May have a trojan
Started by deew, September 09, 2013, 08:59:15 PM
I suspect the threats ESET found were from the AdwCleaner log so go ahead and restart your computer and reinstall MSE.
deew
I now get this message:
An error has occurred in the program during initialization. Error ode: 0x80073b01.
As you might imagine, I still can't access MSE.  I'd like to get rid of it, but can't do that either.  What now?
Dee
Hi, Dee.  Let's take a look with ComboFix.  When reading the instructions, don't worry about attempting to disable MSE. :)
Please follow these instructions carefully.  Download ComboFix from the following location:  Link 1
deew
Corrine, I ran Combofix, but my computer did not like it that MSE wasn't disabled.  The scan took a very long time, however, my computer seems to have a talent for hiding logs.  When I clicked on the Combofix folder in C:\ there were three files and two folders and none of them were the log.  Also, Combofix never rebooted my computer nor did I ever see the Desktop go blank.  One thing I did notice was that the Template settings for my Word Processor program were wiped out.  I have no idea how that happened.
Should I delete Combofix and try running it again?
Dee
Hi, Dee.
In researching Error Code 0x80073b01, the most common solution appears to be using the trial version of HitmanPro.  It can be downloaded and run from a flash drive.  See http://www.surfright.nl/en/hitmanpro
deew
Corrine, I ran HitmanPro, and it found several items that it said disabled MSE, so I selected repair.  It also fiouun several items to be deleted, which I approved.
I logged out and held my breath when I logged back in.  Yippee, the MSE icon was back in the Taskbar.  Let's hope it stays there.
I can't thank you enough for all your patient help. Is there anything else you think may need to be done?
Dee
Oh, my goodness, Dee.  I am so sorry that I missed your last reply.
Since you haven't run ComboFix, if your computer is running fine, you can delete it from your desktop.
Please do the following to uninstall AdwCleaner:
Double-click on AdwCleaner.exe to run the tool again.
  • Click on the Uninstall button.
  • Click Yes when asked are you sure you want to uninstall.
  • Both AdwCleaner.exe, its folder and all logs will be removed.
Adobe Reader is scheduled to be updated on Tuesday, October 8.  Although the recent incident (Illegal Access to Adobe Source Code) shouldn't affect Adobe Reader, it will be a good idea to be sure and update.
