Possible MBR rootkit infection
Started by DR M, November 15, 2013, 09:01:46 AM
While scanning, Eset's warning appeared again. I chose no action and disabled it.
Hi, Panos.
aswMBR didn't identify TDL3.  As you'll recall, I mentioned earlier TDL3 is old (from 2009).  However, I've been reading up on it and believe that the best action is to run ComboFix, which had been updated at that time to deal with it -- well and also knowing that you are prepared to reinstall the OS in case of problems.
Please follow these instructions carefully.  Download ComboFix from the following location:  Link 1
Hi, Corrine.
Yes, you can say that I am prepared for a clean install. Again, no windows disc exists and the computer will be restored to factory settings. My question is: Where is the license of windows? There is no sticker with it on any side of the computer. Has this something to do with the fact that the version is Windows Starter?
Anyway... Hoping that computer's restore won't be neccessary, I post the Combofix log. While scanning, there was a warning that a program (I don't remember the name, but it had exe at the end) could not continue working and windows should close it.
The log:
ComboFix 13-11-16.01 - user 11/18/2013  15:04:35.1.2 - x86
Microsoft Windows 7 Starter   6.1.7601.1.1252.1.1033.18.987.176 [GMT 2:00]
Running from: c:\users\user\Desktop\ComboFix.exe
AV: ESET Smart Security 7.0 *Disabled/Updated* {19259FAE-8396-A113-46DB-15B0E7DFA289}
FW: ESET Personal firewall *Enabled* {211E1E8B-C9F9-A04B-6D84-BC85190CE5F2}
SP: ESET Smart Security 7.0 *Disabled/Updated* {A2447E4A-A5AC-AE9D-7C6B-2EC29C58E834}
c:\windows\PFRO.log
c:\windows\system32\FlashPlayerApp.exe
c:\windows\system32\Tasks\BackgroundContainer Startup Task
(((((((((((((((((((((((((   Files Created from 2013-10-18 to 2013-11-18  )))))))))))))))))))))))))))))))
2013-11-18 14:13 . 2013-11-18 14:13   --------   d-----w-   c:\users\Default\AppData\Local\temp
2013-11-18 13:31 . 2013-11-18 13:31   62576   ----a-w-   c:\programdata\Microsoft\Windows Defender\Definition Updates\{7B4CB518-7CBC-4DDA-BBCD-2555709D48C4}\offreg.dll
2013-11-15 08:12 . 2013-11-15 08:12   --------   d-----w-   C:\18be667fae7b1dce1c
2013-11-15 07:55 . 2013-11-15 07:55   --------   d-----w-   c:\program files\ESET
2013-11-15 07:52 . 2013-11-15 07:52   71048   ----a-w-   c:\windows\system32\FlashPlayerCPLApp.cpl
2013-11-15 07:00 . 2013-10-14 06:39   7796464   ----a-w-   c:\programdata\Microsoft\Windows Defender\Definition Updates\{7B4CB518-7CBC-4DDA-BBCD-2555709D48C4}\mpengine.dll
2013-10-20 14:40 . 2013-09-22 23:28   817664   ----a-w-   c:\program files\Common Files\Microsoft Shared\VGX\VGX.dll
2013-10-20 14:40 . 2013-09-22 23:54   770648   ----a-w-   c:\program files\Internet Explorer\iexplore.exe
2013-10-20 14:40 . 2013-09-22 23:28   1767936   ----a-w-   c:\windows\system32\wininet.dll
2013-10-19 08:49 . 2013-10-19 08:49   50053120   ----a-w-   c:\program files\GUT2DF4.tmp
2013-09-17 13:17 . 2013-09-17 13:17   49240   ----a-w-   c:\windows\system32\drivers\epfwwfp.sys
2013-09-17 13:17 . 2013-09-17 13:17   37416   ----a-w-   c:\windows\system32\drivers\EpfwLWF.sys
2013-09-17 13:17 . 2013-09-17 13:17   188808   ----a-w-   c:\windows\system32\drivers\eamonm.sys
2013-09-17 13:17 . 2013-09-17 13:17   174400   ----a-w-   c:\windows\system32\drivers\epfw.sys
2013-09-17 13:17 . 2013-09-17 13:17   134248   ----a-w-   c:\windows\system32\drivers\ehdrv.sys
2013-09-14 00:48 . 2013-10-19 08:46   338944   ----a-w-   c:\windows\system32\drivers\afd.sys
2013-09-08 02:07 . 2013-10-19 08:46   1294272   ----a-w-   c:\windows\system32\drivers\tcpip.sys
2013-09-08 02:03 . 2013-10-19 08:46   231424   ----a-w-   c:\windows\system32\mswsock.dll
2013-09-03 11:35 . 2012-02-03 17:15   238872   ------w-   c:\windows\system32\MpSigStub.exe
2013-08-29 01:51 . 2013-10-19 08:45   3969472   ----a-w-   c:\windows\system32\ntkrnlpa.exe
2013-08-29 01:51 . 2013-10-19 08:45   3914176   ----a-w-   c:\windows\system32\ntoskrnl.exe
2013-08-29 01:50 . 2013-10-19 08:45   1289096   ----a-w-   c:\windows\system32\ntdll.dll
2013-08-29 01:50 . 2013-10-19 08:45   619520   ----a-w-   c:\windows\system32\tdh.dll
2013-08-29 01:48 . 2013-10-19 08:45   640512   ----a-w-   c:\windows\system32\advapi32.dll
2013-08-28 01:04 . 2013-10-19 08:44   2348544   ----a-w-   c:\windows\system32\win32k.sys
2013-08-28 00:57 . 2013-10-19 08:45   434688   ----a-w-   c:\windows\system32\scavengeui.dll
REGEDIT4
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\00Zecter]
@="{D25B32FE-CB96-491A-98FF-AD59DA382D69}"
[HKEY_CLASSES_ROOT\CLSID\{D25B32FE-CB96-491A-98FF-AD59DA382D69}]
2009-10-29 01:18   661504   ----a-w-   c:\program files\Hewlett-Packard\HP CloudDrive\ShellExt.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\01Zecter]
@="{EB24CA6D-F315-4A81-AC1A-C79CFD77F3F5}"
[HKEY_CLASSES_ROOT\CLSID\{EB24CA6D-F315-4A81-AC1A-C79CFD77F3F5}]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\02Zecter]
@="{B3C78E40-6B64-47C3-AE34-60B770881EB8}"
[HKEY_CLASSES_ROOT\CLSID\{B3C78E40-6B64-47C3-AE34-60B770881EB8}]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\03Zecter]
@="{622AFE52-33F6-4D9F-9966-E0BC52D7D69D}"
[HKEY_CLASSES_ROOT\CLSID\{622AFE52-33F6-4D9F-9966-E0BC52D7D69D}]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\04Zecter]
@="{855156F0-2A0F-11DE-8C30-0800200C9A66}"
[HKEY_CLASSES_ROOT\CLSID\{855156F0-2A0F-11DE-8C30-0800200C9A66}]
"MCShield Monitor"="c:\program files\MCShield\mcshieldrtm.exe" [2012-03-12 583680]
"BackgroundContainer"="c:\users\user\AppData\Local\Conduit\BackgroundContainer\BackgroundContainer.dll" [2013-10-14 319264]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2009-10-16 141848]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2009-10-16 173592]
"Persistence"="c:\windows\system32\igfxpers.exe" [2009-10-16 150552]
"egui"="c:\program files\ESET\ESET Smart Security\egui.exe" [2013-09-12 5110672]
"SPReview"="c:\windows\System32\SPReview\SPReview.exe" [2013-05-18 280576]
[HKLM\~\startupfolder\C:^ProgramData^Microsoft^Windows^Start Menu^Programs^Startup^Bluetooth.lnk]
path=c:\programdata\Microsoft\Windows\Start Menu\Programs\Startup\Bluetooth.lnk
backup=c:\windows\pss\Bluetooth.lnk.CommonStartup
backupExtension=.CommonStartup
[HKLM\~\startupfolder\C:^Users^user^AppData^Roaming^Microsoft^Windows^Start Menu^Programs^Startup^OneNote 2007 Screen Clipper and Launcher.lnk]
path=c:\users\user\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\OneNote 2007 Screen Clipper and Launcher.lnk
backup=c:\windows\pss\OneNote 2007 Screen Clipper and Launcher.lnk.Startup
backupExtension=.Startup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\BackgroundContainer]
2013-10-14 14:00   319264   ----a-w-   c:\users\user\AppData\Local\Conduit\BackgroundContainer\BackgroundContainer.dll
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Freecorder FLV Service]
2011-03-24 07:11   167936   ----a-w-   c:\program files\Freecorder\FLVSrvc.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\GrooveMonitor]
2009-02-26 16:36   30040   ----a-w-   c:\program files\Microsoft Office\Office12\GrooveMonitor.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\HP]
2009-07-14 11:54   589104   ----a-w-   c:\program files\Hewlett-Packard\HP QuickSync\QuickSync.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\HP Software Update]
2011-05-10 00:41   49208   ----a-w-   c:\program files\Hp\HP Software Update\hpwuschd2.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\IAAnotif]
2009-06-05 03:03   186904   ----a-w-   c:\program files\Intel\Intel Matrix Storage Manager\IAAnotif.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Malwarebytes' Anti-Malware]
2012-01-13 12:53   460872   ----a-w-   c:\program files\Malwarebytes' Anti-Malware\mbamgui.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\QlbCtrl.exe]
2009-08-20 08:46   322104   ----a-w-   c:\program files\Hewlett-Packard\HP Quick Launch Buttons\QLBCtrl.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Simplify Media]
2009-10-23 09:56   21498376   ----a-w-   c:\program files\Hp\HP MediaStream\HPMediaStream.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SynTPEnh]
2010-05-27 12:31   1721640   ----a-w-   c:\program files\Synaptics\SynTP\SynTPEnh.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SysTrayApp]
2009-10-12 06:51   495708   ----a-w-   c:\program files\IDT\WDM\sttray.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\WirelessAssistant]
2009-09-01 08:41   499768   ----a-w-   c:\program files\Hewlett-Packard\HP Wireless Assistant\HPWAMain.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ZumoDrive]
2012-01-31 13:17   2042   ----a-w-   c:\program files\Hewlett-Packard\HP CloudDrive\ZumoLauncher.lnk
R2 BBSvc;Bing Bar Update Service;c:\program files\Microsoft\BingBar\BBSvc.EXE [2011-10-21 196176]
R2 SkypeUpdate;Skype Updater;c:\program files\Skype\Updater\Updater.exe [2012-11-09 160944]
R3 Com4QLBEx;Com4QLBEx;c:\program files\Hewlett-Packard\HP Quick Launch Buttons\Com4QLBEx.exe [2009-05-05 228408]
R3 netw5v32;Intel(R) Wireless WiFi Link 5000 Series Adapter Driver for Windows Vista 32 Bit;c:\windows\system32\DRIVERS\netw5v32.sys [2009-07-13 4231168]
R3 RSUSBSTOR;RtsUStor.Sys Realtek USB Card Reader;c:\windows\system32\Drivers\RtsUStor.sys [2009-09-02 174592]
R3 SrvHsfHDA;SrvHsfHDA;c:\windows\system32\DRIVERS\VSTAZL3.SYS [2009-07-13 207360]
R3 SrvHsfV92;SrvHsfV92;c:\windows\system32\DRIVERS\VSTDPV3.SYS [2009-07-13 980992]
R3 SrvHsfWinac;SrvHsfWinac;c:\windows\system32\DRIVERS\VSTCNXT3.SYS [2009-07-13 661504]
R3 TsUsbFlt;TsUsbFlt;c:\windows\system32\drivers\tsusbflt.sys [2010-11-20 52224]
R3 yukonw7;NDIS6.2 Miniport Driver for Marvell Yukon Ethernet Controller;c:\windows\system32\DRIVERS\yk62x86.sys [2009-07-13 311296]
S0 epfwwfp;epfwwfp;c:\windows\system32\DRIVERS\epfwwfp.sys [2013-09-17 49240]
S1 DVMIO;DVMIO;c:\splash.sys\config\dvmio.sys [2009-09-30 17624]
S1 eamonm;eamonm;c:\windows\system32\DRIVERS\eamonm.sys [2013-09-17 188808]
S1 ehdrv;ehdrv;c:\windows\system32\DRIVERS\ehdrv.sys [2013-09-17 134248]
S1 EpfwLWF;Epfw NDIS LightWeight Filter;c:\windows\system32\DRIVERS\EpfwLWF.sys [2013-09-17 37416]
S2 AESTFilters;Andrea ST Filters Service;c:\windows\System32\DriverStore\FileRepository\stwrt.inf_x86_neutral_5576240ee6baaa25\aestsrv.exe [2009-03-02 81920]
S2 BBUpdate;BBUpdate;c:\program files\Microsoft\BingBar\SeaPort.EXE [2011-10-13 249648]
S2 DvmMDES;DeviceVM Meta Data Export Service;c:\splash.sys\config\DVMExportService.exe [2009-07-09 323584]
S2 ekrn;ESET Service;c:\program files\ESET\ESET Smart Security\ekrn.exe [2013-09-12 1337752]
S2 MBAMService;MBAMService;c:\program files\Malwarebytes' Anti-Malware\mbamservice.exe [2012-01-13 652360]
S3 btwl2cap;Bluetooth L2CAP Service;c:\windows\system32\DRIVERS\btwl2cap.sys [2009-09-17 29472]
S3 MBAMProtector;MBAMProtector;c:\windows\system32\drivers\mbam.sys [2011-12-10 20464]
S3 RTL8167;Realtek 8167 NT Driver;c:\windows\system32\DRIVERS\Rt86win7.sys [2009-10-02 204288]
LocalServiceAndNoImpersonation   REG_MULTI_SZ      SSDPSRV upnphost SCardSvr TBS fdrespub AppIDSvc QWAVE wcncsvc
2013-11-18 c:\windows\Tasks\Adobe Flash Player Updater.job
- c:\windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe [2013-11-15 07:53]
2013-11-18 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files\Google\Update\GoogleUpdate.exe [2012-02-05 17:04]
2013-11-18 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~2\Office12\EXCEL.EXE/3000
IE: E&ξαγωγή στο Microsoft Excel - c:\progra~1\MICROS~2\Office12\EXCEL.EXE/3000
IE: Send image to &Bluetooth Device... - c:\program files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
IE: Send page to &Bluetooth Device... - c:\program files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
TCP: DhcpNameServer = 192.168.10.254
URLSearchHooks-{1392b8d2-5c05-419f-a8f6-b9f15a596612} - c:\program files\Freecorder\prxtbFre0.dll
BHO-{1392b8d2-5c05-419f-a8f6-b9f15a596612} - c:\program files\Freecorder\prxtbFre0.dll
Toolbar-{1392b8d2-5c05-419f-a8f6-b9f15a596612} - c:\program files\Freecorder\prxtbFre0.dll
WebBrowser-{1392B8D2-5C05-419F-A8F6-B9F15A596612} - c:\program files\Freecorder\prxtbFre0.dll
SafeBoot-Wdf01000.sys
MSConfigStartUp-Adobe Reader Speed Launcher - c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe
MSConfigStartUp-SunJavaUpdateSched - c:\program files\Java\jre6\bin\jusched.exe
AddRemove-ΜΑΤΖΕΝΤΑ - Αγγλικό-Ελληνικό-Αγγλικό λεξικό όρων ~BCE23F32_is1 - c:\program files\Magenta Demo\polydemo\unins000.exe
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}]
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\Windows\\system32\\Macromed\\Flash\\FlashUtil32_11_9_900_152_ActiveX.exe,-101"
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\Elevation]
"Enabled"=dword:00000001
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\LocalServer32]
@="c:\\Windows\\system32\\Macromed\\Flash\\FlashUtil32_11_9_900_152_ActiveX.exe"
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\TypeLib]
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}]
@="IFlashBroker5"
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}\ProxyStubClsid32]
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}\TypeLib]
"Version"="1.0"
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\PCW\Security]
@Denied: (Full) (Everyone)
- - - - - - - > 'Explorer.exe'(2700)
Completion time: 2013-11-18  16:20:46
ComboFix-quarantined-files.txt  2013-11-18 14:20
Pre-Run: 226,230,714,368 bytes free
Post-Run: 227,459,641,344 bytes free
- - End Of File - - CA03695224BC48674FF9E62195C3C734
BBCF369EC7C1AB809FFF44A0FD8090F6
Hmmm, did you notice, Panos, that the ComboFix log had no mention of TDL3?   Are you still getting alerts from ESET?  If so, can you write down what they are and post here.
I tried to ... read Combofix, but I didn't understand ... the last two words ( :laughing: )
The last warning of Eset I remember was about Freecorder. But this is not a rootkit. It is an old tool-add on- for downloading youtube videos.
I don't remember the other warnings. I will  start the computer and wait it for a little to see if something happen.
The absence of TDL3 from Combofix means clean install??
(Is there a license for Windows 7 Starter?  )
QuoteThe absence of TDL3 from Combofix means clean install??
No, Panos, it means that ComboFix didn't see TDL3 or it would have repaired it.  Plus, aswMBR would have specifically pointed it out if the TDL3 rootkit was on the computer.
Let's run through the other scans, starting with AdwCleaner.  Please download AdwCleaner by Xplode and save to your Desktop.
    Note:  Windows Vista, Windows 7/8 users right-click and select Run As Administrator.
  • Click the Scan button.
  • AdwCleaner will begin.  Be patient as the scan may take some time to complete.
  • After the scan has finished, click the Report button.  A logfile (AdwCleaner[R0].txt) will open in Notepad for review.
  • The  contents of the log file may be confusing. Unless you see a program name that you know should not be removed, don't worry about it. If you  see an entry you want to keep, please let me know about it.
  • A copy of all logfiles are saved in the C:\AdwCleaner folder which was created when running the tool.
Corrine,
I was using the laptop during the last hour, and it looks fine, except from being very very slow when using IE. Ofcourse I don't know how it was before. During the last hour no Eset warning came up. I have made some updates, removed ask bar from add ons in IE, and ran MBAM. Two objects refered to freecorder were removed. I am sorry I ran MBAM without your permission. I was almost sure that you would recommend a format! But ofcourse, you are Corrine!!!
Something I see in the computer is a program called oceanis change background. I tried to use it. It changes desktop's wallpaper. I searched and some people say that perhaps a malware can occure from this. What do you think?
I will be back with adwcleaner's log.
Adwcleaner log
(I DIDN'T CLICK CLEAN. ONLY REPORT.)
# AdwCleaner v3.012 - Report created 18/11/2013 at 22:41:27
# Updated 11/11/2013 by Xplode
# Operating System : Windows 7 Starter Service Pack 1 (32 bits)
# Username : user - USER-PC
# Running from : C:\Users\user\Desktop\AdwCleaner.exe
# Option : Scan
***** [ Services ] *****
File Found : C:\Windows\System32\Tasks\BackgroundContainer Startup Task
Folder Found C:\Program Files\Conduit
Folder Found C:\Program Files\Freecorder
Folder Found C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Freecorder
Folder Found C:\users\user\AppData\Local\Conduit
Folder Found C:\users\user\AppData\LocalLow\Conduit
Folder Found C:\users\user\AppData\LocalLow\Freecorder
Folder Found C:\users\user\AppData\LocalLow\PriceGong
Folder Found C:\users\user\Documents\Freecorder
***** [ Shortcuts ] *****
***** [ Registry ] *****
Key Found : HKCU\Software\AppDataLow\Software\Conduit
Key Found : HKCU\Software\AppDataLow\Software\Freecorder
Key Found : HKCU\Software\AppDataLow\Software\PriceGong
Key Found : HKCU\Software\AppDataLow\Software\smartbar
Key Found : HKCU\Software\AppDataLow\Toolbar
Key Found : HKCU\Software\Ask&Record
Key Found : HKCU\Software\Conduit
Key Found : HKCU\Software\Freecorder
Key Found : HKCU\Software\Microsoft\Internet Explorer\LowRegistry\DOMStorage\conduit.com
Key Found : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{AFDBDDAA-5D3F-42EE-B79C-185A7020515B}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{2E113159-BD8D-4DDB-83B8-C5E5FB6A111B}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{2E113159-BD8D-4DDB-83B8-C5E5FB6A111B}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{3C471948-F874-49F5-B338-4F214A2EE0B1}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
Key Found : HKLM\SOFTWARE\Classes\Conduit.Engine
Key Found : HKLM\SOFTWARE\Classes\protector_dll.protectorbho
Key Found : HKLM\SOFTWARE\Classes\protector_dll.protectorbho.1
Key Found : HKLM\SOFTWARE\Classes\Toolbar.CT1060933
Key Found : HKLM\Software\Conduit
Key Found : HKLM\Software\DeviceVM
Key Found : HKLM\Software\Freecorder
Key Found : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{00EE85F1-BD03-434F-861C-8ADD64906CEA}
Key Found : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{7326F7EE-B62C-4B8D-8D43-F9BE879DFA51}
Key Found : HKLM\SOFTWARE\Microsoft\Tracing\BingBar_RASMANCS
Key Found : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\BackgroundContainer Startup Task
Key Found : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{12FDD3F9-6B89-4DB1-B3C3-F6C4D061A7C1}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{2E113159-BD8D-4DDB-83B8-C5E5FB6A111B}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Freecorder Toolbar
Value Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Run [BackgroundContainer]
Value Found : HKLM\SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks [{1392B8D2-5C05-419F-A8F6-B9F15A596612}]
***** [ Browsers ] *****
-\\ Internet Explorer v10.0.9200.16736
AdwCleaner[R0].txt - [3561 octets] - [18/11/2013 22:41:27]
########## EOF - C:\AdwCleaner\AdwCleaner[R0].txt - [3621 octets] ##########
According to Prevx, it is safe.  From http://www.prevx.com/filenames/X1739755328300891982-X1/WALLPAPERAGENT.EXE.html
QuoteThe filename WALLPAPERAGENT.EXE is used by objects that are classified as safe. It has not yet been seen to be associated with malicious software.
I understand why you ran MBAM.  Yes, with AdwCleaner, I wanted to see what was in the log first before asking you to remove what was found.  Let's continue with the cleanup, particularly since there are leftovers of Ask and Freecoder as well as Conduit and other files that should be removed.
1.  Double-click AdwCleaner.exe to run the tool again.
  • AdwCleaner will begin to scan your computer like it did before.
  • This time click on the Clean button.
  • After rebooting, a logfile report (AdwCleaner[S0].txt) will open automatically.
2.  Please download Junkware Removal Tool to your desktop.
  • Run the tool by double-clicking it.  If you are using Windows Vista or Seven, right-mouse click it and select "Run as Administrator".
3.  In addition, let's see a fresh DDS log.
Good morning, Corrine.
I think that the news are not good.
1. The logs:
# AdwCleaner v3.012 - Report created 19/11/2013 at 09:52:53
# Option : Clean
Folder Deleted : C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Freecorder
Folder Deleted : C:\Program Files\Conduit
Folder Deleted : C:\Program Files\Freecorder
Folder Deleted : C:\users\user\AppData\Local\Conduit
Folder Deleted : C:\users\user\AppData\LocalLow\Conduit
Folder Deleted : C:\users\user\AppData\LocalLow\PriceGong
Folder Deleted : C:\users\user\AppData\LocalLow\Freecorder
Folder Deleted : C:\users\user\Documents\Freecorder
File Deleted : C:\Windows\System32\Tasks\BackgroundContainer Startup Task
  • Key Deleted : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Logon\{E59CEE2F-AE40-47B7-889C-F79862294F5A}
  • Key Deleted : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{E59CEE2F-AE40-47B7-889C-F79862294F5A}
    Key Deleted : HKCU\Software\Microsoft\Internet Explorer\LowRegistry\DOMStorage\conduit.com
    Value Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Run [BackgroundContainer]
    Key Deleted : HKLM\SOFTWARE\Classes\Conduit.Engine
    Key Deleted : HKLM\SOFTWARE\Classes\protector_dll.protectorbho
    Key Deleted : HKLM\SOFTWARE\Classes\protector_dll.protectorbho.1
    Key Deleted : HKLM\SOFTWARE\Microsoft\Tracing\BingBar_RASMANCS
    Key Deleted : HKLM\SOFTWARE\Classes\Toolbar.CT1060933
    Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{3C471948-F874-49F5-B338-4F214A2EE0B1}
    Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
    Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{2E113159-BD8D-4DDB-83B8-C5E5FB6A111B}
    Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
    Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
    Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{2E113159-BD8D-4DDB-83B8-C5E5FB6A111B}
    Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
    Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{2E113159-BD8D-4DDB-83B8-C5E5FB6A111B}
    Key Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{00EE85F1-BD03-434F-861C-8ADD64906CEA}
    Key Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{7326F7EE-B62C-4B8D-8D43-F9BE879DFA51}
    Key Deleted : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{AFDBDDAA-5D3F-42EE-B79C-185A7020515B}
    Value Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks [{1392B8D2-5C05-419F-A8F6-B9F15A596612}]
    Key Deleted : HKCU\Software\Ask&Record
    Key Deleted : HKCU\Software\Conduit
    Key Deleted : HKCU\Software\Freecorder
    Key Deleted : HKCU\Software\AppDataLow\Toolbar
    Key Deleted : HKCU\Software\AppDataLow\Software\Conduit
    Key Deleted : HKCU\Software\AppDataLow\Software\PriceGong
    Key Deleted : HKCU\Software\AppDataLow\Software\smartbar
    Key Deleted : HKCU\Software\AppDataLow\Software\Freecorder
    Key Deleted : HKLM\Software\Conduit
    Key Deleted : HKLM\Software\DeviceVM
    Key Deleted : HKLM\Software\Freecorder
    Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Freecorder Toolbar
    AdwCleaner[R0].txt - [3701 octets] - [18/11/2013 22:41:27]
    AdwCleaner[R1].txt - [3761 octets] - [19/11/2013 09:51:28]
    AdwCleaner[S0].txt - [3796 octets] - [19/11/2013 09:52:53]
    ########## EOF - C:\AdwCleaner\AdwCleaner[S0].txt - [3856 octets] ##########
    Junkware Removal Tool (JRT) by Thisisu
    Version: 6.0.8 (11.05.2013:1)
    OS: Windows 7 Starter x86
    Ran by user on Tue 11/19/2013 at  9:58:23.09
    ~~~ Services
    ~~~ Registry Values
    ~~~ Registry Keys
    ~~~ Files
    ~~~ Folders
    ~~~ Event Viewer Logs were cleared
    Scan was completed on Tue 11/19/2013 at 10:06:06.32
    End of JRT log
    2. DDS REPORTS
    DDS (Ver_2012-11-20.01) - NTFS_x86
    Internet Explorer: 10.0.9200.16736
    Run by user at 10:07:34 on 2013-11-19
    Microsoft Windows 7 Starter   6.1.7601.1.1252.1.1033.18.987.308 [GMT 2:00]
    ============== Running Processes ================
    C:\Windows\system32\wininit.exe
    C:\Windows\system32\lsm.exe
    C:\Windows\System32\DriverStore\FileRepository\stwrt.inf_x86_neutral_5576240ee6baaa25\STacSV.exe
    C:\Windows\system32\WLANExt.exe
    C:\Windows\system32\conhost.exe
    C:\Windows\System32\DriverStore\FileRepository\stwrt.inf_x86_neutral_5576240ee6baaa25\aestsrv.exe
    C:\Program Files\Microsoft\BingBar\BBSvc.EXE
    C:\Program Files\Microsoft\BingBar\SeaPort.EXE
    C:\Program Files\WIDCOMM\Bluetooth Software\btwdins.exe
    C:\SPLASH.SYS\config\DVMExportService.exe
    C:\Program Files\ESET\ESET Smart Security\ekrn.exe
    C:\Program Files\Intel\Intel Matrix Storage Manager\IAANTMon.exe
    C:\Windows\system32\Dwm.exe
    C:\Windows\System32\igfxtray.exe
    C:\Windows\System32\hkcmd.exe
    C:\Program Files\ESET\ESET Smart Security\egui.exe
    C:\Program Files\MCShield\MCShieldRTM.exe
    C:\Windows\system32\igfxsrvc.exe
    C:\Windows\system32\SearchIndexer.exe
    C:\Program Files\Hewlett-Packard\HP Health Check\hphc_service.exe
    C:\Windows\explorer.exe
    C:\Windows\System32\svchost.exe -k secsvcs
    C:\Windows\system32\svchost.exe -k bthsvcs
    BHO: Groove GFS Browser Helper: {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - c:\program files\microsoft office\office12\GrooveShellExtensions.dll
    BHO: Google Toolbar Helper: {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\google toolbar\GoogleToolbar_32.dll
    BHO: Bing Bar Helper: {d2ce3e00-f94a-4740-988e-03dc2f38c34f} -
    BHO: Windows 7 Starter Helper: {D381FF29-7CFB-4D4E-B92A-C4EDDC696614} - c:\program files\oceanis\systemsetting\StarterHelper.dll
    BHO: Java(tm) Plug-In 2 SSV Helper: {DBC80044-A445-435b-BC74-9C25C1C588A9} -
    TB: Bing Bar: {8dcb7100-df86-4384-8842-8fa844297b3f} -
    TB: Google Toolbar: {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\google toolbar\GoogleToolbar_32.dll
    uRun: [MCShield Monitor] c:\program files\mcshield\mcshieldrtm.exe
    mRun: [IgfxTray] c:\windows\system32\igfxtray.exe
    mRun: [HotKeysCmds] c:\windows\system32\hkcmd.exe
    mRun: [Persistence] c:\windows\system32\igfxpers.exe
    mRun: [egui] "c:\program files\eset\eset smart security\egui.exe" /hide /waitservice
    dRunOnce: [SPReview] "c:\windows\system32\spreview\SPReview.exe" /sp:1 /errorfwlink:"http://go.microsoft.com/fwlink/?LinkID=122915" /build:7601
    uPolicies-Explorer: NoDrives = dword:0
    mPolicies-Explorer: NoDrives = dword:0
    IE: E&xport to Microsoft Excel - c:\progra~1\micros~2\office12\EXCEL.EXE/3000
    IE: E&ξαγωγή στο Microsoft Excel - c:\progra~1\micros~2\office12\EXCEL.EXE/3000
    IE: Send image to &Bluetooth Device... - c:\program files\widcomm\bluetooth software\btsendto_ie_ctx.htm
    IE: Send page to &Bluetooth Device... - c:\program files\widcomm\bluetooth software\btsendto_ie.htm
    IE: {2670000A-7350-4f3c-8081-5663EE0C6C49} - {48E73304-E1D6-4330-914C-F5F514E3486C} - c:\program files\microsoft office\office12\ONBttnIE.dll
    IE: {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - c:\program files\skype\toolbars\internet explorer\skypeieplugin.dll
    IE: {92780B25-18CC-41C8-B9BE-3C9C571A8263} - {FF059E31-CC5A-4E2E-BF3B-96E929D65503}
    IE: {CCA281CA-C863-46ef-9331-5C8D4460577F} - c:\program files\widcomm\bluetooth software\btsendto_ie.htm
    DPF: {73ECB3AA-4717-450C-A2AB-D00DAD9EE203} - hxxp://h20614.www2.hp.com/ediags/gmd/Install/Cab/hpdetect118.cab
    TCP: NameServer = 192.168.10.254
    TCP: Interfaces\{6CA92D8C-9201-4E4A-8161-896CD2918CA2} : DHCPNameServer = 192.168.10.254
    TCP: Interfaces\{C9F65FDF-BEBB-443D-AB33-A065C2955EB8} : DHCPNameServer = 192.168.10.254
    Handler: grooveLocalGWS - {88FED34C-F0CA-4636-A375-3CB6248B04CD} - c:\program files\microsoft office\office12\GrooveSystemServices.dll
    Handler: skype-ie-addon-data - {91774881-D725-4E58-B298-07617B9B86A8} - c:\program files\skype\toolbars\internet explorer\skypeieplugin.dll
    Handler: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - c:\program files\common files\skype\Skype4COM.dll
    Notify: igfxcui - igfxdev.dll
    SSODL: WebCheck - <orphaned>
    SEH: Groove GFS Stub Execution Hook - {B5A7F190-DDA6-4420-B3BA-52453494E6CD} - c:\program files\microsoft office\office12\GrooveShellExtensions.dll
    R0 epfwwfp;epfwwfp;c:\windows\system32\drivers\epfwwfp.sys [2013-9-17 49240]
    R1 DVMIO;DVMIO;c:\splash.sys\config\dvmio.sys [2009-9-30 17624]
    R1 eamonm;eamonm;c:\windows\system32\drivers\eamonm.sys [2013-9-17 188808]
    R1 EpfwLWF;Epfw NDIS LightWeight Filter;c:\windows\system32\drivers\EpfwLWF.sys [2013-9-17 37416]
    R2 AESTFilters;Andrea ST Filters Service;c:\windows\system32\driverstore\filerepository\stwrt.inf_x86_neutral_5576240ee6baaa25\AEstSrv.exe [2012-1-31 81920]
    R2 BBSvc;Bing Bar Update Service;c:\program files\microsoft\bingbar\BBSvc.EXE [2011-10-21 196176]
    R2 BBUpdate;BBUpdate;c:\program files\microsoft\bingbar\SeaPort.EXE [2011-10-13 249648]
    R2 DvmMDES;DeviceVM Meta Data Export Service;c:\splash.sys\config\DVMExportService.exe [2009-7-9 323584]
    R2 ekrn;ESET Service;c:\program files\eset\eset smart security\ekrn.exe [2013-9-12 1337752]
    R3 btwl2cap;Bluetooth L2CAP Service;c:\windows\system32\drivers\btwl2cap.sys [2012-1-31 29472]
    R3 RTL8167;Realtek 8167 NT Driver;c:\windows\system32\drivers\Rt86win7.sys [2012-1-31 204288]
    S2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\microsoft.net\framework\v4.0.30319\mscorsvw.exe [2010-3-18 130384]
    S2 SkypeUpdate;Skype Updater;c:\program files\skype\updater\Updater.exe [2012-11-9 160944]
    S3 b57nd60x;Broadcom NetXtreme Gigabit Ethernet - NDIS 6.0;c:\windows\system32\drivers\b57nd60x.sys [2009-7-14 229888]
    S3 Com4QLBEx;Com4QLBEx;c:\program files\hewlett-packard\hp quick launch buttons\Com4QLBEx.exe [2009-12-11 228408]
    S3 netw5v32;Intel(R) Wireless WiFi Link 5000 Series Adapter Driver for Windows Vista 32 Bit;c:\windows\system32\drivers\netw5v32.sys [2009-6-10 4231168]
    S3 RSUSBSTOR;RtsUStor.Sys Realtek USB Card Reader;c:\windows\system32\drivers\RtsUStor.sys [2012-1-31 174592]
    S3 SrvHsfHDA;SrvHsfHDA;c:\windows\system32\drivers\VSTAZL3.SYS [2009-7-14 207360]
    S3 SrvHsfV92;SrvHsfV92;c:\windows\system32\drivers\VSTDPV3.SYS [2009-7-14 980992]
    S3 SrvHsfWinac;SrvHsfWinac;c:\windows\system32\drivers\VSTCNXT3.SYS [2009-7-14 661504]
    S3 TsUsbFlt;TsUsbFlt;c:\windows\system32\drivers\TsUsbFlt.sys [2012-2-12 52224]
    S3 yukonw7;NDIS6.2 Miniport Driver for Marvell Yukon Ethernet Controller;c:\windows\system32\drivers\yk62x86.sys [2009-7-14 311296]
    2013-11-19 07:58:19   --------   d-----w-   c:\windows\ERUNT
    2013-11-18 20:41:19   --------   d-----w-   C:\AdwCleaner
    2013-11-18 19:44:50   --------   d-----w-   c:\users\user\appdata\local\Programs
    2013-11-18 14:18:10   --------   d-sh--w-   C:\$RECYCLE.BIN
    2013-11-18 14:17:23   76288   ----a-w-   c:\windows\system32\drivers\usbccgp.sys
    2013-11-18 14:17:22   6016   ----a-w-   c:\windows\system32\drivers\usbd.sys
    2013-11-18 14:17:22   43008   ----a-w-   c:\windows\system32\drivers\usbehci.sys
    2013-11-18 14:17:22   284672   ----a-w-   c:\windows\system32\drivers\usbport.sys
    2013-11-18 14:17:22   258560   ----a-w-   c:\windows\system32\drivers\usbhub.sys
    2013-11-18 14:17:22   24064   ----a-w-   c:\windows\system32\drivers\usbuhci.sys
    2013-11-18 14:17:22   20480   ----a-w-   c:\windows\system32\drivers\usbohci.sys
    2013-11-18 12:59:22   98816   ----a-w-   c:\windows\sed.exe
    2013-11-18 12:59:22   256000   ----a-w-   c:\windows\PEV.exe
    2013-11-18 12:59:22   208896   ----a-w-   c:\windows\MBR.exe
    2013-11-18 12:56:07   2706432   ----a-w-   c:\windows\system32\mshtml.tlb
    2013-11-18 12:56:05   2877952   ----a-w-   c:\windows\system32\jscript9.dll
    2013-11-18 12:56:04   217600   ----a-w-   c:\program files\internet explorer\sqmapi.dll
    2013-11-18 12:56:04   108032   ----a-w-   c:\program files\internet explorer\jsdebuggeride.dll
    2013-11-18 12:56:02   61440   ----a-w-   c:\windows\system32\iesetup.dll
    2013-11-18 12:56:01   257536   ----a-w-   c:\program files\internet explorer\ieproxy.dll
    2013-11-18 12:56:00   236032   ----a-w-   c:\program files\internet explorer\IEShims.dll
    2013-11-18 12:55:59   71680   ----a-w-   c:\windows\system32\RegisterIEPKEYs.exe
    2013-11-18 12:55:59   109056   ----a-w-   c:\windows\system32\iesysprep.dll
    2013-11-18 12:55:55   817664   ----a-w-   c:\program files\common files\microsoft shared\vgx\VGX.dll
    2013-11-18 12:55:53   1767936   ----a-w-   c:\windows\system32\wininet.dll
    2013-11-18 12:55:51   770736   ----a-w-   c:\program files\internet explorer\iexplore.exe
    2013-11-15 08:12:51   --------   d-----w-   C:\18be667fae7b1dce1c
    2013-11-15 07:55:06   --------   d-----w-   c:\program files\ESET
    2013-11-15 07:52:57   71048   ----a-w-   c:\windows\system32\FlashPlayerCPLApp.cpl
    2013-11-15 07:05:22   1796096   ----a-w-   c:\windows\system32\authui.dll
    2013-11-15 07:05:21   168960   ----a-w-   c:\windows\system32\credui.dll
    2013-11-15 07:05:21   152576   ----a-w-   c:\windows\system32\SmartcardCredentialProvider.dll
    2013-11-15 07:04:49   247808   ----a-w-   c:\windows\system32\schannel.dll
    2013-11-15 07:04:48   369848   ----a-w-   c:\windows\system32\drivers\cng.sys
    2013-11-15 07:04:48   136640   ----a-w-   c:\windows\system32\drivers\ksecpkg.sys
    2013-11-15 07:04:47   67520   ----a-w-   c:\windows\system32\drivers\ksecdd.sys
    2013-11-15 07:04:46   1038848   ----a-w-   c:\windows\system32\lsasrv.dll
    2013-11-15 07:04:45   99840   ----a-w-   c:\windows\system32\sspicli.dll
    2013-11-15 07:04:45   220160   ----a-w-   c:\windows\system32\ncrypt.dll
    2013-11-15 07:04:44   22016   ----a-w-   c:\windows\system32\lsass.exe
    2013-11-15 07:04:43   22016   ----a-w-   c:\windows\system32\secur32.dll
    2013-11-15 07:04:43   15872   ----a-w-   c:\windows\system32\sspisrv.dll
    2013-11-15 07:03:52   305152   ----a-w-   c:\windows\system32\gdi32.dll
    2013-11-15 07:03:45   679424   ----a-w-   c:\windows\system32\IKEEXT.DLL
    2013-11-15 07:03:44   216576   ----a-w-   c:\windows\system32\FWPUCLNT.DLL
    2013-11-15 07:03:43   656896   ----a-w-   c:\windows\system32\nshwfp.dll
    2013-11-15 07:03:31   1168384   ----a-w-   c:\windows\system32\crypt32.dll
    2013-11-15 07:00:54   7796464   ----a-w-   c:\programdata\microsoft\windows defender\definition updates\{7b4cb518-7cbc-4dda-bbcd-2555709d48c4}\mpengine.dll
    2013-10-19 08:49:44   50053120   ----a-w-   c:\program files\GUT2DF4.tmp
    2013-09-17 13:17:38   49240   ----a-w-   c:\windows\system32\drivers\epfwwfp.sys
    2013-09-17 13:17:38   37416   ----a-w-   c:\windows\system32\drivers\EpfwLWF.sys
    2013-09-17 13:17:38   188808   ----a-w-   c:\windows\system32\drivers\eamonm.sys
    2013-09-17 13:17:38   174400   ----a-w-   c:\windows\system32\drivers\epfw.sys
    2013-09-17 13:17:38   134248   ----a-w-   c:\windows\system32\drivers\ehdrv.sys
    2013-09-14 00:48:58   338944   ----a-w-   c:\windows\system32\drivers\afd.sys
    2013-09-08 02:07:12   1294272   ----a-w-   c:\windows\system32\drivers\tcpip.sys
    2013-09-08 02:03:58   231424   ----a-w-   c:\windows\system32\mswsock.dll
    2013-09-03 11:35:12   238872   ------w-   c:\windows\system32\MpSigStub.exe
    2013-08-29 01:51:45   3969472   ----a-w-   c:\windows\system32\ntkrnlpa.exe
    2013-08-29 01:51:45   3914176   ----a-w-   c:\windows\system32\ntoskrnl.exe
    2013-08-29 01:50:30   1289096   ----a-w-   c:\windows\system32\ntdll.dll
    2013-08-29 01:50:16   619520   ----a-w-   c:\windows\system32\tdh.dll
    2013-08-29 01:48:17   640512   ----a-w-   c:\windows\system32\advapi32.dll
    2013-08-28 01:04:30   2348544   ----a-w-   c:\windows\system32\win32k.sys
    2013-08-28 00:57:20   434688   ----a-w-   c:\windows\system32\scavengeui.dll
    =================== ROOTKIT  ====================
    Stealth MBR rootkit/Mebroot/Sinowal/TDL4 detector 0.4.2 by Gmer, http://www.gmer.net
    Windows 6.1.7601 Disk: TOSHIBA_ rev.MH00 -> Harddisk0\DR0 -> \Device\Ide\IAAStorageDevice-0
    device: opened successfully
    user: MBR read successfully
    Disk trace:
    called modules: >>UNKNOWN [0x81A19000]<< >>UNKNOWN [0x86A10000]<< >>UNKNOWN [0x877C4000]<< >>UNKNOWN [0x868BA000]<< >>UNKNOWN [0x81E2C000]<< >>UNKNOWN [0x86B1F000]<<
    _asm { DEC EBP; POP EDX; NOP ; ADD [EBX], AL; ADD [EAX], AL; ADD [EAX+EAX], AL; ADD [EAX], AL;  }
    1 ntkrnlpa!IofCallDriver[0x81A4FBBA] -> \Device\Harddisk0\DR0[0x8506D3E8]
    \Driver\Disk[0x8506C138] -> IRP_MJ_CREATE -> 0x86A1439F
    3 [0x86A1459E] -> ntkrnlpa!IofCallDriver[0x81A4FBBA] -> [0x8462C700]
    \Driver\ACPI[0x83979030] -> IRP_MJ_CREATE -> 0x868C34CC
    5 [0x868C33D4] -> ntkrnlpa!IofCallDriver[0x81A4FBBA] -> \Device\Ide\IAAStorageDevice-0[0x845FB028]
    \Driver\iaStor[0x84602CB8] -> IRP_MJ_CREATE -> 0x86B6392E
    kernel: MBR read successfully
    _asm { XOR AX, AX; MOV SS, AX; MOV SP, 0x7c00; STI ; MOV ES, AX; MOV DS, AX; MOV SI, SP; MOV DI, 0x600; MOV CX, 0x200; CLD ; REP MOVSB ; JMP FAR 0x0:0x660;  }
    user & kernel MBR OK
    copy of MBR has been found in sector 2 !
    Warning: possible TDL3 rootkit infection !
    ============= FINISH: 10:09:07.18 ===============
    Install Date: 1/31/2012 3:16:27 PM
    System Uptime: 11/19/2013 9:53:41 AM (1 hours ago)
    Motherboard: Hewlett-Packard |  | 3660
    Processor: Intel(R) Atom(TM) CPU N450   @ 1.66GHz | CPU | 1666/667mhz
    C: is FIXED (NTFS) - 286 GiB total, 211.471 GiB free.
    D: is FIXED (NTFS) - 12 GiB total, 1.934 GiB free.
    E: is FIXED (FAT32) - 0 GiB total, 0.091 GiB free.
    RP198: 9/3/2013 11:03:44 AM - Windows Update
    RP199: 9/6/2013 1:40:11 PM - Windows Update
    RP200: 10/3/2013 4:07:01 PM - Windows Update
    RP201: 10/11/2013 7:57:33 PM - Windows Update
    RP202: 10/19/2013 11:07:02 AM - Windows Update
    RP203: 10/20/2013 5:22:56 PM - Windows Update
    RP204: 10/26/2013 9:43:12 AM - Windows Update
    RP205: 11/15/2013 8:59:17 AM - Windows Update
    RP206: 11/15/2013 9:32:08 AM - Removed Acrobat.com
    RP207: 11/15/2013 9:33:36 AM - Removed Adobe Reader 9.1 MUI.
    RP208: 11/15/2013 9:38:57 AM - Removed Java(TM) 6 Update 15
    RP210: 11/15/2013 9:41:12 AM - Windows Live Essentials
    RP211: 11/15/2013 9:42:00 AM - WLSetup
    RP212: 11/15/2013 9:52:00 AM - Installed ESET Smart Security
    RP213: 11/15/2013 10:11:29 AM - Windows Update
    RP214: 11/18/2013 2:54:47 PM - Windows Update
    RP215: 11/18/2013 9:42:28 PM - Windows Update
    Update for Microsoft Office 2007 (KB2508958)
    ΜΑΤΖΕΝΤΑ - Αγγλικό-Ελληνικό-Αγγλικό λεξικό όρων ιατρικών επιστη
    ActiveCheck component for HP Active Support Library
    Adobe Flash Player 11 ActiveX
    Adobe Shockwave Player
    ArcSoft WebCam Companion 3
    Bing Bar
    Broadcom 802.11 Wireless LAN Adapter
    CyberLink DVD Suite
    ESET Smart Security
    ESU for Microsoft Windows 7
    Finale 2009
    Freecorder 5
    Google Toolbar for Internet Explorer
    Google Update Helper
    Hewlett-Packard ACLM.NET v1.1.0.0
    HP CloudDrive
    HP Customer Experience Enhancements
    HP Games
    HP Integrated Module with Bluetooth wireless technology
    HP MediaStream
    HP Product Detection
    HP QuickSync
    HP QuickWeb
    HP Setup
    HP Support Assistant
    HP Update
    HP User Guides 0169
    HPAsset component for HP Active Support Library
    IDT Audio
    Intel(R) Graphics Media Accelerator Driver
    Intel® Matrix Storage Manager
    K-Lite Codec Pack 7.6.0 (Full)
    Malwarebytes Anti-Malware version 1.75.0.1300
    MCShield ::Anti-Malware Tool::
    Microsoft .NET Framework 4 Client Profile
    Microsoft Office 2007 Service Pack 3 (SP3)
    Microsoft Office Access MUI (English) 2007
    Microsoft Office Access Setup Metadata MUI (English) 2007
    Microsoft Office Enterprise 2007
    Microsoft Office Excel MUI (English) 2007
    Microsoft Office File Validation Add-In
    Microsoft Office Groove MUI (English) 2007
    Microsoft Office Groove Setup Metadata MUI (English) 2007
    Microsoft Office InfoPath MUI (English) 2007
    Microsoft Office OneNote MUI (English) 2007
    Microsoft Office Outlook MUI (English) 2007
    Microsoft Office PowerPoint MUI (English) 2007
    Microsoft Office Proof (English) 2007
    Microsoft Office Proof (French) 2007
    Microsoft Office Proof (Spanish) 2007
    Microsoft Office Proofing (English) 2007
    Microsoft Office Proofing Tools 2007 Service Pack 3 (SP3)
    Microsoft Office Publisher MUI (English) 2007
    Microsoft Office Shared MUI (English) 2007
    Microsoft Office Shared Setup Metadata MUI (English) 2007
    Microsoft Office Word MUI (English) 2007
    Microsoft Silverlight
    Microsoft Works
    MSXML 4.0 SP2 (KB954430)
    MSXML 4.0 SP2 (KB973688)
    Oceanis Change Background Windows 7
    Power2Go
    QLBCASL
    Realtek Ethernet Controller Driver For Windows Vista and Later
    Realtek USB 2.0 Card Reader
    Recovery Manager
    Security Update for CAPICOM (KB931906)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2518870)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2539636)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2572078)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2604121)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2633870)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2656351)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2656368)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2656368v2)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2656405)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2686827)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2729449)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2737019)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2742595)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2789642)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2804576)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2835393)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2840628)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2840628v2)
    Security Update for Microsoft .NET Framework 4 Client Profile (KB2858302v2)
    Security Update for Microsoft Office 2007 suites (KB2596744) 32-Bit Edition
    Security Update for Microsoft Office 2007 suites (KB2596754) 32-Bit Edition
    Security Update for Microsoft Office 2007 suites (KB2596792) 32-Bit Edition
    Security Update for Microsoft Office 2007 suites (KB2596825) 32-Bit Edition
    Security Update for Microsoft Office 2007 suites (KB2596871) 32-Bit Edition
    Security Update for Microsoft Office 2007 suites (KB2597969) 32-Bit Edition
    Security Update for Microsoft Office 2007 suites (KB2597973) 32-Bit Edition
    Security Update for Microsoft Office 2007 suites (KB2687309) 32-Bit Edition
    Security Update for Microsoft Office 2007 suites (KB2687439) 32-Bit Edition
    Security Update for Microsoft Office 2007 suites (KB2760411) 32-Bit Edition
    Security Update for Microsoft Office 2007 suites (KB2760415) 32-Bit Edition
    Security Update for Microsoft Office 2007 suites (KB2760585) 32-Bit Edition
    Security Update for Microsoft Office 2007 suites (KB2760591) 32-Bit Edition
    Security Update for Microsoft Office 2007 suites (KB2827326) 32-Bit Edition
    Security Update for Microsoft Office 2007 suites (KB2827329) 32-Bit Edition
    Security Update for Microsoft Office Excel 2007 (KB2827324) 32-Bit Edition
    Security Update for Microsoft Office InfoPath 2007 (KB2687440) 32-Bit Edition
    Security Update for Microsoft Office Outlook 2007 (KB2825644) 32-Bit Edition
    Security Update for Microsoft Office PowerPoint 2007 (KB2596764) 32-Bit Edition
    Security Update for Microsoft Office PowerPoint 2007 (KB2596912) 32-Bit Edition
    Security Update for Microsoft Office Publisher 2007 (KB2597971) 32-Bit Edition
    Security Update for Microsoft Office Word 2007 (KB2827330) 32-Bit Edition
    Skype Toolbars
    Skype™ 6.0
    Synaptics Pointing Device Driver
    Times Reader
    Total Uninstall 5.2.0
    Update for 2007 Microsoft Office System (KB967642)
    Update for Microsoft .NET Framework 4 Client Profile (KB2468871)
    Update for Microsoft .NET Framework 4 Client Profile (KB2533523)
    Update for Microsoft .NET Framework 4 Client Profile (KB2600217)
    Update for Microsoft .NET Framework 4 Client Profile (KB2836939)
    Update for Microsoft .NET Framework 4 Client Profile (KB2836939v3)
    Update for Microsoft Office 2007 Help for Common Features (KB963673)
    Update for Microsoft Office 2007 suites (KB2596620) 32-Bit Edition
    Update for Microsoft Office 2007 suites (KB2687493) 32-Bit Edition
    Update for Microsoft Office 2007 suites (KB2767849) 32-Bit Edition
    Update for Microsoft Office 2007 suites (KB2767916) 32-Bit Edition
    Update for Microsoft Office Access 2007 Help (KB963663)
    Update for Microsoft Office Excel 2007 Help (KB963678)
    Update for Microsoft Office Infopath 2007 Help (KB963662)
    Update for Microsoft Office OneNote 2007 Help (KB963670)
    Update for Microsoft Office Outlook 2007 (KB2687404) 32-Bit Edition
    Update for Microsoft Office Outlook 2007 Help (KB963677)
    Update for Microsoft Office Outlook 2007 Junk Email Filter (KB2825642) 32-Bit Edition
    Update for Microsoft Office Powerpoint 2007 Help (KB963669)
    Update for Microsoft Office Publisher 2007 Help (KB963667)
    Update for Microsoft Office Script Editor Help (KB963671)
    Update for Microsoft Office Word 2007 Help (KB963665)
    VLC media player 1.1.11
    Windows Driver Package - Broadcom Bluetooth  (06/15/2009 6.2.0.9000)
    Windows Driver Package - Broadcom Bluetooth  (07/30/2009 6.2.0.9405)
    Windows Driver Package - Broadcom HIDClass  (07/28/2009 6.2.0.9800)
    Windows Live Mesh ActiveX Control for Remote Connections
    Windows Live Sync
    WinRAR 4.10 (32-bit)
    3.LICENSE WINDOWS 7 STARTER ON HP MINI
    I found it. I took off the back cover and it is in there.
Hi, Panos.
Going back over your logs, note that TDSSKiller showed "user & kernel MBR OK".  When both the user & kernel MBR are OK, it is not considered an active MBR infection even if it indicates detected hooks/malicious code, which the log for your nephew's computer does not indicate.  TDSSKiller did not find any signs of TDL3 or TDL4, nor did ComboFix or aswMBR.  Both Dell and HP have a custom MBR for the recovery partition, which is likely why the MBR is identified as unknown.
The three files shown in TDSSKiller as "detected UnsignedFile.Multi.Generic" are all legitimate:
If you'd like to take it one step further, upload the MBR.dat [a copy of your MBR code created by aswMBR] here:  www.virustotal.com.
The file is located here:  C:\Users\user\Desktop\MBR.dat
I didn't understand which file is this, Corrine.
You mean the aswMBR log?
I don't know if it is something I deleted in my effort to make some space on the desktop. Nevertheless, I have all the logs in the usb stick.
Sorry I' m asking another stupid question: why the computer has 4 partitions (volumes)?  :D
It has:
C (NTFS)
HP TOOLS E (FAT32)
RECOVERY D (NTFS)
SYSTEM (NTFS)
What if I deleted them, leaving only C?
The file with the .dat extension, C:\Users\user\Desktop\MBR.dat.
No, no, no!  Do not delete the partitions!!!
D: is FIXED (NTFS) - 12 GiB total, 1.934 GiB free. = Recovery Partition
E: is FIXED (FAT32) - 0 GiB total, 0.091 GiB free. = HP Tools
