and immediately when you see anything on the screen, start tapping the F8 key on your keyboard. Using the arrow keys on your keyboard, select Safe Mode with Networking and press Enter on your keyboard. Windows will now boot into safe mode with networking and prompt you to login as a user.  If so, please see if you get readable DDS logs in Safe Mode.
3.  Please download the TDSSKiller.exe by Kaspersky... save it to your Desktop. <-Important!!!.  If you can get to safe mode with networking, please do this with your Admin account.  Otherwise, we'll see what happens with your wife's account.
  • Double-click on TDSSKiller.exe to run the tool for known TDSS variants.
    Vista - W7 users: Right-click and select "Run As Administrator".
    If TDSSKiller does not run... rename it. Right-click on TDSSKiller.exe, select Rename and give it a random name with the .com file extension (i.e. ektfhtw.com). If you don't see file extensions, please see:  How to change the file extension.
  • Click the Start Scan button.  Do not use the computer during the scan!
  • If the scan completes with nothing found, click Close to exit.
  • If malicious objects are found, they will show in the "Scan results - Select action for found objects[/b]" and offer 3 options.
    • Ensure SKIP is selected... DO NOT attempt to FIX anything yet!
    • Now click on Report to open the log file created by TDSSKiller in your root directory C:\
  • A log file named TDSSKiller_version_dd.mm.yyyy_hh.mm.ss_log.txt will be created and saved to the root directory. (usually Local Disk C:).
  • Copy and paste the contents of that file in your next reply.
PeterJ
Thanks Corinne. Unfortunately I paid for PC Cleaner Pro with my debit card, not a credit card, so doubt I'll see my money again :cry: .  I guess I'll just have to write that off and try to learn from it!
Before I respond to your instructions I want you to know that it's 10.20pm here in London.  Unless you can respond within say the next hour don't worry about it. I'll just get some beauty sleep and pick this up again in the morning.
So....
>I can't get into my account in Safe Mode with Networking.
>Using my wife's account I have tried DSS again when in Safe Mode with Networking and still don't get readable logs.
> I ran a TDSSKiller scan (again in Safe Mode with Networking) but it found nothing. The log reads:
22:06:57.0359 0396  TDSS rootkit removing tool 2.8.18.0 Jun 10 2013 21:44:19
22:06:57.0546 0396  ============================================================
22:06:57.0546 0396  Current date / time: 2013/06/19 22:06:57.0546
22:06:57.0546 0396  SystemInfo:
22:06:57.0546 0396
22:06:57.0546 0396  OS Version: 5.1.2600 ServicePack: 3.0
22:06:57.0546 0396  Product type: Workstation
22:06:57.0546 0396  ComputerName: PETER
22:06:57.0546 0396  UserName: All of Us
22:06:57.0546 0396  Windows directory: C:\WINDOWS
22:06:57.0546 0396  System windows directory: C:\WINDOWS
22:06:57.0546 0396  Processor architecture: Intel x86
22:06:57.0546 0396  Number of processors: 1
22:06:57.0546 0396  Page size: 0x1000
22:06:57.0546 0396  Boot type: Safe boot with network
22:07:05.0468 0396  Drive \Device\Harddisk0\DR0 - Size: 0x953C94000 (37.31 Gb), SectorSize: 0x200, Cylinders: 0x1306, SectorsPerTrack: 0x3F, TracksPerCylinder: 0xFF, Type 'K0', Flags 0x00000054
22:07:05.0468 0396  Drive \Device\Harddisk1\DR2 - Size: 0x7470C06000 (465.76 Gb), SectorSize: 0x200, Cylinders: 0xED81, SectorsPerTrack: 0x3F, TracksPerCylinder: 0xFF, Type 'W'
22:07:05.0500 0396  ============================================================
22:07:05.0500 0396  \Device\Harddisk0\DR0:
22:07:05.0500 0396  MBR partitions:
22:07:05.0500 0396  \Device\Harddisk0\DR0\Partition1: MBR, Type 0x7, StartLBA 0x3F, BlocksNum 0x4A98C86
22:07:05.0500 0396  \Device\Harddisk1\DR2:
22:07:05.0500 0396  \Device\Harddisk1\DR2\Partition1: MBR, Type 0x7, StartLBA 0x3F, BlocksNum 0x3A384C41
22:07:05.0531 0396  C: <-> \Device\Harddisk0\DR0\Partition1
22:07:05.0687 0396  F: <-> \Device\Harddisk1\DR2\Partition1
22:07:05.0687 0396  ============================================================
22:07:05.0687 0396  Initialize success
22:07:21.0343 0408  ============================================================
22:07:21.0343 0408  Scan started
22:07:21.0343 0408  Mode: Manual;
22:07:22.0656 0408  ================ Scan system memory ========================
22:07:22.0656 0408  System memory - ok
22:07:22.0656 0408  ================ Scan services =============================
22:07:22.0781 0408  Abiosdsk - ok
22:07:22.0812 0408  abp480n5 - ok
22:07:22.0890 0408  [ 8FD99680A539792A30E97944FDAECF17 ] ACPI            C:\WINDOWS\system32\DRIVERS\ACPI.sys
22:07:22.0890 0408  ACPI - ok
22:07:22.0953 0408  [ 9859C0F6936E723E4892D7141B1327D5 ] ACPIEC          C:\WINDOWS\system32\drivers\ACPIEC.sys
22:07:22.0968 0408  ACPIEC - ok
22:07:22.0984 0408  Ad-Watch Connect Filter - ok
22:07:23.0015 0408  ADILOADER - ok
22:07:23.0046 0408  adiusbaw - ok
22:07:23.0171 0408  [ F040037B149FD0F5A5044AE563390FA7 ] AdobeFlashPlayerUpdateSvc C:\WINDOWS\system32\Macromed\Flash\FlashPlayerUpdateService.exe
22:07:23.0171 0408  AdobeFlashPlayerUpdateSvc - ok
22:07:23.0203 0408  adpu160m - ok
22:07:23.0250 0408  [ 8BED39E3C35D6A489438B8141717A557 ] aec             C:\WINDOWS\system32\drivers\aec.sys
22:07:23.0265 0408  aec - ok
22:07:23.0328 0408  [ 1E44BC1E83D8FD2305F8D452DB109CF9 ] AFD             C:\WINDOWS\System32\drivers\afd.sys
22:07:23.0343 0408  AFD - ok
22:07:23.0406 0408  [ 08FD04AA961BDC77FB983F328334E3D7 ] agp440          C:\WINDOWS\system32\DRIVERS\agp440.sys
22:07:23.0406 0408  agp440 - ok
22:07:23.0437 0408  Aha154x - ok
22:07:23.0468 0408  aic78u2 - ok
22:07:23.0500 0408  aic78xx - ok
22:07:23.0578 0408  [ A9A3DAA780CA6C9671A19D52456705B4 ] Alerter         C:\WINDOWS\system32\alrsvc.dll
22:07:23.0578 0408  Alerter - ok
22:07:23.0640 0408  [ 8C515081584A38AA007909CD02020B3D ] ALG             C:\WINDOWS\System32\alg.exe
22:07:23.0640 0408  ALG - ok
22:07:23.0671 0408  AliIde - ok
22:07:23.0703 0408  amsint - ok
22:07:23.0828 0408  [ F401929EE0CC92BFE7F15161CA535383 ] Apple Mobile Device C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
22:07:23.0843 0408  Apple Mobile Device - ok
22:07:23.0937 0408  [ D8849F77C0B66226335A59D26CB4EDC6 ] AppMgmt         C:\WINDOWS\System32\appmgmts.dll
22:07:23.0937 0408  AppMgmt - ok
22:07:23.0968 0408  asc - ok
22:07:24.0000 0408  asc3350p - ok
22:07:24.0031 0408  asc3550 - ok
22:07:24.0171 0408  [ 0E5E4957549056E2BF2C49F4F6B601AD ] aspnet_state    C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_state.exe
22:07:24.0328 0408  aspnet_state - ok
22:07:24.0421 0408  [ B153AFFAC761E7F5FCFA822B9C4E97BC ] AsyncMac        C:\WINDOWS\system32\DRIVERS\asyncmac.sys
22:07:24.0421 0408  AsyncMac - ok
22:07:24.0484 0408  [ 9F3A2F5AA6875C72BF062C712CFA2674 ] atapi           C:\WINDOWS\system32\DRIVERS\atapi.sys
22:07:24.0484 0408  atapi - ok
22:07:24.0515 0408  Atdisk - ok
22:07:24.0562 0408  [ 9916C1225104BA14794209CFA8012159 ] Atmarpc         C:\WINDOWS\system32\DRIVERS\atmarpc.sys
22:07:24.0593 0408  Atmarpc - ok
22:07:24.0671 0408  [ DEF7A7882BEC100FE0B2CE2549188F9D ] AudioSrv        C:\WINDOWS\System32\audiosrv.dll
22:07:24.0671 0408  AudioSrv - ok
22:07:24.0734 0408  [ D9F724AA26C010A217C97606B160ED68 ] audstub         C:\WINDOWS\system32\DRIVERS\audstub.sys
22:07:24.0734 0408  audstub - ok
22:07:25.0000 0408  [ 231B6AD3DB2866BC3FDB9979E6B2B61E ] AVGIDSAgent     C:\Program Files\AVG\AVG2012\AVGIDSAgent.exe
22:07:25.0156 0408  AVGIDSAgent - ok
22:07:25.0218 0408  [ EF67527CC2AD77D22AB1405C6470407E ] AVGIDSDriver    C:\WINDOWS\system32\DRIVERS\avgidsdriverx.sys
22:07:25.0234 0408  AVGIDSDriver - ok
22:07:25.0281 0408  [ 61A7E0B02F82CFF3DB2445BBE50B3589 ] AVGIDSFilter    C:\WINDOWS\system32\DRIVERS\avgidsfilterx.sys
22:07:25.0281 0408  AVGIDSFilter - ok
22:07:25.0343 0408  [ D63D83659EEDF60B3A3E620281A888E5 ] AVGIDSHX        C:\WINDOWS\system32\DRIVERS\avgidshx.sys
22:07:25.0343 0408  AVGIDSHX - ok
22:07:25.0390 0408  [ BAF975B72062F53D327788E99D64197E ] AVGIDSShim      C:\WINDOWS\system32\DRIVERS\avgidsshimx.sys
22:07:25.0390 0408  AVGIDSShim - ok
22:07:25.0437 0408  [ 6671345A6E2669AF1966BAF68EC5620F ] Avgldx86        C:\WINDOWS\system32\DRIVERS\avgldx86.sys
22:07:25.0453 0408  Avgldx86 - ok
22:07:25.0515 0408  [ CCDD61545AAEA265977E4B1EFDC74E8C ] Avgmfx86        C:\WINDOWS\system32\DRIVERS\avgmfx86.sys
22:07:25.0515 0408  Avgmfx86 - ok
22:07:25.0562 0408  [ 1FD90B28D2C3100BF4500199C8AD6358 ] Avgrkx86        C:\WINDOWS\system32\DRIVERS\avgrkx86.sys
22:07:25.0578 0408  Avgrkx86 - ok
22:07:25.0640 0408  [ 1647C720358DCC98ACF51E597C461C4D ] Avgtdix         C:\WINDOWS\system32\DRIVERS\avgtdix.sys
22:07:25.0640 0408  Avgtdix - ok
22:07:25.0703 0408  [ EA1145DEBCD508FD25BD1E95C4346929 ] avgwd           C:\Program Files\AVG\AVG2012\avgwdsvc.exe
22:07:25.0718 0408  avgwd - ok
22:07:25.0828 0408  [ 41347688046D49CDE0F6D138A534F73D ] BCMModem        C:\WINDOWS\system32\DRIVERS\BCMSM.sys
22:07:25.0875 0408  BCMModem - ok
22:07:25.0921 0408  [ DA1F27D85E0D1525F6621372E7B685E9 ] Beep            C:\WINDOWS\system32\drivers\Beep.sys
22:07:25.0921 0408  Beep - ok
22:07:26.0015 0408  [ 574738F61FCA2935F5265DC4E5691314 ] BITS            C:\WINDOWS\system32\qmgr.dll
22:07:26.0203 0408  BITS - ok
22:07:26.0265 0408  [ CFD4E51402DA9838B5A04AE680AF54A0 ] Browser         C:\WINDOWS\System32\browser.dll
22:07:26.0265 0408  Browser - ok
22:07:26.0328 0408  [ 90A673FC8E12A79AFBED2576F6A7AAF9 ] cbidf2k         C:\WINDOWS\system32\drivers\cbidf2k.sys
22:07:26.0328 0408  cbidf2k - ok
22:07:26.0406 0408  [ 359E5A91D26D0439933BEF1C29CEDEF7 ] CCALib8         C:\Program Files\Canon\CAL\CALMAIN.exe
22:07:26.0421 0408  CCALib8 - ok
22:07:26.0468 0408  [ 0BE5AEF125BE881C4F854C554F2B025C ] CCDECODE        C:\WINDOWS\system32\DRIVERS\CCDECODE.sys
22:07:26.0468 0408  CCDECODE - ok
22:07:26.0500 0408  cd20xrnt - ok
22:07:26.0562 0408  [ C1B486A7658353D33A10CC15211A873B ] Cdaudio         C:\WINDOWS\system32\drivers\Cdaudio.sys
22:07:26.0578 0408  Cdaudio - ok
22:07:26.0625 0408  [ C885B02847F5D2FD45A24E219ED93B32 ] Cdfs            C:\WINDOWS\system32\drivers\Cdfs.sys
22:07:26.0625 0408  Cdfs - ok
22:07:26.0656 0408  [ 1F4260CC5B42272D71F79E570A27A4FE ] Cdrom           C:\WINDOWS\system32\DRIVERS\cdrom.sys
22:07:26.0656 0408  Cdrom - ok
22:07:26.0687 0408  Changer - ok
22:07:26.0734 0408  [ 1CFE720EB8D93A7158A4EBC3AB178BDE ] cisvc           C:\WINDOWS\System32\cisvc.exe
22:07:26.0734 0408  cisvc - ok
22:07:26.0828 0408  [ 34CBE729F38138217F9C80212A2A0C82 ] ClipSrv         C:\WINDOWS\system32\clipsrv.exe
22:07:26.0828 0408  ClipSrv - ok
22:07:26.0906 0408  [ D87ACAED61E417BBA546CED5E7E36D9C ] clr_optimization_v2.0.50727_32 C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorsvw.exe
22:07:27.0156 0408  clr_optimization_v2.0.50727_32 - ok
22:07:27.0171 0408  CmdIde - ok
22:07:27.0203 0408  COMSysApp - ok
22:07:27.0265 0408  Cpqarray - ok
22:07:27.0343 0408  [ 3D4E199942E29207970E04315D02AD3B ] CryptSvc        C:\WINDOWS\System32\cryptsvc.dll
22:07:27.0343 0408  CryptSvc - ok
22:07:27.0437 0408  [ B459AE4AFCA570088ADDDBE55EABBC92 ] ctsfm2k         C:\WINDOWS\system32\DRIVERS\ctsfm2k.sys
22:07:27.0437 0408  ctsfm2k - ok
22:07:27.0468 0408  dac2w2k - ok
22:07:27.0500 0408  dac960nt - ok
22:07:27.0562 0408  [ 6B27A5C03DFB94B4245739065431322C ] DcomLaunch      C:\WINDOWS\system32\rpcss.dll
22:07:27.0578 0408  DcomLaunch - ok
22:07:27.0640 0408  [ 5E38D7684A49CACFB752B046357E0589 ] Dhcp            C:\WINDOWS\System32\dhcpcsvc.dll
22:07:27.0656 0408  Dhcp - ok
22:07:27.0703 0408  [ 044452051F3E02E7963599FC8F4F3E25 ] Disk            C:\WINDOWS\system32\DRIVERS\disk.sys
22:07:27.0703 0408  Disk - ok
22:07:27.0718 0408  dmadmin - ok
22:07:27.0812 0408  [ D992FE1274BDE0F84AD826ACAE022A41 ] dmboot          C:\WINDOWS\system32\drivers\dmboot.sys
22:07:27.0828 0408  dmboot - ok
22:07:27.0875 0408  [ 7C824CF7BBDE77D95C08005717A95F6F ] dmio            C:\WINDOWS\system32\drivers\dmio.sys
22:07:27.0875 0408  dmio - ok
22:07:27.0953 0408  [ E9317282A63CA4D188C0DF5E09C6AC5F ] dmload          C:\WINDOWS\system32\drivers\dmload.sys
22:07:27.0953 0408  dmload - ok
22:07:28.0000 0408  [ 57EDEC2E5F59F0335E92F35184BC8631 ] dmserver        C:\WINDOWS\System32\dmserver.dll
22:07:28.0000 0408  dmserver - ok
22:07:28.0046 0408  [ 8A208DFCF89792A484E76C40E5F50B45 ] DMusic          C:\WINDOWS\system32\drivers\DMusic.sys
22:07:28.0046 0408  DMusic - ok
22:07:28.0093 0408  [ 5F7E24FA9EAB896051FFB87F840730D2 ] Dnscache        C:\WINDOWS\System32\dnsrslvr.dll
22:07:28.0093 0408  Dnscache - ok
22:07:28.0156 0408  [ 0F0F6E687E5E15579EF4DA8DD6945814 ] Dot3svc         C:\WINDOWS\System32\dot3svc.dll
22:07:28.0171 0408  Dot3svc - ok
22:07:28.0187 0408  dpti2o - ok
22:07:28.0234 0408  [ 8F5FCFF8E8848AFAC920905FBD9D33C8 ] drmkaud         C:\WINDOWS\system32\drivers\drmkaud.sys
22:07:28.0234 0408  drmkaud - ok
22:07:28.0312 0408  [ 842C20BA5D00FA40E5A25B20FECD0F57 ] E100B           C:\WINDOWS\system32\DRIVERS\e100b325.sys
22:07:28.0328 0408  E100B - ok
22:07:28.0390 0408  [ 2187855A7703ADEF0CEF9EE4285182CC ] EapHost         C:\WINDOWS\System32\eapsvc.dll
22:07:28.0390 0408  EapHost - ok
22:07:28.0437 0408  [ EFACD8D57A42A93E244A0DBD357E8CB8 ] EAPPkt          C:\WINDOWS\system32\DRIVERS\EAPPkt.sys
22:07:28.0437 0408  EAPPkt - ok
22:07:28.0500 0408  [ BC93B4A066477954555966D77FEC9ECB ] ERSvc           C:\WINDOWS\System32\ersvc.dll
22:07:28.0500 0408  ERSvc - ok
22:07:28.0546 0408  [ 65DF52F5B8B6E9BBD183505225C37315 ] Eventlog        C:\WINDOWS\system32\services.exe
22:07:28.0578 0408  Eventlog - ok
22:07:28.0703 0408  [ D4991D98F2DB73C60D042F1AEF79EFAE ] EventSystem     C:\WINDOWS\System32\es.dll
22:07:28.0718 0408  EventSystem - ok
22:07:28.0781 0408  [ 38D332A6D56AF32635675F132548343E ] Fastfat         C:\WINDOWS\system32\drivers\Fastfat.sys
22:07:28.0781 0408  Fastfat - ok
22:07:28.0828 0408  [ 99BC0B50F511924348BE19C7C7313BBF ] FastUserSwitchingCompatibility C:\WINDOWS\System32\shsvcs.dll
22:07:28.0828 0408  FastUserSwitchingCompatibility - ok
22:07:28.0859 0408  [ 92CDD60B6730B9F50F6A1A0C1F8CDC81 ] Fdc             C:\WINDOWS\system32\DRIVERS\fdc.sys
22:07:28.0859 0408  Fdc - ok
22:07:28.0921 0408  [ B73EC688C29F81F9DA0FCF63682B3ECB ] FilterService   C:\WINDOWS\system32\DRIVERS\lvuvcflt.sys
22:07:28.0921 0408  FilterService - ok
22:07:29.0000 0408  [ D45926117EB9FA946A6AF572FBE1CAA3 ] Fips            C:\WINDOWS\system32\drivers\Fips.sys
22:07:29.0000 0408  Fips - ok
22:07:29.0031 0408  [ 9D27E7B80BFCDF1CDD9B555862D5E7F0 ] Flpydisk        C:\WINDOWS\system32\DRIVERS\flpydisk.sys
22:07:29.0031 0408  Flpydisk - ok
22:07:29.0109 0408  [ B2CF4B0786F8212CB92ED2B50C6DB6B0 ] FltMgr          C:\WINDOWS\system32\drivers\fltmgr.sys
22:07:29.0109 0408  FltMgr - ok
22:07:29.0234 0408  [ 8BA7C024070F2B7FDD98ED8A4BA41789 ] FontCache3.0.0.0 c:\WINDOWS\Microsoft.NET\Framework\v3.0\WPF\PresentationFontCache.exe
22:07:29.0250 0408  FontCache3.0.0.0 - ok
22:07:29.0281 0408  [ 3E1E2BD4F39B0E2B7DC4F4D2BCC2779A ] Fs_Rec          C:\WINDOWS\system32\drivers\Fs_Rec.sys
22:07:29.0281 0408  Fs_Rec - ok
22:07:29.0328 0408  [ 6AC26732762483366C3969C9E4D2259D ] Ftdisk          C:\WINDOWS\system32\DRIVERS\ftdisk.sys
22:07:29.0328 0408  Ftdisk - ok
22:07:29.0359 0408  [ 065639773D8B03F33577F6CDAEA21063 ] gameenum        C:\WINDOWS\system32\DRIVERS\gameenum.sys
22:07:29.0359 0408  gameenum - ok
22:07:29.0421 0408  [ 8182FF89C65E4D38B2DE4BB0FB18564E ] GEARAspiWDM     C:\WINDOWS\system32\DRIVERS\GEARAspiWDM.sys
22:07:29.0421 0408  GEARAspiWDM - ok
22:07:29.0500 0408  [ 8CA4DA1FC8C3FB098B1AADDDB111CD28 ] genmcmn         C:\WINDOWS\system32\DRIVERS\gmfiltr.sys
22:07:29.0500 0408  genmcmn - ok
22:07:29.0593 0408  [ 5CC2B1D06AC1962AF5FBBCF88D781DD8 ] GoToAssist      C:\Program Files\Citrix\GoToAssist\570\g2aservice.exe
22:07:29.0593 0408  GoToAssist - ok
22:07:29.0640 0408  [ 0A02C63C8B144BD8C86B103DEE7C86A2 ] Gpc             C:\WINDOWS\system32\DRIVERS\msgpc.sys
22:07:29.0640 0408  Gpc - ok
22:07:29.0750 0408  [ F02A533F517EB38333CB12A9E8963773 ] gupdate         C:\Program Files\Google\Update\GoogleUpdate.exe
22:07:29.0765 0408  gupdate - ok
22:07:29.0796 0408  [ F02A533F517EB38333CB12A9E8963773 ] gupdatem        C:\Program Files\Google\Update\GoogleUpdate.exe
22:07:29.0796 0408  gupdatem - ok
22:07:29.0937 0408  [ 4FCCA060DFE0C51A09DD5C3843888BCD ] helpsvc         C:\WINDOWS\PCHealth\HelpCtr\Binaries\pchsvc.dll
22:07:29.0937 0408  helpsvc - ok
22:07:29.0984 0408  HidServ - ok
22:07:30.0031 0408  [ CCF82C5EC8A7326C3066DE870C06DAF1 ] HidUsb          C:\WINDOWS\system32\DRIVERS\hidusb.sys
22:07:30.0031 0408  HidUsb - ok
22:07:30.0109 0408  [ 8878BD685E490239777BFE51320B88E9 ] hkmsvc          C:\WINDOWS\System32\kmsvc.dll
22:07:30.0109 0408  hkmsvc - ok
22:07:30.0140 0408  hpn - ok
22:07:30.0171 0408  hpt3xx - ok
22:07:30.0234 0408  [ F80A415EF82CD06FFAF0D971528EAD38 ] HTTP            C:\WINDOWS\system32\Drivers\HTTP.sys
22:07:30.0281 0408  HTTP - ok
22:07:30.0359 0408  [ 6100A808600F44D999CEBDEF8841C7A3 ] HTTPFilter      C:\WINDOWS\System32\w3ssl.dll
22:07:30.0359 0408  HTTPFilter - ok
22:07:30.0390 0408  i2omgmt - ok
22:07:30.0421 0408  i2omp - ok
22:07:30.0468 0408  [ 4A0B06AA8943C1E332520F7440C0AA30 ] i8042prt        C:\WINDOWS\system32\DRIVERS\i8042prt.sys
22:07:30.0468 0408  i8042prt - ok
22:07:30.0640 0408  [ 1CF03C69B49ACB70C722DF92755C0C8C ] IDriverT        C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
22:07:30.0640 0408  IDriverT - ok
22:07:30.0796 0408  [ C01AC32DC5C03076CFB852CB5DA5229C ] idsvc           c:\WINDOWS\Microsoft.NET\Framework\v3.0\Windows Communication Foundation\infocard.exe
22:07:30.0875 0408  idsvc - ok
22:07:30.0921 0408  [ 083A052659F5310DD8B6A6CB05EDCF8E ] Imapi           C:\WINDOWS\system32\DRIVERS\imapi.sys
22:07:30.0921 0408  Imapi - ok
22:07:30.0984 0408  [ 30DEAF54A9755BB8546168CFE8A6B5E1 ] ImapiService    C:\WINDOWS\System32\imapi.exe
22:07:30.0984 0408  ImapiService - ok
22:07:31.0031 0408  ini910u - ok
22:07:31.0093 0408  [ B5466A9250342A7AA0CD1FBA13420678 ] IntelIde        C:\WINDOWS\system32\DRIVERS\intelide.sys
22:07:31.0093 0408  IntelIde - ok
22:07:31.0140 0408  [ 8C953733D8F36EB2133F5BB58808B66B ] intelppm        C:\WINDOWS\system32\DRIVERS\intelppm.sys
22:07:31.0140 0408  intelppm - ok
22:07:31.0187 0408  [ 3BB22519A194418D5FEC05D800A19AD0 ] ip6fw           C:\WINDOWS\system32\drivers\ip6fw.sys
22:07:31.0187 0408  ip6fw - ok
22:07:31.0234 0408  [ 731F22BA402EE4B62748ADAF6363C182 ] IpFilterDriver  C:\WINDOWS\system32\DRIVERS\ipfltdrv.sys
22:07:31.0234 0408  IpFilterDriver - ok
22:07:31.0296 0408  [ B87AB476DCF76E72010632B5550955F5 ] IpInIp          C:\WINDOWS\system32\DRIVERS\ipinip.sys
22:07:31.0296 0408  IpInIp - ok
22:07:31.0359 0408  [ CC748EA12C6EFFDE940EE98098BF96BB ] IpNat           C:\WINDOWS\system32\DRIVERS\ipnat.sys
22:07:31.0359 0408  IpNat - ok
22:07:31.0421 0408  [ E6BE7A41A28D8F2DB174957454D32448 ] iPod Service    C:\Program Files\iPod\bin\iPodService.exe
22:07:31.0468 0408  iPod Service - ok
22:07:31.0531 0408  [ 23C74D75E36E7158768DD63D92789A91 ] IPSec           C:\WINDOWS\system32\DRIVERS\ipsec.sys
22:07:31.0531 0408  IPSec - ok
22:07:31.0593 0408  [ C93C9FF7B04D772627A3646D89F7BF89 ] IRENUM          C:\WINDOWS\system32\DRIVERS\irenum.sys
22:07:31.0609 0408  IRENUM - ok
22:07:31.0671 0408  [ 05A299EC56E52649B1CF2FC52D20F2D7 ] isapnp          C:\WINDOWS\system32\DRIVERS\isapnp.sys
22:07:31.0671 0408  isapnp - ok
22:07:31.0796 0408  [ 5E06A9D23727DAF96FAA796F1135FDCD ] JavaQuickStarterService C:\Program Files\Java\jre6\bin\jqs.exe
22:07:31.0812 0408  JavaQuickStarterService - ok
22:07:31.0843 0408  [ 463C1EC80CD17420A542B7F36A36F128 ] Kbdclass        C:\WINDOWS\system32\DRIVERS\kbdclass.sys
22:07:31.0843 0408  Kbdclass - ok
22:07:31.0906 0408  [ 9EF487A186DEA361AA06913A75B3FA99 ] kbdhid          C:\WINDOWS\system32\DRIVERS\kbdhid.sys
22:07:31.0906 0408  kbdhid - ok
22:07:31.0968 0408  [ 692BCF44383D056AED41B045A323D378 ] kmixer          C:\WINDOWS\system32\drivers\kmixer.sys
22:07:31.0968 0408  kmixer - ok
22:07:32.0046 0408  [ B467646C54CC746128904E1654C750C1 ] KSecDD          C:\WINDOWS\system32\drivers\KSecDD.sys
22:07:32.0046 0408  KSecDD - ok
22:07:32.0187 0408  [ 62CEF3CA80FF1E3AF738DD11E3505DB1 ] KService        C:\Program Files\Kontiki\KService.exe
22:07:32.0265 0408  KService - ok
22:07:32.0343 0408  [ 3A7C3CBE5D96B8AE96CE81F0B22FB527 ] lanmanserver    C:\WINDOWS\System32\srvsvc.dll
22:07:32.0343 0408  lanmanserver - ok
22:07:32.0406 0408  [ A8888A5327621856C0CEC4E385F69309 ] lanmanworkstation C:\WINDOWS\System32\wkssvc.dll
22:07:32.0406 0408  lanmanworkstation - ok
22:07:32.0437 0408  lbrtfdc - ok
22:07:32.0531 0408  [ A7DB739AE99A796D91580147E919CC59 ] LmHosts         C:\WINDOWS\System32\lmhsvc.dll
22:07:32.0531 0408  LmHosts - ok
22:07:32.0593 0408  [ 1A7DB7A00A4B0D8DA24CD691A4547291 ] LVPr2Mon        C:\WINDOWS\system32\DRIVERS\LVPr2Mon.sys
22:07:32.0593 0408  LVPr2Mon - ok
22:07:32.0703 0408  [ 0DDFDCAA92C7F553328DB06BA599BEA9 ] LVPrcSrv        C:\Program Files\Common Files\LogiShrd\LVMVFM\LVPrcSrv.exe
22:07:32.0703 0408  LVPrcSrv - ok
22:07:32.0968 0408  [ A240E42A7402E927A71B6E8AA4629B13 ] LVUVC           C:\WINDOWS\system32\DRIVERS\lvuvc.sys
22:07:33.0203 0408  LVUVC - ok
22:07:33.0265 0408  [ 4470E3C1E0C3378E4CAB137893C12C3A ] MBAMProtector   C:\WINDOWS\system32\drivers\mbam.sys
22:07:33.0281 0408  MBAMProtector - ok
22:07:33.0390 0408  [ 65085456FD9A74D7F1A999520C299ECB ] MBAMScheduler   C:\Program Files\Malwarebytes' Anti-Malware\mbamscheduler.exe
22:07:33.0406 0408  MBAMScheduler - ok
22:07:33.0484 0408  [ E0D7732F2D2E24B2DB3F67B6750295B8 ] MBAMService     C:\Program Files\Malwarebytes' Anti-Malware\mbamservice.exe
22:07:33.0531 0408  MBAMService - ok
22:07:33.0640 0408  [ F8B823414A22DBF3BEC10DCAA5F93CD8 ] McciCMService   C:\Program Files\Common Files\Motive\McciCMService.exe
22:07:33.0703 0408  McciCMService - ok
22:07:33.0796 0408  [ 8032C19788025BAB2B157AE0BA90B009 ] MDM             C:\Program Files\Common Files\Microsoft Shared\VS7Debug\mdm.exe
22:07:33.0812 0408  MDM - ok
22:07:33.0890 0408  [ 986B1FF5814366D71E0AC5755C88F2D3 ] Messenger       C:\WINDOWS\System32\msgsvc.dll
22:07:33.0890 0408  Messenger - ok
22:07:33.0953 0408  [ 4AE068242760A1FB6E1A44BF4E16AFA6 ] mnmdd           C:\WINDOWS\system32\drivers\mnmdd.sys
22:07:33.0953 0408  mnmdd - ok
22:07:34.0015 0408  [ D18F1F0C101D06A1C1ADF26EED16FCDD ] mnmsrvc         C:\WINDOWS\System32\mnmsrvc.exe
22:07:34.0031 0408  mnmsrvc - ok
22:07:34.0078 0408  [ DFCBAD3CEC1C5F964962AE10E0BCC8E1 ] Modem           C:\WINDOWS\system32\drivers\Modem.sys
22:07:34.0078 0408  Modem - ok
22:07:34.0156 0408  [ 1992E0D143B09653AB0F9C5E04B0FD65 ] MODEMCSA        C:\WINDOWS\system32\drivers\MODEMCSA.sys
22:07:34.0171 0408  MODEMCSA - ok
22:07:34.0218 0408  [ 35C9E97194C8CFB8430125F8DBC34D04 ] Mouclass        C:\WINDOWS\system32\DRIVERS\mouclass.sys
22:07:34.0218 0408  Mouclass - ok
22:07:34.0250 0408  [ B1C303E17FB9D46E87A98E4BA6769685 ] mouhid          C:\WINDOWS\system32\DRIVERS\mouhid.sys
22:07:34.0250 0408  mouhid - ok
22:07:34.0296 0408  [ A80B9A0BAD1B73637DBCBBA7DF72D3FD ] MountMgr        C:\WINDOWS\system32\drivers\MountMgr.sys
22:07:34.0296 0408  MountMgr - ok
22:07:34.0328 0408  mraid35x - ok
22:07:34.0406 0408  [ 9BD4DCB5412921864A7AACDEDFBD1923 ] MREMP50         C:\PROGRA~1\COMMON~1\Motive\MREMP50.SYS
22:07:34.0406 0408  MREMP50 - ok
22:07:34.0421 0408  MREMPR5 - ok
22:07:34.0453 0408  MRENDIS5 - ok
22:07:34.0500 0408  [ 07C02C892E8E1A72D6BF35004F0E9C5E ] MRESP50         C:\PROGRA~1\COMMON~1\Motive\MRESP50.SYS
22:07:34.0500 0408  MRESP50 - ok
22:07:34.0531 0408  [ 11D42BB6206F33FBB3BA0288D3EF81BD ] MRxDAV          C:\WINDOWS\system32\DRIVERS\mrxdav.sys
22:07:34.0546 0408  MRxDAV - ok
22:07:34.0625 0408  [ 7D304A5EB4344EBEEAB53A2FE3FFB9F0 ] MRxSmb          C:\WINDOWS\system32\DRIVERS\mrxsmb.sys
22:07:34.0640 0408  MRxSmb - ok
22:07:34.0703 0408  [ A137F1470499A205ABBB9AAFB3B6F2B1 ] MSDTC           C:\WINDOWS\System32\msdtc.exe
22:07:34.0703 0408  MSDTC - ok
22:07:34.0765 0408  [ C941EA2454BA8350021D774DAF0F1027 ] Msfs            C:\WINDOWS\system32\drivers\Msfs.sys
22:07:34.0765 0408  Msfs - ok
22:07:34.0843 0408  [ 877FFD0FB093B80F5ED6BA64D7921881 ] Msikbd2k        C:\WINDOWS\system32\DRIVERS\msikbd2k.sys
22:07:34.0843 0408  Msikbd2k - ok
22:07:34.0859 0408  MSIServer - ok
22:07:34.0906 0408  [ D1575E71568F4D9E14CA56B7B0453BF1 ] MSKSSRV         C:\WINDOWS\system32\drivers\MSKSSRV.sys
22:07:34.0921 0408  MSKSSRV - ok
22:07:34.0968 0408  [ 325BB26842FC7CCC1FCCE2C457317F3E ] MSPCLOCK        C:\WINDOWS\system32\drivers\MSPCLOCK.sys
22:07:34.0968 0408  MSPCLOCK - ok
22:07:35.0031 0408  [ BAD59648BA099DA4A17680B39730CB3D ] MSPQM           C:\WINDOWS\system32\drivers\MSPQM.sys
22:07:35.0046 0408  MSPQM - ok
22:07:35.0093 0408  [ AF5F4F3F14A8EA2C26DE30F7A1E17136 ] mssmbios        C:\WINDOWS\system32\DRIVERS\mssmbios.sys
22:07:35.0093 0408  mssmbios - ok
22:07:35.0140 0408  [ E53736A9E30C45FA9E7B5EAC55056D1D ] MSTEE           C:\WINDOWS\system32\drivers\MSTEE.sys
22:07:35.0140 0408  MSTEE - ok
22:07:35.0218 0408  [ DE6A75F5C270E756C5508D94B6CF68F5 ] Mup             C:\WINDOWS\system32\drivers\Mup.sys
22:07:35.0218 0408  Mup - ok
22:07:35.0265 0408  [ 5B50F1B2A2ED47D560577B221DA734DB ] NABTSFEC        C:\WINDOWS\system32\DRIVERS\NABTSFEC.sys
22:07:35.0265 0408  NABTSFEC - ok
22:07:35.0359 0408  [ 0102140028FAD045756796E1C685D695 ] napagent        C:\WINDOWS\System32\qagentrt.dll
22:07:35.0406 0408  napagent - ok
22:07:35.0468 0408  [ 1DF7F42665C94B825322FAE71721130D ] NDIS            C:\WINDOWS\system32\drivers\NDIS.sys
22:07:35.0468 0408  NDIS - ok
22:07:35.0515 0408  [ 7FF1F1FD8609C149AA432F95A8163D97 ] NdisIP          C:\WINDOWS\system32\DRIVERS\NdisIP.sys
22:07:35.0515 0408  NdisIP - ok
22:07:35.0578 0408  [ 0109C4F3850DFBAB279542515386AE22 ] NdisTapi        C:\WINDOWS\system32\DRIVERS\ndistapi.sys
22:07:35.0578 0408  NdisTapi - ok
22:07:35.0625 0408  [ F927A4434C5028758A842943EF1A3849 ] Ndisuio         C:\WINDOWS\system32\DRIVERS\ndisuio.sys
22:07:35.0625 0408  Ndisuio - ok
22:07:35.0671 0408  [ EDC1531A49C80614B2CFDA43CA8659AB ] NdisWan         C:\WINDOWS\system32\DRIVERS\ndiswan.sys
22:07:35.0671 0408  NdisWan - ok
22:07:35.0734 0408  [ 9282BD12DFB069D3889EB3FCC1000A9B ] NDProxy         C:\WINDOWS\system32\drivers\NDProxy.sys
22:07:35.0750 0408  NDProxy - ok
22:07:35.0781 0408  [ 5D81CF9A2F1A3A756B66CF684911CDF0 ] NetBIOS         C:\WINDOWS\system32\DRIVERS\netbios.sys
22:07:35.0781 0408  NetBIOS - ok
22:07:35.0843 0408  [ 74B2B2F5BEA5E9A3DC021D685551BD3D ] NetBT           C:\WINDOWS\system32\DRIVERS\netbt.sys
22:07:35.0843 0408  NetBT - ok
22:07:35.0921 0408  [ B857BA82860D7FF85AE29B095645563B ] NetDDE          C:\WINDOWS\system32\netdde.exe
22:07:35.0921 0408  NetDDE - ok
22:07:35.0953 0408  [ B857BA82860D7FF85AE29B095645563B ] NetDDEdsdm      C:\WINDOWS\system32\netdde.exe
22:07:35.0953 0408  NetDDEdsdm - ok
22:07:36.0046 0408  [ BF2466B3E18E970D8A976FB95FC1CA85 ] Netlogon        C:\WINDOWS\System32\lsass.exe
22:07:36.0046 0408  Netlogon - ok
22:07:36.0093 0408  [ 13E67B55B3ABD7BF3FE7AAE5A0F9A9DE ] Netman          C:\WINDOWS\System32\netman.dll
22:07:36.0093 0408  Netman - ok
22:07:36.0171 0408  [ D34612C5D02D026535B3095D620626AE ] NetTcpPortSharing c:\WINDOWS\Microsoft.NET\Framework\v3.0\Windows Communication Foundation\SMSvcHost.exe
22:07:36.0187 0408  NetTcpPortSharing - ok
22:07:36.0234 0408  [ 522215532916836B9CA19EE30658F3C1 ] Nhksrv          C:\WINDOWS\Nhksrv.exe
22:07:36.0625 0408  Nhksrv - ok
22:07:36.0703 0408  [ 943337D786A56729263071623BBB9DE5 ] Nla             C:\WINDOWS\System32\mswsock.dll
22:07:36.0718 0408  Nla - ok
22:07:36.0765 0408  [ CFE3462A9E94A57DCD9676F6B7FE7F67 ] nmwcd           C:\WINDOWS\system32\drivers\ccdcmb.sys
22:07:36.0781 0408  nmwcd - ok
22:07:36.0843 0408  [ 8F2A94F991F8C73CEC26B4B5620D1EDC ] nmwcdc          C:\WINDOWS\system32\drivers\ccdcmbo.sys
22:07:36.0843 0408  nmwcdc - ok
22:07:36.0921 0408  [ 3182D64AE053D6FB034F44B6DEF8034A ] Npfs            C:\WINDOWS\system32\drivers\Npfs.sys
22:07:36.0921 0408  Npfs - ok
22:07:36.0984 0408  [ 78A08DD6A8D65E697C18E1DB01C5CDCA ] Ntfs            C:\WINDOWS\system32\drivers\Ntfs.sys
22:07:37.0000 0408  Ntfs - ok
22:07:37.0046 0408  [ BF2466B3E18E970D8A976FB95FC1CA85 ] NtLmSsp         C:\WINDOWS\System32\lsass.exe
22:07:37.0046 0408  NtLmSsp - ok
22:07:37.0125 0408  [ 156F64A3345BD23C600655FB4D10BC08 ] NtmsSvc         C:\WINDOWS\system32\ntmssvc.dll
22:07:37.0171 0408  NtmsSvc - ok
22:07:37.0234 0408  [ 73C1E1F395918BC2C6DD67AF7591A3AD ] Null            C:\WINDOWS\system32\drivers\Null.sys
22:07:37.0234 0408  Null - ok
22:07:37.0359 0408  [ 71DBDC08DF86B80511E72953FA1AD6B0 ] nv              C:\WINDOWS\system32\DRIVERS\nv4_mini.sys
22:07:37.0453 0408  nv - ok
22:07:37.0515 0408  [ 5ED834603C36414B579979B3A9C90F54 ] NVSvc           C:\WINDOWS\system32\nvsvc32.exe
22:07:37.0531 0408  NVSvc - ok
22:07:37.0578 0408  [ B305F3FAD35083837EF46A0BBCE2FC57 ] NwlnkFlt        C:\WINDOWS\system32\DRIVERS\nwlnkflt.sys
22:07:37.0578 0408  NwlnkFlt - ok
22:07:37.0671 0408  [ C99B3415198D1AAB7227F2C88FD664B9 ] NwlnkFwd        C:\WINDOWS\system32\DRIVERS\nwlnkfwd.sys
22:07:37.0671 0408  NwlnkFwd - ok
22:07:37.0750 0408  [ C720C25B2D0C93DC425155F5B6A707F3 ] ossrv           C:\WINDOWS\system32\DRIVERS\ctoss2k.sys
22:07:37.0750 0408  ossrv - ok
22:07:37.0828 0408  [ F051107FF80F132882E71E3A5D302EC1 ] P16X            C:\WINDOWS\system32\drivers\P16X.sys
22:07:37.0906 0408  P16X - ok
22:07:37.0968 0408  [ 5575FAF8F97CE5E713D108C2A58D7C7C ] Parport         C:\WINDOWS\system32\DRIVERS\parport.sys
22:07:37.0968 0408  Parport - ok
22:07:38.0015 0408  [ BEB3BA25197665D82EC7065B724171C6 ] PartMgr         C:\WINDOWS\system32\drivers\PartMgr.sys
22:07:38.0015 0408  PartMgr - ok
22:07:38.0062 0408  [ 70E98B3FD8E963A6A46A2E6247E0BEA1 ] ParVdm          C:\WINDOWS\system32\drivers\ParVdm.sys
22:07:38.0062 0408  ParVdm - ok
22:07:38.0093 0408  pccsmcfd - ok
22:07:38.0140 0408  [ A219903CCF74233761D92BEF471A07B1 ] PCI             C:\WINDOWS\system32\DRIVERS\pci.sys
22:07:38.0156 0408  PCI - ok
22:07:38.0171 0408  PCIDump - ok
22:07:38.0203 0408  PCIIde - ok
22:07:38.0265 0408  [ 9E89EF60E9EE05E3F2EEF2DA7397F1C1 ] Pcmcia          C:\WINDOWS\system32\drivers\Pcmcia.sys
22:07:38.0265 0408  Pcmcia - ok
22:07:38.0296 0408  PDCOMP - ok
22:07:38.0328 0408  PDFRAME - ok
22:07:38.0359 0408  PDRELI - ok
22:07:38.0406 0408  PDRFRAME - ok
22:07:38.0421 0408  perc2 - ok
22:07:38.0453 0408  perc2hib - ok
22:07:38.0578 0408  [ C8A2D6FF660AC601B7BB9A9B16A5C25E ] PfModNT         C:\WINDOWS\System32\drivers\PfModNT.sys
22:07:38.0578 0408  PfModNT - ok
22:07:38.0625 0408  [ 65DF52F5B8B6E9BBD183505225C37315 ] PlugPlay        C:\WINDOWS\system32\services.exe
22:07:38.0625 0408  PlugPlay - ok
22:07:38.0703 0408  [ D0BE72557DE73ACABBAB536496D23115 ] Point32         C:\WINDOWS\system32\DRIVERS\point32.sys
22:07:38.0703 0408  Point32 - ok
22:07:38.0750 0408  [ BF2466B3E18E970D8A976FB95FC1CA85 ] PolicyAgent     C:\WINDOWS\System32\lsass.exe
22:07:38.0750 0408  PolicyAgent - ok
22:07:38.0812 0408  [ EFEEC01B1D3CF84F16DDD24D9D9D8F99 ] PptpMiniport    C:\WINDOWS\system32\DRIVERS\raspptp.sys
22:07:38.0812 0408  PptpMiniport - ok
22:07:38.0843 0408  [ A32BEBAF723557681BFC6BD93E98BD26 ] Processor       C:\WINDOWS\system32\DRIVERS\processr.sys
22:07:38.0843 0408  Processor - ok
22:07:38.0875 0408  [ BF2466B3E18E970D8A976FB95FC1CA85 ] ProtectedStorage C:\WINDOWS\system32\lsass.exe
22:07:38.0875 0408  ProtectedStorage - ok
22:07:38.0937 0408  [ 0E2EB30605CA6ED2509D59AF6A7362B4 ] Ps2             C:\WINDOWS\system32\DRIVERS\PS2.sys
22:07:38.0937 0408  Ps2 - ok
22:07:38.0984 0408  [ 09298EC810B07E5D582CB3A3F9255424 ] PSched          C:\WINDOWS\system32\DRIVERS\psched.sys
22:07:38.0984 0408  PSched - ok
22:07:39.0046 0408  [ 80D317BD1C3DBC5D4FE7B1678C60CADD ] Ptilink         C:\WINDOWS\system32\DRIVERS\ptilink.sys
22:07:39.0046 0408  Ptilink - ok
22:07:39.0078 0408  ql1080 - ok
22:07:39.0109 0408  Ql10wnt - ok
22:07:39.0140 0408  ql12160 - ok
22:07:39.0187 0408  ql1240 - ok
22:07:39.0203 0408  ql1280 - ok
22:07:39.0265 0408  [ FE0D99D6F31E4FAD8159F690D68DED9C ] RasAcd          C:\WINDOWS\system32\DRIVERS\rasacd.sys
22:07:39.0265 0408  RasAcd - ok
22:07:39.0328 0408  [ AD188BE7BDF94E8DF4CA0A55C00A5073 ] RasAuto         C:\WINDOWS\System32\rasauto.dll
22:07:39.0328 0408  RasAuto - ok
22:07:39.0390 0408  [ 11B4A627BC9614B885C4969BFA5FF8A6 ] Rasl2tp         C:\WINDOWS\system32\DRIVERS\rasl2tp.sys
22:07:39.0390 0408  Rasl2tp - ok
22:07:39.0468 0408  [ 76A9A3CBEADD68CC57CDA5E1D7448235 ] RasMan          C:\WINDOWS\System32\rasmans.dll
22:07:39.0484 0408  RasMan - ok
22:07:39.0531 0408  [ 5BC962F2654137C9909C3D4603587DEE ] RasPppoe        C:\WINDOWS\system32\DRIVERS\raspppoe.sys
22:07:39.0531 0408  RasPppoe - ok
22:07:39.0562 0408  [ FDBB1D60066FCFBB7452FD8F9829B242 ] Raspti          C:\WINDOWS\system32\DRIVERS\raspti.sys
22:07:39.0562 0408  Raspti - ok
22:07:39.0625 0408  [ 7AD224AD1A1437FE28D89CF22B17780A ] Rdbss           C:\WINDOWS\system32\DRIVERS\rdbss.sys
22:07:39.0625 0408  Rdbss - ok
22:07:39.0671 0408  [ 4912D5B403614CE99C28420F75353332 ] RDPCDD          C:\WINDOWS\system32\DRIVERS\RDPCDD.sys
22:07:39.0671 0408  RDPCDD - ok
22:07:39.0718 0408  [ 15CABD0F7C00C47C70124907916AF3F1 ] rdpdr           C:\WINDOWS\system32\DRIVERS\rdpdr.sys
22:07:39.0765 0408  rdpdr - ok
22:07:39.0843 0408  [ 43AF5212BD8FB5BA6EED9754358BD8F7 ] RDPWD           C:\WINDOWS\system32\drivers\RDPWD.sys
22:07:39.0859 0408  RDPWD - ok
22:07:39.0937 0408  [ 3C37BF86641BDA977C3BF8A840F3B7FA ] RDSessMgr       C:\WINDOWS\system32\sessmgr.exe
22:07:39.0953 0408  RDSessMgr - ok
22:07:40.0031 0408  [ 89525CC2DBAD44F7199B9CC188B3F9C5 ] RealNetworks Downloader Resolver Service C:\Program Files\RealNetworks\RealDownloader\rndlresolversvc.exe
22:07:40.0031 0408  RealNetworks Downloader Resolver Service - ok
22:07:40.0078 0408  [ F828DD7E1419B6653894A8F97A0094C5 ] redbook         C:\WINDOWS\system32\DRIVERS\redbook.sys
22:07:40.0078 0408  redbook - ok
22:07:40.0140 0408  [ 7E699FF5F59B5D9DE5390E3C34C67CF5 ] RemoteAccess    C:\WINDOWS\System32\mprdim.dll
22:07:40.0140 0408  RemoteAccess - ok
22:07:40.0218 0408  [ 5B19B557B0C188210A56A6B699D90B8F ] RemoteRegistry  C:\WINDOWS\system32\regsvc.dll
22:07:40.0218 0408  RemoteRegistry - ok
22:07:40.0312 0408  [ AAED593F84AFA419BBAE8572AF87CF6A ] RpcLocator      C:\WINDOWS\System32\locator.exe
22:07:40.0328 0408  RpcLocator - ok
22:07:40.0390 0408  [ 6B27A5C03DFB94B4245739065431322C ] RpcSs           C:\WINDOWS\system32\rpcss.dll
22:07:40.0390 0408  RpcSs - ok
22:07:40.0468 0408  [ 471B3F9741D762ABE75E9DEEA4787E47 ] RSVP            C:\WINDOWS\System32\rsvp.exe
22:07:40.0468 0408  RSVP - ok
22:07:40.0562 0408  [ 463B8AC0130ADF01A85DAEBF646B3DB3 ] RTLWUSB         C:\WINDOWS\system32\DRIVERS\wg111v2.sys
22:07:40.0562 0408  RTLWUSB - ok
22:07:40.0593 0408  [ BF2466B3E18E970D8A976FB95FC1CA85 ] SamSs           C:\WINDOWS\system32\lsass.exe
22:07:40.0593 0408  SamSs - ok
22:07:40.0671 0408  [ 86D007E7A654B9A71D1D7D856B104353 ] SCardSvr        C:\WINDOWS\System32\SCardSvr.exe
22:07:40.0671 0408  SCardSvr - ok
22:07:40.0765 0408  [ 0A9A7365A1CA4319AA7C1D6CD8E4EAFA ] Schedule        C:\WINDOWS\system32\schedsvc.dll
22:07:40.0781 0408  Schedule - ok
22:07:40.0859 0408  [ 90A3935D05B494A5A39D37E71F09A677 ] Secdrv          C:\WINDOWS\system32\DRIVERS\secdrv.sys
22:07:40.0859 0408  Secdrv - ok
22:07:40.0921 0408  [ CBE612E2BB6A10E3563336191EDA1250 ] seclogon        C:\WINDOWS\System32\seclogon.dll
22:07:40.0937 0408  seclogon - ok
22:07:40.0984 0408  [ 7FDD5D0684ECA8C1F68B4D99D124DCD0 ] SENS            C:\WINDOWS\system32\sens.dll
22:07:40.0984 0408  SENS - ok
22:07:41.0031 0408  [ 0F29512CCD6BEAD730039FB4BD2C85CE ] serenum         C:\WINDOWS\system32\DRIVERS\serenum.sys
22:07:41.0031 0408  serenum - ok
22:07:41.0093 0408  [ CCA207A8896D4C6A0C9CE29A4AE411A7 ] Serial          C:\WINDOWS\system32\DRIVERS\serial.sys
22:07:41.0093 0408  Serial - ok
22:07:41.0171 0408  [ 8E6B8C671615D126FDC553D1E2DE5562 ] Sfloppy         C:\WINDOWS\system32\drivers\Sfloppy.sys
22:07:41.0171 0408  Sfloppy - ok
22:07:41.0265 0408  [ 83F41D0D89645D7235C051AB1D9523AC ] SharedAccess    C:\WINDOWS\System32\ipnathlp.dll
22:07:41.0281 0408  SharedAccess - ok
22:07:41.0328 0408  [ 99BC0B50F511924348BE19C7C7313BBF ] ShellHWDetection C:\WINDOWS\System32\shsvcs.dll
22:07:41.0328 0408  ShellHWDetection - ok
22:07:41.0359 0408  Simbad - ok
22:07:41.0406 0408  [ 866D538EBE33709A5C9F5C62B73B7D14 ] SLIP            C:\WINDOWS\system32\DRIVERS\SLIP.sys
22:07:41.0406 0408  SLIP - ok
22:07:41.0468 0408  Sparrow - ok
22:07:41.0531 0408  [ AB8B92451ECB048A4D1DE7C3FFCB4A9F ] splitter        C:\WINDOWS\system32\drivers\splitter.sys
22:07:41.0531 0408  splitter - ok
22:07:41.0593 0408  [ 60784F891563FB1B767F70117FC2428F ] Spooler         C:\WINDOWS\system32\spoolsv.exe
22:07:41.0593 0408  Spooler - ok
22:07:41.0640 0408  [ 76BB022C2FB6902FD5BDD4F78FC13A5D ] sr              C:\WINDOWS\system32\DRIVERS\sr.sys
22:07:41.0640 0408  sr - ok
22:07:41.0703 0408  [ 3805DF0AC4296A34BA4BF93B346CC378 ] srservice       C:\WINDOWS\System32\srsvc.dll
22:07:41.0718 0408  srservice - ok
22:07:41.0812 0408  [ 47DDFC2F003F7F9F0592C6874962A2E7 ] Srv             C:\WINDOWS\system32\DRIVERS\srv.sys
22:07:41.0828 0408  Srv - ok
22:07:41.0890 0408  [ 0A5679B3714EDAB99E357057EE88FCA6 ] SSDPSRV         C:\WINDOWS\System32\ssdpsrv.dll
22:07:41.0890 0408  SSDPSRV - ok
22:07:41.0968 0408  [ 8BAD69CBAC032D4BBACFCE0306174C30 ] stisvc          C:\WINDOWS\system32\wiaservc.dll
22:07:42.0031 0408  stisvc - ok
22:07:42.0093 0408  [ 77813007BA6265C4B6098187E6ED79D2 ] streamip        C:\WINDOWS\system32\DRIVERS\StreamIP.sys
22:07:42.0093 0408  streamip - ok
22:07:42.0140 0408  [ 3941D127AEF12E93ADDF6FE6EE027E0F ] swenum          C:\WINDOWS\system32\DRIVERS\swenum.sys
22:07:42.0140 0408  swenum - ok
22:07:42.0187 0408  [ 8CE882BCC6CF8A62F2B2323D95CB3D01 ] swmidi          C:\WINDOWS\system32\drivers\swmidi.sys
22:07:42.0187 0408  swmidi - ok
22:07:42.0218 0408  SwPrv - ok
22:07:42.0281 0408  symc810 - ok
22:07:42.0312 0408  symc8xx - ok
22:07:42.0343 0408  sym_hi - ok
22:07:42.0359 0408  sym_u3 - ok
22:07:42.0421 0408  [ 8B83F3ED0F1688B4958F77CD6D2BF290 ] sysaudio        C:\WINDOWS\system32\drivers\sysaudio.sys
22:07:42.0421 0408  sysaudio - ok
22:07:42.0484 0408  [ C7ABBC59B43274B1109DF6B24D617051 ] SysmonLog       C:\WINDOWS\system32\smlogsvc.exe
22:07:42.0484 0408  SysmonLog - ok
22:07:42.0546 0408  [ 3CB78C17BB664637787C9A1C98F79C38 ] TapiSrv         C:\WINDOWS\System32\tapisrv.dll
22:07:42.0562 0408  TapiSrv - ok
22:07:42.0640 0408  [ 9AEFA14BD6B182D61E3119FA5F436D3D ] Tcpip           C:\WINDOWS\system32\DRIVERS\tcpip.sys
22:07:42.0671 0408  Tcpip - ok
22:07:42.0750 0408  [ 6471A66807F5E104E4885F5B67349397 ] TDPIPE          C:\WINDOWS\system32\drivers\TDPIPE.sys
22:07:42.0750 0408  TDPIPE - ok
22:07:42.0781 0408  [ C56B6D0402371CF3700EB322EF3AAF61 ] TDTCP           C:\WINDOWS\system32\drivers\TDTCP.sys
22:07:42.0781 0408  TDTCP - ok
22:07:42.0828 0408  [ 88155247177638048422893737429D9E ] TermDD          C:\WINDOWS\system32\DRIVERS\termdd.sys
22:07:42.0828 0408  TermDD - ok
22:07:42.0906 0408  [ FF3477C03BE7201C294C35F684B3479F ] TermService     C:\WINDOWS\System32\termsrv.dll
22:07:42.0953 0408  TermService - ok
22:07:43.0000 0408  [ 99BC0B50F511924348BE19C7C7313BBF ] Themes          C:\WINDOWS\System32\shsvcs.dll
22:07:43.0015 0408  Themes - ok
22:07:43.0062 0408  [ DB7205804759FF62C34E3EFD8A4CC76A ] TlntSvr         C:\WINDOWS\System32\tlntsvr.exe
22:07:43.0078 0408  TlntSvr - ok
22:07:43.0109 0408  TosIde - ok
22:07:43.0171 0408  [ 55BCA12F7F523D35CA3CB833C725F54E ] TrkWks          C:\WINDOWS\system32\trkwks.dll
22:07:43.0187 0408  TrkWks - ok
22:07:43.0265 0408  [ E266683FC95ABDEC17CD378564E1B54B ] TVICHW32        C:\WINDOWS\system32\DRIVERS\TVICHW32.SYS
22:07:43.0265 0408  TVICHW32 - ok
22:07:43.0312 0408  [ 5787B80C2E3C5E2F56C2A233D91FA2C9 ] Udfs            C:\WINDOWS\system32\drivers\Udfs.sys
22:07:43.0328 0408  Udfs - ok
22:07:43.0359 0408  ultra - ok
22:07:43.0437 0408  [ 402DDC88356B1BAC0EE3DD1580C76A31 ] Update          C:\WINDOWS\system32\DRIVERS\update.sys
22:07:43.0453 0408  Update - ok
22:07:43.0515 0408  [ 1EBAFEB9A3FBDC41B8D9C7F0F687AD91 ] upnphost        C:\WINDOWS\System32\upnphost.dll
22:07:43.0531 0408  upnphost - ok
22:07:43.0609 0408  [ EC01DA44B090D2651FC032C8B9257232 ] upperdev        C:\WINDOWS\system32\DRIVERS\usbser_lowerflt.sys
22:07:43.0609 0408  upperdev - ok
22:07:43.0671 0408  [ 05365FB38FCA1E98F7A566AAAF5D1815 ] UPS             C:\WINDOWS\System32\ups.exe
22:07:43.0671 0408  UPS - ok
22:07:43.0734 0408  [ EAFE1E00739AFE6C51487A050E772E17 ] USBAAPL         C:\WINDOWS\system32\Drivers\usbaapl.sys
22:07:43.0734 0408  USBAAPL - ok
22:07:43.0812 0408  [ E919708DB44ED8543A7C017953148330 ] usbaudio        C:\WINDOWS\system32\drivers\usbaudio.sys
22:07:43.0812 0408  usbaudio - ok
22:07:43.0875 0408  [ 173F317CE0DB8E21322E71B7E60A27E8 ] usbccgp         C:\WINDOWS\system32\DRIVERS\usbccgp.sys
22:07:43.0875 0408  usbccgp - ok
22:07:43.0937 0408  [ 65DCF09D0E37D4C6B11B5B0B76D470A7 ] usbehci         C:\WINDOWS\system32\DRIVERS\usbehci.sys
22:07:43.0937 0408  usbehci - ok
22:07:44.0000 0408  [ 1AB3CDDE553B6E064D2E754EFE20285C ] usbhub          C:\WINDOWS\system32\DRIVERS\usbhub.sys
22:07:44.0000 0408  usbhub - ok
22:07:44.0046 0408  [ A717C8721046828520C9EDF31288FC00 ] usbprint        C:\WINDOWS\system32\DRIVERS\usbprint.sys
22:07:44.0046 0408  usbprint - ok
22:07:44.0078 0408  [ A0B8CF9DEB1184FBDD20784A58FA75D4 ] usbscan         C:\WINDOWS\system32\DRIVERS\usbscan.sys
22:07:44.0078 0408  usbscan - ok
22:07:44.0140 0408  [ 1C888B000C2F9492F4B15B5B6B84873E ] usbser          C:\WINDOWS\system32\drivers\usbser.sys
22:07:44.0140 0408  usbser - ok
22:07:44.0203 0408  [ 4ABD37CFBD710E64F01F9DA8710C73F7 ] UsbserFilt      C:\WINDOWS\system32\DRIVERS\usbser_lowerfltj.sys
22:07:44.0203 0408  UsbserFilt - ok
22:07:44.0234 0408  [ A32426D9B14A089EAA1D922E0C5801A9 ] USBSTOR         C:\WINDOWS\system32\DRIVERS\USBSTOR.SYS
22:07:44.0234 0408  USBSTOR - ok
22:07:44.0281 0408  [ 26496F9DEE2D787FC3E61AD54821FFE6 ] usbuhci         C:\WINDOWS\system32\DRIVERS\usbuhci.sys
22:07:44.0281 0408  usbuhci - ok
22:07:44.0328 0408  [ 63BBFCA7F390F4C49ED4B96BFB1633E0 ] usbvideo        C:\WINDOWS\system32\Drivers\usbvideo.sys
22:07:44.0328 0408  usbvideo - ok
22:07:44.0406 0408  [ 0D3A8FAFCEACD8B7625CD549757A7DF1 ] VgaSave         C:\WINDOWS\System32\drivers\vga.sys
22:07:44.0406 0408  VgaSave - ok
22:07:44.0437 0408  ViaIde - ok
22:07:44.0468 0408  [ 4C8FCB5CC53AAB716D810740FE59D025 ] VolSnap         C:\WINDOWS\system32\drivers\VolSnap.sys
22:07:44.0468 0408  VolSnap - ok
22:07:44.0546 0408  [ 7A9DB3A67C333BF0BD42E42B8596854B ] VSS             C:\WINDOWS\System32\vssvc.exe
22:07:44.0562 0408  VSS - ok
22:07:44.0640 0408  [ 16409C468CEEE99B6B129FCAA5C0F206 ] vulfnths        C:\WINDOWS\System32\Drivers\vulfnth.sys
22:07:44.0640 0408  vulfnths - ok
22:07:44.0687 0408  [ E76FB35E30FB885124479A4A0ACA3923 ] vulfntrs        C:\WINDOWS\System32\Drivers\vulfntr.sys
22:07:44.0687 0408  vulfntrs - ok
22:07:44.0750 0408  [ 54AF4B1D5459500EF0937F6D33B1914F ] W32Time         C:\WINDOWS\System32\w32time.dll
22:07:44.0765 0408  W32Time - ok
22:07:44.0828 0408  [ E20B95BAEDB550F32DD489265C1DA1F6 ] Wanarp          C:\WINDOWS\system32\DRIVERS\wanarp.sys
22:07:44.0828 0408  Wanarp - ok
22:07:44.0890 0408  [ DC7F91B2ED24A738C807EA07F298928C ] wceusbsh        C:\WINDOWS\system32\DRIVERS\wceusbsh.sys
22:07:44.0890 0408  wceusbsh - ok
22:07:44.0984 0408  [ D918617B46457B9AC28027722E30F647 ] Wdf01000        C:\WINDOWS\system32\Drivers\wdf01000.sys
22:07:45.0000 0408  Wdf01000 - ok
22:07:45.0031 0408  WDICA - ok
22:07:45.0109 0408  [ 6768ACF64B18196494413695F0C3A00F ] wdmaud          C:\WINDOWS\system32\drivers\wdmaud.sys
22:07:45.0125 0408  wdmaud - ok
22:07:45.0171 0408  [ 77A354E28153AD2D5E120A5A8687BC06 ] WebClient       C:\WINDOWS\System32\webclnt.dll
22:07:45.0171 0408  WebClient - ok
22:07:45.0265 0408  [ 2D0E4ED081963804CCC196A0929275B5 ] winmgmt         C:\WINDOWS\system32\wbem\WMIsvc.dll
22:07:45.0281 0408  winmgmt - ok
22:07:45.0437 0408  [ C51B4A5C05A5475708E3C81C7765B71D ] WmdmPmSN        C:\WINDOWS\system32\MsPMSNSv.dll
22:07:45.0468 0408  WmdmPmSN - ok
22:07:45.0562 0408  [ E76F8807070ED04E7408A86D6D3A6137 ] Wmi             C:\WINDOWS\System32\advapi32.dll
22:07:45.0593 0408  Wmi - ok
22:07:45.0687 0408  [ E0673F1106E62A68D2257E376079F821 ] WmiApSrv        C:\WINDOWS\System32\wbem\wmiapsrv.exe
22:07:45.0703 0408  WmiApSrv - ok
22:07:45.0828 0408  [ F74E3D9A7FA9556C3BBB14D4E5E63D3B ] WMPNetworkSvc   C:\Program Files\Windows Media Player\WMPNetwk.exe
22:07:45.0859 0408  WMPNetworkSvc - ok
22:07:45.0937 0408  [ CF4DEF1BF66F06964DC0D91844239104 ] WpdUsb          C:\WINDOWS\system32\Drivers\wpdusb.sys
22:07:45.0937 0408  WpdUsb - ok
22:07:46.0000 0408  [ 6ABE6E225ADB5A751622A9CC3BC19CE8 ] WS2IFSL         C:\WINDOWS\System32\drivers\ws2ifsl.sys
22:07:46.0000 0408  WS2IFSL - ok
22:07:46.0078 0408  [ 7C278E6408D1DCE642230C0585A854D5 ] wscsvc          C:\WINDOWS\system32\wscsvc.dll
22:07:46.0093 0408  wscsvc - ok
22:07:46.0156 0408  [ C98B39829C2BBD34E454150633C62C78 ] WSTCODEC        C:\WINDOWS\system32\DRIVERS\WSTCODEC.SYS
22:07:46.0156 0408  WSTCODEC - ok
22:07:46.0234 0408  [ EAA6324F51214D2F6718977EC9CE0DEF ] WudfPf          C:\WINDOWS\system32\DRIVERS\WudfPf.sys
22:07:46.0234 0408  WudfPf - ok
22:07:46.0281 0408  [ F91FF1E51FCA30B3C3981DB7D5924252 ] WudfRd          C:\WINDOWS\system32\DRIVERS\wudfrd.sys
22:07:46.0281 0408  WudfRd - ok
22:07:46.0343 0408  [ DDEE3682FE97037C45F4D7AB467CB8B6 ] WudfSvc         C:\WINDOWS\System32\WUDFSvc.dll
22:07:46.0343 0408  WudfSvc - ok
22:07:46.0437 0408  [ 81DC3F549F44B1C1FFF022DEC9ECF30B ] WZCSVC          C:\WINDOWS\System32\wzcsvc.dll
22:07:46.0468 0408  WZCSVC - ok
22:07:46.0515 0408  [ 295D21F14C335B53CB8154E5B1F892B9 ] xmlprov         C:\WINDOWS\System32\xmlprov.dll
22:07:46.0515 0408  xmlprov - ok
22:07:46.0593 0408  ================ Scan global ===============================
22:07:46.0609 0408  [ 42F1F4C0AFB08410E5F02D4B13EBB623 ] C:\WINDOWS\system32\basesrv.dll
22:07:46.0671 0408  [ 69AE2B2E6968C316536E5B10B9702E63 ] C:\WINDOWS\system32\winsrv.dll
22:07:46.0718 0408  [ 69AE2B2E6968C316536E5B10B9702E63 ] C:\WINDOWS\system32\winsrv.dll
22:07:46.0750 0408  [ 65DF52F5B8B6E9BBD183505225C37315 ] C:\WINDOWS\system32\services.exe
22:07:46.0750 0408  [Global] - ok
22:07:46.0765 0408  ================ Scan MBR ==================================
22:07:46.0796 0408  [ 8F558EB6672622401DA993E1E865C861 ] \Device\Harddisk0\DR0
22:07:47.0015 0408  \Device\Harddisk0\DR0 - ok
22:07:47.0062 0408  [ 739B36F7A373FC81121D831231B6D311 ] \Device\Harddisk1\DR2
22:07:47.0593 0408  \Device\Harddisk1\DR2 - ok
22:07:47.0593 0408  ================ Scan VBR ==================================
22:07:47.0609 0408  [ 1086596E8A679CF460806CED6B8F6DEA ] \Device\Harddisk0\DR0\Partition1
22:07:47.0609 0408  \Device\Harddisk0\DR0\Partition1 - ok
22:07:47.0625 0408  [ FBE638CB666E8ABB5DEA7F454977D62D ] \Device\Harddisk1\DR2\Partition1
22:07:47.0640 0408  \Device\Harddisk1\DR2\Partition1 - ok
22:07:47.0640 0408  ============================================================
22:07:47.0640 0408  Scan finished
22:07:47.0671 0432  Detected object count: 0
22:07:47.0671 0432  Actual detected object count: 0
22:08:05.0750 0392  Deinitialize success
Its actually good that TDSSKiller didn't find anything, Peter.  You can delete it from the computer.  Unfortunately, 139d2e78.exe is a trojan downloader.  Although original variants are old, in researching it, I see that there are new variants, which is likely what has infected your account.
Please follow the instructions at here for running Windows Defender Offline.  You will need a writable CD or DVD or a USB stick so you can "write" (save) Windows Defender Offline to it and boot your computer from that media to scan.  Note that it will be a "boot scan", which means you will start the computer with the CD/DVD or USB in the computer.
In the event that does not allow you to provide the logs, since you use AVG as your antivirus solution, please follow the instructions for running the AVG Rescue CD.
PeterJ
OK. I've tried booting Windows Defender from a USB stick but with no success. I'm only given 4 options to boot from:  Normal, Diskette Drive, Harddisk Drive C , and IDE CD-ROM Device.  And yes, I did make sure I'd downloaded the 32 bit version.
I then tried to do it from a CD. Tried many times on different CD's  but the best I ver got was a screen with a blue 'windows' graphic on t, followed by the message  "Your computer needs to restart. Hold down the power button. Ref 0x0000005D "
I then tried creating an AVG Rescue CD, but can't get that to boot either . Again I tried it several times on different CD's (burned using Nero). I don't even get the blue windows graphic with this one.  I've wasted a whole morning it seems  :(
BTW I have discovered that my wife's account does have admin rights.
I also tried re-installing DDS but I'm still not getting logs with readable text - which I notice is being created in 'AuotCAD Script'.
Pete
Ok, since your wife's account has admin rights, that gives us a different avenue.
Download ComboFix from here.
Now, please run ComboFix:
PeterJ
I've run CombiFix - log below.
I had to do it twice as the first time it was interrupted near the end by a message from AVG and it didn't produce a log file .
The AVG message said it had detected a threat ('REGT.EXE') and I was asked to quarantine it (or ignore it, which I didn't want to do).  I think this is probably because I had disabled AVG for 15 mins so I think it may have restarted at this point, before CombiFix had finished. Combifex then sent a message to say 'REGT is not recognised', or something like that.
So I disabled AVG again and re-ran CombiFix.  Log follows.
ComboFix 13-06-20.01 - All of Us 20/06/2013  16:03:38.2.1 - x86
Microsoft Windows XP Professional  5.1.2600.3.1252.44.1033.18.1023.674 [GMT 1:00]
Running from: c:\documents and settings\All of Us\Desktop\ComboFix.exe
AV: AVG Anti-Virus Free Edition 2012 *Disabled/Updated* {17DDD097-36FF-435F-9E1B-52D74245D6BF}
---- Previous Run -------
c:\documents and settings\All of Us\Application Data\alot\Button_0\Button_0.xml
c:\documents and settings\All of Us\Application Data\alot\Button_0\Button_0.xml.backup
c:\documents and settings\All of Us\Application Data\alot\Button_1\Button_1.xml
c:\documents and settings\All of Us\Application Data\alot\Button_1\Button_1.xml.backup
c:\documents and settings\All of Us\Application Data\alot\Button_2\Button_2.xml
c:\documents and settings\All of Us\Application Data\alot\Button_2\Button_2.xml.backup
c:\documents and settings\All of Us\Application Data\alot\Button_3\Button_3.xml
c:\documents and settings\All of Us\Application Data\alot\Button_3\Button_3.xml.backup
c:\documents and settings\All of Us\Application Data\alot\Button_4\Button_4.xml
c:\documents and settings\All of Us\Application Data\alot\Button_4\Button_4.xml.backup
c:\documents and settings\All of Us\Application Data\alot\Button_5\Button_5.xml
c:\documents and settings\All of Us\Application Data\alot\Button_5\Button_5.xml.backup
c:\documents and settings\All of Us\Application Data\alot\Button_6\Button_6.xml
c:\documents and settings\All of Us\Application Data\alot\Button_6\Button_6.xml.backup
c:\documents and settings\All of Us\Application Data\alot\Button_7\Button_7.xml
c:\documents and settings\All of Us\Application Data\alot\Button_7\Button_7.xml.backup
c:\documents and settings\All of Us\Application Data\alot\configurator\configurator.xml
c:\documents and settings\All of Us\Application Data\alot\configurator\configurator.xml.backup
c:\documents and settings\All of Us\Application Data\alot\contextMenu\contextMenu.xml
c:\documents and settings\All of Us\Application Data\alot\contextMenu\contextMenu.xml.backup
c:\documents and settings\All of Us\Application Data\alot\products\products.xml
c:\documents and settings\All of Us\Application Data\alot\products\products.xml.backup
c:\documents and settings\All of Us\Application Data\alot\Resources\BrowserSearch\alot_search_defend.html
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_0\images\alot_logo_button.bmp
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_0\images\alot_logo_button.png
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_1\images\alot_search_button.bmp
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_1\images\alot_search_button.png
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_2\images\default_1008_alot_map_widget_default.bmp
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_2\images\default_1008_alot_map_widget_default.png
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_3\images\default_1182_alot_map_guides.bmp
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_3\images\default_1182_alot_map_guides.png
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_4\images\clear.png
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_4\images\cloudy.png
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_4\images\default_1007_alot_weather_widget.bmp
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_4\images\default_1007_alot_weather_widget.png
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_4\images\mcloud.png
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_4\images\nclear.png
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_4\images\nmcloud.png
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_4\images\pcloud.png
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_4\images\rain.png
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_4\images\shower.png
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_5\images\default_1272_alot_map_travel.bmp
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_5\images\default_1272_alot_map_travel.png
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_6\images\default_1273_alot_map_guides.bmp
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_6\images\default_1273_alot_map_guides.png
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_7\images\default_1596_alot_mrkt_typewriter.bmp
c:\documents and settings\All of Us\Application Data\alot\Resources\Button_7\images\default_1596_alot_mrkt_typewriter.png
c:\documents and settings\All of Us\Application Data\alot\Resources\contextMenu\images\alot_logo_button.bmp
c:\documents and settings\All of Us\Application Data\alot\Resources\contextMenu\images\alot_logo_button.png
c:\documents and settings\All of Us\Application Data\alot\Resources\Shared\domains.dat
c:\documents and settings\All of Us\Application Data\alot\Resources\Shared\images\alot_brand.png
c:\documents and settings\All of Us\Application Data\alot\Resources\Shared\images\alot_splitter.png
c:\documents and settings\All of Us\Application Data\alot\Resources\Shared\images\spinner.bmp
c:\documents and settings\All of Us\Application Data\alot\Resources\Shared\images\widget_bottom.bmp
c:\documents and settings\All of Us\Application Data\alot\Resources\Shared\images\widget_btnclose0.bmp
c:\documents and settings\All of Us\Application Data\alot\Resources\Shared\images\widget_btnclose1.bmp
c:\documents and settings\All of Us\Application Data\alot\Resources\Shared\images\widget_caption.bmp
c:\documents and settings\All of Us\Application Data\alot\Resources\Shared\images\widget_error_bg.bmp
c:\documents and settings\All of Us\Application Data\alot\Resources\Shared\images\widget_error_close.bmp
c:\documents and settings\All of Us\Application Data\alot\Resources\Shared\images\widget_error_icon.bmp
c:\documents and settings\All of Us\Application Data\alot\TimerManager\TimerManager.xml
c:\documents and settings\All of Us\Application Data\alot\TimerManager\TimerManager.xml.backup
c:\documents and settings\All of Us\Application Data\alot\toolbar.xml
c:\documents and settings\All of Us\Application Data\alot\toolbar.xml.backup
c:\documents and settings\All of Us\Application Data\alot\ToolbarSearch\ToolbarSearch.xml
c:\documents and settings\All of Us\Application Data\alot\Updater\Updater.xml
c:\documents and settings\All of Us\Application Data\alot\Updater\Updater.xml.backup
c:\documents and settings\All of Us\GoToAssistDownloadHelper.exe
c:\documents and settings\All of Us\System\win_qs8.jqx
c:\windows\system32\c.bat
F:\Setup.exe
(((((((((((((((((((((((((((((((((((((((   Drivers/Services   )))))))))))))))))))))))))))))))))))))))))))))))))
-------\Service_npf
(((((((((((((((((((((((((   Files Created from 2013-05-20 to 2013-06-20  )))))))))))))))))))))))))))))))
2013-06-20 14:49 . 2008-04-14 00:11   21504   -c--a-w-   c:\windows\system32\dllcache\hidserv.dll
2013-06-20 10:27 . 2008-05-02 13:25   465920   -c----w-   c:\windows\system32\dllcache\imapi2fs.dll
2013-06-20 10:27 . 2008-05-02 13:25   465920   ------w-   c:\windows\system32\imapi2fs.dll
2013-06-20 10:27 . 2008-05-02 13:25   317952   -c----w-   c:\windows\system32\dllcache\imapi2.dll
2013-06-20 10:27 . 2008-05-02 13:25   317952   ------w-   c:\windows\system32\imapi2.dll
2013-06-19 09:53 . 2013-06-19 09:53   --------   dc----w-   C:\Configuration
2013-06-18 07:46 . 2013-06-18 07:46   --------   d-----w-   c:\program files\Uniblue
2013-06-18 07:33 . 2013-06-18 07:33   --------   d-----w-   c:\windows\system32\wbem\Repository
2013-06-18 06:20 . 2013-06-18 06:20   --------   d-----w-   c:\documents and settings\All of Us\Local Settings\Application Data\Citrix
2013-05-29 20:22 . 2013-05-29 20:22   --------   d-----w-   c:\documents and settings\All of Us\SyncFolder
2013-05-29 19:59 . 2013-06-19 09:21   --------   d-----w-   c:\program files\MyPC Backup
2013-05-29 19:59 . 2013-06-18 20:48   5404880   ----a-w-   c:\documents and settings\All Users\Application Data\pclunst.exe
2013-05-29 19:59 . 2013-06-19 07:33   --------   d-----w-   c:\documents and settings\All Users\Application Data\PC1Data
2013-05-29 13:42 . 2013-05-29 19:14   --------   d-----w-   c:\program files\Webroot
2013-05-25 08:52 . 2013-05-25 08:52   --------   d-----w-   c:\program files\Malwarebytes' Anti-Malware
2013-05-25 08:52 . 2013-04-04 13:50   22856   ----a-w-   c:\windows\system32\drivers\mbam.sys
2013-05-15 09:02 . 2012-12-13 15:58   692104   -c--a-w-   c:\windows\system32\FlashPlayerApp.exe
2013-05-15 09:02 . 2011-06-04 07:33   71048   -c--a-w-   c:\windows\system32\FlashPlayerCPLApp.cpl
2013-04-16 22:17 . 2004-01-08 15:23   920064   ----a-w-   c:\windows\system32\wininet.dll
2013-04-16 22:17 . 2001-08-23 12:00   43520   ------w-   c:\windows\system32\licmgr10.dll
2013-04-16 22:17 . 2001-08-23 12:00   1469440   ------w-   c:\windows\system32\inetcpl.cpl
2013-04-12 23:28 . 2004-08-04 05:59   385024   ------w-   c:\windows\system32\html.iec
2013-04-11 02:18 . 2010-09-07 02:49   302368   -c--a-w-   c:\windows\system32\drivers\avgtdix.sys
2013-04-10 01:31 . 2001-08-23 12:00   1876352   ----a-w-   c:\windows\system32\win32k.sys
2013-04-02 07:58 . 2003-03-18 22:14   499712   -c--a-w-   c:\windows\system32\msvcp71.dll
2013-04-02 07:58 . 2003-02-21 04:42   348160   -c--a-w-   c:\windows\system32\msvcr71.dll
2007-12-24 08:03 . 2007-12-24 08:03   2293848   -c--a-w-   c:\program files\FLV PlayerFCSetup.exe
2007-10-13 22:44 . 2007-10-13 22:44   55088   -c--a-w-   c:\program files\MFInstall.exe
2007-02-13 07:01 . 2007-02-13 07:01   5727280   -c--a-w-   c:\program files\Firefox Setup 2.0.0.1.exe
2006-06-26 19:36 . 2006-06-26 19:36   3963304   -c--a-w-   c:\program files\MSASYNC.EXE
2005-10-15 07:38 . 2005-10-15 07:38   9624128   -c--a-w-   c:\program files\NapsterSetup-GB-3.1.1.8.exe
2005-06-26 22:22 . 2005-06-26 22:22   761344   -c--a-w-   c:\program files\ESS4CLEAR.exe
2005-01-21 00:53 . 2005-12-25 13:17   45056   -c----r-   c:\program files\SetAttrib.exe
REGEDIT4
"Spotify Web Helper"="c:\documents and settings\All of Us\Application Data\Spotify\Data\SpotifyWebHelper.exe" [2012-05-19 932528]
"IntelliPoint"="c:\program files\Microsoft IntelliPoint\ipoint.exe" [2005-12-04 461584]
"AVG_TRAY"="c:\program files\AVG\AVG2012\avgtray.exe" [2012-11-19 2598520]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2011-07-05 421888]
"RunNarrator"="Narrator.exe" [2008-04-14 53760]
WG111v2 Smart Wizard Wireless Setting.lnk - c:\program files\NETGEAR\WG111v2 Configuration Utility\RtlWake.exe [2007-2-10 745472]
"HideShutdownScripts"= 0 (0x0)
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\GoToAssist]
2010-10-07 22:05   16680   ----a-w-   c:\program files\Citrix\GoToAssist\570\g2awinlogon.dll
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\session manager]
BootExecute   REG_MULTI_SZ      autocheck autochk *\0c:\progra~1\AVG\AVG2012\avgrsx.exe /sync /restart
@="Driver"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\WudfSvc]
@="Service"
"EnableFirewall"= 0 (0x0)
"c:\\Program Files\\SmartFTP\\SmartFTP.exe"=
"c:\\Program Files\\Real\\RealPlayer\\realplay.exe"=
"c:\\Program Files\\Kontiki\\KService.exe"=
"c:\\WINDOWS\\system32\\muzapp.exe"=
"c:\\Documents and Settings\\All of Us\\Application Data\\Spotify\\spotify.exe"=
"c:\\Program Files\\AVG\\AVG2012\\avgmfapx.exe"=
"c:\\Program Files\\BearShare Applications\\BearShare\\BearShare.exe"=
"c:\\Program Files\\BearShare Applications\\MediaBar\\Datamngr\\ToolBar\\dtUser.exe"=
"c:\\Program Files\\iMesh Applications\\MediaBar\\Datamngr\\ToolBar\\dtUser.exe"=
"c:\\Program Files\\Common Files\\Apple\\Apple Application Support\\WebKit2WebProcess.exe"=
"c:\\Program Files\\Windows Live\\Messenger\\msnmsgr.exe"=
"c:\\Program Files\\AVG\\AVG2012\\avgnsx.exe"=
"c:\\Program Files\\AVG\\AVG2012\\avgdiagex.exe"=
R0 AVGIDSHX;AVGIDSHX;c:\windows\system32\drivers\avgidshx.sys [19/04/2012 04:50 24896]
R0 Avgrkx86;AVG Anti-Rootkit Driver;c:\windows\system32\drivers\avgrkx86.sys [07/09/2010 03:48 31952]
R1 Avgldx86;AVG AVI Loader Driver;c:\windows\system32\drivers\avgldx86.sys [07/09/2010 03:48 250080]
R1 Avgtdix;AVG TDI Driver;c:\windows\system32\drivers\avgtdix.sys [07/09/2010 03:49 302368]
R2 AVGIDSAgent;AVGIDSAgent;c:\program files\AVG\AVG2012\avgidsagent.exe [02/11/2012 04:51 5174392]
R2 avgwd;AVG WatchDog;c:\program files\AVG\AVG2012\avgwdsvc.exe [14/02/2012 04:53 193288]
R2 EAPPkt;Realtek EAPPkt Protocol;c:\windows\system32\drivers\EAPPkt.sys [10/02/2007 14:18 66048]
R2 Nhksrv;Netropa NHK Server;c:\windows\Nhksrv.exe [24/02/2005 10:43 28672]
R3 AVGIDSDriver;AVGIDSDriver;c:\windows\system32\drivers\avgidsdriverx.sys [23/12/2011 13:32 142176]
R3 AVGIDSFilter;AVGIDSFilter;c:\windows\system32\drivers\avgidsfilterx.sys [23/12/2011 13:32 24144]
R3 AVGIDSShim;AVGIDSShim;c:\windows\system32\drivers\avgidsshimx.sys [23/12/2011 13:32 17232]
R3 Msikbd2k;DellTouch;c:\windows\system32\drivers\Msikbd2k.sys [24/02/2005 10:43 6942]
S3 MBAMProtector;MBAMProtector;c:\windows\system32\drivers\mbam.sys [25/05/2013 09:52 22856]
S3 RTLWUSB;NETGEAR WG111v2 54Mbps Wireless USB 2.0 Adapter NT Driver;c:\windows\system32\drivers\wg111v2.sys [10/02/2007 14:18 167808]
S4 MBAMScheduler;MBAMScheduler;c:\program files\Malwarebytes' Anti-Malware\mbamscheduler.exe [25/05/2013 09:52 418376]
S4 MBAMService;MBAMService;c:\program files\Malwarebytes' Anti-Malware\mbamservice.exe [25/05/2013 09:52 701512]
S4 RealNetworks Downloader Resolver Service;RealNetworks Downloader Resolver Service;c:\program files\RealNetworks\RealDownloader\rndlresolversvc.exe [06/03/2013 02:21 39056]
*NewlyCreated* - WUAUSERV
uStart Page = hxxp://login.live.com/login.srf?id=2&vv=700&lc=1033
uSearchMigratedDefaultURL = hxxp://www.google.com/search?q={searchTerms}&sourceid=ie7&rls=com.microsoft:en-US&ie=utf8&oe=utf8
uInternet Connection Wizard,ShellNext = iexplore
uSearchAssistant = hxxp://www.google.com/ie
uSearchURL,(Default) = hxxp://www.google.com/search?q=%s
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~2\Office10\EXCEL.EXE/3000
Trusted Zone: bbc.co.uk\www
Trusted Zone: hotmail.com\www
Trusted Zone: tiscali.co.uk\www
TCP: DhcpNameServer = 192.168.0.1
------- File Associations -------
.scr=AutoCADScriptFile
Toolbar-10 - (no file)
ShellIconOverlayIdentifiers-{FB314ED9-A251-47B7-93E1-CDD82E34AF8B} - (no file)
ShellIconOverlayIdentifiers-{FB314EDA-A251-47B7-93E1-CDD82E34AF8B} - (no file)
ShellIconOverlayIdentifiers-{FB314EDB-A251-47B7-93E1-CDD82E34AF8B} - (no file)
ShellIconOverlayIdentifiers-{FB314EDC-A251-47B7-93E1-CDD82E34AF8B} - (no file)
HKU-Default-Run-NTSF MICROSOFT SYSTEM - fylez.exe
SafeBoot-WudfPf
SafeBoot-WudfRd
Rootkit scan 2013-06-20 16:13
scanning hidden processes ...
scanning hidden files ...
scan completed successfully
hidden files: 0
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}]
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil32_11_7_700_202_ActiveX.exe,-101"
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\Elevation]
"Enabled"=dword:00000001
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\LocalServer32]
@="c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil32_11_7_700_202_ActiveX.exe"
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\TypeLib]
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}]
@="IFlashBroker5"
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}\ProxyStubClsid32]
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}\TypeLib]
"Version"="1.0"
- - - - - - - > 'winlogon.exe'(908)
c:\program files\Citrix\GoToAssist\570\G2AWinLogon.dll
- - - - - - - > 'explorer.exe'(2884)
c:\windows\system32\msi.dll
Completion time: 2013-06-20  16:17:16
ComboFix-quarantined-files.txt  2013-06-20 15:17
Pre-Run: 8,145,833,984 bytes free
Post-Run: 8,117,256,192 bytes free
- - End Of File - - 46F4E9DD3EAD14ACB4B93CB47D3F2411
Is there any change to your user account?
That log does not show any signs of the 139d2378.exe file.  However, seeing the file association for .scr set to AutoCADScriptFile is a likely explanation as to why you had problems with DDS.scr.  Please try the alternate version from here as the additional information will be helpful.
PeterJ
Here's dds.txt.  Do you want Attach as well?
DDS (Ver_2012-11-20.01) - NTFS_x86
Internet Explorer: 8.0.6001.18702  BrowserJavaVersion: 1.6.0_24
Run by All of Us at 19:53:29 on 2013-06-20
Microsoft Windows XP Professional  5.1.2600.3.1252.44.1033.18.1023.490 [GMT 1:00]
============== Running Processes ================
C:\WINDOWS\System32\alg.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Microsoft IntelliPoint\ipoint.exe
C:\Program Files\AVG\AVG2012\avgtray.exe
C:\Documents and Settings\All of Us\Application Data\Spotify\Data\SpotifyWebHelper.exe
C:\Program Files\NETGEAR\WG111v2 Configuration Utility\RtlWake.exe
C:\Program Files\RealNetworks\RealDownloader\recordingmanager.exe
C:\WINDOWS\system32\wbem\wmiprvse.exe
C:\WINDOWS\system32\svchost.exe -k DcomLaunch
C:\WINDOWS\system32\svchost.exe -k rpcss
C:\WINDOWS\system32\svchost.exe -k WudfServiceGroup
C:\WINDOWS\System32\svchost.exe -k NetworkService
BHO: Adobe PDF Reader Link Helper: {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - c:\program files\common files\adobe\acrobat\activex\AcroIEHelper.dll
BHO: RealNetworks Download and Record Plugin for Internet Explorer: {3049C3E9-B461-4BC5-8870-4C09146192CA} - c:\documents and settings\all users\application data\realnetworks\realdownloader\browserplugins\ie\rndlbrowserrecordplugin.dll
BHO: AVG Do Not Track: {31332EEF-CB9F-458F-AFEB-D30E9A66B6BA} - c:\program files\avg\avg2012\avgdtiex.dll
BHO: AVG Safe Search: {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - c:\program files\avg\avg2012\avgssie.dll
BHO: EWPBrowseObject Class: {68F9551E-0411-48E4-9AAF-4BC42A6A46BE} - c:\program files\canon\easy-webprint\EWPBrowseLoader.dll
BHO: SSVHelper Class: {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - c:\program files\java\jre6\bin\ssv.dll
BHO: Windows Live Sign-in Helper: {9030D464-4C02-4ABF-8ECC-5164760863C6} - c:\program files\common files\microsoft shared\windows live\WindowsLiveLogin.dll
BHO: Java(tm) Plug-In 2 SSV Helper: {DBC80044-A445-435b-BC74-9C25C1C588A9} - c:\program files\java\jre6\bin\jp2ssv.dll
BHO: JQSIEStartDetectorImpl Class: {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - c:\program files\java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
TB: Easy-WebPrint: {327C2873-E90D-4c37-AA9D-10AC9BABA46C} - c:\program files\canon\easy-webprint\Toolband.dll
EB: {32683183-48a0-441b-a342-7c2a440a9478} - <orphaned>
uRun: [Spotify Web Helper] "c:\documents and settings\all of us\application data\spotify\data\SpotifyWebHelper.exe"
mRun: [IntelliPoint] "c:\program files\microsoft intellipoint\ipoint.exe"
mRun: [AVG_TRAY] "c:\program files\avg\avg2012\avgtray.exe"
mRun: [QuickTime Task] "c:\program files\quicktime\qttask.exe" -atboottime
dRunOnce: [RunNarrator] Narrator.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\wg111v~1.lnk - c:\program files\netgear\wg111v2 configuration utility\RtlWake.exe
uPolicies-Explorer: NoDriveAutoRun = dword:67108863
uPolicies-Explorer: NoDriveTypeAutoRun = dword:323
uPolicies-Explorer: NoDrives = dword:0
mPolicies-Explorer: NoDrives = dword:0
mPolicies-Explorer: NoDriveAutoRun = dword:67108863
mPolicies-Explorer: NoDriveTypeAutoRun = dword:323
mPolicies-System: HideShutdownScripts = dword:0
mPolicies-Windows\System: Allow-LogonScript-NetbiosDisabled = dword:1
IE: E&xport to Microsoft Excel - c:\progra~1\micros~2\office10\EXCEL.EXE/3000
IE: {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - {CAFEEFAC-0016-0000-0024-ABCDEFFEDCBC} - c:\program files\java\jre6\bin\jp2iexp.dll
IE: {68BCFFE1-A2DA-4B40-9068-87ECBFC19D16} - {68BCFFE1-A2DA-4B40-9068-87ECBFC19D16} - c:\program files\avg\avg2012\avgdtiex.dll
DPF: {17492023-C23A-453E-A040-C7C580BBF700} - hxxp://download.microsoft.com/download/E/5/6/E5611B10-0D6D-4117-8430-A67417AA88CD/LegitCheckControl.cab
DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_24-windows-i586.cab
DPF: {8FFBE65D-2C9C-4669-84BD-5829DC0B603C} - hxxp://fpdownload.macromedia.com/get/flashplayer/current/polarbear/ultrashim.cab
DPF: {CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_24-windows-i586.cab
DPF: {F27237D7-93C8-44C2-AC6E-D6057B9A918F} - hxxps://juniper.net/dana-cached/sc/JuniperSetupClient.cab
TCP: NameServer = 192.168.0.1
TCP: Interfaces\{942D3D83-9953-4E89-B7F4-CD01E1AD0915} : DHCPNameServer = 192.168.0.1
Handler: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - c:\program files\avg\avg2012\avgpp.dll
Notify: GoToAssist - c:\program files\citrix\gotoassist\570\G2AWinLogon.dll
SEH: ShellHook Class - {88485281-8b4b-4f8d-9ede-82e29a064277} - c:\program files\markany\contentsafer\MACSMANAGER.dll
R0 AVGIDSHX;AVGIDSHX;c:\windows\system32\drivers\avgidshx.sys [2012-4-19 24896]
R0 Avgrkx86;AVG Anti-Rootkit Driver;c:\windows\system32\drivers\avgrkx86.sys [2010-9-7 31952]
R1 Avgldx86;AVG AVI Loader Driver;c:\windows\system32\drivers\avgldx86.sys [2010-9-7 250080]
R1 Avgmfx86;AVG Mini-Filter Resident Anti-Virus Shield;c:\windows\system32\drivers\avgmfx86.sys [2010-9-7 41040]
R1 Avgtdix;AVG TDI Driver;c:\windows\system32\drivers\avgtdix.sys [2010-9-7 302368]
R2 avgwd;AVG WatchDog;c:\program files\avg\avg2012\avgwdsvc.exe [2012-2-14 193288]
R2 EAPPkt;Realtek EAPPkt Protocol;c:\windows\system32\drivers\EAPPkt.sys [2007-2-10 66048]
R2 Nhksrv;Netropa NHK Server;c:\windows\Nhksrv.exe [2005-2-24 28672]
R3 AVGIDSDriver;AVGIDSDriver;c:\windows\system32\drivers\avgidsdriverx.sys [2011-12-23 142176]
R3 AVGIDSFilter;AVGIDSFilter;c:\windows\system32\drivers\avgidsfilterx.sys [2011-12-23 24144]
R3 AVGIDSShim;AVGIDSShim;c:\windows\system32\drivers\avgidsshimx.sys [2011-12-23 17232]
R3 Msikbd2k;DellTouch;c:\windows\system32\drivers\Msikbd2k.sys [2005-2-24 6942]
S2 AVGIDSAgent;AVGIDSAgent;c:\program files\avg\avg2012\avgidsagent.exe [2012-11-2 5174392]
S3 Ad-Watch Connect Filter;Ad-Watch Connect Kernel Filter;
  • S3 MBAMProtector;MBAMProtector;c:\windows\system32\drivers\mbam.sys [2013-5-25 22856]
    S3 RTLWUSB;NETGEAR WG111v2 54Mbps Wireless USB 2.0 Adapter NT Driver;c:\windows\system32\drivers\wg111v2.sys [2007-2-10 167808]
    S4 MBAMScheduler;MBAMScheduler;c:\program files\malwarebytes' anti-malware\mbamscheduler.exe [2013-5-25 418376]
    S4 MBAMService;MBAMService;c:\program files\malwarebytes' anti-malware\mbamservice.exe [2013-5-25 701512]
    S4 RealNetworks Downloader Resolver Service;RealNetworks Downloader Resolver Service;c:\program files\realnetworks\realdownloader\rndlresolversvc.exe [2013-3-6 39056]
    =============== File Associations ===============
    FileExt: .scr: AutoCADScriptFile="c:\windows\notepad.exe" "%1"
    ShellExec: FRONTPG.EXE: edit=c:\progra~1\micros~2\office10\FRONTPG.EXE
    2013-06-20 14:49:33   21504   -c--a-w-   c:\windows\system32\dllcache\hidserv.dll
    2013-06-20 14:34:31   --------   dcsha-r-   C:\cmdcons
    2013-06-20 14:32:34   98816   ----a-w-   c:\windows\sed.exe
    2013-06-20 14:32:34   256000   ----a-w-   c:\windows\PEV.exe
    2013-06-20 14:32:34   208896   ----a-w-   c:\windows\MBR.exe
    2013-06-20 10:27:16   465920   -c----w-   c:\windows\system32\dllcache\imapi2fs.dll
    2013-06-20 10:27:16   465920   ------w-   c:\windows\system32\imapi2fs.dll
    2013-06-20 10:27:16   317952   -c----w-   c:\windows\system32\dllcache\imapi2.dll
    2013-06-20 10:27:16   317952   ------w-   c:\windows\system32\imapi2.dll
    2013-06-19 09:53:26   --------   dc----w-   C:\Configuration
    2013-06-18 07:46:55   --------   d-----w-   c:\program files\Uniblue
    2013-06-18 07:33:27   --------   d-----w-   c:\windows\system32\wbem\repository\FS
    2013-06-18 07:33:26   --------   d-----w-   c:\windows\system32\wbem\Repository
    2013-06-18 06:20:22   --------   d-----w-   c:\documents and settings\all of us\local settings\application data\Citrix
    2013-05-29 20:22:46   --------   d-----w-   c:\documents and settings\all of us\SyncFolder
    2013-05-29 19:59:55   --------   d-----w-   c:\program files\MyPC Backup
    2013-05-29 19:59:03   5404880   ----a-w-   c:\documents and settings\all users\application data\pclunst.exe
    2013-05-29 19:59:00   --------   d-----w-   c:\documents and settings\all users\application data\PC1Data
    2013-05-29 13:42:36   --------   d-----w-   c:\program files\Webroot
    2013-05-25 08:52:41   22856   ----a-w-   c:\windows\system32\drivers\mbam.sys
    2013-05-25 08:52:41   --------   d-----w-   c:\program files\Malwarebytes' Anti-Malware
    2013-05-15 09:02:31   71048   -c--a-w-   c:\windows\system32\FlashPlayerCPLApp.cpl
    2013-05-15 09:02:31   692104   -c--a-w-   c:\windows\system32\FlashPlayerApp.exe
    2013-04-16 22:17:15   920064   ----a-w-   c:\windows\system32\wininet.dll
    2013-04-16 22:17:14   43520   ------w-   c:\windows\system32\licmgr10.dll
    2013-04-16 22:17:14   1469440   ------w-   c:\windows\system32\inetcpl.cpl
    2013-04-12 23:28:55   385024   ------w-   c:\windows\system32\html.iec
    2013-04-11 02:18:40   302368   -c--a-w-   c:\windows\system32\drivers\avgtdix.sys
    2013-04-10 01:31:19   1876352   ----a-w-   c:\windows\system32\win32k.sys
    2013-04-02 07:58:42   499712   -c--a-w-   c:\windows\system32\msvcp71.dll
    2013-04-02 07:58:42   348160   -c--a-w-   c:\windows\system32\msvcr71.dll
    2007-12-24 08:03:22   2293848   -c--a-w-   c:\program files\FLV PlayerFCSetup.exe
    2007-10-13 22:44:21   55088   -c--a-w-   c:\program files\MFInstall.exe
    2007-02-13 07:01:55   5727280   -c--a-w-   c:\program files\Firefox Setup 2.0.0.1.exe
    2006-06-26 19:36:08   3963304   -c--a-w-   c:\program files\MSASYNC.EXE
    2005-10-15 07:38:31   9624128   -c--a-w-   c:\program files\NapsterSetup-GB-3.1.1.8.exe
    2005-06-26 22:22:57   761344   -c--a-w-   c:\program files\ESS4CLEAR.exe
    2005-01-21 00:53:22   45056   -c----r-   c:\program files\SetAttrib.exe
    ============= FINISH: 19:55:42.95 ===============
Yes, please copy/paste Attach.txt.
Was DDS run from your account or your wife's account?
PeterJ
Soory, I forgot say that no, I still can't get into my account. I'm still using my wife's ...
Install Date: 23/02/2005 17:15:29
System Uptime: 20/06/2013 19:45:51 (0 hours ago)
Motherboard: Dell Computer Corp. |  |
Processor:               Intel(R) Pentium(R) 4 CPU 2.66GHz | Microprocessor | 2651/533mhz
A: is Removable
C: is FIXED (NTFS) - 37 GiB total, 7.55 GiB free.
D: is CDROM ()
E: is CDROM ()
F: is FIXED (NTFS) - 466 GiB total, 451.3 GiB free.
Class GUID:
Description: C-DillaCdaC11BA
Device ID: ROOT\LEGACY_C-DILLACDAC11BA\0000
Manufacturer:
PNP Device ID: ROOT\LEGACY_C-DILLACDAC11BA\0000
Service:
RP1791: 27/03/2013 07:45:49 - System Checkpoint
RP1792: 28/03/2013 08:37:35 - System Checkpoint
RP1793: 04/04/2013 08:54:06 - System Checkpoint
RP1794: 10/04/2013 10:40:19 - System Checkpoint
RP1795: 10/04/2013 16:25:47 - Software Distribution Service 3.0
RP1796: 12/04/2013 15:24:11 - System Checkpoint
RP1797: 15/04/2013 14:43:02 - System Checkpoint
RP1798: 17/04/2013 09:39:34 - System Checkpoint
RP1799: 20/04/2013 10:58:39 - System Checkpoint
RP1800: 21/04/2013 23:07:54 - System Checkpoint
RP1801: 23/04/2013 09:45:17 - System Checkpoint
RP1802: 25/04/2013 22:26:06 - System Checkpoint
RP1803: 29/04/2013 09:34:59 - System Checkpoint
RP1804: 02/05/2013 09:41:47 - System Checkpoint
RP1805: 03/05/2013 08:31:01 - Printer Driver CUSTPDF Writer Installed
RP1806: 03/05/2013 11:52:19 - Removed greenstreet Publisher 4 Home Edition
RP1807: 05/05/2013 18:20:11 - System Checkpoint
RP1808: 07/05/2013 20:22:55 - System Checkpoint
RP1809: 08/05/2013 20:50:32 - System Checkpoint
RP1810: 15/05/2013 06:26:05 - System Checkpoint
RP1811: 15/05/2013 15:52:54 - Software Distribution Service 3.0
RP1812: 18/05/2013 08:49:55 - System Checkpoint
RP1813: 20/05/2013 15:02:47 - System Checkpoint
RP1814: 24/05/2013 10:54:07 - System Checkpoint
RP1815: 30/05/2013 12:58:50 - System Checkpoint
RP1816: 03/06/2013 15:02:45 - System Checkpoint
RP1817: 17/06/2013 11:40:23 - System Checkpoint
RP1818: 18/06/2013 08:32:35 - Restore Operation
RP1819: 18/06/2013 08:50:01 - Restore Operation
RP1820: 19/06/2013 09:13:34 - System Checkpoint
RP1821: 20/06/2013 10:46:22 - Removed Windows Media Player Firefox Plugin
RP1822: 20/06/2013 11:31:16 - Installed Windows XP KB932716-v2.
4oD
Adobe Flash Player 11 ActiveX
Adobe Flash Player 11 Plugin
Adobe Photoshop 6.0
Adobe Reader X (10.1.7)
Adobe Shockwave Player 11
Adobe SVG Viewer
Ahead Nero Burning ROM
Apple Mobile Device Support
Apple Software Update
ArcSoft MediaImpression 2
AVG 2012
AVS Screen Capture version 2.0.1
AVS Update Manager 1.0
AVS Video Editor 6
AVS Video Recorder 2.5
AVS4YOU Software Navigator 1.4
BCM V.92 56K Modem
BearShare
BT Broadband Desktop Help
BT Broadband Support Tools
Canon MP Navigator EX 1.2
Canon MP160 User Registration
Canon MP190 series MP Drivers
Canon MP190 series User Registration
Canon Utilities CameraWindow DC 8
Canon Utilities ImageBrowser EX
Canon Utilities My Printer
Canon Utilities PhotoStitch
Canon Utilities Solution Menu
Citrix Web Client
CyberTweak Version 1.3 Final
Dan Elwell's Broadband Speed Test
Easy-WebPrint
ecobutton
EmoDio
FinePix Studio
FinePixViewer Resource
FinePixViewer Ver.5.5
Free PDF to Word Doc Converter v1.1
Google Earth Plug-in
Google Update Helper
GoToAssist Corporate
Hotfix for Windows Internet Explorer 7 (KB947864)
Hotfix for Windows XP (KB2570791)
Hotfix for Windows XP (KB2633952)
Hotfix for Windows XP (KB2756822)
Hotfix for Windows XP (KB2779562)
Hotfix for Windows XP (KB932716-v2)
Intel(R) PRO Ethernet Adapter and Software
iTunes
Java Auto Updater
Java(TM) 6 Update 24
Juniper Networks, Inc. Setup Client Activex Control
Logitech Webcam Software
Logitech Webcam Software Driver Package
Malwarebytes Anti-Malware version 1.75.0.1300
MetaFrame Presentation Server Web Client for Win32
Microsoft Choice Guard
Microsoft Compression Client Pack 1.0 for Windows XP
Microsoft IntelliPoint 5.5
Microsoft Internationalized Domain Names Mitigation APIs
Microsoft Kernel-Mode Driver Framework Feature Pack 1.9
Microsoft National Language Support Downlevel APIs
Microsoft Office XP Professional with FrontPage
Microsoft Project 2000
Microsoft Silverlight
Microsoft User-Mode Driver Framework Feature Pack 1.9
Microsoft Visual C++ 2008 Redistributable - KB2467174 - x86 9.0.30729.5570
MSVC80_x86_v2
MSVC90_x86
MSVCRT
MSXML 4.0 SP2 (KB927978)
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
MSXML 4.0 SP2 (KB973688)
Nokia Connectivity Cable Driver
Nokia Ovi Suite
NVIDIA Display Driver
NVIDIA Windows 2000/XP Display Drivers
OGA Notifier 2.0.0048.0
OLYMPUS CAMEDIA Master 4.2
Ovi Desktop Sync Engine
OviMPlatform
PC Pitstop Optimize 1.0v
QuickTime
RealDownloader
RealNetworks - Microsoft Visual C++ 2008 Runtime
RealNetworks - Microsoft Visual C++ 2010 Runtime
RealPlayer
RealUpgrade 1.1
ScanSoft OmniPage SE 4.0
Security Update for CAPICOM (KB931906)
Security Update for Microsoft .NET Framework 3.5 SP1 (KB2604111)
Security Update for Microsoft .NET Framework 3.5 SP1 (KB2657424)
Security Update for Microsoft .NET Framework 3.5 SP1 (KB2736416)
Security Update for Microsoft Windows (KB2564958)
Security Update for Windows Internet Explorer 7 (KB2183461)
Security Update for Windows Internet Explorer 7 (KB2360131)
Security Update for Windows Internet Explorer 7 (KB2416400)
Security Update for Windows Internet Explorer 7 (KB2482017)
Security Update for Windows Internet Explorer 7 (KB928090)
Security Update for Windows Internet Explorer 7 (KB929969)
Security Update for Windows Internet Explorer 7 (KB931768)
Security Update for Windows Internet Explorer 7 (KB933566)
Security Update for Windows Internet Explorer 7 (KB937143)
Security Update for Windows Internet Explorer 7 (KB938127)
Security Update for Windows Internet Explorer 7 (KB939653)
Security Update for Windows Internet Explorer 7 (KB942615)
Security Update for Windows Internet Explorer 7 (KB944533)
Security Update for Windows Internet Explorer 7 (KB950759)
Security Update for Windows Internet Explorer 7 (KB953838)
Security Update for Windows Internet Explorer 7 (KB956390)
Security Update for Windows Internet Explorer 7 (KB958215)
Security Update for Windows Internet Explorer 7 (KB960714)
Security Update for Windows Internet Explorer 7 (KB961260)
Security Update for Windows Internet Explorer 7 (KB963027)
Security Update for Windows Internet Explorer 7 (KB969897)
Security Update for Windows Internet Explorer 7 (KB972260)
Security Update for Windows Internet Explorer 7 (KB974455)
Security Update for Windows Internet Explorer 7 (KB976325)
Security Update for Windows Internet Explorer 7 (KB978207)
Security Update for Windows Internet Explorer 7 (KB982381)
Security Update for Windows Internet Explorer 8 (KB2482017)
Security Update for Windows Internet Explorer 8 (KB2497640)
Security Update for Windows Internet Explorer 8 (KB2510531)
Security Update for Windows Internet Explorer 8 (KB2530548)
Security Update for Windows Internet Explorer 8 (KB2544521)
Security Update for Windows Internet Explorer 8 (KB2559049)
Security Update for Windows Internet Explorer 8 (KB2586448)
Security Update for Windows Internet Explorer 8 (KB2618444)
Security Update for Windows Internet Explorer 8 (KB2647516)
Security Update for Windows Internet Explorer 8 (KB2675157)
Security Update for Windows Internet Explorer 8 (KB2699988)
Security Update for Windows Internet Explorer 8 (KB2722913)
Security Update for Windows Internet Explorer 8 (KB2744842)
Security Update for Windows Internet Explorer 8 (KB2761465)
Security Update for Windows Internet Explorer 8 (KB2792100)
Security Update for Windows Internet Explorer 8 (KB2797052)
Security Update for Windows Internet Explorer 8 (KB2799329)
Security Update for Windows Internet Explorer 8 (KB2809289)
Security Update for Windows Internet Explorer 8 (KB2817183)
Security Update for Windows Internet Explorer 8 (KB2829530)
Security Update for Windows Internet Explorer 8 (KB2847204)
Security Update for Windows Internet Explorer 8 (KB971961)
Security Update for Windows Internet Explorer 8 (KB981332)
Security Update for Windows Internet Explorer 8 (KB982381)
Security Update for Windows XP (KB2412687)
Security Update for Windows XP (KB2476490)
Security Update for Windows XP (KB2479943)
Security Update for Windows XP (KB2491683)
Security Update for Windows XP (KB2503658)
Security Update for Windows XP (KB2503665)
Security Update for Windows XP (KB2506223)
Security Update for Windows XP (KB2507938)
Security Update for Windows XP (KB2508272)
Security Update for Windows XP (KB2509553)
Security Update for Windows XP (KB2511455)
Security Update for Windows XP (KB2524375)
Security Update for Windows XP (KB2535512)
Security Update for Windows XP (KB2536276-v2)
Security Update for Windows XP (KB2536276)
Security Update for Windows XP (KB2544893-v2)
Security Update for Windows XP (KB2544893)
Security Update for Windows XP (KB2555917)
Security Update for Windows XP (KB2562937)
Security Update for Windows XP (KB2566454)
Security Update for Windows XP (KB2567053)
Security Update for Windows XP (KB2567680)
Security Update for Windows XP (KB2570222)
Security Update for Windows XP (KB2570947)
Security Update for Windows XP (KB2584146)
Security Update for Windows XP (KB2585542)
Security Update for Windows XP (KB2592799)
Security Update for Windows XP (KB2598479)
Security Update for Windows XP (KB2603381)
Security Update for Windows XP (KB2618451)
Security Update for Windows XP (KB2619339)
Security Update for Windows XP (KB2620712)
Security Update for Windows XP (KB2621440)
Security Update for Windows XP (KB2624667)
Security Update for Windows XP (KB2631813)
Security Update for Windows XP (KB2633171)
Security Update for Windows XP (KB2639417)
Security Update for Windows XP (KB2641653)
Security Update for Windows XP (KB2646524)
Security Update for Windows XP (KB2647518)
Security Update for Windows XP (KB2653956)
Security Update for Windows XP (KB2655992)
Security Update for Windows XP (KB2659262)
Security Update for Windows XP (KB2660465)
Security Update for Windows XP (KB2661637)
Security Update for Windows XP (KB2676562)
Security Update for Windows XP (KB2685939)
Security Update for Windows XP (KB2686509)
Security Update for Windows XP (KB2691442)
Security Update for Windows XP (KB2695962)
Security Update for Windows XP (KB2698365)
Security Update for Windows XP (KB2705219)
Security Update for Windows XP (KB2707511)
Security Update for Windows XP (KB2709162)
Security Update for Windows XP (KB2712808)
Security Update for Windows XP (KB2718523)
Security Update for Windows XP (KB2719985)
Security Update for Windows XP (KB2723135)
Security Update for Windows XP (KB2724197)
Security Update for Windows XP (KB2727528)
Security Update for Windows XP (KB2731847)
Security Update for Windows XP (KB2753842-v2)
Security Update for Windows XP (KB2753842)
Security Update for Windows XP (KB2757638)
Security Update for Windows XP (KB2758857)
Security Update for Windows XP (KB2761226)
Security Update for Windows XP (KB2770660)
Security Update for Windows XP (KB2778344)
Security Update for Windows XP (KB2779030)
Security Update for Windows XP (KB2780091)
Security Update for Windows XP (KB2799494)
Security Update for Windows XP (KB2802968)
Security Update for Windows XP (KB2807986)
Security Update for Windows XP (KB2808735)
Security Update for Windows XP (KB2813170)
Security Update for Windows XP (KB2813345)
Security Update for Windows XP (KB2820197)
Security Update for Windows XP (KB2820917)
Security Update for Windows XP (KB2829361)
Segoe UI
SmartFTP Client
Sound Blaster Live!
Spotify
Uniblue DriverScanner
Uniblue PowerSuite
Uniblue RegistryBooster
Uniblue SpeedUpMyPC
Uninstall Startup Inspector
Update for Windows Internet Explorer 7 (KB976749)
Update for Windows Internet Explorer 7 (KB980182)
Update for Windows Internet Explorer 8 (KB2447568)
Update for Windows Internet Explorer 8 (KB976662)
Update for Windows XP (KB2541763)
Update for Windows XP (KB2607712)
Update for Windows XP (KB2616676)
Update for Windows XP (KB2641690)
Update for Windows XP (KB2661254-v2)
Update for Windows XP (KB2718704)
Update for Windows XP (KB2736233)
Update for Windows XP (KB2749655)
Update for Windows XP (KB971029)
WebFldrs XP
Wincore MediaBar
Windows Genuine Advantage v1.3.0254.0
Windows Live Call
Windows Live Essentials
Windows Live Messenger
Windows Live Sign-in Assistant
Windows Live Upload Tool
Windows Media Player 11
Windows XP Service Pack 3
WinZip
20/06/2013 15:53:17, error: Service Control Manager [7023]  - The Help and Support service terminated with the following error:  The specified module could not be found.
20/06/2013 15:31:49, error: Service Control Manager [7034]  - The Process Monitor service terminated unexpectedly.  It has done this 1 time(s).
20/06/2013 10:19:23, error: Print [19]  - Sharing printer failed + 1722, Printer Canon MP190 series Printer share name Canon MP190 series Printer.
19/06/2013 14:56:12, error: Service Control Manager [7026]  - The following boot-start or system-start driver(s) failed to load:  AFD Avgldx86 Avgmfx86 Avgtdix Fips intelppm IPSec MRxSmb NetBIOS NetBT RasAcd Rdbss Tcpip WS2IFSL
19/06/2013 14:56:12, error: Service Control Manager [7001]  - The DNS Client service depends on the TCP/IP Protocol Driver service which failed to start because of the following error:  A device attached to the system is not functioning.
19/06/2013 14:56:12, error: Service Control Manager [7001]  - The DHCP Client service depends on the NetBT service which failed to start because of the following error:  A device attached to the system is not functioning.
19/06/2013 14:55:51, error: DCOM [10005]  - DCOM got error "%1084" attempting to start the service netman with arguments "" in order to run the server: {BA126AE5-2166-11D1-B1D0-00805FC1270E}
18/06/2013 09:08:31, error: DCOM [10005]  - DCOM got error "%1084" attempting to start the service StiSvc with arguments "" in order to run the server: {A1F4E726-8CF1-11D1-BF92-0060081ED811}
18/06/2013 08:00:45, error: Service Control Manager [7026]  - The following boot-start or system-start driver(s) failed to load:  Avgldx86 Avgmfx86 Fips intelppm
18/06/2013 08:00:25, error: DCOM [10005]  - DCOM got error "%1084" attempting to start the service EventSystem with arguments "" in order to run the server: {1BE1F766-5536-11D1-B726-00C04FB926AF}
18/06/2013 06:38:59, error: Service Control Manager [7001]  - The Fast User Switching Compatibility service depends on the Terminal Services service which failed to start because of the following error:  The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.
18/06/2013 06:38:59, error: Service Control Manager [7000]  - The General Purpose USB Driver (adildr.sys) service failed to start due to the following error:  The system cannot find the file specified.
17/06/2013 19:46:46, error: Service Control Manager [7034]  - The McciCMService service terminated unexpectedly.  It has done this 1 time(s).
16/06/2013 10:54:07, error: sr [1]  - The System Restore filter encountered the unexpected error '0xC0000001' while processing the file '' on the volume 'HarddiskVolume1'.  It has stopped monitoring the volume.
Thank you, Peter.
Below is a list of programs to be uninstalled, with a brief explanation why:
  • Bearshare is a P2P program.  With P2P file sharing, what means do you have of identifying or authenticating the source of the download? In addition, a file can be distributed among many hosts, and peers will provide for download the sections that they have already downloaded. This results in the distinct possibility of a distribution method in which malicious bits are mixed with with good files.
  • Java has had critical security updates and will need to be updated if it is really needed.  At this point, let's just uninstall the old version.
  • I hope you haven't run Uniblue or PC Pitstop Optimize as programs of this nature tend to do more harm than good and tend to damage the registry.
Please uninstall:
BearShare
Uniblue PowerSuite
Uniblue SpeedUpMyPC
We'll get to Adobe Reader later.  First, let's take a look at a different set of logs.  After removing the above, restart the computer and please download the 32-bit version of Farbar Recovery Scan Tool and save it to your desktop.
  • Double-click to run it. When the tool opens click Yes to disclaimer.
  • Press Scan button.
  • It will make a log (FRST.txt) in the same directory the tool is run. Please copy and paste it to your reply.
  • The first time the tool is run, it makes also another log (Addition.txt). Please attach it to your reply.
PeterJ
Thanks.
I have uninstalled Bearshare (which I haven't used for a couple of years) but it still appears in my Add or Remove programs list.
I have uninstalled PC Pitstop Optimize
I can't uninstall Java (TM) 6 Update 24. I get a message to say 'Windows Installer Service cannot be accessed'.
I tried to uninstall all the Uniblue programs but for each of them I get a message to say ' \(program name)\unins000.msg is missing. Cannot uninstall ' Except for Powersuite for which the message reads  '\PowerSuite\unins0000.dat does not exist.'
One other thing: For many years I've been unable to remove the program called greenstreet Publisher 4 Home Edition.
Hi, Peter.
Please use JavaRa to remove Java.  Use the "Remove JRE" option.  It is available from here:  http://singularlabs.com/software/javara/  Since most people do not need Java these days, we'll get back to whether or not you need to install the current version later.  My goal here is to get the vulnerable/potentially dangerous programs off your computer.
Let's see if we can take care of those files with ComboFix.  Be patient if it takes a bit to process them.
Custom CFScript
Folder::
c:\program files\greenstreet Publisher 4 Home Edition
c:\program files\Uniblue DriverScanner
c:\program files\Uniblue PowerSuite
c:\program files\Uniblue RegistryBooster
c:\program files\Uniblue SpeedUpMyPC
  • Close any open browsers.
After that, please follow the instructions above for Farbar's Recovery Scan Tool.
PeterJ
OK here's the lates ComboFix log...
ComboFix 13-06-22.01 - All of Us 22/06/2013   8:12.4.1 - x86
Microsoft Windows XP Professional  5.1.2600.3.1252.44.1033.18.1023.638 [GMT 1:00]
Command switches used :: c:\documents and settings\All of Us\Desktop\CFScript.txt
(((((((((((((((((((((((((   Files Created from 2013-05-22 to 2013-06-22  )))))))))))))))))))))))))))))))
2013-06-21 07:28 . 2013-06-21 07:28   --------   d-----w-   c:\documents and settings\All of Us\Local Settings\Application Data\PackageAware
2013-05-07 22:30 . 2004-01-08 15:23   920064   ----a-w-   c:\windows\system32\wininet.dll
2013-05-07 22:30 . 2001-08-23 12:00   43520   ------w-   c:\windows\system32\licmgr10.dll
2013-05-07 22:30 . 2001-08-23 12:00   1469440   ------w-   c:\windows\system32\inetcpl.cpl
2013-05-07 21:53 . 2004-08-04 05:59   385024   ------w-   c:\windows\system32\html.iec
2013-05-03 01:26 . 2001-08-23 12:00   2193536   ----a-w-   c:\windows\system32\ntoskrnl.exe
2013-05-03 00:38 . 2001-08-17 13:48   2070144   ----a-w-   c:\windows\system32\ntkrnlpa.exe
REGEDIT4
@="Driver"
@="Service"
Rootkit scan 2013-06-22 08:23
hidden files: 0
@="FlashBroker"
@="IFlashBroker5"
"Version"="1.0"
- - - - - - - > 'explorer.exe'(3212)
Completion time: 2013-06-22  08:26:02
ComboFix-quarantined-files.txt  2013-06-22 07:25
ComboFix2.txt  2013-06-22 07:00
ComboFix3.txt  2013-06-20 15:17
Pre-Run: 7,921,274,880 bytes free
Post-Run: 7,927,902,208 bytes free
- - End Of File - - E1AF95C4B1E1864C7D5694859C97AFDC
