Windows 10 Insider Build Update
Started by Corrine, August 27, 2015, 08:50:02 PM
After announcing no new builds late yesterday afternoon, things changed and Build 16299.15 was released to the Fast Ring for PC last night:  Announcing Windows 10 Insider Preview Build 16299 for PC - Windows Experience BlogWindows Experience Blog:
QuoteUPDATE 10/2: We have released Windows 10 Insider Preview Build 16299.15 to Windows Insiders in the Fast ring. As we prepare to release the Windows 10 Fall Creators Update to the world on October 17th, we will now start testing out servicing this build with the Cumulative Updates via Windows Update.
Windows 10 Insider Preview Build 17017 for PC to both Fast Ring and Skip Ahead:  Announcing Windows 10 Insider Preview Build 17017 for PC - Windows Experience BlogWindows Experience Blog.
In addition to changes/fixes/, Cortana Collections are introduced in this build and management of apps that are configured to run at startup can be found in Settings > apps instead of Task Manager.
Windows Insider Preview Build 17025 for PC to both Fast Ring and Skip Ahead:  Announcing Windows 10 Insider Preview Build 17025 for PC - Windows Experience BlogWindows Experience Blog
Looking forward to these two fixes for Microsoft Edge:
QuoteWe fixed an issue resulting in Microsoft Edge taking an unexpectedly long time to load the new page after clicking on certain links, appearing hung.
We fixed an issue resulting in Microsoft Edge being unexpectedly slow to respond when tabbing through controls with certain third party screen readers active.
Windows Insider Preview Build 17035 Released to Fast & Skip Ahead Rings for PC:  Announcing Windows 10 Insider Preview Build 17035 for PC - Windows Experience BlogWindows Experience Blog
QuotePLEASE NOTE: Due to a bug that causes PCs with AMD processors to bugcheck during upgrading to current builds, we are blocking PCs with AMD processors from receiving this build. We are investigating and working to fix so we can remove this block.
New features and improvements documented in the blog post, along with a long list of fixes.
Known issues added to Build 17035:
  • ADDED 11/10: VPNs which use custom pop-up windows during connection attempts may fail to connect with error 720.
  • ADDED 11/10: Due to a bug that was introduced on this build, you may not receive all of your notifications from Cortana.  Reminders are unaffected by this bug, but you may not receive other  Cortana notifications that you are expecting. We are working to resolve  this issue and will release the fix in an upcoming flight.
  • ADDED 11/10: The Properties dialog for This PC in File Explorer isn't working and can't be invoked from the context menu.
  • ADDED 11/10: Network profiles might change  from Private to Public after upgrading. You can fix this in the  network's properties, however please note that the issue will occur  again after a reboot.
Windows Insider Preview Build 17040 Released to Fast & Skip Ahead Rings for PC: Announcing Windows 10 Insider Preview Build 17040 for PC - Windows Experience BlogWindows Experience Blog
NOTE: The block for AMD PCs is no longer in effect as of this flight.
Windows 10 Insider Preview Build 17063 for PC to Windows Insiders in the Fast & Skip Ahead Rings:  Announcing Windows 10 Insider Preview Build 17063 for PC - Windows Experience BlogWindows Experience Blog
Set aside a lot of time to read the blog post.  There are many, many, many changes/additions/improvements!
Known Issues updated for Build 17063:
  • ADDED 12/21: While  navigating through OOBE, some of the buttons in the pages may not  display correctly. In case of running into this, use the keyboard and  tab forward through the page's controls, or hover over blank areas of  the screen and buttons will be rendered in the process. This should  unblock you and allow you to continue through the OOBE flow.
  • ADDED 12/21: We are investigating reports that  Windows shows that it "needs activation" and trying to activate fails  after upgrading to Build 17063.
  • ADDED 12/21: Audio may not work in certain apps like Firefox after upgrading to Build 17063.
QuoteADDED 1/4/18: Some PCs will bugcheck (GSOD) when entering into Connected Standby.
ADDED 1/4/18: When you open Task View immediately after an upgrade, Timeline may not be visible. If you encounter this, wait 15-30min and try launching Task View again.
ADDED 1/4/18: We're investigating an issue where some Bluetooth devices don't work on this build and Device Manager shows error 43 for these drivers.
ADDED 1/4/18: The Settings app may crash on certain pages if the Settings window isn't big enough. Windows Update Settings is one of the pages impacted. If you're experiencing this, maximizing the Settings window (so it's full screen) will resolve it.
ADDED 1/4/18: In certain cases, USB devices with unreliable connections may cause bugchecks (GSOD) on PCs.
Windows 10 Insider Preview Build 17074 for PC to Windows Insiders in the Fast ring and for those who opted in to Skip Ahead. Announcing Windows 10 Insider Preview Build 17074 for PC - Windows Experience BlogWindows Experience Blog
Important Note:  The same block for AMD processors as explained here is also in place for this flight.
A long list of fixes & improvements plus new features in Edge including * Variable fonts * Notifications API for extensions * Vertical docking for DevTools * Push notification fixes * Credit card autofill * Extensions InPrivate * PDF/EPUB Improvement and moire.
QuoteUPDATE 1/18: Today we have released Windows 10 Insider Preview Build 17074.1002 to Windows Insiders in the Fast ring. This build is the same as the version of Build 17074 released last week with 2 additional fixes. We have fixed the issue causing AMD PCs to become unbootable – which means we have removed the block for AMD PCs we put in place last week. And we also fixed the issue causing certain devices to hang on the boot screen after upgrading if virtualization is enabled in the BIO
QuoteUPDATE 1/19: We have released Windows 10 Insider Preview Build 17074.1002 to Windows Insiders in the Slow ring.
Windows Insider Build 17083 for PC to Windows Insiders in the Fast ring and for those who opted in to Skip Ahead:  Announcing Windows 10 Insider Preview Build 17083 for PC - Windows Experience BlogWindows Experience Blog.
Windows 10 Insider Preview Build 17093 for PC to Windows Insiders in the Fast ring and for those who opted in to Skip Ahead:  Announcing Windows 10 Insider Preview Build 17093 for PC - Windows Experience BlogWindows Experience Blog
Among other changes:
QuoteWindows Security Improvements
Windows Defender is now Windows Security in Settings: We have renamed the settings page under Settings > Update & Security from "Windows Defender" to "Windows Security. This settings page has also been redesigned – putting emphasis on the various protection areas to keep you safe and secure on your PC.
Account Protection Pillar in Windows Defender: We've made it easier for users to protect their identity when signing in to Windows with the new Account Protection pillar in Windows Defender Security Center.  Account Protection will encourage password users to set up Windows Hello Face, Fingerprint or PIN for faster sign in, and will notify Dynamic lock users if Dynamic lock has stopped working because their phone or device Bluetooth is off.
Device Security Pillar in Windows Defender: We're giving you greater insight into the security features integrated in your Windows device. The Device Security page provides you with status reporting and management of security features built into your devices – including toggling features on to provide enhanced protections.
A few other changes include the addition of F11 to Microsoft Edge, changes to the Privacy Settings navigation and lots of changes/improvements.  Note, however the known issue:
QuoteWe have observed seeing longer-than-normal delays during install at the 88% mark. Some delays are as long as 90 minutes before moving forward. Please be patient as the install will complete successfully.
