Windows 10 Insider Build Update
Started by Corrine, August 27, 2015, 08:50:02 PM
Insider Preview Build 15019 released to Fast Ring for PC:  Announcing Windows 10 Insider Preview Build 15019 for PC - Windows Experience BlogWindows Experience Blog
Gamers, be sure to read the blog post!
With Data Privacy tomorrow, it is fitting that the new privacy settings are included in this build.
QuoteIMPORTANT: The download progress indicator shown when downloading this build is currently broken under Settings > Update & security > Windows Update. It may look like you’re getting stuck at 0% or at other percentages. Ignore the indicator and be patient. The build should download fine and the installation should kick off. See this forum post for more details.
Insider Preview Build 15025 released to Fast Ring for PC:  Announcing Windows 10 Insider Preview Build 15025 for PC - Windows Experience BlogWindows Experience Blog
Quote[UPDATED] IMPORTANT: You may see “Initializing…” when attempting to download this build and the download progress indicator shown when downloading this build may seem broken under Settings > Update & security > Windows Update. It may look like you’re getting stuck at 0% or at other percentages. Ignore the indicator and be patient. The build should download fine, and the installation should kick off. See this forum post for more details
Insider Preview Build 15031 released to Fast Ring for PC:  Announcing Windows 10 Insider Preview Build 15031 for PC - Windows Experience BlogWindows Experience Blog.
Known issue regarding Bluetooth:
QuoteGoing to Settings > Devices will crash the Settings app. You will be unable to pair a Bluetooth device. Bluetooth quick actions from Action Center also does not work.
Some people may still run into the "Initializing" issue:
Windows Insider Build 15042 Released to Fast Ring for PC, Build 15043 for Mobile:  Announcing Windows 10 Insider Preview Build 15042 for PC and Build 15043 for Mobile - Windows Experience BlogWindows Experience Blog.
Note:  Due to a bug discovered before release, 32-bit PCs are  blocked from getting this build.
I'm happy to see the addition of a "Prompt to enable Flash in Microsoft Edge (PC)" instead of it being always enabled after allowing it once.
The “Initializing…” issue when attempting to download new builds as well as the download progress indicator appearing to be stuck at 0% or similar should no longer be issues.
See the referenced blog post for additional fixes/improvements as well as known issues.
Windows Insider Build 15046 Released to Fast Ring for PC:  Announcing Windows 10 Insider Preview Build 15046 for PC - Windows Experience BlogWindows Experience Blog
Definitely check out "Application Installation Control"!
Also note the Known issues, particularly that some Ps will fail to update a 71% and roll-back to the previous build.  See this forum post for details.
Windows Insider Build 15048 Released to Fast Ring for PC and Build 15047 for Mobile:  Announcing Windows 10 Insider Preview Build 15048 for PC and Build 15047 for Mobile - Windows Experience BlogWindows Experience Blog.
Bug fixes but that's not all.  In case you missed the original article published in tumblr, a fellow MVP pointed out this morning that it has also been added to the Insiders Blog.  If that wasn't enough, scroll to the bottom of the referenced blog post.  Oh my!!!
Windows Insider Build 15055 Released to Fast Ring for PC and Mobile:  Announcing Windows 10 Insider Preview Build 15055 for PC and Mobile - Windows Experience BlogWindows Experience Blog.
The build includes quite a few Microsoft Edge fixes.  In addition to the other known issues, note the following:
QuoteThere is a bug in this build that can cause a number of inbox apps to fail to launch (such as Store). If you run into this, you can reset the app by going to Settings > Apps > Apps & features > Store > Advanced Options and pressing the “Reset” button. which should allow you to use the app as normal.
Windows Insider Build 15058 Released to Fast Ring for PC:  Announcing Windows 10 Insider Preview Build 15058 for PC - Windows Experience BlogWindows Experience Blog
The new build includes a number of fixes.  Also note the known issue:
QuoteSome PCs may fail to update to Build 15002 and higher due to SYSTEM_PTE_MISUSE error.
Windows Insider Bu8ild 15060 Released to Fast Ring for PC:  Announcing Windows 10 Insider Preview Build 15060 for PC - Windows Experience BlogWindows Experience Blog
New/additional language packs are not available with this build.  In particular note the following from known issues:
QuoteIf your PC fails to install this build on reboot with the error 8024a112, reboot manually again. If your PC appears to hang during the reboot, power your PC off and back on and the install will proceed.
Windows Insider Build 15061 Released to Fast Ring for PC:  Announcing Windows 10 Insider Preview Build 15061 for PC - Windows Experience BlogWindows Experience Blog.
Some fixes and a repeat of the language pack, error 8024a112 from yesterday's build.
Windows Insider Buildr15063 Released to Fast Ring for PC and Mobile:  Announcing Windows 10 Insider Preview Build 15063 for PC and Mobile - Windows Experience BlogWindows Experience Blog.
Only two improvements/fixes for PC but quite a few for Mobile.  Be sure to check Known Issues.
Via Twitter, https://twitter.com/donasarkar/status/847862697324564481
QuoteHeads up #WindowsInsiders - Cumulative Update Build 15063.11 (KB4016250) for PC has been released to all rings https://aka.ms/qp5xz0 *
QuoteToday we are releasing a Cumulative Update Build 15063.11 (KB4016250) for PC to Windows Insiders in all rings. This Cumulative Update brings the following fixes:
  • We fixed an issue where on Surface devices, Bluetooth radio fails to re-enumerate during hibernate/resume.
  • We fixed an issue with McAfee Enterprise to prevent a system crash when the product driver is installed on build 15060 configured with Device Guard.
From the Feedback Hub Announcements:
New Cumulative Updates for Build 15063 release to all rings
Today we are releasing 2 new Cumulative Updates for PC Build 15063 as we prepare the Windows 10 Creators Update to begin rolling out to customers around the world on April 11th.
Cumulative Update Build 15063.13 (KB4016251) is being released to Windows Insiders in the Slow and Release Preview rings. This Cumulative Update includes the same fixes from Cumulative Update 15063.11 plus these additional fixes:
  • We fixed an issue where printer connections from clients running older versions of Windows (V3-XPS-based-drivers) failed to connect to clients running the Windows 10 Creators Update.
  • We fixed an issue where on some devices like the Surface Pro 3, the Windows audio device graph isolation would max out CPU utilization due to being stuck in an endless loop due to defective Realtek APOs.
Cumulative Update Build 15063.14 (KB4016252) is being released to Windows Insiders in the Fast ring. This Cumulative Updater includes the same fixes from Cumulative Update 15063.11 AND Cumulative Update 15063.13 (see above) plus this additional fix:
  • We fixed an issue where non-suspendable processes would suspend after waking a device.
Windows Insider Preview Build 16170 Released to the Fast Ring.  Also available for IT Pros is the new Windows Insider for Business path using corporate credentials to register.  Announcing Windows 10 Insider Preview Build 16170 for PC - Windows Experience BlogWindows Experience Blog
As usual, see the blog post for changes, fixes and, of course, known issues,
