Windows 10 Insider Build Update
Started by Corrine, August 27, 2015, 08:50:02 PM
Insider Preview Build 14383 for PC and Mobile Released to Fast Ring:  Announcing Windows 10 Insider Preview Build 14383 for PC and Mobile | Windows Experience Blog.
The blog post has a long list of fixes, particularly, "updates to the Quick Action area of Action Center will be preserved across upgrades."
A known issue that some have experienced:
QuoteIf you are seeing a notification pop-up once a day that started on 7/1 saying that your Windows evaluation copy expires on 7/15/2016, don’t worry â€" this is a superfluous dialog and your OS won’t expire.  The dialog will also go away soon.
Insider Preview Build 14385 released to Fast Ring for PC & Mobile:  Announcing Windows 10 Insider Preview Build 14385 for PC and Mobile | Windows Experience Blog.
QuoteSurprise! Today we are releasing Build 14385 for both PC and Mobile to Windows Insiders in the Fast ring. But wait â€" it’s the weekend!? We’re churning out builds like crazy and this one has a few hundred bug fixes we wanted to get out to Insiders as quickly as possible to help validate scenarios to make sure we are together building the best possible product.
Insider Preview Build 14388 released to Fast Ring for PC & Mobile:  Announcing Windows 10 Insider Preview Build 14388 for PC and Mobile | Windows Experience Blog.
See the blog post for Improvements & Fixes as well as known issues.
Insider Preview Build 14393 released to Fast Ring for PC & Mobile:  Announcing Windows 10 Insider Preview Build 14393 for PC and Mobile | Windows Experience Blog.
Edit to add:  Known issues for PC
QuoteWe are aware of certain cases in which Surface Books and Surface Pro 4’s may bugcheck (bluescreen) due to a camera driver issue. An updated driver will roll-out via Windows Update soon that will fix this.
For those on the Slow Ring, Windows 10 Insider Preview Build 14393 is being released today for PC and Mobile:  Announcing Windows 10 Insider Preview Build 14393 for PC and Mobile | Windows Experience Blog.
Cumulative Update released for Fast Ring Build 14393 to PC & Mobile.  Build version will be 14393,3
https://twitter.com/donasarkar/status/756605389077086208:
QuoteHey #WindowsInsiders we released a Cumulative Update (KB3176925) for 14393 PC+Mobile devices for Fast Ring. List of fixes will be in FB Hub.
From the Feedback Hub:
QuoteWe have released a Cumulative Update (KB3176925) to Windows 10 Insider Preview Build 14393 on PCs and Mobile devices which will bring the build number to 14393.3. This Cumulative Update includes a handful of fixes:
We have fixed an issue where keyboard input on some Windows tablet devices would not rotate to landscape normally.
We have fixed an issue that results in Windows Updates being delayed on systems with Connected Standby.
We have fixed a problem with text input with Korean Input Method Editor (IME) in some Store apps.
We fixed an issue causing Store apps to stop launching due to a licensing issue.
We have fixed an issue with apps that synchronize using DDE for inter-process communication.
Cumulative Update released for Fast Ring Build 14393 to PC & Mobile.  Build version will be 14393.5.
We have released a Cumulative Update (KB3176927) to Windows 10 Insider Preview Build 14393 on PCs and Mobile devices which will bring the build number to 14393.5. This Cumulative Update includes a handful of fixes:
We have improved reliability and performance of Microsoft Edge with AdBlock and LastPass extensions enabled. These extensions should continue to work after installing other extension updates from the Store.
We fixed an issue causing battery to drain due to runaway CPU processes while a device is idle. We also fixed a battery life issue due to the proximity sensor always running on some devices.
We fixed an issue where the Korean IME would not have the correct composition on some custom TSF3 edit controls on PC.
We fixed an issue where you might not be able to type in text into Search or some Store apps without having to restart the process.
https://support.microsoft.com/en-us/kb/3176927
Cumulative update released to Fast Ring for PC via Windows Update.  New Build version 14393.10.
Via Dona Sarkar:  https://twitter.com/donasarkar/status/760283668208201729
Edit Note:  Hours later, Dona updated the release information to include Slow and Release Preview Rings:  https://twitter.com/donasarkar/status/760348873344753667
In addition to the security updates released today, Cumulative Update Build 14393.67 was released for PC & Mobile to the in Fast, Slow, RP Rings.
via:  https://twitter.com/donasarkar/status/763119636485332992
Feedback Hub:
QuoteWe have released Cumulative Update (KB3176931) to Windows 10 Insider Preview Build 14393 on PCs and Mobile devices which will bring the build number to 14393.67. This Cumulative Update includes the same fixes as KB3176495 (Build 14393.51) with two additional fixes:
  • Addressed issue that causes significantly reduced battery life on Windows Phone when using Bluetooth with “Hey Cortana” feature enabled.
  • Addressed issue that prevents users from completing the out-of-box experience (OOBE) with a local account using Korean characters.
Insider Preview Build 14901 Released to Fast Ring for PC:  Announcing Windows 10 Insider Preview Build 14901 for PC | Windows Experience Blog.
NOTE: Because an updated device targeting needs to roll out, it may take a couple of hours for this build to show up.
QuoteKnown issues:
    Support for kernel debugging over 1394 has been removed, but will be available in an upcoming kit release. A work-around will be posted to the Debugging Tools for Windows Blog shortly.
    Adobe Acrobat Reader crashes when you try to launch it.
Insider Preview Build 14905 Released to Fast Ring for PC & Mobile:  Announcing Windows 10 Insider Preview Build 14905 for PC & Mobile | Windows Experience Blog.
QuoteKnown issues for PC
  • Support for kernel debugging over 1394 has been removed, but will be  available in an upcoming kit release. A work-around will be posted to  the Debugging Tools for Windows Blog shortly.
  • Adobe Acrobat Reader crashes when you try to launch it.
  • Cortana’s text to speech capabilities is not working in this build.  For example, Cortana won’t be able to read text messages out loud for  you, tell jokes, sing, or give verbal prompts.
  • When clicking on the power button on the Start menu, it closes the  Start menu without opening the flyout with restart/shutdown options  appearing. As a workaround â€" you can right-click on the Start button (or  WIN + X) and choose to shutdown via this menu instead.
  • Apps such as Yahoo Mail, Trivia Crack, Google and the Skype  Translator Preview app will crash in this build due to a compatibility  issue from a recent platform change.
  • The Settings app may crash on certain editions of Windows 10 when  navigating to different settings pages due to a missing .dll file. We  are working on getting this fixed soon.
Insider Preview Build 14915 Released to Fast Ring for PC & Mobile:  Announcing Windows 10 Insider Preview Build 14915 for PC and Mobile | Windows Experience Blog.
A few "known issues" in this release, such as Adobe Acrobat Reader still crashes when you try to launch it.  However, the release includes many improvements and fixes.  Of note is the change to Delivery Optimization:
QuoteWindows Insiders that have Delivery Optimization enabled will be able to download new Insider Preview builds, OS updates, and app updates from other PCs on their local network as well as from other PCs on the Internet.
See the blog post for complete details.
Additional known issues added:
ADDED 9/1 for PC: You will lose wireless network connectivity after upgrading to this build on a Surface Pro 1 or Surface Pro 2. See this forum thread for more information.
ADDED 8/31 for Mobil: You will be unable to download and install additional speech and language packs in this build.
Windows Insider Preview Build 14926 for PC & Mobile to Fast Ring:  Announcing Windows 10 Insider Preview Build 14926 for PC and Mobile | Windows Experience Blog.
Note:  If running old builds, please see the blog post about expiration dates.
Included in the lengthy list of fixes is that the Adobe Acrobat crashing issues has been fixed.   For those using Oracle VM VirtualBox, it will crash on launch after upgrading to this build.  As always, see the blog post for a complete list of fixes and issues.
